  4. Viessmann-Adapter
Viessmann-Adapter
viesmann
523 Beiträge 50 Kommentatoren 213.2k Aufrufe 19 Beobachtet
  • P passuff
    Es funktioniertl- besser - manchmal ;)
    viessmann.0 2019-08-05 21:29:09.094 warn No states found for {"type":"state","common":{"name":"","unit":"0=AUS;1=EIN;2=AUS;3=EIN","type":"number","desc":"Status Heizkreispumpe M2.","custom":{"influxdb.0":{"enabled":true,"changesOnly":true,"d
    viessmann.0 2019-08-05 21:29:09.070 warn No states found for {"type":"state","common":{"name":"","unit":"0=AUS;1=EIN;2=AUS;3=EIN","type":"number","desc":"Status Heizkreispumpe M2.","custom":{"influxdb.0":{"enabled":true,"changesOnly":true,"d
    viessmann.0 2019-08-05 21:29:09.068 warn No states found for {"type":"state","common":{"name":"","unit":"0=AUS;1=EIN;2=AUS;3=EIN","type":"number","desc":"Status Heizkreispumpe M2.","custom":{"influxdb.0":{"enabled":true,"changesOnly":true,"d
    viessmann.0 2019-08-05 21:29:08.400 info Connection with Viessmann system disconnected!
    viessmann.0 2019-08-05 21:29:08.399 info Connection with Viessmann system disconnected!
    viessmann.0 2019-08-05 21:29:08.399 warn Malfunction connection--> Error: connect EALREADY 192.168.178.46:3002 - Local (192.168.178.49:59474)
    viessmann.0 2019-08-05 21:24:08.992 warn No states found for {"type":"state","common":{"name":"","unit":"0=AUS;1=EIN;2=AUS;3=EIN","type":"number","desc":"Status Heizkreispumpe M2.","custom":{"influxdb.0":{"enabled":true,"changesOnly":true,"d
    viessmann.0 2019-08-05 21:24:08.923 warn No states found for {"type":"state","common":{"name":"","unit":"0=AUS;1=EIN;2=AUS;3=EIN","type":"number","desc":"Status Heizkreispumpe M2.","custom":{"influxdb.0":{"enabled":true,"changesOnly":true,"d
    viessmann.0 2019-08-05 21:24:08.354 info Connection with Viessmann system disconnected!
    viessmann.0 2019-08-05 21:24:08.354 warn Malfunction connection--> Error: connect EALREADY 192.168.178.46:3002 - Local (192.168.178.49:59122)
    viessmann.0 2019-08-05 21:19:08.319 warn Malfunction connection--> Error: This socket has been ended by the other party
    viessmann.0 2019-08-05 21:19:07.133 info Connection with Viessmann system disconnected!
    viessmann.0 2019-08-05 21:19:07.132 info Connection with Viessmann system disconnected!
    Je öfter man den Raspi startet, desto mehr wiederholende Meldungen bekomme ich.
    blauholstenB Offline
    blauholsten
    #401
    @passuff sagte in Viessmann-Adapter:
    Genau das macht mich irre, ich verstehe nicht warum der Server das als Antwort gibt. Hast du aber mal abgewartet ob der Adapter sich dann wieder verbindet?
    - Alarm Adapter
    P 1 Antwort Letzte Antwort
    • blauholstenB blauholsten
      passuff
      #402
      @blauholsten
      Das macht er nicht immer. Manchmal beim ersten mal. Manchmal aber auch nach 20 min nicht.
        dtp
        schrieb am zuletzt editiert von dtp
        #403
        Auch bei mir wird die Lampe zwar grün, aber der Adapter verbindet sich nicht. Eine Verbindung kommt erst zustande, wenn ich den Adapter manuell neu starte.
        Wenn ich mir das Log so ansehe, dann scheint da ein Clean vor dem Reconnect zu fehlen.
        • blauholstenB Offline
          blauholsten
          #404
          Moin,
          bitte nochmal testen....
          - Alarm Adapter
            dtp
            #405
            Sieht ganz gut aus.
            Ups. Zu früh gefreut.
            blauholstenB 1 Antwort Letzte Antwort
            • D dtp
              Sieht ganz gut aus.
              blauholsten
              #406
              @dtp sagte in Viessmann-Adapter:
              Sieht ganz gut aus.
              Scheint aber trotzdem nicht die richtige Version zu sein....bitte mach in der console noch ein iobroker upload viessmann....bzw deinstalliere den Adapter und installiere von git
              - Alarm Adapter
              • P Offline
                passuff
                #407
                @blauholsten sagte in Viessmann-Adapter:
                bei mir sieht es gut aus mit 1.11. Ich werde weiter beobachten:
                  dtp
                  #408
                  Es ist die Version 1.1.1. Hatte ich eigentlich eben über GitHub installiert.
                  EDIT: Hab den Adapter noch mal neu installiert. Jetzt läuft er.
                  Die Datenpunkte werden wieder aktualisiert.
                    blauholsten
                    #409
                    Das freut mich....
                    Eine Frage, sind die 5min okay, oder soll ich das ändern? Will natürlich auch nicht alle 30sec den log zumüllen wenn der client nicht erreichbar ist.?
                    - Alarm Adapter
                      Das freut mich....
                      passuff
                      #410
                      @blauholsten
                      Danke für das update.
                      Prinzipiell könnte man eine Variable für die Reconnect Zeit in den Einstellungen unterbringen, dann kann jeder es so Einstellen wie er möchte...
                      • bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        #411
                        Variable finde ich gut.
                        Könnte man denn auch noch einen möglichen "reboot auf dem raspi" einfügen (wie oben schon beschrieben).
                        Evtl. auch als "Ankreuz"-Feld zum auswählen.
                        Oder wäre dies zu aufwändig in der Programmierung.
                        Danke.
                        mfg
                        Dieter
                        Danke.
                        blauholstenB D 2 Antworten Letzte Antwort
                        • bahnuhrB bahnuhr
                          Danke.
                          mfg
                          Dieter
                          blauholsten
                          #412
                          @bahnuhr sagte in Viessmann-Adapter:
                          Danke.
                          mfg
                          Dieter
                          damit müsste ich erstmal intensiver beschäftigen. Allerdings befürchte ich, dass das gar nicht so einfach ist alle Systeme unter einen Hut zu bekommen....Windows, Linux, etc.
                          Aber falls unbedingt erforderlich, wäre jede Hilfe dankbar...
                          - Alarm Adapter
                          • P passuff
                            @blauholsten
                            blauholsten
                            #413
                            @blauholsten
                            Mache ich in der nächsten Version.....👍
                            - Alarm Adapter
                              @blauholsten
                              passuff
                              #414
                              @blauholsten
                              Danke!
                              • bahnuhrB bahnuhr
                                Danke.
                                mfg
                                Dieter
                                dtp
                                #415
                                Das bitte nur als Option, wenn überhaupt. Ansonsten besteht ja die Gefahr, dass Raspi und Adapter hier in eine Endlosschleife geraten.
                                Ich persönlich komme gut klar mit den fünf Minuten nach dem Verlust der Verbindung bis zum automatischen Neustart des Adapters. Vielleicht sollte man noch eine maximale Anzahl von Neustarts definieren können. Oder belastet ein permanentes Neustarten des Adapters den ioBroker nur geringfügig?
                                • P passuff
                                  @blauholsten
                                  Danke!
                                  blauholsten
                                  #416
                                  @blauholsten
                                  Danke!
                                  Erledigt in Version 1.2.0
                                  - Alarm Adapter
                                    @blauholsten
                                    Danke!
                                    passuff
                                    #417
                                    @blauholsten
                                    Danke!
                                    Danke!
                                    • P Pep
                                      Also bei mir läuft der Adapter auch super. Habe eine VITOTRONIC 200 KW2
                                      Hat jemand für mich da einen Tipp, wie ich den Ölverbrauch bestimmen kann?
                                      Den Wert
                                      <command name="getOelverbrauch" protocmd="getaddr"></command>
                                      <addr>7574</addr>
                                      <len>4</len>
                                      <unit>OV</unit>
                                      <description>Ermittle angezeigten Oelverbrauch</description>
                                      habe ich drin - da bekomme ich aber immer den gleichen Wert (26083.73) zurück. Kann man eventuell irgendwas berechnen (aus den Brennerstarts usw.)?
                                      martinschm
                                      #418
                                      @Pep said in Viessmann-Adapter:
                                      Hi @pep habe eine Vitrotronic 200 KW1. Könntest du trotzdem mal deine vito.xml posten oder per PN schicken?
                                      Evtl hat sich ja nicht so viel geändert.
                                      • L Linedancer
                                        Hallo Peer,
                                        Mir ist aufgefallen das mein System sensibel darauf reagiert in welcher Reihenfolge der ganze Kram gestartet wird.
                                        Ich muss zuerst mit
                                        sudo /etc/init.d/vcontrol start
                                        den Server auf dem Raspi im Heizungskeller starten, und danach den Viessmann Adapter neu starten, dann bleibt der Adapter grün und es werden Werte abgeholt.
                                        @C1500:
                                        Beim Versuch die Werte per TelNet zu holen ist mir aufgefallen das es teilweise etwas länger dauert, also bis >2-3 Sekunden bis ich eine Antwort bekomme. `
                                        Ja, das ist bei mir auch so.
                                        @C1500:
                                        Ebenso ist die erste Abfrage nach dem Starten der TelNet-Verbindung Fehlerhaft und wird mit einem ERR beantwortet. Die Wiederholung des Befehls bringt aber direkt dann die passende Antwort. `
                                        Das passiert bei mir nicht. Beim ersten Abfragen kommt auch eine Antwort.
                                        @C1500:
                                        Hat jemand das PDF von Viessmann mit den Datenpunkten für die V200KW2?
                                        Gruß Peer `
                                        ich habe das Protokoll für die V200KW1 (ID=2094) im Einsatz.
                                        Hier meine funktionierende vito.xml 1564_vito.xml
                                        und hier die dazu passende vcontrold.xml 1564_vcontrold.xml
                                        Das lesen und schreiben der Daten funktioniert perfekt. Das einzige was bei mir nicht funktioniert ist das setzen vom Niveau der Heizkurve,
                                        martinschm
                                        #419
                                        @Linedancer said in Viessmann-Adapter:
                                        Vielen Dank. Die XMLs für die Vitotronic 200 KW1 hab ich gesucht. Das spart mir eine Menge Arbeit
                                          martinschm
                                          schrieb am zuletzt editiert von martinschm
                                          #420
                                          ich probiere den Adapter grade ans fliegen zu bekommen. Ich verwende die XML von @Linedancer .
                                          vito.xml
                                          Leider bekomme ich im Log immer die Meldung
                                          cannot parse vito.xml Error: Non-whitespace before first tag. Line: 0 Column: 1 Char: �
                                          Jetzt hab ich an ein Encoding Problem zwischen Windows und Linux gedacht. Ich nutze TextpadNotepad++ unter Windows. Kann aber vor dem ersten Tag keinerlei Zeichen ausmachen.
                                          Woran könnte es noch liegen?
                                          PROBLEM GELÖST. Es lag wirklich an der Kodierung. Hab es in TextpadNotepad++ konvertiert und dann ging es.
