  4. Adapter: iobroker.backitup (stable Release)
adapterbackitupiobroker backupbackupiobroker.backitup
2.3k Beiträge 185 Kommentatoren 1.6m Aufrufe 50 Beobachtet
  • tripperT tripper
    @simatec
    Hier mal den Log vom Adapter nach der Wiederherstellung.
    Das ist so aber nicht ganz real reproduziert. Wollte den ioBroker nicht noch einmal komplett löschen, deshalb hier einfach mal ein Restore über die laufende Installation.
    Den ioBroker musste ich per Shell starten, der kam nicht mehr selbst hoch
    backitup.1	2019-02-10 22:21:45.450	info	terminating
    backitup.1	2019-02-10 22:21:45.126	debug	system.adapter.admin.0: logging false
    backitup.1	2019-02-10 22:21:44.940	error	at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
    backitup.1	2019-02-10 22:21:44.940	error	at maybeClose (internal/child_process.js:915:16)
    backitup.1	2019-02-10 22:21:44.940	error	at ChildProcess.emit (events.js:214:7)
    backitup.1	2019-02-10 22:21:44.940	error	at emitTwo (events.js:126:13)
    backitup.1	2019-02-10 22:21:44.940	error	at ChildProcess.exithandler (child_process.js:273:7)
    backitup.1	2019-02-10 22:21:44.940	error	at child_process.exec (/opt/iobroker/node_modules/iobroker.backitup/lib/restore.js:71:13)
    backitup.1	2019-02-10 22:21:44.940	error	ReferenceError: log is not defined
    backitup.1	2019-02-10 22:21:44.939	error	uncaught exception: log is not defined
    backitup.1	2019-02-10 22:21:44.886	debug	sendTo "restore" to system.adapter.admin.0 from system.adapter.backitup.1
    backitup.1	2019-02-10 22:21:38.037	debug	sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.1
    backitup.1	2019-02-10 22:21:19.385	debug	mount activ... umount in 10 Seconds!!
    backitup.1	2019-02-10 22:21:19.369	debug	[total] 10 30 04 */5 * *
    backitup.1	2019-02-10 22:21:19.357	info	[total] backup was activated at 04:30 every 5 day(s)
    backitup.1	2019-02-10 22:21:19.356	debug	[minimal] 10 00 04 */1 * *
    backitup.1	2019-02-10 22:21:19.310	info	[minimal] backup was activated at 04:00 every 1 day(s)
    backitup.1	2019-02-10 22:21:19.230	info	starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.0
    backitup.1	2019-02-10 22:21:19.036	debug	statesDB connected
    backitup.1	2019-02-10 22:21:18.932	debug	objectDB connected
    backitup.1	2019-02-10 22:21:09.181	debug	mount activ... umount in 10 Seconds!!
    backitup.1	2019-02-10 22:21:09.159	debug	[total] 10 30 04 */5 * *
    backitup.1	2019-02-10 22:21:09.138	info	[total] backup was activated at 04:30 every 5 day(s)
    backitup.1	2019-02-10 22:21:09.137	debug	[minimal] 10 00 04 */1 * *
    backitup.1	2019-02-10 22:21:09.060	info	[minimal] backup was activated at 04:00 every 1 day(s)
    backitup.1	2019-02-10 22:21:08.743	warn	Cannot read log file: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/lib/total.json'
    backitup.1	2019-02-10 22:21:08.698	debug	[EXIT] 0
    backitup.1	2019-02-10 22:21:08.698	debug	[DEBUG] [minimal] System successfully restored!
    backitup.1	2019-02-10 22:21:08.697	debug	[DEBUG] [minimal] upload [0] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/01d.svg icons/01d.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.697	debug	[DEBUG] [minimal] upload [1] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/01m.svg icons/01m.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.696	debug	[DEBUG] [minimal] upload [2] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/01n.svg icons/01n.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.696	debug	[DEBUG] [minimal] upload [3] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/02d.svg icons/02d.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.696	debug	[DEBUG] [minimal] upload [4] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/02m.svg icons/02m.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.695	debug	[DEBUG] [minimal] upload [5] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/02n.svg icons/02n.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.695	debug	[DEBUG] [minimal] upload [6] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/03d.svg icons/03d.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.695	debug	[DEBUG] [minimal] upload [7] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/03m.svg icons/03m.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.694	debug	[DEBUG] [minimal] upload [8] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/03n.svg icons/03n.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.694	debug	[DEBUG] [minimal] upload [9] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/04.svg icons/04.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.693	debug	[DEBUG] [minimal] upload [10] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/05d.svg icons/05d.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.693	debug	[DEBUG] [minimal] upload [11] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/05m.svg icons/05m.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.693	debug	[DEBUG] [minimal] upload [12] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/05n.svg icons/05n.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.692	debug	[DEBUG] [minimal] upload [13] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/06d.svg icons/06d.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.692	debug	[DEBUG] [minimal] upload [14] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/06m.svg icons/06m.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.692	debug	[DEBUG] [minimal] upload [15] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/06n.svg icons/06n.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.691	debug	[DEBUG] [minimal] upload [16] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/07d.svg icons/07d.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.691	debug	[DEBUG] [minimal] upload [17] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/07m.svg icons/07m.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.690	debug	[DEBUG] [minimal] upload [18] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/07n.svg icons/07n.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.690	debug	[DEBUG] [minimal] upload [19] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/08d.svg icons/08d.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.690	debug	[DEBUG] [minimal] upload [20] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/08m.svg icons/08m.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.689	debug	[DEBUG] [minimal] upload [30] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/20m.svg icons/20m.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.689	debug	[DEBUG] [minimal] upload [40] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/25d.svg icons/25d.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.689	debug	[DEBUG] [minimal] upload [50] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/28m.svg icons/28m.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.688	debug	[DEBUG] [minimal] upload [60] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/40d.svg icons/40d.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.688	debug	[DEBUG] [minimal] upload [70] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/43m.svg icons/43m.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.687	debug	[DEBUG] [minimal] upload [80] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/48.svg icons/48.svg image/svg+xml
    backitup.1	2019-02-10 22:21:08.687	debug	[DEBUG] [minimal] got /opt/iobroker/node_modules/iobroker.yr/admin
    backitup.1	2019-02-10 22:21:08.687	debug	[DEBUG] [minimal] host.orangepiplus2e Setup "iobroker.web" adapter
    backitup.1	2019-02-10 22:21:08.686	debug	[DEBUG] [minimal] upload [0] iobroker.web.admin /opt/iobroker/node_modules/iobroker.web/admin/index.html index.html text/html
    backitup.1	2019-02-10 22:21:08.686	debug	[DEBUG] [minimal] upload [1] iobroker.web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
    backitup.1	2019-02-10 22:21:08.686	debug	[DEBUG] [minimal] upload [2] iobroker.web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
    backitup.1	2019-02-10 22:21:08.685	debug	[DEBUG] [minimal] upload [3] iobroker.web.admin /opt/iobroker/node_modules/iobroker.web/admin/words.js words.js application/javascript
    backitup.1	2019-02-10 22:21:08.685	debug	[DEBUG] [minimal] got /opt/iobroker/node_modules/iobroker.web/admin
    backitup.1	2019-02-10 22:21:08.684	debug	[DEBUG] [minimal] upload [0] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
    backitup.1	2019-02-10 22:21:08.684	debug	[DEBUG] [minimal] upload [1] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
    backitup.1	2019-02-10 22:21:08.684	debug	[DEBUG] [minimal] upload [2] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
    backitup.1	2019-02-10 22:21:08.683	debug	[DEBUG] [minimal] upload [3] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.pdn lib/css/fancytree/channel.pdn application/octet-stream
    backitup.1	2019-02-10 22:21:08.683	debug	[DEBUG] [minimal] upload [4] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
    backitup.1	2019-02-10 22:21:08.682	debug	[DEBUG] [minimal] upload [5] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.pdn lib/css/fancytree/device.pdn application/octet-stream
    backitup.1	2019-02-10 22:21:08.682	debug	[DEBUG] [minimal] upload [6] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
    backitup.1	2019-02-10 22:21:08.682	debug	[DEBUG] [minimal] upload [7] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
    backitup.1	2019-02-10 22:21:08.681	debug	[DEBUG] [minimal] upload [8] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
    backitup.1	2019-02-10 22:21:08.681	debug	[DEBUG] [minimal] upload [9] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.pdn lib/css/fancytree/state.pdn application/octet-stream
    backitup.1	2019-02-10 22:21:08.681	debug	[DEBUG] [minimal] upload [10] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
    backitup.1	2019-02-10 22:21:08.680	debug	[DEBUG] [minimal] upload [11] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
    backitup.1	2019-02-10 22:21:08.680	debug	[DEBUG] [minimal] upload [12] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
    backitup.1	2019-02-10 22:21:08.679	debug	[DEBUG] [minimal] upload [13] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
    backitup.1	2019-02-10 22:21:08.679	debug	[DEBUG] [minimal] upload [14] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
    backitup.1	2019-02-10 22:21:08.679	debug	[DEBUG] [minimal] upload [15] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
    backitup.1	2019-02-10 22:21:08.678	debug	[DEBUG] [minimal] upload [16] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml text/xml
    backitup.1	2019-02-10 22:21:08.678	debug	[DEBUG] [minimal] upload [17] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
    backitup.1	2019-02-10 22:21:08.677	debug	[DEBUG] [minimal] upload [18] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
    backitup.1	2019-02-10 22:21:08.677	debug	[DEBUG] [minimal] upload [19] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
    backitup.1	2019-02-10 22:21:08.677	debug	[DEBUG] [minimal] upload [20] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/blac
    backitup.1	2019-02-10 22:21:08.676	debug	[DEBUG] [minimal] upload [30] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_4ca300_256x240.png lib/css/themes/jquery-ui/black-tie/images/
    backitup.1	2019-02-10 22:21:08.676	debug	[DEBUG] [minimal] upload [40] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_flat_0_333333_40x100.png lib/css/themes/jquery-ui/blitzer/images/u
    backitup.1	2019-02-10 22:21:08.676	debug	[DEBUG] [minimal] upload [50] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/jquery-ui.css lib/css/themes/jquery-ui/blitzer/jquery-ui.css text/css
    backitup.1	2019-02-10 22:21:08.675	debug	[DEBUG] [minimal] upload [60] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_highlight-soft_100_deedf7_1x100.png lib/css/themes/jquery-ui/cup
    backitup.1	2019-02-10 22:21:08.675	debug	[DEBUG] [minimal] upload [70] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_glass_20_555555_1x400.png lib/css/themes/jquery-ui/custom-dark
    backitup.1	2019-02-10 22:21:08.674	debug	[DEBUG] [minimal] upload [80] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/jquery-ui.min.css lib/css/themes/jquery-ui/custom-dark/jquery-ui.min.css te
    backitup.1	2019-02-10 22:21:08.674	debug	[DEBUG] [minimal] upload [90] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/custom-light/i
    backitup.1	2019-02-10 22:21:08.674	debug	[DEBUG] [minimal] upload [100] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-hard_20_0972a5_1x100.png lib/css/themes/jquery-ui/dar
    backitup.1	2019-02-10 22:21:08.673	debug	[DEBUG] [minimal] upload [150] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_734d99_256x240.png lib/css/themes/jquery-ui/eggplant/images/u
    backitup.1	2019-02-10 22:21:08.673	debug	[DEBUG] [minimal] upload [200] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_88a206_256x240.png lib/css/themes/jquery-ui/hot-sneaks/imag
    backitup.1	2019-02-10 22:21:08.672	debug	[DEBUG] [minimal] upload [250] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_inset-hard_100_fcfdfd_1x100.png lib/css/themes/jquery-ui/redmond/
    backitup.1	2019-02-10 22:21:08.672	debug	[DEBUG] [minimal] upload [300] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_gloss-wave_60_fece2f_500x100.png lib/css/themes/jquery-ui/sunny/ima
    backitup.1	2019-02-10 22:21:08.672	debug	[DEBUG] [minimal] upload [350] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_glass_95_fef1ec_1x400.png lib/css/themes/jquery-ui/vader/images/ui-
    backitup.1	2019-02-10 22:21:08.671	debug	[DEBUG] [minimal] got /opt/iobroker/node_modules/iobroker.web/www
    backitup.1	2019-02-10 22:21:08.671	debug	[DEBUG] [minimal] upload [0] iobroker.vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/index.html index.html text/html
    backitup.1	2019-02-10 22:21:08.670	debug	[DEBUG] [minimal] upload [1] iobroker.vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/index_m.html index_m.html text/html
    backitup.1	2019-02-10 22:21:08.670	debug	[DEBUG] [minimal] upload [2] iobroker.vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/vis-weather.png vis-weather.png image/png
    backitup.1	2019-02-10 22:21:08.670	debug	[DEBUG] [minimal] upload [3] iobroker.vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/words.js words.js application/javascript
    backitup.1	2019-02-10 22:21:08.669	debug	[DEBUG] [minimal] got /opt/iobroker/node_modules/iobroker.vis-weather/admin
    backitup.1	2019-02-10 22:21:08.669	debug	[DEBUG] [minimal] upload [0] iobroker.vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
    backitup.1	2019-02-10 22:21:08.669	debug	[DEBUG] [minimal] upload [1] iobroker.vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
    backitup.1	2019-02-10 22:21:08.668	debug	[DEBUG] [minimal] upload [2] iobroker.vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
    backitup.1	2019-02-10 22:21:08.668	debug	[DEBUG] [minimal] upload [3] iobroker.vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
    backitup.1	2019-02-10 22:21:08.667	debug	[DEBUG] [minimal] got /opt/iobroker/node_modules/iobroker.vis/admin
    backitup.1	2019-02-10 22:21:08.667	debug	[DEBUG] [minimal] upload [0] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
    backitup.1	2019-02-10 22:21:08.667	debug	[DEBUG] [minimal] upload [1] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
    backitup.1	2019-02-10 22:21:08.666	debug	[DEBUG] [minimal] upload [2] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
    backitup.1	2019-02-10 22:21:08.666	debug	[DEBUG] [minimal] upload [3] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
    backitup.1	2019-02-10 22:21:08.666	debug	[DEBUG] [minimal] upload [4] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
    backitup.1	2019-02-10 22:21:08.665	debug	[DEBUG] [minimal] upload [5] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
    backitup.1	2019-02-10 22:21:08.665	debug	[DEBUG] [minimal] upload [6] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff application/font-woff
    backitup.1	2019-02-10 22:21:08.664	debug	[DEBUG] [minimal] upload [7] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
    backitup.1	2019-02-10 22:21:08.664	debug	[DEBUG] [minimal] upload [8] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
    backitup.1	2019-02-10 22:21:08.664	debug	[DEBUG] [minimal] upload [9] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
    backitup.1	2019-02-10 22:21:08.663	debug	[DEBUG] [minimal] upload [10] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
    backitup.1	2019-02-10 22:21:08.663	debug	[DEBUG] [minimal] upload [11] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/edit.src.html edit.src.html text/html
    backitup.1	2019-02-10 22:21:08.662	debug	[DEBUG] [minimal] upload [12] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
    backitup.1	2019-02-10 22:21:08.662	debug	[DEBUG] [minimal] upload [13] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
    backitup.1	2019-02-10 22:21:08.662	debug	[DEBUG] [minimal] upload [14] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
    backitup.1	2019-02-10 22:21:08.661	debug	[DEBUG] [minimal] upload [15] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
    backitup.1	2019-02-10 22:21:08.661	debug	[DEBUG] [minimal] upload [16] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
    backitup.1	2019-02-10 22:21:08.661	debug	[DEBUG] [minimal] upload [17] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
    backitup.1	2019-02-10 22:21:08.660	debug	[DEBUG] [minimal] upload [18] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
    backitup.1	2019-02-10 22:21:08.660	debug	[DEBUG] [minimal] upload [19] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
    backitup.1	2019-02-10 22:21:08.660	debug	[DEBUG] [minimal] upload [20] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
    backitup.1	2019-02-10 22:21:08.659	debug	[DEBUG] [minimal] upload [30] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
    backitup.1	2019-02-10 22:21:08.659	debug	[DEBUG] [minimal] upload [40] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
    backitup.1	2019-02-10 22:21:08.658	debug	[DEBUG] [minimal] upload [50] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/timestamp.png icon/timestamp.png image/png
    backitup.1	2019-02-10 22:21:08.658	debug	[DEBUG] [minimal] upload [60] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/img/back/oblique-line-bk.png img/back/oblique-line-bk.png image/png
    backitup.1	2019-02-10 22:21:08.658	debug	[DEBUG] [minimal] upload [70] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulbOn.png img/bulbOn.png image/png
    backitup.1	2019-02-10 22:21:08.657	debug	[DEBUG] [minimal] upload [80] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
    backitup.1	2019-02-10 22:21:08.657	debug	[DEBUG] [minimal] upload [90] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/index.html index.html text/html
    backitup.1	2019-02-10 22:21:08.657	debug	[DEBUG] [minimal] upload [100] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/delete.png js/fm/icon/actions/delete.png image/png
    backitup.1	2019-02-10 22:21:08.656	debug	[DEBUG] [minimal] upload [150] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditInspect.js js/visEditInspect.js application/javascript
    backitup.1	2019-02-10 22:21:08.656	debug	[DEBUG] [minimal] upload [200] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery.ba-resize.min.js lib/js/jquery.ba-resize.min.js application/javascript
    backitup.1	2019-02-10 22:21:08.656	error	[ERROR] [minimal] (node:25472) [DEP0013] DeprecationWarning: Calling an asynchronous function without callback is deprecated.
    backitup.1	2019-02-10 22:21:08.655	error	[ERROR] [minimal] (node:25472) [DEP0013] DeprecationWarning: Calling an asynchronous function without callback is deprecated.
    simatecS Online
    simatecS Online
    simatec
    #1766
    @tripper
    Wie @apollon77 schon geschrieben hatte, ist da irgendwas an deinem System nicht in Ordnung ubd du nimmst den Fehler immer wieder mit, wenn du einen Restore machst.
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • simatecS Online
      simatecS Online
      simatec
      #1767
      Hier mal eine Zusammenfassung, was im stable Release 1.1.0 alles neu ist:
      Stable Release 1.1.0
      • Unterstützung für Wake on LAN
      • History überarbeitet
      • Backup-Fehlermeldungen in der History
      • Backup-Fehlermeldungen für Telegram hinzugefügt
      • Backup-Fehlermeldungen für Pushover hinzugefügt
      • Backup-Fehlermeldungen für E-Mail hinzugefügt
      • Auswahl für Benachrichtigungen nur bei Backup-Fehlern hinzugefügt
      • Überarbeitung des Start/Stop Handlings bei Backup und Restore
      • Anpassung an den neuen iobroker-Installer
      • Überarbeitung für mount und umount Abfrage
      Viel Spaß mit der neuen Version.
      • simatecS Online
        simatecS Online
        simatec
        #1768
        Da sich leider ein kleiner Bug in das Release eingeschlichen hat, hier ein kleines Update auf Version 1.1.1.
        Diese ist ab sofort im Github und ab heute Nacht in der stable und latest Repo zu finden.
        Changelog
        1.1.1 (12.02.2019)
        • (simatec) Fix iobroker-stop for total backup
        Stable Release 1.1.1
        • RöstkartoffelR Offline
          Röstkartoffel
          schrieb am zuletzt editiert von Röstkartoffel
          #1769
          Ich habe noch ein Problem bei der Redis Sicherung während des Minimal Backups mit "Error: EACCES: permission denied, scandir '/var/lib/redis'".
          Das minimale Backup wird einwandfrei ausgeführt.
          ioBroker frisch aufgesetzt mit allerneuesten Installer.
          Redis eingerichtet und läuft, Backitup V1.1.1, NPM 6.4.1, Node.js v8.15.0, lokale Sicherung
          Egal wie ich das Backup starte (mit DP auf "true" setzten oder automatisch), kommt immer diese Fehlermeldung im Log:
          backitup.0	2019-02-15 11:01:22.481	debug	system.adapter.admin.0: logging false
          backitup.0	2019-02-15 11:01:22.479	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1550224882470,"q":0,"from":"system.adapter.admin.0","lc":1550224882470}
          backitup.0	2019-02-15 11:00:55.915	debug	system.adapter.admin.0: logging true
          backitup.0	2019-02-15 11:00:55.912	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1550224855909,"q":0,"from":"system.adapter.admin.0","lc":1550224855909}
          backitup.0	2019-02-15 10:57:00.351	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1550224620346,"q":0,"from":"system.adapter.backitup.0","lc":1550224620346}
          backitup.0	2019-02-15 10:57:00.339	debug	[minimal] exec: done
          backitup.0	2019-02-15 10:57:00.328	debug	[minimal/history] done
          backitup.0	2019-02-15 10:57:00.256	debug	[minimal/clean] done
          backitup.0	2019-02-15 10:57:00.253	debug	[minimal/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
          backitup.0	2019-02-15 10:57:00.235	debug	[minimal/redis] [IGNORED] Error: EACCES: permission denied, scandir '/var/lib/redis'
          backitup.0	2019-02-15 10:57:00.162	debug	[minimal/minimal] done
          backitup.0	2019-02-15 10:57:00.103	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_02_15-10_56_47_BananaPiPro_backupiobroker.tar.gz
          backitup.0	2019-02-15 10:56:45.796	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":true,"ack":false,"ts":1550224605789,"q":0,"from":"system.adapter.admin.0","lc":1550224605789}
          backitup.0	2019-02-15 10:56:45.213	debug	system.adapter.admin.0: logging false
          backitup.0	2019-02-15 10:56:45.211	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1550224605204,"q":0,"from":"system.adapter.admin.0","lc":1550224605204}
          backitup.0	2019-02-15 10:56:27.491	debug	system.adapter.admin.0: logging true
          backitup.0	2019-02-15 10:56:27.484	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1550224587476,"q":0,"from":"system.adapter.admin.0","lc":1550224587476}
          backitup.0	2019-02-15 10:56:14.757	debug	[total] 10 00 06 */3 * *
          backitup.0	2019-02-15 10:56:14.744	info	[total] backup was activated at 06:00 every 3 day(s)
          backitup.0	2019-02-15 10:56:14.743	debug	[minimal] 10 00 05 */1 * *
          backitup.0	2019-02-15 10:56:14.659	info	[minimal] backup was activated at 05:00 every 1 day(s)
          backitup.0	2019-02-15 10:56:14.590	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.0
          backitup.0	2019-02-15 10:56:14.237	info	States connected to redis: 127.0.0.1:6379
          backitup.0	2019-02-15 10:56:14.219	debug	statesDB connected
          backitup.0	2019-02-15 10:56:14.108	debug	objectDB connected
          Berechtigung Dateien/Ordner:
          Was kann ich tun?
          NUC7i3BNH mit Proxmox und ioBroker (VM Debian Buster), Raspi3 (Slave Smartmeter für eHZ easymeter), Hardware CCU2, SMA SB5000TL-21
          • RöstkartoffelR Röstkartoffel
            Was kann ich tun?
            simatecS Online
            simatecS Online
            simatec
            #1770
            @Röstkartoffel
            Das ist leider wieder ein Rechteproblem des Users iobroker.
            Ich schaue mal, ob wir das mit backitup irgendwie umgehen können.
            Der User iobroker, der mit dem Installer angelegt wird, hat nur sehr beschränkte Rechte.
            In dem Fall hat er keine Rechte, den Pfad von Redis zu lesen.
            Ich kümmere mich darum.
            • AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              #1771
              In dem Fall dürfte es reichen, den User zur redis-Gruppe hinzuzufügen
              sudo usermod -a -G redis iobroker
              simatecS P 3 Antworten Letzte Antwort
              • AlCalzoneA AlCalzone
                simatecS Online
                simatecS Online
                simatec
                #1772
                @AlCalzone
                Vielleicht können wir das nach erfolgreichen Testen noch mit in den Installer aufnehmen.
                • simatecS simatec
                  @AlCalzone
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  #1773
                  @simatec Gerne!
                    simatecS Online
                    simatecS Online
                    simatec
                    #1774
                    @AlCalzone sagte in Adapter: iobroker.backitup (stable Release):
                    @Röstkartoffel
                    Kannst du das mal bitte testen und hier berichten.
                      Röstkartoffel
                      #1775
                      reboot
                      oneclick Backup gestartet und voila, keine Fehlermeldung, RedisBackup vorhanden:
                      Danke.
                        AlCalzoneA Offline
                        AlCalzone
                        #1776
                        Prima :)
                        https://github.com/ioBroker/ioBroker/pull/125
                        • SegwayS Offline
                          SegwayS Offline
                          Segway
                          #1777
                          Ich habe irgendwann dann das Problem, dass nach dem backup anscheinend nicht sauber geschlossen wird und beim nächsten backup DRIVE IS BUSY kommt. Leider kommt auch keine Meldung, dass das angedachte (cron) backup nicht erstellt werden konnte.
                          Ich merke es erst wenn ich mal nachschaue was auf meinen NAS abgelegt wurde.
                          Kann man da nicht eine Meldung reinbringen ?
                          Per Putty mach ich ein einfaches UMOUNT und danach geht wieder alles. Das könnte man auch einbringen oder ?
                          Gruß Dirk
                          • SegwayS Segway
                            simatecS Online
                            simatecS Online
                            simatec
                            #1778
                            @Segway
                            Das dürfte ab Version 1.0.9 nicht mehr vorkommen.
                            Wenn kein umount gemacht werden kann, da noch Daten geschrieben werden, wird jetzt 10 Minuten gewartet und dann der umount erneut durchgeführt.
                            SegwayS 1 Antwort Letzte Antwort
                            • simatecS simatec
                              @Segway
                              SegwayS Offline
                              SegwayS Offline
                              Segway
                              schrieb am zuletzt editiert von Segway
                              #1779
                              @simatec sagte in Adapter: iobroker.backitup (stable Release):
                              Okay, ich habe die 1.0.8 laufen. Dann date ich mal auf 1.1.1 ab.
                              Schuss in Ofen ... der startet erst gar nicht :-(
                              backitup.0	2019-02-15 17:42:29.067	info	terminating
                              backitup.0	2019-02-15 17:42:28.561	error	at tryOnImmediate (timers.js:768:5)
                              backitup.0	2019-02-15 17:42:28.561	error	at runCallback (timers.js:814:20)
                              backitup.0	2019-02-15 17:42:28.561	error	at Immediate.createInstancesObjects [as _onImmediate] (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:748:13)
                              backitup.0	2019-02-15 17:42:28.561	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:788:29
                              backitup.0	2019-02-15 17:42:28.561	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4990:18)
                              backitup.0	2019-02-15 17:42:28.561	error	at Adapter.emit (events.js:208:7)
                              backitup.0	2019-02-15 17:42:28.561	error	at emitNone (events.js:106:13)
                              backitup.0	2019-02-15 17:42:28.561	error	at Adapter.main (/opt/iobroker/node_modules/iobroker.backitup/main.js:615:5)
                              backitup.0	2019-02-15 17:42:28.561	error	at createBackupDir (/opt/iobroker/node_modules/iobroker.backitup/main.js:600:12)
                              backitup.0	2019-02-15 17:42:28.561	error	at Object.fs.mkdirSync (fs.js:885:18)
                              backitup.0	2019-02-15 17:42:28.561	error	Error: EEXIST: file already exists, mkdir '/opt/iobroker/backups'
                              backitup.0	2019-02-15 17:42:28.561	error	uncaught exception: EEXIST: file already exists, mkdir '/opt/iobroker/backups'
                              backitup.0	2019-02-15 17:42:28.544	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.0
                              backitup.0	2019-02-15 17:42:28.350	info	States connected to redis: 127.0.0.1:6379
                              Gruß Dirk
                              • simatecS Online
                                simatecS Online
                                simatec
                                #1780
                                @Segway sagte in Adapter: iobroker.backitup (stable Release):
                                600
                                Starte einfach mal neu ... da ist irgendwas beim Update schief gelaufen.
                                Ggfs mal ein upload machen
                                • simatecS simatec
                                  600
                                  SegwayS Offline
                                  SegwayS Offline
                                  Segway
                                  #1781
                                  600
                                  nur den Adapter neu starten ? Habe ich gemacht. Wird nicht grün
                                  Gruß Dirk
                                  • SegwayS Segway
                                    600
                                    simatecS Online
                                    simatecS Online
                                    simatec
                                    #1782
                                    @Segway
                                    Mach mal ein Upload ...
                                    Es wird probiert den backup Ordner anzulegen.
                                    Das kann nicht sein, denn das macht er nur, wenn er nicht exitiert.
                                    Aber das ist schon seit Version 0.3.0 so ...
                                    Also kann es nur an deinem Update liegen.
                                    • simatecS simatec
                                      @Segway
                                      SegwayS Offline
                                      SegwayS Offline
                                      Segway
                                      #1783
                                      @simatec
                                      Nö, weiterhin gleiches Problem :-(
                                      Gruß Dirk
                                      • SegwayS Offline
                                        SegwayS Offline
                                        Segway
                                        #1784
                                        auch beim Downgrade gleiches Bild. Hier mal was da alles kam beim install
                                        Update backitup from @1.1.1 to @1.0.9
                                        NPM version: 6.4.1
                                        npm install iobroker.backitup@1.0.9 --production --save --prefix "/opt/iobroker" (System call)
                                        gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.15.0"
                                        gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/epoll/.node-gyp"
                                        gyp WARN install got an error, rolling back install
                                        gyp ERR! configure error
                                        gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/epoll/.node-gyp'
                                        gyp ERR! System Linux 4.9.0-8-amd64
                                        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                        gyp ERR! cwd /opt/iobroker/node_modules/epoll
                                        gyp ERR! node -v v8.15.0
                                        gyp ERR! node-gyp -v v3.8.0
                                        gyp ERR! not ok
                                        gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/unix-dgram/.node-gyp"
                                        gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/unix-dgram/.node-gyp'
                                        gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
                                        gyp ERR! not ok
                                        node-pre-gyp WARN Using request for node-pre-gyp https download
                                        node-pre-gyp WARN Tried to download(404): https://github.com/tessel/node-usb/releases/download/1.5.0/usb_bindings-v1.5.0-node-v57-linux-x64.tar.gz
                                        node-pre-gyp WARN Pre-built binaries not found for usb@1.5.0 and node@8.15.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
                                        gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/usb/.node-gyp"
                                        gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/usb/.node-gyp'
                                        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/opt/iobroker/node_modules/usb/src/binding" "--napi_version=3" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"
                                        gyp ERR! cwd /opt/iobroker/node_modules/usb
                                        gyp ERR! not ok
                                        node-pre-gyp ERR! build error
                                        node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
                                        node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/usb/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                        node-pre-gyp ERR! stack at emitTwo (events.js:126:13)
                                        node-pre-gyp ERR! stack at ChildProcess.emit (events.js:214:7)
                                        node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:915:16)
                                        node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
                                        node-pre-gyp ERR! System Linux 4.9.0-8-amd64
                                        node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/usb/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                        node-pre-gyp ERR! cwd /opt/iobroker/node_modules/usb
                                        node-pre-gyp ERR! node -v v8.15.0
                                        node-pre-gyp ERR! node-pre-gyp -v v0.11.0
                                        node-pre-gyp ERR! not ok
                                        gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/bluetooth-hci-socket/.node-gyp"
                                        gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/bluetooth-hci-socket/.node-gyp'
                                        gyp ERR! cwd /opt/iobroker/node_modules/bluetooth-hci-socket
                                        gyp ERR! not ok
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
                                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: epoll@0.1.22 (node_modules/epoll):
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: epoll@0.1.22 install: node-gyp rebuild
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: node-gyp rebuild
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.5.0 (node_modules/usb):
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.5.0 install: node-pre-gyp install --fallback-to-build
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 (node_modules/bluetooth-hci-socket):
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 install: node-gyp rebuild
                                        npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.backitup"
                                        npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
                                        npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
                                        npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                                        npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                                        npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
                                        npm notice created a lockfile as package-lock.json. You should commit this file.
                                        got /opt/iobroker/node_modules/iobroker.backitup/admin
                                        upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                        Update "system.adapter.backitup.0"
                                        upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                        upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                        upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                        Adapter "backitup" updated
                                        Gruß Dirk
                                        • simatecS Online
                                          simatecS Online
                                          simatec
                                          #1785
                                          Dein Problem liegt definitiv nicht an backitup.
                                          Hast du js-controller 1.5.7 laufen?
                                          Dein System hat ein Problem.
