  4. Adapter: iobroker.backitup (stable Release)
adapterbackitupiobroker backupbackupiobroker.backitup
2.3k Beiträge 185 Kommentatoren 1.6m Aufrufe 50 Beobachtet
  • S stoffel67
    habe heute den Backitup-adapter "upgedated", und nun läuft er nicht mehr!
    bekomme folgende Fehlermeldung im Log:
    host.raspiP
    2019-11-26 09:05:22.485
    error
    instance system.adapter.backitup.0 terminated with code 1 ()
    Caught
    error
    by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.backitup/node_modules/googleapis/build/src/index.js:19:22)
    Caught
    error
    by controller[0]: at require (internal/module.js:20:19)
    Caught
    error
    by controller[0]: at Module.require (module.js:504:17)
    Caught
    error
    by controller[0]: at Function.Module._load (module.js:445:3)
    Caught
    2019-11-26 09:05:22.484
    error
    by controller[0]: at tryModuleLoad (module.js:453:12)
    Caught
    error
    by controller[0]: at Module.load (module.js:494:32)
    Caught
    error
    by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    Caught
    error
    by controller[0]: at Module._compile (module.js:549:28)
    Caught
    error
    by controller[0]: at Object.runInThisContext (vm.js:97:10)
    Caught
    error
    by controller[0]: at createScript (vm.js:56:10)
    Caught
    error
    by controller[0]: SyntaxError: Unexpected identifier
    Caught
    2019-11-26 09:05:22.483
    error
    by controller[0]: ^^^^^^^^^^^^^
    Caught
    error
    by controller[0]: async discoverAsync(url) {
    Caught
    2019-11-26 09:05:22.482
    error
    by controller[0]: /opt/iobroker/node_modules/iobroker.backitup/node_modules/googleapis/build/src/googleapis.js:93```
    simatecS Offline
    simatecS Offline
    simatec
    #2177
    @stoffel67
    Welche Node Version hast du installiert?
    Das sieht ganz nach einer Version < 8 aus.
    Seit geraumer zeit wird Node < 8 nicht merh unterstützt, da die Google Drive Api Minimum Node 8 fordert
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
      stoffel67
      #2178
      Ohh, gute Frage...
      node --version bringt: v6.14.1
      was muss ich da machen... node --update?
      Mein Adapter: JUNG/GIRA eNet-Adapter
      • S stoffel67
        Ohh, gute Frage...
        simatecS Offline
        simatecS Offline
        simatec
        #2179
        @stoffel67
        ja mach ein node Update.
        Node 10 ist aktuell die sinnvollste Version.
        https://forum.iobroker.net/post/266625
        • simatecS simatec
          @stoffel67
          stoffel67
          schrieb am zuletzt editiert von stoffel67
          #2180
          @simatec
          OHje... habe ein
          curl -sL https://deb.nodesource.com/setup_10.x |sudo -E bash
          dann
          sudo apt-get install -y nodejs
          dannach iobroker gestartet...
          jetzt hagelt es nur noch Fehler im LOG!
          host.raspiP
          2019-11-26 10:51:08.446
          error
          instance system.adapter.yahka.0 terminated with code 1 ()
          host.raspiP
          error
          Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
          host.raspiP
          error
          Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
          host.raspiP
          error
          Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/ed25519-hap/index.js:1:37)
          host.raspiP
          error
          Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:76:44)
          host.raspiP
          error
          Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
          host.raspiP
          2019-11-26 10:51:08.445
          error
          Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
          host.raspiP
          error
          Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
          host.raspiP
          error
          Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
          host.raspiP
          error
          Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
          host.raspiP
          error
          Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
          host.raspiP
          error
          Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
          host.raspiP
          error
          Caught by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
          host.raspiP
          error
          Caught by controller[0]: NODE_MODULE_VERSION 48. This version of Node.js requires
          host.raspiP
          error
          Caught by controller[0]: was compiled against a different Node.js version using
          host.raspiP
          error
          Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/ed25519-hap/build/Release/ed25519.node'
          host.raspiP
          error
          Caught by controller[0]: ^
          host.raspiP
          error
          Caught by controller[0]: throw e
          host.raspiP
          2019-11-26 10:51:08.442
          error
          Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:83
          kann ich/ muß ich hier auf eine ältere Version????
          • E Offline
            Einstein67
            schrieb am zuletzt editiert von Einstein67
            #2181
            Erstmal Vielen Dank für die Version 1.30! Das History Backup/Restore funktioniert total SUPER!
            Ich hab ein kleines Problem mit den Passwörtern von Wiederhergestellten Adaptern/Instanzen.
            Zum Beispiel beim Adapter Sonoff wird das MQTT-Passwort zwar wiederhergestellt, allerdings falsch. Auch bei BackitUp passiert das selbe mit dem Passwort für den SMB-Mount.
            Mach ich da irgendwas falsch, oder ist dieses Verhalten (aus Sicherheitsgründen) sogar gewünscht?
            • E Einstein67
              stoffel67
              #2182
              so hab jetzt auch beim YAHKA Adapter ein rebuild gemacht, scheint jetzt auch wieder zu laufen...
              allerdings macht der Backit-up Adapter nur noch ein "Standrad"(Minimal-backup)
              das ist bei mir ca. 2MB groß, vorher war ein full-backup 160MB groß
              wie bekomm ich wieder ein Full-Backup?
              Ich hätte schon gern alles gesichert?
              simatecS M 2 Antworten Letzte Antwort
              • S stoffel67
                simatecS Offline
                simatecS Offline
                simatec
                #2183
                @stoffel67
                Full Backups werden nicht mehr unterstützt und werden auch nicht benötigt.
                Das Standard Backup beinhaltet alles, was man braucht
                -1
                • simatecS simatec
                  @stoffel67
                  stoffel67
                  #2184
                  @simatec
                  OK, dh. da ist alles drin was ich für die Widerherstellung meiner ioBroker-Inst. brauche?😮
                  wieso die Größenunterschiede?
                  • S stoffel67
                    @simatec
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #2185
                    @stoffel67
                    Genau und falls du redis, Zigbee oder mysql nutzt, kannst du in backitup dafür die Extra Backups aktivieren
                    • simatecS simatec
                      @stoffel67
                      stoffel67
                      #2186
                      @simatec
                      nee die nutz ich aktuell nicht, aber ganz wichtig Javascript-Scripte und vor allem YAHKA ( sonst "tillt" meine bessere Hälfte)😀
                      • H Henny112
                        @MathiasJ sagte in Adapter: iobroker.backitup (stable Release):
                        @Henny112
                        ich habe eine Instanz, mit der die Backups auf der Dropbox und Googledrive gesichert werden.
                        Bei mir wird zusätzlich noch auf der NAS und auf der Fritzbox gesichert.
                        Sobald die 90 Backups erreicht wurden, leere ich die Dropbox und Googledrive indem ich alle Backups
                        auf einer externen Festpatte sichere.
                        Ich denke, sicherer geht's nimmer.
                        Ah okay. Und das machst du alles mit einer Instanz des Adapter? Aber man kann doch auch einstellen nach 10 löschen immer oder. Also die alten löschen kann man doch einstellen.
                        MathiasJM Offline
                        MathiasJM Offline
                        MathiasJ
                        #2187
                        @Henny112
                        Ja kann man, ist aber so gewollt.
                        IObroker auf dem NUC als VM.
                        H 1 Antwort Letzte Antwort
                        • MathiasJM MathiasJ
                          @Henny112
                          Henny112
                          #2188
                          @MathiasJ danke ich teste das mal.
                            Alexxx2005
                            #2189
                            wie erkenne ich wie weit ein wiederherstellen ist.
                            hab mich mal per sftp aufgeschalten , Logo's
                            unter vis.0. sind hergestellt in der Konsole dreht
                            sich der runde kreis mal rot mal grün.
                            Grüße Alex
                            • A Alexxx2005
                              Grüße Alex
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #2190
                              @Alexxx2005
                              Welche Version von Backitup ist installiert und wie lange läuft die Wiederherstellung schon?
                                Alexxx2005
                                #2191
                                das neuste was es derzeit in der adapter umgebung im iobroker gibt (kann grad nicht schauen) es läuft seit heute ca.: 16 Uhr , waren 15 Vis Seiten und um die 30 Instanzen (Adapter mit Logo und weiteres VIS Zubehör.
                                Grüße Aex
                                • A Alexxx2005
                                  Grüße Aex
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #2192
                                  @Alexxx2005
                                  Hast du Installer Fix vorher laufen lassen?
                                  Falls nein starte mal auf Konsole
                                  Sollte inzwischen fertig sein
                                    Alexxx2005
                                    #2193
                                    für ein Backup Newbie was is ein Installer Fix , wie kann ich es laufen lassen ?
                                    Nein habe es Zuvor nicht laufen lassen , ist das irgendwo dokumentiert wie man da vorgehen muss (richtige Reihenfolge) konnte da nichts finden, sorry
                                    Grüße Alex
                                    • A Alexxx2005
                                      Grüße Alex
                                      #2194
                                      @Alexxx2005 sagte in Adapter: iobroker.backitup (stable Release):
                                      Link steht bei @simatec im Footer
                                      der steht bei mir im Footer
                                      • opossumO Offline
                                        opossumO Offline
                                        opossum
                                        #2195
                                        Hallo @simatec ,
                                        habe das jetzt getestet. Leider keinen Erfolg. Hier meine Daten. Ich habe BackitUp so eingestellt, dass zu einer bestimmten Uhrzeit das Backup geschrieben wird. Über NAS/COPY habe ich eingestellt, dass das Backup noch nach /media/backup kopiert wird. Das klappt auch, nur wird die Backupdatei für das mysql-Backup noch nicht korrekt geschrieben.
                                        Hier der Screen für /opt/iobroker/backups:
                                        Hier ist der Zeitstempel für die Dateien einmal 27.11.2019 07:13:14 für das Minimalbackup, der Zeitstempel für das mysql-Backup ist der 27.11.2019 07:13:36
                                        Hier der Screen von /media/backup:
                                        Man sieht, dass die Dateien in /media/backup/ einen Zeitstempel vom 27.11.2019 07:13:24 besitzen.
                                        Aus meiner Sicht wird das mysql-Backup zu früh kopiert und damit dann in /media/backup unbrauchbar. Schaust Du Dir das bei Gelegenheit mal an. Hat keine Eile, da ich zur Zeit die Datenbank mit einem Script sichere.
                                        Läuft da bei mir vielleicht etwas auf dem NUC verkehrt? Rechte von /media/backup stehen auf 777.
                                        https://www.schlepper-petersdorf.de
                                        • opossumO opossum
                                          Hallo @simatec ,
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #2196
                                          @opossum
                                          Zeige mal bitte deine Einstellungen von NAS/Copy.
                                          Haste du den Installer Fix mal drüberlaufen lassen?
                                          Stelle die Instanz auch mal bitte auf debug und poste mal den log der Backuperstellung bitte hier.
                                          Ich schaue mir das auch gleich noch einmal an ...
