  3. Off Topic
  4. Pflege des Betriebssystems
  5. Update Konsolen Pflege
    1.7k
    1.5k
Geplant Angeheftet Gesperrt Verschoben Ungelöst Pflege des Betriebssystems
42 Beiträge 4 Kommentatoren 655 Aufrufe 3 Beobachtet
  • J jwedenig
    so schauts aus zur Zeit
    Thomas BraunT
    Thomas BraunT
    @jwedenig
    Gib mal die vollständige Ausgabe von
    iob diag
    zum Besten. Da sieht man mehr.
    • J
      J
      jwedenig
      *** iob diag is starting up, please wait ***
      iob diag needs to be updated. Please execute 'iobroker fix' first.
      • J jwedenig
        Thomas BraunT
        Thomas BraunT
        @jwedenig sagte:
        Tjoar... Mach das mal. Kann aber sein, dass es nicht mehr funktioniert, weil deine Paketquellen nicht mehr aktuell sind...
        • J
          J
          jwedenig
          ```bash
          Script v.2026-08-30
          *** BASE SYSTEM ***
          Operating System: Debian GNU/Linux 11 (bullseye)
             Static hostname: raspberrypi
                   Icon name: computer
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          OS is similar to:
          Model		: Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Unknown
          Kernel          : aarch64
          Userland        : 64bit
          System was installed 1221 days ago (on 2023-05-03).
          Systemuptime and Load:
           17:00:15 up 36 min,  1 user,  load average: 1.37, 1.16, 1.19
          CPU threads     : 4
          *** LIFE CYCLE STATUS ***
          Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          ~ Under-voltage has occurred
          ~ Arm frequency capping has occurred
          ~ Throttling has occurred
          ~ Soft temperature limit has occurred
          *** TIME AND TIMEZONES ***
                         Local time: Sat 2026-09-05 17:00:15 CEST
                     Universal time: Sat 2026-09-05 15:00:15 UTC
                           RTC time: n/a
                          Time zone: Europe/Vienna (CEST, +0200)
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          js-controller is not running
          *** DISPLAY-SERVER SETUP ***
          Display-Server:		Unknown
          Display-Manager: 	Not found
          Desktop:
          Session:		tty
          Boot Target: 		multi-user.target
          *** MEMORY ***
          Mem:            7.8G        112M        6.5G        1.0M        1.2G        7.6G
          Swap:            99M          0B         99M
          Total:          7.9G        112M        6.6G
          Active iob-Instances: 	1
                   7811 M total memory
                    112 M used memory
                    333 M active memory
                    687 M inactive memory
                   6472 M free memory
                    167 M buffer memory
                   1059 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          top - 17:00:15 up 36 min,  1 user,  load average: 1.37, 1.16, 1.19
          Tasks: 197 total,   1 running, 196 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  1.4 us,  2.9 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   7811.3 total,   6471.7 free,    112.1 used,   1227.5 buff/cache
          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   7576.4 avail Mem
          *** FAILED SERVICES ***
            UNIT             LOAD   ACTIVE SUB    DESCRIPTION
          * iobroker.service loaded failed failed ioBroker Server
          1 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          /dev/root      ext4       29G   14G   15G  48% /
          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
          /dev/sda1      vfat      255M   33M  223M  13% /boot
          tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
          Messages concerning filesystems in dmesg (Last 15 lines only):
          [Sat Sep  5 16:23:50 2026] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Sat Sep  5 16:23:50 2026] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Sat Sep  5 16:23:51 2026] EXT4-fs (sda2): re-mounted. Quota mode: none.
          Show mounted filesystems:
          TARGET  SOURCE    FSTYPE OPTIONS
          /       /dev/sda2 ext4   rw,noatime
          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          1.7G	/var/
          1.4G	/var/log
          1.3G	/var/log/journal/1598db5f087d4d8687cc062072e44690
          155M	/var/lib
          Archived and active journals take up 1.2G in the file system.
          /opt/iobroker/backups:
          1.3G	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          2.8G	/opt/iobroker/iobroker-data/
          2.3G	/opt/iobroker/iobroker-data/history
          285M	/opt/iobroker/iobroker-data/files
          195M	/opt/iobroker/iobroker-data/backup-objects
          61M	/opt/iobroker/iobroker-data/files/vis
          32M	/opt/iobroker/iobroker-data/objects.jsonl
          7.9M	/opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json
          7.2M	/opt/iobroker/iobroker-data/states.jsonl
          7.1M	/opt/iobroker/iobroker-data/backup-objects/2026-09-05_15-37_objects.jsonl.gz
          7.0M	/opt/iobroker/iobroker-data/files/vis/widgets/echarts/static/js/vendors-node_modules_mui_icons-material_esm_index_js.bfab266f.chunk.js.map
          USB-Devices by-id:
          USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
          please always prefer the links 'by-id':
          /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
          *** ZigBee Settings ***
          Zigbee Network Settings on your coordinator / in nvbackup are:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          • J jwedenig
            ```bash
            Script v.2026-08-30
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            OS is similar to:
            Docker          : false
            Unknown
            Kernel          : aarch64
            Userland        : 64bit
            CPU threads     : 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            Desktop:
            Session:		tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     7811 M total memory
                      112 M used memory
                      333 M active memory
                     6472 M free memory
                      167 M buffer memory
                     1059 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            *** FILESYSTEM ***
            /var:
            1.7G	/var/
            1.4G	/var/log
            155M	/var/lib
            USB-Devices by-id:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            Thomas BraunT
            Thomas BraunT
            @jwedenig
            True... Musst du JETZT machen. Hätte schon vor geraumer Zeit passieren müssen.
            Check die Stronversorgung.
            pi
            Verwende im neuen System einen anderen username, also weder 'pi' noch 'iobroker'. Haste keinen schönen Vornamen?
            Die Ausgabe ist aber unvollständig.
            • J
              J
              jwedenig
              ```bash
              Script v.2026-08-30
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
              OS is similar to:
              Docker          : false
              Unknown
              Kernel          : aarch64
              Userland        : 64bit
              CPU threads     : 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              Desktop:
              Session:		tty
              *** MEMORY ***
              Swap:            99M          0B         99M
                       7811 M total memory
                        112 M used memory
                        333 M active memory
                       6472 M free memory
                        167 M buffer memory
                       1059 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              *** FILESYSTEM ***
              /var:
              1.7G	/var/
              1.4G	/var/log
              155M	/var/lib
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              === ZigBee Port Overview ===
              Instance        Configured Port                     Available by-id Port                Status
              zigbee.0        ...ngle_Plus_0001-if00-port0        ...ngle_Plus_0001-if00-port0        ✓ Matching
              *** NodeJS-Installation ***
              /usr/bin/nodejs		v22.23.2
              /usr/bin/node		v22.23.2
              /usr/bin/npm		10.9.8
              /usr/bin/npx		10.9.8
              ✓ Node.js installation is correct
              nodejs:
                Installed: 22.23.2-1nodesource1
                Candidate: 22.23.2-1nodesource1
                Version table:
               *** 22.23.2-1nodesource1 600
                      500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                   22.23.1-1nodesource1 600
                   22.23.0-1nodesource1 600
                   22.22.3-1nodesource1 600
                   22.22.2-1nodesource1 600
                   22.22.1-1nodesource1 600
                   22.22.0-1nodesource1 600
                   22.21.0-1nodesource1 600
                   22.20.0-1nodesource1 600
                   22.19.0-1nodesource1 600
                   22.18.0-1nodesource1 600
                   22.17.1-1nodesource1 600
                   22.17.0-1nodesource1 600
                   22.16.0-1nodesource1 600
                   22.15.1-1nodesource1 600
                   22.15.0-1nodesource1 600
                   22.14.0-1nodesource1 600
                   22.13.1-1nodesource1 600
                   22.13.0-1nodesource1 600
                   22.12.0-1nodesource1 600
                   22.11.0-1nodesource1 600
                   22.10.0-1nodesource1 600
                   22.9.0-1nodesource1 600
                   22.8.0-1nodesource1 600
                   22.7.0-1nodesource1 600
                   22.6.0-1nodesource1 600
                   22.5.1-1nodesource1 600
                   22.5.0-1nodesource1 600
                   22.4.1-1nodesource1 600
                   22.4.0-1nodesource1 600
                   22.3.0-1nodesource1 600
                   22.2.0-1nodesource1 600
                   22.1.0-1nodesource1 600
                   22.0.0-1nodesource1 600
                   12.22.12~dfsg-1~deb11u8 500
                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
              No problems detected
              Errors in npm tree: 0
              No known Vulnerabilities detected!
              *** ioBroker-Installation ***
              ioBroker Status
              iobroker is not running on this host.
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              raspberrypi         raspberrypi (version: 7.2.2, hostname: raspberrypi   , alive, uptime: 1990)
              Core adapters versions
              js-controller: 	7.2.2
              admin: 		8.0.11
              javascript: 	10.1.3
              nodejs modules from github: 	9
              +-- iobroker.fusionsolar@1.2.4 (git+ssh://git@github.com/KornSW/ioBroker.fusionsolar.git#50f776fd8f991d0832be3d660de7a38a4763093d)
              +-- iobroker.huum-sauna@0.5.0 (git+ssh://git@github.com/Chris-656/ioBroker.huum-sauna.git#29839546d990296fa85845e0dca5060f2be698ed)
              +-- iobroker.onkyo@2.1.2 (git+ssh://git@github.com/ioBroker/ioBroker.onkyo.git#c2d620441c632840b9125f08ecd7c5ef06482ead)
              +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#056daf7c0911a454ee3f4a0f7f3b329cf70222c2)
              +-- iobroker.switchbot-cloud@0.1.0 (git+ssh://git@github.com/kaschtn/ioBroker.switchbot-cloud.git#35cd79211d153fcbfc492f19d4a38e422b575257)
              +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/arteck/ioBroker.switchbot-hub.git#666f01f7e8b49322d68d63360322a9f11169911a)
              +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
              +-- iobroker.vw-connect@0.9.4 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#4321b81482d5d8ce71ce9cf87fe597a069f26852)
              `-- wake_on_lan@1.0.0 (git+ssh://git@github.com/agnat/node_wake_on_lan.git#dd6404623ccf4bc55b0ba8788ba38312b55435a1)
              Adapter State
                system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
                system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
                system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
                system.adapter.energiefluss.1           : energiefluss          : raspberrypi                              -  enabled
                system.adapter.evcc.0                   : evcc                  : raspberrypi                              - disabled, port: 7070
                system.adapter.fahrplan.0               : fahrplan              : raspberrypi                              - disabled
                system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
                system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                system.adapter.fusionsolar.0            : fusionsolar           : raspberrypi                              -  enabled
                system.adapter.go-e.0                   : go-e                  : raspberrypi                              -  enabled
                system.adapter.heos.0                   : heos                  : raspberrypi                              -  enabled
                system.adapter.history.0                : history               : raspberrypi                              -  enabled
                system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              - disabled, port: 0
                system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
                system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 80
                system.adapter.huum-sauna.0             : huum-sauna            : raspberrypi                              - disabled
                system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                system.adapter.javascript.1             : javascript            : raspberrypi                              -  enabled
                system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
                system.adapter.linktap.0                : linktap               : raspberrypi                              -  enabled
                system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
                system.adapter.onkyo.0                  : onkyo                 : raspberrypi                              -  enabled
                system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
                system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
                system.adapter.rest-api.0               : rest-api              : raspberrypi                              -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
                system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled
                system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
                system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
                system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
                system.adapter.switchbot-cloud.0        : switchbot-cloud       : raspberrypi                              - disabled
                system.adapter.switchbot-hub.0          : switchbot-hub         : raspberrypi                              -  enabled
                system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 192.168.1.41, run as: admin
                system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                system.adapter.trashschedule.1          : trashschedule         : raspberrypi                              -  enabled
                system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
                system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Upgrade policy: none
              Installed ioBroker-Adapters
              │ (index) │ id                                  │ name                 │ version          │ upgrade policy │
              │ 0       │ 'system.adapter.admin'              │ 'admin'              │ '8.0.11'         │ 'none'         │
              │ 1       │ 'system.adapter.alexa2'             │ 'alexa2'             │ '3.28.3'         │ 'none'         │
              │ 2       │ 'system.adapter.backitup'           │ 'backitup'           │ '4.0.3'          │ 'none'         │
              │ 3       │ 'system.adapter.birthdays'          │ 'birthdays'          │ '6.1.0'          │ 'none'         │
              │ 4       │ 'system.adapter.denon'              │ 'denon'              │ '1.15.12'        │ 'none'         │
              │ 5       │ 'system.adapter.devices'            │ 'devices'            │ '1.2.14'         │ 'none'         │
              │ 6       │ 'system.adapter.discovery'          │ 'discovery'          │ '5.0.0'          │ 'none'         │
              │ 7       │ 'system.adapter.echarts'            │ 'echarts'            │ '3.1.0'          │ 'none'         │
              │ 8       │ 'system.adapter.energiefluss'       │ 'energiefluss'       │ '3.6.2'          │ 'none'         │
              │ 9       │ 'system.adapter.evcc'               │ 'evcc'               │ '0.2.4'          │ 'none'         │
              │ 10      │ 'system.adapter.fahrplan'           │ 'fahrplan'           │ '1.4.1'          │ 'none'         │
              │ 11      │ 'system.adapter.fb-checkpresence'   │ 'fb-checkpresence'   │ '1.4.2'          │ 'none'         │
              │ 12      │ 'system.adapter.flot'               │ 'flot'               │ '1.12.0'         │ 'none'         │
              │ 13      │ 'system.adapter.fullybrowser'       │ 'fullybrowser'       │ '3.1.2'          │ 'none'         │
              │ 14      │ 'system.adapter.fusionsolar'        │ 'fusionsolar'        │ '1.2.4'          │ 'none'         │
              │ 15      │ 'system.adapter.go-e'               │ 'go-e'               │ '1.0.41'         │ 'none'         │
              │ 16      │ 'system.adapter.heos'               │ 'heos'               │ '3.0.4'          │ 'none'         │
              │ 17      │ 'system.adapter.history'            │ 'history'            │ '4.0.0'          │ 'none'         │
              │ 18      │ 'system.adapter.hm-rega'            │ 'hm-rega'            │ '5.1.0'          │ 'none'         │
              │ 19      │ 'system.adapter.hm-rpc'             │ 'hm-rpc'             │ '3.0.1'          │ 'none'         │
              │ 20      │ 'system.adapter.homeconnect'        │ 'homeconnect'        │ '1.6.1'          │ 'none'         │
              │ 21      │ 'system.adapter.hue'                │ 'hue'                │ '3.16.2'         │ 'none'         │
              │ 22      │ 'system.adapter.huum-sauna'         │ 'huum-sauna'         │ '0.5.0'          │ 'none'         │
              │ 23      │ 'system.adapter.ical'               │ 'ical'               │ '1.21.0'         │ 'none'         │
              │ 24      │ 'system.adapter.icons-icons8'       │ 'icons-icons8'       │ '0.0.1'          │ 'none'         │
              │ 25      │ 'system.adapter.icons-mfd-svg'      │ 'icons-mfd-svg'      │ '1.2.0'          │ 'none'         │
              │ 26      │ 'system.adapter.info'               │ 'info'               │ '2.0.0'          │ 'none'         │
              │ 27      │ 'system.adapter.iot'                │ 'iot'                │ '6.0.3'          │ 'none'         │
              │ 28      │ 'system.adapter.javascript'         │ 'javascript'         │ '10.1.3'         │ 'none'         │
              │ 29      │ 'system.adapter.lgtv'               │ 'lgtv'               │ '2.7.4'          │ 'none'         │
              │ 30      │ 'system.adapter.linktap'            │ 'linktap'            │ '1.0.3'          │ 'none'         │
              │ 31      │ 'system.adapter.meross'             │ 'meross'             │ '1.17.0'         │ 'none'         │
              │ 32      │ 'system.adapter.mqtt'               │ 'mqtt'               │ '6.1.4'          │ 'none'         │
              │ 33      │ 'system.adapter.octoprint'          │ 'octoprint'          │ '5.1.0'          │ 'none'         │
              │ 34      │ 'system.adapter.onkyo'              │ 'onkyo'              │ '2.1.2'          │ 'none'         │
              │ 35      │ 'system.adapter.parser'             │ 'parser'             │ '4.0.1'          │ 'none'         │
              │ 36      │ 'system.adapter.ping'               │ 'ping'               │ '3.0.1'          │ 'none'         │
              │ 37      │ 'system.adapter.rest-api'           │ 'rest-api'           │ '4.0.1'          │ 'none'         │
              │ 38      │ 'system.adapter.shelly'             │ 'shelly'             │ '10.6.1'         │ 'none'         │
              │ 39      │ 'system.adapter.simple-api'         │ 'simple-api'         │ '3.0.7'          │ 'none'         │
              │ 40      │ 'system.adapter.snmp'               │ 'snmp'               │ '3.4.0'          │ 'none'         │
              │ 41      │ 'system.adapter.socketio'           │ 'socketio'           │ '7.1.3'          │ 'none'         │
              │ 42      │ 'system.adapter.sonos'              │ 'sonos'              │ '3.0.0'          │ 'none'         │
              │ 43      │ 'system.adapter.sourceanalytix'     │ 'sourceanalytix'     │ '0.4.15-alpha.1' │ 'none'         │
              │ 44      │ 'system.adapter.spotify-premium'    │ 'spotify-premium'    │ '3.0.1'          │ 'none'         │
              │ 45      │ 'system.adapter.switchbot-cloud'    │ 'switchbot-cloud'    │ '0.1.0'          │ 'none'         │
              │ 46      │ 'system.adapter.switchbot-hub'      │ 'switchbot-hub'      │ '0.1.2'          │ 'none'         │
              │ 47      │ 'system.adapter.telegram'           │ 'telegram'           │ '5.0.5'          │ 'none'         │
              │ 48      │ 'system.adapter.terminal'           │ 'terminal'           │ '1.0.0'          │ 'none'         │
              │ 49      │ 'system.adapter.text2command'       │ 'text2command'       │ '4.0.0'          │ 'none'         │
              │ 50      │ 'system.adapter.trashschedule'      │ 'trashschedule'      │ '5.3.0'          │ 'none'         │
              │ 51      │ 'system.adapter.vis'                │ 'vis'                │ '1.5.6'          │ 'none'         │
              │ 52      │ 'system.adapter.vis-bars'           │ 'vis-bars'           │ '0.1.4'          │ 'none'         │
              │ 53      │ 'system.adapter.vis-canvas-gauges'  │ 'vis-canvas-gauges'  │ '1.0.1'          │ 'none'         │
              │ 54      │ 'system.adapter.vis-history'        │ 'vis-history'        │ '1.0.0'          │ 'none'         │
              │ 55      │ 'system.adapter.vis-hqwidgets'      │ 'vis-hqwidgets'      │ '1.6.1'          │ 'none'         │
              │ 56      │ 'system.adapter.vis-inventwo'       │ 'vis-inventwo'       │ '4.1.1'          │ 'none'         │
              │ 57      │ 'system.adapter.vis-jqui-mfd'       │ 'vis-jqui-mfd'       │ '1.1.3'          │ 'none'         │
              │ 58      │ 'system.adapter.vis-justgage'       │ 'vis-justgage'       │ '2.1.7'          │ 'none'         │
              │ 59      │ 'system.adapter.vis-materialdesign' │ 'vis-materialdesign' │ '0.5.94'         │ 'none'         │
              │ 60      │ 'system.adapter.vis-metro'          │ 'vis-metro'          │ '1.2.0'          │ 'none'         │
              │ 61      │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2'          │ 'none'         │
              │ 62      │ 'system.adapter.vw-connect'         │ 'vw-connect'         │ '0.9.4'          │ 'none'         │
              │ 63      │ 'system.adapter.web'                │ 'web'                │ '8.0.0'          │ 'none'         │
              │ 64      │ 'system.adapter.ws'                 │ 'ws'                 │ '4.1.0'          │ 'none'         │
              │ 65      │ 'system.adapter.zigbee'             │ 'zigbee'             │ '3.5.5'          │ 'none'         │
              ioBroker-Adapter Versions and update status
              Used repository: stable
              Adapter    "admin"        : 8.0.11   , installed 8.0.11
              Adapter    "alexa2"       : 3.28.3   , installed 3.28.3
              Adapter    "backitup"     : 4.0.3    , installed 4.0.3
              Adapter    "birthdays"    : 6.1.0    , installed 6.1.0
              Adapter    "denon"        : 1.15.12  , installed 1.15.12
              Adapter    "devices"      : 1.2.14   , installed 1.2.14
              Adapter    "echarts"      : 3.1.0    , installed 3.1.0
              Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
              Adapter    "evcc"         : 0.2.4    , installed 0.2.4
              Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
              Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
              Adapter    "go-e"         : 1.0.41   , installed 1.0.41
              Adapter    "heos"         : 3.0.4    , installed 3.0.4
              Adapter    "history"      : 4.0.0    , installed 4.0.0
              Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
              Adapter    "homeconnect"  : 1.6.1    , installed 1.6.1
              Adapter    "hue"          : 3.16.2   , installed 3.16.2
              Adapter    "huum-sauna"   : 0.5.0    , installed 0.5.0
              Adapter    "ical"         : 1.21.0   , installed 1.21.0
              Adapter    "iot"          : 6.0.3    , installed 6.0.3
              Adapter    "javascript"   : 10.1.3   , installed 10.1.3
              Controller "js-controller": 7.2.2    , installed 7.2.2
              Adapter    "lgtv"         : 2.7.4    , installed 2.7.4
              Adapter    "linktap"      : 1.0.3    , installed 1.0.3
              Adapter    "meross"       : 1.17.0   , installed 1.17.0
              Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
              Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
              Adapter    "parser"       : 4.0.1    , installed 4.0.1
              Adapter    "ping"         : 3.0.1    , installed 3.0.1
              Adapter    "rest-api"     : 4.0.1    , installed 4.0.1
              Adapter    "shelly"       : 10.6.1   , installed 10.6.1
              Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
              Adapter    "snmp"         : 3.4.0    , installed 3.4.0
              Adapter    "socketio"     : 7.1.3    , installed 7.1.3
              Adapter    "sonos"        : 3.0.0    , installed 3.0.0
              Adapter    "spotify-premium": 3.0.1  , installed 3.0.1
              Adapter    "telegram"     : 5.0.5    , installed 5.0.5
              Adapter    "terminal"     : 1.0.0    , installed 1.0.0
              Adapter    "text2command" : 4.0.0    , installed 4.0.0
              Adapter    "trashschedule": 5.3.0    , installed 5.3.0
              Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
              Adapter    "vis-inventwo" : 4.1.1    , installed 4.1.1
              Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
              Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
              Adapter    "web"          : 8.0.0    , installed 8.0.0
              Adapter    "ws"           : 4.1.0    , installed 4.1.0
              Adapter    "zigbee"       : 3.5.5    , installed 3.5.5
              Objects and States
              Objects: 	22557
              States: 	18991
              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:2 http://deb.debian.org/debian bullseye InRelease
              Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
              Reading package lists...
              Pending systemupdates: 3
              *** Listening Ports ***
              Netid State  Recv-Q Send-Q Local Address:Port          Peer Address:PortProcess
              udp   UNCONN 0      0            0.0.0.0:44371              0.0.0.0:*    users:(("avahi-daemon",pid=395,fd=14))
              udp   UNCONN 0      0            0.0.0.0:bootpc             0.0.0.0:*    users:(("dhcpcd",pid=786,fd=13))
              udp   UNCONN 0      0            0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=395,fd=12))
              udp   UNCONN 0      0                  *:38790                    *:*    users:(("avahi-daemon",pid=395,fd=15))
              udp   UNCONN 0      0                  *:dhcpv6-client            *:*    users:(("dhcpcd",pid=786,fd=16))
              udp   UNCONN 0      0                  *:mdns                     *:*    users:(("avahi-daemon",pid=395,fd=13))
              tcp   LISTEN 0      128          0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=526,fd=3))
              tcp   LISTEN 0      128             [::]:ssh                   [::]:*    users:(("sshd",pid=526,fd=4))
              2026-09-05 16:57:24.951  - warn: host.raspberrypi instance system.adapter.trashschedule.0 terminated due to SIGKILL
              2026-09-05 16:57:24.952  - info: host.raspberrypi instance system.adapter.trashschedule.0 terminated with code null ()
              2026-09-05 16:57:24.952  - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGKILL
              2026-09-05 16:57:24.952  - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
              2026-09-05 16:57:24.994  - warn: host.raspberrypi instance system.adapter.go-e.0 terminated due to SIGKILL
              2026-09-05 16:57:24.994  - info: host.raspberrypi instance system.adapter.go-e.0 terminated with code null ()
              2026-09-05 16:57:25.032  - warn: host.raspberrypi instance system.adapter.vw-connect.0 terminated due to SIGKILL
              2026-09-05 16:57:25.033  - info: host.raspberrypi instance system.adapter.vw-connect.0 terminated with code null ()
              2026-09-05 16:57:25.092  - warn: host.raspberrypi instance system.adapter.trashschedule.1 terminated due to SIGKILL
              2026-09-05 16:57:25.092  - info: host.raspberrypi instance system.adapter.trashschedule.1 terminated with code null ()
              2026-09-05 16:57:25.164  - warn: host.raspberrypi instance system.adapter.simple-api.0 terminated due to SIGKILL
              2026-09-05 16:57:25.165  - info: host.raspberrypi instance system.adapter.simple-api.0 terminated with code null ()
              2026-09-05 16:57:25.295  - warn: host.raspberrypi instance system.adapter.linktap.0 terminated due to SIGKILL
              2026-09-05 16:57:25.296  - info: host.raspberrypi instance system.adapter.linktap.0 terminated with code null ()
              2026-09-05 16:57:25.298  - warn: host.raspberrypi instance system.adapter.rest-api.0 terminated due to SIGKILL
              2026-09-05 16:57:25.299  - info: host.raspberrypi instance system.adapter.rest-api.0 terminated with code null ()
              2026-09-05 16:57:25.346  - warn: host.raspberrypi instance system.adapter.alexa2.0 terminated due to SIGKILL
              2026-09-05 16:57:25.347  - info: host.raspberrypi instance system.adapter.alexa2.0 terminated with code null ()
              2026-09-05 16:57:25.762  - info: host.raspberrypi instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
              2026-09-05 16:57:25.802  - warn: host.raspberrypi instance system.adapter.meross.0 terminated due to SIGKILL
              2026-09-05 16:57:25.802  - info: host.raspberrypi instance system.adapter.meross.0 terminated with code null ()
              2026-09-05 16:57:25.873  - info: host.raspberrypi instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
              2026-09-05 16:57:26.068  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
              2026-09-05 16:57:26.068  - info: host.raspberrypi All instances are stopped.
              2026-09-05 16:57:26.248  - info: host.raspberrypi terminated
              ============= Mark until here for C&P =============
              iob diag has finished.
              pi@raspberrypi:~ $ iobroker fix
              • J
                J
                jwedenig
                ok, ich bestelle mir zuerst eine neue SSD, möchte nichts löschen, und dann gehe ich es an. Ich mache zwar regelmäßig update/upgrade, aber wann das Betriebssystem fällig ist bekomme ich nicht mit! Wie kann ich dies in Zukunft verbessern. Bin halt nicht ständig in Foren unterwegs nach dem Motto - wenn alles läuft dann läufts!
                • J jwedenig
                  Thomas BraunT
                  Thomas BraunT
                  @jwedenig sagte:
                  In iob diag gibt es dazu einen Check der Lebenszeit:
                  Sollte bei dir in Rot erscheinen. Das aktuelle stable-Release wird in grüner Schrift gemeldet und wenn es Zeit wird weiter zu ziehen wird das sog. oldstable (also der Vorgänger zur aktuellen stable) in Gelb gemeldet.
                  Alles was nicht grün ist muss angepackt werden.
                  • J
                    J
                    jwedenig
                    ok, danke, wo finde ich hier von Dir die beste Methode zum Installieren? Es gibt ja haufenweise Install-Tipps, ich hätte gerne DEINE
                    • J jwedenig
                      Thomas BraunT
                      Thomas BraunT
                      @jwedenig
                      https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                      • J
                        J
                        jwedenig
                        schrieb am zuletzt editiert von jwedenig
                        danke Dir, das funzt auch mit einer SSD über usb? oder muss ich hier was beachten, da die Anleitung für SD Karte ist? und was meintest du vorher mit Strom checken? Brauche ich ein anderes Netzteil? danke für deine Hilfe
                        • J jwedenig
                          Thomas BraunT
                          Thomas BraunT
                          @jwedenig sagte:
                          Das Ziellaufwerk kann ausgesucht werden.
                          Möglich. Die genannten Meldungen weisen jedenfalls darauf hin.
                          • J
                            J
                            jwedenig
                            mit den 2 Dateien am Computer bin ich mal safe, oder?
                            • J jwedenig
                              Thomas BraunT
                              Thomas BraunT
                              @jwedenig sagte:
                              Kann ich dir nicht sagen, ob das alles ist.
                              • J
                                J
                                jwedenig
                                naja, hat halt der Backup Adapter ausgespuckt - das Netztweil ist übrigens ein Original Netzteil, also das auch neu kaufen?
                                • J jwedenig
                                  Thomas BraunT
                                  Thomas BraunT
                                  @jwedenig
                                  Die Meldungen mit under-voltage können auch durch unsauberes herunterfahren kommen.
                                  • J
                                    J
                                    jwedenig
                                    ok, danke, ich würde mich hier wieder melden, sollten Probleme auftreten, Liebe Grüße Jürgen
                                      @jwedenig
                                      OliverIOO
                                      OliverIOO
                                      OliverIO
                                      @Thomas-Braun sagte:
                                      oder zuviele weitere Geräte, HATs und Erweiterungen dran.
                                      oder einfach Netzteil-Alterung.
                                      Meine Adapter und Widgets
                                      Links im Profil
                                      • mcm1957M mcm1957 verschob dieses Thema von Error/Bug am
                                      • J
                                        J
                                        jwedenig
                                        hi! ich habe jetzt das Image auf meine externe SSD geflasht , welche über einen USB Hub mit Stromversorgung angesteckt ist. Leider taucht der Raspi im Netzwerk nicht auf? Er hängt wie vorher an der LAN Buchse. Die rote Led leuchtet permanent, die grüne blinkt, und beim Lan Anschluss leuchtet nur die Gelbe!
                                        • J jwedenig
                                          Thomas BraunT
                                          Thomas BraunT
                                          @jwedenig
                                          Und über den von dir vergebenen hostname?
                                          Oder über die u.U. von deinem DHCP-Server neuvergebene IP?
                                          83.8k
