  4. Hilfe nach Umzug von raspbian auf VM (Debian)
proxmox debian npm familyexit-codeadmin adapter
40 Beiträge 6 Kommentatoren 2.5k Aufrufe 5 Beobachtet
  • S schneidy76
    @Homoran
    root@192.168.0.172's password:
    Linux debian 4.19.0-6-686-pae #1 SMP Debian 4.19.67-2+deb10u2 (2019-11-11) i686
    permitted by applicable law.
    Last login: Wed Nov 27 22:23:33 2019 from 192.168.0.130
    root@debian:~# curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
    ## Installing the NodeSource Node.js 10.x repo...
    ## Populating apt-get cache...
    + apt-get update
    OK:1 http://security.debian.org/debian-security buster/updates InRelease
    OK:2 http://deb.debian.org/debian buster InRelease
    OK:3 http://deb.debian.org/debian buster-updates InRelease
    OK:4 https://deb.nodesource.com/node_10.x buster InRelease
    ## Confirming "buster" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_10.x/dists/buster/Rele        ase'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
    OK
    ## Creating apt sources list file for the NodeSource Node.js 10.x repo...
    + echo 'deb https://deb.nodesource.com/node_10.x buster main' > /etc/apt/sources        .list.d/nodesource.list
    + echo 'deb-src https://deb.nodesource.com/node_10.x buster main' >> /etc/apt/so        urces.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    ## Run `sudo apt-get install -y nodejs` to install Node.js 10.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
         echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/s        ources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    root@debian:~# sudo apt install -y nodejs
    Die folgenden zusätzlichen Pakete werden installiert:
      libc-ares2 libnode64 libuv1 nodejs-doc
    Vorgeschlagene Pakete:
      npm
    Die folgenden NEUEN Pakete werden installiert:
      libc-ares2 libnode64 libuv1 nodejs nodejs-doc
    0 aktualisiert, 5 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
    Es müssen noch 0 B von 6.913 kB an Archiven heruntergeladen werden.
    Nach dieser Operation werden 29,6 MB Plattenplatz zusätzlich benutzt.
    Vormals nicht ausgewähltes Paket libc-ares2:i386 wird gewählt.
    (Lese Datenbank ... 35121 Dateien und Verzeichnisse sind derzeit installiert.)
    Vorbereitung zum Entpacken von .../libc-ares2_1.14.0-1_i386.deb ...
    Entpacken von libc-ares2:i386 (1.14.0-1) ...
    Vormals nicht ausgewähltes Paket libuv1:i386 wird gewählt.
    Vorbereitung zum Entpacken von .../libuv1_1.24.1-1_i386.deb ...
    Entpacken von libuv1:i386 (1.24.1-1) ...
    Vormals nicht ausgewähltes Paket libnode64:i386 wird gewählt.
    Vorbereitung zum Entpacken von .../libnode64_10.15.2~dfsg-2_i386.deb ...
    Entpacken von libnode64:i386 (10.15.2~dfsg-2) ...
    Vormals nicht ausgewähltes Paket nodejs wird gewählt.
    Vorbereitung zum Entpacken von .../nodejs_10.15.2~dfsg-2_i386.deb ...
    Entpacken von nodejs (10.15.2~dfsg-2) ...
    Vormals nicht ausgewähltes Paket nodejs-doc wird gewählt.
    Vorbereitung zum Entpacken von .../nodejs-doc_10.15.2~dfsg-2_all.deb ...
    Entpacken von nodejs-doc (10.15.2~dfsg-2) ...
    libc-ares2:i386 (1.14.0-1) wird eingerichtet ...
    libuv1:i386 (1.24.1-1) wird eingerichtet ...
    libnode64:i386 (10.15.2~dfsg-2) wird eingerichtet ...
    nodejs-doc (10.15.2~dfsg-2) wird eingerichtet ...
    nodejs (10.15.2~dfsg-2) wird eingerichtet ...
    update-alternatives: /usr/bin/nodejs wird verwendet, um /usr/bin/js (js) im auto        matischen Modus bereitzustellen
    Trigger für libc-bin (2.28-10) werden verarbeitet ...
    Trigger für man-db (2.8.5-2) werden verarbeitet ...
    root@debian:~# sudo reboot
    login as: root
    Last login: Wed Nov 27 22:38:48 2019 from 192.168.0.130
    root@debian:~# npm -v
    -bash: npm: Kommando nicht gefunden.
    root@debian:~# sudo -H npm install -g npm@6
    sudo: npm: Befehl nicht gefunden
    root@debian:~# node -v
    v10.15.2
    aber warum???
    BBTownB Offline
    BBTownB Offline
    BBTown
    @schneidy76 und NPM sollte bei der Installation von node automatisch mit installiert werden
    • BBTownB BBTown
      schneidy76
      @BBTown
      ja sollte
      apt install -y npm
      bringt wenigstens npm 5.8.0 hervor
      Raspberry Matic (RP3), LIVE PV Monitoring mit Smartmeter, Poolsteuerung mit NodeRed, KNX Ausbau (ersetzt stückweise HM & klassische Installation), ioBroker Multihost (RP4 &RP2), Visu mit VIS
      BBTownB 1 Antwort Letzte Antwort
      • S schneidy76
        @BBTown
        ja sollte
        apt install -y npm
        BBTownB Offline
        BBTownB Offline
        BBTown
        @schneidy76 sagte in Hilfe nach Umzug von raspbian auf VM (Debian):
        ja sollte
        ich wollte damit @Homoran Antwort untermauern, dass wahrscheinlich etwas mit der Ausgangslage bzw. deinem System nicht stimmt
        • BBTownB BBTown
          ja sollte
          schneidy76
          @BBTown
          danke Dir, aber die VM ist brandneu aufgesetzt
          kein Plan im Moment
          • S schneidy76
            @BBTown
            kein Plan im Moment
            BBTownB Offline
            BBTownB Offline
            BBTown
            schrieb am zuletzt editiert von BBTown
            @schneidy76 mit welchem Betriebssystem und in welcher Version?
            • BBTownB BBTown
              schneidy76
              schrieb am zuletzt editiert von schneidy76
              @BBTown
              in proxmox - als Basis den net Installer nur ssh Dienste und die Basisinstallation
              curl mit sudo apt install -y curl installiert
              Ich habe das hier noch gefunden:
              Wir installieren sudo mit dem Befehl „apt-get install -y sudo„
              Nun fügen wir unseren selbst angelegten User mit „adduser <<username>> sudo“ (z.B. „adduser dhecker sudo„) hinzu
              wir starten nun den Server mit dem Befehl „reboot“ neu und loggen uns danach wieder ein
              nun werden einige benötigte Tools installiert. Einfach diese Befehle ausführen:
              sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs curl software-properties-common
              curl -sL https://deb.nodesource.com/setup_6.x | sudo bash
              sudo npm install -g npm
              Stammt aus von dieser Anleitung
              klick
              Das weicht allerdings von der Anleitung in der Doku ab.
              Könnte es helfen?
              VG Torsten
              • S schneidy76
                @BBTown
                klick
                Könnte es helfen?
                VG Torsten
                @schneidy76
                Ist das debian netinstall amd64?
                  @schneidy76
                  schneidy76
                  @Homoran glaube ja, sitze jetzt nicht davor
                  vpn sei Dank: debian-10.2.0-i386-netiso.iso
                  • S schneidy76
                    @BBTown
                    klick
                    Könnte es helfen?
                    VG Torsten
                    Bitte keine externen (veralteten) Anleitungen verwenden.
                    Debian wird ganz normal in der VM installiert. Einige fehlenden Pakete müssen nachinstalliert werden (curl, Sudo...)
                    Anschließend wird nodejs und iobroker nach der offiziellen Anleitung ganz normal installiert.
                      schneidy76
                      @Homoran okay, aber wie bekomme ich jetzt die richtige node, nodejs und npm drauf??? ❔
                      • S schneidy76
                        sigi234S Online
                        sigi234S Online
                        https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
                        • sigi234S sigi234
                          schneidy76
                          @sigi234
                          komme nicht über 10.15.2 (node & nodejs) hinaus
                          npm 5.8.0
                          nochmal rollback auf debian frisch ohne alles - auch ohne curl Installation
                          Anmelden als root
                          also dann:
                          apt-get install -y curl
                          dann
                          curl -sL https://deb.nodesource.com/setup_10.x | bash -
                          bringt node & nodejs, aber kein npm!!!
                          apt install -y npm
                          • S schneidy76
                            @sigi234
                            npm 5.8.0
                            Anmelden als root
                            also dann:
                            dann
                            apt install -y npm
                            welche versionen?
                              welche versionen?
                              schneidy76
                              @Homoran node & nodejs 10.15.2
                              npm 5.8.0
                              • S schneidy76
                                npm 5.8.0
                                MK-66
                                @schneidy76
                                Du musst auf jeden Fall Debian ... amd64 installieren. Mit Debian i386 lassen sich die nodejs und npm Versionen nicht korrekt installieren... Diese Erfahrung habe zumindest ich gemacht.
                                HomoranH S 2 Antworten Letzte Antwort
                                • M MK-66
                                  @schneidy76
                                  @MK-66 sagte in Hilfe nach Umzug von raspbian auf VM (Debian):
                                  Davon bin ich jetzt ausgegangen.
                                  Deswegen hatte ich ja auch nachgefragt
                                  • M MK-66
                                    @schneidy76
                                    schneidy76
                                    @MK-66 muss man ja auch wissen , Danke 👍
                                      schneidy76
                                      Super, jetzt funktioniert alles soweit, bis auf die Multihost Umgebung.
                                      Bekomme den RP nicht verbunden. Egal was und wie ich es tue:
                                      No connection to states 192.168.0.115:6379[redis]
                                      Es scheint, als wenn proxmox den Port blockiert. Aber den 8081 kann ich ja aufrufen, denn ich komme per Http ja auf die Weboberfläche vom Master...
                                      • S schneidy76
                                        @schneidy76
                                        Doku gelesen?
                                        https://www.iobroker.net/#de/documentation/config/multihost.md
                                          @schneidy76
                                          Doku gelesen?
                                          schneidy76
                                          @Homoran Danke für den Tritt!!!
                                          bind 0.0.0.0 war es
