  3. Off Topic
  4. Proxmox
  5. Umzug von Raspi auf Proxmox
Geplant Angeheftet Gesperrt Verschoben Proxmox
25 Beiträge 11 Kommentatoren 1.0k Aufrufe 10 Beobachtet
  • S Stefan341
    Erstmal die Ausgabe von iob diag
    Vielleicht kann man daraus ja schon etwas erkennen
    ```bash
    Script v.2026-10-01
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: ioB-pve
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 7.0.14-24-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Pentium(R) Gold G6500 CPU @ 4.10GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64bit
    System was installed 2 days ago (on 2026-10-18).
    Systemuptime and Load:
     20:56:36 up 5 min,  0 users,  load average: 1.56, 0.95, 0.42
    CPU threads     : 2
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2026-10-20 20:56:36 CEST
               Universal time: Tue 2026-10-20 18:56:36 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    Stefan
    HOME=/home/Stefan
    GROUPS=Stefan sudo users iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        Not found
    Desktop:
    Session:
    Boot Target:            multi-user.target
    *** MEMORY ***
    Mem:            4.3G        3.6G        671M        3.8M         61M        729M
    Swap:             0B          0B          0B
    Total:          4.3G        3.6G        671M
    Active iob-Instances:   28
             4096 M total memory
             3400 M used memory
             3305 M active memory
               11 M inactive memory
              639 M free memory
                0 M buffer memory
               58 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    top - 20:56:37 up 5 min,  0 users,  load average: 1.56, 0.95, 0.42
    Tasks:  46 total,   2 running,  44 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 47.6 us,  4.8 sy,  0.0 ni, 47.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   4096.0 total,    675.9 free,   3364.8 used,     58.9 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.    731.2 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                   Type      Size  Used Avail Use% Mounted on
    rpool/data/subvol-100-disk-0 zfs        50G  2.7G   48G   6% /
    none                         tmpfs     492K  4.0K  488K   1% /dev
    udev                         devtmpfs  6.8G     0  6.8G   0% /dev/tty
    tmpfs                        tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                        tmpfs     3.1G  100K  3.1G   1% /run
    tmpfs                        tmpfs     7.8G  3.6M  7.7G   1% /tmp
    tmpfs                        tmpfs     5.0M     0  5.0M   0% /run/lock
    Messages concerning filesystems in dmesg (Last 15 lines only):
    Show mounted filesystems:
    TARGET SOURCE                       FSTYPE OPTIONS
    /      rpool/data/subvol-100-disk-0 zfs    rw,relatime,xattr,posixacl,casesensitive
    /var:
    224M    /var/
    153M    /var/cache
    151M    /var/cache/apt
    98M     /var/cache/apt/archives
    68M     /var/lib
    Archived and active journals take up 437K in the file system.
    /opt/iobroker/backups:
    110M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    287M    /opt/iobroker/iobroker-data/
    264M    /opt/iobroker/iobroker-data/files
    86M     /opt/iobroker/iobroker-data/files/vis
    56M     /opt/iobroker/iobroker-data/files/0_userdata.0
    34M     /opt/iobroker/iobroker-data/files/0_userdata.0/szenen
    24M     /opt/iobroker/iobroker-data/files/vis/ring/doorbell.mp4
    24M     /opt/iobroker/iobroker-data/files/vis/doorbell.mp4
    12M     /opt/iobroker/iobroker-data/objects.jsonl
    8.4M    /opt/iobroker/iobroker-data/files/vis/stickup.mp4
    7.7M    /opt/iobroker/iobroker-data/files/vis/ring/stickup.mp4
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    *** ZigBee Settings ***
    Zigbee Network Settings on your coordinator / in nvbackup are:
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    === ZigBee Port Overview ===
    Instance        Configured Port                     Available by-id Port                Status
    zigbee.1        tcp://192.168.50.10:6638            -                                   tcp
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v24.22.0
    /usr/bin/node           v24.22.0
    /usr/bin/npm            11.19.1
    /usr/bin/npx            11.19.1
    ✓ Node.js installation is correct
    Recommended versions are nodejs 24.22.0 and npm 11.19.1
    nodejs:
      Installed: 24.22.0-1nodesource1
      Candidate: 24.22.0-1nodesource1
      Version table:
     *** 24.22.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages
         24.21.0-1nodesource1 1001
         24.20.0-1nodesource1 1001
         24.19.0-1nodesource1 1001
         24.18.1-1nodesource1 1001
         24.18.0-1nodesource1 1001
         24.17.0-1nodesource1 1001
         24.16.0-1nodesource1 1001
         24.15.0-1nodesource1 1001
         24.14.1-1nodesource1 1001
         24.14.0-1nodesource1 1001
         24.13.1-1nodesource1 1001
         24.13.0-1nodesource1 1001
         24.12.0-1nodesource1 1001
         24.11.1-1nodesource1 1001
         24.11.0-1nodesource1 1001
         24.10.0-1nodesource1 1001
         24.9.0-1nodesource1 1001
         24.8.0-1nodesource1 1001
         24.7.0-1nodesource1 1001
         24.6.0-1nodesource1 1001
         24.5.0-1nodesource1 1001
         24.4.1-1nodesource1 1001
         24.4.0-1nodesource1 1001
         24.3.0-1nodesource1 1001
         24.1.0-1nodesource1 1001
         24.0.2-1nodesource1 1001
         24.0.1-1nodesource1 1001
         24.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u3 500
            500 http://security.debian.org trixie-security/main amd64 Packages
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    No known Vulnerabilities detected!
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioB-Slave           ioB-Slave (version: 7.2.5, hostname: ioB-Slave     , alive, uptime: 77)
    ioB-pve             ioB-pve (version: 7.2.5, hostname: ioB-pve       , alive, uptime: 107)
    Core adapters versions
    js-controller:  7.2.5
    admin:          8.0.14
    javascript:     10.1.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioB-pve                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : ioB-pve                                  -  enabled
      system.adapter.alexa2.0                 : alexa2                : ioB-pve                                  -  enabled
      system.adapter.alexa2.1                 : alexa2                : ioB-pve                                  - disabled
    + system.adapter.backitup.0               : backitup              : ioB-pve                                  -  enabled
    + system.adapter.backitup.1               : backitup              : ioB-pve                                  -  enabled
      system.adapter.birthdays.0              : birthdays             : ioB-Slave                                -  enabled
      system.adapter.cameras.0                : cameras               : ioB-Slave                                - disabled, port: 8200, bind: 192.168.100.125
    + system.adapter.daswetter.0              : daswetter             : ioB-pve                                  -  enabled
      system.adapter.devices.0                : devices               : ioB-pve                                  - disabled
    + system.adapter.discovery.0              : discovery             : ioB-pve                                  -  enabled
      system.adapter.dwd.0                    : dwd                   : ioB-pve                                  -  enabled
    + system.adapter.email.0                  : email                 : ioB-Slave                                -  enabled
      system.adapter.energiefluss.0           : energiefluss          : ioB-Slave                                - disabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioB-pve                                  -  enabled
      system.adapter.feiertage.0              : feiertage             : ioB-Slave                                -  enabled
    + system.adapter.firetv.0                 : firetv                : ioB-pve                                  -  enabled
      system.adapter.flot.0                   : flot                  : ioB-Slave                                - disabled
    + system.adapter.fritzbox.0               : fritzbox              : ioB-pve                                  -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : ioB-pve                                  -  enabled
    + system.adapter.fritzdect.1              : fritzdect             : ioB-pve                                  -  enabled
      system.adapter.heizungssteuerung.0      : heizungssteuerung     : ioB-pve                                  - disabled
      system.adapter.history.0                : history               : ioB-Slave                                - disabled
      system.adapter.ical.0                   : ical                  : ioB-pve                                  -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioB-pve                                  - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioB-Slave                                - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioB-pve                                  - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioB-pve                                  - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioB-pve                                  - disabled
      system.adapter.influxdb.0               : influxdb              : ioB-Slave                                - disabled, port: 8086
    + system.adapter.javascript.0             : javascript            : ioB-pve                                  -  enabled
      system.adapter.luftdaten.0              : luftdaten             : ioB-pve                                  -  enabled
      system.adapter.matter.0                 : matter                : ioB-pve                                  -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : ioB-pve                                  -  enabled, port: 1890, bind: 0.0.0.0
      system.adapter.nina.0                   : nina                  : ioB-Slave                                -  enabled
      system.adapter.octoprint.0              : octoprint             : ioB-Slave                                - disabled
      system.adapter.pi-hole.0                : pi-hole               : ioB-Slave                                - disabled
    + system.adapter.pollenflug.0             : pollenflug            : ioB-pve                                  -  enabled
    + system.adapter.pushover.0               : pushover              : ioB-pve                                  -  enabled
    + system.adapter.pushover.1               : pushover              : ioB-pve                                  -  enabled
    + system.adapter.pushover.2               : pushover              : ioB-pve                                  -  enabled
      system.adapter.pushover.3               : pushover              : ioB-pve                                  -  enabled
    + system.adapter.radar2.0                 : radar2                : ioB-pve                                  -  enabled
      system.adapter.reolink.0                : reolink               : ioB-pve                                  -  enabled
    + system.adapter.residents.0              : residents             : ioB-Slave                                -  enabled
    + system.adapter.ring.0                   : ring                  : ioB-pve                                  -  enabled
      system.adapter.roborock.0               : roborock              : ioB-Slave                                - disabled
      system.adapter.schoolfree.0             : schoolfree            : ioB-Slave                                -  enabled
    + system.adapter.sonoff.0                 : sonoff                : ioB-pve                                  -  enabled, port: 1883, bind: 192.168.100.125
    + system.adapter.sql.0                    : sql                   : ioB-Slave                                -  enabled
      system.adapter.tankerkoenig.0           : tankerkoenig          : ioB-Slave                                -  enabled
    + system.adapter.tr-064.0                 : tr-064                : ioB-pve                                  -  enabled
    + system.adapter.tr-064.1                 : tr-064                : ioB-Slave                                -  enabled
      system.adapter.trashschedule.0          : trashschedule         : ioB-Slave                                -  enabled
      system.adapter.upnp.0                   : upnp                  : ioB-pve                                  - disabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioB-Slave                                - disabled
    + system.adapter.vis-2.0                  : vis-2                 : ioB-pve                                  -  enabled
      system.adapter.vis-bars.0               : vis-bars              : ioB-Slave                                - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioB-Slave                                - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioB-Slave                                - disabled
      system.adapter.vis-homekittiles.0       : vis-homekittiles      : ioB-pve                                  - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioB-Slave                                - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioB-Slave                                - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : ioB-Slave                                - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioB-Slave                                - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : ioB-Slave                                - disabled
      system.adapter.vis-metro.0              : vis-metro             : ioB-Slave                                - disabled
      system.adapter.vis-players.0            : vis-players           : ioB-Slave                                - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioB-Slave                                - disabled
      system.adapter.vis-weather.0            : vis-weather           : ioB-Slave                                - disabled
      system.adapter.vis.0                    : vis                   : ioB-pve                                  -  enabled
      system.adapter.wallpanel.0              : wallpanel             : ioB-Slave                                - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : ioB-pve                                  -  enabled
      system.adapter.web.0                    : web                   : ioB-pve                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : ioB-pve                                  -  enabled
    + system.adapter.zigbee.0                 : zigbee                : ioB-Slave                                -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_1a043fc8e5a5ed11bc85f1a32981d5c7-if00-port0
    + system.adapter.zigbee.1                 : zigbee                : ioB-pve                                  -  enabled, port: tcp://192.168.50.10:6638
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    │ (index) │ id                                           │ name                          │ version  │ upgrade policy │
    │ 0       │ 'system.adapter.admin'                       │ 'admin'                       │ '8.0.14' │ 'none'         │
    │ 1       │ 'system.adapter.alexa-timer-vis'             │ 'alexa-timer-vis'             │ '3.0.3'  │ 'none'         │
    │ 2       │ 'system.adapter.alexa2'                      │ 'alexa2'                      │ '3.28.3' │ 'none'         │
    │ 3       │ 'system.adapter.backitup'                    │ 'backitup'                    │ '4.0.3'  │ 'none'         │
    │ 4       │ 'system.adapter.birthdays'                   │ 'birthdays'                   │ '6.1.0'  │ 'none'         │
    │ 5       │ 'system.adapter.cameras'                     │ 'cameras'                     │ '2.1.2'  │ 'none'         │
    │ 6       │ 'system.adapter.daswetter'                   │ 'daswetter'                   │ '4.5.9'  │ 'none'         │
    │ 7       │ 'system.adapter.devices'                     │ 'devices'                     │ '1.2.14' │ 'none'         │
    │ 8       │ 'system.adapter.discovery'                   │ 'discovery'                   │ '5.0.0'  │ 'none'         │
    │ 9       │ 'system.adapter.dwd'                         │ 'dwd'                         │ '2.8.5'  │ 'none'         │
    │ 10      │ 'system.adapter.email'                       │ 'email'                       │ '3.0.0'  │ 'none'         │
    │ 11      │ 'system.adapter.energiefluss'                │ 'energiefluss'                │ '3.6.2'  │ 'none'         │
    │ 12      │ 'system.adapter.fb-checkpresence'            │ 'fb-checkpresence'            │ '1.4.2'  │ 'none'         │
    │ 13      │ 'system.adapter.feiertage'                   │ 'feiertage'                   │ '1.4.0'  │ 'none'         │
    │ 14      │ 'system.adapter.firetv'                      │ 'firetv'                      │ '2.2.0'  │ 'none'         │
    │ 15      │ 'system.adapter.flot'                        │ 'flot'                        │ '1.12.0' │ 'none'         │
    │ 16      │ 'system.adapter.fritzbox'                    │ 'fritzbox'                    │ '0.7.0'  │ 'none'         │
    │ 17      │ 'system.adapter.fritzdect'                   │ 'fritzdect'                   │ '2.6.2'  │ 'none'         │
    │ 18      │ 'system.adapter.heizungssteuerung'           │ 'heizungssteuerung'           │ '2.1.1'  │ 'none'         │
    │ 19      │ 'system.adapter.history'                     │ 'history'                     │ '4.0.0'  │ 'none'         │
    │ 20      │ 'system.adapter.ical'                        │ 'ical'                        │ '1.21.0' │ 'none'         │
    │ 21      │ 'system.adapter.icons-addictive-flavour-png' │ 'icons-addictive-flavour-png' │ '0.1.0'  │ 'none'         │
    │ 22      │ 'system.adapter.icons-icons8'                │ 'icons-icons8'                │ '0.0.1'  │ 'none'         │
    │ 23      │ 'system.adapter.icons-mfd-png'               │ 'icons-mfd-png'               │ '1.2.1'  │ 'none'         │
    │ 24      │ 'system.adapter.icons-mfd-svg'               │ 'icons-mfd-svg'               │ '1.2.0'  │ 'none'         │
    │ 25      │ 'system.adapter.icons-ultimate-png'          │ 'icons-ultimate-png'          │ '1.0.1'  │ 'none'         │
    │ 26      │ 'system.adapter.influxdb'                    │ 'influxdb'                    │ '4.0.2'  │ 'none'         │
    │ 27      │ 'system.adapter.javascript'                  │ 'javascript'                  │ '10.1.3' │ 'none'         │
    │ 28      │ 'system.adapter.luftdaten'                   │ 'luftdaten'                   │ '6.0.1'  │ 'none'         │
    │ 29      │ 'system.adapter.matter'                      │ 'matter'                      │ '1.3.1'  │ 'none'         │
    │ 30      │ 'system.adapter.mqtt'                        │ 'mqtt'                        │ '6.1.4'  │ 'none'         │
    │ 31      │ 'system.adapter.nina'                        │ 'nina'                        │ '0.0.25' │ 'none'         │
    │ 32      │ 'system.adapter.octoprint'                   │ 'octoprint'                   │ '5.1.0'  │ 'none'         │
    │ 33      │ 'system.adapter.pi-hole'                     │ 'pi-hole'                     │ '2.0.0'  │ 'none'         │
    │ 34      │ 'system.adapter.pollenflug'                  │ 'pollenflug'                  │ '2.0.0'  │ 'none'         │
    │ 35      │ 'system.adapter.pushover'                    │ 'pushover'                    │ '6.1.0'  │ 'none'         │
    │ 36      │ 'system.adapter.radar2'                      │ 'radar2'                      │ '2.4.0'  │ 'none'         │
    │ 37      │ 'system.adapter.reolink'                     │ 'reolink'                     │ '1.4.2'  │ 'none'         │
    │ 38      │ 'system.adapter.residents'                   │ 'residents'                   │ '1.1.1'  │ 'none'         │
    │ 39      │ 'system.adapter.ring'                        │ 'ring'                        │ '7.0.2'  │ 'none'         │
    │ 40      │ 'system.adapter.roborock'                    │ 'roborock'                    │ '0.7.4'  │ 'none'         │
    │ 41      │ 'system.adapter.scenes'                      │ 'scenes'                      │ '4.0.4'  │ 'none'         │
    │ 42      │ 'system.adapter.schoolfree'                  │ 'schoolfree'                  │ '2.1.0'  │ 'none'         │
    │ 43      │ 'system.adapter.simple-api'                  │ 'simple-api'                  │ '3.0.7'  │ 'none'         │
    │ 44      │ 'system.adapter.socketio'                    │ 'socketio'                    │ '7.1.3'  │ 'none'         │
    │ 45      │ 'system.adapter.sonoff'                      │ 'sonoff'                      │ '3.3.0'  │ 'none'         │
    │ 46      │ 'system.adapter.sql'                         │ 'sql'                         │ '3.0.1'  │ 'none'         │
    │ 47      │ 'system.adapter.tankerkoenig'                │ 'tankerkoenig'                │ '3.4.0'  │ 'none'         │
    │ 48      │ 'system.adapter.tr-064'                      │ 'tr-064'                      │ '4.3.0'  │ 'none'         │
    │ 49      │ 'system.adapter.trashschedule'               │ 'trashschedule'               │ '5.3.0'  │ 'none'         │
    │ 50      │ 'system.adapter.upnp'                        │ 'upnp'                        │ '1.1.0'  │ 'none'         │
    │ 51      │ 'system.adapter.vis'                         │ 'vis'                         │ '1.5.6'  │ 'none'         │
    │ 52      │ 'system.adapter.vis-2'                       │ 'vis-2'                       │ '2.13.8' │ 'none'         │
    │ 53      │ 'system.adapter.vis-2-widgets-gauges'        │ 'vis-2-widgets-gauges'        │ '2.0.2'  │ 'none'         │
    │ 54      │ 'system.adapter.vis-bars'                    │ 'vis-bars'                    │ '0.1.4'  │ 'none'         │
    │ 55      │ 'system.adapter.vis-canvas-gauges'           │ 'vis-canvas-gauges'           │ '1.0.1'  │ 'none'         │
    │ 56      │ 'system.adapter.vis-fancyswitch'             │ 'vis-fancyswitch'             │ '1.1.0'  │ 'none'         │
    │ 57      │ 'system.adapter.vis-homekittiles'            │ 'vis-homekittiles'            │ '0.4.6'  │ 'none'         │
    │ 58      │ 'system.adapter.vis-hqwidgets'               │ 'vis-hqwidgets'               │ '1.6.1'  │ 'none'         │
    │ 59      │ 'system.adapter.vis-icontwo'                 │ 'vis-icontwo'                 │ '2.11.6' │ 'none'         │
    │ 60      │ 'system.adapter.vis-inventwo'                │ 'vis-inventwo'                │ '4.1.1'  │ 'none'         │
    │ 61      │ 'system.adapter.vis-justgage'                │ 'vis-justgage'                │ '2.1.7'  │ 'none'         │
    │ 62      │ 'system.adapter.vis-material-advanced'       │ 'vis-material-advanced'       │ '1.7.4'  │ 'none'         │
    │ 63      │ 'system.adapter.vis-metro'                   │ 'vis-metro'                   │ '1.2.0'  │ 'none'         │
    │ 64      │ 'system.adapter.vis-players'                 │ 'vis-players'                 │ '0.1.6'  │ 'none'         │
    │ 65      │ 'system.adapter.vis-timeandweather'          │ 'vis-timeandweather'          │ '1.2.2'  │ 'none'         │
    │ 66      │ 'system.adapter.vis-weather'                 │ 'vis-weather'                 │ '2.5.13' │ 'none'         │
    │ 67      │ 'system.adapter.wallpanel'                   │ 'wallpanel'                   │ '0.3.11' │ 'none'         │
    │ 68      │ 'system.adapter.weatherunderground'          │ 'weatherunderground'          │ '3.7.0'  │ 'none'         │
    │ 69      │ 'system.adapter.web'                         │ 'web'                         │ '8.0.0'  │ 'none'         │
    │ 70      │ 'system.adapter.ws'                          │ 'ws'                          │ '4.1.0'  │ 'none'         │
    │ 71      │ 'system.adapter.yahka'                       │ 'yahka'                       │ '1.1.6'  │ 'none'         │
    │ 72      │ 'system.adapter.yahoo-stock-market'          │ 'yahoo-stock-market'          │ '0.0.7'  │ 'none'         │
    │ 73      │ 'system.adapter.zigbee'                      │ 'zigbee'                      │ '3.5.5'  │ 'none'         │
    ioBroker-Adapter Versions and update status
    Used repository: stable
    Adapter    "admin"        : 8.2.0    , installed 8.0.14 [Updatable]
    Adapter    "alexa-timer-vis": 3.0.3  , installed 3.0.3
    Adapter    "alexa2"       : 3.28.3   , installed 3.28.3
    Adapter    "backitup"     : 4.0.3    , installed 4.0.3
    Adapter    "daswetter"    : 4.6.1    , installed 4.5.9  [Updatable]
    Adapter    "devices"      : 4.2.2    , installed 1.2.14 [Updatable]
    Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
    Adapter    "firetv"       : 2.2.0    , installed 2.2.0
    Adapter    "fritzbox"     : 0.7.0    , installed 0.7.0
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "heizungssteuerung": 2.1.1, installed 2.1.1
    Adapter    "ical"         : 1.21.2   , installed 1.21.0 [Updatable]
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "javascript"   : 10.4.4   , installed 10.1.3 [Updatable]
    Controller "js-controller": 7.2.5    , installed 7.2.5
    Adapter    "luftdaten"    : 6.0.1    , installed 6.0.1
    Adapter    "matter"       : 1.3.1    , installed 1.3.1
    Adapter    "mqtt"         : 8.1.2    , installed 6.1.4  [Updatable]
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "pushover"     : 6.1.0    , installed 6.1.0
    Adapter    "radar2"       : 2.4.0    , installed 2.4.0
    Adapter    "reolink"      : 1.4.2    , installed 1.4.2
    Adapter    "ring"         : 7.0.2    , installed 7.0.2
    Adapter    "socketio"     : 9.0.1    , installed 7.1.3  [Updatable]
    Adapter    "sonoff"       : 5.1.1    , installed 3.3.0  [Updatable]
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2"        : 2.15.8   , installed 2.13.8 [Updatable]
    Adapter    "vis-homekittiles": 0.4.6 , installed 0.4.6
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "ws"           : 4.1.0    , installed 3.0.19 [Updatable]
    Adapter    "yahka"        : 1.1.6    , installed 1.1.6
    Adapter    "zigbee"       : 3.5.5    , installed 3.5.5
    Objects and States
    Objects:        36
    States:         3
    Hit:1 http://security.debian.org trixie-security InRelease
    Hit:2 http://deb.debian.org/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://deb.nodesource.com/node_24.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 1
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q Local Address:Port   Peer Address:PortProcess
    udp   UNCONN 0      0            0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=90,fd=5),("systemd",pid=1,fd=35))
    udp   UNCONN 0      0               [::]:sunrpc         [::]:*    users:(("rpcbind",pid=90,fd=7),("systemd",pid=1,fd=37))
    tcp   LISTEN 0      100        127.0.0.1:smtp        0.0.0.0:*    users:(("master",pid=273,fd=13))
    tcp   LISTEN 0      511          0.0.0.0:9000        0.0.0.0:*    users:(("iobroker.js-con",pid=4057,fd=29))
    tcp   LISTEN 0      511          0.0.0.0:9001        0.0.0.0:*    users:(("iobroker.js-con",pid=4057,fd=23))
    tcp   LISTEN 0      4096         0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=90,fd=4),("systemd",pid=1,fd=34))
    tcp   LISTEN 0      100            [::1]:smtp           [::]:*    users:(("master",pid=273,fd=14))
    tcp   LISTEN 0      4096               *:ssh               *:*    users:(("sshd",pid=131,fd=3),("systemd",pid=1,fd=51))
    tcp   LISTEN 0      4096            [::]:sunrpc         [::]:*    users:(("rpcbind",pid=90,fd=6),("systemd",pid=1,fd=36))
    2026-10-20 20:58:38.148  - info: host.ioB-pve added notifications configuration of host
    2026-10-20 20:58:38.638  - info: host.ioB-pve 77 instances found
    2026-10-20 20:58:38.646  - info: host.ioB-pve starting 34 instances
    2026-10-20 20:58:38.944  - info: host.ioB-pve Delete state "system.host.ioB-pve.versions.nodeCurrent"
    2026-10-20 20:58:38.981  - info: host.ioB-pve Delete state "system.host.ioB-pve.versions.nodeNewest"
    2026-10-20 20:58:38.990  - info: host.ioB-pve instance system.adapter.admin.0 in version "8.0.14" started with pid 4077
    2026-10-20 20:58:39.025  - info: host.ioB-pve Delete state "system.host.ioB-pve.versions.nodeNewestNext"
    2026-10-20 20:58:39.026  - info: host.ioB-pve Delete state "system.host.ioB-pve.versions.npmCurrent"
    2026-10-20 20:58:39.027  - info: host.ioB-pve Delete state "system.host.ioB-pve.versions.npmNewest"
    2026-10-20 20:58:39.029  - info: host.ioB-pve Delete state "system.host.ioB-pve.versions.npmNewestNext"
    2026-10-20 20:58:39.030  - info: host.ioB-pve Some obsolete host states deleted.
    2026-10-20 20:58:39.901  - error: admin.0 (4077) admin.0 already running
    2026-10-20 20:58:39.902  - warn: admin.0 (4077) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-10-20 20:58:40.464  - error: host.ioB-pve instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-10-20 20:58:40.464  - info: host.ioB-pve Restart adapter system.adapter.admin.0 because enabled
    2026-10-20 20:58:42.968  - info: host.ioB-pve instance system.adapter.javascript.0 in version "10.1.3" started with pid 4089
    2026-10-20 20:58:43.744  - error: javascript.0 (4089) javascript.0 already running
    2026-10-20 20:58:43.744  - warn: javascript.0 (4089) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-10-20 20:58:44.291  - error: host.ioB-pve instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-10-20 20:58:44.291  - info: host.ioB-pve Restart adapter system.adapter.javascript.0 because enabled
    2026-10-20 20:58:46.971  - info: host.ioB-pve instance system.adapter.pushover.0 in version "6.1.0" started with pid 4120
    2026-10-20 20:58:47.673  - error: pushover.0 (4120) pushover.0 already running
    2026-10-20 20:58:47.674  - warn: pushover.0 (4120) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2026-10-20 20:58:48.222  - error: host.ioB-pve instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2026-10-20 20:58:48.222  - info: host.ioB-pve Restart adapter system.adapter.pushover.0 because enabled
    ============= Mark until here for C&P =============
    iob diag has finished.
    paul53P
    paul53P
    @Stefan341 [sagte: etwas erkennen
    Du hast dem Container nur etwa 4 GB RAM zugewiesen. Das ist bei den vielen aktiven Instanzen zu wenig.
    Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
    • S
      S
      Stefan341
      Ich habe jetzt auf 8GB RAM erhöht. Reicht das? Was ist sinnvoll bei SWAP?
      • S Stefan341
        Thomas BraunT
        Thomas BraunT
        Most Active Developer
        @Stefan341
        Kommt drauf an. Ich würde wohl so mindestens 2GB dafür vorsehen.
          @Stefan341
          S
          S
          Stefan341
          @Thomas-Braun
          Ich hab alles soweit angepasst und die Adapter auf den neusten Stand gebracht.
          Hier das aktuelle iob diag
          ```bash
          Script v.2026-10-01
          *** BASE SYSTEM ***
            Virtualization: lxc
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64bit
           21:53:59 up 11 min,  0 users,  load average: 1.07, 1.00, 0.62
          CPU threads     : 2
                         Local time: Tue 2026-10-20 21:53:59 CEST
                     Universal time: Tue 2026-10-20 19:53:59 UTC
                           RTC time: n/a
                    RTC in local TZ: no
          Stefan
          HOME=/home/Stefan
          iobroker
          HOME=/home/iobroker
          Desktop:
          Session:
          *** MEMORY ***
          Mem:            8.6G        4.8G        3.8G        3.8M         63M        3.8G
          Swap:             0B          0B          0B
          Total:          8.6G        4.8G        3.8G
          Active iob-Instances:   38
                   8192 M total memory
                   4533 M used memory
                   4439 M active memory
                      0 M inactive memory
                   3601 M free memory
                      0 M buffer memory
                     60 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          top - 21:54:00 up 11 min,  0 users,  load average: 1.07, 1.00, 0.62
          Tasks:  55 total,   1 running,  54 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  5.3 us, 10.5 sy,  0.0 ni, 84.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   8192.0 total,   3600.8 free,   4534.2 used,     60.4 buff/cache
          MiB Swap:      0.0 total,      0.0 free,      0.0 used.   3657.8 avail Mem
          *** FILESYSTEM ***
          rpool/data/subvol-100-disk-0 zfs        50G  2.8G   48G   6% /
          tmpfs                        tmpfs     7.8G  3.5M  7.7G   1% /tmp
          /var:
          224M    /var/
          153M    /var/cache
          151M    /var/cache/apt
          68M     /var/lib
          Archived and active journals take up 449K in the file system.
          280M    /opt/iobroker/iobroker-data/
          244M    /opt/iobroker/iobroker-data/files
          64M     /opt/iobroker/iobroker-data/files/vis
          22M     /opt/iobroker/iobroker-data/objects.jsonl
          12M     /opt/iobroker/iobroker-data/files/vis/ring/doorbell.mp4
          12M     /opt/iobroker/iobroker-data/files/vis/doorbell.mp4
          8.8M    /opt/iobroker/iobroker-data/states.jsonl
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          ioB-Slave           ioB-Slave (version: 7.2.5, hostname: ioB-Slave     , alive, uptime: 3077)
          ioB-pve             ioB-pve (version: 7.2.5, hostname: ioB-pve       , alive, uptime: 692)
          admin:          8.2.0
          javascript:     10.4.4
          Adapter State
          + system.adapter.alexa2.0                 : alexa2                : ioB-pve                                  -  enabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioB-pve                                  -  enabled
          + system.adapter.matter.0                 : matter                : ioB-pve                                  -  enabled
          + system.adapter.nina.0                   : nina                  : ioB-Slave                                -  enabled
          + system.adapter.pushover.3               : pushover              : ioB-pve                                  -  enabled
          + system.adapter.reolink.0                : reolink               : ioB-pve                                  -  enabled
          + system.adapter.tankerkoenig.0           : tankerkoenig          : ioB-Slave                                -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : ioB-Slave                                -  enabled
          + system.adapter.web.0                    : web                   : ioB-pve                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          │ 0       │ 'system.adapter.admin'                       │ 'admin'                       │ '8.2.0'  │ 'none'         │
          │ 6       │ 'system.adapter.daswetter'                   │ 'daswetter'                   │ '4.6.1'  │ 'none'         │
          │ 7       │ 'system.adapter.devices'                     │ 'devices'                     │ '4.2.2'  │ 'none'         │
          │ 20      │ 'system.adapter.ical'                        │ 'ical'                        │ '1.21.2' │ 'none'         │
          │ 27      │ 'system.adapter.javascript'                  │ 'javascript'                  │ '10.4.4' │ 'none'         │
          │ 30      │ 'system.adapter.mqtt'                        │ 'mqtt'                        │ '8.1.2'  │ 'none'         │
          │ 44      │ 'system.adapter.socketio'                    │ 'socketio'                    │ '9.0.1'  │ 'none'         │
          │ 45      │ 'system.adapter.sonoff'                      │ 'sonoff'                      │ '5.1.1'  │ 'none'         │
          │ 52      │ 'system.adapter.vis-2'                       │ 'vis-2'                       │ '2.15.8' │ 'none'         │
          Adapter    "admin"        : 8.2.0    , installed 8.2.0
          Adapter    "daswetter"    : 4.6.1    , installed 4.6.1
          Adapter    "devices"      : 4.2.2    , installed 4.2.2
          Adapter    "ical"         : 1.21.2   , installed 1.21.2
          Adapter    "javascript"   : 10.4.4   , installed 10.4.4
          Adapter    "mqtt"         : 8.1.2    , installed 8.1.2
          Adapter    "socketio"     : 9.0.1    , installed 9.0.1
          Adapter    "sonoff"       : 5.1.1    , installed 5.1.1
          Adapter    "vis-2"        : 2.15.8   , installed 2.15.8
          Adapter    "ws"           : 4.1.0    , installed 4.1.0
          Objects and States
          Objects:        32901
          States:         27461
          Hit:1 http://deb.debian.org/debian trixie InRelease
          Hit:2 http://security.debian.org trixie-security InRelease
          udp   UNCONN 0      0              0.0.0.0:mdns        0.0.0.0:*    users:(("io.matter.0",pid=1493,fd=40))
          udp   UNCONN 0      0              0.0.0.0:mdns        0.0.0.0:*    users:(("io.matter.0",pid=1493,fd=35))
          udp   UNCONN 0      0              0.0.0.0:mdns        0.0.0.0:*    users:(("io.yahka.0",pid=1348,fd=31))
          udp   UNCONN 0      0      192.168.100.125:mdns        0.0.0.0:*    users:(("io.tr-064.0",pid=1196,fd=36))
          udp   UNCONN 0      0              0.0.0.0:bootps      0.0.0.0:*    users:(("io.radar2.0",pid=1005,fd=31))
          udp   UNCONN 0      0              0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=92,fd=5),("systemd",pid=1,fd=35))
          udp   UNCONN 0      0              0.0.0.0:34624       0.0.0.0:*    users:(("io.matter.0",pid=1493,fd=38))
          udp   UNCONN 0      0                 [::]:mdns           [::]:*    users:(("io.matter.0",pid=1493,fd=41))
          udp   UNCONN 0      0                 [::]:mdns           [::]:*    users:(("io.matter.0",pid=1493,fd=36))
          udp   UNCONN 0      0                 [::]:sunrpc         [::]:*    users:(("rpcbind",pid=92,fd=7),("systemd",pid=1,fd=37))
          udp   UNCONN 0      0                 [::]:34624          [::]:*    users:(("io.matter.0",pid=1493,fd=37))
          tcp   LISTEN 0      511            0.0.0.0:9001        0.0.0.0:*    users:(("iobroker.js-con",pid=95,fd=23))
          tcp   LISTEN 0      511            0.0.0.0:9000        0.0.0.0:*    users:(("iobroker.js-con",pid=95,fd=29))
          tcp   LISTEN 0      4096           0.0.0.0:sunrpc      0.0.0.0:*    users:(("rpcbind",pid=92,fd=4),("systemd",pid=1,fd=34))
          tcp   LISTEN 0      511            0.0.0.0:1890        0.0.0.0:*    users:(("io.mqtt.0",pid=7388,fd=35))
          tcp   LISTEN 0      511    192.168.100.125:1883        0.0.0.0:*    users:(("io.sonoff.0",pid=6671,fd=36))
          tcp   LISTEN 0      100          127.0.0.1:smtp        0.0.0.0:*    users:(("master",pid=258,fd=13))
          tcp   LISTEN 0      511            0.0.0.0:38457       0.0.0.0:*    users:(("io.yahka.0",pid=1348,fd=30))
          tcp   LISTEN 0      100              [::1]:smtp           [::]:*    users:(("master",pid=258,fd=14))
          tcp   LISTEN 0      4096              [::]:sunrpc         [::]:*    users:(("rpcbind",pid=92,fd=6),("systemd",pid=1,fd=36))
          tcp   LISTEN 0      4096                 *:ssh               *:*    users:(("sshd",pid=117,fd=3),("systemd",pid=1,fd=51))
          tcp   LISTEN 0      511                  *:34624             *:*    users:(("io.matter.0",pid=1493,fd=39))
          tcp   LISTEN 0      511                  *:8082              *:*    users:(("io.web.0",pid=7048,fd=35))
          tcp   LISTEN 0      511                  *:tproxy            *:*    users:(("io.admin.0",pid=5922,fd=39))
          2026-10-20 21:53:12.112  - info: daswetter.0 (1603) terminating
          2026-10-20 21:53:12.193  - info: host.ioB-pve instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2026-10-20 21:53:13.836  - info: mqtt.0 (7388) Server: Changed type of "mqtt.0.1OG-DG_TX_Ultimate_3Ch.STATE" from "string" to "mixed"
          2026-10-20 21:53:22.728  - info: mqtt.0 (7388) Server: Changed type of "mqtt.0.EG-KE_TX_Ultimate_3Ch.STATE" from "string" to "mixed"
          2026-10-20 21:53:23.488  - info: host.ioB-pve "system.adapter.daswetter.0" enabled
          2026-10-20 21:53:23.918  - info: host.ioB-pve instance system.adapter.daswetter.0 in version "4.6.1" started with pid 8556
          2026-10-20 21:53:24.855  - info: mqtt.0 (7388) Server: Changed type of "mqtt.0.1OG-DG_TX_Ultimate_3Ch.COMMAND" from "string" to "mixed"
          2026-10-20 21:53:25.045  - info: daswetter.0 (8556) starting. Version 4.6.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v24.22.0, js-controller: 7.2.5
          2026-10-20 21:53:25.375  - error: daswetter.0 (8556) DasWetter_0: API key contains 29 invalid characters: [\ud, \ud, \u2, \u4, \u2, \u4, \u1, \u7, \u2, \u7, \u8, \u4, \u3, \u7, \u7, \u2, \u2, \u0, \u7, \u6, \u5, \u6, \ue, \u5, \u7, \u3, \ud, \u0, \u0]
          2026-10-20 21:53:25.864  - error: daswetter.0 (8556) DasWetter_0: axios error in GetLocationFreetext: message=Request failed with status code 401, code=ERR_BAD_REQUEST, status=401, data={"ok":false,"expiracion":1792526005780,"info":{"message":"Unauthorized"}}
          2026-10-20 21:53:25.949  - error: daswetter.0 (8556) DasWetter_0: no location hash available, please check postcode and city settings
          2026-10-20 21:53:25.950  - error: daswetter.0 (8556) DasWetter_0: no location hash available, please check postcode and city settings
          2026-10-20 21:53:34.569  - info: mqtt.0 (7388) Server: Changed type of "mqtt.0.EG_Flur_TX_Ultimate_1Ch.STATE" from "string" to "mixed"
          2026-10-20 21:53:45.393  - info: mqtt.0 (7388) Server: Changed type of "mqtt.0.EG_Gaeste-WC_TX_Ultimate_1Ch.STATE" from "string" to "mixed"
          2026-10-20 21:54:02.024  - debug: ring.0 (1092) Device 213497705 ("Haustür"): Received Update
          2026-10-20 21:54:02.024  - debug: ring.0 (1092) Device 384912755 ("Parkplatz"): Received Update
          2026-10-20 21:54:02.425  - debug: ring.0 (1092) Device 213497705 ("Haustür"): Update Health Callback
          2026-10-20 21:54:02.437  - debug: ring.0 (1092) Device 384912755 ("Parkplatz"): Update Health Callback
          2026-10-20 21:54:09.377  - info: sonoff.0 (6671) Object updated: sonoff.0.1OG - Deckenlampe RF/R2.SleepMode
          2026-10-20 21:54:09.507  - info: sonoff.0 (6671) Object updated: sonoff.0.1OG - Deckenlampe RF/R2.Wifi_SSId
          2026-10-20 21:54:09.603  - info: sonoff.0 (6671) Object updated: sonoff.0.1OG - Deckenlampe RF/R2.Wifi_BSSId
          2026-10-20 21:54:09.701  - info: sonoff.0 (6671) Object updated: sonoff.0.1OG - Deckenlampe RF/R2.Wifi_Channel
          2026-10-20 21:54:09.706  - info: sonoff.0 (6671) Object updated: sonoff.0.1OG - Deckenlampe RF/R2.Hostname
          2026-10-20 21:54:09.708  - info: sonoff.0 (6671) Object updated: sonoff.0.1OG - Deckenlampe RF/R2.IPAddress
          2026-10-20 21:54:11.418  - info: mqtt.0 (7388) Server: Changed type of "mqtt.0.KE-EG_2Ch_TX_Ultimate.STATE" from "string" to "mixed"
          • S
            S
            Stefan341
            schrieb am zuletzt editiert von Stefan341
            Die Vis läuft jetzt. Ich habe aber das Gefühl, dass alles sehr langsam ist.
            Bei den Adaptern die auf dem Slave sind, wird mir angezeigt, dass die Adapter dort nicht installiert sind. Bei Hosts ist der Slave aber ganz normal grün.
            Ist der Fehler in Proxmox relevant?
            client connection: 127.0.0.1:59028
            error reading from pty: Input/output error (os error 5)
            TASK ERROR: command '/usr/bin/termproxy 5900 --path /vms/100 --perm VM.Console --vncticket-endpoint --verify-port --ticket-fd 6 -- /usr/bin/dtach -A /var/run/dtach/vzctlconsole100 -r winch -z lxc-console -n 100 -e -1' failed: exit code 1
            Von der Auslastung her würde ich sagen es ist ok oder?
            Adapter können auch nicht aufgerufen werden
            • S
              S
              Stefan341
              Ich habe jetzt nochmal einen neuen Container strikt nach der Anleitung von @thomas-braun aufgesetzt, das Backup neu eingespielt und hatte erneut das Problem, dass alles nur sehr langsam lief. Da ich das Ganze im Multihost betreibe, habe ich den Host und Slave neu verbunden. Jetzt rennt das Teil :)
              Allerdings habe ich jetzt noch ein Problem: Bei allen meinen Icon-Adaptern für die Vis wird angezeigt, dass der Adapter Web geupdatet werden muss. Dieser ist allerdings auf Version 8.0.0. Kann es sein, dass irgendwo eine alte Versionsnummer steht und die anderen Adapter diese auslesen?
              -1
              • S Stefan341
                Thomas BraunT
                Thomas BraunT
                @Stefan341 sagte:
                Ja, bei Multihost müssen die Versionen auf allen hosts aktuell gehalten werden. Am besten auf den gleichen Versionsstand hieven.
                  @Stefan341 sagte:
                  S
                  S
                  Stefan341
                  @Thomas-Braun
                  Ist auf beiden Geräten aktuell. V.8.0.0
                  • S Stefan341
                    @Thomas-Braun
                    crunchipC
                    crunchipC
                    Developer Global Moderator Most Active Forum Testing
                    @Stefan341 browser reload, ggf, beide neu durchstarten
                      S
                      S
                      Stefan341
                      @crunchip
                      Auch das führte leider nicht zum Erfolg
                      • S Stefan341
                        Thomas BraunT
                        Thomas BraunT
                        @Stefan341 sagte:
                        Schau in
                        iob diag
                        rein. Ggfls auf beiden Systemen.
                          @Stefan341 sagte:
                          Schau in
                          iob diag
                          S
                          S
                          Stefan341
                          @Thomas-Braun
                          Das Problem scheint sich erledigt zu haben. Keine Ahnung warum, aber die Adapter meckern zumindest nichtmehr über die Version von web
                          Jetzt bleibt noch das Problem das ich auf dem Slave iconsets als Adapter installiert habe, die Icons in der vis aber nicht angezeigt werden und ich sie gerne auf dem Master hätte. Wenn ich in Instanzen einfach von Slave auf Master ändere, wird angezeigt das der Adapter auf dem Master nicht installiert ist. Bei „normalen“ Adaptern konnte ich das beheben indem ich den Adapter einmal unter Adapter aufgerufen habe. Dann wurde er scheinbar auf den Master kopiert. Das funktioniert bei den Icons aber nicht.
                          • EisteeE
                            EisteeE
                            Eistee
                            Faszinierend wie umständlich man doch ioBroker unter proxmox alles installieren kann.
                            Für alle die es einfacher wollen: https://community-scripts.org/scripts/iobroker
                            Gruß Alina
                            • EisteeE Eistee
                              Gruß Alina
                              CodierknechtC
                              CodierknechtC
                              Codierknecht
                              @Eistee sagte:
                              Klar kann man das auch damit machen.
                              Es soll aber auch Leute geben, die sich nicht darauf verlassen wollen, was so alles in externen Scripten steckt.
                              HmIP|ZigBee|Tasmota|Unifi
                              Zabbix Certified Specialist
                              84.2k
