  4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
1.6k Beiträge 101 Kommentatoren 728.9k Aufrufe 95 Beobachtet
  • F Fichte
    Hallo ihr zwei
    Gibt es dann noch ein Update vom Adapter oder über Beta installieren?
    LG
    arteckA Offline
    arteckA Offline
    arteck
    #1510
    @fichte installier den über GIT
      tippy88
      #1511
      Kann mir jemand helfen, warum der Device Watcher im Ping Adapter keine Geräte findet?
      Vers 2.13.1
      device-watcher.1
      2025-10-28 10:20:30.227	debug	Number of selected days for daily offline devices message: 1. Send Message on: 2 ...
      device-watcher.1
      2025-10-28 10:20:30.179	debug	Start the function writeDatapoints
      device-watcher.1
      2025-10-28 10:20:30.179	debug	Function finished: main
      device-watcher.1
      2025-10-28 10:20:30.178	debug	Created and filled data for all adapters
      device-watcher.1
      2025-10-28 10:20:30.127	debug	Start the function writeDatapoints
      device-watcher.1
      2025-10-28 10:20:30.105	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      device-watcher.1
      2025-10-28 10:20:30.101	debug	Function started main
      device-watcher.1
      2025-10-28 10:20:29.843	debug	Start the function createBlacklist
      device-watcher.1
      2025-10-28 10:20:29.843	info	Number of selected adapters to monitor devices: 1. Loading data from: Ping ...
      device-watcher.1
      2025-10-28 10:20:29.843	debug	[{"Selektor":"ping.*.alive","timeSelector":".alive","adapterID":"ping","adapter":"Ping","battery":"none","reach":".alive","isLowBat":"none"}]
      device-watcher.1
      2025-10-28 10:20:29.842	debug	Set language to de
      device-watcher.1
      2025-10-28 10:20:29.842	debug	Adapter device-watcher was started
      ilovegymI 1 Antwort Letzte Antwort
      • T tippy88
        Vers 2.13.1
        device-watcher.1
        device-watcher.1
        device-watcher.1
        device-watcher.1
        device-watcher.1
        device-watcher.1
        device-watcher.1
        device-watcher.1
        device-watcher.1
        device-watcher.1
        device-watcher.1
        device-watcher.1
        ilovegymI Offline
        ilovegymI Offline
        ilovegym
        #1512
        @tippy88
        im Ping-Adapter "Erweiterte Informationen" angeklickt?
        • ilovegymI ilovegym
          @tippy88
          tippy88
          #1513
          @ilovegym said in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
          @tippy88
          Nein, ist irgendwo dokumentiert dass dies erforderlich ist und ich habe es überlesen?
          • T tippy88
            @tippy88
            ilovegymI Offline
            ilovegymI Offline
            ilovegym
            #1514
            @tippy88 keine ahnung, ich kann dir nur sagen, dass es bei mir so funktioniert. Probiers doch mal aus, mehr wie alles zerschiessen und dir dein Server loeschen, abfackeln und sprengen kann sowieso nicht passieren.. :)
            • arteckA Offline
              arteckA Offline
              arteck
              #1515
              ich habe mal ein paar Anpassungen gemacht
              unter anderem paar issues korrigiert
              * (arteck) Dependencies have been fixed
              * (arteck) ping adapter have been fixed
              * (arteck) optimisations for adapter without info.connection state
              * (arteck) clean code
              * (arteck) silent notification for telegram
              * (arteck) add matter devices
              wer lust hat mal was zum Testen.. bitte aber nicht auf Produktiven System da sich die Struktur geändert hat und ihr ohne Backup nicht zurück kommt
              so sieht jetzt der einstieg aus
              leider müsst ihr die Überwachten Adapter neu einstellen. ich musste bissel Aufräumen..
              GIT -> https://github.com/iobroker-community-adapters/ioBroker.device-watcher/tarball/silentTelegram
              S 2 Antworten Letzte Antwort
              • arteckA arteck
                S Abwesend
                S Abwesend
                Shadowhunter23
                #1516
                @arteck said in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
                Wäre es nicht sinnvoll das löschen der Einstellungen zu kennzeichnen?
                Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                ioBroker Backup Analyzer
                • S Shadowhunter23
                  arteckA Offline
                  arteckA Offline
                  arteck
                  #1517
                  @Shadowhunter23 man bekommt eine message.. leider nicht wenn du über git installierst.
                  Merlin123M S 2 Antworten Letzte Antwort
                  • arteckA arteck
                    Merlin123M Offline
                    Merlin123M Offline
                    Merlin123
                    #1518
                    @arteck Auch bei dem normalen Update kommt nur die Meldung aus dem Screenshot bevor man aktualisiert.
                    Beta-Tester
                    • arteckA arteck
                      S Abwesend
                      S Abwesend
                      Shadowhunter23
                      #1519
                      Ich hab normal per Update installiert und nicht per git
                      • arteckA arteck
                        S Abwesend
                        S Abwesend
                        Shadowhunter23
                        schrieb am zuletzt editiert von Shadowhunter23
                        #1520
                        Vorher waren die Offlinezeit in Minuten angegeben, hat das einen speziellen Grund dass es nun Sekunden sind?
                        • arteckA Offline
                          arteckA Offline
                          arteck
                          #1521
                          ja es wurde einmal so und einmal so im Adapter angegeben.. ich wollte es einheitlich haben..
                          wo ist das Problem ???
                          • S Abwesend
                            S Abwesend
                            Shadowhunter23
                            #1522
                            Probleme gibt es keine. Mir waren die Minuten Angaben nur angenehmer. Aber alles gut.
                            • JLegJ Offline
                              JLegJ Offline
                              JLeg
                              schrieb am zuletzt editiert von JLeg
                              #1523
                              in der neuen Version sind ja die "Offlinezeiten" ja aus den "Experteneinstellungen" direkt nach vorne zu den gelisteten Adaptern gewandert - finde ich sehr gut.
                              Allerdings ist imo nun nicht ganz klar, ob die ursprüngliche Bedeutung gleich geblieben ist:
                              • der alte Default war "-1" - jetzt ist er "0"
                              • in der alten Version musste man explizit "0" konfigurieren, wenn "Sie die Datenpunkte der Geräte (alive, online,...) direkt zur Statusermittlung nutzen möchten"
                              => das bedeutet, für das "alte" Verhalten muss man nun andersrum explizit "-1" setzen, oder hat sich der Default nur "gedreht"?
                              Edit: gerade erst gesehen - diese Fehlermeldungen tröpfeln nach dem Update ins Log:
                              2025-11-17 14:08:47.434  - error: device-watcher.0 (3730144) Issue at state change: TypeError: Cannot read properties of null (reading '1')
                              2025-11-17 14:09:02.544  - error: device-watcher.0 (3730144) Issue at state change: TypeError: Cannot read properties of null (reading '1')
                              • arteckA Offline
                                arteckA Offline
                                arteck
                                #1524
                                -1 und 0 waren im alten Adapter gleichgestellt.. also nur Optik..
                                für die Fehlermeldung brauch ich die Einstellungen des Adapter.. als screenshot bitte
                                • JLegJ Offline
                                  JLegJ Offline
                                  JLeg
                                  #1525
                                  ...ich habe mal versucht, das möglichst "kompakt" hinzukriegen:
                                  aktivierte Instanzen: fritzdect, shelly, sonoff, zigbee
                                  nicht Sichtbares = leer bzw. Default
                                    deta
                                    schrieb am zuletzt editiert von deta
                                    #1526
                                    habe den Adapter nach Anleitung installiert.
                                    Nun wollte ich über Grafana mir das Anzeigen lassen.
                                    https://github.com/iobroker-community-adapters/ioBroker.device-watcher/blob/main/docs/de/grafana_flux.md
                                    Auch hier alles gemacht.
                                    Funktioniert auch soweit.
                                    Frage wie bekomme ich das so angezeigt?
                                    Wo muss ich was einstellen. Versuche das schon den ganzen Tag.
                                    Also diese combi.
                                    cu Deta
                                      Maxtor62
                                      #1527
                                      Hallo, Habe den Adapter auch mal Installiert. Komme mit den Fehlermeldungen nicht klar.
                                      device-watcher.0
                                      2025-12-12 16:15:00.189	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                      device-watcher.0
                                      2025-12-12 16:14:45.142	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                      device-watcher.0
                                      2025-12-12 16:14:30.142	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                      device-watcher.0
                                      2025-12-12 16:14:15.141	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                      device-watcher.0
                                      2025-12-12 16:14:00.140	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                      device-watcher.0
                                      2025-12-12 16:13:45.139	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                      device-watcher.0
                                      2025-12-12 16:13:30.142	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                      device-watcher.0
                                      2025-12-12 16:13:15.139	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                      device-watcher.0
                                      2025-12-12 16:13:00.140	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                      device-watcher.0
                                      2025-12-12 16:12:45.139	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                      device-watcher.0
                                      2025-12-12 16:12:30.143	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                      device-watcher.0
                                      2025-12-12 16:12:15.138	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                      device-watcher.0
                                      2025-12-12 16:12:12.127	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                      device-watcher.0
                                      2025-12-12 16:12:12.076	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                      device-watcher.0
                                      2025-12-12 16:12:12.074	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                      device-watcher.0
                                      2025-12-12 16:12:12.055	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                      device-watcher.0
                                      2025-12-12 16:12:12.048	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                      device-watcher.0
                                      2025-12-12 16:12:12.036	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                      device-watcher.0
                                      2025-12-12 16:12:12.029	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                      device-watcher.0
                                      2025-12-12 16:12:00.142	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                      device-watcher.0
                                      2025-12-12 16:11:45.137	error	Issue at state change: TypeError: Cannot read properties of null (reading '1')
                                      device-watcher.0
                                      2025-12-12 16:11:42.126	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                      device-watcher.0
                                      2025-12-12 16:11:42.077	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                      device-watcher.0
                                      2025-12-12 16:11:42.076	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                      device-watcher.0
                                      2025-12-12 16:11:42.060	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                      device-watcher.0
                                      2025-12-12 16:11:42.056	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                      device-watcher.0
                                      2025-12-12 16:11:42.048	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                      device-watcher.0
                                      2025-12-12 16:11:42.042	error	[getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                      Was mach ich falsch?
                                      Wer meint er ist was, hat aufgehört was zu werden
                                      • S Abwesend
                                        S Abwesend
                                        Shadowhunter23
                                        #1528
                                        https://github.com/iobroker-community-adapters/ioBroker.device-watcher/issues/575
                                        • M Maxtor62
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          device-watcher.0
                                          deta
                                          #1529
                                          @Maxtor62 es sind nicht alle Adapter die beobachten.
                                          Ich hatte mal alle raus und dann nach und nach dazu gesetzt bis ich die nicht aktiv hatte, die den Fehler bringen.
