  4. Test Adapter Material Design Widgets v0.2.x
visadapatervisualizationmaterialwidget
902 Beiträge 77 Kommentatoren 343.5k Aufrufe 79 Beobachtet
  • O Oli
    @Scrounger
    Chrome, sieht aus wie im geposteten Edit Modus
    [Deprecation] Application Cache was previously restricted to secure origins only from M70 on but now secure origin use is deprecated and will be removed in M82.  Please shift your use case over to Service Workers.
    vis.js:3163 Create inner vis object javascript.0.Rezepte.Rezeptsuche.Arbeitszeit
    vis.js:3163 Create inner vis object javascript.0.Rezepte.Rezeptsuche.Schwierigkeitsgrad
    vis.js:3163 Create inner vis object javascript.0.Rezepte.Rezeptsuche.Kalorien
    vis.js:3163 Create inner vis object javascript.0.Rezepte.Rezeptsuche.Zubereitung
    vis.js:3163 Create inner vis object javascript.0.Essensplan.save_rezept
    vis.js:3163 Create inner vis object javascript.0.Essensplan.vis_switch
    vis.js:3163 Create inner vis object tvspielfilm.0.json.tipps
    vis.js:3163 Create inner vis object javascript.0.TV.TVjetzt
    vis.js:3163 Create inner vis object javascript.0.TV.Schalter
    vis.js:3163 Create inner vis object javascript.0.TV.TVgleich
    vis.js:3163 Create inner vis object javascript.0.TV.TV20
    vis.js:3163 Create inner vis object javascript.0.TV.TV22
    vis.js:3163 Create inner vis object javascript.0.RSS-Feed.Bild.Tabelle
    vis.js:3163 Create inner vis object javascript.0.RSS-Feed.Tagesschau.Link_Tagesschau
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät1.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Anzahl
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät1.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät1.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät1.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät1.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät1.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät2.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät2.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät2.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät2.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät2.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät2.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät3.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät3.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät3.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät3.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät3.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät3.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät4.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät4.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät4.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät4.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät4.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät4.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät5.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät5.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät5.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät5.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät5.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät5.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät6.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät6.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät6.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät6.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät6.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät6.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät7.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät7.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät7.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät7.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät7.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät7.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät8.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät8.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät8.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät8.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät8.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät8.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät9.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät9.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät9.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät9.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät9.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät9.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät10.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät10.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät10.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät10.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät10.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät10.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät11.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät11.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät11.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät11.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät11.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät11.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät12.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät12.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät12.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät12.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät12.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät12.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät13.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät13.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät13.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät13.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät13.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät13.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät14.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät14.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät14.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät14.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät14.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät14.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät15.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät15.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät15.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät15.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät15.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät15.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät16.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät16.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät16.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät16.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät16.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät16.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät17.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät17.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät17.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät17.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät17.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät17.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät18.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät18.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät18.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät18.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät18.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät18.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät19.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät19.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät19.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät19.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät19.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät19.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät20.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät20.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät20.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät20.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät20.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät20.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät21.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät21.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät21.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät21.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät21.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät21.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät22.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät22.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät22.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät22.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät22.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät22.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät23.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät23.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät23.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät23.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät23.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät23.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät24.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät24.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät24.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät24.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät24.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät24.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät25.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät25.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät25.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät25.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät25.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät25.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät26.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät26.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät26.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät26.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät26.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät26.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät27.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät27.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät27.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät27.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät27.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät27.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät28.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät28.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät28.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät28.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät28.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät28.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät29.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät29.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät29.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät29.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät29.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät29.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät30.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät30.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät30.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät30.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät30.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät30.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät31.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät31.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät31.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät31.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät31.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät31.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät32.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät32.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät32.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät32.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät32.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät32.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät33.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät33.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät33.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät33.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät33.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät33.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät34.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät34.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät34.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät34.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät34.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät34.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät35.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät35.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät35.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät35.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät35.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät35.Update
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät36.NameGerät
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät36.UptimeStr
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät36.Status
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät36.IPAdresse
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät36.Bild
    vis.js:3163 Create inner vis object javascript.0.Netzwerk.Gerät36.Update
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter1.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Anzahl
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter1.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter1.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter1.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter1.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter1.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter1.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter7.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter7.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter7.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter7.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter7.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter7.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter7.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter13.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter13.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter13.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter13.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter13.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter13.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter13.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter19.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter19.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter19.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter19.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter19.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter19.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter19.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter25.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter25.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter25.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter25.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter25.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter25.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter25.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter26.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter26.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter26.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter26.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter26.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter26.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter26.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter20.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter20.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter20.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter20.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter20.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter20.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter20.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter14.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter14.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter14.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter14.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter14.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter14.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter14.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter2.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter2.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter2.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter2.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter2.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter2.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter2.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter8.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter8.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter8.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter8.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter8.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter8.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter8.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter9.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter9.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter9.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter9.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter9.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter9.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter9.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter27.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter27.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter27.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter27.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter27.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter27.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter27.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter21.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter21.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter21.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter21.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter21.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter21.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter21.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter15.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter15.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter15.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter15.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter15.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter15.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter15.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter3.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter3.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter3.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter3.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter3.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter3.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter3.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter10.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter10.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter10.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter10.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter10.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter10.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter10.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter28.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter28.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter28.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter28.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter28.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter28.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter28.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter22.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter22.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter22.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter22.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter22.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter22.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter22.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter16.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter16.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter16.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter16.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter16.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter16.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter16.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter4.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter4.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter4.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter4.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter4.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter4.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter4.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter11.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter11.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter11.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter11.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter11.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter11.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter11.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter29.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter29.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter29.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter29.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter29.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter29.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter29.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter23.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter23.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter23.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter23.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter23.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter23.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter23.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter17.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter17.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter17.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter17.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter17.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter17.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter17.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter5.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter5.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter5.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter5.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter5.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter5.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter5.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter12.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter12.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter12.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter12.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter12.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter12.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter12.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter30.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter30.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter30.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter30.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter30.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter30.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter30.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter24.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter24.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter24.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter24.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter24.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter24.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter24.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter18.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter18.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter18.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter18.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter18.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter18.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter18.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter6.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter6.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter6.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter6.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter6.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter6.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter6.Uptime
    vis.js:3163 Create inner vis object 0
    vis.js:3163 Create inner vis object 100
    vis.js:3163 Create inner vis object 250
    vis.js:3163 Create inner vis object javascript.0.Adapter.AdapterNummer
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter31.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter31.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter31.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter31.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter31.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter31.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter37.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter37.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter37.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter37.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter37.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter37.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter43.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter43.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter43.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter43.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter43.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter43.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter49.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter49.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter49.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter49.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter49.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter49.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter55.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter55.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter55.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter55.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter55.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter55.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter56.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter56.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter56.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter56.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter56.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter56.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter50.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter50.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter50.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter50.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter50.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter50.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter44.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter44.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter44.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter44.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter44.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter44.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter32.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter32.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter32.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter32.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter32.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter32.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter38.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter38.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter38.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter38.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter38.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter38.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter39.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter39.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter39.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter39.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter39.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter39.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter57.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter57.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter57.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter57.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter57.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter57.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter51.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter51.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter51.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter51.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter51.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter51.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter45.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter45.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter45.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter45.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter45.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter45.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter33.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter33.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter33.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter33.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter33.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter33.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter40.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter40.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter40.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter40.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter40.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter40.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter58.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter58.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter58.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter58.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter58.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter58.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter52.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter52.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter52.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter52.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter52.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter52.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter46.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter46.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter46.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter46.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter46.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter46.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter34.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter34.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter34.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter34.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter34.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter34.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter41.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter41.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter41.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter41.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter41.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter41.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter59.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter59.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter59.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter59.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter59.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter59.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter53.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter53.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter53.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter53.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter53.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter53.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter47.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter47.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter47.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter47.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter47.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter47.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter35.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter35.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter35.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter35.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter35.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter35.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter42.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter42.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter42.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter42.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter42.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter42.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter60.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter60.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter60.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter60.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter60.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter60.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter54.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter54.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter54.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter54.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter54.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter54.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter48.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter48.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter48.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter48.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter48.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter48.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter36.Bild
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter36.Connected
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter36.MemRSS
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter36.MemUsed
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter36.MemTotal
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter36.Uptime
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter60.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter59.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter58.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter57.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter56.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter55.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter54.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter53.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter52.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter51.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter50.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter49.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter48.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter47.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter46.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter45.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter44.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter43.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter42.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter41.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter40.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter39.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter38.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter37.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter36.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter35.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter34.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter33.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter32.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Adapter.Adapter31.NameAdapter
    vis.js:3163 Create inner vis object javascript.0.Status.Speed-Test.download
    vis.js:3163 Create inner vis object javascript.0.Status.Speed-Test.upload
    vis.js:3163 Create inner vis object javascript.0.Status.Speed-Test.ping
    vis.js:3163 Create inner vis object javascript.0.homee.Anzahl_Geräte
    vis.js:3163 Create inner vis object javascript.0.homee.Anzahl_Batterie
    vis.js:3163 Create inner vis object javascript.0.homee.Anzahl_ohne_Batterie
    vis.js:3163 Create inner vis object javascript.0.homee.Anzahl_homeegramme
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät1.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät1.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät1.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät1.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät2.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät2.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät2.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät2.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät3.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät3.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät3.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät3.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät4.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät4.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät4.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät4.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät5.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät5.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät5.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät5.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät6.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät6.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät6.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät6.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät7.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät7.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät7.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät7.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät8.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät8.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät8.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät8.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät9.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät9.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät9.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät9.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät10.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät10.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät10.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät10.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät11.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät11.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät11.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät11.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät12.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät12.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät12.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät12.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät13.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät13.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät13.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät13.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät14.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät14.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät14.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät14.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät15.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät15.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät15.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät15.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät16.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät16.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät16.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät16.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät17.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät17.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät17.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät17.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät34.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät34.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät34.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät34.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät33.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät33.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät33.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät33.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät32.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät32.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät32.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät32.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät31.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät31.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät31.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät31.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät30.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät30.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät30.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät30.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät29.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät29.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät29.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät29.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät28.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät28.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät28.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät28.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät27.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät27.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät27.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät27.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät26.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät26.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät26.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät26.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät25.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät25.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät25.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät25.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät24.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät24.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät24.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät24.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät23.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät23.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät23.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät23.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät22.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät22.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät22.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät22.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät21.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät21.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät21.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät21.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät20.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät20.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät20.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät20.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät19.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät19.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät19.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät19.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät18.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät18.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät18.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät18.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Anzahl_Aktivierte_homeegramme
    vis.js:3163 Create inner vis object javascript.0.homee.Anzahl_deaktivierte_homeegramme
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät42.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät42.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät42.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät42.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät41.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät41.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät41.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät41.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät40.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät40.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät40.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät40.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät39.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät39.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät39.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät39.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät38.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät38.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät38.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät38.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät37.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät37.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät37.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät37.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät36.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät36.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät36.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät36.NameGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät35.BatterieLevel
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät35.BatterieStand
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät35.BezeichnungGerät
    vis.js:3163 Create inner vis object javascript.0.homee.Gerät35.NameGerät
    vis.js:3163 Create inner vis object info.0.sysinfo.os.versions.npm
    vis.js:3163 Create inner vis object info.0.sysinfo.os.versions.node
    vis.js:3163 Create inner vis object info.0.sysinfo.os.versions.git
    vis.js:3163 Create inner vis object snmp.0.192_168_2_115.Freier_Speicher RAM
    vis.js:3163 Create inner vis object info.0.newsfeed_filtered
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.iobroker.iobroker_ram_usage
    vis.js:3163 Create inner vis object info.0.sysinfo.cpu.currentLoad.currentload
    vis.js:3163 Create inner vis object backitup.0.history.iobrokerLastTime
    vis.js:3163 Create inner vis object info.0.sysinfo.os.processes.all
    vis.js:3163 Create inner vis object info.0.sysinfo.os.versions.kernel
    vis.js:3163 Create inner vis object info.0.sysinfo.system.hardware.model
    vis.js:3163 Create inner vis object info.0.sysinfo.os.info.platform
    vis.js:3163 Create inner vis object info.0.sysinfo.os.processes.list
    vis.js:3163 Create inner vis object javascript.0.Chart.history.timeInterval
    vis.js:3163 Create inner vis object system.adapter.admin.0.memRss
    vis.js:3163 Create inner vis object javascript.0.ioBroker.ioBroker_Updates
    vis.js:3163 Create inner vis object backitup.0.oneClick.iobroker
    vis.js:3163 Create inner vis object backitup.0.history.html
    vis.js:3163 Create inner vis object backitup.0.output.line
    vis.js:3163 Create inner vis object javascript.0.Backup.Backupgröße
    vis.js:3163 Create inner vis object info.0.sysinfo.cpu.info.brand
    vis.js:3163 Create inner vis object info.0.sysinfo.disks.fsSize.fs0.use
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.qnap.qnap_gesamtspeicher
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.qnap.qnap_freier_speicher
    vis.js:3163 Create inner vis object snmp.0.192_168_2_115.Gesamtspeicher_RAM
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.win10_ram_free
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.uptime
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.win10_ram_usage
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.win10_cpu_usage
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.win10_c_usage
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.win10_d_usage
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.win10_f_usage
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.win10_totalsize
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.win10_freespace
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.pc.win10_ram_total
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.laptop.win10_ram_free
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.laptop.uptime
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.laptop.win10_ram_usage
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.laptop.win10_cpu_usage
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.laptop.win10_c_usage
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.laptop.win10_totalsize
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.laptop.win10_freespace
    vis.js:3163 Create inner vis object javascript.0.Ressourcen.laptop.win10_ram_total
    vis.js:3163 Create inner vis object javascript.0.Log-Script.Loganzeige
    vis.js:3163 Create inner vis object javascript.0.Log-Script.logError.clearJSON
    vis.js:3163 Create inner vis object javascript.0.Log-Script.Stand
    vis.js:3163 Create inner vis object javascript.0.Log-Script.logInfo.logJSONcount
    vis.js:3163 Create inner vis object javascript.0.Log-Script.logWarn.logJSONcount
    vis.js:3163 Create inner vis object javascript.0.Log-Script.logError.logJSONcount
    vis.js:3163 Create inner vis object javascript.0.Log-Script.logInfo.LetzterEintrag
    vis.js:3163 Create inner vis object javascript.0.Log-Script.logWarn.LetzterEintrag
    vis.js:3163 Create inner vis object javascript.0.Log-Script.logError.LetzterEintrag
    vis.js:3163 Create inner vis object javascript.0.Log-Script.logInfo.ClearDate
    vis.js:3163 Create inner vis object javascript.0.Log-Script.logWarn.ClearDate
    vis.js:3163 Create inner vis object javascript.0.Log-Script.logError.ClearDate
    vis.js:3163 Create inner vis object javascript.0.Log-Script.logWarn.clearJSON
    vis.js:3163 Create inner vis object javascript.0.Log-Script.logInfo.clearJSON
    vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.OrdnerCheck
    vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.LatestChangeDP_Factor
    vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.HTMLTable
    vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.RunSuccessful
    vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.MonsterSearch
    vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.ObjectAnzahlCheck
    vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.ohneInstanzAnzeige
    vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.JavaInstanzCheck
    vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.CheckAliase
    vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.RunScript
    vis.js:3163 Create inner vis object controll-own.0.mount.CPULuefter
    vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.TypeAnalyse
    vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.WertAnalyse
    vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.SmartHomeAnalyse
    vis.js:3163 Create inner vis object javascript.0.ProofingDatapoints.HistoryAnalyse
    vis.js:3163 Create inner vis object yamaha.0.input
    vis.js:3163 Create inner vis object yamaha.0.Realtime.TUN.PRESET
    vis.js:3163 Create inner vis object yamaha.0.power
    vis.js:3163 Create inner vis object yamaha.0.Realtime.MAIN.VOL
    vis.js:3163 Create inner vis object yamaha.0.Realtime.MAIN.INP
    vis.js:3163 Create inner vis object yamaha.0.Realtime.TUN.AVAIL
    vis.js:3163 Create inner vis object yamaha.0.Realtime.MAIN.PWR
    vis.js:3163 Create inner vis object hm-rega.0.22425.ProgramExecute
    vis.js:3163 Create inner vis object hm-rega.0.22436.ProgramExecute
    vis.js:3163 Create inner vis object musiccast.0.RX-V481_08125F03.netusb.presetrecallnumber
    vis.js:3163 Create inner vis object musiccast.0.RX-V481_08125F03.netusb.albumart_url
    vis.js:3163 Create inner vis object yamaha.0.Commands.skip
    vis.js:3163 Create inner vis object yamaha.0.Commands.stop
    vis.js:3163 Create inner vis object yamaha.0.Commands.toggleMute
    vis.js:3163 Create inner vis object yamaha.0.Commands.rewind
    vis.js:3163 Create inner vis object yamaha.0.Realtime.SERVER.ELAPSEDTIME
    vis.js:3163 Create inner vis object yamaha.0.Realtime.SERVER.PLAYBACKINFO
    vis.js:3163 Create inner vis object yamaha.0.Realtime.NETRADIO.ELAPSEDTIME
    vis.js:3163 Create inner vis object yamaha.0.Realtime.NETRADIO.AVAIL
    vis.js:3163 Create inner vis object yamaha.0.Realtime.TUN.FMFREQ
    vis.js:3163 Create inner vis object yamaha.0.Realtime.NETRADIO.PLAYBACKINFO
    vis.js:3163 Create inner vis object ping.0.ioBroker.192_168_2_108
    vis.js:3163 Create inner vis object yamaha.0.Realtime.NETRADIO.MAXLINE
    vis.js:3163 Create inner vis object denon.0.info.friendlyName
    vis.js:3163 Create inner vis object yaTUN.AVAILmaha.0.Realtime.
    vis.js:3163 Create inner vis object yamaha.0.Realtime.TUN.RDSCLOCK
    vis.js:3163 Create inner vis object hm-rpc.0.MEQ0251193.4.AUTO_MODE
    vis.js:3163 Create inner vis object hm-rpc.0.MEQ0251193.4.BOOST_MODE
    vis.js:3163 Create inner vis object hm-rpc.0.MEQ0251193.4.SET_TEMPERATURE
    vis.js:3163 Create inner vis object hm-rpc.0.MEQ0251193.4.ACTUAL_TEMPERATURE
    vis.js:3163 Create inner vis object hm-rpc.0.MEQ0251193.4.VALVE_STATE
    vis.js:3163 Create inner vis object hm-rpc.0.MEQ0251193.4.MANU_MODE
    vis.js:3163 Create inner vis object hm-rpc.0.MEQ0251193.4.CONTROL_MODE
    vis.js:3163 Create inner vis object hm-rpc.0.MEQ0250683.4.VALVE_STATE
    vis.js:3163 Create inner vis object hm-rpc.0.MEQ0250683.4.ACTUAL_TEMPERATURE
    vis.js:3163 Create inner vis object hm-rpc.0.MEQ0251193.4.BOOST_STATE
    hqwidgets.js:902 Version vis-hqwidgets: 1.1.2
    jquery-1.11.2.min.js:4 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
    send @ jquery-1.11.2.min.js:4
    jquery-1.11.2.min.js:4 Failed to load resource: the server responded with a status of 404 (Not Found)
    conn.js:1142 Error: can't render tplMusiccastAlbumArt w03368 on "400_Denon":
    conn.js:1142 Error: 0 - Error: can.view: No template or empty template:tplMusiccastAlbumArt.ejsError: can.view: No template or empty template:tplMusiccastAlbumArt.ejs
    conn.js:1142 Error: 1 -     at u (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:58:256)
    conn.js:1142 Error: 2 -     at Object.error (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:58:953)
    conn.js:1142 Error: 3 -     at j (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:2:27295)
    conn.js:1142 Error: 4 -     at Object.fireWith [as rejectWith] (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:2:28108)
    conn.js:1142 Error: 5 -     at x (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:22086)
    conn.js:1142 Error: 6 -     at b (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:25980)
    conn.js:1142 Error: 7 -     at Object.send (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:26084)
    conn.js:1142 Error: 8 -     at Object.ajax (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:21520)
    conn.js:1142 Error: 9 -     at o (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:58:899)
    conn.js:1142 Error: 10 -     at http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:46:3358
    conn.js:1142 Error: can't render tplBarNavigator w03370 on "400_Denon":
    conn.js:1142 Error: 0 - Error: can.view: No template or empty template:tplBarNavigator.ejsError: can.view: No template or empty template:tplBarNavigator.ejs
    conn.js:1142 Error: can't render tplkodiButton w03371 on "400_Denon":
    conn.js:1142 Error: 0 - Error: can.view: No template or empty template:tplkodiButton.ejsError: can.view: No template or empty template:tplkodiButton.ejs
    translate.js:20 "Resolution assistant": {"en": "Resolution assistant", "de": "Resolution assistant", "ru": "Resolution assistant"},
    translate.js:20 "width of resolution": {"en": "width of resolution", "de": "width of resolution", "ru": "width of resolution"},
    translate.js:20 "used rule": {"en": "used rule", "de": "used rule", "ru": "used rule"},
    translate.js:20 "number of columns": {"en": "number of columns", "de": "number of columns", "ru": "number of columns"},
    translate.js:20 "distance between views": {"en": "distance between views", "de": "distance between views", "ru": "distance between views"},
    transparens.png:1 Failed to load resource: the server responded with a status of 404 (Not Found)
    2:8082/icons-mfd-svg/status_light_low.svg:1 Failed to load resource: the server responded with a status of 404 (Not Found)
    Edge sieht jetzt auch aus wie es soll
    Alle
    Fehler
    Warnungen
    Info
    Protokolle
    Protokoll beibehalten
    Ziel
    SCRIPT7016: SCRIPT7016: XMLHttpRequest wird nicht mehr verwendet, während das synchronous-Kennzeichen auf TRUE festgelegt ist, weil die Websiteleistung für den Benutzer beeinträchtigt wird.
    Error: 1 -    at u (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:58:250)
    Error: 2 -    at error (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:58:953)
    Error: 3 -    at j (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:2:27287)
    Error: 4 -    at k.fireWith (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:2:28044)
    Error: 5 -    at x (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:21630)
    Error: 6 -    at b (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:25977)
    Error: 7 -    at send (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:25630)
    Error: 8 -    at ajax (http://192.168.2.120:8082/lib/js/jquery-1.11.2.min.js:4:21514)
    Error: 9 -    at o (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:58:890)
    Error: 10 -    at Anonymous function (http://192.168.2.120:8082/vis/lib/js/can.custom.min.js:46:3349)
    HTTP404: NICHT GEFUNDEN: Der Server hat keine Übereinstimmungen für den angeforderten URI (Uniform Resource Identifier) gefunden.
    GET - http://192.168.2.120:8082/vis.0/transparens.png
    GET - http://192.168.2.120:8082/icons-mfd-svg/status_light_low.svg
    (XHR)GET - http://192.168.2.120:8082/vis/tplMusiccastAlbumArt.ejs
    (XHR)GET - http://192.168.2.120:8082/vis/tplBarNavigator.ejs
    (XHR)GET - http://192.168.2.120:8082/vis/tplkodiButton.ejs
    (XHR)GET - http://192.168.2.120:8082/icons-mfd-svg/status_light_low.svg
    XML5619: Fehlerhafte Syntax in einem Dokument.
    index.html (1,1)
    [1579019015685] Request 8 states.
    [1579019015762] Request 1 states.
    [1579019015813] Request 4 states.
    [1579019015864] Request 1 states.
    [1579019015938] Request 1 states.
    [1579019015981] Request 5 states.
    [1579019016115] Request 9 states.
    [1579019016238] Request 12 states.
    [1579019016383] Request 8 states.
    [1579019016464] Request 3 states.
    [1579019016502] Request 3 states.
    [1579019016564] Request 6 states.
    Unlocalized string: vs_editor_contrib_find_browser_findWidget_13
    ScroungerS Offline
    ScroungerS Offline
    Scrounger
    schrieb am zuletzt editiert von Scrounger
    #479
    @Oli sagte in Test Adapter Material Design Widgets v0.2.x:
    @Scrounger
    Chrome, sieht aus wie im geposteten Edit Modus
    Also log sieht gut aus. Chrome ist allerdings bissle schwierig vorallem in Grenzfällen. Versuch mal die Höhe der eingebundenen Views um 1-2px zu erhöhen bzw. zu reduzieren. Oder ordne die views anders an, also änder die Reihenfolge.
    Wenn das auch nichts bringt, kannst mal per css noch folgendes versuchen:
    .materialdesign-masonry-container{
      orphans: 1 !important;
      widows: 1 !important;
    Beide Werte gleich erhöhen. Damit steuert man bei chrome wieviele zeilen mindestens angzeigt werden müssen.
    Oder du machst mir ein Beispielprojekt, weil ich kann den Fehler nicht reproduzieren, ist zu speziell ;)
    • ScroungerS Scrounger
      Auf vielfachen Wunsch, Input Widget ist fertig -> master testen v0.2.40
      Schaut euch das online Beispiel an!
      Date und Time Picker kann ich nicht verändern, da werden die vom System genommen (Browser, Android, ios, etc.)
      Weiter kann man jetzt beim Masonry Widget Auflösungen (Breite) für Handy und Tablet definieren, jeweils für Hoch- und Querformat und dann gezielt die Anzahl der Spalten und Abstand einstellen. Kann man aber auch alles nicht konfigurieren, dann werden default einstellungen verwendet.
      Um das einfach zu konfigurieren könnt ihr euch eine Card einblenden lassen, wo alle notwendigen Infos zur konfiguration stehen:
      d3763f01-61cb-4873-9463-b225c34556a8-grafik.png688cda25-8ded-4a21-a101-1bdb4faf936a-grafik.png
      @Oli
      Teste bitte nochmal diese Version, hab da noch was gefixt. Edge sollte jetzt auch wieder gehen.
      Und ganz wichtig - wie sieht es zur runtime aus und was steht zur runtime in der console.
      Diese Infos brauch ich,da beim Editor nicht immer alles korrekt dargestellt bzw. andere punkte mit reinspielen können!
      sigi234S Online
      sigi234S Online
      #480
      @Scrounger sagte in Test Adapter Material Design Widgets v0.2.x:
      Coole , Danke.
      Frage, gibt es eine Möglichkeit mehrere vordefinierte Texte zu erstellen?
      ScroungerS 1 Antwort Letzte Antwort
      • sigi234S sigi234
        Coole , Danke.
        ScroungerS Offline
        ScroungerS Offline
        Scrounger
        #481
        @sigi234 sagte in Test Adapter Material Design Widgets v0.2.x:
        Versteh ich nciht wie du das genau meinst
        O sigi234S 2 Antworten Letzte Antwort
          O Online
          O Online
          Oli
          #482
          @Scrounger
          mit Google scheint gar nichts richtig zu funktionieren, der erkennt nicht mal die aktuelle Spaltenanzahl
          Oliver
          • O Oli
            @Scrounger
            ScroungerS Offline
            ScroungerS Offline
            Scrounger
            #483
            @Oli
            Das bezweifle ich, da ich das selbst mit Chrome hoch und runter getestet habe.
            Hast du meine oben angemerkten Punkte mal probiert?!
            Mach doch einfach ein Beispiel Projekt, wo das Problem auftritt, dann kann ich mir es anschauen.
              sigi234S Online
              sigi234S Online
              #484
              Sowie ein select value list
              • sigi234S sigi234
                ScroungerS Offline
                ScroungerS Offline
                Scrounger
                #485
                Du meinst autocomplete?
                  sigi234S Online
                  sigi234S Online
                  #486
                  @Scrounger
                  Jupp, autocomplete
                  • sigi234S sigi234
                    @Scrounger
                    Jupp, autocomplete
                    ScroungerS Offline
                    ScroungerS Offline
                    Scrounger
                    #487
                    @sigi234
                    Klar würde gehen. Ich selber hab aber keine Anwendungsfall dafür. Außer du gibts mir jetzt ne zündende idee ;)
                    sigi234S O 3 Antworten Letzte Antwort
                      @sigi234
                      sigi234S Online
                      sigi234S Online
                      #488
                      @sigi234
                      Ich nehme dein Widget für die Anfrage an einen Echo-Dot. Da habe ich immer die selben eingaben.
                      Also:
                      Wie ist das Wetter
                      Wie spät ist es
                      Wie ist der Verkehr
                      Usw....
                        @sigi234
                        O Online
                        O Online
                        Oli
                        schrieb am zuletzt editiert von Oli
                        #489
                        @Scrounger
                        würde ich dir gerne, ist aber zu groß, sind 16Mb
                        Oliver
                        • O Oli
                          @Scrounger
                          sigi234S Online
                          sigi234S Online
                          #490
                          Als Zip?
                          O 1 Antwort Letzte Antwort
                          • sigi234S sigi234
                            Als Zip?
                            O Online
                            O Online
                            Oli
                            #491
                            @sigi234
                            die 16Mb sind ja schon als Zip, weis gar nicht was da so groß ist
                            Oliver
                              @sigi234
                              O Online
                              O Online
                              Oli
                              #492
                              @Scrounger
                              hier mein Beispiel Projekt, auch mit den Button die unter der Navigation nicht funktionieren
                              2020-01-14-Wetter.zip
                              Oliver
                              • sigi234S sigi234
                                @sigi234
                                Also:
                                Wie ist das Wetter
                                Wie spät ist es
                                Wie ist der Verkehr
                                Usw....
                                ScroungerS Offline
                                ScroungerS Offline
                                Scrounger
                                #493
                                Also:
                                Wie ist das Wetter
                                Wie spät ist es
                                Wie ist der Verkehr
                                Usw....
                                Wieso machst des nicht per Spracheingabe? Bzw. das Select Widget ist doch super dafür. Daneben packst dann noch das Input Widget, falls du mal andere eingaben tätigen willst.
                                Du siehst schon noch nicht die zündende Idee für mich ;)
                                @intruder7 sagte in Test Adapter Material Design Widgets v0.2.x:
                                eingetragen um Bytes in MegaBytes umzurechnen. Dieses führte allerdings zu einem NaN.😞
                                Habs korrigiert, aktuellen master testen
                                • D Online
                                  D Online
                                  darkiop
                                  #494
                                  Danke für das Input Widget, schau ich mir die Tage auch mal an :)
                                  Beim Slider ist mir aufgefallen, das der vorangestellte Text nicht über die Widget Optionen gefärbt werden kann. Unter 'Beschriftung' gibt es auch aktuell keine Option für die Schriftfarbe. Ich kann das über CSS überschreiben, aber ist das so gewollt?
                                  Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                                  • D darkiop
                                    ScroungerS Offline
                                    ScroungerS Offline
                                    Scrounger
                                    #495
                                    @darkiop
                                    Stimmt Bau ich ein
                                      @Zipkart sagte in Test Adapter Material Design Widgets v0.2.x:
                                      1. Wie kann ich Icons einfärben?
                                      Geht nicht, musst du entsprechend die grafik davor bearbeiten und dann einfügen. Evtl. geht das auch per css, hab ich aber noch nicht probiert.
                                      1. Kann man Icons auch vertikal zentrieren?
                                      Button vertical:
                                      Beispiel gibts dafür auch im Online Example Project
                                      1. Ich habe über den Adapter vis-material-webfont adapter for ioBroker zusätzliche Icons installiert diese werden mit dem folgenden Befehl Eingebunden.
                                        Weiß jemand wie man an der Stelle auch die Frage, zentrieren oder ähnliches per Befehl einbinden kann?
                                      z.b. so
                                      <span class="mdi mdi-power" style="text-align: center;"></span>
                                      @Maverick78 sagte in Test Adapter Material Design Widgets v0.2.x:
                                      Ich nutze ein Material Design Bar Chart aus Einzelobjekten. Ich bekomme es einfach nicht hin das der Barchart nach Höhe der Werte eingefärbt wird.
                                      Geht mit binding, du musst z.B. folgendes
                                      {wert:0_userdata.0.material-design-widgets.Chart.val0;wert > 70 ? "#ff0000" :: wert > 60 ? "#FFFF00" :: "#85888a"}
                                      bei Farbe des entsprechenden Datensatzes eintragen
                                      Außerdem hätte ich die x-Werte auch gerne Datenobjekten zugewiesen.
                                      Geht auch per binding, z.B.
                                      Zum thema binding, am besten hier mal einlesen https://github.com/ioBroker/ioBroker.vis
                                      und im Forum suchen, gibt sehr viele Beispiele.
                                      Maverick78
                                      #496
                                      @Scrounger said in Test Adapter Material Design Widgets v0.2.x:
                                      Das habe ich bereits probiert, funktioniert aber nicht.
                                      • M Maverick78
                                        ScroungerS Offline
                                        ScroungerS Offline
                                        Scrounger
                                        #497
                                        @Maverick78
                                        bindings werden nur zur runtime angezeigt und nicht im Editor.
                                          @Maverick78
                                          Maverick78
                                          schrieb am zuletzt editiert von Maverick78
                                          #498
                                          @Scrounger danke!
                                          Hab es hinbekommen!
