  4. Adapter: iobroker.backitup (stable Release)
adapterbackitupiobroker backupbackupiobroker.backitup
2.3k Beiträge 185 Kommentatoren 1.6m Aufrufe 50 Beobachtet
  • tripperT Offline
    tripperT Offline
    tripper
    #1760
    ` > >! @tripper:
    ! > Bei mir funktioniert das Standard Backup nicht. Komplett Backup läuft soweit ich das sehe ohne Probleme
    Gestartet...
    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"****"}
    [DEBUG] [mount] - done
    [DEBUG] [minimal] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"test","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"****","context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"iobroker"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [ERROR] [minimal] - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:193
                                result.objects[j].value.common.host === hostname) {
    TypeError: Cannot read property 'host' of undefined
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:193:60
        at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
        at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
        at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
        at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
        at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
        at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
        at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
        at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
        at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
    [DEBUG] [minimal] - done
    [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
    [DEBUG] [cifs] - done
    [DEBUG] [clean] start with {"deleteBackupAfter":0}
    [DEBUG] [clean] - done
    [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"test","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_01_27-23_09_34_test_backupiobroker.tar.gz"],"errors":{},"done":["mount","minimal"],"types":["minimal"]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"iobroker"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"27\. Januar 2019 um 23:09 Uhr"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [history] - backitup.1.history.html
    [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"****","backupDir":"/opt/iobroker/backups"}
    [DEBUG] [umount] - wait 60 seconds for umount!
    [DEBUG] [umount] - done
    [EXIT] 1</anonymous></anonymous></anonymous>
    Leider verstehe ich nicht viel davon was mir hier gemeldet wird. Wenn ich in "/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/" nachschaue liegen da Dateien mit Datum um 1985 :) !
    Hab ich mir da evtl. mit der kürzlich per Komplett Backup (ja ich weiss das sollte man nicht, minimal ging aber auch dort schon nicht) wiederhergestellten iobroker Installation irgendwas eingeschleppt? Dort hatte ich auch öfters irgendwelche seltsamen Zeitstempel
    Da meine Frage hier wohl untergegangen ist habe ich mich nochmal durchs Forum gewühlt und bin in einem Beitrag zum manuellen Backup fündig geworden:
    viewtopic.php?t=13900#p147282
    Der quick Hack hat funktioniert, verstanden habe ich das Problem respektive die Lösung aber nicht. Werde morgen mal den ioBroker neu installieren und die Daten diesmal per minimal-backup wiederherstellen. Vielleicht behebt das ja das seltsame Verhalten und ich kann wieder ruhig schlafen ;)
    • simatecS Online
      simatecS Online
      simatec
      #1761
      Wie @Appolon77 geschrieben hat, scheint bei dir etwas nicht richtig zu laufen.
      Von daher nutze für den restore nach dem neu aufsetzen definitiv ein minimal backup.
      Mit einem total holst du dir den Fehler mit großer Wahrscheinlichkeit wieder rein.
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • tripperT Offline
        tripperT Offline
        tripper
        #1762
        Hab gestern ioBroker komplett gelöscht und nach offizieller Anleitung neu installiert. Danach minimal-restore per Shell (per Adapter ging nicht) und dann "update all"
        Wenn ich nun das Standard Backup per Adapter auslöse kommt immer noch die gleiche Meldung wie vorher:
        Dann wohl wieder mit dem "Hack". Aber eine saubere Lösung scheint mir das nicht zu sein.
        Evtl. übersehe ich einfach etwas was nicht korrekt ist an meiner Installation, bin froh um Jeden Hinweis.
        PS: SEHR SCHICK DAS NEUE FORUM !!! Ich bin überwältigt von den neuen Funktionen! Tolle Arbeit die hier wieder einmal gemacht wurde👍
        • tripperT tripper
          simatecS Online
          simatecS Online
          simatec
          #1763
          @tripper
          Dann ist grundsätzlich etwas an deiner Installation nicht in Ordnung und wird leider auch beim Restore wieder mit übernommen.
          Was funktioniert bei dir am Restore über den Adapter nicht?
          Bitte poste hier mal den Log.
          tripperT 1 Antwort Letzte Antwort
          • simatecS Online
            simatecS Online
            simatec
            #1764
            Ab sofort ist das stable Release 1.1.0 im Github Online und ab heute Nacht auch in der latest und stable Repo.
            Changelog
            1.1.0 (10.02.2019)
            • (simatec) stable Release
            • simatecS simatec
              @tripper
              tripperT Offline
              tripperT Offline
              tripper
              schrieb am zuletzt editiert von tripper
              #1765
              @simatec
              Hier mal den Log vom Adapter nach der Wiederherstellung.
              Das ist so aber nicht ganz real reproduziert. Wollte den ioBroker nicht noch einmal komplett löschen, deshalb hier einfach mal ein Restore über die laufende Installation.
              Den ioBroker musste ich per Shell starten, der kam nicht mehr selbst hoch
              backitup.1	2019-02-10 22:21:45.450	info	terminating
              backitup.1	2019-02-10 22:21:45.126	debug	system.adapter.admin.0: logging false
              backitup.1	2019-02-10 22:21:44.940	error	at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
              backitup.1	2019-02-10 22:21:44.940	error	at maybeClose (internal/child_process.js:915:16)
              backitup.1	2019-02-10 22:21:44.940	error	at ChildProcess.emit (events.js:214:7)
              backitup.1	2019-02-10 22:21:44.940	error	at emitTwo (events.js:126:13)
              backitup.1	2019-02-10 22:21:44.940	error	at ChildProcess.exithandler (child_process.js:273:7)
              backitup.1	2019-02-10 22:21:44.940	error	at child_process.exec (/opt/iobroker/node_modules/iobroker.backitup/lib/restore.js:71:13)
              backitup.1	2019-02-10 22:21:44.940	error	ReferenceError: log is not defined
              backitup.1	2019-02-10 22:21:44.939	error	uncaught exception: log is not defined
              backitup.1	2019-02-10 22:21:44.886	debug	sendTo "restore" to system.adapter.admin.0 from system.adapter.backitup.1
              backitup.1	2019-02-10 22:21:38.037	debug	sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.1
              backitup.1	2019-02-10 22:21:19.385	debug	mount activ... umount in 10 Seconds!!
              backitup.1	2019-02-10 22:21:19.369	debug	[total] 10 30 04 */5 * *
              backitup.1	2019-02-10 22:21:19.357	info	[total] backup was activated at 04:30 every 5 day(s)
              backitup.1	2019-02-10 22:21:19.356	debug	[minimal] 10 00 04 */1 * *
              backitup.1	2019-02-10 22:21:19.310	info	[minimal] backup was activated at 04:00 every 1 day(s)
              backitup.1	2019-02-10 22:21:19.230	info	starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.0
              backitup.1	2019-02-10 22:21:19.036	debug	statesDB connected
              backitup.1	2019-02-10 22:21:18.932	debug	objectDB connected
              backitup.1	2019-02-10 22:21:09.181	debug	mount activ... umount in 10 Seconds!!
              backitup.1	2019-02-10 22:21:09.159	debug	[total] 10 30 04 */5 * *
              backitup.1	2019-02-10 22:21:09.138	info	[total] backup was activated at 04:30 every 5 day(s)
              backitup.1	2019-02-10 22:21:09.137	debug	[minimal] 10 00 04 */1 * *
              backitup.1	2019-02-10 22:21:09.060	info	[minimal] backup was activated at 04:00 every 1 day(s)
              backitup.1	2019-02-10 22:21:08.743	warn	Cannot read log file: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/lib/total.json'
              backitup.1	2019-02-10 22:21:08.698	debug	[EXIT] 0
              backitup.1	2019-02-10 22:21:08.698	debug	[DEBUG] [minimal] System successfully restored!
              backitup.1	2019-02-10 22:21:08.697	debug	[DEBUG] [minimal] upload [0] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/01d.svg icons/01d.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.697	debug	[DEBUG] [minimal] upload [1] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/01m.svg icons/01m.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.696	debug	[DEBUG] [minimal] upload [2] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/01n.svg icons/01n.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.696	debug	[DEBUG] [minimal] upload [3] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/02d.svg icons/02d.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.696	debug	[DEBUG] [minimal] upload [4] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/02m.svg icons/02m.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.695	debug	[DEBUG] [minimal] upload [5] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/02n.svg icons/02n.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.695	debug	[DEBUG] [minimal] upload [6] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/03d.svg icons/03d.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.695	debug	[DEBUG] [minimal] upload [7] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/03m.svg icons/03m.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.694	debug	[DEBUG] [minimal] upload [8] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/03n.svg icons/03n.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.694	debug	[DEBUG] [minimal] upload [9] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/04.svg icons/04.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.693	debug	[DEBUG] [minimal] upload [10] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/05d.svg icons/05d.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.693	debug	[DEBUG] [minimal] upload [11] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/05m.svg icons/05m.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.693	debug	[DEBUG] [minimal] upload [12] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/05n.svg icons/05n.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.692	debug	[DEBUG] [minimal] upload [13] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/06d.svg icons/06d.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.692	debug	[DEBUG] [minimal] upload [14] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/06m.svg icons/06m.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.692	debug	[DEBUG] [minimal] upload [15] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/06n.svg icons/06n.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.691	debug	[DEBUG] [minimal] upload [16] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/07d.svg icons/07d.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.691	debug	[DEBUG] [minimal] upload [17] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/07m.svg icons/07m.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.690	debug	[DEBUG] [minimal] upload [18] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/07n.svg icons/07n.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.690	debug	[DEBUG] [minimal] upload [19] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/08d.svg icons/08d.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.690	debug	[DEBUG] [minimal] upload [20] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/08m.svg icons/08m.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.689	debug	[DEBUG] [minimal] upload [30] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/20m.svg icons/20m.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.689	debug	[DEBUG] [minimal] upload [40] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/25d.svg icons/25d.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.689	debug	[DEBUG] [minimal] upload [50] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/28m.svg icons/28m.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.688	debug	[DEBUG] [minimal] upload [60] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/40d.svg icons/40d.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.688	debug	[DEBUG] [minimal] upload [70] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/43m.svg icons/43m.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.687	debug	[DEBUG] [minimal] upload [80] iobroker.yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/48.svg icons/48.svg image/svg+xml
              backitup.1	2019-02-10 22:21:08.687	debug	[DEBUG] [minimal] got /opt/iobroker/node_modules/iobroker.yr/admin
              backitup.1	2019-02-10 22:21:08.687	debug	[DEBUG] [minimal] host.orangepiplus2e Setup "iobroker.web" adapter
              backitup.1	2019-02-10 22:21:08.686	debug	[DEBUG] [minimal] upload [0] iobroker.web.admin /opt/iobroker/node_modules/iobroker.web/admin/index.html index.html text/html
              backitup.1	2019-02-10 22:21:08.686	debug	[DEBUG] [minimal] upload [1] iobroker.web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
              backitup.1	2019-02-10 22:21:08.686	debug	[DEBUG] [minimal] upload [2] iobroker.web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
              backitup.1	2019-02-10 22:21:08.685	debug	[DEBUG] [minimal] upload [3] iobroker.web.admin /opt/iobroker/node_modules/iobroker.web/admin/words.js words.js application/javascript
              backitup.1	2019-02-10 22:21:08.685	debug	[DEBUG] [minimal] got /opt/iobroker/node_modules/iobroker.web/admin
              backitup.1	2019-02-10 22:21:08.684	debug	[DEBUG] [minimal] upload [0] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
              backitup.1	2019-02-10 22:21:08.684	debug	[DEBUG] [minimal] upload [1] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
              backitup.1	2019-02-10 22:21:08.684	debug	[DEBUG] [minimal] upload [2] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
              backitup.1	2019-02-10 22:21:08.683	debug	[DEBUG] [minimal] upload [3] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.pdn lib/css/fancytree/channel.pdn application/octet-stream
              backitup.1	2019-02-10 22:21:08.683	debug	[DEBUG] [minimal] upload [4] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
              backitup.1	2019-02-10 22:21:08.682	debug	[DEBUG] [minimal] upload [5] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.pdn lib/css/fancytree/device.pdn application/octet-stream
              backitup.1	2019-02-10 22:21:08.682	debug	[DEBUG] [minimal] upload [6] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
              backitup.1	2019-02-10 22:21:08.682	debug	[DEBUG] [minimal] upload [7] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
              backitup.1	2019-02-10 22:21:08.681	debug	[DEBUG] [minimal] upload [8] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
              backitup.1	2019-02-10 22:21:08.681	debug	[DEBUG] [minimal] upload [9] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.pdn lib/css/fancytree/state.pdn application/octet-stream
              backitup.1	2019-02-10 22:21:08.681	debug	[DEBUG] [minimal] upload [10] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
              backitup.1	2019-02-10 22:21:08.680	debug	[DEBUG] [minimal] upload [11] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
              backitup.1	2019-02-10 22:21:08.680	debug	[DEBUG] [minimal] upload [12] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
              backitup.1	2019-02-10 22:21:08.679	debug	[DEBUG] [minimal] upload [13] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
              backitup.1	2019-02-10 22:21:08.679	debug	[DEBUG] [minimal] upload [14] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
              backitup.1	2019-02-10 22:21:08.679	debug	[DEBUG] [minimal] upload [15] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
              backitup.1	2019-02-10 22:21:08.678	debug	[DEBUG] [minimal] upload [16] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml text/xml
              backitup.1	2019-02-10 22:21:08.678	debug	[DEBUG] [minimal] upload [17] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
              backitup.1	2019-02-10 22:21:08.677	debug	[DEBUG] [minimal] upload [18] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
              backitup.1	2019-02-10 22:21:08.677	debug	[DEBUG] [minimal] upload [19] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
              backitup.1	2019-02-10 22:21:08.677	debug	[DEBUG] [minimal] upload [20] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/blac
              backitup.1	2019-02-10 22:21:08.676	debug	[DEBUG] [minimal] upload [30] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_4ca300_256x240.png lib/css/themes/jquery-ui/black-tie/images/
              backitup.1	2019-02-10 22:21:08.676	debug	[DEBUG] [minimal] upload [40] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_flat_0_333333_40x100.png lib/css/themes/jquery-ui/blitzer/images/u
              backitup.1	2019-02-10 22:21:08.676	debug	[DEBUG] [minimal] upload [50] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/jquery-ui.css lib/css/themes/jquery-ui/blitzer/jquery-ui.css text/css
              backitup.1	2019-02-10 22:21:08.675	debug	[DEBUG] [minimal] upload [60] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_highlight-soft_100_deedf7_1x100.png lib/css/themes/jquery-ui/cup
              backitup.1	2019-02-10 22:21:08.675	debug	[DEBUG] [minimal] upload [70] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_glass_20_555555_1x400.png lib/css/themes/jquery-ui/custom-dark
              backitup.1	2019-02-10 22:21:08.674	debug	[DEBUG] [minimal] upload [80] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/jquery-ui.min.css lib/css/themes/jquery-ui/custom-dark/jquery-ui.min.css te
              backitup.1	2019-02-10 22:21:08.674	debug	[DEBUG] [minimal] upload [90] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/custom-light/i
              backitup.1	2019-02-10 22:21:08.674	debug	[DEBUG] [minimal] upload [100] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-hard_20_0972a5_1x100.png lib/css/themes/jquery-ui/dar
              backitup.1	2019-02-10 22:21:08.673	debug	[DEBUG] [minimal] upload [150] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_734d99_256x240.png lib/css/themes/jquery-ui/eggplant/images/u
              backitup.1	2019-02-10 22:21:08.673	debug	[DEBUG] [minimal] upload [200] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_88a206_256x240.png lib/css/themes/jquery-ui/hot-sneaks/imag
              backitup.1	2019-02-10 22:21:08.672	debug	[DEBUG] [minimal] upload [250] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_inset-hard_100_fcfdfd_1x100.png lib/css/themes/jquery-ui/redmond/
              backitup.1	2019-02-10 22:21:08.672	debug	[DEBUG] [minimal] upload [300] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_gloss-wave_60_fece2f_500x100.png lib/css/themes/jquery-ui/sunny/ima
              backitup.1	2019-02-10 22:21:08.672	debug	[DEBUG] [minimal] upload [350] iobroker.web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_glass_95_fef1ec_1x400.png lib/css/themes/jquery-ui/vader/images/ui-
              backitup.1	2019-02-10 22:21:08.671	debug	[DEBUG] [minimal] got /opt/iobroker/node_modules/iobroker.web/www
              backitup.1	2019-02-10 22:21:08.671	debug	[DEBUG] [minimal] upload [0] iobroker.vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/index.html index.html text/html
              backitup.1	2019-02-10 22:21:08.670	debug	[DEBUG] [minimal] upload [1] iobroker.vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/index_m.html index_m.html text/html
              backitup.1	2019-02-10 22:21:08.670	debug	[DEBUG] [minimal] upload [2] iobroker.vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/vis-weather.png vis-weather.png image/png
              backitup.1	2019-02-10 22:21:08.670	debug	[DEBUG] [minimal] upload [3] iobroker.vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/words.js words.js application/javascript
              backitup.1	2019-02-10 22:21:08.669	debug	[DEBUG] [minimal] got /opt/iobroker/node_modules/iobroker.vis-weather/admin
              backitup.1	2019-02-10 22:21:08.669	debug	[DEBUG] [minimal] upload [0] iobroker.vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
              backitup.1	2019-02-10 22:21:08.669	debug	[DEBUG] [minimal] upload [1] iobroker.vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
              backitup.1	2019-02-10 22:21:08.668	debug	[DEBUG] [minimal] upload [2] iobroker.vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
              backitup.1	2019-02-10 22:21:08.668	debug	[DEBUG] [minimal] upload [3] iobroker.vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
              backitup.1	2019-02-10 22:21:08.667	debug	[DEBUG] [minimal] got /opt/iobroker/node_modules/iobroker.vis/admin
              backitup.1	2019-02-10 22:21:08.667	debug	[DEBUG] [minimal] upload [0] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
              backitup.1	2019-02-10 22:21:08.667	debug	[DEBUG] [minimal] upload [1] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
              backitup.1	2019-02-10 22:21:08.666	debug	[DEBUG] [minimal] upload [2] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
              backitup.1	2019-02-10 22:21:08.666	debug	[DEBUG] [minimal] upload [3] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
              backitup.1	2019-02-10 22:21:08.666	debug	[DEBUG] [minimal] upload [4] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
              backitup.1	2019-02-10 22:21:08.665	debug	[DEBUG] [minimal] upload [5] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
              backitup.1	2019-02-10 22:21:08.665	debug	[DEBUG] [minimal] upload [6] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff application/font-woff
              backitup.1	2019-02-10 22:21:08.664	debug	[DEBUG] [minimal] upload [7] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
              backitup.1	2019-02-10 22:21:08.664	debug	[DEBUG] [minimal] upload [8] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
              backitup.1	2019-02-10 22:21:08.664	debug	[DEBUG] [minimal] upload [9] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
              backitup.1	2019-02-10 22:21:08.663	debug	[DEBUG] [minimal] upload [10] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
              backitup.1	2019-02-10 22:21:08.663	debug	[DEBUG] [minimal] upload [11] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/edit.src.html edit.src.html text/html
              backitup.1	2019-02-10 22:21:08.662	debug	[DEBUG] [minimal] upload [12] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
              backitup.1	2019-02-10 22:21:08.662	debug	[DEBUG] [minimal] upload [13] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
              backitup.1	2019-02-10 22:21:08.662	debug	[DEBUG] [minimal] upload [14] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
              backitup.1	2019-02-10 22:21:08.661	debug	[DEBUG] [minimal] upload [15] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
              backitup.1	2019-02-10 22:21:08.661	debug	[DEBUG] [minimal] upload [16] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
              backitup.1	2019-02-10 22:21:08.661	debug	[DEBUG] [minimal] upload [17] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
              backitup.1	2019-02-10 22:21:08.660	debug	[DEBUG] [minimal] upload [18] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
              backitup.1	2019-02-10 22:21:08.660	debug	[DEBUG] [minimal] upload [19] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
              backitup.1	2019-02-10 22:21:08.660	debug	[DEBUG] [minimal] upload [20] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
              backitup.1	2019-02-10 22:21:08.659	debug	[DEBUG] [minimal] upload [30] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
              backitup.1	2019-02-10 22:21:08.659	debug	[DEBUG] [minimal] upload [40] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
              backitup.1	2019-02-10 22:21:08.658	debug	[DEBUG] [minimal] upload [50] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/icon/timestamp.png icon/timestamp.png image/png
              backitup.1	2019-02-10 22:21:08.658	debug	[DEBUG] [minimal] upload [60] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/img/back/oblique-line-bk.png img/back/oblique-line-bk.png image/png
              backitup.1	2019-02-10 22:21:08.658	debug	[DEBUG] [minimal] upload [70] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulbOn.png img/bulbOn.png image/png
              backitup.1	2019-02-10 22:21:08.657	debug	[DEBUG] [minimal] upload [80] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
              backitup.1	2019-02-10 22:21:08.657	debug	[DEBUG] [minimal] upload [90] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/index.html index.html text/html
              backitup.1	2019-02-10 22:21:08.657	debug	[DEBUG] [minimal] upload [100] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/delete.png js/fm/icon/actions/delete.png image/png
              backitup.1	2019-02-10 22:21:08.656	debug	[DEBUG] [minimal] upload [150] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditInspect.js js/visEditInspect.js application/javascript
              backitup.1	2019-02-10 22:21:08.656	debug	[DEBUG] [minimal] upload [200] iobroker.vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery.ba-resize.min.js lib/js/jquery.ba-resize.min.js application/javascript
              backitup.1	2019-02-10 22:21:08.656	error	[ERROR] [minimal] (node:25472) [DEP0013] DeprecationWarning: Calling an asynchronous function without callback is deprecated.
              backitup.1	2019-02-10 22:21:08.655	error	[ERROR] [minimal] (node:25472) [DEP0013] DeprecationWarning: Calling an asynchronous function without callback is deprecated.
              • tripperT tripper
                @simatec
                simatecS Online
                simatecS Online
                simatec
                #1766
                @tripper
                Wie @apollon77 schon geschrieben hatte, ist da irgendwas an deinem System nicht in Ordnung ubd du nimmst den Fehler immer wieder mit, wenn du einen Restore machst.
                • simatecS Online
                  simatecS Online
                  simatec
                  #1767
                  Hier mal eine Zusammenfassung, was im stable Release 1.1.0 alles neu ist:
                  Stable Release 1.1.0
                  • Unterstützung für Wake on LAN
                  • History überarbeitet
                  • Backup-Fehlermeldungen in der History
                  • Backup-Fehlermeldungen für Telegram hinzugefügt
                  • Backup-Fehlermeldungen für Pushover hinzugefügt
                  • Backup-Fehlermeldungen für E-Mail hinzugefügt
                  • Auswahl für Benachrichtigungen nur bei Backup-Fehlern hinzugefügt
                  • Überarbeitung des Start/Stop Handlings bei Backup und Restore
                  • Anpassung an den neuen iobroker-Installer
                  • Überarbeitung für mount und umount Abfrage
                  Viel Spaß mit der neuen Version.
                  • simatecS Online
                    simatecS Online
                    simatec
                    #1768
                    Da sich leider ein kleiner Bug in das Release eingeschlichen hat, hier ein kleines Update auf Version 1.1.1.
                    Diese ist ab sofort im Github und ab heute Nacht in der stable und latest Repo zu finden.
                    Changelog
                    1.1.1 (12.02.2019)
                    • (simatec) Fix iobroker-stop for total backup
                    Stable Release 1.1.1
                    • RöstkartoffelR Offline
                      Röstkartoffel
                      schrieb am zuletzt editiert von Röstkartoffel
                      #1769
                      Ich habe noch ein Problem bei der Redis Sicherung während des Minimal Backups mit "Error: EACCES: permission denied, scandir '/var/lib/redis'".
                      Das minimale Backup wird einwandfrei ausgeführt.
                      ioBroker frisch aufgesetzt mit allerneuesten Installer.
                      Redis eingerichtet und läuft, Backitup V1.1.1, NPM 6.4.1, Node.js v8.15.0, lokale Sicherung
                      Egal wie ich das Backup starte (mit DP auf "true" setzten oder automatisch), kommt immer diese Fehlermeldung im Log:
                      backitup.0	2019-02-15 11:01:22.481	debug	system.adapter.admin.0: logging false
                      backitup.0	2019-02-15 11:01:22.479	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1550224882470,"q":0,"from":"system.adapter.admin.0","lc":1550224882470}
                      backitup.0	2019-02-15 11:00:55.915	debug	system.adapter.admin.0: logging true
                      backitup.0	2019-02-15 11:00:55.912	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1550224855909,"q":0,"from":"system.adapter.admin.0","lc":1550224855909}
                      backitup.0	2019-02-15 10:57:00.351	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1550224620346,"q":0,"from":"system.adapter.backitup.0","lc":1550224620346}
                      backitup.0	2019-02-15 10:57:00.339	debug	[minimal] exec: done
                      backitup.0	2019-02-15 10:57:00.328	debug	[minimal/history] done
                      backitup.0	2019-02-15 10:57:00.256	debug	[minimal/clean] done
                      backitup.0	2019-02-15 10:57:00.253	debug	[minimal/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                      backitup.0	2019-02-15 10:57:00.235	debug	[minimal/redis] [IGNORED] Error: EACCES: permission denied, scandir '/var/lib/redis'
                      backitup.0	2019-02-15 10:57:00.162	debug	[minimal/minimal] done
                      backitup.0	2019-02-15 10:57:00.103	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_02_15-10_56_47_BananaPiPro_backupiobroker.tar.gz
                      backitup.0	2019-02-15 10:56:45.796	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":true,"ack":false,"ts":1550224605789,"q":0,"from":"system.adapter.admin.0","lc":1550224605789}
                      backitup.0	2019-02-15 10:56:45.213	debug	system.adapter.admin.0: logging false
                      backitup.0	2019-02-15 10:56:45.211	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1550224605204,"q":0,"from":"system.adapter.admin.0","lc":1550224605204}
                      backitup.0	2019-02-15 10:56:27.491	debug	system.adapter.admin.0: logging true
                      backitup.0	2019-02-15 10:56:27.484	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1550224587476,"q":0,"from":"system.adapter.admin.0","lc":1550224587476}
                      backitup.0	2019-02-15 10:56:14.757	debug	[total] 10 00 06 */3 * *
                      backitup.0	2019-02-15 10:56:14.744	info	[total] backup was activated at 06:00 every 3 day(s)
                      backitup.0	2019-02-15 10:56:14.743	debug	[minimal] 10 00 05 */1 * *
                      backitup.0	2019-02-15 10:56:14.659	info	[minimal] backup was activated at 05:00 every 1 day(s)
                      backitup.0	2019-02-15 10:56:14.590	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.0
                      backitup.0	2019-02-15 10:56:14.237	info	States connected to redis: 127.0.0.1:6379
                      backitup.0	2019-02-15 10:56:14.219	debug	statesDB connected
                      backitup.0	2019-02-15 10:56:14.108	debug	objectDB connected
                      Berechtigung Dateien/Ordner:
                      Was kann ich tun?
                      NUC7i3BNH mit Proxmox und ioBroker (VM Debian Buster), Raspi3 (Slave Smartmeter für eHZ easymeter), Hardware CCU2, SMA SB5000TL-21
                      • RöstkartoffelR Röstkartoffel
                        Was kann ich tun?
                        simatecS Online
                        simatecS Online
                        simatec
                        #1770
                        @Röstkartoffel
                        Das ist leider wieder ein Rechteproblem des Users iobroker.
                        Ich schaue mal, ob wir das mit backitup irgendwie umgehen können.
                        Der User iobroker, der mit dem Installer angelegt wird, hat nur sehr beschränkte Rechte.
                        In dem Fall hat er keine Rechte, den Pfad von Redis zu lesen.
                        Ich kümmere mich darum.
                        • AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          #1771
                          In dem Fall dürfte es reichen, den User zur redis-Gruppe hinzuzufügen
                          sudo usermod -a -G redis iobroker
                          simatecS P 3 Antworten Letzte Antwort
                          • AlCalzoneA AlCalzone
                            simatecS Online
                            simatecS Online
                            simatec
                            #1772
                            @AlCalzone
                            Vielleicht können wir das nach erfolgreichen Testen noch mit in den Installer aufnehmen.
                            • simatecS simatec
                              @AlCalzone
                              AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              #1773
                              @simatec Gerne!
                                simatecS Online
                                simatecS Online
                                simatec
                                #1774
                                @AlCalzone sagte in Adapter: iobroker.backitup (stable Release):
                                @Röstkartoffel
                                Kannst du das mal bitte testen und hier berichten.
                                  Röstkartoffel
                                  #1775
                                  reboot
                                  oneclick Backup gestartet und voila, keine Fehlermeldung, RedisBackup vorhanden:
                                  Danke.
                                    AlCalzoneA Offline
                                    AlCalzone
                                    #1776
                                    Prima :)
                                    https://github.com/ioBroker/ioBroker/pull/125
                                    • SegwayS Offline
                                      SegwayS Offline
                                      Segway
                                      #1777
                                      Ich habe irgendwann dann das Problem, dass nach dem backup anscheinend nicht sauber geschlossen wird und beim nächsten backup DRIVE IS BUSY kommt. Leider kommt auch keine Meldung, dass das angedachte (cron) backup nicht erstellt werden konnte.
                                      Ich merke es erst wenn ich mal nachschaue was auf meinen NAS abgelegt wurde.
                                      Kann man da nicht eine Meldung reinbringen ?
                                      Per Putty mach ich ein einfaches UMOUNT und danach geht wieder alles. Das könnte man auch einbringen oder ?
                                      Gruß Dirk
                                      • SegwayS Segway
                                        simatecS Online
                                        simatecS Online
                                        simatec
                                        #1778
                                        @Segway
                                        Das dürfte ab Version 1.0.9 nicht mehr vorkommen.
                                        Wenn kein umount gemacht werden kann, da noch Daten geschrieben werden, wird jetzt 10 Minuten gewartet und dann der umount erneut durchgeführt.
                                        SegwayS 1 Antwort Letzte Antwort
                                        • simatecS simatec
                                          @Segway
                                          SegwayS Offline
                                          SegwayS Offline
                                          Segway
                                          schrieb am zuletzt editiert von Segway
                                          #1779
                                          @simatec sagte in Adapter: iobroker.backitup (stable Release):
                                          Okay, ich habe die 1.0.8 laufen. Dann date ich mal auf 1.1.1 ab.
                                          Schuss in Ofen ... der startet erst gar nicht :-(
                                          backitup.0	2019-02-15 17:42:29.067	info	terminating
                                          backitup.0	2019-02-15 17:42:28.561	error	at tryOnImmediate (timers.js:768:5)
                                          backitup.0	2019-02-15 17:42:28.561	error	at runCallback (timers.js:814:20)
                                          backitup.0	2019-02-15 17:42:28.561	error	at Immediate.createInstancesObjects [as _onImmediate] (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:748:13)
                                          backitup.0	2019-02-15 17:42:28.561	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:788:29
                                          backitup.0	2019-02-15 17:42:28.561	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4990:18)
                                          backitup.0	2019-02-15 17:42:28.561	error	at Adapter.emit (events.js:208:7)
                                          backitup.0	2019-02-15 17:42:28.561	error	at emitNone (events.js:106:13)
                                          backitup.0	2019-02-15 17:42:28.561	error	at Adapter.main (/opt/iobroker/node_modules/iobroker.backitup/main.js:615:5)
                                          backitup.0	2019-02-15 17:42:28.561	error	at createBackupDir (/opt/iobroker/node_modules/iobroker.backitup/main.js:600:12)
                                          backitup.0	2019-02-15 17:42:28.561	error	at Object.fs.mkdirSync (fs.js:885:18)
                                          backitup.0	2019-02-15 17:42:28.561	error	Error: EEXIST: file already exists, mkdir '/opt/iobroker/backups'
                                          backitup.0	2019-02-15 17:42:28.561	error	uncaught exception: EEXIST: file already exists, mkdir '/opt/iobroker/backups'
                                          backitup.0	2019-02-15 17:42:28.544	info	starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.0
                                          backitup.0	2019-02-15 17:42:28.350	info	States connected to redis: 127.0.0.1:6379
                                          Gruß Dirk
