  4. Proxmox Container - Backitup Restore klappt nicht
proxmox redis backitup
21 Beiträge 5 Kommentatoren 1.9k Aufrufe 3 Beobachtet
  • htreckslerH htrecksler
    @weidlix ok, dann ist etwas faul
    W Offline
    W Offline
    weidlix
    @htrecksler
    Definitiv. Ich glaub redis ist das problem
    Error: Redis connection in broken state: connection timeout exceeded.
        at RedisClient.connection_gone (/opt/iobroker/node_modules/redis/index.js:649:19)
        at Socket.<anonymous> (/opt/iobroker/node_modules/redis/index.js:289:14)
        at Object.onceWrapper (events.js:286:20)
        at Socket.emit (events.js:198:13)
        at TCP._handle.close (net.js:607:12)
    2019-10-31 18:25:57.291  - ^[[32minfo^[[39m: iobroker Starting node restart.js
    2019-10-31 18:25:57.291  - ^[[32minfo^[[39m: iobroker exit 0
    2019-10-31 18:25:57.292  - ^[[33mwarn^[[39m: host.iobrokerProd AbortError: GET can't be processed. The connection is already closed.
    2019-10-31 18:25:57.292  - ^[[31merror^[[39m: host.iobrokerProd PUBLISH can't be processed. The connection is already closed.
    2019-10-31 18:25:57.292  - ^[[31merror^[[39m: host.iobrokerProd AbortError: PUBLISH can't be processed. The connection is already closed.
        at handle_offline_command (/opt/iobroker/node_modules/redis/index.js:851:15)
        at RedisClient.internal_send_command (/opt/iobroker/node_modules/redis/index.js:885:9)
        at RedisClient.publish (/opt/iobroker/node_modules/redis/lib/commands.js:58:25)
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:192:20
        at callbackOrEmit (/opt/iobroker/node_modules/redis/lib/utils.js:89:9)
        at /opt/iobroker/node_modules/redis/lib/utils.js:107:13
    • W Offline
      W Offline
      weidlix
      Nach dem starten des Restore sehe ich folgende Fehlermeldung in den Logs:
      2019-10-31 19:26:41.760  - ^[[32minfo^[[39m: host.iobrokerProd All instances are stopped.
      2019-10-31 19:26:41.847  - ^[[32minfo^[[39m: host.iobrokerProd terminated
      2019-10-31 19:26:55.016  - ^[[32minfo^[[39m: host.iobrokerProd iobroker.js-controller version 1.5.14 js-controller starting
      2019-10-31 19:26:55.018  - ^[[32minfo^[[39m: host.iobrokerProd Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
      2019-10-31 19:26:55.018  - ^[[32minfo^[[39m: host.iobrokerProd hostname: iobrokerProd, node: v10.17.0
      2019-10-31 19:26:55.019  - ^[[32minfo^[[39m: host.iobrokerProd ip addresses: 192.168.178.189 fe80::481e:ff:feb3:42c
      2019-10-31 19:26:55.200  - ^[[32minfo^[[39m: host.iobrokerProd  inMem-objects listening on port 9001
      2019-10-31 19:26:55.222  - ^[[32minfo^[[39m: host.iobrokerProd InMemoryDB connected
      2019-10-31 19:26:55.267  - ^[[32minfo^[[39m: Delete host system.host.iobrokerProd
      2019-10-31 19:26:55.291  - ^[[32minfo^[[39m: host.iobrokerProd 46 instances found
      2019-10-31 19:26:55.298  - ^[[33mwarn^[[39m: host.iobrokerProd startInstance cannot find adapter "flot@1.9.1". Try to install it... 1 attempt
      2019-10-31 19:26:55.298  - ^[[32minfo^[[39m: iobroker install flot@1.9.1
      2019-10-31 19:26:55.327  - ^[[32minfo^[[39m: host.iobrokerProd starting 2 instances
      2019-10-31 19:26:55.426  - ^[[32minfo^[[39m: host.iobrokerProd instance system.adapter.admin.0 started with pid 1550
      2019-10-31 19:26:57.986  - ^[[32minfo^[[39m: iobroker No connection to states 127.0.0.1:6379[redis]
      2019-10-31 19:26:57.992  - ^[[32minfo^[[39m: iobroker exit 22
      • W weidlix
        simatecS Offline
        simatecS Offline
        simatec
        @weidlix
        Führe mal den Restore über iobroker restore 0 aus. Dann bitte mal den Log posten
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        W 1 Antwort Letzte Antwort
        • PeoplesP Offline
          PeoplesP Offline
          Peoples
          schrieb am zuletzt editiert von Peoples
          Evtl. Auch Mal eine VM einrichten dort iob funktionsfähig installieren, rechte prüfen und dann das minimale zurück spielen. Hatte auch Probleme mit den Containern
          Habe ich gestern so gemacht und alles ohne Probleme durchgelaufen
          • simatecS simatec
            @weidlix
            W Offline
            W Offline
            weidlix
            @simatec
            Hi, ich lade das backup via FTP. muss ich da bei restore 0 was beachten? Wahrscheinlich schaut das in den ioBroker backup folder oder?
            • W Offline
              W Offline
              weidlix
              Hab jetzt einfach mal ein iobroker restore 0 ausgeführt.
              Folgende Fehlermeldung:
              root@iobrokerProd:/opt/iobroker/backups# iobroker restore 0
              Aber vorher über UI angestoßen. Also vielleicht schon vorher kaputt.
              • W weidlix
                crunchipC Offline
                crunchipC Offline
                @weidlix guck doch mal was
                iobroker status
                Zeigt
                simatecS W 2 Antworten Letzte Antwort
                  iobroker status
                  Zeigt
                  simatecS Offline
                  simatecS Offline
                  simatec
                  @crunchip
                  Was sagt iobroker status
                  • W Offline
                    W Offline
                    weidlix
                    Restore 0 mit frischem Container sagt:
                    oot@ioBrokerProd:/opt/iobroker/backups# cd ..
                    root@ioBrokerProd:/opt/iobroker# iobroker restore 0
                    Stop iobroker first!
                    root@ioBrokerProd:/opt/iobroker# iobroker stop
                    /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:568
                            if (parseInt(name.trim(), 10).toString() === name.trim().toString()) {
                    TypeError: name.trim is not a function
                        at BackupRestore.restoreBackup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:568:27)
                        at dbConnect (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1501:28)
                        at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3114:29)
                        at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemServer.js:184:26)
                        at runCallback (timers.js:705:18)
                        at tryOnImmediate (timers.js:676:5)
                        at processImmediate (timers.js:658:5)
                      iobroker status
                      Zeigt
                      W Offline
                      W Offline
                      weidlix
                      @crunchip said in Proxmox Container - Backitup Restore klappt nicht:
                      guck doch mal was
                      root@ioBrokerProd:/opt/iobroker# iobroker status
                      iobroker is running
                      Objects type: file
                      States  type: file
                      • simatecS simatec
                        @crunchip
                        crunchipC Offline
                        crunchipC Offline
                        @simatec den status ob redis aktiv ist.
                        War ja nur so ein gedankengang, falls ja, das vllt etwas falsch eingestellt wurde.
                        • W Offline
                          W Offline
                          weidlix
                          So restore mit Dateiname funktioniert. Aber danach komme ich nicht auf die admin Oberflache:
                          host.ioBrokerProd object system.certificates created
                          System successfully restored!
                          root@ioBrokerProd:/opt/iobroker/backups# cd ..
                          root@ioBrokerProd:/opt/iobroker# iobroker start
                          • W Offline
                            W Offline
                            weidlix
                            Ok, ich glaube ich bin ein Schritt weiter. Mein alter iobroker auf dem PI hate als State DB redis eingestellt. Meine Neuinstallation hatte File eingestellt. Jetzt habe ich auf dem NUC redis installiert und auf redis umgestellt. Allerdings lief der Redis Server nicht. Den have ich jetzt händisch gestartet und jetzt sehe ich in den Logs dass Adapter installiert werden.
                            Was muss ich denn tun damit der Redis Server automatisch startet wenn ich den Container hochfahre?
                            • W weidlix
                              crunchipC Offline
                              crunchipC Offline
                              @weidlix dann lag ich ja doch nicht ganz falsch. Der sollte doch eigentlich automatisch starten.
                              Hast du eigens nen Ct für Redis erstellt oder Redis in IoBroker installiert?
                              • W weidlix
                                crunchipC Offline
                                crunchipC Offline
                                @weidlix Link Text zum Thema Redis
                                  W Offline
                                  W Offline
                                  weidlix
                                  @crunchip
                                  Hab redis im ioBroker container installiert. Wurde aber nicht automatisch gestartet. Kenne mich damit auch nicht aus. Denke aber wenn ich den Container neu starte startet redis momentan nicht automatisch mit.
                                  • W weidlix
                                    @crunchip
                                    crunchipC Offline
                                    crunchipC Offline
                                    @weidlix mit einem
                                    sudo systemctl enable redis
                                    sollte es automatisch starten
