  4. Proxmox Container - Backitup Restore klappt nicht
proxmox redis backitup
21 Beiträge 5 Kommentatoren 1.9k Aufrufe 3 Beobachtet
  • W Offline
    W Offline
    weidlix
    2-3 Stunden habe ich schon gewartet.
    htreckslerH 1 Antwort Letzte Antwort
    • W weidlix
      htreckslerH Offline
      htreckslerH Offline
      htrecksler
      Forum Testing
      @weidlix ok, dann ist etwas faul
      Gruss Hermann
      W 1 Antwort Letzte Antwort
      • htreckslerH htrecksler
        W Offline
        W Offline
        weidlix
        @htrecksler
        Definitiv. Ich glaub redis ist das problem
        Error: Redis connection in broken state: connection timeout exceeded.
            at RedisClient.connection_gone (/opt/iobroker/node_modules/redis/index.js:649:19)
            at Socket.<anonymous> (/opt/iobroker/node_modules/redis/index.js:289:14)
            at Object.onceWrapper (events.js:286:20)
            at Socket.emit (events.js:198:13)
            at TCP._handle.close (net.js:607:12)
        2019-10-31 18:25:57.291  - ^[[32minfo^[[39m: iobroker Starting node restart.js
        2019-10-31 18:25:57.291  - ^[[32minfo^[[39m: iobroker exit 0
        2019-10-31 18:25:57.292  - ^[[33mwarn^[[39m: host.iobrokerProd AbortError: GET can't be processed. The connection is already closed.
        2019-10-31 18:25:57.292  - ^[[31merror^[[39m: host.iobrokerProd PUBLISH can't be processed. The connection is already closed.
        2019-10-31 18:25:57.292  - ^[[31merror^[[39m: host.iobrokerProd AbortError: PUBLISH can't be processed. The connection is already closed.
            at handle_offline_command (/opt/iobroker/node_modules/redis/index.js:851:15)
            at RedisClient.internal_send_command (/opt/iobroker/node_modules/redis/index.js:885:9)
            at RedisClient.publish (/opt/iobroker/node_modules/redis/lib/commands.js:58:25)
            at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:192:20
            at callbackOrEmit (/opt/iobroker/node_modules/redis/lib/utils.js:89:9)
            at /opt/iobroker/node_modules/redis/lib/utils.js:107:13
        • W Offline
          W Offline
          weidlix
          Nach dem starten des Restore sehe ich folgende Fehlermeldung in den Logs:
          2019-10-31 19:26:41.760  - ^[[32minfo^[[39m: host.iobrokerProd All instances are stopped.
          2019-10-31 19:26:41.847  - ^[[32minfo^[[39m: host.iobrokerProd terminated
          2019-10-31 19:26:55.016  - ^[[32minfo^[[39m: host.iobrokerProd iobroker.js-controller version 1.5.14 js-controller starting
          2019-10-31 19:26:55.018  - ^[[32minfo^[[39m: host.iobrokerProd Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
          2019-10-31 19:26:55.018  - ^[[32minfo^[[39m: host.iobrokerProd hostname: iobrokerProd, node: v10.17.0
          2019-10-31 19:26:55.019  - ^[[32minfo^[[39m: host.iobrokerProd ip addresses: 192.168.178.189 fe80::481e:ff:feb3:42c
          2019-10-31 19:26:55.200  - ^[[32minfo^[[39m: host.iobrokerProd  inMem-objects listening on port 9001
          2019-10-31 19:26:55.222  - ^[[32minfo^[[39m: host.iobrokerProd InMemoryDB connected
          2019-10-31 19:26:55.267  - ^[[32minfo^[[39m: Delete host system.host.iobrokerProd
          2019-10-31 19:26:55.291  - ^[[32minfo^[[39m: host.iobrokerProd 46 instances found
          2019-10-31 19:26:55.298  - ^[[33mwarn^[[39m: host.iobrokerProd startInstance cannot find adapter "flot@1.9.1". Try to install it... 1 attempt
          2019-10-31 19:26:55.298  - ^[[32minfo^[[39m: iobroker install flot@1.9.1
          2019-10-31 19:26:55.327  - ^[[32minfo^[[39m: host.iobrokerProd starting 2 instances
          2019-10-31 19:26:55.426  - ^[[32minfo^[[39m: host.iobrokerProd instance system.adapter.admin.0 started with pid 1550
          2019-10-31 19:26:57.986  - ^[[32minfo^[[39m: iobroker No connection to states 127.0.0.1:6379[redis]
          2019-10-31 19:26:57.992  - ^[[32minfo^[[39m: iobroker exit 22
          • W weidlix
            simatecS Offline
            simatecS Offline
            simatec
            @weidlix
            Führe mal den Restore über iobroker restore 0 aus. Dann bitte mal den Log posten
            • Besuche meine Github Seite
            • HowTo Restore ioBroker
            • PeoplesP Offline
              PeoplesP Offline
              Peoples
              schrieb am zuletzt editiert von Peoples
              Evtl. Auch Mal eine VM einrichten dort iob funktionsfähig installieren, rechte prüfen und dann das minimale zurück spielen. Hatte auch Probleme mit den Containern
              Habe ich gestern so gemacht und alles ohne Probleme durchgelaufen
              • simatecS simatec
                @weidlix
                W Offline
                W Offline
                weidlix
                @simatec
                Hi, ich lade das backup via FTP. muss ich da bei restore 0 was beachten? Wahrscheinlich schaut das in den ioBroker backup folder oder?
                • W Offline
                  W Offline
                  weidlix
                  Hab jetzt einfach mal ein iobroker restore 0 ausgeführt.
                  Folgende Fehlermeldung:
                  root@iobrokerProd:/opt/iobroker/backups# iobroker restore 0
                  Aber vorher über UI angestoßen. Also vielleicht schon vorher kaputt.
                  • W weidlix
                    crunchipC Offline
                    crunchipC Offline
                    @weidlix guck doch mal was
                    iobroker status
                    Zeigt
                    simatecS W 2 Antworten Letzte Antwort
                      iobroker status
                      Zeigt
                      simatecS Offline
                      simatecS Offline
                      simatec
                      @crunchip
                      Was sagt iobroker status
                      • W Offline
                        W Offline
                        weidlix
                        Restore 0 mit frischem Container sagt:
                        oot@ioBrokerProd:/opt/iobroker/backups# cd ..
                        root@ioBrokerProd:/opt/iobroker# iobroker restore 0
                        Stop iobroker first!
                        root@ioBrokerProd:/opt/iobroker# iobroker stop
                        /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:568
                                if (parseInt(name.trim(), 10).toString() === name.trim().toString()) {
                        TypeError: name.trim is not a function
                            at BackupRestore.restoreBackup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:568:27)
                            at dbConnect (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1501:28)
                            at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3114:29)
                            at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemServer.js:184:26)
                            at runCallback (timers.js:705:18)
                            at tryOnImmediate (timers.js:676:5)
                            at processImmediate (timers.js:658:5)
                          iobroker status
                          Zeigt
                          W Offline
                          W Offline
                          weidlix
                          @crunchip said in Proxmox Container - Backitup Restore klappt nicht:
                          guck doch mal was
                          root@ioBrokerProd:/opt/iobroker# iobroker status
                          iobroker is running
                          Objects type: file
                          States  type: file
                          • simatecS simatec
                            @crunchip
                            crunchipC Offline
                            crunchipC Offline
                            @simatec den status ob redis aktiv ist.
                            War ja nur so ein gedankengang, falls ja, das vllt etwas falsch eingestellt wurde.
                            • W Offline
                              W Offline
                              weidlix
                              So restore mit Dateiname funktioniert. Aber danach komme ich nicht auf die admin Oberflache:
                              host.ioBrokerProd object system.certificates created
                              System successfully restored!
                              root@ioBrokerProd:/opt/iobroker/backups# cd ..
                              root@ioBrokerProd:/opt/iobroker# iobroker start
                              • W Offline
                                W Offline
                                weidlix
                                Ok, ich glaube ich bin ein Schritt weiter. Mein alter iobroker auf dem PI hate als State DB redis eingestellt. Meine Neuinstallation hatte File eingestellt. Jetzt habe ich auf dem NUC redis installiert und auf redis umgestellt. Allerdings lief der Redis Server nicht. Den have ich jetzt händisch gestartet und jetzt sehe ich in den Logs dass Adapter installiert werden.
                                Was muss ich denn tun damit der Redis Server automatisch startet wenn ich den Container hochfahre?
                                • W weidlix
                                  crunchipC Offline
                                  crunchipC Offline
                                  @weidlix dann lag ich ja doch nicht ganz falsch. Der sollte doch eigentlich automatisch starten.
                                  Hast du eigens nen Ct für Redis erstellt oder Redis in IoBroker installiert?
                                  • W weidlix
                                    crunchipC Offline
                                    crunchipC Offline
                                    @weidlix Link Text zum Thema Redis
                                      W Offline
                                      W Offline
                                      weidlix
                                      @crunchip
                                      Hab redis im ioBroker container installiert. Wurde aber nicht automatisch gestartet. Kenne mich damit auch nicht aus. Denke aber wenn ich den Container neu starte startet redis momentan nicht automatisch mit.
                                      • W weidlix
                                        @crunchip
                                        crunchipC Offline
                                        crunchipC Offline
                                        @weidlix mit einem
                                        sudo systemctl enable redis
                                        sollte es automatisch starten
