  3. Einsteigerfragen
  4. Installation
  5. Hiler für den Umzug auf Fujitsu Rechner
50 Beiträge 5 Kommentatoren 1.1k Aufrufe 6 Beobachtet
  • B
    B
    brokeling
                                ┌─ ioBroker Installer 2026-10-29 ──────────────────────────────────────────┐
                                │  √ Installing prerequisites                                              │
                                │  √ Creating ioBroker user and directory                                  │
                                │  √ Installing ioBroker                                                   │
                                │  √ Installing and configuring Redis                                      │
                                │  √ Finalizing installation                                               │
                                │  ioBroker was installed successfully                                     │
                                │  Open in a browser and start configuring:                                │
                                │    http://192.168.178.53:8081                                            │
                                │  You need to re-login before doing anything else on the console!         │
                                │  Please run 'iob fix' first after the required re-login to finalize      │
                                │  the setup.                                                              │
                                │  You can check the logs under /home/fu/iobroker-install.log              │
    • B brokeling
                                  │  Installs ioBroker into /opt/iobroker.                                   │
                                  │  Debian GNU/Linux 13 (trixie) (x86_64), Node.js v24.22.2                 │
                                  │  Standard users should not change the defaults, just press               │
                                  │  Enter.        │
                                  │  ► Install ioBroker                                                      │
                                  │    [x] Start ioBroker after the installation                             │
                                  │    [x] Install Redis for objects and states                              │
                                  │    Quit        │
                                  │  Installs Node.js if needed, the ioBroker packages and the service       │
                                  │  that starts ioBroker at boot.                                           │
                                  │  Classic output with every detail instead of this display: start the     │
                                  │  installer with --classic.                                               │
      Ich hatte hier install Redis auch mit markiert.
      Und jetzt auch.
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      @brokeling
      Keine Ahnung was der Installer da macht. Aber offenbar irgendwas verkehrt und an der Paketdatenbank vorbei, wenn da redis auf einem Debian installiert werden soll.
      • B
        B
        brokeling
        und ich habe wieder kein Glück. keine Erreichbarkeit.
                                    ┌─ ioBroker Fixer 2026-10-29 ──────────────────────────────────────────────┐
                                    │  √ Checking ioBroker user and directory permissions                      │
                                    │  √ Check and cleanup npm temporary directories                           │
                                    │  √ Database maintenance                                                  │
                                    │  √ Checking autostart                                                    │
                                    │  Your installation was fixed successfully                                │
                                    │  Run iobroker start to start ioBroker again!                             │
                                    │  You can check the logs under /home/fu/iobroker-fix.log                  │
        fu@debian:~$ iobroker start
        fu@debian:~$ iobroker status
         Cannot read system.config: null (OK when migrating or restoring)
        iobroker is not running on this host.
        No iobroker host is running.
        Objects type: redis
        States  type: redis
        • B brokeling
          Objects type: redis
          States  type: redis
          Thomas BraunT
          Thomas BraunT
          @brokeling Was besagen denn die Critical Errors von oben?
          Und
          Installation date unknown (filesystem does not support birth time).
          schaut auch komisch aus, ext4 hat nämlich ein Geburtsdatum.
          • B
            B
            brokeling
            meintest du das:
            fu@debian:~$ sudo dmesg --level=emerg,alert,crit -T
            [Mo Nov  2 19:51:38 2026] mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 7: ae00000000801136
            [Mo Nov  2 19:51:38 2026] mce: [Hardware Error]: TSC 0 ADDR 8c2c6d40 MISC 3040000086
            [Mo Nov  2 19:51:38 2026] mce: [Hardware Error]: PROCESSOR 0:906ea TIME 1793645497 SOCKET 0 APIC 0 microcode 0
            [Mo Nov  2 19:51:38 2026] mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 9: ae00000000801136
            [Mo Nov  2 19:51:38 2026] mce: [Hardware Error]: TSC 0 ADDR 8f05bec0 MISC 43040000086
            [Mo Nov  2 19:51:38 2026] mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 10: ee00000000801136
            [Mo Nov  2 19:51:38 2026] mce: [Hardware Error]: TSC 0 ADDR 8c2c6d00 MISC 43040000086
            fu@debian:~$
            • B brokeling
              meintest du das:
              fu@debian:~$
              Thomas BraunT
              Thomas BraunT
              @brokeling
              Schau mal ob es da was aktuelleres gibt:
              Firmware Version: V5.0.0.13 R1.25.0 for D3613-A1x
                 Firmware Date: Tue 2020-06-30
              • B brokeling
                meintest du das:
                fu@debian:~$
                Thomas BraunT
                Thomas BraunT
                @brokeling
                Meine KI flüstert mir dazu ein:
                Was für den Q958 zu tun bleibt
                Neueres BIOS suchen. Fujitsu/FSAS liefert für diese Board-Generation noch Updates – das Schwestergesicht Q558 (D3603-A1x) hat erst im Nov 2025 R1.39.0 bekommen ( Fujitsu Support). Für D3613-A1x auf support.ts.fujitsu.com nachsehen, ob es etwas neueres als R1.25.0 gibt – die Schwester-Boards haben den MCE-Fix seit R1.8.0 drin, für D3613 wäre zu prüfen, ob das ebenfalls enthalten bzw. nachgezogen wurde. (Nach der Kontron-Ausgliederung tauchen die Images auch auf ftp.kontron.com auf.)
                intel-microcode installieren – im Log steht microcode 0, es lief also zum Boot-Zeitpunkt kein Microcode-Update; alleine schon der aktuellen Microcode-Revisions wegen sinnvoll.
                Wenn kein neueres BIOS existiert oder es nicht hilft: Bei stabile laufender Kiste ist mce=nobootlog in der Kernel-Zeile der saubere Weg – genau der von Fujitsu-Changelog gemeinte Fall. Nur wenn die Maschine daneben jemals einfrieren sollte, wäre wieder alles offen und RAM/CPU dran.
                  @brokeling
                  Marc BergM
                  Marc BergM
                  Marc Berg
                  Der Installer hat einen Bug im Zusammenhang mit der Redis Installation.
                  Das kann man zwar heilen durch
                  iob stop
                  sudo rm /opt/iobroker/iobroker-data/iobroker.json
                  iob setup custom
                  iob setup first
                  iob start
                  aber vielleicht besser auf einen Fix warten.
                  EDIT: bei iob setup custom natürlich "redis" wählen
                  Pi-hole, Traefik, Checkmk, Conbee II+Zigbee2MQTT, LoRaWAN
                  • B
                    B
                    brokeling
                    ok, verstehe da nicht viel.
                    Was kann ich jetzt machen?
                    Wann kommt ein offizieller Fix?
                    • B brokeling
                      Marc BergM
                      Marc BergM
                      Marc Berg
                      @brokeling sagte:
                      Müsste jemand eine Issue eröffnen. Ich wüsste aber nicht mal, in welchem Repo der Installer liegt. @thomas-braun Weißt du das?
                      • mcm1957M
                        mcm1957M
                        mcm1957
                        @bluefox
                        Ev. kannst du da mal schaun was der installer macht ?
                        Support Repositoryverwaltung.
                        LESEN - gute Forenbeitrage
                        • mcm1957M mcm1957
                          @bluefox
                          Marc BergM
                          Marc BergM
                          Marc Berg
                          @mcm1957 sagte:
                          Das Problem steckt in configure_iobroker_redis. Die Funktion schreibt die iobroker.json vor dem setup first, und der Installer führt setup first nur aus, wenn die Datei fehlt.
                          • Marc BergM Marc Berg
                            @mcm1957 sagte:
                            mcm1957M
                            mcm1957M
                            mcm1957
                            @Marc-Berg said:
                            @mcm1957 sagte:
                            Ok, dann ändere ich auf: 'Kannst du das bitte fixen? DANKE'
                            @marc-berg
                            DANKE für Analyse.
                            • Thomas BraunT
                              Thomas BraunT
                              Was passiert denn, wenn man zuvor redis 'zu Fuß' installiert?
                              • B
                                B
                                brokeling
                                Für das ein Bios Firmware Upate schlägt mir KI vor:
                                Firmware-Manager einrichten
                                Software installieren
                                Tippe folgenden Befehl ein, um das offizielle Linux-Update-Tool zu installieren:
                                sudo apt install fwupd (Bestätige eventuelle Rückfragen mit Y oder J).
                                Nach neuen Versionen suchen
                                Datenbank aktualisieren
                                Lade nun die aktuelle Liste der verfügbaren Updates von den Herstellerservern herunter:
                                sudo fwupdmgr refresh...
                                • B brokeling
                                  Thomas BraunT
                                  Thomas BraunT
                                  @brokeling
                                  Kannste mal probieren. Ich weiß nur nicht, ob das Gerät dort auch geführt wird. Eigentlich betätigen sich in der Firmware Database eher andere Hersteller. Haste denn das Paket 'intel-microcode' schon mal nachinstalliert, falls es fehlt?
                                    @brokeling sagte:
                                    Thomas BraunT
                                    Thomas BraunT
                                    @Marc-Berg
                                    Ja, weiß ich. PR hab ich mal gestellt:
                                    https://github.com/ioBroker/ioBroker/pull/788
                                      @brokeling
                                      B
                                      B
                                      brokeling
                                      @Thomas-Braun sagte:
                                      @brokeling
                                      angeblich hat er was aktualisiert. aber scheinbar nur sicherheitsrelevantes.
                                      intel-microcode ist nachinstalliert. aber hier hat er gemeldet - hat er schon.
                                      wie kann es bei mir weitergehen?
                                      • B brokeling
                                        @brokeling
                                        Thomas BraunT
                                        Thomas BraunT
                                        @brokeling
                                        Du kannst auf einen Fix warten. Oder du installierst zuerst redis und lässt dann den ioBroker-Installer laufen. Ich glaube, der macht aber einen Fehler in der Datenbankinitialisierung.
                                        Das was @marc-berg vorschlägt kannst du auch mal probieren.
                                        • B
                                          B
                                          brokeling
                                          schrieb am zuletzt editiert von brokeling
                                          Ich hab das von @marc-berg gemacht.
                                          iob läuft jetzt :)
                                          Kann ich das so dann lassen?
                                          Oder ist das jetzt eine wacklige Konstruktion?
                                          Jetzt backup zurückladen???
                                          WYFzznu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\r\nCZs+WTJGBBhTJJTfKeP7AKGj3y/QniAPpmRpWTQd\r\n-----END CERTIFICATE-----\r\n"
                                          Update certificate defaultPrivate
                                          The object "system.certificates" was updated successfully.
                                          Update certificate defaultPublic
                                          fu@debian:~$ iob start
                                          fu@debian:~$ iob status
                                          At least one iobroker host is running.
                                          Objects type: redis
                                          States  type: redis
                                          fu@debian:~$
                                          84.2k
