<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Update Konsolen Pflege]]></title><description><![CDATA[<p dir="auto">Sorry, ich bin hier glaub ich falsch, oder kann mir wer mit diesen Error Meldungen beim Updaten helfen?</p>
<pre><code>pi@raspberrypi:~ $ sudo apt-get update
Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
Hit:2 http://deb.debian.org/debian bullseye InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
Reading package lists... Done
pi@raspberrypi:~ $ sudo apt full-upgrade
Building dependency tree... Done
Calculating upgrade... Done
The following packages will be upgraded:
  dpkg-dev libdpkg-perl xz-utils
3 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 4,092 kB of archives.
After this operation, 8,192 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Err:1 http://security.debian.org/debian-security bullseye-security/main arm64 xz-utils arm64 5.2.5-2.1~deb11u2
  404  Not Found [IP: 2a04:4e42:41::644 80]
Get:2 http://security.debian.org/debian-security bullseye-security/main arm64 dpkg-dev all 1.20.14 [2,317 kB]
Ign:3 http://security.debian.org/debian-security bullseye-security/main arm64 libdpkg-perl all 1.20.14
Err:3 http://security.debian.org/debian-security bullseye-security/main arm64 libdpkg-perl all 1.20.14
Fetched 2,317 kB in 1s (4,552 kB/s)
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/x/xz-utils/xz-utils_5.2.5-2.1%7edeb11u2_arm64.deb  404  Not Found [IP: 2a04:4e42:41::644 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/d/dpkg/libdpkg-perl_1.20.14_all.deb  404  Not Found [IP: 2a04:4e42:41::644 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
pi@raspberrypi:~ $
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/85298/update-konsolen-pflege</link><generator>RSS for Node</generator><lastBuildDate>Sat, 12 Sep 2026 08:16:13 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/85298.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 05 Sep 2026 14:35:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Update Konsolen Pflege on Fri, 11 Sep 2026 15:18:43 GMT]]></title><description><![CDATA[<p dir="auto">eine andere Frage noch: Da du ja meintest  Flot ist veraltet, die Alternative wäre ja laut Blogs "Echarts"<br />
Jetzt habe ich das Problem, dass ich die Oberfläche kurz sehe, und dann wird alles weiss und nichts ist sichtbar.<br />
Ist dies bekannt bzw ein Bug? Wie kann ich dies ändern?</p>
]]></description><link>https://forum.iobroker.net/post/1354583</link><guid isPermaLink="true">https://forum.iobroker.net/post/1354583</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Fri, 11 Sep 2026 15:18:43 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Fri, 11 Sep 2026 15:16:20 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwedenig" aria-label="Profile: jwedenig">@<bdi>jwedenig</bdi></a> <a href="/post/1354574">sagte</a>:</p>
<p dir="auto">aber die Adapter sind auf Github auch nicht aktueller, oder verstehe ich da was falsch?</p>
</blockquote>
<p dir="auto">Das kannst du nicht sagen, weil da die Versionsnummern keine Rolle spielen. Da kann sich 'irgendwas' in 'irgendeinem' Zustand drin befinden. Zusätzlich sind diese GitHub-Installationen schwieriger zu pflegen und halt nicht 'ordentlich' in den ioBroker eingebunden.<br />
Es gibt auch erste Adapter, die sich gar nicht mehr darüber installieren lassen, vermutlich werden das in nächster Zeit auch noch wesentlich mehr werden, weil man eigentlich von diesen 'wilden Installationen' weg will.</p>
]]></description><link>https://forum.iobroker.net/post/1354582</link><guid isPermaLink="true">https://forum.iobroker.net/post/1354582</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 11 Sep 2026 15:16:20 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Fri, 11 Sep 2026 15:09:44 GMT]]></title><description><![CDATA[<p dir="auto">ok danke</p>
]]></description><link>https://forum.iobroker.net/post/1354581</link><guid isPermaLink="true">https://forum.iobroker.net/post/1354581</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Fri, 11 Sep 2026 15:09:44 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Fri, 11 Sep 2026 13:57:01 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">verstehe ich da was falsch?</p>
</blockquote>
<p dir="auto">Man soll nie ohne Not von Github installieten.<br />
Die dort liegenden Versionen können z.B auch unfertige Zwischenstände sein.</p>
<p dir="auto">Immer über die Repos oder npm installieren, ausser der Developer hat das explizit gesagt, um z.B. eine Korrektur zu testen.</p>
]]></description><link>https://forum.iobroker.net/post/1354577</link><guid isPermaLink="true">https://forum.iobroker.net/post/1354577</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Fri, 11 Sep 2026 13:57:01 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Fri, 11 Sep 2026 13:11:16 GMT]]></title><description><![CDATA[<p dir="auto">super , danke dir, aber die Adapter sind auf Github auch nicht aktueller, oder verstehe ich da was falsch?</p>
]]></description><link>https://forum.iobroker.net/post/1354574</link><guid isPermaLink="true">https://forum.iobroker.net/post/1354574</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Fri, 11 Sep 2026 13:11:16 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Thu, 10 Sep 2026 20:23:25 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwedenig" aria-label="Profile: jwedenig">@<bdi>jwedenig</bdi></a> <a href="/post/1354535">sagte</a>:</p>
<p dir="auto">nodejs modules from github: 	8</p>
</blockquote>
<p dir="auto">Schau mal dass du die von GitHub runterbekommst.<br />
Z.B.:</p>
<pre><code>huum-sauna
latest
    0.5.0 for 18 months
stable
    0.5.0 for 18 months
</code></pre>
<pre><code>onkyo
latest
    2.1.2 for 54 months
stable
    2.1.2 for 54 months
</code></pre>
<pre><code>sourceanalytix
latest
    0.5.6 for 39 days
stable
</code></pre>
<pre><code>vis-materialdesign
latest
    0.5.9 for 63 months
stable
    0.5.9 for 63 months
</code></pre>
<pre><code>vw-connect
latest
    0.9.10 for 23 days
stable
</code></pre>
<p dir="auto">Und den info, den  flot sowie  den terminal Adapter würde ich rauswerfen.</p>
<blockquote>
<p dir="auto">Adapter    "ws"           : 4.1.0    , installed 3.0.19 [Updatable]</p>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/1354537</link><guid isPermaLink="true">https://forum.iobroker.net/post/1354537</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 10 Sep 2026 20:23:25 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Thu, 10 Sep 2026 19:36:37 GMT]]></title><description><![CDATA[<p dir="auto">Alles gut jetzt wieder?</p>
<pre><code>
```bash
Script v.2026-08-30
*** BASE SYSTEM ***
Operating System: Debian GNU/Linux 13 (trixie)
 Static hostname: iobroker
       Icon name: computer
          Kernel: Linux 6.18.39+rpt-rpi-v8
    Architecture: arm64
OS is similar to:
Model		: Raspberry Pi 4 Model B Rev 1.5
Docker          : false
Virtualization  : none
Unknown
Kernel          : aarch64
Userland        : 64bit
System was installed 84 days ago (on 2026-06-18).
Systemuptime and Load:
 21:27:20 up 5 min,  1 user,  load average: 7.14, 4.32, 1.84
CPU threads     : 4
*** LIFE CYCLE STATUS ***
Operating System is the current Debian stable version codenamed 'trixie'!
*** RASPBERRY THROTTLING ***
Current issues:
Previously detected issues:
*** TIME AND TIMEZONES ***
               Local time: Thu 2026-09-10 21:27:20 CEST
           Universal time: Thu 2026-09-10 19:27:20 UTC
                 RTC time: n/a
                Time zone: Europe/Vienna (CEST, +0200)
              NTP service: active
          RTC in local TZ: no
*** Users and Groups ***
User that called 'iob diag':
wedl
HOME=/home/wedl
GROUPS=wedl adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input lpadmin iobroker
iobroker
HOME=/home/iobroker
*** DISPLAY-SERVER SETUP ***
Display-Server:		Unknown
Display-Manager: 	Not found
Desktop:
Session:		tty
Boot Target: 		multi-user.target
*** MEMORY ***
Mem:            8.2G        5.6G        2.1G         13M        651M        2.6G
Swap:           2.1G          0B        2.1G
Total:           10G        5.6G        4.2G
Active iob-Instances: 	24
         7818 M total memory
         5343 M used memory
         5265 M active memory
          319 M inactive memory
         1956 M free memory
           64 M buffer memory
          556 M swap cache
         2047 M total swap
            0 M used swap
         2047 M free swap
top - 21:27:21 up 5 min,  1 user,  load average: 7.14, 4.32, 1.84
Tasks: 227 total,   4 running, 223 sleeping,   0 stopped,   0 zombie
%Cpu(s): 74.5 us,  5.9 sy,  0.0 ni, 19.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   7818.8 total,   1953.3 free,   5346.8 used,    621.7 buff/cache
MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   2472.0 avail Mem
*** FAILED SERVICES ***
0 loaded units listed.
*** DMESG CRITICAL ERRORS ***
No critical errors detected
*** FILESYSTEM ***
udev           devtmpfs  3.6G     0  3.6G   0% /dev
tmpfs          tmpfs     1.6G  9.0M  1.6G   1% /run
/dev/sda2      ext4      220G  9.3G  202G   5% /
tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
tmpfs          tmpfs     3.9G  4.0M  3.9G   1% /tmp
/dev/sda1      vfat      505M   66M  439M  14% /boot/firmware
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
tmpfs          tmpfs     782M  8.0K  782M   1% /run/user/1000
Messages concerning filesystems in dmesg (Last 15 lines only):
[Thu Sep 10 21:22:15 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
[Thu Sep 10 21:22:15 2026] EXT4-fs (sda2): mounted filesystem 15f4c6be-1102-4331-9904-f78e78afd1fd ro with ordered data mode. Quota mode: none.
[Thu Sep 10 21:22:18 2026] EXT4-fs (sda2): re-mounted 15f4c6be-1102-4331-9904-f78e78afd1fd r/w.
Show mounted filesystems:
TARGET           SOURCE    FSTYPE OPTIONS
/                /dev/sda2 ext4   rw,noatime
`-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
/var:
2.5G	/var/
232M	/var/cache
226M	/var/cache/apt
184M	/var/lib
148M	/var/lib/apt/lists
Archived and active journals take up 8M in the file system.
/opt/iobroker/backups:
119M	/opt/iobroker/backups/
/opt/iobroker/iobroker-data:
2.7G	/opt/iobroker/iobroker-data/
2.3G	/opt/iobroker/iobroker-data/history
249M	/opt/iobroker/iobroker-data/files
41M	/opt/iobroker/iobroker-data/files/vis.0
31M	/opt/iobroker/iobroker-data/files/vis
52M	/opt/iobroker/iobroker-data/objects.jsonl
26M	/opt/iobroker/iobroker-data/states.jsonl
7.9M	/opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json
6.8M	/opt/iobroker/iobroker-data/files/parser.admin/custom/assets/_virtual_mf___mfe_internal__ConfigCustomParserSet__mf_owner__1__loadShare___mf_0_iobroker_mf_1_gui_mf_2_components__loadShare__.js-cQtCjkik.js
6.8M	/opt/iobroker/iobroker-data/files/javascript.admin/custom/assets/_virtual_mf___mfe_internal__ConfigCustomJavascriptSet__mf_owner__1__loadShare___mf_0_iobroker_mf_1_gui_mf_2_components__loadShare__.js-DMefPDeL.js
USB-Devices by-id:
USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
please always prefer the links 'by-id':
/dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
*** ZigBee Settings ***
Zigbee Network Settings on your coordinator / in nvbackup are:
zigbee.X
Extended Pan ID:
*** MASKED ***
Pan ID:
*** MASKED ***
Channel:
*** MASKED ***
Network Key:
*** MASKED ***
=== ZigBee Port Overview ===
Instance        Configured Port                     Available by-id Port                Status
zigbee.0        ...ngle_Plus_0001-if00-port0        ...ngle_Plus_0001-if00-port0        ✓ Matching
*** NodeJS-Installation ***
/usr/bin/nodejs		v22.23.2
/usr/bin/node		v22.23.2
/usr/bin/npm		10.9.8
/usr/bin/npx		10.9.8
✓ Node.js installation is correct
nodejs:
  Installed: 22.23.2-1nodesource1
  Candidate: 22.23.2-1nodesource1
  Version table:
 *** 22.23.2-1nodesource1 1001
        500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
        100 /var/lib/dpkg/status
     22.23.1-1nodesource1 1001
     22.23.0-1nodesource1 1001
     22.22.3-1nodesource1 1001
     22.22.2-1nodesource1 1001
     22.22.1-1nodesource1 1001
     22.22.0-1nodesource1 1001
     22.21.0-1nodesource1 1001
     22.20.0-1nodesource1 1001
     22.19.0-1nodesource1 1001
     22.18.0-1nodesource1 1001
     22.17.1-1nodesource1 1001
     22.17.0-1nodesource1 1001
     22.16.0-1nodesource1 1001
     22.15.1-1nodesource1 1001
     22.15.0-1nodesource1 1001
     22.14.0-1nodesource1 1001
     22.13.1-1nodesource1 1001
     22.13.0-1nodesource1 1001
     22.12.0-1nodesource1 1001
     22.11.0-1nodesource1 1001
     22.10.0-1nodesource1 1001
     22.9.0-1nodesource1 1001
     22.8.0-1nodesource1 1001
     22.7.0-1nodesource1 1001
     22.6.0-1nodesource1 1001
     22.5.1-1nodesource1 1001
     22.5.0-1nodesource1 1001
     22.4.1-1nodesource1 1001
     22.4.0-1nodesource1 1001
     22.3.0-1nodesource1 1001
     22.2.0-1nodesource1 1001
     22.1.0-1nodesource1 1001
     22.0.0-1nodesource1 1001
     20.19.2+dfsg-1+deb13u2 500
        500 http://deb.debian.org/debian trixie/main arm64 Packages
        500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
No problems detected
Errors in npm tree: 0
No known Vulnerabilities detected!
*** ioBroker-Installation ***
ioBroker Status
Objects type: jsonl
States  type: jsonl
Hosts:
iobroker            iobroker (version: 7.2.2, hostname: iobroker      , alive, uptime: 374)
Core adapters versions
js-controller: 	7.2.2
admin: 		8.0.11
javascript: 	10.1.3
+-- iobroker.fusionsolar@1.2.4 (git+ssh://git@github.com/KornSW/ioBroker.fusionsolar.git#50f776fd8f991d0832be3d660de7a38a4763093d)
+-- iobroker.huum-sauna@0.5.0 (git+ssh://git@github.com/Chris-656/ioBroker.huum-sauna.git#29839546d990296fa85845e0dca5060f2be698ed)
+-- iobroker.onkyo@2.1.2 (git+ssh://git@github.com/ioBroker/ioBroker.onkyo.git#096ed2d2dcd097312ffa770db3155d3dada68e30)
+-- iobroker.sourceanalytix@0.5.6 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#37fea482105bc89e2de6e8c0b812b98b455a5d0b)
+-- iobroker.switchbot-cloud@0.1.0 (git+ssh://git@github.com/kaschtn/ioBroker.switchbot-cloud.git#35cd79211d153fcbfc492f19d4a38e422b575257)
+-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/arteck/ioBroker.switchbot-hub.git#666f01f7e8b49322d68d63360322a9f11169911a)
+-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
+-- iobroker.vw-connect@0.9.11 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#9e524ea3db1b352ae44bb84ed2c293a60c09c857)
Adapter State
+ system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
+ system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
+ system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
+ system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
  system.adapter.devices.0                : devices               : iobroker                                 -  enabled
+ system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
+ system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
+ system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
+ system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
+ system.adapter.evcc.0                   : evcc                  : iobroker                                 -  enabled, port: 7070
  system.adapter.fahrplan.0               : fahrplan              : iobroker                                 -  enabled
+ system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
  system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
+ system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
+ system.adapter.fusionsolar.0            : fusionsolar           : iobroker                                 -  enabled
  system.adapter.go-e.0                   : go-e                  : iobroker                                 -  enabled
+ system.adapter.heos.0                   : heos                  : iobroker                                 -  enabled
+ system.adapter.history.0                : history               : iobroker                                 -  enabled
+ system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
+ system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
+ system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
+ system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
+ system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
  system.adapter.huum-sauna.0             : huum-sauna            : iobroker                                 -  enabled
  system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
  system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
  system.adapter.info.0                   : info                  : iobroker                                 -  enabled
  system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
+ system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
+ system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
  system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
+ system.adapter.linktap.0                : linktap               : iobroker                                 -  enabled
+ system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
+ system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
  system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
  system.adapter.onkyo.0                  : onkyo                 : iobroker                                 -  enabled
+ system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
+ system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
+ system.adapter.rest-api.0               : rest-api              : iobroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
+ system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
+ system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
+ system.adapter.snmp.0                   : snmp                  : iobroker                                 -  enabled
+ system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
+ system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
+ system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
  system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 -  enabled
+ system.adapter.switchbot-cloud.0        : switchbot-cloud       : iobroker                                 -  enabled
+ system.adapter.switchbot-hub.0          : switchbot-hub         : iobroker                                 -  enabled
+ system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
+ system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 192.168.1.41, run as: admin
  system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
  system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
  system.adapter.trashschedule.1          : trashschedule         : iobroker                                 -  enabled
  system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
  system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
  system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
  system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
  system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
  system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
+ system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
  system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
  system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
+ system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
+ instance is alive
ioBroker-Repositories
Active repo(s): stable
Upgrade policy: none
Installed ioBroker-Adapters
│ (index) │ id                                  │ name                 │ version   │ upgrade policy │
│ 0       │ 'system.adapter.admin'              │ 'admin'              │ '8.0.11'  │ 'none'         │
│ 1       │ 'system.adapter.alexa2'             │ 'alexa2'             │ '3.28.3'  │ 'none'         │
│ 2       │ 'system.adapter.backitup'           │ 'backitup'           │ '4.0.3'   │ 'none'         │
│ 3       │ 'system.adapter.birthdays'          │ 'birthdays'          │ '6.1.0'   │ 'none'         │
│ 4       │ 'system.adapter.denon'              │ 'denon'              │ '1.15.12' │ 'none'         │
│ 5       │ 'system.adapter.devices'            │ 'devices'            │ '1.2.14'  │ 'none'         │
│ 6       │ 'system.adapter.discovery'          │ 'discovery'          │ '5.0.0'   │ 'none'         │
│ 7       │ 'system.adapter.echarts'            │ 'echarts'            │ '3.1.0'   │ 'none'         │
│ 8       │ 'system.adapter.energiefluss'       │ 'energiefluss'       │ '3.6.2'   │ 'none'         │
│ 9       │ 'system.adapter.evcc'               │ 'evcc'               │ '0.2.4'   │ 'none'         │
│ 10      │ 'system.adapter.fahrplan'           │ 'fahrplan'           │ '1.4.1'   │ 'none'         │
│ 11      │ 'system.adapter.fb-checkpresence'   │ 'fb-checkpresence'   │ '1.4.2'   │ 'none'         │
│ 12      │ 'system.adapter.flot'               │ 'flot'               │ '1.12.0'  │ 'none'         │
│ 13      │ 'system.adapter.fullybrowser'       │ 'fullybrowser'       │ '3.1.2'   │ 'none'         │
│ 14      │ 'system.adapter.fusionsolar'        │ 'fusionsolar'        │ '1.2.4'   │ 'none'         │
│ 15      │ 'system.adapter.go-e'               │ 'go-e'               │ '1.0.41'  │ 'none'         │
│ 16      │ 'system.adapter.heos'               │ 'heos'               │ '3.0.4'   │ 'none'         │
│ 17      │ 'system.adapter.history'            │ 'history'            │ '4.0.0'   │ 'none'         │
│ 18      │ 'system.adapter.hm-rega'            │ 'hm-rega'            │ '5.1.0'   │ 'none'         │
│ 19      │ 'system.adapter.hm-rpc'             │ 'hm-rpc'             │ '3.0.1'   │ 'none'         │
│ 20      │ 'system.adapter.homeconnect'        │ 'homeconnect'        │ '1.6.1'   │ 'none'         │
│ 21      │ 'system.adapter.hue'                │ 'hue'                │ '3.16.2'  │ 'none'         │
│ 22      │ 'system.adapter.huum-sauna'         │ 'huum-sauna'         │ '0.5.0'   │ 'none'         │
│ 23      │ 'system.adapter.ical'               │ 'ical'               │ '1.21.0'  │ 'none'         │
│ 24      │ 'system.adapter.icons-icons8'       │ 'icons-icons8'       │ '0.0.1'   │ 'none'         │
│ 25      │ 'system.adapter.icons-mfd-svg'      │ 'icons-mfd-svg'      │ '1.2.0'   │ 'none'         │
│ 26      │ 'system.adapter.info'               │ 'info'               │ '2.0.0'   │ 'none'         │
│ 27      │ 'system.adapter.iot'                │ 'iot'                │ '6.0.3'   │ 'none'         │
│ 28      │ 'system.adapter.javascript'         │ 'javascript'         │ '10.1.3'  │ 'none'         │
│ 29      │ 'system.adapter.lgtv'               │ 'lgtv'               │ '2.7.4'   │ 'none'         │
│ 30      │ 'system.adapter.linktap'            │ 'linktap'            │ '1.0.3'   │ 'none'         │
│ 31      │ 'system.adapter.meross'             │ 'meross'             │ '1.17.0'  │ 'none'         │
│ 32      │ 'system.adapter.mqtt'               │ 'mqtt'               │ '6.1.4'   │ 'none'         │
│ 33      │ 'system.adapter.octoprint'          │ 'octoprint'          │ '5.1.0'   │ 'none'         │
│ 34      │ 'system.adapter.onkyo'              │ 'onkyo'              │ '2.1.2'   │ 'none'         │
│ 35      │ 'system.adapter.parser'             │ 'parser'             │ '4.0.1'   │ 'none'         │
│ 36      │ 'system.adapter.ping'               │ 'ping'               │ '3.0.1'   │ 'none'         │
│ 37      │ 'system.adapter.rest-api'           │ 'rest-api'           │ '4.0.1'   │ 'none'         │
│ 38      │ 'system.adapter.shelly'             │ 'shelly'             │ '10.6.1'  │ 'none'         │
│ 39      │ 'system.adapter.simple-api'         │ 'simple-api'         │ '3.0.7'   │ 'none'         │
│ 40      │ 'system.adapter.snmp'               │ 'snmp'               │ '3.4.0'   │ 'none'         │
│ 41      │ 'system.adapter.socketio'           │ 'socketio'           │ '7.1.3'   │ 'none'         │
│ 42      │ 'system.adapter.sonos'              │ 'sonos'              │ '3.0.0'   │ 'none'         │
│ 43      │ 'system.adapter.sourceanalytix'     │ 'sourceanalytix'     │ '0.5.6'   │ 'none'         │
│ 44      │ 'system.adapter.spotify-premium'    │ 'spotify-premium'    │ '3.0.1'   │ 'none'         │
│ 45      │ 'system.adapter.switchbot-cloud'    │ 'switchbot-cloud'    │ '0.1.0'   │ 'none'         │
│ 46      │ 'system.adapter.switchbot-hub'      │ 'switchbot-hub'      │ '0.1.2'   │ 'none'         │
│ 47      │ 'system.adapter.telegram'           │ 'telegram'           │ '5.0.5'   │ 'none'         │
│ 48      │ 'system.adapter.terminal'           │ 'terminal'           │ '1.0.0'   │ 'none'         │
│ 49      │ 'system.adapter.text2command'       │ 'text2command'       │ '4.0.0'   │ 'none'         │
│ 50      │ 'system.adapter.trashschedule'      │ 'trashschedule'      │ '5.3.0'   │ 'none'         │
│ 51      │ 'system.adapter.vis'                │ 'vis'                │ '1.5.6'   │ 'none'         │
│ 52      │ 'system.adapter.vis-bars'           │ 'vis-bars'           │ '0.1.4'   │ 'none'         │
│ 53      │ 'system.adapter.vis-canvas-gauges'  │ 'vis-canvas-gauges'  │ '1.0.1'   │ 'none'         │
│ 54      │ 'system.adapter.vis-history'        │ 'vis-history'        │ '1.0.0'   │ 'none'         │
│ 55      │ 'system.adapter.vis-hqwidgets'      │ 'vis-hqwidgets'      │ '1.6.1'   │ 'none'         │
│ 56      │ 'system.adapter.vis-inventwo'       │ 'vis-inventwo'       │ '4.1.1'   │ 'none'         │
│ 57      │ 'system.adapter.vis-jqui-mfd'       │ 'vis-jqui-mfd'       │ '1.1.3'   │ 'none'         │
│ 58      │ 'system.adapter.vis-justgage'       │ 'vis-justgage'       │ '2.1.7'   │ 'none'         │
│ 59      │ 'system.adapter.vis-materialdesign' │ 'vis-materialdesign' │ '0.5.94'  │ 'none'         │
│ 60      │ 'system.adapter.vis-metro'          │ 'vis-metro'          │ '1.2.0'   │ 'none'         │
│ 61      │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2'   │ 'none'         │
│ 62      │ 'system.adapter.vw-connect'         │ 'vw-connect'         │ '0.9.11'  │ 'none'         │
│ 63      │ 'system.adapter.web'                │ 'web'                │ '8.0.0'   │ 'none'         │
│ 64      │ 'system.adapter.ws'                 │ 'ws'                 │ '4.1.0'   │ 'none'         │
│ 65      │ 'system.adapter.zigbee'             │ 'zigbee'             │ '3.5.5'   │ 'none'         │
ioBroker-Adapter Versions and update status
Used repository: stable
Adapter    "admin"        : 8.0.11   , installed 8.0.11
Adapter    "alexa2"       : 3.28.3   , installed 3.28.3
Adapter    "backitup"     : 4.0.3    , installed 4.0.3
Adapter    "birthdays"    : 6.1.0    , installed 6.1.0
Adapter    "denon"        : 1.15.12  , installed 1.15.12
Adapter    "devices"      : 1.2.14   , installed 1.2.14
Adapter    "echarts"      : 3.1.0    , installed 3.1.0
Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
Adapter    "evcc"         : 0.2.4    , installed 0.2.4
Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
Adapter    "go-e"         : 1.0.41   , installed 1.0.41
Adapter    "heos"         : 3.0.4    , installed 3.0.4
Adapter    "history"      : 4.0.0    , installed 4.0.0
Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
Adapter    "homeconnect"  : 1.6.1    , installed 1.6.1
Adapter    "hue"          : 3.16.2   , installed 3.16.2
Adapter    "huum-sauna"   : 0.5.0    , installed 0.5.0
Adapter    "ical"         : 1.21.0   , installed 1.21.0
Adapter    "iot"          : 6.0.3    , installed 6.0.3
Adapter    "javascript"   : 10.1.3   , installed 10.1.3
Controller "js-controller": 7.2.2    , installed 7.2.2
Adapter    "lgtv"         : 2.7.4    , installed 2.7.4
Adapter    "linktap"      : 1.0.3    , installed 1.0.3
Adapter    "meross"       : 1.17.0   , installed 1.17.0
Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
Adapter    "parser"       : 4.0.1    , installed 4.0.1
Adapter    "ping"         : 3.0.1    , installed 3.0.1
Adapter    "rest-api"     : 4.0.1    , installed 4.0.1
Adapter    "shelly"       : 10.6.1   , installed 10.6.1
Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
Adapter    "snmp"         : 3.4.0    , installed 3.4.0
Adapter    "socketio"     : 7.1.3    , installed 7.1.3
Adapter    "sonos"        : 3.0.0    , installed 3.0.0
Adapter    "spotify-premium": 3.0.1  , installed 3.0.1
Adapter    "telegram"     : 5.0.5    , installed 5.0.5
Adapter    "terminal"     : 1.0.0    , installed 1.0.0
Adapter    "text2command" : 4.0.0    , installed 4.0.0
Adapter    "trashschedule": 5.3.0    , installed 5.3.0
Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
Adapter    "vis-inventwo" : 4.1.1    , installed 4.1.1
Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
Adapter    "web"          : 8.0.0    , installed 8.0.0
Adapter    "zigbee"       : 3.5.5    , installed 3.5.5
Objects and States
Objects: 	27823
States: 	24770
Hit:1 http://deb.debian.org/debian trixie InRelease
Hit:2 http://deb.debian.org/debian trixie-updates InRelease
Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
Pending systemupdates: 0
*** Listening Ports ***
Netid State  Recv-Q Send-Q               Local Address:Port          Peer Address:PortProcess
udp   UNCONN 0      0                          0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=621,fd=12))
udp   UNCONN 0      0                          0.0.0.0:55921              0.0.0.0:*    users:(("io.heos.0",pid=1085,fd=30))
udp   UNCONN 0      0                          0.0.0.0:40053              0.0.0.0:*    users:(("io.snmp.0",pid=1379,fd=35))
udp   UNCONN 0      0                          0.0.0.0:48964              0.0.0.0:*    users:(("avahi-daemon",pid=621,fd=14))
udp   UNCONN 0      0                          0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=598,fd=5),("systemd",pid=1,fd=171))
udp   UNCONN 0      0      [fe80::b367:1cd0:bdfd:9da1]:dhcpv6-client            *:*    users:(("NetworkManager",pid=680,fd=28))
udp   UNCONN 0      0                                *:54127                    *:*    users:(("avahi-daemon",pid=621,fd=15))
udp   UNCONN 0      0                                *:mdns                     *:*    users:(("avahi-daemon",pid=621,fd=13))
udp   UNCONN 0      0                                *:sunrpc                   *:*    users:(("rpcbind",pid=598,fd=7),("systemd",pid=1,fd=173))
tcp   LISTEN 0      511                      127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=832,fd=29))
tcp   LISTEN 0      511                      127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=832,fd=23))
tcp   LISTEN 0      511                        0.0.0.0:1882               0.0.0.0:*    users:(("io.shelly.0",pid=1373,fd=36))
tcp   LISTEN 0      511                        0.0.0.0:1883               0.0.0.0:*    users:(("io.mqtt.0",pid=2605,fd=35))
tcp   LISTEN 0      511                   192.168.1.41:2010               0.0.0.0:*    users:(("io.hm-rpc.1",pid=1123,fd=35))
tcp   LISTEN 0      511                   192.168.1.41:2001               0.0.0.0:*    users:(("io.hm-rpc.0",pid=1111,fd=35))
tcp   LISTEN 0      4096                       0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=598,fd=4),("systemd",pid=1,fd=170))
tcp   LISTEN 0      128                        0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=844,fd=6))
tcp   LISTEN 0      511                              *:3500                     *:*    users:(("io.sonos.0",pid=1401,fd=31))
tcp   LISTEN 0      511                              *:omniorb                  *:*    users:(("io.terminal.0",pid=1810,fd=35))
tcp   LISTEN 0      511                              *:8093                     *:*    users:(("io.rest-api.0",pid=1699,fd=34))
tcp   LISTEN 0      511                              *:8082                     *:*    users:(("io.web.0",pid=2104,fd=35))
tcp   LISTEN 0      511                              *:tproxy                   *:*    users:(("io.admin.0",pid=888,fd=35))
tcp   LISTEN 0      511                              *:8087                     *:*    users:(("io.simple-api.0",pid=1720,fd=35))
tcp   LISTEN 0      511                              *:8084                     *:*    users:(("io.socketio.0",pid=1746,fd=34))
tcp   LISTEN 0      4096                          [::]:sunrpc                [::]:*    users:(("rpcbind",pid=598,fd=6),("systemd",pid=1,fd=172))
tcp   LISTEN 0      128                           [::]:ssh                   [::]:*    users:(("sshd",pid=844,fd=7))
2026-09-10 21:30:08.486  - info: javascript.0 (917) script.js.Weldscripts.Javascript.Sprit_Benzin: Ende Spritvergleich
2026-09-10 21:30:08.562  - info: javascript.0 (917) script.js.Weldscripts.Javascript.Sprit: Start Spritvergleich
2026-09-10 21:30:08.574  - info: javascript.0 (917) script.js.Weldscripts.Javascript.Sprit: Ende Spritvergleich
2026-09-10 21:30:14.957  - info: hm-rega.0 (1095) request state values
2026-09-10 21:30:15.889  - info: switchbot-cloud.0 (1777) State value to set for "switchbot-cloud.0.FC86276F8B5A.power" has to be type "boolean" but received type "string"
2026-09-10 21:30:25.600  - info: mqtt.0 (2605) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.mqtt, node: v22.23.2, js-controller: 7.2.2
2026-09-10 21:30:26.569  - info: mqtt.0 (2605) Starting MQTT server on 0.0.0.0:1883
2026-09-10 21:30:28.209  - warn: lgtv.0 (1194) [WATCHDOG] No reconnect attempt for 89s while disconnected — recreating LGTV instance
2026-09-10 21:30:28.224  - info: host.iobroker "system.adapter.huum-sauna.0" disabled
2026-09-10 21:30:28.225  - info: host.iobroker stopInstance system.adapter.huum-sauna.0 (force=false, process=true)
2026-09-10 21:30:28.381  - info: host.iobroker stopInstance system.adapter.huum-sauna.0 send kill signal
2026-09-10 21:30:28.385  - info: huum-sauna.0 (1596) Got terminate signal TERMINATE_YOURSELF
2026-09-10 21:30:28.388  - info: huum-sauna.0 (1596) terminating
2026-09-10 21:30:28.393  - info: huum-sauna.0 (1596) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2026-09-10 21:30:28.895  - info: huum-sauna.0 (1596) terminating
2026-09-10 21:30:28.897  - info: huum-sauna.0 (1596) terminating
2026-09-10 21:30:29.497  - info: host.iobroker stopInstance timeout system.adapter.huum-sauna.0 killing pid 1596
2026-09-10 21:30:29.847  - warn: host.iobroker instance system.adapter.huum-sauna.0 terminated due to SIGKILL
2026-09-10 21:30:29.848  - info: host.iobroker instance system.adapter.huum-sauna.0 terminated with code null ()
2026-09-10 21:30:35.268  - info: host.iobroker "system.adapter.info.0" disabled
2026-09-10 21:30:36.591  - info: hm-rega.0 (1095) Updated all datapoints
2026-09-10 21:30:36.752  - info: hm-rega.0 (1095) got 51 variables
2026-09-10 21:30:38.283  - info: host.iobroker "system.adapter.info.0" enabled
2026-09-10 21:30:38.869  - warn: host.iobroker startInstance cannot find adapter "info@2.0.0". Try to install it... 1 attempt
2026-09-10 21:30:38.871  - info: host.iobroker iobroker install info@2.0.0 using installedFrom
</code></pre>
<p dir="auto">============= Mark until here for C&amp;P =============</p>
<p dir="auto">iob diag has finished.</p>
<pre><code></code></pre>
]]></description><link>https://forum.iobroker.net/post/1354535</link><guid isPermaLink="true">https://forum.iobroker.net/post/1354535</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Thu, 10 Sep 2026 19:36:37 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Thu, 10 Sep 2026 17:40:06 GMT]]></title><description><![CDATA[<p dir="auto">mh, das ist komisch! Habe alles wie du es beschreibst mit dem pi imager gemacht! Jetzt weiss ich leider auch nicht weiter, dies selbe SSD läuft bei meinem 2ten Raspi auch</p>
]]></description><link>https://forum.iobroker.net/post/1354523</link><guid isPermaLink="true">https://forum.iobroker.net/post/1354523</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Thu, 10 Sep 2026 17:40:06 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Thu, 10 Sep 2026 17:12:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwedenig" aria-label="Profile: jwedenig">@<bdi>jwedenig</bdi></a></p>
<p dir="auto">Da ich dir nicht über die Schultern geschaut habe kann ich dazu auch nichts sagen.<br />
Grundsätzlich funktioniert das aber eigentlich sehr geschmeidig.</p>
]]></description><link>https://forum.iobroker.net/post/1354518</link><guid isPermaLink="true">https://forum.iobroker.net/post/1354518</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 10 Sep 2026 17:12:29 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Thu, 10 Sep 2026 17:10:45 GMT]]></title><description><![CDATA[<p dir="auto">ich habe jetzt wieder die alte SSD dran, und es klappt auf Anhieb und die grüne Lan LED leuchtet, ist hier ein Problem mit USB 3.0? oder Bootloader (Ki)?</p>
]]></description><link>https://forum.iobroker.net/post/1354516</link><guid isPermaLink="true">https://forum.iobroker.net/post/1354516</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Thu, 10 Sep 2026 17:10:45 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Thu, 10 Sep 2026 16:56:10 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwedenig" aria-label="Profile: jwedenig">@<bdi>jwedenig</bdi></a> <a href="/post/1354509">sagte</a>:</p>
<p dir="auto">sollte beim Lanstecker nicht auch eine grüne Led hin und wieder blinken?</p>
</blockquote>
<p dir="auto">Die vBlinkerei ist bei jedem Pi anders. Musste mal in die Anleitung schauen</p>
]]></description><link>https://forum.iobroker.net/post/1354513</link><guid isPermaLink="true">https://forum.iobroker.net/post/1354513</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 10 Sep 2026 16:56:10 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Thu, 10 Sep 2026 16:48:06 GMT]]></title><description><![CDATA[<p dir="auto">also hostname war iobroker, benutzer wedl also im terminal : ssh wedl@iobroker</p>
]]></description><link>https://forum.iobroker.net/post/1354510</link><guid isPermaLink="true">https://forum.iobroker.net/post/1354510</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Thu, 10 Sep 2026 16:48:06 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Thu, 10 Sep 2026 16:46:27 GMT]]></title><description><![CDATA[<p dir="auto">ich habe es über den hostnamen probiert - negativ, und die Fritzbox findet den Raspi auch nicht, sollte beim Lanstecker nicht auch eine grüne Led hin und wieder blinken?</p>
]]></description><link>https://forum.iobroker.net/post/1354509</link><guid isPermaLink="true">https://forum.iobroker.net/post/1354509</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Thu, 10 Sep 2026 16:46:27 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Thu, 10 Sep 2026 16:42:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwedenig" aria-label="Profile: jwedenig">@<bdi>jwedenig</bdi></a></p>
<p dir="auto">Und über den von dir vergebenen hostname?<br />
Oder über die u.U. von deinem DHCP-Server neuvergebene IP?</p>
]]></description><link>https://forum.iobroker.net/post/1354506</link><guid isPermaLink="true">https://forum.iobroker.net/post/1354506</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 10 Sep 2026 16:42:41 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Thu, 10 Sep 2026 16:18:27 GMT]]></title><description><![CDATA[<p dir="auto">hi! ich habe jetzt das Image auf meine externe SSD geflasht , welche über einen USB Hub mit Stromversorgung angesteckt ist. Leider taucht der Raspi im Netzwerk nicht auf? Er hängt wie vorher an der  LAN Buchse. Die rote Led leuchtet permanent, die grüne blinkt, und beim Lan Anschluss leuchtet nur die Gelbe!</p>
]]></description><link>https://forum.iobroker.net/post/1354500</link><guid isPermaLink="true">https://forum.iobroker.net/post/1354500</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Thu, 10 Sep 2026 16:18:27 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Sat, 05 Sep 2026 15:55:02 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a> <a href="/post/1353775">sagte</a>:</p>
<p dir="auto">Die Meldungen mit under-voltage können auch durch unsauberes herunterfahren kommen.</p>
</blockquote>
<p dir="auto">oder zuviele weitere Geräte, HATs und Erweiterungen dran.<br />
oder einfach Netzteil-Alterung.</p>
]]></description><link>https://forum.iobroker.net/post/1353779</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353779</guid><dc:creator><![CDATA[OliverIO]]></dc:creator><pubDate>Sat, 05 Sep 2026 15:55:02 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Sat, 05 Sep 2026 15:33:25 GMT]]></title><description><![CDATA[<p dir="auto">ok, danke, ich würde mich hier wieder melden, sollten Probleme auftreten, Liebe Grüße Jürgen</p>
]]></description><link>https://forum.iobroker.net/post/1353776</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353776</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Sat, 05 Sep 2026 15:33:25 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Sat, 05 Sep 2026 15:32:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwedenig" aria-label="Profile: jwedenig">@<bdi>jwedenig</bdi></a></p>
]]></description><link>https://forum.iobroker.net/post/1353775</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353775</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 05 Sep 2026 15:32:25 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Sat, 05 Sep 2026 15:30:51 GMT]]></title><description><![CDATA[<p dir="auto">naja, hat halt der Backup Adapter ausgespuckt - das Netztweil ist übrigens ein Original Netzteil, also das auch neu kaufen?</p>
]]></description><link>https://forum.iobroker.net/post/1353774</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353774</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Sat, 05 Sep 2026 15:30:51 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Sat, 05 Sep 2026 15:28:23 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwedenig" aria-label="Profile: jwedenig">@<bdi>jwedenig</bdi></a> <a href="/post/1353772">sagte</a>:</p>
<p dir="auto">mit den 2 Dateien am Computer bin ich mal safe, oder?</p>
</blockquote>
<p dir="auto">Kann ich dir nicht sagen, ob das alles ist.</p>
]]></description><link>https://forum.iobroker.net/post/1353773</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353773</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 05 Sep 2026 15:28:23 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Sat, 05 Sep 2026 15:27:38 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1788622034402-bildschirmfoto-2026-09-05-um-17.26.44.png" alt="Bildschirmfoto 2026-09-05 um 17.26.44.png" class=" img-fluid img-markdown" width="830" height="98" /></p>
]]></description><link>https://forum.iobroker.net/post/1353772</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353772</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Sat, 05 Sep 2026 15:27:38 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Sat, 05 Sep 2026 15:26:07 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwedenig" aria-label="Profile: jwedenig">@<bdi>jwedenig</bdi></a> <a href="/post/1353769">sagte</a>:</p>
<p dir="auto">das funzt auch mit einer SSD über usb?</p>
</blockquote>
<p dir="auto">Das Ziellaufwerk kann ausgesucht werden.</p>
<blockquote>
<p dir="auto">Brauche ich ein anderes Netzteil?</p>
</blockquote>
<p dir="auto">Möglich. Die genannten Meldungen weisen jedenfalls darauf hin.</p>
]]></description><link>https://forum.iobroker.net/post/1353770</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353770</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 05 Sep 2026 15:26:07 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Sat, 05 Sep 2026 15:24:24 GMT]]></title><description><![CDATA[<p dir="auto">danke Dir, das funzt auch mit einer SSD über usb? oder muss ich hier was beachten, da die Anleitung für SD Karte ist? und was meintest du vorher mit Strom checken? Brauche ich ein anderes Netzteil? danke für deine Hilfe</p>
]]></description><link>https://forum.iobroker.net/post/1353769</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353769</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Sat, 05 Sep 2026 15:24:24 GMT</pubDate></item><item><title><![CDATA[Reply to Update Konsolen Pflege on Sat, 05 Sep 2026 15:18:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwedenig" aria-label="Profile: jwedenig">@<bdi>jwedenig</bdi></a></p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht">https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht</a></p>
]]></description><link>https://forum.iobroker.net/post/1353768</link><guid isPermaLink="true">https://forum.iobroker.net/post/1353768</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 05 Sep 2026 15:18:59 GMT</pubDate></item></channel></rss>
