  4. [Aufruf] Adapter: Snips - Offline Speak2Text
snips
635 Beiträge 43 Kommentatoren 261.3k Aufrufe 22 Beobachtet
  • WalW
    WalW
    Wal
    schrieb am zuletzt editiert von Wal
    #342
    Hier mal meine Config:
    Snips-Server:
    Connected to device localhost
    OS version ................... Debian GNU/Linux 9 (stretch)
    Installed assistant .......... ioBroker
    Language ..................... de
    Hotword ...................... hey_snips
    ASR engine ................... snips
    Status ....................... Live
    Service status:
    snips-analytics .............. (not running)
    snips-asr .................... 0.60.8 (running)
    snips-audio-server ........... 0.60.8 (running)
    snips-dialogue ............... 0.60.8 (running)
    snips-hotword ................ 0.60.8 (running)
    snips-nlu .................... 0.60.8 (running)
    snips-skill-server ........... 0.60.8 (not running)
    snips-tts .................... 0.60.8 (running)
    [snips-common]
     bus = "mqtt"
     mqtt = "localhost:1500"
    # audio = ["+@mqtt"]
    # assistant = "/usr/share/snips/assistant"
    # user_dir = "/var/lib/snips"
    [snips-audio-server]
    # frame = 256
    bind = "livingroom@mqtt"
    # mike = "Built-in Microphone"
    # disable_playback = false
    [snips-hotword]
    # model = "/usr/share/snips/hotword"
    # hotword_id = "default"
    # sensitivity = "0.5"
    audio = ["livingroom@mqtt", "kitchen@mqtt"]
    Satellit:
    OS version ................... Raspbian GNU/Linux 9 (stretch)
    Installed assistant .......... Not installed
    Status ....................... Live (no assistant)
    Service status:
    snips-asr .................... (not running)
    snips-audio-server ........... 0.60.12 (running)
    snips-dialogue ............... (not running)
    snips-hotword ................ (not running)
    snips-nlu .................... (not running)
    snips-skill-server ........... (not running)
    snips-tts .................... (not running)
    [snips-common]
    # bus = "mqtt"
    mqtt = "192.168.111.5:1500"
    # frame = 256
    bind = "kitchen@mqtt"
    # disable_capture = false
    Injection geht mit dieser Config bei mir.
    Edit: snips-injection ist nur auf dem Server installiert.
    Walter
    DoorIO-Adapter
    ___manalishi_ unltdnetworxU 2 Antworten Letzte Antwort
    • unltdnetworxU unltdnetworx
      @frank70 sagte in [Aufruf] Adapter: Snips - Offline Speak2Text:
      Ist ein Audio-Server bei injects notwendig?
      Für die injects musst du lediglich den den Dienst installieren und sollte dann normalerweise laufen:
      sudo apt-get install -y snips-injection
      Du musst beim Audio Server immer den Namen des Satelliten eintragen.
      [snips-common]
      mqtt = "YOUR_BASE_IP/HOST_NAME:1883"
      Bei Snips Common deinen Server. Z.B. Server.fritz. box:1883
      Kann es sein, dass du das Gerät evtl. neugestartet hast und die jeweiligen Server nicht neustarten?
      ___manalishi_
      ___manalishi_
      ___manalishi
      #343
      @unltdnetworx Ich habe den install cmd für den snips-injection service nochmals ausgeführt.
      Jetzt funktionieren die Injects wieder! Verstaden habe ich es ehrlich gesagt nicht ganz.
      Wegen dem angeblich falschen Repository bei sam init habe ich die Installation auf der VM ja mit:
      "apt install -y alsa-utils snips-platform-voice snips-skill-server snips-watch curl unzip"
      und nach der Node installation mit:
      "npm install -g snips-sam" installiert
      Sollte dabei der injection-service nicht mit installiert worden sein?
      /ioBoker auf PVE LXC
      • A AndiM
        @frank70 said in [Aufruf] Adapter: Snips - Offline Speak2Text:
        Habe ein USB Headset an der VM angeschlossen und den danach audio-server starten können.
        Injects gehen auch bei laufendem audio-server nicht.
        servus,
        brauchst auch nicht ...
        schau mal mit "sam service log" ob er nicht versucht irgend welche Dienste zu starten, was das System ausbremst, bzw. siehst damit auch warum er die Injects net schafft.
        Services welche er starten will aber nicht benötigt werden kannst übrigens mit:
        sudo systemctl disable/enable snips-?????????.service
        de- oder aktivieren.
        lg
        ___manalishi_
        ___manalishi_
        ___manalishi
        #344
        @AndiM
        Merci! Guter Hinweis. Ich habe den Skill-Server und den Audio-Server deaktiviert. Die Errors im logfile sind jetzt weg!
        • WalW Wal
          Snips-Server:
          Service status:
          [snips-common]
           bus = "mqtt"
          # frame = 256
          [snips-hotword]
          Satellit:
          Service status:
          [snips-common]
          # bus = "mqtt"
          # frame = 256
          ___manalishi_
          ___manalishi_
          ___manalishi
          schrieb am zuletzt editiert von ___manalishi
          #345
          @Wal Snips-Injection war natürlich auf den Satteliten auch installiert, weil ich die Geräte ursprünglich als Standalone-Device installiert habe.
          Nächste Woche bekomme ich hoffentlich meinen Gehäuse Prototypen (habe selbst noch keinen Drucker). Soll ich nochmal versuchen das Jabra mit einem PiZero im Gehäuse zu positionieren oder habt ihr das als "zu teuer" verworfen?
          WalW 1 Antwort Letzte Antwort
          • ___manalishi_ ___manalishi
            WalW
            WalW
            Wal
            #346
            Lass es erst mal gut sein, wenn es mal gut funktioniert sprechen wir nochmal darüber.☺
            Walter
            DoorIO-Adapter
            ___manalishi_ 1 Antwort Letzte Antwort
            • R
              R
              rascal
              #347
              zwei kurze Fragen:
              • Wenn ich einen Satelliten installiere, kann ich dann in Iobroker dafür eine extra Text2Command Instanz verwenden, oder läuft der Satellit über die Text2Command des Main?
              • Wäre es eine Idee/ist es möglich Snips nur für Sprachausgabe zu verwenden? Bzw. eine Sprachausgabe synchron auf allen Snips Instanzen auszugeben?
              • R
                R
                rascal
                schrieb am zuletzt editiert von rascal
                #348
                Ok, ich habe jetzt ausprobiert:
                einen Master + ein Satellite
                Beide Eingabe gehen über eine Iobroker-Snips Instanz zu einem Text2Command Adapter, logisch - keine Überraschung.
                zwei Master
                Jeder Snips geht auf eine Iobroker_Snips Instanz, aber es bringt nichts, dass man 2 Text2Command Adapter installiert, die verhalten sich wie einer :(
                Hintergrund meiner Fragen:
                2 Zimmer: zb: Bad und Küche
                Wie mache ich es, dass, wenn ich in der Küche "Licht an" sage, in der Küche das Licht an geht und wenn ich im Bad "Licht an" sage, das Licht im Bad an geht, bzw auch im richtigen Raum die Antwort erfolgt?
                • unltdnetworxU
                  unltdnetworxU
                  unltdnetworx
                  #349
                  @rascal
                  Hey Rascal,
                  also ich persönlich würde mir immer eine andere Lösung suchen, als zwei Master zu betreiben. Da hast du immer doppelte Arbeit.
                  Aber zum Thema Satelliten und Raumerkennung hatten wir oben schon mal geschrieben. Wir sind noch dran, ist aber definitiv geplant. Momentan haben wir aber das Problem, dass wir die Ausgabe nicht gesichert auf dem richtigen Gerät bekommen, falls zwei Satelliten zeitnah zueinander benutzt werden.
                  Jetzt sollten wir auch erst mal den 25.02. abwarten. Dann kommt eine neue Snips-Version heraus, mit größeren Änderungen.
                  Gruß, Michael
                  Weitere Infos im Profil.
                  Wenn euch der Beitrag weitergeholfen hat, könnt ihr die Bewertung rechts unten im Beitrag nutzen.
                  • unltdnetworxU
                    unltdnetworxU
                    unltdnetworx
                    #350
                    Noch eine andere Frage. Hat jemand seinen ioBroker auch auf einer Synology mit Docker laufen?
                    Ich habe HDD-Standby bei längerer Nichtbenutzung aktiv und das Gefühl, dass Snips manchmal ewig braucht um zu antworten. Bin mir nicht sicher, ob es am Aufwecken der Festplatten liegt.
                    Gruß, Michael
                    • unltdnetworxU
                      unltdnetworxU
                      unltdnetworx
                      #351
                      @Wal
                      Ich hab, glaub ich, die Lösung für ein paar Probleme gefunden. Muss sie nur noch umsetzen. 😂
                      Man kann nämlich die SessionID verarbeiten. Somit kann man die Endgeräte/Satelliten gezielt rückansprechen und auch Timeouts nach nicht erkannten Intents verkürzen/sofort abbrechen.
                      Mal schauen, wir schnell das umsetzbar ist. Freitag hab ich etwas Zeit dafür.
                      Gruß, Michael
                      WalW A 2 Antworten Letzte Antwort
                        @Wal
                        WalW
                        WalW
                        Wal
                        #352
                        @unltdnetworx ,
                        super 👍 i.M. muss ich meine neue Libreelec-Maschine (Beelink S2 N5000) umbauen, die hat kein IR. Der Prototyp des IR-Empfängers/Einschalters läuft aber schon ohne Probleme.
                        Walter
                        DoorIO-Adapter
                          @Wal
                          A
                          A
                          AndiM
                          schrieb am zuletzt editiert von AndiM
                          #353
                          @unltdnetworx t2c fängt mit der session id nicht viel an ... wollt ihr ein eigenes Snips2C machen? ... hätt ich nur mehr Ahnung von Java/node.js :(
                          • WalW Wal
                            ___manalishi_
                            ___manalishi_
                            ___manalishi
                            #354
                            @Wal habe das hier zufällig gesehen. Wäre das vielleicht was?
                            https://aiyprojects.withgoogle.com/voice/
                            Natürlich nur die Komponenten, nicht die Pappschachtel☺
                            • unltdnetworxU
                              unltdnetworxU
                              unltdnetworx
                              schrieb am zuletzt editiert von unltdnetworx
                              #355
                              @AndiM
                              Ja genau das ist das Hauptproblem. Aber nichtsdestotrotz arbeitet der Adapter im Moment nur neben Snips und greift die Daten ab. Er sollte aber richtig mit Snips kommunizieren, das geht eben mit den SessionIDs. In der Theorie hab ich eine Idee. Muss morgen mal sehen, ob es auch praktisch klappt umzusetzen.
                              Zur Kommunikation mit t2c muss entweder eine t2c-Regel die Daten entsprechend zurückgeben oder t2c um SessionIDs erweitert werden.
                              Zur Not muss wirklich der Snips-Adapter erweitert werden. Aber das wäre nur die äußerste Lösung.
                              Gruß, Michael
                                ___manalishi_
                                ___manalishi_
                                ___manalishi
                                #356
                                @unltdnetworx said in [Aufruf] Adapter: Snips - Offline Speak2Text:
                                I.d.R. gehen die Platten nicht auf Standby wenn eine Applikation läuft. Habe keine Erfahrung mit dem ioBroker on Docker, aber wenn du z.B Mailserver laufen hast oder auch Unifi WifiController auf Docker, dann schalten die Platten nicht ab.
                                Ich habe lange Wartezeiten und Fehverhlalten beim LED Feedback auf meinen Satteliten, starte seit ein paar Tagen die Snips Services sowohl auf dem Server als auch auf beiden PI's per crontab 2 mal täglich.
                                • unltdnetworxU
                                  unltdnetworxU
                                  unltdnetworx
                                  #357
                                  Danke für dein Feedback. Bei mir gehen die denke ich schon in Standby, zumindest dauert der erste Aufruf manchmal etwas länger. Könnte natürlich auch an Snips liegen. Bin mal auf das Update am 25.02. gespannt.
                                  Gruß, Michael
                                  • R
                                    R
                                    rascal
                                    #358
                                    ich spiele mich schon die letzten paar Tage mit snips.
                                    Ich habe es im Moment mit zwei "Main" + 2 Snips Instanzen + Javascript Programmen gelöst, funktioniert ganz gut.
                                    Was mir aufgefallen ist, bzw was ich mir wünschen würde, wäre:
                                    • die Möglichkeit die Lautstärke des Bestätigungstones ("Hey Snips - "PING" - Command - PING") über einen Snips-Datenpunkt laufend anpassen zu können. Zum Beispiel unter Tags etwas lauter, in der Nacht leiser.
                                    • die Möglichkeit, Snips Programmgesteuert in den "Lauschmodus" zu schalten. Damit wären z.B. Antworten an Snips möglich, ohne "Hey snips" zu sagen. Beispiel: snips:"Die Sonne scheint draußen, soll ich die Rolläden beschatten?" - Benutzer:"Ja bitte" (und nicht "Hey snips, ja bitte")
                                      Wäre doch ein netter Schritt in Richtung Unterhaltung mit dem Haus oder? :)
                                    • unltdnetworxU
                                      unltdnetworxU
                                      unltdnetworx
                                      #359
                                      Zu Punkt 1: Das scheint momentan leider von Snips aus nicht zu funktionieren.
                                      An Punkt 2 bin ich gerade dran. Das liegt daran, dass dem Adapter momentan die Sessions des Snips herzlich egal sind.
                                      Gruß, Michael
                                      smartboartS M 2 Antworten Letzte Antwort
                                        smartboartS
                                        smartboartS
                                        smartboart
                                        schrieb am zuletzt editiert von smartboart
                                        #360
                                        Hi, heute gibt es ein neues release von snips....wie schaut es mit dem Update aus....Wenn das jemand ausprobiert hat, kann man ja hier mal die Erfahrungen posten....Werde im laufe der Woche mal das system updaten und berichten...Ist bei mir eh alles noch im Test, bzw. nutze ich es nicht wirklich...ist noch im just for fun Betrieb...Ist denn zu erwarten, dass der adapter oder der skill nicht kompatibel sein koennten?
                                        Ansosnten ist vlt. ein image backup im Vorfeld angebracht...
                                        unltdnetworxU 1 Antwort Letzte Antwort
                                        • smartboartS smartboart
                                          unltdnetworxU
                                          unltdnetworxU
                                          unltdnetworx
                                          #361
                                          @smartboart
                                          Werde heute Abend mal testen. Aber die Release Notes lesen sich nicht so gravierend, als dass der Adapter nicht mehr funktionieren würde.
                                          Auf die verbesserte Hotword Erkennung bin ich gespannt. ☺
                                          Gruß, Michael
                                          33.2k
                                          84.3k
