  5. Fenster und andere Geräte zählen opt. Alexa Ansagen
    1.9k
    1.5k
blocklyjavascript
1.2k Beiträge 41 Kommentatoren 539.8k Aufrufe 71 Beobachtet
  • L linux150
    @dslraser
    Hallo!
    Ich hab ja dein Script mit meinen Sensoren ausgebaut.
    Was genau muss ich denn da jetzt bei meinem Script ändern?
    Bei mir kommt im Log jetzt
    javascript.0	2019-12-23 14:29:45.542	warn	(1369) at processImmediate (timers.js:658:5)
    javascript.0	2019-12-23 14:29:45.541	warn	(1369) at tryOnImmediate (timers.js:676:5)
    javascript.0	2019-12-23 14:29:45.541	warn	(1369) at runCallback (timers.js:705:18)
    javascript.0	2019-12-23 14:29:45.540	warn	(1369) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:226:41)
    javascript.0	2019-12-23 14:29:45.540	warn	(1369) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4745:37)
    javascript.0	2019-12-23 14:29:45.539	warn	(1369) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
    javascript.0	2019-12-23 14:29:45.539	warn	(1369) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
    javascript.0	2019-12-23 14:29:45.538	warn	(1369) at Object.<anonymous> (script.js.common.Temperaturansage_komplett:620:3)
    javascript.0	2019-12-23 14:29:45.537	warn	(1369) at setStateDelayed (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1302:25)
    javascript.0	2019-12-23 14:29:45.537	warn	(1369) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
    javascript.0	2019-12-23 14:29:45.534	warn	(1369) State "alexa2.0.Echo-Devices.5DD04228BFA44B5684355A5DFB817B43.Commands.ssml" not found
    javascript.0	2019-12-23 14:29:45.534	warn	(1369) at processImmediate (timers.js:658:5)
    javascript.0	2019-12-23 14:29:45.533	warn	(1369) at tryOnImmediate (timers.js:676:5)
    javascript.0	2019-12-23 14:29:45.533	warn	(1369) at runCallback (timers.js:705:18)
    javascript.0	2019-12-23 14:29:45.532	warn	(1369) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:226:41)
    javascript.0	2019-12-23 14:29:45.532	warn	(1369) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4745:37)
    javascript.0	2019-12-23 14:29:45.531	warn	(1369) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
    javascript.0	2019-12-23 14:29:45.531	warn	(1369) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
    javascript.0	2019-12-23 14:29:45.530	warn	(1369) at Object.<anonymous> (script.js.common.Temperaturansage_komplett:619:3)
    javascript.0	2019-12-23 14:29:45.529	warn	(1369) at setStateDelayed (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1302:25)
    javascript.0	2019-12-23 14:29:45.528	warn	(1369) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
    javascript.0	2019-12-23 14:29:45.518	warn	(1369) State "alexa2.0.Echo-Devices.5DD04228BFA44B5684355A5DFB817B43.Commands.speak-volume" not found
    Java Adapter ist bei mir 4.1.12
    lg
    linux150
    dslraserD
    dslraserD
    dslraser
    @linux150
    das wird nicht gefunden...
    Hast Du den Alexa2 Adapter installiert ?
    Schau mal nach ob es diesen DP aus der Fehlermeldung bei Dir in den Objekten gibt.
    Wenn ja, was ist das für ein Gerät, womit Du die Abfrage startest ?
    Sollte es Dein Handy sein, oder This Device, da wird diese Abfrage nicht unterstützt. Dort gibt es diese Sprachausgabe nicht.
    L 1 Antwort Letzte Antwort
    • dslraserD dslraser
      @linux150
      L
      L
      linux150
      schrieb am zuletzt editiert von linux150
      @dslraser
      habe über Webinterface den Datenpunkt getriggert, und da dürfte beim Alexa Adapter was nicht gestimmt haben.
      Hab jetzt mal vor Ort die Ansage direkt gestartet, und jetzt hat wieder alles funktioniert. Auch per WI übern Datenpunkt startet die Ansage jetzt wieder. Evtl. hat die Seriennummer nicht gepasst ... Egal
      Mit deinem Blockly hab ich vor ca. 2 Wochen begonnen, und alle meine Sensoren eingebunden.
      Aber wie gesagt es wäre schön wenn du mir sagen könntest was du geändert hast damit ich mein Script anpassen könnte.
      Ein neuer Import bringt mir ja nix, denn dann sind ja meine Anpassungen alle weg...
      Außer ich hab eh keinen Bedarf was zu ändern ?
      lg
      linux150
      • L linux150
        @dslraser
        lg
        linux150
        dslraserD
        dslraserD
        dslraser
        @linux150
        Ich habe das setzen der Lautstärke verändert. Importieren kannst Du das neue Blockly ja trotzdem. Wenn Du nur einen Teil aus Deinem Blockly anschließend tauschen willst, dann geht das ja auch recht einfach.
        Du mußt nur das aus Deinem Blockly, was Du gern exportieren möchtest, z.B. Deine Geräte, anklicken, oder wenn es mehrere sind in z.B. einen falls Baustein ins Maul packen (nicht speichern) und nur den gesamten Baustein(also z.B. das falls) samt Inhalt makieren / anklicken und auf exportieren gehen. Dann wird nur dieser Teil erxportiert. Diesen dann ins neue Blockly importieren und austauschen.
          @linux150
          L
          L
          linux150
          @dslraser
          Danke, das ist ein guter Ansatz. Das werde ich mal testen. 👍
          • dslraserD
            dslraserD
            dslraser
            Ich habe ich noch eine Möglichkeit der Ansagen erstellt. Dort geht die Ansage über die Funktionen und Aufzählungen. Dort gehen noch einige Dinge mehr...
            https://forum.iobroker.net/post/346230
            • EuloE
              EuloE
              Eulo
              schrieb am zuletzt editiert von Eulo
              Bei mir sind die Datenpunkte erstellt, sie sind im iot vorhanden aber ich habe alexa schon gefühlt 1000 mal suchen lassen, und sie findet einfach nichts. Woran könnte das liegen?
              • EuloE Eulo
                dslraserD
                dslraserD
                dslraser
                @ginvibe
                welches Blockly hast Du genommen ?
                EuloE 1 Antwort Letzte Antwort
                  @ginvibe
                  EuloE
                  EuloE
                  Eulo
                  @dslraser said in Alexa Ansagen über ssml:
                  @ginvibe
                  Offene Fenster abfrage und Batteriestatus aus deinem Post Vorlage Telegram offene Fenster und mehr
                  • EuloE Eulo
                    @ginvibe
                    dslraserD
                    dslraserD
                    dslraser
                    @ginvibe sagte in Alexa Ansagen über ssml:
                    @ginvibe
                    Jetzt kann ich Dur nicht folgen...Das sind doch Blocklys für den Telegram Versand.
                    Warum postest Du hier bei den ssml Ansagen ? Oder verstehe ich was falsch ?
                      @ginvibe
                      EuloE
                      EuloE
                      Eulo
                      @dslraser sagte in Alexa Ansagen über ssml:
                      @ginvibe
                      naja der telegram versand soll ja via. Alexa Sprachbefehl ausgelöst werden. Oder habe ich da was falsch verstanden?
                      • EuloE Eulo
                        @ginvibe
                        dslraserD
                        dslraserD
                        dslraser
                        Nein, hast Du nicht falsch verstanden, hat aber trotzdem nichts mit ssml zu tun.
                        Der Sprachbefehl (über eine Routine in der Alexa App) drückt/aktualisiert eigentlich nur den angelegten Datenpunkt, das ist der Trigger.
                        Kommt denn ein Telegram wenn Du den Button in den Objekten drückst ?
                        Edit: zeig mal Deinen Button in iot.
                          EuloE
                          EuloE
                          Eulo
                          eine Telegram Nachricht bekomme ich wenn ich den Button in den Objekten drücke.
                          • EuloE Eulo
                            dslraserD
                            dslraserD
                            dslraser
                            Das ist ja schon mal gut. Zeig mal bitte von dem erstellten Datenpunkt den RAW.
                            Womit bzw. wie suchst Du neue Geräte ? Per Sprachbefehl, über die App oder über den Browser ? Sind andere Geräte da ?
                            Wenn der in iot ist, dann sollte Alexa den auch finden, hm...
                            Das diese DP nicht gefunden werden hatte ich bisher noch nie ...
                              EuloE
                              EuloE
                              Eulo
                              einmal die RAW
                                "from": "system.adapter.javascript.0",
                                "user": "system.user.admin",
                                "ts": 1579678810205,
                                "common": {
                                  "name": "Batteriestatus",
                                  "role": "button",
                                  "type": "mixed",
                                  "read": true,
                                  "write": true,
                                  "def": false,
                                  "smartName": {
                                    "de": "Batteriestatus",
                                    "smartType": "SWITCH"
                                "native": {},
                                "acl": {
                                  "object": 1636,
                                  "owner": "system.user.admin",
                                  "state": 1636
                                "_id": "javascript.0.Eigene_Datenpunkte.04Telegram.Batteriestatus.Batteriestatus",
                                "type": "state"
                               "common": {
                                 "name": "Fensterstatus",
                                 "role": "button",
                                 "type": "mixed",
                                 "read": true,
                                 "write": true,
                                 "smartName": {
                                   "de": "Fensterstatus",
                               "native": {},
                               "type": "state",
                               "ts": 1579678000070,
                               "_id": "javascript.0.Eigene_Datenpunkte.04Telegram.Fensterstatus.Fensterstatus",
                               "acl": {
                                 "object": 1636,
                                 "state": 1636,
                              Ich habe sie einerseits per Sprachbefehl gesucht, und anderer seits über die App. Wobei ich bei der App entweder unter "Smart Home > Sonstiges" gesucht habe oder unter "Smart Home > Schalter" gesucht habe.
                              Alle anderen geräte wie Hue Lampen, Heizkörper Thermostate sind drin.
                              • EuloE Eulo
                                einmal die RAW
                                  "common": {
                                    "role": "button",
                                    "type": "mixed",
                                    "read": true,
                                    "write": true,
                                    "def": false,
                                    "smartName": {
                                  "native": {},
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636
                                  "type": "state"
                                 "common": {
                                   "role": "button",
                                   "type": "mixed",
                                   "read": true,
                                   "write": true,
                                   "smartName": {
                                 "native": {},
                                 "type": "state",
                                 "acl": {
                                   "object": 1636,
                                   "state": 1636,
                                dslraserD
                                dslraserD
                                dslraser
                                @ginvibe
                                probiere mal bitte als type boolean (nicht mixed) und dann nochmal iot öffnen und wieder schliessen, danach nochmal neue Geräte suchen.
                                (obwohl es daran nicht liegen dürfte)
                                  @ginvibe
                                  EuloE
                                  EuloE
                                  Eulo
                                  @ginvibe
                                  wie änder ich das auf boolean?
                                  • EuloE Eulo
                                    @ginvibe
                                    dslraserD
                                    dslraserD
                                    dslraser
                                    @ginvibe
                                    ich nutze mittlerweile 0_userdata.0
                                    Probiere mal das hier. Bitte auch die "alten" erstellten Datenpunkte löschen, sonst wären die doppelt in iot. (wenn Du als Speicherort javascript.x haben willst, lässt sich das in der JS Funktion "Datenpunkte anlegen" einstellen)
                                    Du mußt das Blockly ja noch nicht komplett fertig machen, nur starten, damit der DP angelegt wird, dann im iot schauen, ob vorhanden und dann die Gerätesuche nochmal starten. Schau mal ob es damit geht.
                                    Telegram-Batterieliste.txt
                                    • EuloE Eulo
                                      @ginvibe
                                      dslraserD
                                      dslraserD
                                      dslraser
                                      da rein klicken, also da drinn (ganz rechts auf </> . klicken)
                                      und dann da ändern (das ist das Beispiel aus dem ersten Beitrag)
                                        @ginvibe
                                        EuloE
                                        EuloE
                                        Eulo
                                        @ginvibe
                                        das hab ich jetzt gemacht, und alexa findet dennoch nichts.
                                        • EuloE Eulo
                                          @ginvibe
                                          dslraserD
                                          dslraserD
                                          dslraser
                                          @ginvibe
                                          das verstehe ich nicht...
                                          83.8k
