  4. Proxmox Container - Backitup Restore klappt nicht
proxmox redis backitup
21 Beiträge 5 Kommentatoren 1.9k Aufrufe 3 Beobachtet
    @weidlix guck doch mal was
    iobroker status
    Zeigt
    simatecS Offline
    simatecS Offline
    simatec
    @crunchip
    Was sagt iobroker status
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • W Offline
      W Offline
      weidlix
      Restore 0 mit frischem Container sagt:
      oot@ioBrokerProd:/opt/iobroker/backups# cd ..
      root@ioBrokerProd:/opt/iobroker# iobroker restore 0
      Stop iobroker first!
      root@ioBrokerProd:/opt/iobroker# iobroker stop
      /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:568
              if (parseInt(name.trim(), 10).toString() === name.trim().toString()) {
      TypeError: name.trim is not a function
          at BackupRestore.restoreBackup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:568:27)
          at dbConnect (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1501:28)
          at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3114:29)
          at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemServer.js:184:26)
          at runCallback (timers.js:705:18)
          at tryOnImmediate (timers.js:676:5)
          at processImmediate (timers.js:658:5)
        iobroker status
        Zeigt
        W Offline
        W Offline
        weidlix
        @crunchip said in Proxmox Container - Backitup Restore klappt nicht:
        guck doch mal was
        root@ioBrokerProd:/opt/iobroker# iobroker status
        iobroker is running
        Objects type: file
        States  type: file
        • simatecS simatec
          @crunchip
          crunchipC Offline
          crunchipC Offline
          @simatec den status ob redis aktiv ist.
          War ja nur so ein gedankengang, falls ja, das vllt etwas falsch eingestellt wurde.
          • W Offline
            W Offline
            weidlix
            So restore mit Dateiname funktioniert. Aber danach komme ich nicht auf die admin Oberflache:
            host.ioBrokerProd object system.certificates created
            System successfully restored!
            root@ioBrokerProd:/opt/iobroker/backups# cd ..
            root@ioBrokerProd:/opt/iobroker# iobroker start
            No connection to states 127.0.0.1:6379[redis]
            • W Offline
              W Offline
              weidlix
              Ok, ich glaube ich bin ein Schritt weiter. Mein alter iobroker auf dem PI hate als State DB redis eingestellt. Meine Neuinstallation hatte File eingestellt. Jetzt habe ich auf dem NUC redis installiert und auf redis umgestellt. Allerdings lief der Redis Server nicht. Den have ich jetzt händisch gestartet und jetzt sehe ich in den Logs dass Adapter installiert werden.
              Was muss ich denn tun damit der Redis Server automatisch startet wenn ich den Container hochfahre?
              • W weidlix
                crunchipC Offline
                crunchipC Offline
                @weidlix dann lag ich ja doch nicht ganz falsch. Der sollte doch eigentlich automatisch starten.
                Hast du eigens nen Ct für Redis erstellt oder Redis in IoBroker installiert?
                W 1 Antwort Letzte Antwort
                • W weidlix
                  crunchipC Offline
                  crunchipC Offline
                  @weidlix Link Text zum Thema Redis
                    W Offline
                    W Offline
                    weidlix
                    @crunchip
                    Hab redis im ioBroker container installiert. Wurde aber nicht automatisch gestartet. Kenne mich damit auch nicht aus. Denke aber wenn ich den Container neu starte startet redis momentan nicht automatisch mit.
                    • W weidlix
                      @crunchip
                      crunchipC Offline
                      crunchipC Offline
                      @weidlix mit einem
                      sudo systemctl enable redis
                      sollte es automatisch starten
