  4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
    1.0k
1.6k Beiträge 101 Kommentatoren 759.2k Aufrufe 95 Beobachtet
  • F Offline
    Fichte
    #1509
    Hallo ihr zwei
    Gibt es dann noch ein Update vom Adapter oder über Beta installieren?
    LG
    • F Fichte
      Hallo ihr zwei
      LG
      arteckA Offline
      arteckA Offline
      arteck
      #1510
      @fichte installier den über GIT
        tippy88
        #1511
        Kann mir jemand helfen, warum der Device Watcher im Ping Adapter keine Geräte findet?
        Vers 2.13.1
        device-watcher.1
        2025-10-28 10:20:30.227	debug	Number of selected days for daily offline devices message: 1. Send Message on: 2 ...
        device-watcher.1
        2025-10-28 10:20:30.179	debug	Start the function writeDatapoints
        device-watcher.1
        2025-10-28 10:20:30.179	debug	Function finished: main
        device-watcher.1
        2025-10-28 10:20:30.178	debug	Created and filled data for all adapters
        device-watcher.1
        2025-10-28 10:20:30.127	debug	Start the function writeDatapoints
        device-watcher.1
        2025-10-28 10:20:30.105	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        device-watcher.1
        2025-10-28 10:20:30.101	debug	Function started main
        device-watcher.1
        2025-10-28 10:20:29.843	debug	Start the function createBlacklist
        device-watcher.1
        2025-10-28 10:20:29.843	info	Number of selected adapters to monitor devices: 1. Loading data from: Ping ...
        device-watcher.1
        2025-10-28 10:20:29.843	debug	[{"Selektor":"ping.*.alive","timeSelector":".alive","adapterID":"ping","adapter":"Ping","battery":"none","reach":".alive","isLowBat":"none"}]
        device-watcher.1
        2025-10-28 10:20:29.842	debug	Set language to de
        device-watcher.1
        2025-10-28 10:20:29.842	debug	Adapter device-watcher was started
        ilovegymI 1 Antwort Letzte Antwort
        • T tippy88
          Vers 2.13.1
          device-watcher.1
          device-watcher.1
          device-watcher.1
          device-watcher.1
          device-watcher.1
          device-watcher.1
          device-watcher.1
          device-watcher.1
          device-watcher.1
          device-watcher.1
          device-watcher.1
          device-watcher.1
          ilovegymI Offline
          ilovegymI Offline
          ilovegym
          #1512
          @tippy88
          im Ping-Adapter "Erweiterte Informationen" angeklickt?
          • ilovegymI ilovegym
            @tippy88
            tippy88
            #1513
            @ilovegym said in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
            @tippy88
            Nein, ist irgendwo dokumentiert dass dies erforderlich ist und ich habe es überlesen?
            • T tippy88
              @tippy88
              ilovegymI Offline
              ilovegymI Offline
              ilovegym
              #1514
              @tippy88 keine ahnung, ich kann dir nur sagen, dass es bei mir so funktioniert. Probiers doch mal aus, mehr wie alles zerschiessen und dir dein Server loeschen, abfackeln und sprengen kann sowieso nicht passieren.. :)
              • arteckA Offline
                arteckA Offline
                arteck
                #1515
                ich habe mal ein paar Anpassungen gemacht
                unter anderem paar issues korrigiert
                * (arteck) Dependencies have been fixed
                * (arteck) ping adapter have been fixed
                * (arteck) optimisations for adapter without info.connection state
                * (arteck) clean code
                * (arteck) silent notification for telegram
                * (arteck) add matter devices
                wer lust hat mal was zum Testen.. bitte aber nicht auf Produktiven System da sich die Struktur geändert hat und ihr ohne Backup nicht zurück kommt
                so sieht jetzt der einstieg aus
                leider müsst ihr die Überwachten Adapter neu einstellen. ich musste bissel Aufräumen..
                GIT -> https://github.com/iobroker-community-adapters/ioBroker.device-watcher/tarball/silentTelegram
                S 2 Antworten Letzte Antwort
                • arteckA arteck
                  S Abwesend
                  S Abwesend
                  Shadowhunter23
                  #1516
                  @arteck said in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
                  Wäre es nicht sinnvoll das löschen der Einstellungen zu kennzeichnen?
                  Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                  ioBroker Backup Analyzer
                  • S Shadowhunter23
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #1517
                    @Shadowhunter23 man bekommt eine message.. leider nicht wenn du über git installierst.
                    Merlin123M S 2 Antworten Letzte Antwort
                    • arteckA arteck
                      Merlin123M Offline
                      Merlin123M Offline
                      Merlin123
                      #1518
                      @arteck Auch bei dem normalen Update kommt nur die Meldung aus dem Screenshot bevor man aktualisiert.
                      Beta-Tester
                      • arteckA arteck
                        S Abwesend
                        S Abwesend
                        Shadowhunter23
                        #1519
                        Ich hab normal per Update installiert und nicht per git
                        • arteckA arteck
                          S Abwesend
                          S Abwesend
                          Shadowhunter23
                          schrieb am zuletzt editiert von Shadowhunter23
                          #1520
                          Vorher waren die Offlinezeit in Minuten angegeben, hat das einen speziellen Grund dass es nun Sekunden sind?
                          • arteckA Offline
                            arteckA Offline
                            arteck
                            #1521
                            ja es wurde einmal so und einmal so im Adapter angegeben.. ich wollte es einheitlich haben..
                            wo ist das Problem ???
                            • S Abwesend
                              S Abwesend
                              Shadowhunter23
                              #1522
                              Probleme gibt es keine. Mir waren die Minuten Angaben nur angenehmer. Aber alles gut.
                              • JLegJ Offline
                                JLegJ Offline
                                JLeg
                                schrieb am zuletzt editiert von JLeg
                                #1523
                                in der neuen Version sind ja die "Offlinezeiten" ja aus den "Experteneinstellungen" direkt nach vorne zu den gelisteten Adaptern gewandert - finde ich sehr gut.
                                Allerdings ist imo nun nicht ganz klar, ob die ursprüngliche Bedeutung gleich geblieben ist:
                                • der alte Default war "-1" - jetzt ist er "0"
                                • in der alten Version musste man explizit "0" konfigurieren, wenn "Sie die Datenpunkte der Geräte (alive, online,...) direkt zur Statusermittlung nutzen möchten"
                                => das bedeutet, für das "alte" Verhalten muss man nun andersrum explizit "-1" setzen, oder hat sich der Default nur "gedreht"?
                                Edit: gerade erst gesehen - diese Fehlermeldungen tröpfeln nach dem Update ins Log:
                                2025-11-17 14:08:47.434  - error: device-watcher.0 (3730144) Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                2025-11-17 14:09:02.544  - error: device-watcher.0 (3730144) Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                • arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #1524
                                  -1 und 0 waren im alten Adapter gleichgestellt.. also nur Optik..
                                  für die Fehlermeldung brauch ich die Einstellungen des Adapter.. als screenshot bitte
                                  • JLegJ Offline
                                    JLegJ Offline
                                    JLeg
                                    #1525
                                    ...ich habe mal versucht, das möglichst "kompakt" hinzukriegen:
                                    aktivierte Instanzen: fritzdect, shelly, sonoff, zigbee
                                    nicht Sichtbares = leer bzw. Default
                                      deta
                                      schrieb am zuletzt editiert von deta
                                      #1526
                                      habe den Adapter nach Anleitung installiert.
                                      Nun wollte ich über Grafana mir das Anzeigen lassen.
                                      https://github.com/iobroker-community-adapters/ioBroker.device-watcher/blob/main/docs/de/grafana_flux.md
                                      Auch hier alles gemacht.
                                      Funktioniert auch soweit.
                                      Frage wie bekomme ich das so angezeigt?
                                      Wo muss ich was einstellen. Versuche das schon den ganzen Tag.
                                      Also diese combi.
                                      cu Deta
                                        Maxtor62
                                        #1527
                                        Hallo, Habe den Adapter auch mal Installiert. Komme mit den Fehlermeldungen nicht klar.
                                        device-watcher.0
                                        2025-12-12 16:15:00.189	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                        device-watcher.0
                                        2025-12-12 16:14:45.142	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                        device-watcher.0
                                        2025-12-12 16:14:30.142	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                        device-watcher.0
                                        2025-12-12 16:14:15.141	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                        device-watcher.0
                                        2025-12-12 16:14:00.140	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                        device-watcher.0
                                        2025-12-12 16:13:45.139	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                        device-watcher.0
                                        2025-12-12 16:13:30.142	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                        device-watcher.0
                                        2025-12-12 16:13:15.139	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                        device-watcher.0
                                        2025-12-12 16:13:00.140	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                        device-watcher.0
                                        2025-12-12 16:12:45.139	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                        device-watcher.0
                                        2025-12-12 16:12:30.143	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                        device-watcher.0
                                        2025-12-12 16:12:15.138	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                        device-watcher.0
                                        2025-12-12 16:12:12.127	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                        device-watcher.0
                                        2025-12-12 16:12:12.076	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                        device-watcher.0
                                        2025-12-12 16:12:12.074	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                        device-watcher.0
                                        2025-12-12 16:12:12.055	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                        device-watcher.0
                                        2025-12-12 16:12:12.048	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                        device-watcher.0
                                        2025-12-12 16:12:12.036	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                        device-watcher.0
                                        2025-12-12 16:12:12.029	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                        device-watcher.0
                                        2025-12-12 16:12:00.142	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                        device-watcher.0
                                        2025-12-12 16:11:45.137	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                        device-watcher.0
                                        2025-12-12 16:11:42.126	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                        device-watcher.0
                                        2025-12-12 16:11:42.077	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                        device-watcher.0
                                        2025-12-12 16:11:42.076	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                        device-watcher.0
                                        2025-12-12 16:11:42.060	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                        device-watcher.0
                                        2025-12-12 16:11:42.056	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                        device-watcher.0
                                        2025-12-12 16:11:42.048	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                        device-watcher.0
                                        2025-12-12 16:11:42.042	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                        Was mach ich falsch?
                                        Wer meint er ist was, hat aufgehört was zu werden
                                        • S Abwesend
                                          S Abwesend
                                          Shadowhunter23
                                          #1528
                                          https://github.com/iobroker-community-adapters/ioBroker.device-watcher/issues/575
