  4. [How-to] Node.js für ioBroker richtig updaten
installationlinuxnodenode.jsnodejswindows
1.1k Beiträge 106 Kommentatoren 885.4k Aufrufe 112 Beobachtet
  • F Offline
    FuLLHDvs480p
    schrieb am zuletzt editiert von FuLLHDvs480p
    #226
    habe folgendes Problem:
    rock64@rock64:/opt/iobroker$ iobroker stop
    rock64@rock64:/opt/iobroker$ curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
    ## Installing the NodeSource Node.js 10.x repo...
    ## Populating apt-get cache...
    + apt-get update
    Hit:1 http://security.debian.org stretch/updates InRelease
    Hit:2 http://ppa.launchpad.net/ayufan/rock64-ppa/ubuntu xenial InRelease
    Get:3 http://deb.ayufan.eu/orgs/ayufan-rock64/releases  InRelease [1339 B]
    Ign:4 http://cdn-fastly.deb.debian.org/debian stretch InRelease
    Get:5 http://cdn-fastly.deb.debian.org/debian stretch-updates InRelease [91.0 kB]
    Hit:6 https://deb.nodesource.com/node_10.x stretch InRelease
    Hit:7 http://cdn-fastly.deb.debian.org/debian stretch Release
    Fetched 92.4 kB in 2s (39.7 kB/s)
    Reading package lists... Done
    ## Confirming "stretch" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_10.x/dists/stretch/Release'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
    OK
    ## Creating apt sources list file for the NodeSource Node.js 10.x repo...
    + echo 'deb https://deb.nodesource.com/node_10.x stretch main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src https://deb.nodesource.com/node_10.x stretch main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    Ign:3 http://cdn-fastly.deb.debian.org/debian stretch InRelease
    Hit:4 http://cdn-fastly.deb.debian.org/debian stretch-updates InRelease
    Get:5 http://deb.ayufan.eu/orgs/ayufan-rock64/releases  InRelease [1339 B]
    Hit:6 http://cdn-fastly.deb.debian.org/debian stretch Release
    Hit:7 https://deb.nodesource.com/node_10.x stretch InRelease
    Fetched 1339 B in 2s (583 B/s)
    ## Run `sudo apt-get install -y nodejs` to install Node.js 10.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
         echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    rock64@rock64:/opt/iobroker$ sudo apt-get install -y nodejs
    Building dependency tree
    nodejs is already the newest version (10.16.0-1nodesource1).
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    rock64@rock64:/opt/iobroker$ node -v
    v10.16.0
    rock64@rock64:/opt/iobroker$ curl -sL https://iobroker.net/fix.sh | bash -
        Welcome to the ioBroker installation fixer!
        Script version: 2019-07-21
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
        Checking ioBroker user and directory permissions (2/3)
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    rock64@rock64:/opt/iobroker$ npm rebuild
    > @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
    > npm install node-pre-gyp
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp
    npm ERR! path /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp
    npm ERR! code EACCES
    npm ERR! errno -13
    npm ERR! syscall access
    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp'
    npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp']
    npm ERR!   stack:
    npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path:
    npm ERR!    '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    npm ERR!     /home/rock64/.npm/_logs/2019-07-26T09_47_03_405Z-debug.log
    npm ERR! code ELIFECYCLE
    npm ERR! errno 243
    npm ERR! @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall: `npm install node-pre-gyp`
    npm ERR! Exit status 243
    npm ERR!
    npm ERR! Failed at the @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall script.
    npm ERR!     /home/rock64/.npm/_logs/2019-07-26T09_47_03_647Z-debug.log
    rock64@rock64:/opt/iobroker$ npm install @abandonware/bluetooth-hci-socket
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/abbrev
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/ansi-regex
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/aproba
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/balanced-match
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/chownr
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/code-point-at
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/concat-map
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/brace-expansion
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/console-control-strings
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/core-util-is
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/deep-extend
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/delegates
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/detect-libc
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/fs.realpath
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/has-unicode
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/inherits
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/ini
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/isarray
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/minimatch
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/ignore-walk
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/minimist
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/mkdirp
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/needle/node_modules/debug
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/npm-bundled
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/npm-packlist
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/number-is-nan
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/is-fullwidth-code-point
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/object-assign
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/os-homedir
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/os-tmpdir
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/osenv
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/nopt
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/path-is-absolute
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/process-nextick-args
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/rc/node_modules/minimist
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/safe-buffer
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/safer-buffer
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/iconv-lite
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/sax
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/set-blocking
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/signal-exit
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/string_decoder
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/strip-ansi
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/string-width
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/strip-json-comments
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/util-deprecate
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/readable-stream
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/are-we-there-yet
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/wide-align
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/gauge
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/npmlog
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/wrappy
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/once
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/inflight
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/glob
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/rimraf
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/yallist
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/minipass
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/fs-minipass
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/minizlib
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/tar
    npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/bluetooth-hci-socket'
    npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-detector'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.radar/node_modules/bluetooth-hci-socket/package.json'
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket'
    npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket']
    npm ERR!   stack:
    npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket\'',
    npm ERR!   path:
    npm ERR!    '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket' }
    npm ERR!
    npm ERR!
    npm ERR!     /home/rock64/.npm/_logs/2019-07-26T09_58_41_378Z-debug.log
    Fixer Script habe ich laufen lassen,
    Radar2 und Ble vorher komplett gelöscht.
    Auch die Neuinstallation von bluetooth-hci-socket schlägt fehl.
    js-controller: 1.5.14
    Jemand eine Idee?
    • F FuLLHDvs480p
      + apt-get update
      OK
      + apt-get update
      v10.16.0
      Autostart enabled!
      npm ERR! errno -13
      npm ERR!   stack:
      npm ERR!   path:
      npm ERR!
      npm ERR!
      npm ERR! errno 243
      npm ERR!
      npm ERR! errno -13
      npm ERR!   stack:
      npm ERR!   path:
      npm ERR!
      npm ERR!
      Jemand eine Idee?
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      #227
      @FuLLHDvs480p Eigentlich dürfte das nicht passieren, aber probier mal im Ordner /opt/iobroker folgendes:
      sudo -H -u iobroker npm install @abandonware/bluetooth-hci-socket
      um die Installation als Benutzer iobroker auszuführen, der dort Schreibrechte haben müsste.
      F 1 Antwort Letzte Antwort
      • AlCalzoneA AlCalzone
        FuLLHDvs480p
        #228
        @AlCalzone Wenn ich mich über Putty als iobroker anmelde schließt sich das Fenster direkt wieder.
        Wenn ich mich als root anmelde und danach auf den Benutzer iobroker wechseln will kommt:
        root@rock64:~# su iobroker
        This account is currently not available.
        Hab die Installation mal als rock64 laufen lassen und bekomme diese Fehler:
        rock64@rock64:~$ cd /opt/iobroker/
        rock64@rock64:/opt/iobroker$ sudo -H -u iobroker npm install @abandonware/bluetooth-hci-socket
        [sudo] password for rock64:
        npm notice created a lockfile as package-lock.json. You should commit this file.
        + node-pre-gyp@0.12.0
        added 63 packages from 24 contributors, updated 1 package and audited 97 packages in 13.598s
        found 0 vulnerabilities
        > @abandonware/bluetooth-hci-socket@0.5.3-1 install /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
        > node-pre-gyp install --fallback-to-build
        node-pre-gyp WARN Using request for node-pre-gyp https download
        node-pre-gyp WARN Tried to download(404): https://github.com/sandeepmistry/node-bluetooth-hci-socket/releases/download/0.5.3-1/binding-0.5.3-1-node-v64-linux-arm64.tar.gz
        node-pre-gyp WARN Pre-built binaries not found for @abandonware/bluetooth-hci-socket@0.5.3-1 and node@10.16.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
        make: Entering directory '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build'
          CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
        ../src/BluetoothHciSocket.cpp: In member function 'void BluetoothHciSocket::poll()':
        ../src/BluetoothHciSocket.cpp:252:95: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
             Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
        In file included from ../src/BluetoothHciSocket.cpp:8:0:
        ../../../nan/nan.h:1045:46: note: declared here
           NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
        ../src/BluetoothHciSocket.cpp: In member function 'void BluetoothHciSocket::emitErrnoError()':
        ../src/BluetoothHciSocket.cpp:283:93: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
        ../src/BluetoothHciSocket.cpp: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)':
        ../src/BluetoothHciSocket.cpp:396:34: warning: 'int64_t v8::Value::IntegerValue() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
               devId = arg0->IntegerValue();
        In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                         from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                         from /home/iobroker/.node-gyp/10.16.0/include/node/node_buffer.h:25,
                         from ../src/BluetoothHciSocket.cpp:7:
        /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2476:46: note: declared here
           V8_DEPRECATED("Use maybe version", int64_t IntegerValue() const);
        /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro 'V8_DEPRECATED'
           declarator __attribute__((deprecated(message)))
        ../src/BluetoothHciSocket.cpp: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)':
        ../src/BluetoothHciSocket.cpp:418:34: warning: 'int64_t v8::Value::IntegerValue() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
          SOLINK_MODULE(target) Release/obj.target/binding.node
          COPY Release/binding.node
          COPY /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node
          TOUCH Release/obj.target/action_after_build.stamp
        make: Leaving directory '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/build'
        > bluetooth-hci-socket@0.5.1 install /opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket
        > node-gyp rebuild
        make: Entering directory '/opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket/build'
        ../src/BluetoothHciSocket.cpp:251:95: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
        ../../../../nan/nan.h:980:46: note: declared here
        ../src/BluetoothHciSocket.cpp:275:72: error: no matching function for call to 'v8::Function::NewInstance(int, v8::Local<v8::Value> [1])'
           Local<Value> error = errorConstructor->NewInstance(1, constructorArgs);
        In file included from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63:0,
        /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3993:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const
           V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(
        /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3993:44: note:   candidate expects 3 arguments, 2 provided
        /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3996:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const
        /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:3996:44: note:   candidate expects 1 argument, 2 provided
        ../src/BluetoothHciSocket.cpp:282:93: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
        ../src/BluetoothHciSocket.cpp:395:34: warning: 'int64_t v8::Value::IntegerValue() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
        ../src/BluetoothHciSocket.cpp:417:34: warning: 'int64_t v8::Value::IntegerValue() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
        binding.target.mk:99: recipe for target 'Release/obj.target/binding/src/BluetoothHciSocket.o' failed
        make: *** [Release/obj.target/binding/src/BluetoothHciSocket.o] Error 1
        make: Leaving directory '/opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket/build'
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
        gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
        gyp ERR! System Linux 4.4.132-1075-rockchip-ayufan-ga83beded8524
        gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket
        gyp ERR! node -v v10.16.0
        gyp ERR! node-gyp -v v3.8.0
        gyp ERR! not ok
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 (node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-socket):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 install: `node-gyp rebuild`
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
        + @abandonware/bluetooth-hci-socket@0.5.3-1
        removed 63 packages, updated 1 package and audited 19313 packages in 242.798s
        found 99 vulnerabilities (54 low, 5 moderate, 40 high)
          run `npm audit fix` to fix them, or `npm audit` for details
        • F FuLLHDvs480p
          > node-gyp rebuild
          gyp ERR! not ok
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          #229
          @FuLLHDvs480p sagte in [How-to] Node.js für ioBroker richtig updaten:
          Das ist gewollt.
          Das scheint funktioniert zu haben. Der Fehler kommt von dem Versuch, eine ältere Version davon zu kompilieren.
          Nein, du hast sie als iobroker ausgeführt, deswegen ja auch das umständlichere Kommando sudo -H -u iobroker ...
            Das ist gewollt.
            FuLLHDvs480p
            #230
            @AlCalzone Okay.
            Der npm rebuild läuft trotzdem nicht durch:
            npm ERR! errno -13
            npm ERR!   stack:
            npm ERR!   path:
            npm ERR!
            npm ERR!
            npm ERR!     /home/rock64/.npm/_logs/2019-07-26T14_46_23_187Z-debug.log
            npm ERR! errno 243
            npm ERR!
            npm ERR!     /home/rock64/.npm/_logs/2019-07-26T14_46_23_397Z-debug.log
            Kann ich hingehen und den ganzen Ordner von dem bluetooth-hci-socket löschen?
            StabilostickS 1 Antwort Letzte Antwort
            • F FuLLHDvs480p
              @AlCalzone Okay.
              npm ERR! errno -13
              npm ERR!   stack:
              npm ERR!   path:
              npm ERR!
              npm ERR!
              npm ERR! errno 243
              npm ERR!
              StabilostickS Offline
              Stabilostick
              #231
              @FuLLHDvs480p
              Führe bitte die folgenden Befehle aus:
              cd /opt/iobroker
              iobroker stop
              sudo rm -r /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
              npm install @abandonware/bluetooth-hci-socket --force
              iobroker start
              • StabilostickS Stabilostick
                @FuLLHDvs480p
                cd /opt/iobroker
                iobroker stop
                iobroker start
                FuLLHDvs480p
                #232
                @Stabilostick
                cd /opt/iobroker
                iobroker stop
                ergab folgendes:
                rock64@rock64:/opt/iobroker$ sudo rm -r /opt/iobroker/node_modules/@abandonware/        bluetooth-hci-socket
                rock64@rock64:/opt/iobroker$ npm install @abandonware/bluetooth-hci-socket --force
                npm WARN using --force I sure hope you know what you are doing.
                > @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall /opt/iobroker/node_modules/@abandonware/bluetoot        h-hci-socket
                added 63 packages from 24 contributors, updated 1 package and audited 97 packages in 12.486s
                > bluetooth-hci-socket@0.5.1 install /opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_        modules/bluetooth-hci-socket
                > node-gyp rebuild
                make: Entering directory '/opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/blu        etooth-hci-socket/build'
                ../src/BluetoothHciSocket.cpp:251:95: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Ob        ject>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
                ../src/BluetoothHciSocket.cpp:275:72: error: no matching function for call to 'v8::Function::NewInstanc        e(int, v8::Local<v8::Value> [1])'
                In file included from /home/rock64/.node-gyp/10.16.0/include/node/node.h:63:0,
                                 from /home/rock64/.node-gyp/10.16.0/include/node/node_buffer.h:25,
                /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3993:44: note: candidate: v8::MaybeLocal<v8::Object> v        8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const
                /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3993:44: note:   candidate expects 3 arguments, 2 prov        ided
                /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3996:44: note: candidate: v8::MaybeLocal<v8::Object> v        8::Function::NewInstance(v8::Local<v8::Context>) const
                /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3996:44: note:   candidate expects 1 argument, 2 provi        ded
                ../src/BluetoothHciSocket.cpp:282:93: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Ob        ject>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
                ../src/BluetoothHciSocket.cpp: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BluetoothH        ciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)':
                In file included from /home/rock64/.node-gyp/10.16.0/include/node/v8.h:26:0,
                                 from /home/rock64/.node-gyp/10.16.0/include/node/node.h:63,
                /home/rock64/.node-gyp/10.16.0/include/node/v8.h:2476:46: note: declared here
                /home/rock64/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro 'V8_DEPRECAT        ED'
                ../src/BluetoothHciSocket.cpp: In static member function 'static Nan::NAN_METHOD_RETURN_TYPE BluetoothH        ciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)':
                make: Leaving directory '/opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/blue        tooth-hci-socket/build'
                gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/bu        ild.js:262:23)
                gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js        " "rebuild"
                gyp ERR! cwd /opt/iobroker/node_modules/iobroker.radar/node_modules/noble/node_modules/bluetooth-hci-so        cket
                gyp ERR! not ok
                > osx-temperature-sensor@1.0.3 install /opt/iobroker/node_modules/osx-temperature-sensor
                > node-gyp rebuild
                make: Entering directory '/opt/iobroker/node_modules/osx-temperature-sensor/build'
                  SOLINK_MODULE(target) Release/obj.target/none.node
                  COPY Release/none.node
                make: Leaving directory '/opt/iobroker/node_modules/osx-temperature-sensor/build'
                > xpc-connection@0.1.4 install /opt/iobroker/node_modules/xpc-connection
                > node-gyp rebuild
                make: Entering directory '/opt/iobroker/node_modules/xpc-connection/build'
                make: Leaving directory '/opt/iobroker/node_modules/xpc-connection/build'
                > @abandonware/bluetooth-hci-socket@0.5.3-1 install /opt/iobroker/node_modules/@abandonware/bluetooth-h        ci-socket
                node-pre-gyp WARN Tried to download(404): https://github.com/sandeepmistry/node-bluetooth-hci-socket/re        leases/download/0.5.3-1/binding-0.5.3-1-node-v64-linux-arm64.tar.gz
                node-pre-gyp WARN Pre-built binaries not found for @abandonware/bluetooth-hci-socket@0.5.3-1 and node@1        0.16.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
                ../src/BluetoothHciSocket.cpp:252:95: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Ob        ject>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
                ../src/BluetoothHciSocket.cpp:283:93: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Ob        ject>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
                npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/bluetooth-hci-soc        ket'
                npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-det        ector'
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.radar/node        _modules/bluetooth-hci-socket/package.json'
                added 8 packages from 7 contributors and audited 19313 packages in 210.767s
                darauf das npm rebuild ergab:
                rock64@rock64:/opt/iobroker$ ^C
                rock64@rock64:/opt/iobroker$ clear
                updated 1 package and audited 97 packages in 8.593s
                [@abandonware/bluetooth-hci-socket] Success: "/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node" already installed
                Pass --update-binary to reinstall or --build-from-source to recompile
                > usb@1.6.0 install /opt/iobroker/node_modules/iobroker.ble/node_modules/usb
                > prebuild-install --verbose || node-gyp rebuild
                prebuild-install info begin Prebuild-install version 5.3.0
                prebuild-install info looking for cached prebuild @ /home/rock64/.npm/_prebuilds/c716aa-usb-v1.6.0-node-v64-linux-arm64.tar.gz
                prebuild-install http request GET https://github.com/tessel/node-usb/releases/download/v1.6.0/usb-v1.6.0-node-v64-linux-arm64.tar.gz
                prebuild-install http 404 https://github.com/tessel/node-usb/releases/download/v1.6.0/usb-v1.6.0-node-v64-linux-arm64.tar.gz
                prebuild-install WARN install No prebuilt binaries found (target=10.16.0 runtime=node arch=arm64 libc= platform=linux)
                make: Entering directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/usb/build'
                  CC(target) Release/obj.target/libusb/libusb/libusb/core.o
                  CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
                  CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
                  CC(target) Release/obj.target/libusb/libusb/libusb/io.o
                  CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
                  CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
                  CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
                  CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
                  CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
                  CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
                  AR(target) Release/obj.target/usb.a
                  COPY Release/usb.a
                  CXX(target) Release/obj.target/usb_bindings/src/node_usb.o
                ../src/node_usb.cc: In function 'void handleHotplug(std::pair<libusb_device*, libusb_hotplug_event>)':
                ../src/node_usb.cc:151:58: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
                  Nan::MakeCallback(Nan::New(hotplugThis), "emit", 2, argv);
                In file included from ../src/helpers.h:3:0,
                                 from ../src/node_usb.h:21,
                                 from ../src/node_usb.cc:1:
                ../node_modules/nan/nan.h:1001:46: note: declared here
                  CXX(target) Release/obj.target/usb_bindings/src/device.o
                ../src/device.cc: In static member function 'static void Req::default_after(uv_work_t*)':
                ../src/device.cc:237:64: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declaratio                                                ns]
                    Nan::MakeCallback(device, Nan::New(baton->callback), 1, argv);
                                 from ../src/device.cc:1:
                ../node_modules/nan/nan.h:959:46: note: declared here
                  CXX(target) Release/obj.target/usb_bindings/src/transfer.o
                ../src/transfer.cc: In function 'void handleCompletion(Transfer*)':
                ../src/transfer.cc:126:72: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarat                                                ions]
                   Nan::MakeCallback(self->handle(), Nan::New(self->v8callback), 3, argv);
                                 from ../src/transfer.cc:1:
                  SOLINK_MODULE(target) Release/obj.target/usb_bindings.node
                  COPY Release/usb_bindings.node
                make: Leaving directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/usb/build'
                > @abandonware/noble@1.9.2-2 install /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
                > node-gyp rebuild
                make: Entering directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build'
                  SOLINK_MODULE(target) Release/obj.target/noble.node
                  COPY Release/noble.node
                make: Leaving directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build'
                  COPY Release/usb.a
                > @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket
                updated 1 package and audited 95 packages in 8.66s
                > @abandonware/bluetooth-hci-socket@0.5.3-1 install /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket
                [@abandonware/bluetooth-hci-socket] Success: "/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node" already installed
                > @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings
                > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                make: Entering directory '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/build'
                  CXX(target) Release/obj.target/bindings/src/serialport.o
                  CXX(target) Release/obj.target/bindings/src/serialport_unix.o
                  CXX(target) Release/obj.target/bindings/src/poller.o
                  CXX(target) Release/obj.target/bindings/src/serialport_linux.o
                  SOLINK_MODULE(target) Release/obj.target/bindings.node
                  COPY Release/bindings.node
                make: Leaving directory '/opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/build'
                > grpc@1.20.3 install /opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc
                > node-pre-gyp install --fallback-to-build --library=static_library
                [grpc] Success: "/opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/node/extension_binary/node-v64-linux-arm64-glibc/grpc_node.node" already installed
                > protobufjs@6.8.8 postinstall /opt/iobroker/node_modules/iobroker.iogo/node_modules/@grpc/proto-loader/node_modules/protobufjs
                > node scripts/postinstall
                (node:19565) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 SIGINT listeners added. Use emitter.setMaxListeners() to increase limit
                > iobroker.javascript@4.1.14 postinstall /opt/iobroker/node_modules/iobroker.javascript
                > node ./install/installTypings.js
                Installing NodeJS typings...
                latest @types: 12, installed node: 10
                > iobroker.js-controller@1.5.14 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                > node lib/preinstallCheck.js
                NPM version: 6.4.1
                npm version >= 5: disabling package-lock
                > iobroker.js-controller@1.5.14 install /opt/iobroker/node_modules/iobroker.js-controller
                > node iobroker.js setup first
                > unix-dgram@2.0.3 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/unix-dgram
                > node-gyp rebuild
                make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/unix-dgram/build'
                  CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                  SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                  COPY Release/unix_dgram.node
                make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/unix-dgram/build'
                > websocket@1.0.28 install /opt/iobroker/node_modules/iobroker.lgtv/node_modules/websocket
                > (node-gyp rebuild 2> builderror.log) || (exit 0)
                make: Entering directory '/opt/iobroker/node_modules/iobroker.lgtv/node_modules/websocket/build'
                  CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
                  SOLINK_MODULE(target) Release/obj.target/bufferutil.node
                  COPY Release/bufferutil.node
                  CXX(target) Release/obj.target/validation/src/validation.o
                  SOLINK_MODULE(target) Release/obj.target/validation.node
                  COPY Release/validation.node
                make: Leaving directory '/opt/iobroker/node_modules/iobroker.lgtv/node_modules/websocket/build'
                > ws@0.7.0 install /opt/iobroker/node_modules/iobroker.owntracks/node_modules/ws
                make: Entering directory '/opt/iobroker/node_modules/iobroker.owntracks/node_modules/ws/build'
                bufferutil.target.mk:101: recipe for target 'Release/obj.target/bufferutil/src/bufferutil.o' failed
                make: Leaving directory '/opt/iobroker/node_modules/iobroker.owntracks/node_modules/ws/build'
                > ws@0.6.5 install /opt/iobroker/node_modules/iobroker.owntracks/node_modules/websocket-stream/node_modules/ws
                make: Entering directory '/opt/iobroker/node_modules/iobroker.owntracks/node_modules/websocket-stream/node_modules/ws/build'
                make: Leaving directory '/opt/iobroker/node_modules/iobroker.owntracks/node_modules/websocket-stream/node_modules/ws/build'
                > usb@1.5.0 install /opt/iobroker/node_modules/iobroker.radar/node_modules/usb
                [usb] Success: "/opt/iobroker/node_modules/iobroker.radar/node_modules/usb/src/binding/usb_bindings.node" already installed
                > node-gyp rebuild
                ../src/BluetoothHciSocket.cpp:251:95: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated                                                -declarations]
                /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3993:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const
                /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3993:44: note:   candidate expects 3 arguments, 2 provided
                /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3996:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const
                /home/rock64/.node-gyp/10.16.0/include/node/v8.h:3996:44: note:   candidate expects 1 argument, 2 provided
                ../src/BluetoothHciSocket.cpp:282:93: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated                                                -declarations]
                /home/rock64/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro 'V8_DEPRECATED'
                gyp ERR! not ok
                npm ERR! errno 1
                npm ERR! bluetooth-hci-socket@0.5.1 install: `node-gyp rebuild`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the bluetooth-hci-socket@0.5.1 install script.
                npm ERR!     /home/rock64/.npm/_logs/2019-07-27T16_07_21_234Z-debug.log
                Hab gerade Versucht ble auf die neue Version zu bringen, bekomme dann die Fehler:
                $ ./iobroker upgrade ble
                Update ble from @0.7.4 to @0.8.1
                NPM version: 6.4.1
                npm install iobroker.ble@0.8.1 --production --save --prefix "/opt/iobroker" (System call)
                npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gypnpm
                npm
                 WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/bluetooth-hci-socket'npm WARN ELOOP: too many symbolic links encountered, stat '/opt/iobroker/node_modules/iobroker.type-detector'
                npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gypnpm ERR! code EACCES
                npm ERR! errno -13
                npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp'npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp']
                npm ERR!
                   stack:npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp\'',
                npm
                 ERR!   errno: -13,npm ERR!   code: 'EACCES',
                npm ERR!   path:
                npm
                ERR!    '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp' }npm ERR!
                npm ERR!
                 The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current user
                npm ERR!
                npm
                 ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try running
                npm ERR!     /home/iobroker/.npm/_logs/2019-07-27T17_03_18_601Z-debug.log
                ERROR: host.rock64 Cannot install iobroker.ble@0.8.1: 243
                • MicM Offline
                  MicM Offline
                  Mic
                  #233
                  Hi Leute,
                  vielen Dank für Eure Arbeit :-) Ihr habt in der Zwischenzeit auch noch mal einiges verbessert wie es scheint 😎
                  Erfolgreich durchgeführt bei mir ohne Fehlermeldungen. Ich habe hierzu auf Proxmox einen neuen Debian-Container erstellt, Vorgehensweise war wie folgt:
                  1. Debian-Container (CT) erstellen
                  2. In Proxmox den CT starten und auf die Konsole gehen
                  3. Neuen Nicht-Admin-User anlegen: adduser <username>
                  4. sudo installieren: apt-get install -y sudo
                  5. User zur sudo-Gruppe hinzufügen: adduser <username> sudo
                  6. Der Befehl ip addr gibt uns die IP-Adresse. Damit können wir uns nun mit Putty verbinden, immer den neu angelegten User nehmen, nicht den admin.
                  7. Nun im Putty aktualisieren:
                    sudo apt-get update && sudo apt-get upgrade && sudo apt-get dist-upgrade
                  8. curl installieren: sudo apt-get install curl
                  9. Zur Sicherheit in Proxmox einen Snapshot erstellen
                  10. curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
                  11. sudo apt install -y nodejs
                  12. sudo npm install -g npm
                  13. sudo reboot
                  14. curl -sL https://iobroker.net/install.sh | bash -
                  15. Fertig :)
                  Danach noch folgendes:
                  1. Adapter „BackitUp“ installieren.
                  2. Full-Backup ins Verzeichnis „/opt/iobroker/backups” kopieren und im BackitUp-Adapter einspielen ("Wiederherstellen")
                  3. Host / IP: Beim Umzug hat sich die IP und Host-Name geändert. Daher in der Konsole folgendes ausführen:
                    3.1 iobroker stop
                    3.2 iobroker host this. Man kann auch einen neuen Hostnamen vergeben, dazu iobroker host set newHostName eingeben.
                    3.3 Die folgenden Dateien bearbeiten: /opt/iobroker/iobroker-data/objects.json und /opt/iobroker/iobroker-data/states.json und dort alle IP-Adressen durch die neue IP ersetzen.
                    3.4 iobroker start
                    Details: siehe https://github.com/ioBroker/ioBroker/wiki/Console-commands#iobroker-host
                  4. Sonoff-Adapter: Hier in auf der jeweiligen Site des Gerätes (z.B. http://192.168.XX.XX/? unter „Configuration > Configure MQTT“ die neue IP eintragen.
                  • MicM Mic
                    Hi Leute,
                    13. sudo reboot
                    15. Fertig :)
                      3.1 iobroker stop
                      3.4 iobroker start
                    crunchipC Offline
                    crunchipC Offline
                    #234
                    @Mic Super mit der Beschreibung/Auflistung.
                    Hast du dein System neu aufgesetzt? Warum nun IoBroker im Container? Hattest du den nicht in ner VM laufen?
                    Bin auch grad am überlegen, nen Container zu erstellen, für ne Testumgebung.
                    Produktiv läuft er auf ner VM.
                    • MicM Offline
                      MicM Offline
                      Mic
                      #235
                      @crunchip
                      Ja, ich habe neu aufgesetzt, hatte aber auch vorher schon den ioBroker im Container, nicht VM. Meine persönlichen Gründe dafür:
                      • weniger Ressourcenverbrauch
                      • schnellere initiale Installation
                      • kleinere Backups
                      • MicM Mic
                        @crunchip
                        • kleinere Backups
                        crunchipC Offline
                        crunchipC Offline
                        #236
                        @Mic ok
                        das muss ich mal testen ob alles in nem Container funktioniert, vllt stell ich dann auch um.
                        • L Offline
                          LJSven
                          #237
                          Wenn ich den Befehl
                          ausführe, wird das Update nur auf 10.16.0 gemacht - nicht auf 10.16.1
                          Was mache ich falsch?
                          • L LJSven
                            Wenn ich den Befehl
                            sigi234S Online
                            sigi234S Online
                            #238
                            @LJSven sagte in [How-to] Node.js für ioBroker richtig updaten:
                            Wenn ich den Befehl
                            Nix, v10.16.0 ist die empfohlene...............
                            L 1 Antwort Letzte Antwort
                            • sigi234S sigi234
                              Wenn ich den Befehl
                              LJSven
                              #239
                              @sigi234 sagte in [How-to] Node.js für ioBroker richtig updaten:
                              Wenn ich den Befehl
                              Okay, im Info Adapter zeigt er mir die "gelb" an bzw. sagt "Es gibt eine neuere Version...."
                              • L LJSven
                                Wenn ich den Befehl
                                sigi234S Online
                                sigi234S Online
                                #240
                                Aha, bei mir nicht...........
                                Doch bei mir jetzt auch..........
                                • marcusklM Offline
                                  marcusklM Offline
                                  marcuskl
                                  #241
                                  Bei mir ist auch 10.16.1 Empfohlen, wie kommt das ?
                                  Host: Intel Nuc6cayh (16GB Ram, 240GB SSD) mit Proxmox.
                                  Iobroker VM, InfluxDB LXC, Pihole LXC, Tasmoadmin LXC, Easy2connect VM
                                  • apollon77A Offline
                                    #242
                                    Weil es die seit ein paar Tagen gibt und SIe aktueller als die 10.1.6.0 ist :-)
                                    Wir EMpfehlen bei ioBroker eine LTS Version. In dem Fall "10.x"
                                    • Dr. BakteriusD Offline
                                      Dr. Bakterius
                                      #243
                                      Sorry für crossposting aber bei mir meldet der Info-Adapter nach einem Update auf 10.16.1, dass die Version 10.16.1 installiert ist, es aber die neuere Version 10.16.0 gibt. 🤔
                                        #244
                                        @Dr-Bakterius Dann doch bitte anstelle dieses Cross-Posts der, korrekt, hier nicht hergehört, ein GitHub Issue im Info Adapter anlegen falls es das nicht schon gibt.
                                        Dr. BakteriusD 1 Antwort Letzte Antwort
                                        • apollon77A apollon77
                                          Dr. Bakterius
                                          #245
                                          @apollon77 Schon klar, aber 1. wurde das Thema nunmal hier auch aufgeworfen, 2. geht es anderen vielleicht auch so und 3. ist doch ein Forum genau dafür da - sonst könnten alle gleich auf Git umziehen.
