  4. Adapter: iobroker.backitup (stable Release)
adapterbackitupiobroker backupbackupiobroker.backitup
2.3k Beiträge 185 Kommentatoren 1.8m Aufrufe 50 Beobachtet
  • DiginixD Diginix
    @Rocket85
    ps aux | grep io.
    zeigt dir nach iobroker stop welche Zombi Adapter noch laufen.
    Diese kannst du dann versuchen zu beenden mit
    sudo pkill -f io.%adaptername%
    Noch härter wäre ansonsten
    sudo kill -9 %prozessid%
    Aber schon merkwürdig dass nach iobroker stop überhaupt noch was läuft.
    R
    R
    Rocket85
    #2143
    @Diginix sagte in Adapter: iobroker.backitup (stable Release):
    sudo pkill -f io.
    Vielen DANK, Fixen hat jetzt geklappt und einen anderen Fehler behoben, allerdings beim Backup kommt nun eine andere Fehlermeldung.
    Gestartet...
    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":null,"mount":" 192.168.178.49","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/usbshare1/ioBroker-Backup/Standard","dirMinimal":"/usbshare1/ioBroker-Backup/Standard","dirTotal":"/usbshare1/ioBroker-Backup/Komplett","user":"ioBroker-Backup","pass":"****"}
    [ERROR] [mount] - [undefined
    Usage:
    mount [-lhV]
    mount -a [options]
    mount [options] [--source] <source> | [--target] <directory>
    mount [options] <source> <directory>
    mount <operation> <mountpoint> [<target>]
    Mount a filesystem.
    Options:
    -a, --all mount all filesystems mentioned in fstab
    -c, --no-canonicalize don't canonicalize paths
    -f, --fake dry run; skip the mount(2) syscall
    -F, --fork fork off for each device (use with -a)
    -T, --fstab <path> alternative file to /etc/fstab
    -i, --internal-only don't call the mount.<type> helpers
    -l, --show-labels show also filesystem labels
    -n, --no-mtab don't write to /etc/mtab
    -o, --options <list> comma-separated list of mount options
    -O, --test-opts <list> limit the set of filesystems (use with -a)
    -r, --read-only mount the filesystem read-only (same as -o ro)
    -t, --types <list> limit the set of filesystem types
    --source <src> explicitly specifies source (path, label, uuid)
    --target <target> explicitly specifies mountpoint
    -v, --verbose say what is being done
    -w, --rw, --read-write mount the filesystem read-write (default)
    -h, --help display this help and exit
    -V, --version output version information and exit
    Source:
    -L, --label <label> synonym for LABEL=<label>
    -U, --uuid <uuid> synonym for UUID=<uuid>
    LABEL=<label> specifies device by filesystem label
    UUID=<uuid> specifies device by filesystem UUID
    PARTLABEL=<label> specifies device by partition label
    PARTUUID=<uuid> specifies device by partition UUID
    <device> specifies device by path
    <directory> mountpoint for bind mounts (see --bind/rbind)
    <file> regular file for loopdev setup
    Operations:
    -B, --bind mount a subtree somewhere else (same as -o bind)
    -M, --move move a subtree to some other place
    -R, --rbind mount a subtree and all submounts somewhere else
    --make-shared mark a subtree as shared
    --make-slave mark a subtree as slave
    --make-private mark a subtree as private
    --make-unbindable mark a subtree as unbindable
    --make-rshared recursively mark a whole subtree as shared
    --make-rslave recursively mark a whole subtree as slave
    --make-rprivate recursively mark a whole subtree as private
    --make-runbindable recursively mark a whole subtree as unbindable
    For more details see mount(8).
    • R Rocket85
      sudo pkill -f io.
      Gestartet...
      Usage:
      mount [-lhV]
      mount -a [options]
      Mount a filesystem.
      Options:
      Source:
      Operations:
      simatecS
      simatecS
      simatec
      #2144
      @Rocket85
      Bitte lest doch die Doku ... Diese Frage wurde hier schon sehr oft gestellt.
      Du hast das Paket cifs-utils nicht installiert
      sudo apt-get install cifs-utils
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • R
        R
        Rocket85
        #2145
        pi@raspberrypi:~ $ cd /opt/iobroker
        pi@raspberrypi:/opt/iobroker $ sudo apt-get install cifs-utils
        cifs-utils ist schon die neueste Version (2:6.7-1).
        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 94 nicht aktualisiert.
        scheint schon installiert gewesen zu sein
        • R Rocket85
          GlasfaserG
          GlasfaserG
          #2146
          @Rocket85 sagte in Adapter: iobroker.backitup (stable Release):
          Reboot schonmal durchgeführt?
          zeige mal die Ausgabe von :
          cat /proc/filesystems|grep cifs
          Wenn keine Ausgabe erfolgt ,dann neu installieren:
          sudo apt-get update && sudo apt-get dist-upgrade
          sudo apt purge cifs-utils
          sudo apt install cifs-utils
          Reboot
          • simatecS
            simatecS
            simatec
            #2147
            Ab sofort ist die finale Version 1.3.0 auf Github und in der latest Repro verfügbar.
            Es gab einige Änderungen, die hier mal im Detail aufgelistet werden.
            Changelog
            1.3.0 (22.11.2019)
            • (simatec) Support Ende für das total backup
            • (simatec) Backup des Historydaten Pfads hinzugefügt
            • (simatec) Starten aller Adapter nach der Wiederherstellung hinzugefügt
            • (simatec) Überarbeitung der Wiederherstellung für Redis
            • (simatec) Überarbeitung der Log Ausgaben
            • (simatec) Neuaufbau der Start/Stop Prozesse unter Unix
            • (simatec) Neuaufbau der Start/Stop Prozesse unter Windows
            • (simatec) neue Übersetzungen
            • (simatec) Anpassungen an den neuen Windows Installer
            • (simatec) Anpassungen an den neuen Linux Installer
            • (simatec) einige kleine Bugs behoben
            • simatecS simatec
              Changelog
              1.3.0 (22.11.2019)
              DiginixD
              DiginixD
              Diginix
              #2148
              @simatec sagte in Adapter: iobroker.backitup (stable Release):
              Changelog
              1.3.0 (22.11.2019)
              Ist damit z.b. dieser Pfad vom history Adapter gemeint, in dem die JSON Dateien aller Objekte liegen?
              /opt/iobroker/iobroker-data/history/
              Wir der dann komplett mit in das minimal Backup gezippt oder separat?
              ..:: So long! Tom ::..
              • DiginixD Diginix
                Changelog
                1.3.0 (22.11.2019)
                simatecS
                simatecS
                simatec
                #2149
                @Diginix
                Es wird der Pfad eingetragen, wo täglich deine Historydaten gespeichert werden.
                Dieser Pfad ist bei jedem User ein Anderer, da dieser im History Adapter individuell festgelegt werden kann.
                • simatecS simatec
                  @Diginix
                  DiginixD
                  DiginixD
                  Diginix
                  #2150
                  @simatec
                  Ok, also dann bei mir dann der genannte. Und was passiert nun damit?
                  • DiginixD Diginix
                    @simatec
                    simatecS
                    simatecS
                    simatec
                    #2151
                    @Diginix
                    Es wird eine separate tar.gz erzeugt.
                    Dort wird der komplette Inhalt deines History Pfades gesichert.
                    Somit sichert backitup mit dem Standard Backup alle relevanten Dinge, die für einen System Crash oder Umzug benötigt werden.
                    Im Detail:
                    • Iobroker Backup
                    • Redis Backup
                    • MySql Backup
                    • Zigbee Datenbank Backup
                    • History Daten Backup
                    Alle diese Backups können über das Webinterface von Backitup nacheinander wieder hergestellt werden.
                    Zusätzlich noch für Homematic User das CCU Backup, welches sich über das Webinterface der CCU wiederherstellen lässt.
                    • S
                      S
                      skokarl
                      #2152
                      @simatec, Ist die neue Version abwärtskompatibel ?
                      • S skokarl
                        simatecS
                        simatecS
                        simatec
                        #2153
                        @skokarl sagte in Adapter: iobroker.backitup (stable Release):
                        Abwärtskompatibel zu den erstellten Backups definitiv ja.
                        Abwärtskompatibel zu total backups aber nicht.
                        Da durch falsche Benutzung zu viele User ihre Probleme mit dem Total Backup hatten, wird dies nicht länger unterstützt.
                        S GlasfaserG 2 Antworten Letzte Antwort
                        • simatecS simatec
                          S
                          S
                          skokarl
                          #2154
                          @simatec
                          Danke, das Totale hab ich nie probiert, mit dem Standard bin ich hoch zufrieden !!!!
                          Super Arbeit ....
                          aber vielleicht mal eine Anregung für die nächste Version,
                          man weiß eigentlich nie wirklich wie weit er ist beim Restore, oder wielange es noch dauert.
                          Vielleicht kann man da irgendwas einbauen 😊
                          • S skokarl
                            @simatec
                            Super Arbeit ....
                            simatecS
                            simatecS
                            simatec
                            #2155
                            @skokarl
                            Das ist eher schwierig, da ja iobroker für den Restore gestoppt wird und der restore im Hintergrund läuft.
                            Ansich wurde aber der Restore Prozess mit dem Start / Stop Optionen überarbeitet und arbeitet nun zuverlässig.
                            Unter Linux kannst du mit htop das ganze aber beobachten.
                            Ansonsten ist der Restore durch, wenn iobroker wieder gestartet ist.
                            Da bekommst du dann auch die Log Ausgabe
                            • simatecS simatec
                              @skokarl
                              S
                              S
                              skokarl
                              #2156
                              @skokarl
                              Ah, ok.
                              • B
                                B
                                bishop
                                schrieb am zuletzt editiert von bishop
                                #2157
                                hallo,
                                hab seit paar Tagen das Problem das kein Backup mehr erstellt wird.
                                das backup ist 6kb gross mehr nicht.
                                in den logs steht
                                [DEBUG] [total/total] TAR started...
                                [DEBUG] [total/total] Ignore dir: /opt/iobroker/backups
                                [DEBUG] [total/total] Packed 0MB so far...
                                was läuft da schief?
                                HomoranH simatecS 2 Antworten Letzte Antwort
                                • B bishop
                                  hallo,
                                  in den logs steht
                                  #2158
                                  @bishop sagte in Adapter: iobroker.backitup (stable Release):
                                  seit paar Tagen
                                  Was hast du da geändert?
                                  • B bishop
                                    hallo,
                                    in den logs steht
                                    simatecS
                                    simatecS
                                    simatec
                                    #2159
                                    @bishop
                                    Welche Version ist installiert?
                                    Das total wird nicht mehr länger unterstützt und ist ab Version 1.3.0 nicht mehr verfügbar
                                    • B
                                      B
                                      bishop
                                      #2160
                                      @simatec
                                      ich habe die version 1.2.2 installiert.
                                      Oh warum wird es nicht mehr unterstützt?
                                      Wie kann ich dann eine Komplette Sicherung erstellen die ich dann bei einer frischen Iobroker Installation wieder einspielen kann?
                                      • simatecS simatec
                                        GlasfaserG
                                        GlasfaserG
                                        #2161
                                        @bishop
                                        • NegaleinN
                                          NegaleinN
                                          Negalein
                                          #2162
                                          Ich habe auch den FTP-Upload eingestellt, leider wird dieser nicht erstellt.
                                          Lokal wird das Backup tadellos angelegt.
                                          FTP-Daten stimmen.
                                          Liegt das nun am FTP-Server oder am Backitup?
                                          BackItUp:
                                          Das Backup wurde nicht vollständig erstellt. Bitte überprüfe die Fehlermeldungen!!
                                          ftp: Error: Logout.
                                          ° Fixer ---> iob fix
                                          33.2k
                                          84.4k
