5.8k Beiträge 156 Kommentatoren 5.9m Aufrufe 137 Beobachtet
    @SBorg
    root@IoBroker:~# nc
    Cmd line:
    SBorgS
    SBorgS
    SBorg
    #512
    @crunchip sagte in [Linux Shell-Skript] WLAN-Wetterstation:
    @SBorg
    root@IoBroker:~# nc
    Cmd line:
    😎 oder auch nicht. Da ist der Fehler. Dein Docker nutzt anscheinend eine ältere Version von "nc". Der kann dann wohl kein "-w"
    Versuch mal nc --help
    LG SBorg ( SBorg auf GitHub)
    • SBorgS SBorg
      @SBorg
      root@IoBroker:~# nc
      Cmd line:
      crunchipC
      crunchipC
      Developer Global Moderator Most Active Forum Testing
      #513
      @SBorg
      [v1.10-41+b1]
      connect to somewhere:   nc [-options] hostname port[s] [ports] ...
      listen for inbound:     nc -l -p port [-options] [hostname] [port]
      options:
              -c shell commands       as `-e'; use /bin/sh to exec [dangerous!!]
              -e filename             program to exec after connect [dangerous!!]
              -b                      allow broadcasts
              -g gateway              source-routing hop point[s], up to 8
              -G num                  source-routing pointer: 4, 8, 12, ...
              -h                      this cruft
              -i secs                 delay interval for lines sent, ports scanned
              -k                      set keepalive option on socket
              -l                      listen mode, for inbound connects
              -n                      numeric-only IP addresses, no DNS
              -o file                 hex dump of traffic
              -p port                 local port number
              -r                      randomize local and remote ports
              -q secs                 quit after EOF on stdin and delay of secs
              -s addr                 local source address
              -T tos                  set Type Of Service
              -t                      answer TELNET negotiation
              -u                      UDP mode
              -v                      verbose [use twice to be more verbose]
              -w secs                 timeout for connects and final net reads
              -C                      Send CRLF as line-ending
              -z                      zero-I/O mode [used for scanning]
      port numbers can be individual or ranges: lo-hi [inclusive];
      hyphens in port names must be backslash escaped (e.g. 'ftp\-data').
        @SBorg
        [v1.10-41+b1]
        options:
                -b                      allow broadcasts
                -h                      this cruft
                -u                      UDP mode
        SBorgS
        SBorgS
        SBorg
        #514
        @crunchip Zumindest hat er "w", aber eine andere Reihenfolge? Sollte zwar IMO egal sein, aber wenn sie es so schreiben...
        nc -l -p 55555 -v -w 1
        • SBorgS SBorg
          crunchipC
          crunchipC
          #515
          @SBorg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
          das gleiche, no connection
            SBorgS
            SBorgS
            SBorg
            #516
            Erklärt warum es bei dir nur mit "p" läuft. Ev, gibt es noch mehr Unterschiede. Installiere doch mal versuchsweise den netcat-openbsd
            • SBorgS SBorg
              crunchipC
              crunchipC
              #517
              netcat-openbsd
              hab ich gemacht
              mit nc -l -p 55555 -v -w 1 kommen auch nun die werte👍
                netcat-openbsd
                hab ich gemacht
                SBorgS
                SBorgS
                SBorg
                #518
                @crunchip Puuuhhh, schwere Geburt 😁
                Jetzt müsste dann auch bei dir die V1.0.0 laufen :)
                ...und Jahresregenmenge funktioniert nun schon den 3. Tag hintereinander. Heute wird es nix werden, strahlender Sonnenschein und 0mm Regen 🤘
                • SBorgS SBorg
                  crunchipC
                  crunchipC
                  #519
                  @SBorg
                  allerdings....aber Dank deiner Hilfe 😊 👍
                  probiere ich gleich aus, aber ich befürchte, ich hab schon wieder das Problem, das 2mal ausgeführt wird,....hab ich zumindest vorhin gesehen.
                  aber ich schmeiss jetzt erst mal das neu script drauf und hoffe das jetzt Daten kommen
                  oder liegt mein Fehler im Cron anlegen?
                  Script liegt ja in /home/iobroker....also user iobroker
                  den Cron hab ich aber als root angelegt, oder muss ich mich dafür als user iobroker anmelden?
                  Script läuft und auch kein Kommunikationsfehler mehr
                  • SBorgS SBorg
                    @Nashra Hmm, er will es als "String" loggen, obwohl er eine Zahl (float) erkannt hat.
                    Sind die zwei Datenpunkte wirklich als "Zahl" angelegt?
                    NashraN
                    NashraN
                    Nashra
                    schrieb am zuletzt editiert von Nashra
                    #520
                    Ja sind als Zahl.
                    Gruß Ralf
                      @SBorg
                      SBorgS
                      SBorgS
                      SBorg
                      #521
                      Ne du, da war/ist schon alles korrekt, ich habe mich auch zum Teil verguckt :(
                      Es gibt quasi ein korrektes 2x laufen und ein doppelt laufen. Hä...?!?
                      Doppelt laufen im Sinne von zwei mal gestartet, dies wäre falsch. Aber das Skript läuft "scheinbar" trotzdem doppelt.
                      Einmal das "echte" Skript und dann noch quasi ein Zombie. Das ist aber nichts weiter als die wetterstation.sub, die Funktionen für das Skript bereitstellt. Da hier aber auf das Datenpaket der Station gewartet wird, sieht es fast so aus als würde es dauernd laufen. Dies kann man daran erkennen, dass die sog. VSZ gleich ist (weiß):
                      Im gelben Rahmen sieht man dann, dass ich am 15.03. das Skript gestartet habe und um 13:16 Uhr den ps -aux | grep wetter, der dann zur gleichen Zeit den "Zombie" erwischt hat.
                      Würde ich ihn aktuell (13:38 Uhr) erneut ausführen, wäre VSZ mit "11940" gleich, Startzeit des Skriptes wäre immer noch 15.03., aber "grep + Zombie" stünden auf 13:38
                      Trifft man genau die halbe Sekunde die er zum verarbeiten des empfangenen Datenpakets von der Wetterstation braucht, läuft dann tatsächlich nur das Skript.
                      • SBorgS SBorg
                        crunchipC
                        crunchipC
                        #522
                        @SBorg hehe, genau das meinte ich hier, auf die Frage...wo kommt die ...Uhrzeit her
                        vielen Dank, für die ausführliche Erklärung, hätt ich mir das Stundenlange (Suche den Fehler) sparen können😂 😂
                        Werte für javascript.0.Wetterstation._Kommunikationsfehler läuft nun auch wie es soll, außer einmal Nachts 00:17, fehlte einmal ein Wert, so wie ich das sehe
                        • NashraN Nashra
                          Ja sind als Zahl.
                          SBorgS
                          SBorgS
                          SBorg
                          #523
                          @Nashra Da er bei dir eh nix in die Influx geloggt hat, kannst du die beiden Serien auch mal droppen. Die werden dann beim nächsten speichern eines Wertes neu angelegt.
                          Im Terminal:
                          1. influx
                          2. show databases
                          3. use blabla
                          4. show series
                          5. select * from "javascript.0.Wetterstation.Regen_Monat"
                            5.1 drop series from "javascript.0.Wetterstation.Regen_Monat"
                          6. exit
                          zu 1: kann uU etwas dauern bis was passiert
                          zu 2: deinen Datenbanknamen merken (ich nehme mal blabla)
                          zu 4: zeigt nun alle Datenreihen an (ich gehe mal von javascript.0.Wetterstation.Regen_Monat aus)
                          zu 5: Anführungszeichen müssen wg. der Punkte im Namen sein, zeigt nun die Messreihe an
                          zu 5.1: Dies löscht nun die kpl. Serie !
                            SBorgS
                            SBorgS
                            SBorg
                            #524
                            @crunchip 😖 😞 🙄 😁 😇 😂
                            IMO nicht, da steht ja influxdb.0
                            Ein Komm-Fehler würde ebenfalls als simple-api.0 auftauchen, da ich ja den Wert vom Skript aus in den DP schreibe. Um 0:17 hat er dann false in die Influx-Datenbank geschrieben. Du hast bestimmt eine ähnliche Konfig:
                            Damit schreibe ich zwar nur jede Änderung in die Influx, bekäme aber wenn es >24h ohne Fehler läuft unter Grafana ein "No data" (bei 24h Zeitraum). Könnte man zwar mit "value to text" ev. um mappen, aber wayne (zumindest mich nicht :) ) stört es 2 Werte pro 24h zu schreiben. Ich logge den sowieso nur 3 Tage. "Was juckt es die Eiche..." wenn ich einen Fehler vor 3 Wochen hatte...
                            • SBorgS SBorg
                              crunchipC
                              crunchipC
                              #525
                              @SBorg ja hab es ähnlich, alla 30 min, ist meine Standard Einstellung in Influx, deshalb hatte nen Denkfehler🤦 , genau falsch rum gedacht, alles gut😊
                              • S
                                S
                                skokarl
                                #526
                                so, da mein Geburtstag naht, und ich hoffe überrascht zu werden, 😁
                                ... gibt es hier eigentich schon jemand der mal seine View zur Verfügung stellen will ?
                                Würde ich mir gerne schonmal ansehen.
                                • S skokarl
                                  crunchipC
                                  crunchipC
                                  #527
                                  @skokarl 2 sind im ersten Beitrag verlinkt
                                    GlasfaserG
                                    GlasfaserG
                                    #528
                                    @crunchip
                                    Wer ließ sich denn hier 527 Beiträge durch und dann noch vom ersten Beitrag ab :)😙
                                    @skokarl
                                    Na ... wann ist denn dein Geburtstag , damit wir hier alle eine Wetterprogrose auch an dem Tag durchführen können 😜
                                    • GlasfaserG Glasfaser
                                      @crunchip
                                      @skokarl
                                      crunchipC
                                      crunchipC
                                      #529
                                      @Glasfaser sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                                      Na jeder der es nutzen möchte😁 , ausserdem ist doch eigens dafür extra dieser Thread gemacht worden, mit einem Mausklick😛 , aktuell sein
                                      • S
                                        S
                                        skokarl
                                        #530
                                        Ich hatte das doch auch schon alles gelesen 😬 ...... lese doch schon lange hier mit,
                                        aber war das nicht so, dass die Bilder anfangs nicht verlinkt waren ?
                                        Glaube @Glasfaser hat immer noch nicht verlinkt ... 😀
                                        Trotzdem Danke, dann muss ich mich noch um den provisorischen Mast fürs Wochenende kümmern ....😀
                                        p.s. die beiden Views sehen super aus.
                                        • S skokarl
                                          crunchipC
                                          crunchipC
                                          #531
                                          @skokarl sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                                          des wird bestimmt dein Geburtstagsgeschenk, der Rest muss dann warten bis Weihnachten: 😂
                                          33.2k
                                          84.4k
