  4. JavaScript
  5. Hilfe bei RSS-feed benötigt !
426 Beiträge 13 Kommentatoren 105.3k Aufrufe 13 Beobachtet
  • sigi234S sigi234
    @J-A-R-V-I-S
    Ja, bekomme aber immer das:
    javascript.0	2020-01-30 14:21:20.466	error	(2172) at endReadableNT (_stream_readable.js:1145:12)
    javascript.0	2020-01-30 14:21:20.466	error	(2172) at IncomingMessage.emit (events.js:203:15)
    javascript.0	2020-01-30 14:21:20.466	error	(2172) at Object.onceWrapper (events.js:286:20)
    javascript.0	2020-01-30 14:21:20.466	error	(2172) at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\request\request.js:1083:12)
    javascript.0	2020-01-30 14:21:20.466	error	(2172) at Request.emit (events.js:198:13)
    javascript.0	2020-01-30 14:21:20.466	error	(2172) at Request.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\request\request.js:1161:10)
    javascript.0	2020-01-30 14:21:20.466	error	(2172) at Request.self.callback (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\node_modules\request\request.js:185:22)
    javascript.0	2020-01-30 14:21:20.466	error	(2172) at Request.request [as _callback] (script.js.Eigene_Datenpunkte.RSS.Feuerwehr1:47:27)
    javascript.0	2020-01-30 14:21:20.466	error	(2172) at JSON.parse (<anonymous>:null:null)
    javascript.0	2020-01-30 14:21:20.466	error	(2172) script.js.Eigene_Datenpunkte.RSS.Feuerwehr1: SyntaxError: Unexpected end of JSON input
    javascript.0	2020-01-30 14:21:20.409	info	(2172) script.js.Eigene_Datenpunkte.RSS.Feuerwehr1: registered 0 subscriptions and 0 schedules
    javascript.0	2020-01-30 14:21:20.407	info	(2172) Start javascript script.js.Eigene_Datenpunkte.RSS.Feuerwehr1
    javascript.0	2020-01-30 14:21:20.400	info	(2172) Stop script script.js.Eigene_Datenpunkte.RSS.Feuerwehr1
    Skript:
    const request = require('request');
    const fwArray = ['FF Pucking-Hasenufer', 'FF Freindorf '];
    const dpObj = {};
    const neuerAlarm = 'javascript.0.Feuerwehr2.neuerAlarm';
    const alarme = 'javascript.0.Feuerwehr2.alarme';
    let DP = "javascript.0.Feuerwehr2";
    //Datenpunkt anlegen
    createState(DP+'.neuerAlarm', '', { name: "Feuerwehreinsatzmeldungen", type: "boolean", role: "state" });
    createState(DP+'.alarme', '', { name: "neue Meldung", type: "string", role: "state" });
    request('http://intranet.ooelfv.at/webext2/rss/json_laufend.txt', (err, res, body) => {
    if(err || res.statusCode != 200) {
        log(body, 'error');
        return;
    const obj = JSON.parse(body);
    const einsaetze = obj.einsaetze;
    const einsatzCount = obj.cnt_einsaetze;
    for(let i = 0; i < einsatzCount; i++) {
        const einsatz = einsaetze[i].einsatz;
        const feuerwehren = einsatz.feuerwehrenarray;
        const feuerwehrCount = Object.keys(feuerwehren).length;
        for(let j = 0; j < feuerwehrCount; j++) {
            const feuerwehr = feuerwehren[j];
            for(let k = 0; k < fwArray.length; k++) {
                if(feuerwehr.fwname == fwArray[k]) {
                    dpObj[einsatz.num1] = {id: einsatz.num1, alarmstufe: einsatz.alarmstufe};
    const oldState = JSON.parse(getState(alarme).val);
    let newAlarm = false;
    if(oldState && Object.keys(oldState).length == Object.keys(dpObj).length) {
        for(let key in dpObj) {
            if(dpObj[key].id == oldState[key].id) {
                continue;
            } else newAlarm = true;
        setState(neuerAlarm, newAlarm);
    setState(alarme, JSON.stringify(dpObj));
    Irgend etwas das stimmt mit dem Code einfügen nicht.
    J.A.R.V.I.S.J Offline
    J.A.R.V.I.S.
    #103
    @sigi234 schau mal bitte, was in dem DP "alarme" drinsteht. Das Skript kann den Inhalt nicht parsen.
    • J.A.R.V.I.S.J J.A.R.V.I.S.
      sigi234S Online
      sigi234S Online
      #104
      @J-A-R-V-I-S sagte in Hilfe bei RSS-feed benötigt !:
        "from": "system.adapter.javascript.0",
        "user": "system.user.admin",
        "ts": 1580248014195,
        "common": {
          "name": "neue Meldung",
          "type": "string",
          "role": "state"
        "native": {
          "type": "string",
          "role": "state"
        "acl": {
          "object": 1636,
          "owner": "system.user.admin",
          "state": 1636
        "_id": "javascript.0.Feuerwehr2.alarme",
        "type": "state"
      Alle DP bleiben leer.
      Rot: Skript von @SBorg - funtioniert
      Grün: Skript von @J-A-R-V-I-S - Fehler
      J.A.R.V.I.S.J 1 Antwort Letzte Antwort
      • sigi234S sigi234
          "common": {
            "type": "string",
            "role": "state"
          "native": {
            "type": "string",
            "role": "state"
          "acl": {
            "object": 1636,
            "state": 1636
          "type": "state"
        J.A.R.V.I.S.
        #105
        @sigi234 dann füg mal testweise folgende Zeile unterhalb von createState ein:
        setState(DP + '.alarme', '{}');
          sigi234S Online
          sigi234S Online
          #106
          Jetzt kommt was:
          {"E200102990":{"id":"E200102990","alarmstufe":1}}
          true
          • sigi234S sigi234
            Jetzt kommt was:
            true
            J.A.R.V.I.S.
            schrieb am zuletzt editiert von J.A.R.V.I.S.
            #107
            @sigi234 sehr gut. Dann versuch mal Folgendes:
            ersetzen durch
            const oldState = (getState(alarme).val) ? JSON.parse(getState(alarme).val) : {};
              ersetzen durch
              sigi234S Online
              sigi234S Online
              #108
              ersetzen durch
              Das selbe wie vorher.
              • sigi234S sigi234
                ersetzen durch
                J.A.R.V.I.S.
                #109
                @sigi234 dann nimm mal die createState raus, du hast die DPs ja schon. Dann lass einmal etwas reinschreiben, dann sollte das soweit passen.
                  sigi234S Online
                  sigi234S Online
                  #110
                  Danke, geht. Wie kann ich den DP javascript.0.Feuerwehr2.alarme als Table ausgeben?
                  • ? Offline
                    #111
                    Darf ich mich bei euch mal kurz dranhängen?
                    Ich versuche im Moment lediglich die Darstellung eines RSS-Feeds in meiner Vis.
                    Mit dem Script aus den ersten Posts kann ich auch schon meine Meldungen im Log sehen, allerdings habe ich noch Probleme mit dem Umlauten Ä, Ö, Ü...
                    wie habt ihr das gelöst?
                    (mein Feed: https://ticker.mvg.de/)
                      SBorgS Offline
                      SBorgS Offline
                      SBorg
                      #112
                      @Supaamensch Fällt mir aktuell gerade nichts ein. Lösung braucht es eigentlich keine, da es mit den Umlauten normalerweise "einfach" funktioniert. Der Feed hat sie korrekt und der RSS-Parser kann sie auch korrekt handeln. Bliebe eigentlich nur das System selbst auf dem das Skript läuft, dass dessen Länderumgebung bspw. auf Englisch oä. steht?
                      LG SBorg ( SBorg auf GitHub)
                      • SBorgS SBorg
                        #113
                        @SBorg Habe es auf 2 Systemen getestet, einmal ein Mac als Host und einmal Windows als Host, beide mit deutscher Spracheinstellung.
                        ioBroker steht bei beiden auch auf Deutsch.
                        Woran kann das sonst noch liegen?
                        Edit: Fällt mir gerade ein, ich verarbeite an anderer Stelle auch einen JSON-String, da passt es mit den Umlauten, kann also ja eigentlich kaum am System liegen, oder?
                          SBorgS Offline
                          SBorgS Offline
                          SBorg
                          #114
                          @Supaamensch Eben ausprobiert, bei mir funktioniert es:
                          Nimm mal dieses JS:
                          let Parser = require('rss-parser');
                           let parser = new Parser({
                              xml2js: { emptyTag: '--EMPTY--', },
                              maxRedirects: 50,
                              timeout: 60000,
                              customFields: { item: [['description','description', {keepArray: true}],] }
                          (async () => {
                            let feed = await parser.parseURL('https://ticker.mvg.de/');
                            console.log(feed.title);
                            feed.items.forEach(item => {
                              console.log(item.title + ':' + item.link + " " + item.description)
                          • SBorgS SBorg
                            Nimm mal dieses JS:
                                maxRedirects: 50,
                                timeout: 60000,
                            (async () => {
                            #115
                            @SBorg Tatsache, jetzt klappt's hier auch!
                            Vielen Dank
                            • S salmi
                              Liebe Forumgemeinde,
                              ich habe schon einiges versucht um meine Idee hinzubekommen, aber leider ohne erfolg.
                              Ich bin Mitglied in einer Feuerwehr in Oberösterreich und ich würde gerne mein Smarthome bei Einsatz steuern können.
                              Es wird ein RSS-Feed http://intranet.ooelfv.at/webext2/rss/rss_laufend.xml zur Verfügung gestellt wo die Einsäte in OÖ aufgelistet sind, dieses würde ich gerne nutzen auf meine Feuerwehr filtern und wenn ein Einsatz anliegt soll ein Datenpunkt erstellt werden (abfrage alle 1 Minuten). Diesen Datenpunkt kann ich ja dann abgreifen und zum beispiel das Licht einzuschalten und das Garagentor zu öffnen und so weiter.
                              Könnte mir hier wer behilflich sein um ein solches Skipt zu erstellen. Würde euch sehr dankbar sein.
                              Freundliche Grüße
                              Stefan
                              sigi234S Online
                              sigi234S Online
                              #116
                              @salmi
                              @SBorg
                              @J-A-R-V-I-S
                              https://forum.iobroker.net/topic/31294/test-adapter-rssfeed-v0-0-x
                              • NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                #117
                                @SBorg
                                @J-A-R-V-I-S
                                Sigi hat mich auf diesen Thread gebracht. :)
                                Toll was ihr hier wieder geschafft habt.
                                Leider habe ich nach den 116 Beiträgen den Überblick verloren, welches Script nun das finale ist.
                                Ich denke das von @J-A-R-V-I-S mit der Möglichkeit mehrere FFs einzutragen.
                                Oder hat @sigi234 das finale Script, da in den letzten Beiträgen noch viel probiert wurde?
                                Wäre toll, wenn jemand das endgültige Script (mehrere FFs und DP für gerade ein Einsatz) hier kurz reinstellen könnte! :)
                                ° Fixer ---> iob fix
                                • NegaleinN Negalein
                                  @SBorg
                                  @J-A-R-V-I-S
                                  OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  #118
                                  @negalein
                                  Kennst du meinen Adapter rssfeed?
                                  Der ruft automatisch feeds in verschiedenen Standards ab und vereinheitlicht diese.
                                  Für vis gibt es fertige Widgets für die Anzeige, welche He sich aber auch noch individuell anpassen lässt.
                                  https://forum.iobroker.net/topic/31294/test-adapter-rssfeed-v0-0-x?_=1628281401617
                                  Meine Adapter und Widgets
                                  Links im Profil
                                  • OliverIOO OliverIO
                                    @negalein
                                    NegaleinN Offline
                                    NegaleinN Offline
                                    Negalein
                                    #119
                                    @oliverio sagte in Hilfe bei RSS-feed benötigt !:
                                    Nein, kannte ich noch nicht.
                                    Der liest RSS aus und bereitet sie für VIS auf?
                                    Einen DP um zB Alexa zu startet bekommt man da auch?
                                      OliverIOO Offline
                                      OliverIOO Offline
                                      OliverIO
                                      #120
                                      @negalein sagte in Hilfe bei RSS-feed benötigt !:
                                      ich seh jetzt nicht so die Verbindung zwischen einem rss-feed und alexa.
                                      rss wird ja vorwiegend für Nachrichten verwendet.
                                      Der Adapter sorgt für den Abruf und speichert die daten unabhängig vom ursprungsformat (rss,atom rdf) als json in einem datenpunkt. gerne kannst du die daten in einem skript weiter verarbeiten oder auf die aktualsisierung des datenpunktes reagieren. wobei da hab ich festgestellt, dass einige feed provider zwar das "last updated" ändern aber nicht wirklich neue inhalte liefern.
                                      du kannst natürlich dann beliebig auf die aktualisierung reagieren und ggfs das auch in alexa ansagen lassen.
                                      Für vis gibt es diverse widgets
                                      zur darstellung eines feeds oder auch zur
                                      Aggregation mehrerer feeds in eine, sagen wir mal timeline
                                      oder auch als laufband
                                      einfach mal ausprobieren.
                                      http://www.tagesschau.de/xml/rss2
                                      https://www.spiegel.de/schlagzeilen/tops/index.rss
                                      https://www.hoerzu.de/rss/tipp/spielfilm/
                                      die ausgabe des rssfeeds lässt sich über eine templatesprache beliebig ausgeben lassen.
                                      Links im Profil
                                      • NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        #121
                                        In diesem Fall hier schon.
                                        Bei einem Feuerwehreinsatz ist es nützlich zB auch über Alexa, Google, Licht, usw. informiert zu werden.
                                        OliverIOO sigi234S 2 Antworten Letzte Antwort
                                          OliverIOO Offline
                                          OliverIOO Offline
                                          OliverIO
                                          #122
                                          @negalein
                                          ja aber der adapter selbst macht nix mit alexa.
                                          welchen skript-klebstoff du zur automatisierung da noch hinzufügst, deswegen sind wir ja alle hier
                                          zum thema feuer hatte ich glaube mal was für siggi gemacht
                                          details findest du im thread. das ist ein besipiel von individual-visualisierung von rss daten
                                          Links im Profil
