  4. Test js-controller v2.0.x (GitHub)
    1.5k
js-controller
1.0k Beiträge 48 Kommentatoren 435.7k Aufrufe 35 Beobachtet
  • coyoteC coyote
    @apollon77 irgendwie wollen manche Scripte nicht laufen und warum steht bei mir an jedem Script "Instanz deaktiviert" obwohl sie aktiviert ist? 🤔
    Dieses Script hier will auch nicht mehr:
    var HueApi = require("node-hue-api").HueApi;
    // Replace IP and username!!!
     var host = "192.168.66.31",
         username = "16f4f7d727e98e3f3eaXXXXXXX",
         api = new HueApi(host, username);
     var groups_ = [],
         lights_ = [],
         objects_ = [];
     // Log JSON results
     var displayResults = function(result) {
         console.log('Reponse: '+JSON.stringify(result, null, 2));
     // Parse Light Group 0 (All Lights)
     var parseGroup0 = function(result) {
         if (!result.lights){return} // Empty group
         var id = result.id,
             lights = result.lights,
             name = "All Lights";
         console.debug('group: '+name+', lights: '+lights);
         groups_[lights] = name;
     // Parse Light Groups
     var parseGroups = function(result) {
         for (var i = 0; i < result.length; i++) {
             if (!result[i].lights){continue} // Empty group
             var id = result[i].id,
                 lights = result[i].lights,
                 name = result[i].name;
     // Parse Lights
     var parseLights = function(result) {
             console.debug('light: '+name+', id: '+id);
             lights_[id] = name;
     // Create States in ioBroker
     var createStates = function(result) {
         // Resync button
         createState('PhilipsHue.Scenes.Resync', false, {role: "button", name: 'Resync Philips Hue Groups, Lights and Scenes'});
             if (!result[i].appdata.data){continue} // skip internal szenes
                 name = result[i].name.replace(/"/g,''),
                 pathname = name.replace(/ /g,'_');
             // Get light names
             var light_names = [];
             for (var j = 0; j < lights.length; j++) {
                 var light_name = lights_[lights[j]];
                 light_names.push(light_name);
             // Room, group or lights linked with scene
             var group = 'Group: '+groups_[lights] || 'Lights: '+light_names.join(", ");
             // Create States and skip duplicates
             if (!objects_[lights+pathname]){
                 console.debug('scene: '+name+', '+group);
                 createState('PhilipsHue.Scenes.'+pathname+'.'+id, false, {role: "button", name: 'Scene: '+name+' ('+group+')'});
                 objects_[lights+pathname] = true;
     // Delete States
     function deleteStates(){
         console.log('Deleting current objects for scenes...');
         objects_ = [];
         $('javascript.0.PhilipsHue.Scenes.*').each(function (id) {
             deleteState(id);
     // Fetch data from Hue API
     function init(){
         api.getGroup(0, function(err, group0) {
             if (err) throw err;
             console.log('Processing group 0...');
             //displayResults(group0);
             parseGroup0(group0);
         api.groups(function(err, groups) {
             if (err) throw err;
             console.log('Processing ' + groups.length + ' groups...');
             //displayResults(groups);
             parseGroups(groups);
         api.lights(function(err, lights) {
             if (err) throw err;
             console.log('Processing ' + lights.lights.length + ' lights...');
             //displayResults(lights);
             parseLights(lights.lights);
         api.scenes(function(err, scenes) {
             if (err) throw err;
             console.log('Processing ' + scenes.length + ' scenes...');
             //displayResults(scenes);
             createStates(scenes);
     // Init on start
     init();
     // Activate scene
     on({id: /^javascript\.0\.PhilipsHue.Scenes\./, val: true}, function (obj) {
         if (obj.id == 'javascript.0.PhilipsHue.Scenes.Resync'){return}
         sceneId = obj.id.split('.').pop();
         console.log('Activating '+obj.name);
         api.activateScene(sceneId, function(err, result) {
             if (err) throw err;
             displayResults(result);
         setState(obj.id, false);
     // Resync
     on({id: 'javascript.0.PhilipsHue.Scenes.Resync', val: true}, function (obj) {
         console.log('Resync triggered...');
         groups_ = [];
         lights_ = [];
         deleteStates();
         init();
     /*schedule("0 3 * * *", function () {
         groups_ = [];
         lights_ = [];
         deleteStates();
         init();
    javascript.0	2019-10-10 19:49:59.137	info	(15370) script.js.Hue_Szenen_abfragen: registered 2 subscriptions and 1 schedule
    javascript.0	2019-10-10 19:49:59.099	info	(15370) Start javascript script.js.Hue_Szenen_abfragen
    javascript.0	2019-10-10 19:49:55.995	info	(15370) Stop script script.js.Hue_Szenen_abfragen
    Das wars mehr kommt da nicht mehr... Ne Idee wo ich suchen kann? Mir ist es nur aufgefallen, als meine Hue Lampe heute nicht an ging, wird über ein Script gesteuert.
    apollon77A
    apollon77A
    #726
    @coyote ich hab beim JavaScript Adapter dazu ein issue gesehn.
    coyoteC 1 Antwort Letzte Antwort
    • apollon77A apollon77
      coyoteC
      coyoteC
      coyote
      #727
      @apollon77 ah ok, alles klar.
      Warum das Script nicht mehr korrekt läuft, muss ich selbst mal schauen, irgendwas passt da nicht.
      Die anderen Scripte laufen anscheinend ja.
        @apollon77
        Ja ich habe ein file/file System.
        Die Umänderung in unit geht kurzzeitig bis sich wieder die Temperatur ändert und dann taucht wieder das Hieroglyphzeichen auf.
        Hier die Datei aus Objekte: zigbee.0.00158d00034d13af.json
        apollon77A
        apollon77A
        #728
        @Nuggelbeb welche zigbee Version?
          #729
          @apollon77
          Installierte Version: 0.11.3
            @apollon77
            apollon77A
            apollon77A
            #730
            @Nuggelbeb @arteck sagte mir du sollst mal aktuelle GitHub nehmen.
              #731
              @apollon77
              Auf GitHub ist es doch die aktuelle Version.
              • D
                D
                darkiop
                #732
                Direkt von Github installieren (Adapter --> Katze Symbol oder 'iobroker url http://.....), dann hast die letzten Commits unabhängig der letzten Version.
                Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                • D darkiop
                  #733
                  @darkiop
                  Okay, da ist es V 0.11.4
                  Bis jetzt geht es. melde mich morgen noch einmal.
                  • MathiasJM
                    MathiasJM
                    MathiasJ
                    #734
                    Weiß jemand, was mit Frankjoke los ist?
                    So wie ich mich kenne, zerschieße ich was bei einer Änderung. Dashalb lasse ich es lieber.......
                    IObroker auf dem NUC als VM.
                    • MathiasJM MathiasJ
                      apollon77A
                      apollon77A
                      #735
                      @MathiasJ Er ist dran. Das eine File manuell abzupassen tut vorher und nachher!
                      • coyoteC
                        coyoteC
                        coyote
                        #736
                        @apollon77 kannst du mir vllt da weiterhelfen? Habe diese "node-hue-api" gerade nochmal neu in die javascript instanz hinzugefügt, dann kommt folgendes:
                        host.debian	2019-10-10 22:53:54.042	info	instance system.adapter.javascript.0 terminated with code 156 (156)
                        host.debian	2019-10-10 22:53:54.042	error	Caught by controller[9]: (node:20588) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
                        host.debian	2019-10-10 22:53:54.042	error	Caught by controller[8]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
                        host.debian	2019-10-10 22:53:54.042	error	Caught by controller[8]: (node:20588) UnhandledPromiseRejectionWarning: Error: connect ECONNREFUSED 192.168.66.31:443
                        host.debian	2019-10-10 22:53:54.042	error	Caught by controller[7]: (node:20588) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
                        host.debian	2019-10-10 22:53:54.041	error	Caught by controller[6]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
                        host.debian	2019-10-10 22:53:54.041	error	Caught by controller[6]: (node:20588) UnhandledPromiseRejectionWarning: Error: connect ECONNREFUSED 192.168.66.31:443
                        host.debian	2019-10-10 22:53:54.041	error	Caught by controller[5]: (node:20588) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
                        host.debian	2019-10-10 22:53:54.041	error	Caught by controller[4]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
                        host.debian	2019-10-10 22:53:54.041	error	Caught by controller[4]: (node:20588) UnhandledPromiseRejectionWarning: Error: connect ECONNREFUSED 192.168.66.31:443
                        host.debian	2019-10-10 22:53:54.041	error	Caught by controller[3]: (node:20588) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js proc
                        host.debian	2019-10-10 22:53:54.041	error	Caught by controller[2]: (node:20588) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
                        host.debian	2019-10-10 22:53:54.041	error	Caught by controller[1]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1106:14)
                        host.debian	2019-10-10 22:53:54.040	error	Caught by controller[1]: (node:20588) UnhandledPromiseRejectionWarning: Error: connect ECONNREFUSED 192.168.66.31:443
                        host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: ********************************************************************************
                        host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: Please consult the documentation at https://github.com/peter-murray/node-hue-api for the documentation on the new API.
                        host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: require("node-hue-api").v3
                        host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: You need to migrate your code to use the new API available via import
                        host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: This will be removed in v4.x of node-hue-api.
                        host.debian	2019-10-10 22:53:54.040	error	Caught by controller[0]: This shim provides a limited backporting of the features available in the updated API in v3.x.
                        host.debian	2019-10-10 22:53:54.039	error	Caught by controller[0]: Backwards compatibility shim for node-hue-api.
                        host.debian	2019-10-10 22:53:54.035	error	Caught by controller[0]: ********************************************************************************
                        javascript.0	2019-10-10 22:53:52.981	info	(20588) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        javascript.0	2019-10-10 22:53:52.432	info	(20588) Got terminate signal TERMINATE_YOURSELF
                        Vorher hatte das ohne Probleme funktioniert
                        • coyoteC coyote
                          apollon77A
                          apollon77A
                          #737
                          @coyote sagte in [Aufruf] js-controller 2.0 Beta Test:
                          192.168.66.31:443
                          Also einmal 192.168.66.31:443 ECONREFUSED heist Connection Refused. DU kannst dich da nicht hin verbinden oder sowas. Da sist aber jetzt 100% Offtopic hier
                            192.168.66.31:443
                            coyoteC
                            coyoteC
                            coyote
                            schrieb am zuletzt editiert von coyote
                            #738
                            @apollon77 ja das ist mir eigentlich schon klar, die HueBridge ist aber erreichbar, also eigentlich kann es da nicht dran liegen und der Fehler kam ja erst als ich den node-hue-api in der Javascript Instanz nochmal hinzugefügt hab, deshalb dachte ich es könnte was mit dem js-controller zu tun haben, da es vorher ohne Probleme lief.
                            Es geht mir eher um die unteren Zeilen
                            • coyoteC coyote
                              apollon77A
                              apollon77A
                              #739
                              @coyote Docker? Netzwerk? Firewall? SOwas vllt? Kannst Du von dem ioBroker Host die seite mit curl oder so erreichen? Owas ... aber anderer Thread Bitte!
                                coyoteC
                                coyoteC
                                coyote
                                #740
                                @apollon77 weder noch und ja ich kann auch über die iobroker objekte von hue, direkt meine lampen schalten, also ist die Bridge ja erreichbar. Hat damit nichts zu tun. Mir geht es nur um diese node-hue-api, das funktioniert nicht mehr. Gestern mit der 2.0.24 ging das ja noch ohne Probleme, sonst noch ne Idee?
                                • coyoteC coyote
                                  apollon77A
                                  apollon77A
                                  #741
                                  @coyote keine ohne jetzt tief rein zu schauen. Die Änderungen 24->25 sind diesbezüglich auch an sich irrelevant.
                                    coyoteC
                                    coyoteC
                                    coyote
                                    #742
                                    @apollon77 hm ok, naja könnte auch schon vorher ein Problem gewesen sein und ich hab es nicht gemerkt, erst als ich heute die Objekte neu synchronisieren wollte. Naja, dann weiß ich es momentan erst auch mal nicht, muss ich weiter suchen. Keine Ahnung was er jetzt für ein Problem mit dem node-hue-api hat, da bin ich nicht tief genug drin in der Materie.
                                    • coyoteC
                                      coyoteC
                                      coyote
                                      #743
                                      @apollon77 falls du irgendwann Zeit hast kannst du vllt mal kurz in die Log Datei schauen. Habe gerade die Javascript Instanz auf 4.3.0 upgedatet und Fehler im Log, weiß aber jetzt nicht, ob das mit dem js-controller zusammenhängt. Wenn nicht mach ich nen neuen Beitrag dazu.
                                      Hier:Log.txt
                                      • coyoteC coyote
                                        Hier:Log.txt
                                        apollon77A
                                        apollon77A
                                        #744
                                        @coyote der eine teil mir Write permissives ist mal wieder npm beim Paket Update wegen irgendwelchen rechten. Am besten install fiyer laufen lassen um sowas zu fixen.
                                        Ansonsten
                                        1. TypeError: Cannot read property 'Tail' of undefined
                                        Ist ggf folgefehler weil die tail library nicht installiert wurde korrekt.
                                        Also beides nicht Controller. Fixe die permission Fehler dann weiterschauen
                                        • apollon77A
                                          apollon77A
                                          #745
                                          So, ich mache hier heute Abend zu. Weiter geht es --> https://forum.iobroker.net/topic/25692/js-controller-2-0-ab-sofort-im-latest-repo
                                          Ich bedanke mich bei Euch allen für die Super Zusammenarbeit. Zusammen haben wir glaube ich eine super getestete Version für "die Allgemeinheit" bekommen die jetzt, falls noch was drin ist, im Latest Repo final "reifen" kann :-)
                                          Ich melde mich um Weihnachten rum dann zur 2.1 wieder ;-)
