  4. Viessmann-Adapter
Viessmann-Adapter
viesmann
523 Beiträge 50 Kommentatoren 213.2k Aufrufe 19 Beobachtet
  • blauholstenB blauholsten
    @bahnuhr sagte in Viessmann-Adapter:
    habe V1.1.1 installiert.
    nach timeout automatisch verbinden klappt.
    Es bringt aber nichts.
    Nach 3-4 Minuten kommt wieder timeout.
    viessmann.0	2019-08-17 08:12:12.739	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 08:12:02.727	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 08:12:02.727	error	Timeout connection error!
    viessmann.0	2019-08-17 08:09:02.693	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 08:08:52.677	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 08:08:52.677	error	Timeout connection error!
    viessmann.0	2019-08-17 08:05:52.647	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 08:05:42.640	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 08:05:42.640	error	Timeout connection error!
    viessmann.0	2019-08-17 08:02:42.608	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 08:02:32.595	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 08:02:32.595	error	Timeout connection error!
    viessmann.0	2019-08-17 07:59:32.565	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 07:59:22.549	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 07:59:22.549	error	Timeout connection error!
    viessmann.0	2019-08-17 07:56:22.518	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 07:56:12.512	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 07:56:12.512	error	Timeout connection error!
    viessmann.0	2019-08-17 07:53:12.482	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 07:53:02.475	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 07:53:02.475	error	Timeout connection error!
    viessmann.0	2019-08-17 07:50:02.446	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 07:49:52.434	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 07:49:52.434	error	Timeout connection error!
    viessmann.0	2019-08-17 07:46:52.401	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 07:46:42.386	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 07:46:42.386	error	Timeout connection error!
    viessmann.0	2019-08-17 07:43:42.355	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 07:43:32.340	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 07:43:32.340	error	Timeout connection error!
    viessmann.0	2019-08-17 07:40:32.314	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 07:40:22.313	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 07:40:22.313	error	Timeout connection error!
    viessmann.0	2019-08-17 07:37:22.277	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 07:37:12.261	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 07:37:12.261	error	Timeout connection error!
    viessmann.0	2019-08-17 07:34:12.246	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 07:34:02.228	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 07:34:02.228	error	Timeout connection error!
    viessmann.0	2019-08-17 07:31:02.200	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 07:30:52.184	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 07:30:52.184	error	Timeout connection error!
    viessmann.0	2019-08-17 07:27:52.166	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 07:27:42.150	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 07:27:42.150	error	Timeout connection error!
    viessmann.0	2019-08-17 07:24:42.127	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 07:24:32.112	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 07:24:32.112	error	Timeout connection error!
    viessmann.0	2019-08-17 07:21:32.088	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 07:21:22.073	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 07:21:22.073	error	Timeout connection error!
    viessmann.0	2019-08-17 07:18:22.056	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 07:18:12.040	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 07:18:12.040	error	Timeout connection error!
    viessmann.0	2019-08-17 07:15:12.010	info	Connect with Viessmann sytem!
    viessmann.0	2019-08-17 07:15:02.007	info	Connection with Viessmann system disconnected!
    viessmann.0	2019-08-17 07:15:02.007	error	Timeout connection error!
    Wenn ich nun den Raspi neu reboote und die Instanz neu starten und dann klappt es wieder.
    Deshalb nochmal die Anforderung von mir:
    Kann man dies einbauen in das Script.
    Danke.
    Hier bockt dann aber aber dein raspi bzw. der dort drauf laufende vcontrold.
    Für dein Fall wäre es Sinninger und einfacher einfach ein kleines Skript laufen zu lassen und dann dein Pi neu starten zu lassen. Falls du dabei Hilfe brauchst, einfach bescheid geben....
    bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    #427
    @blauholsten sagte in Viessmann-Adapter:
    Ja, ich glaube ich brauche da Hilfe.
    Denn dies habe ich schon mal versucht.
    anbei mal meine Versuche:
    // Wenn der Viessmann Adapter keine Daten mehr bekommt (Verbindung nicht geschlossen) dann force_reload beim raspi und Adapter nach 2 Min. neu starten
    /* Ablauf
    - PC wird neu gestartet oder Adapter ist nicht grün
    - nach 30 Sek. prüfen ob immer noch false
    - 3 Min. warten
    - Adapter ausschalten
    - Raspi force-reload durchführen
    - 2 Min. warten
    - Adapter starten
    - 1 Min. warten -> prüfen ob Adapter true ist -> wenn ja, dann Telegram "gestartet"
      wenn nein dann Telegram Nachricht "nicht erfolgreich"
    var logging = true;
    var idTest = ["system.adapter.viessmann.0.connected", "viessmann.0.info.connection"];
    on({id: idTest, change: "ne", val: false, ack: true}, function(obj){
        if (logging) log("Adapter ist false");
        setTimeout(function() {     // 30 Sek. warten
            if (getState("system.adapter.viessmann.0.connected").val === false || getState("viessmann.0.info.connection").val === false) {
                if (logging) log("nach 30 Sek. Adapter ist weiterhin false");
                setTimeout(function() {     // 3 Min. warten
                    stopviessmann();        // Adapter gestoppt !
                    raspi();                // Raspi force-reload durchführen
                    setTimeout(function() { // 2 Min. warten
                        startviessmann();   // Adapter neu gestartet !
                        setTimeout(function() {  // 1 Min. warten
                            if (getState("system.adapter.viessmann.0.connected").val === true & getState("viessmann.0.info.connection").val === true) {
                                log ('Viessmann war nicht mehr verbunden; Raspi und Adapter wurden neu gestartet!');
                                sendTo('telegram', {user: 'Dieter',text: "Viessmann war nicht mehr verbunden; Raspi und Adapter wurden neu gestartet!", parse_mode: 'HTML'});
                            } else {
                                log ('Viessmann war nicht mehr verbunden; Raspi und Adapter konnten nicht neu gestartet werden!');
                                sendTo('telegram', {user: 'Dieter',text: "Viessmann war nicht mehr verbunden; Raspi und Adapter konnten nicht neu gestartet werden!", parse_mode: 'HTML'});
                        }, 60000);  // 1 Min.
                    }, 120000);     // 2 Min.
                }, 180000);         // 3 Min.
            } else {
                if (logging) log("nach 30 Sek. Adapter ist true");
        }, 30000);          // 30 Sek.
    function raspi() {
        const Client = require('ssh2').Client;      //ssh2 muss vorher beim Adapter javascript eingebunden werden.
        var conn = new Client();
        conn.on('ready', function() {
            conn.exec('sudo /etc/vcontrold/force_reload.sh', function(err, stream) {
                if (err) throw err;
                stream.on('close', function(code, signal) {
                    conn.end();
                }).on('data', function(data) {
                    log('Ausgabe: ' + data);
                }).stderr.on('data', function(data) {
                    log('Fehler: ' + data);
        }).connect({
            host: '192.168.xxx.xx', // IP des RPi
            port: 22,
            username: 'xxx',
           password: 'xxx'
    function stopviessmann() {
        var obj = getObject('system.adapter.viessmann.0');
        obj.common.enabled = false;
        setObject('system.adapter.viessmann.0', obj);
        log ('Viessmann Adapter gestoppt!');
    function startviessmann() {
        obj.common.enabled = true;
        log ('Viessmann Adapter neu gestartet!');
    /*  // alter on
    on({id: "viessmann.0.info.connection", change:"ne", val: false, ack: true}, function(obj){
            log ('Viessmann war nicht mehr verbunden; Raspi und Adapter neu gestartet!');
            raspi();
                setState('system.adapter.viessmann.0.alive', false);
            }, 60000);
                if (getState('system.adapter.viessmann.0.alive').val === false) {
                    setState('system.adapter.viessmann.0.alive', true);
            }, 120000);
    /*  // Werte holen mit ssh2  ---------------------------------------------------
    function raspi() {
        conn.exec('vclient -h 127.0.0.1:3002 -c getTempA', function(err, stream) {
          if (err) throw err;
            conn.end();
      }).connect({
        port: 22,
        username: 'xxx',
        password: 'xxx'
    raspi();
    //, getTempWWist, getTempWWsoll, getTempKist, getTempKsoll
    Das force-reload.sh auf dem raspi sah wie folgt aus:
    # force-reload ausfuehren und Text an telegram
    curl -s -k "https://api.telegram.org/botabcde:xcyA-ExGV8/sendMessage" -d text="<b>Pi-Heizung: force-reload ausgefuehrt !</b>" -d chat_id=257abcde -d parse_mode=html
    sleep 3
    sudo /etc/init.d/vcontrol force-reload
    Fazit:
    Meine Versuche haben immer irgendwo gehakt.
    Was bräuchte ich:
    1. connection steht nicht (entweder ist der Adapter gelb oder die Werte kommen eben nicht an)
    2. Intanz ausschalten
    3. nach x Sek. reboot bei dem raspi
    4. nach x Sek. Instanz wieder an.
    mfg
    Dieter
    Danke.
    blauholstenB 1 Antwort Letzte Antwort
      martinschm
      #428
      Im Adapter kann ich ja konfigurieren, in welchen Abständen welche Daten abgefragt werden.
      Welche Intervalle machen denn Sinn?
      Bei Abgas und Wassertemperatur, Errorcodes sowie Brennerstarts?
      • bahnuhrB bahnuhr
        /* Ablauf
        - 3 Min. warten
        - 2 Min. warten
        - Adapter starten
        var logging = true;
                                } else {
                } else {
        function raspi() {
                    if (err) throw err;
                        conn.end();
            }).connect({
                port: 22,
                username: 'xxx',
               password: 'xxx'
        /*  // alter on
                raspi();
                }, 60000);
                }, 120000);
        function raspi() {
              if (err) throw err;
                conn.end();
          }).connect({
            port: 22,
            username: 'xxx',
            password: 'xxx'
        raspi();
        sleep 3
        Fazit:
        Was bräuchte ich:
        mfg
        Dieter
        blauholstenB Offline
        blauholsten
        #429
        /* Ablauf
        - 3 Min. warten
        - 2 Min. warten
        - Adapter starten
        var logging = true;
                                } else {
                } else {
        function raspi() {
                    if (err) throw err;
                        conn.end();
            }).connect({
                port: 22,
                username: 'xxx',
               password: 'xxx'
        /*  // alter on
                raspi();
                }, 60000);
                }, 120000);
        function raspi() {
              if (err) throw err;
                conn.end();
          }).connect({
            port: 22,
            username: 'xxx',
            password: 'xxx'
        raspi();
        sleep 3
        Fazit:
        Was bräuchte ich:
        mfg
        Dieter
        Auf die schnelle vom Handy. Das mit dem Adapters stoppen usw. Kannst du dir schenken.
        Mache folgendes.......
        Stelle dein Skript so um, dass du nur auf den Connection Datenpunkt des Adapters triggerst. Sollte das passieren, lässt du bei
        Wert false Zeit x (ich würde min 10m wählen)laufen, dann führst du einen Befehl aus der den Pi neu starten lässt. Bei true den timer wieder löschen. Mehr brauchst du eigentlich nicht zu machen. Bei weitere Hilfe einfach melden....
        - Alarm Adapter
        • M martinschm
          blauholsten
          #430
          @martinschm das musst du ein wenig testen, allerdings sollte man relativ unwichtige Werte wie Brennerstarts und erros nicht zu klein wählen. Sowas Frage ich alle fünf Minuten ab. Temperaturen im Sekunden Bereich.
          - Alarm Adapter
            dtp
            #431
            Übrigens, das Sortieren bzgl. des Abfrageintervalls klappt noch nicht so richtig. Ein Sortieren nach Name und Beschreibung funktioniert dagegen.
            Würde mir noch wünschen, dass man für die Abfrageintervalle einzelne Abfragepunkte markieren kann, um dann für diese einheitlich das Abfrageintervall ändern zu könnnen. Außerdem wäre ein Filterfunktion toll, so dass man z.B. "temp" eingeben kann, um nur noch die Temperatur-Abfragepunkte angezeigt zu bekommen.
            • P Offline
              passuff
              schrieb am zuletzt editiert von passuff
              #432
              Es gibt ja bereits einen Dp "connection", der die Verbindung überwacht.
              Soweit ich nachvollziehen kann, ist dieser an den Log Eintrag " Connection with Viessmann system disconnected" geknüpft. Wenn ich beispielsweise die Heizung kurz ausschalte, oder den USB Stecker entferne, erhalte ich diesen Eintrag.
              Ich benötige einen zweiten dp, der auf viessmann.0 Timeout connection error! Triggert. Bei mir der Fall, wenn sich vcontrold oder der raspi aufgehängt hat. Ist dies der Fall würde ich den raspi gerne neustarten. Auf ein Log Eintrag zu triggern, ist vermutlich schwierig. Daher die Bitte für einen zusätzlichen Datenpunkt.
              • P passuff
                blauholsten
                #433
                @passuff sagte in Viessmann-Adapter:
                Neue Version erstellt, bitte testen....
                - Alarm Adapter
                P 1 Antwort Letzte Antwort
                  passuff
                  #434
                  @blauholsten
                  installiert (1.2.2.)
                  Finde keinen Unterschied (neuer DP?)
                  • C Offline
                    C1500
                    #435
                    Servus
                    ich verzweifle gerade etwas.
                    Es hatte alles schon mal super funktioniert, daher kann ich die Hardware ausschließen.
                    Bis vor kurzem hatte ich nur das Probelm, das ich keine Zahlenwerte schreiben konnte. Lesen ging problemlos.
                    Das umschalten von WW auf H+WW klappte hingegen.
                    Ich hab es jetzt gerade geschafft, das gr nichts mehr geht. Weder schreiben noch lesen.
                    Den PI neu zu starten bringt nix.
                    Hab alle Updates auf dem PI gemacht.
                    Hab auch versucht, vcontrold vom GIT neu zu installieren.
                    Aktuell kann ich die Telnet-Verbindung herstellen.
                    "vctrld>commands" bringt auch die möglichen Befehle.
                    Sobald ich aber einen davon eingebe, (z.B. getTempA) schließt sich Putty.
                    ioBroker kann auch nichts abfragen, die vito.xml vcontrold.xml wurden aber richtig eingelesen.
                    Im LOG steht folgenes:
                    Mir gehen die Ideen aus :(
                    Könnte mir bitte jemand helfen?
                    Danke und Gruß
                    Peer
                    • P passuff
                      @blauholsten
                      blauholsten
                      #436
                      @blauholsten
                      Das sollte eigentlich du sein, habe aber festgestellt das dieser bei Adapter Start wieder weg ist?
                      - Alarm Adapter
                        @blauholsten
                        passuff
                        #437
                        @blauholsten
                        verstehe deinen Satz nicht...
                        • C Offline
                          C1500
                          #438
                          Er meint vermutlich folgendes:
                          Der DP sollte eigentlich da sein
                          Er hat aber festgestellt, dieser DB bei Adapter Start wieder weg ist.
                          • blauholstenB Offline
                            blauholsten
                            #439
                            so jetzt sollte er da sein (1.2.3)
                            - Alarm Adapter
                              dtp
                              #440
                              In letzter Zeit musste ich den ioBroker recht häufig wegen Aktualisierung des js-controllers neu starten. Nach dem Neustart wurde auch immer der Viessmann-Adapter mit grüner Ampel angezeigt. Aber kann es sein, dass er dann trotzdem nicht die Werte von vcontrold ausgelesen bekommt? Bei mir wird da jedenfalls regelmäßig nichts in Flot angezeigt und ich muss den Viessmann-Adapter manuell neu starten, bis es wieder funktioniert.
                              • bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                #441
                                Ist bei mir auch so.
                                Nur Adapter neu starten reicht bei mir nicht.
                                Ich muss zusätzlich manuell einen reboot beim raspi machen.
                                Und nur das hilft dann.
                                Deshalb ja auch meine Anforderung, dass man einstellen könnte dass der Adapter den raspi neu starten soll.
                                mfg
                                Dieter
                                Danke.
                                P D 2 Antworten Letzte Antwort
                                • bahnuhrB bahnuhr
                                  mfg
                                  Dieter
                                  passuff
                                  #442
                                  @bahnuhr
                                  So auch bei mir neuerdings...daher meine Anfrage nach dem zusätzlichen DP...
                                  • bahnuhrB bahnuhr
                                    mfg
                                    Dieter
                                    dtp
                                    #443
                                    Nee, ist bei dir was anderes.
                                    Ich habe keinerlei Probleme damit, dass der Viessmann-Adapter nach einem ioBroker-Neustart meinen Raspi mit vcontrold findet. Der wird immer sofort gefunden. Ich muss also nie meinen Raspi neustarten.
                                    Mir geht es darum, dass ich den Viessmann-Adapter nach einem ioBroker-Neustart noch mal extra neu starten muss, damit er sich die aktuellen Werte holt. Wenn ich dagegen bei laufendem ioBroker den Rapsi neu starte, dann werden die Werte vom Viessmann-Adapter automatisch nach einer gewissen Zeit eingelesen, ohne dass ich den Adapter neu starten müsste.
                                    • J Offline
                                      joefarm
                                      #444
                                      ich hab den Viessmann-Adapter zusammen mit vcontrold am laufen und schalte darüber meine Heizung an und aus. Soweit so gut, funktioniert eigentlich auch ganz gut. Allerdings passiert es nach ein paar Stunden, dass der Adapter die Verbindung zum vcontrold verliert und dann ca. alle 7-8 Minuten ein zusätzlicher vcontrold geforkt wird. Es werden dann immer mehr, aber die Verbindung zum Adapter kommt nicht mehr zustande. Wenn ich dann per Hand alle vcontrold Prozesse kille und den vcontrold neu starte, geht wieder alles. Und dann geht das Spiel wieder von vorne los...
                                      Ich versuch jetzt schon seit ein paar Tagen dem Problem auf die Spur zu kommen, bin aber nicht erfolgreich... Jemand eine Idee?
                                        sonusfaber
                                        #445
                                        wie kann ich nach einer programmierten Zustandsänderung meiner Heizung (z.B setBetriebArtM2) in Javascript forcieren, dass gleich anschließen ein getBetriebArtM2 ausgeführt wird. Gerne auch aus Javascript heraus.
                                        Ich rufe die Betriebsart z.B. nur alle 2 Stunden auf und damit wird der neue Zustand u.U erst 2 Stunden später aktualisiert.
                                        Danke schon mal vorab.
                                        • S sonusfaber
                                          blauholsten
                                          #446
                                          @sonusfaber lass doch die states alle 2min o.ä. abfragen
                                          - Alarm Adapter
