  4. JavaScript
  5. Script geht zeitweise auf Pause
javascript
32 Beiträge 7 Kommentatoren 3.3k Aufrufe 5 Beobachtet
  • NegaleinN Negalein
    gerade diesen Error im Log gefunden.
    Ist eventuell hilfreich.
    2020-01-07 12:00:09.310  - info: javascript.0 (593) script.js.common.Spritpreisrechner: Start Spritvergleich
    2020-01-07 12:00:09.317  - error: javascript.0 (593) Error in callback: TypeError: Cannot read property 'amount' of undefined
    2020-01-07 12:00:09.318  - error: javascript.0 (593)     at Object.<anonymous> (script.js.common.Spritpreisrechner:52:107)
    2020-01-07 12:00:09.318  - error: javascript.0 (593)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
    2020-01-07 12:00:09.318  - error: javascript.0 (593)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
    2020-01-07 12:00:09.318  - error: javascript.0 (593)     at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4745:37)
    2020-01-07 12:00:09.318  - error: javascript.0 (593)     at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:226:41)
    2020-01-07 12:00:09.318  - error: javascript.0 (593)     at runCallback (timers.js:705:18)
    2020-01-07 12:00:09.318  - error: javascript.0 (593)     at tryOnImmediate (timers.js:676:5)
    2020-01-07 12:00:09.318  - error: javascript.0 (593)     at processImmediate (timers.js:658:5)
    2020-01-06 12:00:07.441  - info: javascript.0 (593) script.js.common.Spritpreisrechner: Start Spritvergleich
    2020-01-06 12:00:07.456  - error: javascript.0 (593) Error in callback: TypeError: Cannot read property 'amount' of undefined
    2020-01-06 12:00:07.457  - error: javascript.0 (593)     at Object.<anonymous> (script.js.common.Spritpreisrechner:52:107)
    2020-01-06 12:00:07.458  - error: javascript.0 (593)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
    2020-01-06 12:00:07.459  - error: javascript.0 (593)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
    2020-01-06 12:00:07.459  - error: javascript.0 (593)     at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4745:37)
    2020-01-06 12:00:07.459  - error: javascript.0 (593)     at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:226:41)
    2020-01-06 12:00:07.460  - error: javascript.0 (593)     at runCallback (timers.js:705:18)
    2020-01-06 12:00:07.460  - error: javascript.0 (593)     at tryOnImmediate (timers.js:676:5)
    2020-01-06 12:00:07.460  - error: javascript.0 (593)     at processImmediate (timers.js:658:5)
    2020-01-05 12:00:08.658  - info: javascript.0 (7579) script.js.common.Spritpreisrechner: Start Spritvergleich
    2020-01-05 12:00:08.669  - error: javascript.0 (7579) Error in callback: TypeError: Cannot read property 'amount' of undefined
    2020-01-05 12:00:08.669  - error: javascript.0 (7579)     at Object.<anonymous> (script.js.common.Spritpreisrechner:52:107)
    2020-01-05 12:00:08.670  - error: javascript.0 (7579)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
    2020-01-05 12:00:08.670  - error: javascript.0 (7579)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
    2020-01-05 12:00:08.670  - error: javascript.0 (7579)     at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4745:37)
    2020-01-05 12:00:08.670  - error: javascript.0 (7579)     at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:226:41)
    2020-01-05 12:00:08.670  - error: javascript.0 (7579)     at runCallback (timers.js:705:18)
    2020-01-05 12:00:08.670  - error: javascript.0 (7579)     at tryOnImmediate (timers.js:676:5)
    2020-01-05 12:00:08.670  - error: javascript.0 (7579)     at processImmediate (timers.js:658:5)
    Dieser Fehler tritt täglich zur Mittagszeit auf.
    AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    @Negalein Dann hat eine der Stationen gerade keine Preisinformation (Zeile 52/53). Die sollte das Skript dann bestenfalls ignorieren.
    Dazu nach Zeile 18 folgendes einfügen:
    gasStation = gasStation.filter(g => g.prices.length > 0);
    • AlCalzoneA AlCalzone
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      @AlCalzone sagte in Script geht zeitweise auf Pause:
      Füge in Zeile 41 folgendes ein:
      Werde es beobachten.
      ° Fixer ---> iob fix
        AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        @Negalein Hab nochmal bearbeitet, bitte beachten
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          Also
          	if (gasStation[index].prices.length < 1) continue;
          wieder raus
          und nach Zeile 18
          rein.
          Sieht dann so aus?
           var gasStation = JSON.parse(obj.state.val);
              if (gasStation.length === 0) return;
            Also
            wieder raus
            und nach Zeile 18
            rein.
            Sieht dann so aus?
            AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            @Negalein Jup! Allerdings bitte selbst testen, hab ich von unterwegs getippselt.
            NegaleinN 2 Antworten Letzte Antwort
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              werd es mal ein paar Tage beobachten und mich wieder melden.
              Danke erstmal!
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                kurze Rückmeldung!
                Bis jetzt ist das Script einwandfrei durchgelaufen!
                Danke nochmals
                • NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  @AlCalzone
                  gestern ist das Script wieder in Pause gegangen.
                  Diesmal mit einem anderen Fehler (filter is not a function).
                  Das ganze ist von 03:26 bis 06:54 (hab nicht alles angehänt, da immer die gleiche Meldung) aufgetreten.
                  Kann man das irgendwie beheben? Oder liegt es an der zu parsenden Seite?
                  Falls es nicht zu beheben/umgehen ist, gibt es eine Möglichkeit ein Script zu überwachen, damit ich zumindest eine Benachrichtigung auf Telegram/Alexa bekomme?
                  Danke dir
                  2020-01-22 03:26:02.812  - info: javascript.0 (22538) script.js.common.Spritpreisrechner: Start Spritvergleich
                  2020-01-22 03:26:02.814  - error: javascript.0 (22538) Error in callback: TypeError: gasStation.filter is not a function
                  2020-01-22 03:26:02.814  - error: javascript.0 (22538)     at Object.<anonymous> (script.js.common.Spritpreisrechner:19:29)
                  2020-01-22 03:26:02.814  - error: javascript.0 (22538)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                  2020-01-22 03:26:02.814  - error: javascript.0 (22538)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                  2020-01-22 03:26:02.814  - error: javascript.0 (22538)     at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4745:37)
                  2020-01-22 03:26:02.814  - error: javascript.0 (22538)     at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:226:41)
                  2020-01-22 03:26:02.815  - error: javascript.0 (22538)     at runCallback (timers.js:705:18)
                  2020-01-22 03:26:02.815  - error: javascript.0 (22538)     at tryOnImmediate (timers.js:676:5)
                  2020-01-22 03:26:02.815  - error: javascript.0 (22538)     at processImmediate (timers.js:658:5)
                  2020-01-22 03:26:52.805  - info: javascript.0 (22538) script.js.common.Spritpreisrechner: Start Spritvergleich
                  2020-01-22 03:26:52.806  - error: javascript.0 (22538) Error in callback: TypeError: gasStation.filter is not a function
                  2020-01-22 03:26:52.807  - error: javascript.0 (22538)     at Object.<anonymous> (script.js.common.Spritpreisrechner:19:29)
                  2020-01-22 03:26:52.807  - error: javascript.0 (22538)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                  2020-01-22 03:26:52.807  - error: javascript.0 (22538)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                  2020-01-22 03:26:52.807  - error: javascript.0 (22538)     at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4745:37)
                  2020-01-22 03:26:52.807  - error: javascript.0 (22538)     at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:226:41)
                  2020-01-22 03:26:52.807  - error: javascript.0 (22538)     at runCallback (timers.js:705:18)
                  2020-01-22 03:26:52.807  - error: javascript.0 (22538)     at tryOnImmediate (timers.js:676:5)
                  2020-01-22 03:26:52.807  - error: javascript.0 (22538)     at processImmediate (timers.js:658:5)
                  2020-01-22 03:27:02.804  - info: javascript.0 (22538) script.js.common.Spritpreisrechner: Start Spritvergleich
                  2020-01-22 03:27:02.805  - error: javascript.0 (22538) Error in callback: TypeError: gasStation.filter is not a function
                  2020-01-22 03:27:02.805  - error: javascript.0 (22538)     at Object.<anonymous> (script.js.common.Spritpreisrechner:19:29)
                  2020-01-22 03:27:02.805  - error: javascript.0 (22538)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                  2020-01-22 03:27:02.806  - error: javascript.0 (22538)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                  2020-01-22 03:27:02.806  - error: javascript.0 (22538)     at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4745:37)
                  2020-01-22 03:27:02.806  - error: javascript.0 (22538)     at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:226:41)
                  2020-01-22 03:27:02.806  - error: javascript.0 (22538)     at runCallback (timers.js:705:18)
                  2020-01-22 03:27:02.806  - error: javascript.0 (22538)     at tryOnImmediate (timers.js:676:5)
                  2020-01-22 03:27:02.806  - error: javascript.0 (22538)     at processImmediate (timers.js:658:5)
                  2020-01-22 03:27:32.803  - info: javascript.0 (22538) script.js.common.Spritpreisrechner: Start Spritvergleich
                  2020-01-22 03:27:32.804  - error: javascript.0 (22538) Error in callback: TypeError: gasStation.filter is not a function
                  2020-01-22 03:27:32.805  - error: javascript.0 (22538)     at Object.<anonymous> (script.js.common.Spritpreisrechner:19:29)
                  2020-01-22 03:27:32.805  - error: javascript.0 (22538)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                  2020-01-22 03:27:32.808  - error: javascript.0 (22538)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                  2020-01-22 03:27:32.808  - error: javascript.0 (22538)     at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4745:37)
                  2020-01-22 03:27:32.808  - error: javascript.0 (22538)     at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:226:41)
                  2020-01-22 03:27:32.808  - error: javascript.0 (22538)     at runCallback (timers.js:705:18)
                  2020-01-22 03:27:32.808  - error: javascript.0 (22538)     at tryOnImmediate (timers.js:676:5)
                  2020-01-22 03:27:32.809  - error: javascript.0 (22538)     at processImmediate (timers.js:658:5)
                  sigi234S T AlCalzoneA 3 Antworten Letzte Antwort
                    @AlCalzone
                    Danke dir
                    sigi234S Online
                    sigi234S Online
                    @Negalein sagte in Script geht zeitweise auf Pause:
                    Jupp, hatte ich Heute auch.
                      @AlCalzone
                      Danke dir
                      T Nicht stören
                      T Nicht stören
                      ticaki
                      @Negalein
                      if (!isScriptActive("Test")) {
                          runScript("Test");
                      // oder sende msg.
                      Hoffe das hilft.
                      Spenden
                      • T ticaki
                        @Negalein
                            runScript("Test");
                        // oder sende msg.
                        Hoffe das hilft.
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        @ticaki sagte in Script geht zeitweise auf Pause:
                        Hoffe das hilft.
                        Das wird als eigenes Script angelegt?
                          Hoffe das hilft.
                          T Nicht stören
                          T Nicht stören
                          ticaki
                          @Negalein
                          Ja. Weiß nur nicht wie das Trennzeichen für Unterordner aussieht. :)
                          EDIT: must du alle x Zeiteinheiten per Cron ausführen lassen.
                          sieht das in deinem Script so aus?
                          Spenden
                          • T ticaki
                            @Negalein
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            So schaut das Script aus
                            //  "Spritpreise_AT v.0.5"        //
                            //  e-control Spritpreise        //
                            //  ursprüngl. Script von steinejo_io vom        //
                            //  Zwingend erforderlich sind der Parser Adapter und die URL aus der API. Links und Hilfe zum Erstellemn findet ihr im Folgenden Lnk:  //
                            //  https://forum.iobroker.net/topic/20314/skripten-des-e-control-spritpreisrechners                                                    //
                            //  Das manuelle Anlegen von Daenpunkten ist nicht mehr notwendig. erledigt das Script beim ersten Aufruf.                              //
                            //  Auf das "E" Zeichen habe ich verzichtet, da es in VIS genz einfach an der jeweils gewünschten Stelle produzierbar ist.              //
                            on({id: "parser.0.Spritpreisrechner"/*Spritpreisrechner*/, change: 'any'}, function(obj)
                            log("Start Spritvergleich");
                                //Aral=1, eni=2, Shell=3, OMV=4, avanti=5, bp=6, JET=7, Turmöl=8, Lagerhaus=9, AVIA=10, A1=11, Diskont=12, IQ=13
                                var arrMarke = ['Aral', 'eni', 'Shell', 'OMV', 'avanti', 'BP', 'JET', 'Turmöl', 'Lagerhaus', 'AVIA', 'A1', 'Diskont', 'DISKONT', 'IQ', 'SB-Tankstelle', 'bp', 'Land', 'Bp'];
                            	var i = 0;
                                for (var i = 1; i <= 5; i++) {
                                    // console.log(i);
                                    // console.log("javascript.0.Sprit_AT.name_"+i);
                                    createState("javascript.0.Sprit_AT.Treffer_"+i+".Name_"+i, {type: "string", name: "Platz "+i, read: true, write: true});
                                    createState("javascript.0.Sprit_AT.Treffer_"+i+".Preis_"+i, {type: "string", name: "Platz "+i, read: true, write: true});
                                    createState("javascript.0.Sprit_AT.Treffer_"+i+".PreisP_"+i, {type: "string", name: "Platz "+i, read: true, write: true});
                            		createState("javascript.0.Sprit_AT.Treffer_"+i+".Strasse_"+i, {type: "string", name: "Platz "+i, read: true, write: true});
                                    createState("javascript.0.Sprit_AT.Treffer_"+i+".PLZ_Ort_"+i, {type: "string", name: "Platz "+i, read: true, write: true});
                                    createState("javascript.0.Sprit_AT.Treffer_"+i+".Logo_"+i, {type: "number", name: "Logo "+i, read: true, write: true});
                            		createState("javascript.0.Sprit_AT.Treffer_"+i+".Latitude_"+i, {type: "number", name: "Latitude "+i, read: true, write: true});
                            		createState("javascript.0.Sprit_AT.Treffer_"+i+".Longitude_"+i, {type: "number", name: "Longitude "+i, read: true, write: true});
                            		createState("javascript.0.Sprit_AT.Treffer_"+i+".offen_"+i, {type: "boolean", name: "offen "+i, read: true, write: true});
                                var index = 0;
                                //for (index = 0; index < gasStation.length; ++index) {
                                for (index = 0; index <= 4; ++index) {
                            	var arrname = gasStation[index].name.split(' ');
                            		if (arrname.length > 0) {
                            				var markenname = arrname[0];
                            			else
                            				var markenname = gasStation[index].name;
                            		var station = gasStation[index].name;
                                setState("javascript.0.Sprit_AT.Treffer_"+(index+1)+".Name_"+(index+1), gasStation[index].name);
                                setState("javascript.0.Sprit_AT.Treffer_"+(index+1)+".Preis_"+(index+1), (gasStation[index].prices[0].amount).toString().replace(".",","));
                                setState("javascript.0.Sprit_AT.Treffer_"+(index+1)+".PreisP_"+(index+1), (gasStation[index].prices[0].amount).toString().replace(".","."));
                            	setState("javascript.0.Sprit_AT.Treffer_"+(index+1)+".Strasse_"+(index+1), (gasStation[index].location.address));
                                setState("javascript.0.Sprit_AT.Treffer_"+(index+1)+".PLZ_Ort_"+(index+1), (gasStation[index].location.postalCode) + " " + (gasStation[index].location.city));
                                setState("javascript.0.Sprit_AT.Treffer_"+(index+1)+".Latitude_"+(index+1), (gasStation[index].location.latitude));
                            	setState("javascript.0.Sprit_AT.Treffer_"+(index+1)+".Longitude_"+(index+1), (gasStation[index].location.longitude));
                            	setState("javascript.0.Sprit_AT.Treffer_"+(index+1)+".offen_"+(index+1), (gasStation[index].open));
                            	var markennameklein=markenname.toLowerCase();
                            	var x= 0;
                            	for (x=0; x < arrMarke.length; x++) {
                            		var arrMklein=arrMarke[x].toLowerCase();
                            		//console.log("x=" + x + "/ Markennameklein =" + markennameklein + "/ Array =" + arrMklein);
                            		if (arrMklein == markennameklein) {
                            			setState("javascript.0.Sprit_AT.Treffer_"+(index+1)+".Logo_"+(index+1), (x+1));
                            log("Ende Spritvergleich");
                            Das wird vom Parser geregelt. Der fragt die Adresse alle 10 Sek. ab und das Script reagiert darauf.
                              	var i = 0;
                                      // console.log(i);
                                  var index = 0;
                              			else
                              	var x= 0;
                              T Nicht stören
                              T Nicht stören
                              ticaki
                              @Negalein
                              Dein letzter Fehler sieht so aus als wenn der Parser keine Daten geliefert hat und deshalb Zeile 18 gescheitert ist
                              Versuche bitte mal folgendes: 2 Zeilen vertauschen und gasStation auf array/object prüfen.
                              if (typeof gasStation != 'object' || gasStation.length === 0) return;
                              EDIT: ups
                              Spenden
                              • T ticaki
                                @Negalein
                                EDIT: ups
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                Habs eingefügt/vertauscht und werde es die nächsten Tage beobachten.
                                  T Nicht stören
                                  T Nicht stören
                                  ticaki
                                  @Negalein
                                  hab editiert bitte beachten
                                  Spenden
                                  • T ticaki
                                    @Negalein
                                    NegaleinN Offline
                                    NegaleinN Offline
                                    Negalein
                                    Also
                                    gegen
                                    tauschen
                                      Also
                                      gegen
                                      tauschen
                                      T Nicht stören
                                      T Nicht stören
                                      ticaki
                                      @Negalein
                                      Jup, habs nochmal verbessert. Mache zwar viel mit Arrays, mußte aber bis dato noch nicht prüfen, ob es auch eines ist :)
                                      if (!Array.isArray(gasStation) || gasStation.length === 0) return;
                                      Spenden
                                      • T ticaki
                                        @Negalein
                                        NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        Thx
                                          Thx
                                          sigi234S Online
                                          sigi234S Online
                                          Thx
                                          Kann man das Skript jetzt oben benutzen? Ist das das aktuelle.
