Test Adapter Aura
@MeinzIsAs Es wird mittlerweile angeboten.
bekomme diese Meldungen nach Update :
aura.0 2026-11-16 12:01:02.850 info aura: open the aura instance settings and press "Check backend" for the full report (also in aura.0.info.backendCheck) aura.0 2026-11-16 12:01:02.489 info aura: HTTP server listening on port 8095 aura.0 2026-11-16 12:01:01.250 info aura: web adapter extension on — also reachable as <web.0>/aura/ (that instance restarts whenever this instance is started, stopped or reconfigured) aura.0 2026-11-16 12:01:01.136 info starting. Version 1.0.2 in C:/SmartHome/node_modules/iobroker.aura, node: v24.22.3, js-controller: 7.2.5 aura.0 2026-11-16 12:00:55.154 error Error: Connection is closed. at Redis.sendCommand (C:\SmartHome\node_modules\ioredis\built\redis\index.js:636:24) at Redis.psubscribe (C:\SmartHome\node_modules\ioredis\built\commander.js:121:25) at ObjectsInRedisClient._subscribe (file:///C:/SmartHome/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:2011:23) at Immediate.<anonymous> (file:///C:/SmartHome/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:2047:25) at process.processImmediate (node:internal/timers:576:21) aura.0 2026-11-16 12:00:55.153 error unhandled promise rejection: Connection is closed. aura.0 2026-11-16 12:00:55.153 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). aura.0 2026-11-16 12:00:55.151 warn [announcements] could not load the rules: DB closed aura.0 2026-11-16 12:00:54.938 info terminating aura.0 2026-11-16 12:00:54.938 info terminating aura.0 2026-11-16 12:00:54.650 warn setInterval called, but adapter is shutting down aura.0 2026-11-16 12:00:54.650 warn setTimeout called, but adapter is shutting down aura.0 2026-11-16 12:00:54.649 warn setInterval called, but adapter is shutting down aura.0 2026-11-16 12:00:54.439 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason aura.0 2026-11-16 12:00:54.438 info terminating aura.0 2026-11-16 12:00:54.437 info Got terminate signal TERMINATE_YOURSELF aura.0 2026-11-16 12:00:54.427 info aura: web adapter extension on — also reachable as <web.0>/aura/ (that instance restarts whenever this instance is started, stopped or reconfigured) aura.0 2026-11-16 12:00:54.288 info starting. Version 1.0.2 in C:/SmartHome/node_modules/iobroker.aura, node: v24.22.3, js-controller: 7.2.5 aura.0 2026-11-16 12:00:25.121 info terminating aura.0 2026-11-16 12:00:25.121 info terminating aura.0 2026-11-16 12:00:24.606 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason aura.0 2026-11-16 12:00:24.606 info terminating aura.0 2026-11-16 12:00:24.601 info Got terminate signal TERMINATE_YOURSELF
Hat jemand ne Idee, wie man den Heizplan aus dem heatingcontrol Adapter mit Aura umsetzen könnte?
Die aktuellen Raumeinstellungen bekommt man prima mit dem Thermostat Widget hin, aber beim Heizplan komme ich nicht sinnvoll weiter. In der vis gibt es ein fertiges Widget, das sieht dann so aus:
Die aktuellen Raumeinstellungen bekommt man prima mit dem Thermostat Widget hin, aber beim Heizplan komme ich nicht sinnvoll weiter. In der vis gibt es ein fertiges Widget, das sieht dann so aus:Mal schnell Claude gefragt:
Mit Aura-Bordmitteln geht das recht gut – der Heizplan von heatingcontrol besteht ja nur aus einfachen Datenpunkten.
Die Datenpunkte
Beim Profiltyp „Mo-Fr / Sa-So“ legt der Adapter je Raum und Zeitraum zwei Werte an:
heatingcontrol.0.Profiles.0.<Raum>.Mo-Fr.Periods.0.time → "07:00" heatingcontrol.0.Profiles.0.<Raum>.Mo-Fr.Periods.0.Temperature → 21 … Periods.1, .2, … und dasselbe unter Sa-SoAchtung: Die Profilnummer zählt im Datenpunkt ab 0 –
CurrentProfile = 1entsprichtProfiles.0.Umsetzung: Universal-Widget mit eigenem Raster (ohne Code)
So lässt sich die VIS-Tabelle direkt nachbauen:
- Widget „Universal“ mit Layout „Benutzerdefiniert“, 3 Spalten (Nr. | aus | Temperatur).
- Pro Zeitraum eine Zeile:
- Zelle
textmit der Nummer - Zelle
input, verbunden mit…Periods.N.time - Zelle
stepper, verbunden mit…Periods.N.Temperature(Schritt 0,5, Einheit °C)
- Zelle
- Für „Sa-So“ eine
text-Zelle als Zwischenüberschrift über die ganze Breite, darunter dieselben Zeilen. - Das Raster einmal bauen, für jeden weiteren Raum kopieren und nur den Raumnamen in den Datenpunkten ersetzen.
z.B.:
Export: aura-widget-universal-Heizplan_Studio__Profil_1_.json
@sigi234 Danke für den Log, das ist harmlos.
Nach dem Update gleicht Aura beim ersten Start einmal das eigene Instanzobjekt an (z. B. die Links in der Instanzübersicht). Jede Änderung daran lässt den js-controller die Instanz neu starten. Deshalb siehst du um 12:00:54 den Start und 150 ms später gleich wieder TERMINATE_YOURSELF.
Der erste Start lief in diesem Moment aber noch weiter. Daher kommen die Warnungen adapter is shutting down, could not load the rules: DB closed und der Connection is closed-Fehler von Redis: Die DB-Verbindung war schon zu. Ab 12:01:01 läuft die Instanz sauber (HTTP server listening on port 8095), und bei weiteren Starts sollte das nicht mehr auftreten.
In der nächsten Beta (@next) wartet Aura in diesem Fall auf den Neustart, statt weiterzustarten. Dann bleibt der Log beim Update sauber. An 1.0.2 ändert sich wegen des Code-Freeze nichts, es ist ja nur kosmetisch.
Die Datenpunkte
- Zelle
- Zelle
- Für „Sa-So“ eine
z.B.:
Die Datenpunkte
heatingcontrol.0.Profiles.0.<Raum>.Mo-Fr.Periods.0.time → "07:00" heatingcontrol.0.Profiles.0.<Raum>.Mo-Fr.Periods.0.Temperature → 21 … Periods.1, .2, … und dasselbe unter Sa-SoSo lässt sich die VIS-Tabelle direkt nachbauen:
- Zelle
- Zelle
- Für „Sa-So“ eine
Ich hab die Eingabe noch durch den Datumswähler (Nur Uhrzeit, Ausgabe 13:00) ersetzt:
Die Datenpunkte
- Zelle
- Zelle
- Für „Sa-So“ eine
Die Datenpunkte
- Zelle
- Zelle
- Für „Sa-So“ eine
wäre es möglich ein export dieses widgets zur verfügung zu stellen?
danke schon mal. :) -
Die Datenpunkte
- Zelle
- Zelle
- Für „Sa-So“ eine
Nutzt eigentlich jemand das Widget Statusübersicht für Schwache Batterien, Offene Fenster, Nicht erreichbar usw.?
Gibt es etwas was ihr dort gerne anders haben wollt?
Werden alle Geräte korrekt erkannt?Nutzt ihr bereits die Layouts Zweilig und Zuletzt gewechselt?
Sowas kann man sich z.B. bauen:
Du überforderst uns mit all den Funktionen und Einstellungsmöglichkeiten, wir kommen mit dem Ausprobieren und Testen gar nicht mehr hinterher
Aber danke für die Inspiration, werde ich so ggf. nachbauen.
@dering ja, habe ich ebenfalls für Batterien
Der Adapter iobroker.voice (vorheriger name ai-parakeet)
enthält nun eine hotword webkomponente die auch in aura verwendet werden kann.Zur Verarbeitung des gesprochenen Text und steuerung des iobrokers kann entweder der Adapter
smart-text2command oder auch der
assistant verwendet werden.Hier ein video zur Verwendung der webkomponente in Verbindung mit dem Adapter smart.text2command
https://forum.iobroker.net/topic/85812/test-adapter-smart-text2command
assistant verwendet werden.Eventuell, solltest du video hier posten um zu zeigen, dass ALLES lokal läuft und wie schnell das reagiert. Das überzeugt mehr.
Hab das jetzt auch mal ausprobiert. Leider werden für die Homematic-Geräten bei Fenstermeldungen nur die Gruppen erkannt (bei mir hm-rpc.1). Keine einzelnen Geräte (bei mir hm-rpc.0).
Bei den Batteriemeldungen funktioniert das richtig.Falls das hilft, hier mal die Objektdaten der Variable von einem einzelnen Fensterkontakt
{ "type": "state", "common": { "name": "EG_Küche_Fenster:1.STATE", "def": 0, "type": "number", "read": true, "write": false, "min": 0, "max": 1, "states": { "0": "CLOSED", "1": "OPEN" }, "role": "value.window" }, "native": { "MIN": "CLOSED", "UNIT": "\"\"", "OPERATIONS": 5, "MAX": "OPEN", "FLAGS": 1, "ID": "STATE", "TAB_ORDER": 0, "TYPE": "ENUM", "DEFAULT": "CLOSED", "VALUE_LIST": [ "CLOSED", "OPEN" ], "CONTROL": "DOOR_SENSOR.STATE" }, "from": "system.adapter.hm-rega.0", "user": "system.user.admin", "ts": 1735207694074, "_id": "hm-rpc.0.00109A498FCE8F.1.STATE", "acl": { "object": 1636, "state": 1636, "owner": "system.user.admin", "ownerGroup": "system.group.administrator" } }Wenn in einem Raum dann mehrere Fenster sind, wäre es interessant zu wissen welches.
Super wäre es auch noch, die Namen der gefundenen Geräte durch einen eigenen Text ersetzen zu lassen.
Ähnlich wie bei den Batterien, bei denen man ja die Zuordnung der Type machen kann.Zum Beispiel wird jetzt angezeigt:
DB_Bad_Thermostat:0 > DG_Bad_Thermostat:0.LOW_BATBei den Shelly Meldern wird kein Name angezeigt. Steht bei den Wassermeldern nur "Channel sensor > Flood" und bei den Rauchmeldern nur "Channel Smoke0 > Smoke detected".
Ich habe im Post oben den Link zum Video eingefügt.
Das Video ist noch vor dem Einsatz des verbesserten "iobroker" wakewords entstanden
https://forum.iobroker.net/topic/84910/test-adapter-aura/416 -
@MeinzIsAs Danke für den Test und den Objekt-Dump! Im nächsten Beta:
- Klassische HomeMatic-Kontakte (Rolle value.window, wie dein HM-Sec-SCo) werden jetzt erkannt, jedes Fenster eine eigene Zeile. Die Heizgruppen fallen in Räumen mit eigenem Kontakt weg, damit nichts doppelt kommt.
- Allgemeine Kanalnamen wie „Channel sensor“ oder „Channel Smoke0“ werden durch den Gerätenamen ersetzt. Aus „X:0 › X:0.LOW_BAT“ wird „X:0 › LOW_BAT“. Neue Filtervorlage „HomeMatic-Kanal (:1) weg“.
- Unter Darstellung → „Gerätenamen bearbeiten“ kannst du jedem Gerät einen eigenen Namen geben. Er gilt für alle Zeilen des Geräts.
Kannst du mir noch den Objekt-Dump eines Gruppen-Datenpunkts (hm-rpc.1) und eines Shelly-Sensors schicken? Dann prüfe ich, ob die Gruppen sauber wegfallen und der Shelly-Name ankommt.
Moin, in deinem Screenshot werden auch Volt angezeigt, wie geht das?
Ich habe habe über 20 Sensoren (HomeMatic, HomeMatic IP und Zigbee) die mir die Voltzahl der Batterien liefern, kein einziger Datenpunkt davon wird mir im Widget angezeigt. Dabei sind die doch die interessanten Werte.
Ist das so gewollt? Oder soll ich dazu ein Issue aufmachen, wenn ja, Feature oder Bug? Welche Daten brauchst du dazu?
Gruß, Johannes
Die Datenpunkte
- Zelle
- Zelle
- Für „Sa-So“ eine
z.B.:
@lesiflo Hi,
das geht super einfach mit dem Timer.
Ziel DP ist der SET Temperatur deiner Thermostat
Pro Zimmer ein Timer
Timer erlauben, dass eigene Werte für den Schaltpunkt eingegeben werden dürfen
Der Timer hat den Vorteil, dass Ausnahmezeiten wie Feiertage und Urlaub schon eingebaut sind.
Hier ein Screenshot:
