  4. Node.js update bei 32Bit System hat node entfernt
37 Beiträge 5 Kommentatoren 10.4k Aufrufe 4 Beobachtet
  • Z
    Z
    ZockerFloh7
    *** iob diag is starting up, please wait ***
    iob diag needs to be updated. Please execute 'iobroker fix' first.
    ^C
    pi@raspberrypi:~ $ iobroker fix
    library: loaded
    Library version=2026-04-11
        Welcome to the ioBroker installation fixer!
        Script version: 2025-09-18
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:3 https://apt.pivccu.de/piVCCU stable InRelease [13.6 kB]
    Fetched 13.6 kB in 1s (15.6 kB/s)
    Reading package lists... Done
    E: Unable to locate package polkitd
    Installed polkitd
        Checking ioBroker user and directory permissions (2/5)
    ACL enabled: true
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
    Authentication is required to stop 'iobroker.service'.
    Authenticating as: ,,, (pi)
    Password: polkit-agent-helper-1: pam_authenticate failed: Authentication failure
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    • Z
      Z
      ZockerFloh7
      ```bash
      Script v.2026-06-01
      *** BASE SYSTEM ***
      Operating System: Raspbian GNU/Linux 11 (bullseye)
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      OS is similar to: debian
      Model           : Raspberry Pi 4 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32bit
      System was installed 2013 days ago (on 2020-12-07).
      Outdated 32Bit architecture detected. Only a pure 64Bit-System will be supported in the future. You will have to reinstall your operating system with full 64Bit support or upgrade to more modern hardware soon.
      Systemuptime and Load:
       18:09:20 up  1:38,  1 user,  load average: 0.58, 0.54, 0.55
      CPU threads     : 4
      *** LIFE CYCLE STATUS ***
      ERROR: Package 'distro-info' is not installed. Please do:
      sudo apt update && sudo apt install distro-info
      Alternatively execute the 'iob fix'
      • Z
        Z
        ZockerFloh7
        pi@raspberrypi:~ $
        apt policy distro-info distro-info-data
        distro-info:
          Installed: 1.0+deb11u1
          Candidate: 1.0+deb11u1
          Version table:
         *** 1.0+deb11u1 500
        distro-info-data:
          Installed: 0.51+deb11u11
          Candidate: 0.51+deb11u11
          Version table:
         *** 0.51+deb11u11 500
        • Z ZockerFloh7
          pi@raspberrypi:~ $
          distro-info:
            Version table:
           *** 1.0+deb11u1 500
          distro-info-data:
            Version table:
          Thomas BraunT
          Thomas BraunT
          Most Active Developer
          @ZockerFloh7
          Wie dem auch sei. Alles krum und schief bei dir.
          NEUINSTALLATION von RaspberryOS 13 'Trixie' JETZT,
          Backup des iobroker einspielen, fertig.
          • Z
            Z
            ZockerFloh7
            Alles klar, danke für die Hilfe
              @ZockerFloh7 sagte:
              es sagt alles passt
              Bitte zeigen!
              Homoran sagte:
              es sagt alles passt
              Sagt es nicht!
              @ZockerFloh7 sagte:
                Homoran sagte:
                es sagt alles passt
                Sagt es nicht!
                @ZockerFloh7 sagte:
                Thomas BraunT
                Thomas BraunT
                @Homoran
                Eher noch relevant ist das fehlende polkitd
                Installed polkitd
                  @Homoran
                  Installed polkitd
                  @Thomas-Braun ja aber selbst danach immer noch auth failure
                    Thomas BraunT
                    Thomas BraunT
                    @Homoran sagte:
                    failure
                    Das kannste aber auf das gesamte System beziehen. Failure vorne wie hinten.
                    • Z
                      Z
                      ZockerFloh7
                      Password:
                      ==== AUTHENTICATION COMPLETE ===
                      Autostart enabled!
                      hatte nur das pw falsch
                      • Z ZockerFloh7
                        Password:
                        Autostart enabled!
                        @ZockerFloh7 sagte:
                        Also läuft jetzt alles wieder?
                        Incl nodejs22?
                        Z 1 Antwort Letzte Antwort
                          @ZockerFloh7 sagte:
                          Incl nodejs22?
                          Z
                          Z
                          ZockerFloh7
                          @Homoran sagte:
                          @ZockerFloh7 sagte:
                          Incl nodejs22?
                          Ja, aber nodejs20
                          Ich werd die Tage auf 64Bit wechseln...
                          • Z ZockerFloh7
                            @Homoran sagte:
                            @ZockerFloh7 sagte:
                            Incl nodejs22?
                            Ja, aber nodejs20
                            @ZockerFloh7 sagte:
                            Aber beeil dich, bevor dein 5 1/2 Jahre irgend wie am "Leben" gezwungenes System seinen letzten Atemzug macht.
                            • Z
                              Z
                              ZockerFloh7
                              mach ich, danke 👍
                              • Z ZockerFloh7
                                mach ich, danke 👍
                                Thomas BraunT
                                Thomas BraunT
                                @ZockerFloh7
                                Und bevor du wieder 'irgendwas' 'irgendwie' machst...
                                Mach es danach:
                                https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                • Z
                                  Z
                                  ZockerFloh7
                                  Danke für den Tip
                                  • Z
                                    Z
                                    ZockerFloh7
                                    Migration ging gut, die Anleitung für pivccu ist aber outdatet.
                                    Wenns wer braucht, hier sind die steps beschrieben: https://homematic-forum.de/forum/viewtopic.php?f=69&t=86504&start=20
                                    • Z ZockerFloh7
                                      Thomas BraunT
                                      Thomas BraunT
                                      @ZockerFloh7 sagte:
                                      Schaut beim ersten Querlesen aber auch 'komisch' aus.
                                      Warum nicht direkt die offizielle Anleitung?
                                      https://github.com/alexreinert/piVCCU/blob/master/docs/setup/raspberrypi.md
                                      • G
                                        G
                                        günni1955
                                        Das Problem hatte ich auch. Hab dann das Repository wo der Pfad zu Nodejs 20.x drin steht aktualisiert. Die Zeile mit 20,x kopiert. eingefügt und 20.x auf 22.x geändert.
                                        dann System update und full-upgrade und reboot. Dann war alles gut.
                                        • G günni1955
                                          mcm1957M
                                          mcm1957M
                                          mcm1957
                                          MUTIG würd ich sagen...
                                          Von node.js 22 auf einem 32 Bit (wahrscheinlich Uralt-)System wird wohl abgeraten. Bring dein System mal auf Stand. Erste Adapetr erfordern bereist minimal node.js 24 (= current, ab Oktober im maintancemode)
                                          Support Repositoryverwaltung.
                                          LESEN - gute Forenbeitrage
                                          84.1k
