  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    apollon77A
3.8k Beiträge 469 Kommentatoren 2.6m Aufrufe 414 Beobachtet
  • eumatsE
    eumatsE
    eumats
    schrieb am zuletzt editiert von eumats
    Hallo.
    Der Adapter läuft bei mir zwar stabil, aber ich bekomme sporadisch die folgende Fehlermeldung:
    host.iobroker-server	2019-12-04 14:03:15.398	info	Restart adapter system.adapter.vw-connect.0 because enabled
    host.iobroker-server	2019-12-04 14:03:15.397	error	instance system.adapter.vw-connect.0 terminated with code 156 (156)
    vw-connect.0	2019-12-04 14:03:14.889	info	(23863) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    vw-connect.0	2019-12-04 14:03:14.889	warn	(23863) Restart initiated
    vw-connect.0	2019-12-04 13:08:39.719	error	at endReadableNT (_stream_readable.js:1143:12)
    vw-connect.0	2019-12-04 13:08:39.719	error	at IncomingMessage.emit (events.js:203:15)
    vw-connect.0	2019-12-04 13:08:39.719	error	at Object.onceWrapper (events.js:286:20)
    vw-connect.0	2019-12-04 13:08:39.719	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
    vw-connect.0	2019-12-04 13:08:39.719	error	at Request.emit (events.js:198:13)
    vw-connect.0	2019-12-04 13:08:39.719	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
    vw-connect.0	2019-12-04 13:08:39.719	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    vw-connect.0	2019-12-04 13:08:39.719	error	at Request.request.post [as _callback] (/opt/iobroker/node_modules/iobroker.vw-connect/main.js:511:26)
    vw-connect.0	2019-12-04 13:08:39.719	error	at JSON.parse (<anonymous>)
    vw-connect.0	2019-12-04 13:08:39.719	error	(22493) SyntaxError: Unexpected end of JSON input
    vw-connect.0	2019-12-04 13:08:39.718	error	(22493)
    vw-connect.0	2019-12-04 13:08:39.718	error	(22493) SyntaxError: Unexpected end of JSON input
    vw-connect.0	2019-12-04 13:08:39.718	error	(22493) Failing to parse refresh token. Restart instance for relogin.
    Soll ich einen issue bei github aufmachen?
    AlCalzoneA T 2 Antworten Letzte Antwort
    • eumatsE eumats
      Hallo.
      AlCalzoneA
      AlCalzoneA
      AlCalzone
      @eumats sagte in Test Adapter VW Connect v0.0.x:
      Die Instanz erkennt ein Problem startet sich selbst neu. Der Fehler sollte ggf. einfach verschluckt werden und die Meldung als Warn/Info ausgegeben werden.
      • eumatsE eumats
        Hallo.
        T
        T
        tombox
        @eumats Installiere bitte die aktuelle github version und starte die instanz neu. Ich habe in letzter Zeit das handling verbessert. Dann sollten auch aussagekräftiger Logs produziert werden die du dann hier posten kannst. Die Errors Ausgaben werden wahrscheinlich noch reduziert werden, da die VW Server doch relativ instabil sind.
        eumatsE 1 Antwort Letzte Antwort
        • T tombox
          eumatsE
          eumatsE
          eumats
          @tombox sagte in Test Adapter VW Connect v0.0.x:
          Alles klar. Mache ich und melde dann wenn wieder was auftritt.
          • AtzeAckermannA AtzeAckermann
            Ok. dann habe ich wahrscheinlich was falsch verstanden:
            Also ich habe einen VW Touran BJ 2019 mit Standheizung. Diese kann ich in der App auch starten.
            Einen Ordner unter climate finde ich nicht...
            T
            T
            tombox
            @AtzeAckermann Das mit der Standheizung war verdammt knifflig aber ich habe mal eine neu Version erstellt die Standheizung und Lock/Unlock machen kann, wenn man den pin in den optionen hinterlegt. Ich konnte es leider nicht erfolgreich testen da es in der App auch nicht funktionierte.
            • AtzeAckermannA
              AtzeAckermannA
              AtzeAckermann
              Cool! Danke schön!!!!
              Ich werde es testen aktuell scheinen aber die VW Servies eh etwas unverläßlich zu sein. Und wir haben ein Limit getroffen: "Batterieschutz aktiviert
              Die maximale Anzahl an Aktionen wurde erreicht. Um Ihre Fahrzeugbatterie zu schonen, wurde vorübergehend ein Batterieschutz aktiviert. Sie können den Batterieschutz deaktivieren, indem Sie die Zündung Ihres Fahrzeugs Touran einmal an- und ausschalten."
              • T tombox
                @Alexxx2005
                on('vw-connect.0.XYZXXXXXX.position.carCoordinate.latitude',function(obj){
                   setState("latitude", obj.state.val / 1000000)
                M
                M
                micwit
                schrieb am zuletzt editiert von micwit
                @tombox said in Test Adapter VW Connect v0.0.x:
                Die Koordinaten umrechnen
                kannmir das einer erklären, bzw sagen wie und wo ich die in VIS eintrage?
                AlCalzoneA T A 3 Antworten Letzte Antwort
                • M micwit
                  AlCalzoneA
                  AlCalzoneA
                  AlCalzone
                  @micwit Siehe meinen Kommentar:
                  @AlCalzone sagte in Test Adapter VW Connect v0.0.x:
                  @Alexxx2005 Du kannst im Skripte-Adapter ein Skript bauen, was auf Änderungen des Datenpunkts lauscht, den Inhalt durch 1000000 (edit: zu wenige Nullen) teilt und das Ergebnis davon in einen anderen Datenpunkt deiner Wahl schreibt.
                  Diesen Ziel-Datenpunkt trägst du in VIS ein.
                  • M micwit
                    T
                    T
                    tombox
                    @micwit Was möchtest du denn genau in der Vis darstellen? Nur Lat Long Werte?
                    • M micwit
                      A
                      A
                      Alexxx2005
                      schrieb am zuletzt editiert von Alexxx2005
                      @micwit
                      Da kann ich dir helfen , habe es erst die Tage gemacht...
                      Als ersten zu Objekte gehen, Javascript.0 markieren und oben auf das "+"
                      dann ein neuer Datenpunkt , Typ Zahl anlegen "latitude"
                      nach Bestätigung das % Zeichen entfernen
                      das selbe mit dem nächsten Datenpunkt "longitude" machen.
                      Im Reiter Skripte zwei Javaskripte erstellen eins für Latitude :
                      const idlatitude = "vw-connect.0.WAUZZZ****.position.carCoordinate.latitude"; // Datenpunkt-ID ist eine Konstante
                      var latitude = getState(idlatitude).val;  // Deklaration globale Variable und Initialisierung für Skriptstart
                      function calclatitude() {  // Umrechnen und in Datenpunkt schreiben
                         setState("javascript.0.latitude", parseFloat(latitude) / 1000000, true); // parseFloat nur erforderlich, wenn latitude ein String ist
                      calclatitude();  // Aufruf bei Skriptstart
                      on(idlatitude, function(data) {  // Triggern bei Wertänderung und Übergabe des Datenpunkt-Objektes an lokale Variable data
                         latitude = data.state.val;  // Wert des auslösenden Datenpunktes
                         calclatitude();
                         log('latitude wurde geändert');
                      und eins für longitude
                      const idlongitude = "vw-connect.0.WAUZZZ****.position.carCoordinate.longitude"; // Datenpunkt-ID ist eine Konstante
                      var longitude = getState(idlongitude).val;  // Deklaration globale Variable und Initialisierung für Skriptstart
                      function calclongitude() {  // Umrechnen und in Datenpunkt schreiben
                         setState("javascript.0.longitude", parseFloat(longitude) / 1000000, true); // parseFloat nur erforderlich, wenn longitude ein String ist
                      calclongitude();  // Aufruf bei Skriptstart
                      on(idlongitude, function(data) {  // Triggern bei Wertänderung und Übergabe des Datenpunkt-Objektes an lokale Variable data
                         longitude = data.state.val;  // Wert des auslösenden Datenpunktes
                         calclongitude();
                         log('longitude wurde geändert');
                      das war's
                      Grüße Alex
                      • A Alexxx2005
                        @micwit
                           calclatitude();
                           calclongitude();
                        das war's
                        Grüße Alex
                        T
                        T
                        tombox
                        @Alexxx2005
                        Den ersten Teil kann man im Skript am anfang mit
                        createState("longitude", 0);
                        realisieren
                        du solltest deine vin rausnehmen
                        Wenn euch das so wichtig ist mit dem long lat ist kann ich das in der nächsten version noch reinnehmen
                        • T tombox
                          @Alexxx2005
                          realisieren
                          A
                          A
                          Alexxx2005
                          @tombox
                          ok schon wieder was gelernt :-)
                          ja wenn man Open Street Map machen will braucht man es.
                          Grüße Alex
                          • A Alexxx2005
                            @tombox
                            Grüße Alex
                            T
                            T
                            tombox
                            @tombox Habe mal die convertierung in die github version eingebaut.
                            Bitte auch mal testen ob die aktuelle Version noch funktioniert, da eine schwierige Abhängigkeit für die Standheizung und Öffnen /Schließen reingekommen ist.
                            • S
                              S
                              Sneak-L8
                              @AtzeAckermann sagte in Test Adapter VW Connect v0.0.x:
                              Ich vermute, dass liegt an der automatischen Aktualisierungsanforderung die tombox auf meinen Wunsch eingebaut hat, weil selbst die App selbst nicht immer aktuelle Daten liefert und man sie um ein Daten-Update bitten muss.
                              Das war aber wohl zu viel des Guten und führt zum Abschalten. Danach kommen glaube ich (zumindest aktuell bei mir) keine neuen Daten mehr. Auch nicht nach Neustart und nicht in der App.
                              Daher habe ich tombox gebeten, das wieder rauszunehmen oder nur z.B. alle Stunde zu machen.
                              • S Sneak-L8
                                T
                                T
                                tombox
                                @Sneak-L8 in der neuen Version ist es ein seperates interval. Aber Batterieschutz ist glaube ich was standheizung spezifisches
                                • cHefroCkerC
                                  cHefroCkerC
                                  cHefroCker
                                  kann mir jemand sagen, welches app bei skoda benötigt wird? ich habe daten vom 3.12, und etwa 3 oder 4 verschiedene skoda apps am laufen, trotzdem will er mir die fahrdaten nicht aktualisieren. ich habe jedes app aktiv geöffnet, und mir einen telegram alarm eingerichtet um über neue daten informiert zu werden
                                  • cHefroCkerC cHefroCker
                                    T
                                    T
                                    tombox
                                    @Sandro-Ballarini Ich habe mit der Android 3.1.6 skoda connect gearbeitet. Zum testen einfach alle apps beenden. Zündung ein aus. Instanz stoppen über github neuinstallieren und Instanz starten.
                                    • R
                                      R
                                      RichieXX
                                      schrieb am zuletzt editiert von RichieXX
                                      Bin geeade beim Testen mit einem Skoda BJ 2019. Wenn ich die Standheizung auf true (vw-connect.0.TMBXXXXXXXXXXXX.remote.standheizung) setze, bkomme ich den Fehler "No Security information found" und "The Security PIN is currently locked" im Log. Hab ich bei der Einrichtung etwas vergessen? Benutzer und Passwort habe ich eingetragen und die den Type auf SKODA gestellt.
                                      • R RichieXX
                                        T
                                        T
                                        tombox
                                        @RichieXX hi du hast sicher in den Einstellungen den PIN eingegeben und er funktioniert in der App? Ich brauche mal die komplette Fehlermeldung und vielleicht auf debug die Instanz stellen für mehr Informationen.
                                        • R
                                          R
                                          RichieXX
                                          Ich habe nur Benutzername und Passwort. Wo bekomme ich die S-PIN her?
                                          83.9k
