Umzug von Raspi auf Proxmox
Erstmal die Ausgabe von iob diag
Vielleicht kann man daraus ja schon etwas erkennen
========== Start marking the full check here =========== ```bash Script v.2026-10-01 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: ioB-pve Icon name: computer-container Chassis: container ☐ Virtualization: lxc Kernel: Linux 7.0.14-24-pve Architecture: x86-64 OS is similar to: model name : Intel(R) Pentium(R) Gold G6500 CPU @ 4.10GHz Docker : false Virtualization : lxc Kernel : x86_64 Userland : 64bit System was installed 2 days ago (on 2026-10-18). Systemuptime and Load: 20:56:36 up 5 min, 0 users, load average: 1.56, 0.95, 0.42 CPU threads : 2 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** TIME AND TIMEZONES *** Local time: Tue 2026-10-20 20:56:36 CEST Universal time: Tue 2026-10-20 18:56:36 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: inactive RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': Stefan HOME=/home/Stefan GROUPS=Stefan sudo users iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 4.3G 3.6G 671M 3.8M 61M 729M Swap: 0B 0B 0B Total: 4.3G 3.6G 671M Active iob-Instances: 28 4096 M total memory 3400 M used memory 3305 M active memory 11 M inactive memory 639 M free memory 0 M buffer memory 58 M swap cache 0 M total swap 0 M used swap 0 M free swap *** top - Table Of Processes *** top - 20:56:37 up 5 min, 0 users, load average: 1.56, 0.95, 0.42 Tasks: 46 total, 2 running, 44 sleeping, 0 stopped, 0 zombie %Cpu(s): 47.6 us, 4.8 sy, 0.0 ni, 47.6 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 4096.0 total, 675.9 free, 3364.8 used, 58.9 buff/cache MiB Swap: 0.0 total, 0.0 free, 0.0 used. 731.2 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System Legend: LOAD -> Reflects whether the unit definition was properly loaded. ACTIVE -> The high-level unit activation state, i.e. generalization of SUB. SUB -> The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** dmesg: read kernel buffer failed: Operation not permitted No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on rpool/data/subvol-100-disk-0 zfs 50G 2.7G 48G 6% / none tmpfs 492K 4.0K 488K 1% /dev udev devtmpfs 6.8G 0 6.8G 0% /dev/tty tmpfs tmpfs 7.8G 0 7.8G 0% /dev/shm tmpfs tmpfs 3.1G 100K 3.1G 1% /run tmpfs tmpfs 7.8G 3.6M 7.7G 1% /tmp tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock Messages concerning filesystems in dmesg (Last 15 lines only): dmesg: read kernel buffer failed: Operation not permitted Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / rpool/data/subvol-100-disk-0 zfs rw,relatime,xattr,posixacl,casesensitive Files in neuralgic directories: /var: 224M /var/ 153M /var/cache 151M /var/cache/apt 98M /var/cache/apt/archives 68M /var/lib Hint: You are currently not seeing messages from other users and the system. Users in groups 'adm', 'systemd-journal' can see all messages. Pass -q to turn off this notice. Archived and active journals take up 437K in the file system. /opt/iobroker/backups: 110M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 287M /opt/iobroker/iobroker-data/ 264M /opt/iobroker/iobroker-data/files 86M /opt/iobroker/iobroker-data/files/vis 56M /opt/iobroker/iobroker-data/files/0_userdata.0 34M /opt/iobroker/iobroker-data/files/0_userdata.0/szenen The five largest files in iobroker-data are: 24M /opt/iobroker/iobroker-data/files/vis/ring/doorbell.mp4 24M /opt/iobroker/iobroker-data/files/vis/doorbell.mp4 12M /opt/iobroker/iobroker-data/objects.jsonl 8.4M /opt/iobroker/iobroker-data/files/vis/stickup.mp4 7.7M /opt/iobroker/iobroker-data/files/vis/ring/stickup.mp4 USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** ZigBee Settings *** Zigbee Network Settings on your coordinator / in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' === ZigBee Port Overview === Instance Configured Port Available by-id Port Status -------- ---------------- ---------------------------- ------ zigbee.1 tcp://192.168.50.10:6638 - tcp *** NodeJS-Installation *** /usr/bin/nodejs v24.22.0 /usr/bin/node v24.22.0 /usr/bin/npm 11.19.1 /usr/bin/npx 11.19.1 ✓ Node.js installation is correct Recommended versions are nodejs 24.22.0 and npm 11.19.1 nodejs: Installed: 24.22.0-1nodesource1 Candidate: 24.22.0-1nodesource1 Version table: *** 24.22.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 24.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.2-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 20.19.2+dfsg-1+deb13u3 500 500 http://security.debian.org trixie-security/main amd64 Packages 20.19.2+dfsg-1+deb13u2 500 500 http://deb.debian.org/debian trixie/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: ioB-Slave ioB-Slave (version: 7.2.5, hostname: ioB-Slave , alive, uptime: 77) ioB-pve ioB-pve (version: 7.2.5, hostname: ioB-pve , alive, uptime: 107) Core adapters versions js-controller: 7.2.5 admin: 8.0.14 javascript: 10.1.3 nodejs modules from github: 0 Adapter State + system.adapter.admin.0 : admin : ioB-pve - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa-timer-vis.0 : alexa-timer-vis : ioB-pve - enabled system.adapter.alexa2.0 : alexa2 : ioB-pve - enabled system.adapter.alexa2.1 : alexa2 : ioB-pve - disabled + system.adapter.backitup.0 : backitup : ioB-pve - enabled + system.adapter.backitup.1 : backitup : ioB-pve - enabled system.adapter.birthdays.0 : birthdays : ioB-Slave - enabled system.adapter.cameras.0 : cameras : ioB-Slave - disabled, port: 8200, bind: 192.168.100.125 + system.adapter.daswetter.0 : daswetter : ioB-pve - enabled system.adapter.devices.0 : devices : ioB-pve - disabled + system.adapter.discovery.0 : discovery : ioB-pve - enabled system.adapter.dwd.0 : dwd : ioB-pve - enabled + system.adapter.email.0 : email : ioB-Slave - enabled system.adapter.energiefluss.0 : energiefluss : ioB-Slave - disabled system.adapter.fb-checkpresence.0 : fb-checkpresence : ioB-pve - enabled system.adapter.feiertage.0 : feiertage : ioB-Slave - enabled + system.adapter.firetv.0 : firetv : ioB-pve - enabled system.adapter.flot.0 : flot : ioB-Slave - disabled + system.adapter.fritzbox.0 : fritzbox : ioB-pve - enabled + system.adapter.fritzdect.0 : fritzdect : ioB-pve - enabled + system.adapter.fritzdect.1 : fritzdect : ioB-pve - enabled system.adapter.heizungssteuerung.0 : heizungssteuerung : ioB-pve - disabled system.adapter.history.0 : history : ioB-Slave - disabled system.adapter.ical.0 : ical : ioB-pve - enabled system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioB-pve - disabled system.adapter.icons-icons8.0 : icons-icons8 : ioB-Slave - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : ioB-pve - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : ioB-pve - disabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : ioB-pve - disabled system.adapter.influxdb.0 : influxdb : ioB-Slave - disabled, port: 8086 + system.adapter.javascript.0 : javascript : ioB-pve - enabled system.adapter.luftdaten.0 : luftdaten : ioB-pve - enabled system.adapter.matter.0 : matter : ioB-pve - enabled + system.adapter.mqtt.0 : mqtt : ioB-pve - enabled, port: 1890, bind: 0.0.0.0 system.adapter.nina.0 : nina : ioB-Slave - enabled system.adapter.octoprint.0 : octoprint : ioB-Slave - disabled system.adapter.pi-hole.0 : pi-hole : ioB-Slave - disabled + system.adapter.pollenflug.0 : pollenflug : ioB-pve - enabled + system.adapter.pushover.0 : pushover : ioB-pve - enabled + system.adapter.pushover.1 : pushover : ioB-pve - enabled + system.adapter.pushover.2 : pushover : ioB-pve - enabled system.adapter.pushover.3 : pushover : ioB-pve - enabled + system.adapter.radar2.0 : radar2 : ioB-pve - enabled system.adapter.reolink.0 : reolink : ioB-pve - enabled + system.adapter.residents.0 : residents : ioB-Slave - enabled + system.adapter.ring.0 : ring : ioB-pve - enabled system.adapter.roborock.0 : roborock : ioB-Slave - disabled system.adapter.schoolfree.0 : schoolfree : ioB-Slave - enabled + system.adapter.sonoff.0 : sonoff : ioB-pve - enabled, port: 1883, bind: 192.168.100.125 + system.adapter.sql.0 : sql : ioB-Slave - enabled system.adapter.tankerkoenig.0 : tankerkoenig : ioB-Slave - enabled + system.adapter.tr-064.0 : tr-064 : ioB-pve - enabled + system.adapter.tr-064.1 : tr-064 : ioB-Slave - enabled system.adapter.trashschedule.0 : trashschedule : ioB-Slave - enabled system.adapter.upnp.0 : upnp : ioB-pve - disabled system.adapter.vis-2-widgets-gauges.0 : vis-2-widgets-gauges : ioB-Slave - disabled + system.adapter.vis-2.0 : vis-2 : ioB-pve - enabled system.adapter.vis-bars.0 : vis-bars : ioB-Slave - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : ioB-Slave - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : ioB-Slave - disabled system.adapter.vis-homekittiles.0 : vis-homekittiles : ioB-pve - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : ioB-Slave - disabled system.adapter.vis-icontwo.0 : vis-icontwo : ioB-Slave - disabled system.adapter.vis-inventwo.0 : vis-inventwo : ioB-Slave - disabled system.adapter.vis-justgage.0 : vis-justgage : ioB-Slave - disabled system.adapter.vis-material-advanced.0 : vis-material-advanced : ioB-Slave - disabled system.adapter.vis-metro.0 : vis-metro : ioB-Slave - disabled system.adapter.vis-players.0 : vis-players : ioB-Slave - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : ioB-Slave - disabled system.adapter.vis-weather.0 : vis-weather : ioB-Slave - disabled system.adapter.vis.0 : vis : ioB-pve - enabled system.adapter.wallpanel.0 : wallpanel : ioB-Slave - disabled system.adapter.weatherunderground.0 : weatherunderground : ioB-pve - enabled system.adapter.web.0 : web : ioB-pve - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.yahka.0 : yahka : ioB-pve - enabled + system.adapter.zigbee.0 : zigbee : ioB-Slave - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_1a043fc8e5a5ed11bc85f1a32981d5c7-if00-port0 + system.adapter.zigbee.1 : zigbee : ioB-pve - enabled, port: tcp://192.168.50.10:6638 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : ioB-pve - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.mqtt.0 : mqtt : ioB-pve - enabled, port: 1890, bind: 0.0.0.0 + system.adapter.sonoff.0 : sonoff : ioB-pve - enabled, port: 1883, bind: 192.168.100.125 system.adapter.web.0 : web : ioB-pve - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : ioB-Slave - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_1a043fc8e5a5ed11bc85f1a32981d5c7-if00-port0 + system.adapter.zigbee.1 : zigbee : ioB-pve - enabled, port: tcp://192.168.50.10:6638 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬──────────────────────────────────────────────┬───────────────────────────────┬──────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼──────────────────────────────────────────────┼───────────────────────────────┼──────────┼────────────────┤ │ 0 │ 'system.adapter.admin' │ 'admin' │ '8.0.14' │ 'none' │ │ 1 │ 'system.adapter.alexa-timer-vis' │ 'alexa-timer-vis' │ '3.0.3' │ 'none' │ │ 2 │ 'system.adapter.alexa2' │ 'alexa2' │ '3.28.3' │ 'none' │ │ 3 │ 'system.adapter.backitup' │ 'backitup' │ '4.0.3' │ 'none' │ │ 4 │ 'system.adapter.birthdays' │ 'birthdays' │ '6.1.0' │ 'none' │ │ 5 │ 'system.adapter.cameras' │ 'cameras' │ '2.1.2' │ 'none' │ │ 6 │ 'system.adapter.daswetter' │ 'daswetter' │ '4.5.9' │ 'none' │ │ 7 │ 'system.adapter.devices' │ 'devices' │ '1.2.14' │ 'none' │ │ 8 │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0' │ 'none' │ │ 9 │ 'system.adapter.dwd' │ 'dwd' │ '2.8.5' │ 'none' │ │ 10 │ 'system.adapter.email' │ 'email' │ '3.0.0' │ 'none' │ │ 11 │ 'system.adapter.energiefluss' │ 'energiefluss' │ '3.6.2' │ 'none' │ │ 12 │ 'system.adapter.fb-checkpresence' │ 'fb-checkpresence' │ '1.4.2' │ 'none' │ │ 13 │ 'system.adapter.feiertage' │ 'feiertage' │ '1.4.0' │ 'none' │ │ 14 │ 'system.adapter.firetv' │ 'firetv' │ '2.2.0' │ 'none' │ │ 15 │ 'system.adapter.flot' │ 'flot' │ '1.12.0' │ 'none' │ │ 16 │ 'system.adapter.fritzbox' │ 'fritzbox' │ '0.7.0' │ 'none' │ │ 17 │ 'system.adapter.fritzdect' │ 'fritzdect' │ '2.6.2' │ 'none' │ │ 18 │ 'system.adapter.heizungssteuerung' │ 'heizungssteuerung' │ '2.1.1' │ 'none' │ │ 19 │ 'system.adapter.history' │ 'history' │ '4.0.0' │ 'none' │ │ 20 │ 'system.adapter.ical' │ 'ical' │ '1.21.0' │ 'none' │ │ 21 │ 'system.adapter.icons-addictive-flavour-png' │ 'icons-addictive-flavour-png' │ '0.1.0' │ 'none' │ │ 22 │ 'system.adapter.icons-icons8' │ 'icons-icons8' │ '0.0.1' │ 'none' │ │ 23 │ 'system.adapter.icons-mfd-png' │ 'icons-mfd-png' │ '1.2.1' │ 'none' │ │ 24 │ 'system.adapter.icons-mfd-svg' │ 'icons-mfd-svg' │ '1.2.0' │ 'none' │ │ 25 │ 'system.adapter.icons-ultimate-png' │ 'icons-ultimate-png' │ '1.0.1' │ 'none' │ │ 26 │ 'system.adapter.influxdb' │ 'influxdb' │ '4.0.2' │ 'none' │ │ 27 │ 'system.adapter.javascript' │ 'javascript' │ '10.1.3' │ 'none' │ │ 28 │ 'system.adapter.luftdaten' │ 'luftdaten' │ '6.0.1' │ 'none' │ │ 29 │ 'system.adapter.matter' │ 'matter' │ '1.3.1' │ 'none' │ │ 30 │ 'system.adapter.mqtt' │ 'mqtt' │ '6.1.4' │ 'none' │ │ 31 │ 'system.adapter.nina' │ 'nina' │ '0.0.25' │ 'none' │ │ 32 │ 'system.adapter.octoprint' │ 'octoprint' │ '5.1.0' │ 'none' │ │ 33 │ 'system.adapter.pi-hole' │ 'pi-hole' │ '2.0.0' │ 'none' │ │ 34 │ 'system.adapter.pollenflug' │ 'pollenflug' │ '2.0.0' │ 'none' │ │ 35 │ 'system.adapter.pushover' │ 'pushover' │ '6.1.0' │ 'none' │ │ 36 │ 'system.adapter.radar2' │ 'radar2' │ '2.4.0' │ 'none' │ │ 37 │ 'system.adapter.reolink' │ 'reolink' │ '1.4.2' │ 'none' │ │ 38 │ 'system.adapter.residents' │ 'residents' │ '1.1.1' │ 'none' │ │ 39 │ 'system.adapter.ring' │ 'ring' │ '7.0.2' │ 'none' │ │ 40 │ 'system.adapter.roborock' │ 'roborock' │ '0.7.4' │ 'none' │ │ 41 │ 'system.adapter.scenes' │ 'scenes' │ '4.0.4' │ 'none' │ │ 42 │ 'system.adapter.schoolfree' │ 'schoolfree' │ '2.1.0' │ 'none' │ │ 43 │ 'system.adapter.simple-api' │ 'simple-api' │ '3.0.7' │ 'none' │ │ 44 │ 'system.adapter.socketio' │ 'socketio' │ '7.1.3' │ 'none' │ │ 45 │ 'system.adapter.sonoff' │ 'sonoff' │ '3.3.0' │ 'none' │ │ 46 │ 'system.adapter.sql' │ 'sql' │ '3.0.1' │ 'none' │ │ 47 │ 'system.adapter.tankerkoenig' │ 'tankerkoenig' │ '3.4.0' │ 'none' │ │ 48 │ 'system.adapter.tr-064' │ 'tr-064' │ '4.3.0' │ 'none' │ │ 49 │ 'system.adapter.trashschedule' │ 'trashschedule' │ '5.3.0' │ 'none' │ │ 50 │ 'system.adapter.upnp' │ 'upnp' │ '1.1.0' │ 'none' │ │ 51 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 52 │ 'system.adapter.vis-2' │ 'vis-2' │ '2.13.8' │ 'none' │ │ 53 │ 'system.adapter.vis-2-widgets-gauges' │ 'vis-2-widgets-gauges' │ '2.0.2' │ 'none' │ │ 54 │ 'system.adapter.vis-bars' │ 'vis-bars' │ '0.1.4' │ 'none' │ │ 55 │ 'system.adapter.vis-canvas-gauges' │ 'vis-canvas-gauges' │ '1.0.1' │ 'none' │ │ 56 │ 'system.adapter.vis-fancyswitch' │ 'vis-fancyswitch' │ '1.1.0' │ 'none' │ │ 57 │ 'system.adapter.vis-homekittiles' │ 'vis-homekittiles' │ '0.4.6' │ 'none' │ │ 58 │ 'system.adapter.vis-hqwidgets' │ 'vis-hqwidgets' │ '1.6.1' │ 'none' │ │ 59 │ 'system.adapter.vis-icontwo' │ 'vis-icontwo' │ '2.11.6' │ 'none' │ │ 60 │ 'system.adapter.vis-inventwo' │ 'vis-inventwo' │ '4.1.1' │ 'none' │ │ 61 │ 'system.adapter.vis-justgage' │ 'vis-justgage' │ '2.1.7' │ 'none' │ │ 62 │ 'system.adapter.vis-material-advanced' │ 'vis-material-advanced' │ '1.7.4' │ 'none' │ │ 63 │ 'system.adapter.vis-metro' │ 'vis-metro' │ '1.2.0' │ 'none' │ │ 64 │ 'system.adapter.vis-players' │ 'vis-players' │ '0.1.6' │ 'none' │ │ 65 │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2' │ 'none' │ │ 66 │ 'system.adapter.vis-weather' │ 'vis-weather' │ '2.5.13' │ 'none' │ │ 67 │ 'system.adapter.wallpanel' │ 'wallpanel' │ '0.3.11' │ 'none' │ │ 68 │ 'system.adapter.weatherunderground' │ 'weatherunderground' │ '3.7.0' │ 'none' │ │ 69 │ 'system.adapter.web' │ 'web' │ '8.0.0' │ 'none' │ │ 70 │ 'system.adapter.ws' │ 'ws' │ '4.1.0' │ 'none' │ │ 71 │ 'system.adapter.yahka' │ 'yahka' │ '1.1.6' │ 'none' │ │ 72 │ 'system.adapter.yahoo-stock-market' │ 'yahoo-stock-market' │ '0.0.7' │ 'none' │ │ 73 │ 'system.adapter.zigbee' │ 'zigbee' │ '3.5.5' │ 'none' │ └─────────┴──────────────────────────────────────────────┴───────────────────────────────┴──────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: stable Adapter "admin" : 8.2.0 , installed 8.0.14 [Updatable] Adapter "alexa-timer-vis": 3.0.3 , installed 3.0.3 Adapter "alexa2" : 3.28.3 , installed 3.28.3 Adapter "backitup" : 4.0.3 , installed 4.0.3 Adapter "daswetter" : 4.6.1 , installed 4.5.9 [Updatable] Adapter "devices" : 4.2.2 , installed 1.2.14 [Updatable] Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "firetv" : 2.2.0 , installed 2.2.0 Adapter "fritzbox" : 0.7.0 , installed 0.7.0 Adapter "fritzdect" : 2.6.2 , installed 2.6.2 Adapter "heizungssteuerung": 2.1.1, installed 2.1.1 Adapter "ical" : 1.21.2 , installed 1.21.0 [Updatable] Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "javascript" : 10.4.4 , installed 10.1.3 [Updatable] Controller "js-controller": 7.2.5 , installed 7.2.5 Adapter "luftdaten" : 6.0.1 , installed 6.0.1 Adapter "matter" : 1.3.1 , installed 1.3.1 Adapter "mqtt" : 8.1.2 , installed 6.1.4 [Updatable] Adapter "pollenflug" : 2.0.0 , installed 2.0.0 Adapter "pushover" : 6.1.0 , installed 6.1.0 Adapter "radar2" : 2.4.0 , installed 2.4.0 Adapter "reolink" : 1.4.2 , installed 1.4.2 Adapter "ring" : 7.0.2 , installed 7.0.2 Adapter "socketio" : 9.0.1 , installed 7.1.3 [Updatable] Adapter "sonoff" : 5.1.1 , installed 3.3.0 [Updatable] Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "upnp" : 1.1.0 , installed 1.1.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.15.8 , installed 2.13.8 [Updatable] Adapter "vis-homekittiles": 0.4.6 , installed 0.4.6 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "ws" : 4.1.0 , installed 3.0.19 [Updatable] Adapter "yahka" : 1.1.6 , installed 1.1.6 Adapter "zigbee" : 3.5.5 , installed 3.5.5 Objects and States Please stand by - This may take a while Objects: 36 States: 3 *** OS-Repositories and Updates *** Hit:1 http://security.debian.org trixie-security InRelease Hit:2 http://deb.debian.org/debian trixie InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 https://deb.nodesource.com/node_24.x nodistro InRelease Reading package lists... Pending systemupdates: 1 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=90,fd=5),("systemd",pid=1,fd=35)) udp UNCONN 0 0 [::]:sunrpc [::]:* users:(("rpcbind",pid=90,fd=7),("systemd",pid=1,fd=37)) tcp LISTEN 0 100 127.0.0.1:smtp 0.0.0.0:* users:(("master",pid=273,fd=13)) tcp LISTEN 0 511 0.0.0.0:9000 0.0.0.0:* users:(("iobroker.js-con",pid=4057,fd=29)) tcp LISTEN 0 511 0.0.0.0:9001 0.0.0.0:* users:(("iobroker.js-con",pid=4057,fd=23)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=90,fd=4),("systemd",pid=1,fd=34)) tcp LISTEN 0 100 [::1]:smtp [::]:* users:(("master",pid=273,fd=14)) tcp LISTEN 0 4096 *:ssh *:* users:(("sshd",pid=131,fd=3),("systemd",pid=1,fd=51)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=90,fd=6),("systemd",pid=1,fd=36)) *** Log File - Last 25 Lines *** 2026-10-20 20:58:38.148 - info: host.ioB-pve added notifications configuration of host 2026-10-20 20:58:38.638 - info: host.ioB-pve 77 instances found 2026-10-20 20:58:38.646 - info: host.ioB-pve starting 34 instances 2026-10-20 20:58:38.944 - info: host.ioB-pve Delete state "system.host.ioB-pve.versions.nodeCurrent" 2026-10-20 20:58:38.981 - info: host.ioB-pve Delete state "system.host.ioB-pve.versions.nodeNewest" 2026-10-20 20:58:38.990 - info: host.ioB-pve instance system.adapter.admin.0 in version "8.0.14" started with pid 4077 2026-10-20 20:58:39.025 - info: host.ioB-pve Delete state "system.host.ioB-pve.versions.nodeNewestNext" 2026-10-20 20:58:39.026 - info: host.ioB-pve Delete state "system.host.ioB-pve.versions.npmCurrent" 2026-10-20 20:58:39.027 - info: host.ioB-pve Delete state "system.host.ioB-pve.versions.npmNewest" 2026-10-20 20:58:39.029 - info: host.ioB-pve Delete state "system.host.ioB-pve.versions.npmNewestNext" 2026-10-20 20:58:39.030 - info: host.ioB-pve Some obsolete host states deleted. 2026-10-20 20:58:39.901 - error: admin.0 (4077) admin.0 already running 2026-10-20 20:58:39.902 - warn: admin.0 (4077) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2026-10-20 20:58:40.464 - error: host.ioB-pve instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2026-10-20 20:58:40.464 - info: host.ioB-pve Restart adapter system.adapter.admin.0 because enabled 2026-10-20 20:58:42.968 - info: host.ioB-pve instance system.adapter.javascript.0 in version "10.1.3" started with pid 4089 2026-10-20 20:58:43.744 - error: javascript.0 (4089) javascript.0 already running 2026-10-20 20:58:43.744 - warn: javascript.0 (4089) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2026-10-20 20:58:44.291 - error: host.ioB-pve instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2026-10-20 20:58:44.291 - info: host.ioB-pve Restart adapter system.adapter.javascript.0 because enabled 2026-10-20 20:58:46.971 - info: host.ioB-pve instance system.adapter.pushover.0 in version "6.1.0" started with pid 4120 2026-10-20 20:58:47.673 - error: pushover.0 (4120) pushover.0 already running 2026-10-20 20:58:47.674 - warn: pushover.0 (4120) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2026-10-20 20:58:48.222 - error: host.ioB-pve instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2026-10-20 20:58:48.222 - info: host.ioB-pve Restart adapter system.adapter.pushover.0 because enabled============= Mark until here for C&P =============
iob diag has finished.
Bring die ganzen ioBroker-Adapter auf Stand.
iob update iob upgradeUnnd dann schauen, was wann da wo passiert.
Und SWAP 0 ist bei mageren 4GB RAM auch tödlich. Gib der Kiste mehr Luft.
@Stefan341 [sagte: etwas erkennen
Du hast dem Container nur etwa 4 GB RAM zugewiesen. Das ist bei den vielen aktiven Instanzen zu wenig.
Kommt drauf an. Ich würde wohl so mindestens 2GB dafür vorsehen.
@Thomas-Braun
Ich hab alles soweit angepasst und die Adapter auf den neusten Stand gebracht.
Hier das aktuelle iob diag========== Start marking the full check here =========== ```bash Script v.2026-10-01 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: ioB-pve Icon name: computer-container Chassis: container ☐ Virtualization: lxc Kernel: Linux 7.0.14-24-pve Architecture: x86-64 OS is similar to: model name : Intel(R) Pentium(R) Gold G6500 CPU @ 4.10GHz Docker : false Virtualization : lxc Kernel : x86_64 Userland : 64bit System was installed 2 days ago (on 2026-10-18). Systemuptime and Load: 21:53:59 up 11 min, 0 users, load average: 1.07, 1.00, 0.62 CPU threads : 2 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** TIME AND TIMEZONES *** Local time: Tue 2026-10-20 21:53:59 CEST Universal time: Tue 2026-10-20 19:53:59 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: inactive RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': Stefan HOME=/home/Stefan GROUPS=Stefan sudo users iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 8.6G 4.8G 3.8G 3.8M 63M 3.8G Swap: 0B 0B 0B Total: 8.6G 4.8G 3.8G Active iob-Instances: 38 8192 M total memory 4533 M used memory 4439 M active memory 0 M inactive memory 3601 M free memory 0 M buffer memory 60 M swap cache 0 M total swap 0 M used swap 0 M free swap *** top - Table Of Processes *** top - 21:54:00 up 11 min, 0 users, load average: 1.07, 1.00, 0.62 Tasks: 55 total, 1 running, 54 sleeping, 0 stopped, 0 zombie %Cpu(s): 5.3 us, 10.5 sy, 0.0 ni, 84.2 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 8192.0 total, 3600.8 free, 4534.2 used, 60.4 buff/cache MiB Swap: 0.0 total, 0.0 free, 0.0 used. 3657.8 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System Legend: LOAD -> Reflects whether the unit definition was properly loaded. ACTIVE -> The high-level unit activation state, i.e. generalization of SUB. SUB -> The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** dmesg: read kernel buffer failed: Operation not permitted No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on rpool/data/subvol-100-disk-0 zfs 50G 2.8G 48G 6% / none tmpfs 492K 4.0K 488K 1% /dev udev devtmpfs 6.8G 0 6.8G 0% /dev/tty tmpfs tmpfs 7.8G 0 7.8G 0% /dev/shm tmpfs tmpfs 3.1G 100K 3.1G 1% /run tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 7.8G 3.5M 7.7G 1% /tmp Messages concerning filesystems in dmesg (Last 15 lines only): dmesg: read kernel buffer failed: Operation not permitted Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / rpool/data/subvol-100-disk-0 zfs rw,relatime,xattr,posixacl,casesensitive Files in neuralgic directories: /var: 224M /var/ 153M /var/cache 151M /var/cache/apt 98M /var/cache/apt/archives 68M /var/lib Hint: You are currently not seeing messages from other users and the system. Users in groups 'adm', 'systemd-journal' can see all messages. Pass -q to turn off this notice. Archived and active journals take up 449K in the file system. /opt/iobroker/backups: 110M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 280M /opt/iobroker/iobroker-data/ 244M /opt/iobroker/iobroker-data/files 64M /opt/iobroker/iobroker-data/files/vis 56M /opt/iobroker/iobroker-data/files/0_userdata.0 34M /opt/iobroker/iobroker-data/files/0_userdata.0/szenen The five largest files in iobroker-data are: 22M /opt/iobroker/iobroker-data/objects.jsonl 12M /opt/iobroker/iobroker-data/files/vis/ring/doorbell.mp4 12M /opt/iobroker/iobroker-data/files/vis/doorbell.mp4 8.8M /opt/iobroker/iobroker-data/states.jsonl 8.4M /opt/iobroker/iobroker-data/files/vis/stickup.mp4 USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** ZigBee Settings *** Zigbee Network Settings on your coordinator / in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' === ZigBee Port Overview === Instance Configured Port Available by-id Port Status -------- ---------------- ---------------------------- ------ zigbee.1 tcp://192.168.50.10:6638 - tcp *** NodeJS-Installation *** /usr/bin/nodejs v24.22.0 /usr/bin/node v24.22.0 /usr/bin/npm 11.19.1 /usr/bin/npx 11.19.1 ✓ Node.js installation is correct Recommended versions are nodejs 24.22.0 and npm 11.19.1 nodejs: Installed: 24.22.0-1nodesource1 Candidate: 24.22.0-1nodesource1 Version table: *** 24.22.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 24.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.2-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.1-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 24.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages 20.19.2+dfsg-1+deb13u3 500 500 http://security.debian.org trixie-security/main amd64 Packages 20.19.2+dfsg-1+deb13u2 500 500 http://deb.debian.org/debian trixie/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: ioB-Slave ioB-Slave (version: 7.2.5, hostname: ioB-Slave , alive, uptime: 3077) ioB-pve ioB-pve (version: 7.2.5, hostname: ioB-pve , alive, uptime: 692) Core adapters versions js-controller: 7.2.5 admin: 8.2.0 javascript: 10.4.4 nodejs modules from github: 0 Adapter State + system.adapter.admin.0 : admin : ioB-pve - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa-timer-vis.0 : alexa-timer-vis : ioB-pve - enabled + system.adapter.alexa2.0 : alexa2 : ioB-pve - enabled system.adapter.alexa2.1 : alexa2 : ioB-pve - disabled + system.adapter.backitup.0 : backitup : ioB-pve - enabled + system.adapter.backitup.1 : backitup : ioB-pve - enabled system.adapter.birthdays.0 : birthdays : ioB-Slave - enabled system.adapter.cameras.0 : cameras : ioB-Slave - disabled, port: 8200, bind: 192.168.100.125 + system.adapter.daswetter.0 : daswetter : ioB-pve - enabled system.adapter.devices.0 : devices : ioB-pve - disabled + system.adapter.discovery.0 : discovery : ioB-pve - enabled system.adapter.dwd.0 : dwd : ioB-pve - enabled + system.adapter.email.0 : email : ioB-Slave - enabled system.adapter.energiefluss.0 : energiefluss : ioB-Slave - disabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : ioB-pve - enabled system.adapter.feiertage.0 : feiertage : ioB-Slave - enabled + system.adapter.firetv.0 : firetv : ioB-pve - enabled system.adapter.flot.0 : flot : ioB-Slave - disabled + system.adapter.fritzbox.0 : fritzbox : ioB-pve - enabled + system.adapter.fritzdect.0 : fritzdect : ioB-pve - enabled + system.adapter.fritzdect.1 : fritzdect : ioB-pve - enabled system.adapter.heizungssteuerung.0 : heizungssteuerung : ioB-pve - disabled system.adapter.history.0 : history : ioB-Slave - disabled system.adapter.ical.0 : ical : ioB-pve - enabled system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioB-pve - disabled system.adapter.icons-icons8.0 : icons-icons8 : ioB-Slave - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : ioB-pve - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : ioB-pve - disabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : ioB-pve - disabled system.adapter.influxdb.0 : influxdb : ioB-Slave - disabled, port: 8086 + system.adapter.javascript.0 : javascript : ioB-pve - enabled system.adapter.luftdaten.0 : luftdaten : ioB-pve - enabled + system.adapter.matter.0 : matter : ioB-pve - enabled + system.adapter.mqtt.0 : mqtt : ioB-pve - enabled, port: 1890, bind: 0.0.0.0 + system.adapter.nina.0 : nina : ioB-Slave - enabled system.adapter.octoprint.0 : octoprint : ioB-Slave - disabled system.adapter.pi-hole.0 : pi-hole : ioB-Slave - disabled + system.adapter.pollenflug.0 : pollenflug : ioB-pve - enabled + system.adapter.pushover.0 : pushover : ioB-pve - enabled + system.adapter.pushover.1 : pushover : ioB-pve - enabled + system.adapter.pushover.2 : pushover : ioB-pve - enabled + system.adapter.pushover.3 : pushover : ioB-pve - enabled + system.adapter.radar2.0 : radar2 : ioB-pve - enabled + system.adapter.reolink.0 : reolink : ioB-pve - enabled + system.adapter.residents.0 : residents : ioB-Slave - enabled + system.adapter.ring.0 : ring : ioB-pve - enabled system.adapter.roborock.0 : roborock : ioB-Slave - disabled system.adapter.schoolfree.0 : schoolfree : ioB-Slave - enabled + system.adapter.sonoff.0 : sonoff : ioB-pve - enabled, port: 1883, bind: 192.168.100.125 + system.adapter.sql.0 : sql : ioB-Slave - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : ioB-Slave - enabled + system.adapter.tr-064.0 : tr-064 : ioB-pve - enabled + system.adapter.tr-064.1 : tr-064 : ioB-Slave - enabled + system.adapter.trashschedule.0 : trashschedule : ioB-Slave - enabled system.adapter.upnp.0 : upnp : ioB-pve - disabled system.adapter.vis-2-widgets-gauges.0 : vis-2-widgets-gauges : ioB-Slave - disabled + system.adapter.vis-2.0 : vis-2 : ioB-pve - enabled system.adapter.vis-bars.0 : vis-bars : ioB-Slave - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : ioB-Slave - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : ioB-Slave - disabled system.adapter.vis-homekittiles.0 : vis-homekittiles : ioB-pve - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : ioB-Slave - disabled system.adapter.vis-icontwo.0 : vis-icontwo : ioB-Slave - disabled system.adapter.vis-inventwo.0 : vis-inventwo : ioB-Slave - disabled system.adapter.vis-justgage.0 : vis-justgage : ioB-Slave - disabled system.adapter.vis-material-advanced.0 : vis-material-advanced : ioB-Slave - disabled system.adapter.vis-metro.0 : vis-metro : ioB-Slave - disabled system.adapter.vis-players.0 : vis-players : ioB-Slave - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : ioB-Slave - disabled system.adapter.vis-weather.0 : vis-weather : ioB-Slave - disabled system.adapter.vis.0 : vis : ioB-pve - enabled system.adapter.wallpanel.0 : wallpanel : ioB-Slave - disabled system.adapter.weatherunderground.0 : weatherunderground : ioB-pve - enabled + system.adapter.web.0 : web : ioB-pve - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.yahka.0 : yahka : ioB-pve - enabled + system.adapter.zigbee.0 : zigbee : ioB-Slave - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_1a043fc8e5a5ed11bc85f1a32981d5c7-if00-port0 + system.adapter.zigbee.1 : zigbee : ioB-pve - enabled, port: tcp://192.168.50.10:6638 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : ioB-pve - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.mqtt.0 : mqtt : ioB-pve - enabled, port: 1890, bind: 0.0.0.0 + system.adapter.sonoff.0 : sonoff : ioB-pve - enabled, port: 1883, bind: 192.168.100.125 + system.adapter.web.0 : web : ioB-pve - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : ioB-Slave - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_1a043fc8e5a5ed11bc85f1a32981d5c7-if00-port0 + system.adapter.zigbee.1 : zigbee : ioB-pve - enabled, port: tcp://192.168.50.10:6638 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬──────────────────────────────────────────────┬───────────────────────────────┬──────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼──────────────────────────────────────────────┼───────────────────────────────┼──────────┼────────────────┤ │ 0 │ 'system.adapter.admin' │ 'admin' │ '8.2.0' │ 'none' │ │ 1 │ 'system.adapter.alexa-timer-vis' │ 'alexa-timer-vis' │ '3.0.3' │ 'none' │ │ 2 │ 'system.adapter.alexa2' │ 'alexa2' │ '3.28.3' │ 'none' │ │ 3 │ 'system.adapter.backitup' │ 'backitup' │ '4.0.3' │ 'none' │ │ 4 │ 'system.adapter.birthdays' │ 'birthdays' │ '6.1.0' │ 'none' │ │ 5 │ 'system.adapter.cameras' │ 'cameras' │ '2.1.2' │ 'none' │ │ 6 │ 'system.adapter.daswetter' │ 'daswetter' │ '4.6.1' │ 'none' │ │ 7 │ 'system.adapter.devices' │ 'devices' │ '4.2.2' │ 'none' │ │ 8 │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0' │ 'none' │ │ 9 │ 'system.adapter.dwd' │ 'dwd' │ '2.8.5' │ 'none' │ │ 10 │ 'system.adapter.email' │ 'email' │ '3.0.0' │ 'none' │ │ 11 │ 'system.adapter.energiefluss' │ 'energiefluss' │ '3.6.2' │ 'none' │ │ 12 │ 'system.adapter.fb-checkpresence' │ 'fb-checkpresence' │ '1.4.2' │ 'none' │ │ 13 │ 'system.adapter.feiertage' │ 'feiertage' │ '1.4.0' │ 'none' │ │ 14 │ 'system.adapter.firetv' │ 'firetv' │ '2.2.0' │ 'none' │ │ 15 │ 'system.adapter.flot' │ 'flot' │ '1.12.0' │ 'none' │ │ 16 │ 'system.adapter.fritzbox' │ 'fritzbox' │ '0.7.0' │ 'none' │ │ 17 │ 'system.adapter.fritzdect' │ 'fritzdect' │ '2.6.2' │ 'none' │ │ 18 │ 'system.adapter.heizungssteuerung' │ 'heizungssteuerung' │ '2.1.1' │ 'none' │ │ 19 │ 'system.adapter.history' │ 'history' │ '4.0.0' │ 'none' │ │ 20 │ 'system.adapter.ical' │ 'ical' │ '1.21.2' │ 'none' │ │ 21 │ 'system.adapter.icons-addictive-flavour-png' │ 'icons-addictive-flavour-png' │ '0.1.0' │ 'none' │ │ 22 │ 'system.adapter.icons-icons8' │ 'icons-icons8' │ '0.0.1' │ 'none' │ │ 23 │ 'system.adapter.icons-mfd-png' │ 'icons-mfd-png' │ '1.2.1' │ 'none' │ │ 24 │ 'system.adapter.icons-mfd-svg' │ 'icons-mfd-svg' │ '1.2.0' │ 'none' │ │ 25 │ 'system.adapter.icons-ultimate-png' │ 'icons-ultimate-png' │ '1.0.1' │ 'none' │ │ 26 │ 'system.adapter.influxdb' │ 'influxdb' │ '4.0.2' │ 'none' │ │ 27 │ 'system.adapter.javascript' │ 'javascript' │ '10.4.4' │ 'none' │ │ 28 │ 'system.adapter.luftdaten' │ 'luftdaten' │ '6.0.1' │ 'none' │ │ 29 │ 'system.adapter.matter' │ 'matter' │ '1.3.1' │ 'none' │ │ 30 │ 'system.adapter.mqtt' │ 'mqtt' │ '8.1.2' │ 'none' │ │ 31 │ 'system.adapter.nina' │ 'nina' │ '0.0.25' │ 'none' │ │ 32 │ 'system.adapter.octoprint' │ 'octoprint' │ '5.1.0' │ 'none' │ │ 33 │ 'system.adapter.pi-hole' │ 'pi-hole' │ '2.0.0' │ 'none' │ │ 34 │ 'system.adapter.pollenflug' │ 'pollenflug' │ '2.0.0' │ 'none' │ │ 35 │ 'system.adapter.pushover' │ 'pushover' │ '6.1.0' │ 'none' │ │ 36 │ 'system.adapter.radar2' │ 'radar2' │ '2.4.0' │ 'none' │ │ 37 │ 'system.adapter.reolink' │ 'reolink' │ '1.4.2' │ 'none' │ │ 38 │ 'system.adapter.residents' │ 'residents' │ '1.1.1' │ 'none' │ │ 39 │ 'system.adapter.ring' │ 'ring' │ '7.0.2' │ 'none' │ │ 40 │ 'system.adapter.roborock' │ 'roborock' │ '0.7.4' │ 'none' │ │ 41 │ 'system.adapter.scenes' │ 'scenes' │ '4.0.4' │ 'none' │ │ 42 │ 'system.adapter.schoolfree' │ 'schoolfree' │ '2.1.0' │ 'none' │ │ 43 │ 'system.adapter.simple-api' │ 'simple-api' │ '3.0.7' │ 'none' │ │ 44 │ 'system.adapter.socketio' │ 'socketio' │ '9.0.1' │ 'none' │ │ 45 │ 'system.adapter.sonoff' │ 'sonoff' │ '5.1.1' │ 'none' │ │ 46 │ 'system.adapter.sql' │ 'sql' │ '3.0.1' │ 'none' │ │ 47 │ 'system.adapter.tankerkoenig' │ 'tankerkoenig' │ '3.4.0' │ 'none' │ │ 48 │ 'system.adapter.tr-064' │ 'tr-064' │ '4.3.0' │ 'none' │ │ 49 │ 'system.adapter.trashschedule' │ 'trashschedule' │ '5.3.0' │ 'none' │ │ 50 │ 'system.adapter.upnp' │ 'upnp' │ '1.1.0' │ 'none' │ │ 51 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 52 │ 'system.adapter.vis-2' │ 'vis-2' │ '2.15.8' │ 'none' │ │ 53 │ 'system.adapter.vis-2-widgets-gauges' │ 'vis-2-widgets-gauges' │ '2.0.2' │ 'none' │ │ 54 │ 'system.adapter.vis-bars' │ 'vis-bars' │ '0.1.4' │ 'none' │ │ 55 │ 'system.adapter.vis-canvas-gauges' │ 'vis-canvas-gauges' │ '1.0.1' │ 'none' │ │ 56 │ 'system.adapter.vis-fancyswitch' │ 'vis-fancyswitch' │ '1.1.0' │ 'none' │ │ 57 │ 'system.adapter.vis-homekittiles' │ 'vis-homekittiles' │ '0.4.6' │ 'none' │ │ 58 │ 'system.adapter.vis-hqwidgets' │ 'vis-hqwidgets' │ '1.6.1' │ 'none' │ │ 59 │ 'system.adapter.vis-icontwo' │ 'vis-icontwo' │ '2.11.6' │ 'none' │ │ 60 │ 'system.adapter.vis-inventwo' │ 'vis-inventwo' │ '4.1.1' │ 'none' │ │ 61 │ 'system.adapter.vis-justgage' │ 'vis-justgage' │ '2.1.7' │ 'none' │ │ 62 │ 'system.adapter.vis-material-advanced' │ 'vis-material-advanced' │ '1.7.4' │ 'none' │ │ 63 │ 'system.adapter.vis-metro' │ 'vis-metro' │ '1.2.0' │ 'none' │ │ 64 │ 'system.adapter.vis-players' │ 'vis-players' │ '0.1.6' │ 'none' │ │ 65 │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2' │ 'none' │ │ 66 │ 'system.adapter.vis-weather' │ 'vis-weather' │ '2.5.13' │ 'none' │ │ 67 │ 'system.adapter.wallpanel' │ 'wallpanel' │ '0.3.11' │ 'none' │ │ 68 │ 'system.adapter.weatherunderground' │ 'weatherunderground' │ '3.7.0' │ 'none' │ │ 69 │ 'system.adapter.web' │ 'web' │ '8.0.0' │ 'none' │ │ 70 │ 'system.adapter.ws' │ 'ws' │ '4.1.0' │ 'none' │ │ 71 │ 'system.adapter.yahka' │ 'yahka' │ '1.1.6' │ 'none' │ │ 72 │ 'system.adapter.yahoo-stock-market' │ 'yahoo-stock-market' │ '0.0.7' │ 'none' │ │ 73 │ 'system.adapter.zigbee' │ 'zigbee' │ '3.5.5' │ 'none' │ └─────────┴──────────────────────────────────────────────┴───────────────────────────────┴──────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: stable Adapter "admin" : 8.2.0 , installed 8.2.0 Adapter "alexa-timer-vis": 3.0.3 , installed 3.0.3 Adapter "alexa2" : 3.28.3 , installed 3.28.3 Adapter "backitup" : 4.0.3 , installed 4.0.3 Adapter "daswetter" : 4.6.1 , installed 4.6.1 Adapter "devices" : 4.2.2 , installed 4.2.2 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "firetv" : 2.2.0 , installed 2.2.0 Adapter "fritzbox" : 0.7.0 , installed 0.7.0 Adapter "fritzdect" : 2.6.2 , installed 2.6.2 Adapter "heizungssteuerung": 2.1.1, installed 2.1.1 Adapter "ical" : 1.21.2 , installed 1.21.2 Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "javascript" : 10.4.4 , installed 10.4.4 Controller "js-controller": 7.2.5 , installed 7.2.5 Adapter "luftdaten" : 6.0.1 , installed 6.0.1 Adapter "matter" : 1.3.1 , installed 1.3.1 Adapter "mqtt" : 8.1.2 , installed 8.1.2 Adapter "pollenflug" : 2.0.0 , installed 2.0.0 Adapter "pushover" : 6.1.0 , installed 6.1.0 Adapter "radar2" : 2.4.0 , installed 2.4.0 Adapter "reolink" : 1.4.2 , installed 1.4.2 Adapter "ring" : 7.0.2 , installed 7.0.2 Adapter "socketio" : 9.0.1 , installed 9.0.1 Adapter "sonoff" : 5.1.1 , installed 5.1.1 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "upnp" : 1.1.0 , installed 1.1.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.15.8 , installed 2.15.8 Adapter "vis-homekittiles": 0.4.6 , installed 0.4.6 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "ws" : 4.1.0 , installed 4.1.0 Adapter "yahka" : 1.1.6 , installed 1.1.6 Adapter "zigbee" : 3.5.5 , installed 3.5.5 Objects and States Please stand by - This may take a while Objects: 32901 States: 27461 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://security.debian.org trixie-security InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 https://deb.nodesource.com/node_24.x nodistro InRelease Reading package lists... Pending systemupdates: 1 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.matter.0",pid=1493,fd=40)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.matter.0",pid=1493,fd=35)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("io.yahka.0",pid=1348,fd=31)) udp UNCONN 0 0 192.168.100.125:mdns 0.0.0.0:* users:(("io.tr-064.0",pid=1196,fd=36)) udp UNCONN 0 0 0.0.0.0:bootps 0.0.0.0:* users:(("io.radar2.0",pid=1005,fd=31)) udp UNCONN 0 0 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=92,fd=5),("systemd",pid=1,fd=35)) udp UNCONN 0 0 0.0.0.0:34624 0.0.0.0:* users:(("io.matter.0",pid=1493,fd=38)) udp UNCONN 0 0 [::]:mdns [::]:* users:(("io.matter.0",pid=1493,fd=41)) udp UNCONN 0 0 [::]:mdns [::]:* users:(("io.matter.0",pid=1493,fd=36)) udp UNCONN 0 0 [::]:sunrpc [::]:* users:(("rpcbind",pid=92,fd=7),("systemd",pid=1,fd=37)) udp UNCONN 0 0 [::]:34624 [::]:* users:(("io.matter.0",pid=1493,fd=37)) tcp LISTEN 0 511 0.0.0.0:9001 0.0.0.0:* users:(("iobroker.js-con",pid=95,fd=23)) tcp LISTEN 0 511 0.0.0.0:9000 0.0.0.0:* users:(("iobroker.js-con",pid=95,fd=29)) tcp LISTEN 0 4096 0.0.0.0:sunrpc 0.0.0.0:* users:(("rpcbind",pid=92,fd=4),("systemd",pid=1,fd=34)) tcp LISTEN 0 511 0.0.0.0:1890 0.0.0.0:* users:(("io.mqtt.0",pid=7388,fd=35)) tcp LISTEN 0 511 192.168.100.125:1883 0.0.0.0:* users:(("io.sonoff.0",pid=6671,fd=36)) tcp LISTEN 0 100 127.0.0.1:smtp 0.0.0.0:* users:(("master",pid=258,fd=13)) tcp LISTEN 0 511 0.0.0.0:38457 0.0.0.0:* users:(("io.yahka.0",pid=1348,fd=30)) tcp LISTEN 0 100 [::1]:smtp [::]:* users:(("master",pid=258,fd=14)) tcp LISTEN 0 4096 [::]:sunrpc [::]:* users:(("rpcbind",pid=92,fd=6),("systemd",pid=1,fd=36)) tcp LISTEN 0 4096 *:ssh *:* users:(("sshd",pid=117,fd=3),("systemd",pid=1,fd=51)) tcp LISTEN 0 511 *:34624 *:* users:(("io.matter.0",pid=1493,fd=39)) tcp LISTEN 0 511 *:8082 *:* users:(("io.web.0",pid=7048,fd=35)) tcp LISTEN 0 511 *:tproxy *:* users:(("io.admin.0",pid=5922,fd=39)) *** Log File - Last 25 Lines *** 2026-10-20 21:53:12.112 - info: daswetter.0 (1603) terminating 2026-10-20 21:53:12.193 - info: host.ioB-pve instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2026-10-20 21:53:13.836 - info: mqtt.0 (7388) Server: Changed type of "mqtt.0.1OG-DG_TX_Ultimate_3Ch.STATE" from "string" to "mixed" 2026-10-20 21:53:22.728 - info: mqtt.0 (7388) Server: Changed type of "mqtt.0.EG-KE_TX_Ultimate_3Ch.STATE" from "string" to "mixed" 2026-10-20 21:53:23.488 - info: host.ioB-pve "system.adapter.daswetter.0" enabled 2026-10-20 21:53:23.918 - info: host.ioB-pve instance system.adapter.daswetter.0 in version "4.6.1" started with pid 8556 2026-10-20 21:53:24.855 - info: mqtt.0 (7388) Server: Changed type of "mqtt.0.1OG-DG_TX_Ultimate_3Ch.COMMAND" from "string" to "mixed" 2026-10-20 21:53:25.045 - info: daswetter.0 (8556) starting. Version 4.6.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v24.22.0, js-controller: 7.2.5 2026-10-20 21:53:25.375 - error: daswetter.0 (8556) DasWetter_0: API key contains 29 invalid characters: [\ud, \ud, \u2, \u4, \u2, \u4, \u1, \u7, \u2, \u7, \u8, \u4, \u3, \u7, \u7, \u2, \u2, \u0, \u7, \u6, \u5, \u6, \ue, \u5, \u7, \u3, \ud, \u0, \u0] 2026-10-20 21:53:25.864 - error: daswetter.0 (8556) DasWetter_0: axios error in GetLocationFreetext: message=Request failed with status code 401, code=ERR_BAD_REQUEST, status=401, data={"ok":false,"expiracion":1792526005780,"info":{"message":"Unauthorized"}} 2026-10-20 21:53:25.949 - error: daswetter.0 (8556) DasWetter_0: no location hash available, please check postcode and city settings 2026-10-20 21:53:25.950 - error: daswetter.0 (8556) DasWetter_0: no location hash available, please check postcode and city settings 2026-10-20 21:53:34.569 - info: mqtt.0 (7388) Server: Changed type of "mqtt.0.EG_Flur_TX_Ultimate_1Ch.STATE" from "string" to "mixed" 2026-10-20 21:53:45.393 - info: mqtt.0 (7388) Server: Changed type of "mqtt.0.EG_Gaeste-WC_TX_Ultimate_1Ch.STATE" from "string" to "mixed" 2026-10-20 21:54:02.024 - debug: ring.0 (1092) Device 213497705 ("Haustür"): Received Update 2026-10-20 21:54:02.024 - debug: ring.0 (1092) Device 384912755 ("Parkplatz"): Received Update 2026-10-20 21:54:02.425 - debug: ring.0 (1092) Device 213497705 ("Haustür"): Update Health Callback 2026-10-20 21:54:02.437 - debug: ring.0 (1092) Device 384912755 ("Parkplatz"): Update Health Callback 2026-10-20 21:54:09.377 - info: sonoff.0 (6671) Object updated: sonoff.0.1OG - Deckenlampe RF/R2.SleepMode 2026-10-20 21:54:09.507 - info: sonoff.0 (6671) Object updated: sonoff.0.1OG - Deckenlampe RF/R2.Wifi_SSId 2026-10-20 21:54:09.603 - info: sonoff.0 (6671) Object updated: sonoff.0.1OG - Deckenlampe RF/R2.Wifi_BSSId 2026-10-20 21:54:09.701 - info: sonoff.0 (6671) Object updated: sonoff.0.1OG - Deckenlampe RF/R2.Wifi_Channel 2026-10-20 21:54:09.706 - info: sonoff.0 (6671) Object updated: sonoff.0.1OG - Deckenlampe RF/R2.Hostname 2026-10-20 21:54:09.708 - info: sonoff.0 (6671) Object updated: sonoff.0.1OG - Deckenlampe RF/R2.IPAddress 2026-10-20 21:54:11.418 - info: mqtt.0 (7388) Server: Changed type of "mqtt.0.KE-EG_2Ch_TX_Ultimate.STATE" from "string" to "mixed"============= Mark until here for C&P =============
Die Vis läuft jetzt. Ich habe aber das Gefühl, dass alles sehr langsam ist.
Bei den Adaptern die auf dem Slave sind, wird mir angezeigt, dass die Adapter dort nicht installiert sind. Bei Hosts ist der Slave aber ganz normal grün.
Ist der Fehler in Proxmox relevant?
client connection: 127.0.0.1:59028 error reading from pty: Input/output error (os error 5) TASK ERROR: command '/usr/bin/termproxy 5900 --path /vms/100 --perm VM.Console --vncticket-endpoint --verify-port --ticket-fd 6 -- /usr/bin/dtach -A /var/run/dtach/vzctlconsole100 -r winch -z lxc-console -n 100 -e -1' failed: exit code 1Von der Auslastung her würde ich sagen es ist ok oder?
Adapter können auch nicht aufgerufen werden
Ich habe jetzt nochmal einen neuen Container strikt nach der Anleitung von @thomas-braun aufgesetzt, das Backup neu eingespielt und hatte erneut das Problem, dass alles nur sehr langsam lief. Da ich das Ganze im Multihost betreibe, habe ich den Host und Slave neu verbunden. Jetzt rennt das Teil :)
Allerdings habe ich jetzt noch ein Problem: Bei allen meinen Icon-Adaptern für die Vis wird angezeigt, dass der Adapter Web geupdatet werden muss. Dieser ist allerdings auf Version 8.0.0. Kann es sein, dass irgendwo eine alte Versionsnummer steht und die anderen Adapter diese auslesen?
Ja, bei Multihost müssen die Versionen auf allen hosts aktuell gehalten werden. Am besten auf den gleichen Versionsstand hieven.
@Thomas-Braun
Ist auf beiden Geräten aktuell. V.8.0.0 -
@Thomas-Braun
Ist auf beiden Geräten aktuell. V.8.0.0@Stefan341 browser reload, ggf, beide neu durchstarten
Schau in
iob diagrein. Ggfls auf beiden Systemen.
Schau in
@Thomas-Braun
Das Problem scheint sich erledigt zu haben. Keine Ahnung warum, aber die Adapter meckern zumindest nichtmehr über die Version von webJetzt bleibt noch das Problem das ich auf dem Slave iconsets als Adapter installiert habe, die Icons in der vis aber nicht angezeigt werden und ich sie gerne auf dem Master hätte. Wenn ich in Instanzen einfach von Slave auf Master ändere, wird angezeigt das der Adapter auf dem Master nicht installiert ist. Bei „normalen“ Adaptern konnte ich das beheben indem ich den Adapter einmal unter Adapter aufgerufen habe. Dann wurde er scheinbar auf den Master kopiert. Das funktioniert bei den Icons aber nicht.
Faszinierend wie umständlich man doch ioBroker unter proxmox alles installieren kann.
Für alle die es einfacher wollen: https://community-scripts.org/scripts/iobrokerGruß Alina
