  4. Test Coronavirus Statistics for ioBroker
adapter installationadapterentwicklungtesten
1.2k Beiträge 120 Kommentatoren 629.3k Aufrufe 94 Beobachtet
  • DutchmanD Dutchman
    Aktuelle Test Version 0.6.9
    Veröffentlichungsdatum 22-03-2021
    Github Link https://github.com/iobroker-community-adapters/ioBroker.coronavirus-statistics/blob/master/README.md
    NPM npm i ioBroker.coronavirus-statistics@latest
    Adapter to show Global Corona Virus information and current reports
    Coronavirus Live Statistics adapter for ioBroker
    There is no configuration required, after installation it will :
    • Receive global information world-wide and write it to "global_totals"
    • Create a folder for each country with all relevant information regarding COVID-19
    • Update the information every 15 minutes
    The following information is available :
    Datapoint Details
    active Amount of current infected people
    cases Amount of totally known cases
    casesPerOneMillion Amount of totally known cases per million citizen
    critical Amount of critical situation (Hospitalized)
    deaths Amount of current registered deaths
    deathsPerOneMillion Amount of current registered deaths per million citizen
    recovered Amount of totally known recovered cases
    todayCases New Cases by Today
    todayDeaths Amount of totally known people died today
    test Total number of covid-19 tests taken globally
    tests per one million counties Total number of covid-19 tests taken globally per one million
    Please be aware this adapter uses as much as possible up-to-date information but there can be an delay of several hours depending on the country's report.
    German Federal States : https://npgeo-corona-npgeo-de.hub.arcgis.com/ s
    Generic Source : https://coronavirus-19-api.herokuapp.com
    Advanced settings
    Option Description
    All Countries Get data for all countries World-Wide (Default: false)
    Continents Group total amounts by continent in seperate state (Default: false)
    Delete unused States Delete data when countries are deselected (Default: false)
    German counties Get counties data for Germany (Selected only, Default false)
    German federal states Get federal state data for Germany (Selected only, Default false)
    Get all German federal states Get federal state data for Germany (Default false)
    Get all German counties Get all counties data for Germany (Default false)
    For Germany only
    It's possible to get data for federal states (Bundesländer) and counties (Landeskreise).
    You can choose to recieve all data or just select specific regions in advanced settings.
    Please note : After activation the the adapter must run 1 time to get all federal states and counties before table loads !
    Add missing countries
    It may happen that countries are not recognized correctly because the API delivers some country names not ISO conform. In such a case you will get a warning message in the log, which looks like this
    coronavirus-statistics.0	2020-03-21 09:05:31.328	warn	(22937) Timor-Leste not found in lib! Must be added to the country name translator.
    Using the datapoint coronavirus-statistics.0.countryTranslator you can assign a country yourself. Look for the name of the corresponding country here:
    List with country names
    With the selected country name you have to create a JSON string and enter it in the datapoint coronavirus-statistics.0.countryTranslator.
    The JSON string then looks like this, for example:
    	"Cabo_Verde": "Cape Verde",
    	"Timor-Leste": "East Timor"
    As first value the name from the warning message must be taken from the log. The name of the country from the List with country names is then assigned to this.
    Changelog
    sigi234S
    sigi234S
    @Dutchman sagte in Test Coronavirus Statistics for ioBroker:
    COVID-19
    coronavirus-statistics.0	2020-03-16 13:29:07.148	error	at endReadableNT (_stream_readable.js:1145:12)
    coronavirus-statistics.0	2020-03-16 13:29:07.148	error	at IncomingMessage.emit (events.js:203:15)
    coronavirus-statistics.0	2020-03-16 13:29:07.148	error	at Object.onceWrapper (events.js:286:20)
    coronavirus-statistics.0	2020-03-16 13:29:07.148	error	at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\request\request.js:1076:12)
    coronavirus-statistics.0	2020-03-16 13:29:07.148	error	at Request.emit (events.js:198:13)
    coronavirus-statistics.0	2020-03-16 13:29:07.148	error	at Request.<anonymous> (C:\Program Files\iobroker\Test\node_modules\request\request.js:1154:10)
    coronavirus-statistics.0	2020-03-16 13:29:07.148	error	at Request.self.callback (C:\Program Files\iobroker\Test\node_modules\request\request.js:185:22)
    coronavirus-statistics.0	2020-03-16 13:29:07.148	error	at Request.request [as _callback] (C:\Program Files\iobroker\Test\node_modules\iobroker.coronavirus-statistics\main.js:51:26)
    coronavirus-statistics.0	2020-03-16 13:29:07.148	error	at JSON.parse (<anonymous>)
    coronavirus-statistics.0	2020-03-16 13:29:07.148	error	(14256) SyntaxError: Unexpected end of JSON input
    coronavirus-statistics.0	2020-03-16 13:29:07.148	error	(14256) uncaught exception: Unexpected end of JSON input
    • sigi234S sigi234
      COVID-19
      DutchmanD
      DutchmanD
      Dutchman
      @sigi234 sagte in Test Coronavirus Statistics for ioBroker:
      COVID-19
      das passiert wen die API nicht erreichbar ist, keine sorge nach 15 min probieren wir es nochmal.
      Ich spiele mit dem Gedanken direkt einen retry ein zu bauen aber denke mal 15 min ist ok damit die API auch nicht überlastet wird
      • DutchmanD
        DutchmanD
        Dutchman
        sollte mit 0.2.0 nicht mehr passieren
          Datapoint Details
          Advanced settings
          Option Description
          For Germany only
          Changelog
          sigi234S
          sigi234S
          @Dutchman
          Test:
          In der Land Liste sind undefinierbare Länder drinnen
          Wünsche:
          Ein DP als Table
          Land ein/aus blendbar
          Zahlen konfigurierbar
          DutchmanD K 2 Antworten Letzte Antwort
          • sigi234S sigi234
            @Dutchman
            Test:
            Wünsche:
            Ein DP als Table
            DutchmanD
            DutchmanD
            Dutchman
            Ein DP als Table
            gerne gitissue erstellen, kan ich es abarbeiten
            same here
            sie meinen ?
              Ein DP als Table
              same here
              sie meinen ?
              sigi234S
              sigi234S
              sie meinen ?
              Größe änderbar
              • sigi234S sigi234
                sie meinen ?
                Größe änderbar
                DutchmanD
                DutchmanD
                Dutchman
                sie meinen ?
                Größe änderbar
                welche Größe ?
                  sie meinen ?
                  Größe änderbar
                  welche Größe ?
                  sigi234S
                  sigi234S
                  sie meinen ?
                  Größe änderbar
                  welche Größe ?
                  • sigi234S sigi234
                    sie meinen ?
                    Größe änderbar
                    welche Größe ?
                    DutchmanD
                    DutchmanD
                    Dutchman
                    sie meinen ?
                    Größe änderbar
                    welche Größe ?
                    da bin ich raus @Bluefox war so nett die zu machen front-end ist nicht meine stärke
                      Datapoint Details
                      Advanced settings
                      Option Description
                      For Germany only
                      Changelog
                      sigi234S
                      sigi234S
                      @Dutchman
                      coronavirus-statistics.0	2020-03-16 15:18:59.329	info	(13556) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      coronavirus-statistics.0	2020-03-16 15:18:55.508	warn	(13556) State attribute definition missing for + updated
                      coronavirus-statistics.0	2020-03-16 15:18:50.119	info	(13556) starting. Version 0.2.0 in C:/Program Files/iobroker/Test/node_modules/iobroker.coronavirus-statistics, node: v10.16.3
                      • sigi234S sigi234
                        @Dutchman
                        Hallo, wie kann ich das Widget anwenden?
                        Erledigt, ein Neustart hat geholfen.
                        LatziL
                        LatziL
                        Latzi
                        Die Frage stellt sich mir auch, dummerweise hat ein Neustart mir nicht die Augen geöffnet. Kannst du mir bitte weiterhelfen?
                        • sigi234S sigi234
                          @Dutchman
                          @Dutchman
                          Habe das WARN auch
                          • LatziL Latzi
                            sigi234S
                            sigi234S
                            @Latzi sagte in Test Coronavirus Statistics for ioBroker:
                            • T
                              T
                              Tobias
                              Habt ihr auch ein Problem mit der Darstellung?
                              Unterste Zeile...
                              • T Tobias
                                Unterste Zeile...
                                sigi234S
                                sigi234S
                                @Tobias
                                CSS Font und Text
                                T 1Topf1 2 Antworten Letzte Antwort
                                • S
                                  S
                                  stimezo
                                  Forum Testing
                                  Kann man sich aber auch schnell selber basteln :-) :
                                  Christian
                                  sigi234S C P A 4 Antworten Letzte Antwort
                                  • S stimezo
                                    Christian
                                    sigi234S
                                    sigi234S
                                    @stimezo
                                    Kannst du die Icons zur Verfügung stellen?
                                    • sigi234S sigi234
                                      @stimezo
                                      S
                                      S
                                      stimezo
                                      Forum Testing
                                      @stimezo
                                      Per mail?
                                      Christian
                                      • sigi234S sigi234
                                        @Tobias
                                        CSS Font und Text
                                        T
                                        T
                                        Tobias
                                        @sigi234
                                        Danke. Da bin ich ja echt ein newbie...
                                          @Dutchman
                                          Habe das WARN auch
                                          DutchmanD
                                          DutchmanD
                                          Dutchman
                                          @Homoran sagte in Test Coronavirus Statistics for ioBroker:
                                          Habe das WARN auch
                                          fixed in 0.2.1
                                          33.2k
                                          84.3k
