Update Konsolen Pflege
so schauts aus zur Zeit -
*** iob diag is starting up, please wait *** iob diag needs to be updated. Please execute 'iobroker fix' first. -
========== Start marking the full check here =========== ```bash Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 11 (bullseye) Static hostname: raspberrypi Icon name: computer Kernel: Linux 6.1.21-v8+ Architecture: arm64 OS is similar to: Model : Raspberry Pi 4 Model B Rev 1.5 Docker : false Virtualization : none Unknown Kernel : aarch64 Userland : 64bit System was installed 1221 days ago (on 2023-05-03). Systemuptime and Load: 17:00:15 up 36 min, 1 user, load average: 1.37, 1.16, 1.19 CPU threads : 4 *** LIFE CYCLE STATUS *** Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: ~ Under-voltage has occurred ~ Arm frequency capping has occurred ~ Throttling has occurred ~ Soft temperature limit has occurred *** TIME AND TIMEZONES *** Local time: Sat 2026-09-05 17:00:15 CEST Universal time: Sat 2026-09-05 15:00:15 UTC RTC time: n/a Time zone: Europe/Vienna (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker User that is running 'js-controller': js-controller is not running *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 7.8G 112M 6.5G 1.0M 1.2G 7.6G Swap: 99M 0B 99M Total: 7.9G 112M 6.6G Active iob-Instances: 1 7811 M total memory 112 M used memory 333 M active memory 687 M inactive memory 6472 M free memory 167 M buffer memory 1059 M swap cache 99 M total swap 0 M used swap 99 M free swap *** top - Table Of Processes *** top - 17:00:15 up 36 min, 1 user, load average: 1.37, 1.16, 1.19 Tasks: 197 total, 1 running, 196 sleeping, 0 stopped, 0 zombie %Cpu(s): 1.4 us, 2.9 sy, 0.0 ni, 95.7 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 7811.3 total, 6471.7 free, 112.1 used, 1227.5 buff/cache MiB Swap: 100.0 total, 100.0 free, 0.0 used. 7576.4 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * iobroker.service loaded failed failed ioBroker Server LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 14G 15G 48% / devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 1.6G 1.1M 1.6G 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/sda1 vfat 255M 33M 223M 13% /boot tmpfs tmpfs 782M 0 782M 0% /run/user/1000 Messages concerning filesystems in dmesg (Last 15 lines only): [Sat Sep 5 16:23:50 2026] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none. [Sat Sep 5 16:23:50 2026] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [Sat Sep 5 16:23:51 2026] EXT4-fs (sda2): re-mounted. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime `-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 1.7G /var/ 1.4G /var/log 1.3G /var/log/journal/1598db5f087d4d8687cc062072e44690 1.3G /var/log/journal 155M /var/lib Archived and active journals take up 1.2G in the file system. /opt/iobroker/backups: 1.3G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 2.8G /opt/iobroker/iobroker-data/ 2.3G /opt/iobroker/iobroker-data/history 285M /opt/iobroker/iobroker-data/files 195M /opt/iobroker/iobroker-data/backup-objects 61M /opt/iobroker/iobroker-data/files/vis The five largest files in iobroker-data are: 32M /opt/iobroker/iobroker-data/objects.jsonl 7.9M /opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json 7.2M /opt/iobroker/iobroker-data/states.jsonl 7.1M /opt/iobroker/iobroker-data/backup-objects/2026-09-05_15-37_objects.jsonl.gz 7.0M /opt/iobroker/iobroker-data/files/vis/widgets/echarts/static/js/vendors-node_modules_mui_icons-material_esm_index_js.bfab266f.chunk.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 *** ZigBee Settings *** Zigbee Network Settings on your coordinator / in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' -
========== Start marking the full check here =========== ```bash Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 11 (bullseye) Static hostname: raspberrypi Icon name: computer Kernel: Linux 6.1.21-v8+ Architecture: arm64 OS is similar to: Model : Raspberry Pi 4 Model B Rev 1.5 Docker : false Virtualization : none Unknown Kernel : aarch64 Userland : 64bit System was installed 1221 days ago (on 2023-05-03). Systemuptime and Load: 17:00:15 up 36 min, 1 user, load average: 1.37, 1.16, 1.19 CPU threads : 4 *** LIFE CYCLE STATUS *** Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: ~ Under-voltage has occurred ~ Arm frequency capping has occurred ~ Throttling has occurred ~ Soft temperature limit has occurred *** TIME AND TIMEZONES *** Local time: Sat 2026-09-05 17:00:15 CEST Universal time: Sat 2026-09-05 15:00:15 UTC RTC time: n/a Time zone: Europe/Vienna (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker User that is running 'js-controller': js-controller is not running *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 7.8G 112M 6.5G 1.0M 1.2G 7.6G Swap: 99M 0B 99M Total: 7.9G 112M 6.6G Active iob-Instances: 1 7811 M total memory 112 M used memory 333 M active memory 687 M inactive memory 6472 M free memory 167 M buffer memory 1059 M swap cache 99 M total swap 0 M used swap 99 M free swap *** top - Table Of Processes *** top - 17:00:15 up 36 min, 1 user, load average: 1.37, 1.16, 1.19 Tasks: 197 total, 1 running, 196 sleeping, 0 stopped, 0 zombie %Cpu(s): 1.4 us, 2.9 sy, 0.0 ni, 95.7 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 7811.3 total, 6471.7 free, 112.1 used, 1227.5 buff/cache MiB Swap: 100.0 total, 100.0 free, 0.0 used. 7576.4 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * iobroker.service loaded failed failed ioBroker Server LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 14G 15G 48% / devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 1.6G 1.1M 1.6G 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/sda1 vfat 255M 33M 223M 13% /boot tmpfs tmpfs 782M 0 782M 0% /run/user/1000 Messages concerning filesystems in dmesg (Last 15 lines only): [Sat Sep 5 16:23:50 2026] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none. [Sat Sep 5 16:23:50 2026] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [Sat Sep 5 16:23:51 2026] EXT4-fs (sda2): re-mounted. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime `-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 1.7G /var/ 1.4G /var/log 1.3G /var/log/journal/1598db5f087d4d8687cc062072e44690 1.3G /var/log/journal 155M /var/lib Archived and active journals take up 1.2G in the file system. /opt/iobroker/backups: 1.3G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 2.8G /opt/iobroker/iobroker-data/ 2.3G /opt/iobroker/iobroker-data/history 285M /opt/iobroker/iobroker-data/files 195M /opt/iobroker/iobroker-data/backup-objects 61M /opt/iobroker/iobroker-data/files/vis The five largest files in iobroker-data are: 32M /opt/iobroker/iobroker-data/objects.jsonl 7.9M /opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json 7.2M /opt/iobroker/iobroker-data/states.jsonl 7.1M /opt/iobroker/iobroker-data/backup-objects/2026-09-05_15-37_objects.jsonl.gz 7.0M /opt/iobroker/iobroker-data/files/vis/widgets/echarts/static/js/vendors-node_modules_mui_icons-material_esm_index_js.bfab266f.chunk.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 *** ZigBee Settings *** Zigbee Network Settings on your coordinator / in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask'Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
True... Musst du JETZT machen. Hätte schon vor geraumer Zeit passieren müssen.
~ Soft temperature limit has occurredCheck die Stronversorgung.
piVerwende im neuen System einen anderen username, also weder 'pi' noch 'iobroker'. Haste keinen schönen Vornamen?
Die Ausgabe ist aber unvollständig.
========== Start marking the full check here =========== ```bash Script v.2026-08-30 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 11 (bullseye) Static hostname: raspberrypi Icon name: computer Kernel: Linux 6.1.21-v8+ Architecture: arm64 OS is similar to: Model : Raspberry Pi 4 Model B Rev 1.5 Docker : false Virtualization : none Unknown Kernel : aarch64 Userland : 64bit System was installed 1221 days ago (on 2023-05-03). Systemuptime and Load: 17:00:15 up 36 min, 1 user, load average: 1.37, 1.16, 1.19 CPU threads : 4 *** LIFE CYCLE STATUS *** Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: ~ Under-voltage has occurred ~ Arm frequency capping has occurred ~ Throttling has occurred ~ Soft temperature limit has occurred *** TIME AND TIMEZONES *** Local time: Sat 2026-09-05 17:00:15 CEST Universal time: Sat 2026-09-05 15:00:15 UTC RTC time: n/a Time zone: Europe/Vienna (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker User that is running 'js-controller': js-controller is not running *** DISPLAY-SERVER SETUP *** Display-Server: Unknown Display-Manager: Not found Desktop: Session: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 7.8G 112M 6.5G 1.0M 1.2G 7.6G Swap: 99M 0B 99M Total: 7.9G 112M 6.6G Active iob-Instances: 1 7811 M total memory 112 M used memory 333 M active memory 687 M inactive memory 6472 M free memory 167 M buffer memory 1059 M swap cache 99 M total swap 0 M used swap 99 M free swap *** top - Table Of Processes *** top - 17:00:15 up 36 min, 1 user, load average: 1.37, 1.16, 1.19 Tasks: 197 total, 1 running, 196 sleeping, 0 stopped, 0 zombie %Cpu(s): 1.4 us, 2.9 sy, 0.0 ni, 95.7 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 7811.3 total, 6471.7 free, 112.1 used, 1227.5 buff/cache MiB Swap: 100.0 total, 100.0 free, 0.0 used. 7576.4 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * iobroker.service loaded failed failed ioBroker Server LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 14G 15G 48% / devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 1.6G 1.1M 1.6G 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/sda1 vfat 255M 33M 223M 13% /boot tmpfs tmpfs 782M 0 782M 0% /run/user/1000 Messages concerning filesystems in dmesg (Last 15 lines only): [Sat Sep 5 16:23:50 2026] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none. [Sat Sep 5 16:23:50 2026] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [Sat Sep 5 16:23:51 2026] EXT4-fs (sda2): re-mounted. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime `-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 1.7G /var/ 1.4G /var/log 1.3G /var/log/journal/1598db5f087d4d8687cc062072e44690 1.3G /var/log/journal 155M /var/lib Archived and active journals take up 1.2G in the file system. /opt/iobroker/backups: 1.3G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 2.8G /opt/iobroker/iobroker-data/ 2.3G /opt/iobroker/iobroker-data/history 285M /opt/iobroker/iobroker-data/files 195M /opt/iobroker/iobroker-data/backup-objects 61M /opt/iobroker/iobroker-data/files/vis The five largest files in iobroker-data are: 32M /opt/iobroker/iobroker-data/objects.jsonl 7.9M /opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json 7.2M /opt/iobroker/iobroker-data/states.jsonl 7.1M /opt/iobroker/iobroker-data/backup-objects/2026-09-05_15-37_objects.jsonl.gz 7.0M /opt/iobroker/iobroker-data/files/vis/widgets/echarts/static/js/vendors-node_modules_mui_icons-material_esm_index_js.bfab266f.chunk.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 *** ZigBee Settings *** Zigbee Network Settings on your coordinator / in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' === ZigBee Port Overview === Instance Configured Port Available by-id Port Status -------- ---------------- ---------------------------- ------ zigbee.0 ...ngle_Plus_0001-if00-port0 ...ngle_Plus_0001-if00-port0 ✓ Matching *** NodeJS-Installation *** /usr/bin/nodejs v22.23.2 /usr/bin/node v22.23.2 /usr/bin/npm 10.9.8 /usr/bin/npx 10.9.8 ✓ Node.js installation is correct nodejs: Installed: 22.23.2-1nodesource1 Candidate: 22.23.2-1nodesource1 Version table: *** 22.23.2-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 22.23.1-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.23.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.22.3-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.22.2-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.22.1-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.22.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.21.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.20.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.19.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.18.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.17.1-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.17.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.16.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.15.1-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.15.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.14.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.13.1-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.13.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.12.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.11.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.10.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.9.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.8.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.7.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.6.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.5.1-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.5.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.4.1-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.4.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.3.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.2.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.1.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.0.0-1nodesource1 600 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 12.22.12~dfsg-1~deb11u8 500 500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages 12.22.12~dfsg-1~deb11u4 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: No known Vulnerabilities detected! *** ioBroker-Installation *** ioBroker Status iobroker is not running on this host. Objects type: jsonl States type: jsonl Hosts: raspberrypi raspberrypi (version: 7.2.2, hostname: raspberrypi , alive, uptime: 1990) Core adapters versions js-controller: 7.2.2 admin: 8.0.11 javascript: 10.1.3 nodejs modules from github: 9 +-- iobroker.fusionsolar@1.2.4 (git+ssh://git@github.com/KornSW/ioBroker.fusionsolar.git#50f776fd8f991d0832be3d660de7a38a4763093d) +-- iobroker.huum-sauna@0.5.0 (git+ssh://git@github.com/Chris-656/ioBroker.huum-sauna.git#29839546d990296fa85845e0dca5060f2be698ed) +-- iobroker.onkyo@2.1.2 (git+ssh://git@github.com/ioBroker/ioBroker.onkyo.git#c2d620441c632840b9125f08ecd7c5ef06482ead) +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#056daf7c0911a454ee3f4a0f7f3b329cf70222c2) +-- iobroker.switchbot-cloud@0.1.0 (git+ssh://git@github.com/kaschtn/ioBroker.switchbot-cloud.git#35cd79211d153fcbfc492f19d4a38e422b575257) +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/arteck/ioBroker.switchbot-hub.git#666f01f7e8b49322d68d63360322a9f11169911a) +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92) +-- iobroker.vw-connect@0.9.4 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#4321b81482d5d8ce71ce9cf87fe597a069f26852) `-- wake_on_lan@1.0.0 (git+ssh://git@github.com/agnat/node_wake_on_lan.git#dd6404623ccf4bc55b0ba8788ba38312b55435a1) Adapter State system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alexa2.0 : alexa2 : raspberrypi - enabled system.adapter.backitup.0 : backitup : raspberrypi - enabled system.adapter.birthdays.0 : birthdays : raspberrypi - enabled system.adapter.denon.0 : denon : raspberrypi - enabled system.adapter.devices.0 : devices : raspberrypi - disabled system.adapter.discovery.0 : discovery : raspberrypi - enabled system.adapter.echarts.0 : echarts : raspberrypi - enabled system.adapter.energiefluss.0 : energiefluss : raspberrypi - enabled system.adapter.energiefluss.1 : energiefluss : raspberrypi - enabled system.adapter.evcc.0 : evcc : raspberrypi - disabled, port: 7070 system.adapter.fahrplan.0 : fahrplan : raspberrypi - disabled system.adapter.fb-checkpresence.0 : fb-checkpresence : raspberrypi - enabled system.adapter.flot.0 : flot : raspberrypi - disabled system.adapter.fullybrowser.0 : fullybrowser : raspberrypi - enabled system.adapter.fusionsolar.0 : fusionsolar : raspberrypi - enabled system.adapter.go-e.0 : go-e : raspberrypi - enabled system.adapter.heos.0 : heos : raspberrypi - enabled system.adapter.history.0 : history : raspberrypi - enabled system.adapter.hm-rega.0 : hm-rega : raspberrypi - enabled system.adapter.hm-rpc.0 : hm-rpc : raspberrypi - enabled, port: 0 system.adapter.hm-rpc.1 : hm-rpc : raspberrypi - disabled, port: 0 system.adapter.homeconnect.0 : homeconnect : raspberrypi - enabled system.adapter.hue.0 : hue : raspberrypi - enabled, port: 80 system.adapter.huum-sauna.0 : huum-sauna : raspberrypi - disabled system.adapter.ical.0 : ical : raspberrypi - enabled system.adapter.icons-icons8.0 : icons-icons8 : raspberrypi - enabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : raspberrypi - disabled system.adapter.info.0 : info : raspberrypi - enabled system.adapter.iot.0 : iot : raspberrypi - enabled system.adapter.javascript.0 : javascript : raspberrypi - enabled system.adapter.javascript.1 : javascript : raspberrypi - enabled system.adapter.lgtv.0 : lgtv : raspberrypi - enabled system.adapter.linktap.0 : linktap : raspberrypi - enabled system.adapter.meross.0 : meross : raspberrypi - enabled system.adapter.mqtt.0 : mqtt : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 system.adapter.octoprint.0 : octoprint : raspberrypi - enabled system.adapter.onkyo.0 : onkyo : raspberrypi - enabled system.adapter.parser.0 : parser : raspberrypi - enabled system.adapter.ping.0 : ping : raspberrypi - disabled system.adapter.rest-api.0 : rest-api : raspberrypi - enabled, port: 8093, bind: 0.0.0.0, run as: admin system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 system.adapter.simple-api.0 : simple-api : raspberrypi - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.snmp.0 : snmp : raspberrypi - enabled system.adapter.socketio.0 : socketio : raspberrypi - enabled, port: 8084, bind: 0.0.0.0, run as: admin system.adapter.sonos.0 : sonos : raspberrypi - enabled system.adapter.sourceanalytix.0 : sourceanalytix : raspberrypi - enabled system.adapter.spotify-premium.0 : spotify-premium : raspberrypi - enabled system.adapter.switchbot-cloud.0 : switchbot-cloud : raspberrypi - disabled system.adapter.switchbot-hub.0 : switchbot-hub : raspberrypi - enabled system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0 system.adapter.terminal.0 : terminal : raspberrypi - enabled, port: 8088, bind: 192.168.1.41, run as: admin system.adapter.text2command.0 : text2command : raspberrypi - enabled system.adapter.trashschedule.0 : trashschedule : raspberrypi - enabled system.adapter.trashschedule.1 : trashschedule : raspberrypi - enabled system.adapter.vis-bars.0 : vis-bars : raspberrypi - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : raspberrypi - disabled system.adapter.vis-history.0 : vis-history : raspberrypi - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypi - disabled system.adapter.vis-inventwo.0 : vis-inventwo : raspberrypi - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : raspberrypi - disabled system.adapter.vis-justgage.0 : vis-justgage : raspberrypi - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : raspberrypi - disabled system.adapter.vis-metro.0 : vis-metro : raspberrypi - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : raspberrypi - disabled system.adapter.vis.0 : vis : raspberrypi - enabled system.adapter.vw-connect.0 : vw-connect : raspberrypi - enabled system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 + instance is alive Enabled adapters with bindings system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.hm-rpc.0 : hm-rpc : raspberrypi - enabled, port: 0 system.adapter.hue.0 : hue : raspberrypi - enabled, port: 80 system.adapter.mqtt.0 : mqtt : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 system.adapter.rest-api.0 : rest-api : raspberrypi - enabled, port: 8093, bind: 0.0.0.0, run as: admin system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 system.adapter.simple-api.0 : simple-api : raspberrypi - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.socketio.0 : socketio : raspberrypi - enabled, port: 8084, bind: 0.0.0.0, run as: admin system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0 system.adapter.terminal.0 : terminal : raspberrypi - enabled, port: 8088, bind: 192.168.1.41, run as: admin system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters ┌─────────┬─────────────────────────────────────┬──────────────────────┬──────────────────┬────────────────┐ │ (index) │ id │ name │ version │ upgrade policy │ ├─────────┼─────────────────────────────────────┼──────────────────────┼──────────────────┼────────────────┤ │ 0 │ 'system.adapter.admin' │ 'admin' │ '8.0.11' │ 'none' │ │ 1 │ 'system.adapter.alexa2' │ 'alexa2' │ '3.28.3' │ 'none' │ │ 2 │ 'system.adapter.backitup' │ 'backitup' │ '4.0.3' │ 'none' │ │ 3 │ 'system.adapter.birthdays' │ 'birthdays' │ '6.1.0' │ 'none' │ │ 4 │ 'system.adapter.denon' │ 'denon' │ '1.15.12' │ 'none' │ │ 5 │ 'system.adapter.devices' │ 'devices' │ '1.2.14' │ 'none' │ │ 6 │ 'system.adapter.discovery' │ 'discovery' │ '5.0.0' │ 'none' │ │ 7 │ 'system.adapter.echarts' │ 'echarts' │ '3.1.0' │ 'none' │ │ 8 │ 'system.adapter.energiefluss' │ 'energiefluss' │ '3.6.2' │ 'none' │ │ 9 │ 'system.adapter.evcc' │ 'evcc' │ '0.2.4' │ 'none' │ │ 10 │ 'system.adapter.fahrplan' │ 'fahrplan' │ '1.4.1' │ 'none' │ │ 11 │ 'system.adapter.fb-checkpresence' │ 'fb-checkpresence' │ '1.4.2' │ 'none' │ │ 12 │ 'system.adapter.flot' │ 'flot' │ '1.12.0' │ 'none' │ │ 13 │ 'system.adapter.fullybrowser' │ 'fullybrowser' │ '3.1.2' │ 'none' │ │ 14 │ 'system.adapter.fusionsolar' │ 'fusionsolar' │ '1.2.4' │ 'none' │ │ 15 │ 'system.adapter.go-e' │ 'go-e' │ '1.0.41' │ 'none' │ │ 16 │ 'system.adapter.heos' │ 'heos' │ '3.0.4' │ 'none' │ │ 17 │ 'system.adapter.history' │ 'history' │ '4.0.0' │ 'none' │ │ 18 │ 'system.adapter.hm-rega' │ 'hm-rega' │ '5.1.0' │ 'none' │ │ 19 │ 'system.adapter.hm-rpc' │ 'hm-rpc' │ '3.0.1' │ 'none' │ │ 20 │ 'system.adapter.homeconnect' │ 'homeconnect' │ '1.6.1' │ 'none' │ │ 21 │ 'system.adapter.hue' │ 'hue' │ '3.16.2' │ 'none' │ │ 22 │ 'system.adapter.huum-sauna' │ 'huum-sauna' │ '0.5.0' │ 'none' │ │ 23 │ 'system.adapter.ical' │ 'ical' │ '1.21.0' │ 'none' │ │ 24 │ 'system.adapter.icons-icons8' │ 'icons-icons8' │ '0.0.1' │ 'none' │ │ 25 │ 'system.adapter.icons-mfd-svg' │ 'icons-mfd-svg' │ '1.2.0' │ 'none' │ │ 26 │ 'system.adapter.info' │ 'info' │ '2.0.0' │ 'none' │ │ 27 │ 'system.adapter.iot' │ 'iot' │ '6.0.3' │ 'none' │ │ 28 │ 'system.adapter.javascript' │ 'javascript' │ '10.1.3' │ 'none' │ │ 29 │ 'system.adapter.lgtv' │ 'lgtv' │ '2.7.4' │ 'none' │ │ 30 │ 'system.adapter.linktap' │ 'linktap' │ '1.0.3' │ 'none' │ │ 31 │ 'system.adapter.meross' │ 'meross' │ '1.17.0' │ 'none' │ │ 32 │ 'system.adapter.mqtt' │ 'mqtt' │ '6.1.4' │ 'none' │ │ 33 │ 'system.adapter.octoprint' │ 'octoprint' │ '5.1.0' │ 'none' │ │ 34 │ 'system.adapter.onkyo' │ 'onkyo' │ '2.1.2' │ 'none' │ │ 35 │ 'system.adapter.parser' │ 'parser' │ '4.0.1' │ 'none' │ │ 36 │ 'system.adapter.ping' │ 'ping' │ '3.0.1' │ 'none' │ │ 37 │ 'system.adapter.rest-api' │ 'rest-api' │ '4.0.1' │ 'none' │ │ 38 │ 'system.adapter.shelly' │ 'shelly' │ '10.6.1' │ 'none' │ │ 39 │ 'system.adapter.simple-api' │ 'simple-api' │ '3.0.7' │ 'none' │ │ 40 │ 'system.adapter.snmp' │ 'snmp' │ '3.4.0' │ 'none' │ │ 41 │ 'system.adapter.socketio' │ 'socketio' │ '7.1.3' │ 'none' │ │ 42 │ 'system.adapter.sonos' │ 'sonos' │ '3.0.0' │ 'none' │ │ 43 │ 'system.adapter.sourceanalytix' │ 'sourceanalytix' │ '0.4.15-alpha.1' │ 'none' │ │ 44 │ 'system.adapter.spotify-premium' │ 'spotify-premium' │ '3.0.1' │ 'none' │ │ 45 │ 'system.adapter.switchbot-cloud' │ 'switchbot-cloud' │ '0.1.0' │ 'none' │ │ 46 │ 'system.adapter.switchbot-hub' │ 'switchbot-hub' │ '0.1.2' │ 'none' │ │ 47 │ 'system.adapter.telegram' │ 'telegram' │ '5.0.5' │ 'none' │ │ 48 │ 'system.adapter.terminal' │ 'terminal' │ '1.0.0' │ 'none' │ │ 49 │ 'system.adapter.text2command' │ 'text2command' │ '4.0.0' │ 'none' │ │ 50 │ 'system.adapter.trashschedule' │ 'trashschedule' │ '5.3.0' │ 'none' │ │ 51 │ 'system.adapter.vis' │ 'vis' │ '1.5.6' │ 'none' │ │ 52 │ 'system.adapter.vis-bars' │ 'vis-bars' │ '0.1.4' │ 'none' │ │ 53 │ 'system.adapter.vis-canvas-gauges' │ 'vis-canvas-gauges' │ '1.0.1' │ 'none' │ │ 54 │ 'system.adapter.vis-history' │ 'vis-history' │ '1.0.0' │ 'none' │ │ 55 │ 'system.adapter.vis-hqwidgets' │ 'vis-hqwidgets' │ '1.6.1' │ 'none' │ │ 56 │ 'system.adapter.vis-inventwo' │ 'vis-inventwo' │ '4.1.1' │ 'none' │ │ 57 │ 'system.adapter.vis-jqui-mfd' │ 'vis-jqui-mfd' │ '1.1.3' │ 'none' │ │ 58 │ 'system.adapter.vis-justgage' │ 'vis-justgage' │ '2.1.7' │ 'none' │ │ 59 │ 'system.adapter.vis-materialdesign' │ 'vis-materialdesign' │ '0.5.94' │ 'none' │ │ 60 │ 'system.adapter.vis-metro' │ 'vis-metro' │ '1.2.0' │ 'none' │ │ 61 │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2' │ 'none' │ │ 62 │ 'system.adapter.vw-connect' │ 'vw-connect' │ '0.9.4' │ 'none' │ │ 63 │ 'system.adapter.web' │ 'web' │ '8.0.0' │ 'none' │ │ 64 │ 'system.adapter.ws' │ 'ws' │ '4.1.0' │ 'none' │ │ 65 │ 'system.adapter.zigbee' │ 'zigbee' │ '3.5.5' │ 'none' │ └─────────┴─────────────────────────────────────┴──────────────────────┴──────────────────┴────────────────┘ ioBroker-Adapter Versions and update status Used repository: stable Adapter "admin" : 8.0.11 , installed 8.0.11 Adapter "alexa2" : 3.28.3 , installed 3.28.3 Adapter "backitup" : 4.0.3 , installed 4.0.3 Adapter "birthdays" : 6.1.0 , installed 6.1.0 Adapter "denon" : 1.15.12 , installed 1.15.12 Adapter "devices" : 1.2.14 , installed 1.2.14 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "echarts" : 3.1.0 , installed 3.1.0 Adapter "energiefluss" : 3.6.2 , installed 3.6.2 Adapter "evcc" : 0.2.4 , installed 0.2.4 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "fullybrowser" : 3.1.2 , installed 3.1.2 Adapter "go-e" : 1.0.41 , installed 1.0.41 Adapter "heos" : 3.0.4 , installed 3.0.4 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "hm-rega" : 5.1.0 , installed 5.1.0 Adapter "hm-rpc" : 3.0.1 , installed 3.0.1 Adapter "homeconnect" : 1.6.1 , installed 1.6.1 Adapter "hue" : 3.16.2 , installed 3.16.2 Adapter "huum-sauna" : 0.5.0 , installed 0.5.0 Adapter "ical" : 1.21.0 , installed 1.21.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "iot" : 6.0.3 , installed 6.0.3 Adapter "javascript" : 10.1.3 , installed 10.1.3 Controller "js-controller": 7.2.2 , installed 7.2.2 Adapter "lgtv" : 2.7.4 , installed 2.7.4 Adapter "linktap" : 1.0.3 , installed 1.0.3 Adapter "meross" : 1.17.0 , installed 1.17.0 Adapter "mqtt" : 6.1.4 , installed 6.1.4 Adapter "octoprint" : 5.1.0 , installed 5.1.0 Adapter "onkyo" : 2.1.2 , installed 2.1.2 Adapter "parser" : 4.0.1 , installed 4.0.1 Adapter "ping" : 3.0.1 , installed 3.0.1 Adapter "rest-api" : 4.0.1 , installed 4.0.1 Adapter "shelly" : 10.6.1 , installed 10.6.1 Adapter "simple-api" : 3.0.7 , installed 3.0.7 Adapter "snmp" : 3.4.0 , installed 3.4.0 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "sonos" : 3.0.0 , installed 3.0.0 Adapter "spotify-premium": 3.0.1 , installed 3.0.1 Adapter "telegram" : 5.0.5 , installed 5.0.5 Adapter "terminal" : 1.0.0 , installed 1.0.0 Adapter "text2command" : 4.0.0 , installed 4.0.0 Adapter "trashschedule": 5.3.0 , installed 5.3.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.6.1 , installed 1.6.1 Adapter "vis-inventwo" : 4.1.1 , installed 4.1.1 Adapter "vis-jqui-mfd" : 1.1.3 , installed 1.1.3 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-materialdesign": 0.5.9, installed 0.5.94 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "ws" : 4.1.0 , installed 4.1.0 Adapter "zigbee" : 3.5.5 , installed 3.5.5 Objects and States Please stand by - This may take a while Objects: 22557 States: 18991 *** OS-Repositories and Updates *** Hit:1 http://security.debian.org/debian-security bullseye-security InRelease Hit:2 http://deb.debian.org/debian bullseye InRelease Hit:3 http://deb.debian.org/debian bullseye-updates InRelease Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease Reading package lists... Pending systemupdates: 3 *** Listening Ports *** Netid State Recv-Q Send-Q Local Address:Port Peer Address:PortProcess udp UNCONN 0 0 0.0.0.0:44371 0.0.0.0:* users:(("avahi-daemon",pid=395,fd=14)) udp UNCONN 0 0 0.0.0.0:bootpc 0.0.0.0:* users:(("dhcpcd",pid=786,fd=13)) udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:* users:(("avahi-daemon",pid=395,fd=12)) udp UNCONN 0 0 *:38790 *:* users:(("avahi-daemon",pid=395,fd=15)) udp UNCONN 0 0 *:dhcpv6-client *:* users:(("dhcpcd",pid=786,fd=16)) udp UNCONN 0 0 *:mdns *:* users:(("avahi-daemon",pid=395,fd=13)) tcp LISTEN 0 128 0.0.0.0:ssh 0.0.0.0:* users:(("sshd",pid=526,fd=3)) tcp LISTEN 0 128 [::]:ssh [::]:* users:(("sshd",pid=526,fd=4)) *** Log File - Last 25 Lines *** 2026-09-05 16:57:24.951 - warn: host.raspberrypi instance system.adapter.trashschedule.0 terminated due to SIGKILL 2026-09-05 16:57:24.952 - info: host.raspberrypi instance system.adapter.trashschedule.0 terminated with code null () 2026-09-05 16:57:24.952 - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGKILL 2026-09-05 16:57:24.952 - info: host.raspberrypi instance system.adapter.web.0 terminated with code null () 2026-09-05 16:57:24.994 - warn: host.raspberrypi instance system.adapter.go-e.0 terminated due to SIGKILL 2026-09-05 16:57:24.994 - info: host.raspberrypi instance system.adapter.go-e.0 terminated with code null () 2026-09-05 16:57:25.032 - warn: host.raspberrypi instance system.adapter.vw-connect.0 terminated due to SIGKILL 2026-09-05 16:57:25.033 - info: host.raspberrypi instance system.adapter.vw-connect.0 terminated with code null () 2026-09-05 16:57:25.092 - warn: host.raspberrypi instance system.adapter.trashschedule.1 terminated due to SIGKILL 2026-09-05 16:57:25.092 - info: host.raspberrypi instance system.adapter.trashschedule.1 terminated with code null () 2026-09-05 16:57:25.164 - warn: host.raspberrypi instance system.adapter.simple-api.0 terminated due to SIGKILL 2026-09-05 16:57:25.165 - info: host.raspberrypi instance system.adapter.simple-api.0 terminated with code null () 2026-09-05 16:57:25.295 - warn: host.raspberrypi instance system.adapter.linktap.0 terminated due to SIGKILL 2026-09-05 16:57:25.296 - info: host.raspberrypi instance system.adapter.linktap.0 terminated with code null () 2026-09-05 16:57:25.298 - warn: host.raspberrypi instance system.adapter.rest-api.0 terminated due to SIGKILL 2026-09-05 16:57:25.299 - info: host.raspberrypi instance system.adapter.rest-api.0 terminated with code null () 2026-09-05 16:57:25.346 - warn: host.raspberrypi instance system.adapter.alexa2.0 terminated due to SIGKILL 2026-09-05 16:57:25.347 - info: host.raspberrypi instance system.adapter.alexa2.0 terminated with code null () 2026-09-05 16:57:25.762 - info: host.raspberrypi instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR) 2026-09-05 16:57:25.802 - warn: host.raspberrypi instance system.adapter.meross.0 terminated due to SIGKILL 2026-09-05 16:57:25.802 - info: host.raspberrypi instance system.adapter.meross.0 terminated with code null () 2026-09-05 16:57:25.873 - info: host.raspberrypi instance system.adapter.history.0 terminated with code 0 (NO_ERROR) 2026-09-05 16:57:26.068 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR) 2026-09-05 16:57:26.068 - info: host.raspberrypi All instances are stopped. 2026-09-05 16:57:26.248 - info: host.raspberrypi terminated============= Mark until here for C&P =============
iob diag has finished.
pi@raspberrypi:~ $ iobroker fix
ok, ich bestelle mir zuerst eine neue SSD, möchte nichts löschen, und dann gehe ich es an. Ich mache zwar regelmäßig update/upgrade, aber wann das Betriebssystem fällig ist bekomme ich nicht mit! Wie kann ich dies in Zukunft verbessern. Bin halt nicht ständig in Foren unterwegs nach dem Motto - wenn alles läuft dann läufts!
In iob diag gibt es dazu einen Check der Lebenszeit:
Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!Sollte bei dir in Rot erscheinen. Das aktuelle stable-Release wird in grüner Schrift gemeldet und wenn es Zeit wird weiter zu ziehen wird das sog. oldstable (also der Vorgänger zur aktuellen stable) in Gelb gemeldet.
Alles was nicht grün ist muss angepackt werden. -
ok, danke, wo finde ich hier von Dir die beste Methode zum Installieren? Es gibt ja haufenweise Install-Tipps, ich hätte gerne DEINE
danke Dir, das funzt auch mit einer SSD über usb? oder muss ich hier was beachten, da die Anleitung für SD Karte ist? und was meintest du vorher mit Strom checken? Brauche ich ein anderes Netzteil? danke für deine Hilfe
mit den 2 Dateien am Computer bin ich mal safe, oder?
naja, hat halt der Backup Adapter ausgespuckt - das Netztweil ist übrigens ein Original Netzteil, also das auch neu kaufen?
Die Meldungen mit under-voltage können auch durch unsauberes herunterfahren kommen.
ok, danke, ich würde mich hier wieder melden, sollten Probleme auftreten, Liebe Grüße Jürgen
M mcm1957 verschob dieses Thema von Error/Bug am
hi! ich habe jetzt das Image auf meine externe SSD geflasht , welche über einen USB Hub mit Stromversorgung angesteckt ist. Leider taucht der Raspi im Netzwerk nicht auf? Er hängt wie vorher an der LAN Buchse. Die rote Led leuchtet permanent, die grüne blinkt, und beim Lan Anschluss leuchtet nur die Gelbe!
