  4. Test Adapter SourceAnalytix v0.2.x
adaptertest
958 Beiträge 103 Kommentatoren 352.1k Aufrufe 71 Beobachtet
  • F Offline
    f0rd42
    #373
    Hi
    mir sind gerade ein paar Logs aufgefallen:
    sourceanalytix.0	2019-02-06 12:24:00.200	info	Object array of trigger : {"type":"state","common":{"name":"Letzte Regeneration Über","type":"number","role":"number","desc":"Letzte Regeneration Über","read":true,"write":true,"def":0,"min":0,"unit"
    sourceanalytix.0	2019-02-06 12:24:00.200	info	Object array from trigger : ["smartmeter.0.1-0:1_8_0_255.value","smartmeter.1.1_8_1.value"]
    sourceanalytix.0	2019-02-06 12:24:00.200	info	Object array of trigger : {"type":"state","common":{"name":"Letzte Regeneration","type":"string","role":"string","desc":"Letzte Regeneration vor x h","read":true,"write":true,"def":0,"min":0,"unit":"
    sourceanalytix.0	2019-02-06 12:24:00.199	info	Object array from trigger : ["smartmeter.0.1-0:1_8_0_255.value","smartmeter.1.1_8_1.value"]
    sourceanalytix.0	2019-02-06 12:24:00.199	info	Object array of trigger : {"type":"state","common":{"name":"Restzeit/-menge Reg.Schritt","type":"number","role":"number","desc":"Restzeit/-menge Reg.Schritt","read":true,"write":true,"def":0,"min":0,
    sourceanalytix.0	2019-02-06 12:24:00.199	info	Object array of trigger : {"type":"state","common":{"name":"Kapazitätszahl","type":"number","role":"number","desc":"Kapazitätszahl","read":true,"write":true,"def":0,"min":0,"unit":"m³*°dH"},"from":"s
    sourceanalytix.0	2019-02-06 12:24:00.197	info	Object array from trigger : ["smartmeter.0.1-0:1_8_0_255.value","smartmeter.1.1_8_1.value"]
    sourceanalytix.0	2019-02-06 12:24:00.197	info	Object array of trigger : {"type":"state","common":{"name":"Restkapazität","type":"number","role":"number","desc":"Restkapazität","read":true,"write":true,"def":0,"min":0,"unit":"m³*°dH"},"from":"sys
    sourceanalytix.0	2019-02-06 12:24:00.197	info	Object array of trigger : {"type":"state","common":{"name":"Aktueller Durchfluss","type":"number","role":"number","desc":"Aktueller Durchfluss","read":true,"write":true,"def":0,"min":0,"unit":"m³/h",
    sourceanalytix.0	2019-02-06 12:24:00.196	info	Object array from trigger : ["smartmeter.0.1-0:1_8_0_255.value","smartmeter.1.1_8_1.value"]
    sourceanalytix.0	2019-02-06 12:24:00.196	info	Object array of trigger : {"type":"state","common":{"name":"Regeneration aktiv","type":"number","role":"number","desc":"Regeneration aktiv","read":true,"write":true,"def":0,"min":0,"unit":""},"from":
    sourceanalytix.0	2019-02-06 12:24:00.193	info	Object array of trigger : {"type":"state","common":{"name":"Voraussichtliche nächste Regeneration","type":"string","role":"string","desc":"Voraussichtliche nächste Regeneration","read":true,"write":t
    sourceanalytix.0	2019-02-06 12:24:00.192	info	Object array from trigger : ["smartmeter.0.1-0:1_8_0_255.value","smartmeter.1.1_8_1.value"]
    sourceanalytix.0	2019-02-06 12:24:00.192	info	Object array of trigger : {"type":"state","common":{"name":"0= Austauscher gestört/in Regeneration 1= Austauscher in Betrieb","type":"number","role":"number","desc":"0= Austauscher gestört/in Regener
    sourceanalytix.0	2019-02-06 12:24:00.192	info	Object array of trigger : {"type":"state","common":{"name":"Aktuelle Restkapazität Austauscher","type":"number","role":"number","desc":"Aktuelle Restkapazität Austauscher","read":true,"write":true,"d
    sourceanalytix.0	2019-02-06 12:24:00.192	info	Object array of trigger : {"type":"state","common":{"name":"Ergebnis letzter E-Mail Versand 0=keine Mail versandt 1=Mail erfolgreich versandt 2=Benutzerdaten fehlerhaft 3= kein Internetzugang/Server
    sourceanalytix.0	2019-02-06 12:24:00.191	info	Object array from trigger : ["smartmeter.0.1-0:1_8_0_255.value","smartmeter.1.1_8_1.value"]
    warum "vergreift" sich denn sourceanalytix an meiner Wasserenthärtungsanlage?
    Eigestellt ist bei den Datenpunkten nichts
    • lobomauL Offline
      lobomauL Offline
      lobomau
      #374
      @Dutchman:
      Probier Mal bitte aus Admin anstatt Konsole zu installieren.
      Hoffentlich finde ich heute Zeit weiter zu machen…
      Sent from my iPhone using Tapatalk `
      Ich habe es immer per Admin gemacht. Ich bekomme es nur nicht vernünftig de- und installiert. Er sagt unter "latest", Version 2.2.26 verfügbar.
      Nach der Installation steht aber 2.2.27. installiert. Aber richtig zuende installieren tut er auch nicht mehr. Ich glaube ich bekomme 2.2.27 nicht richtig deinstalliert.
      Beim Versuch zu installieren:
      cloud.0 2019-02-06 12:51:06.133 warn Unknown command: cmdExit
      cloud.0 2019-02-06 12:51:05.137 warn Unknown command: cmdExit
      cloud.0 2019-02-06 12:51:05.136 warn Unknown command: cmdStderr
      iobroker 2019-02-06 12:51:05.129 info exit 1
      iobroker 2019-02-06 12:51:05.125 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
      iobroker 2019-02-06 12:51:05.125 error at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      iobroker 2019-02-06 12:51:05.125 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      iobroker 2019-02-06 12:51:05.125 error at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
      iobroker 2019-02-06 12:51:05.125 error at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      iobroker 2019-02-06 12:51:05.125 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      iobroker 2019-02-06 12:51:05.125 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      iobroker 2019-02-06 12:51:05.125 error at Socket.objects.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:522:34)
      iobroker 2019-02-06 12:51:05.125 error at Install.createInstance (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:672:34)
      iobroker 2019-02-06 12:51:05.125 error at Object.getAdapterDir (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:805:17)
      iobroker 2019-02-06 12:51:05.125 error TypeError: Cannot read property 'substring' of undefined
      iobroker 2019-02-06 12:51:05.125 error ^
      iobroker 2019-02-06 12:51:05.125 error /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:805 if (adapter.substring(0, appName.length + 1) === appName + '.') {
      cloud.0 2019-02-06 12:51:04.830 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:04.828 info upload [0] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/custom_m.html custom_m.html text/html
      cloud.0 2019-02-06 12:51:04.769 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:04.766 info upload [1] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/de/translations.json i18n/de/translations.json application/json
      cloud.0 2019-02-06 12:51:04.708 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:04.706 info upload [2] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/en/translations.json i18n/en/translations.json application/json
      cloud.0 2019-02-06 12:51:04.649 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:04.647 info upload [3] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/es/translations.json i18n/es/translations.json application/json
      cloud.0 2019-02-06 12:51:04.586 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:04.583 info upload [4] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      cloud.0 2019-02-06 12:51:04.527 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:04.525 info upload [5] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/it/translations.json i18n/it/translations.json application/json
      cloud.0 2019-02-06 12:51:04.454 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:04.451 info upload [6] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      cloud.0 2019-02-06 12:51:04.393 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:04.390 info upload [7] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      cloud.0 2019-02-06 12:51:04.331 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:04.329 info upload [8] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      cloud.0 2019-02-06 12:51:04.242 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:04.239 info upload [9] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      cloud.0 2019-02-06 12:51:03.989 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:03.986 info upload [10] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      cloud.0 2019-02-06 12:51:03.916 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:03.914 info upload [11] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/index_m.html index_m.html text/html
      cloud.0 2019-02-06 12:51:03.812 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:03.810 info upload [12] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/settings_details.png settings_details.png image/png
      cloud.0 2019-02-06 12:51:03.748 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:03.745 info upload [13] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/settings_open.png settings_open.png image/png
      cloud.0 2019-02-06 12:51:03.672 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:03.670 info upload [14] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/sourceanalytix.png sourceanalytix.png image/png
      cloud.0 2019-02-06 12:51:03.613 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:03.611 info upload [15] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/style.css style.css text/css
      cloud.0 2019-02-06 12:51:03.554 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:03.551 info upload [16] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/tsconfig.json tsconfig.json application/json
      cloud.0 2019-02-06 12:51:03.462 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:03.458 info upload [17] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/words.js words.js application/javascript
      cloud.0 2019-02-06 12:51:03.434 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:03.431 info got /opt/iobroker/node_modules/iobroker.sourceanalytix/admin
      cloud.0 2019-02-06 12:51:03.406 warn Unknown command: cmdStdout
      iobroker 2019-02-06 12:51:03.404 info host.iobroker-ubuntu install adapter sourceanalytix
      iobroker 2019-02-06 12:51:02.476 info add sourceanalytix --host iobroker-ubuntu</anonymous></anonymous>
      Installationsdialog zeigt aber keine Einträge, als wenn nicths passieren würde. ABer log zeigt, dass etwas passiert.
      Dann beim Versuch zu deinstallieren:
      cloud.0	2019-02-06 12:59:56.365	warn	Unknown command: cmdStdout
      iobroker	2019-02-06 12:59:56.362	info	path: '/home/iobroker/.npm/_logs' }
      iobroker	2019-02-06 12:59:56.362	info	syscall: 'scandir',
      iobroker	2019-02-06 12:59:56.362	info	code: 'EACCES',
      iobroker	2019-02-06 12:59:56.362	info	errno: -13,
      iobroker	2019-02-06 12:59:56.362	info	glob error { Error: EACCES: permission denied, scandir '/home/iobroker/.npm/_logs' stack: 'Error: EACCES: permission denied, scandir \'/home/iobroker/.npm/_logs\'',
      host.iobroker-ubuntu	2019-02-06 12:58:51.796	error	Cannot write files: /opt/iobroker/iobroker-data/files/sourceanalytix.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/files/sourceanalytix.admin/_data.json'
      cloud.0	2019-02-06 12:58:51.457	warn	Unknown command: cmdStdout
      iobroker	2019-02-06 12:58:51.454	info	npm uninstall iobroker.sourceanalytix --silent --save --prefix "/opt/iobroker" (System call)
      cloud.0	2019-02-06 12:58:50.833	warn	Unknown command: cmdStdout
      iobroker	2019-02-06 12:58:50.816	info	host.iobroker-ubuntu Deleting 1 state(s).
      cloud.0	2019-02-06 12:58:50.812	warn	Unknown command: cmdStdout
      iobroker	2019-02-06 12:58:50.807	info	host.iobroker-ubuntu Deleting 1 object(s).
      cloud.0	2019-02-06 12:58:50.785	warn	Unknown command: cmdStdout
      iobroker	2019-02-06 12:58:50.778	info	host.iobroker-ubuntu Counted 1 states (system.adapter.sourceanalytix.*) from states
      cloud.0	2019-02-06 12:58:50.652	warn	Unknown command: cmdStdout
      iobroker	2019-02-06 12:58:50.649	info	host.iobroker-ubuntu Counted 1 states of sourceanalytix
      cloud.0	2019-02-06 12:58:48.441	warn	Unknown command: cmdStdout
      iobroker	2019-02-06 12:58:48.438	info	host.iobroker-ubuntu no instances of adapter sourceanalytix found
      cloud.0	2019-02-06 12:58:48.415	warn	Unknown command: cmdStdout
      iobroker	2019-02-06 12:58:48.412	info	Delete adapter "sourceanalytix"
      iobroker	2019-02-06 12:58:47.559	info	del sourceanalytix
      Edit: habe scheinbar allgemein einen bug. Oder ist es normal, dass sich über cloud iobroker.pro das Dialogfeld beim Installieren sich nicht aktualisiert? Habe eben anderen Adapter installiert und es kommt nix. Es steht einfach: Gestartet… $ ./iobroker upgrade "Adaptername"
      Host: NUC8i3 mit Proxmox:
      • Slave: Pi4
      • U Offline
        U Offline
        UncleB
        #375
        Mal ne blöde Fragen..
        Welchen Datenpunkt muss ich loggen um eine Tägliche / Monatliche /Jährliche Auswertung zu erhalten?
        Vermutlich ENERGY_TODAY?
        Oder passiert das Live mit Current?
        ![](</s><URL url=)https://i.postimg.cc/xTktVh29/Download.png" />
        • Homer.J.H Offline
          Homer.J.H Offline
          Homer.J.
          #376
          @UncleB:
          ![](</s><URL url=)https://i.postimg.cc/xTktVh29/Download.png" /> ` Energy total Rest geht von alleine.
          • C Offline
            Creator
            #377
            So ich habe auch mal den Adapter installiert.
            Ich vertstehe gerade nicht wie ich dafür sorgen kann, dass die Berechnung bei 0 anfängt.
            Es ist egal ob ich beim Startwert 0 oder den aktuellen Zählerstand hinterlege, der aktuelle Monat war echt teuer...
            Dazu wäre es für viele glaube ich ich super, wenn in der Oberfläche bei den Einstellungen eine erklärung stehen würde. :) Als Tooltipp oder so.
            a200A 1 Antwort Letzte Antwort
            • C Creator
              a200A Offline
              a200A Offline
              a200
              schrieb am zuletzt editiert von a200
              #378
              @Creator said in [Neuer Adapter Beta 0.2.21] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
              Aber wie hast du das gemacht? Der Adapter (0.2.27) ist nicht im IoBroker und wenn ich den über git installieren will, dann bekomme ich Fehlermeldung beim erzeugen der Instanz.
              IoBroker auf QNAP TS-451, Raspi und NUC
              • a200A a200
                sigi234S Online
                sigi234S Online
                #379
                @a200
                Über die Katze...
                • sigi234S sigi234
                  @a200
                  Über die Katze...
                  a200A Offline
                  a200A Offline
                  a200
                  #380
                  @sigi234
                  ja, aber dann wird die 0.2.27er Version geladen und die macht bei der Erstellung einer Instanz Probleme!!002.PNG.
                  Welches os hast du denn und wann hast du die 0.2.26 Version Installiert?
                  • a200A a200
                    @sigi234
                    sigi234S Online
                    sigi234S Online
                    #381
                    @a200
                    Windows 10, bin wieder auf die 0.2.26 gegangen.
                    • sigi234S sigi234
                      @a200
                      a200A Offline
                      a200A Offline
                      a200
                      #382
                      @sigi234 said in [Neuer Adapter Beta 0.2.21] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                      @a200
                      ok. ich bin auf der qnap. aber wie kannst du auf 0.2.26 gegangen. Bei der Katz kriege ich automatisch die 0.2.27.
                      • hg6806H Offline
                        hg6806H Offline
                        hg6806
                        #383
                        Sag mal Dutchman, wann gibt es denn eine neue Version?
                        Besonders das todo
                        "add object states for previous [x]day, [x]week, [x]month, [x]quarter, [x]year configurable in adapter settings"
                        ist für mich interessant, da ich immer die letzten Tage/Wochen per Balkengrafik anzeigen lasse.
                        • a200A a200
                          @a200
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          #384
                          @a200 said in [Neuer Adapter Beta 0.2.21] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                          Du musst den Expertenmodus einschalten. Dann siehst du ganz rechts (neben dem Papierkorb) ein neues Symbol. Mit dem kannst du dann die Version auswählen.
                          ° Fixer ---> iob fix
                          • NegaleinN Negalein
                            a200A Offline
                            a200A Offline
                            a200
                            #385
                            @Negalein said in [Neuer Adapter Beta 0.2.21] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                            Vielen Dank, wenn du Screenshots von oben siehst, dann wirst du merken, dass dieses Icon bei dem Adapter bei mir nicht angezeigt wird. Allerdings habe ich mir Dutchmans Hilfe das Problem gelöst. Ich habe das latest-repo als default angemeldet und dann wurde die 0.2.26 gezogen. Danach die Respos wieder aus Standard gesetzt. Also alles gut jetzt! vielen Dank an alle!
                            portyP 1 Antwort Letzte Antwort
                              Treep77
                              schrieb am zuletzt editiert von Treep77
                              #386
                              Hab die 0.2.26 Version installiert. Muss man die Objektordner (Tage/Woche---) selbst erstellen?? Bekomme bei den Objekten keine Unterordner angezeigt.
                              EDIT: Fehler gefunden....hab 2 Häckchen vergessen.
                              • DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                #387
                                Dieses Wochenende wird weiter gehen in der Entwicklung dieses Adapters hatte bissl zuviel tun letzten Wochen 😉
                                • hg6806H Offline
                                  hg6806H Offline
                                  hg6806
                                  #388
                                  Klasse !!!
                                  • SmarthomeMFS Offline
                                    SmarthomeMF
                                    #389
                                    Ich lese wieder mit
                                    Max
                                    ioBroker auf einem NUC ,16GB RAM, 120GB SSD) mit Proxmox
                                    Cloud Pro, iot, Alexa, Sonos, sonoff, Fronius, Harmony, Doorbird, Shelly, Hue, Loxone, Mihome, …
                                      burncolonia
                                      #390
                                      Ein freundliches Hallo in die Runde. Auch ich habe mich sehr über diesen Adapter gefreut, kann ich doch damit perfekt meinen Stromverbrauch messen bzw mitloggen.
                                      Ich habe ein ganz anderes Problem. Ich wollte aus Performance-Gründen den Raspi gegen einen NUC mit 8GB RAM austauschen. Der Umzug klappt auch soweit gut nur werden leider keine Daten von sourceanalytix übernommen. Weder über iobroker backup / restore noch über den kopierten History Ordner.
                                      Könnte mir jemand sagen wo die Daten liegen?
                                      Freundliche Grüße
                                      vom BuRn
                                      • B burncolonia
                                        Freundliche Grüße
                                        vom BuRn
                                        #391
                                        @burncolonia
                                        Hattest du auf dem Raspberry Pi redis aktiviert?
                                          @burncolonia
                                          burncolonia
                                          schrieb am zuletzt editiert von burncolonia
                                          #392
                                          @Homoran nicht wissentlich. jedoch wurde beim restore gemeckert er würde Redis nicht erreichen, welches ich dann nachinstalliert habe ...
                                          hilft das weiter oder was kann ich noch liefern?
