  3. Off Topic
  4. Grafana
  5. Fritzbox mit Grafana visualisieren [Version 2022]
Geplant Angeheftet Gesperrt Verschoben Grafana
144 Beiträge 12 Kommentatoren 39.5k Aufrufe 16 Beobachtet
  • M Maxtor62
    @dp20eic
    hi sorry für meine Ungeduld. Hab halt schon so viel probiert.
    Auf der Fritte hab ich extra ein User eingerichtet den ich dafür nehme. Hat alle Rechte.
    Die Einrichtung habe ich jedes Mal genau so wie Du oder auf Github beschrieben, gemacht.
    Fritzconnection und alle Python Module installiert.
    Hier die fritzinfluxdb.ini
    [influxdb]
    # requires a hostname or IP which points to your InfluxDB instance
    hostname = 192.168.178.139
    # define the port your InfluxDB instance is listening on
    port = 8086
    # weather TLS encryption is enabled or disabled
    #tls_enabled = false
    # set this to 'true' to enforces TLS certificate validation
    #verify_tls = false
    # set a measurement name which is used to write the data to InfluxDB
    # If this is changed from the default then it also has to be changed
    # from the default value during the Grafana dashboard installation
    measurement_name = fritzbox
    # The amount of days the data should be stored in InfluxDB.
    # Older data will be deleted.
    # Attention: THIS IS ONLY CONFIGURED ON NEW DB/BUCKET CREATION!
    data_retention_days = 365
    # define which InfluxDB version you are using
    version = 2
    ##### InfluxDB version 1.x options
    # username and password to use to write data to InfluxDB
    username =
    password =
    # defines the InfluxDB database to write the data to
    # if the credentials permit to create databases then this
    # will be created automatically
    database =
    ##### InfluxDB version 2.x options
    # requires an InfluxDB API token with permissions to write to the desired bucket
    token = RRoG5NJBBUqnql1OKaHuxo3d2xqz0YpA-2AOO-fviu1Ft5mpafJizebVkpiQdGxwdtQvDv3AUJvXWLMreSQ1NA==
    # a valid InfluxDB organisation needs to be defined which is used during login
    organisation = home
    # defines the InfluxDB bucket to write the data to
    # if the credentials permit to create buckets then this
    bucket = fritzbox
    ### [fritzbox]
    ### Controls the parameters for connecting to your InfluxDB instance.
    [fritzbox]
    # changes the default FritzBox IP
    # username and password to connect to the FritzBox
    username = XXXX
    password = XXXX
    # Define the port the FritzBox is listening on
    # change to 49443 if you use ssl
    port = 49000
    # weather TLS encryption is enabled or disabled (will set port to 49443 if port is undefined)
    # set this to 'true' to enforces TLS certificate validation (only affects Lua sessions)
    #verify_tls = false
    # defines the InfluxDB measurement tag which is used
    # to tag data from this FritzBox
    #box_tag = fritz.box
    # Define the FritzBox time zone. Used to convert dates/times from FritzBox to correct UTC Timestamp
    timezone = Europe/Berlin
    # the maximum of time in seconds which a connection to the FritzBox is allowed to take
    connect_timeout = 30
    # interval to request data from FritzBox in seconds
    # the value CAN'T be lower then 10 seconds
    request_interval = 30
    # EOF
    Danke und Grüße
    #135
    @maxtor62 sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
    Moin,
    also da sehe ich erst einmal keine Klinke.
    Ich habe mal nach dem im Log aufgeführten Fehler ha_alert im Source auf Github gesucht, das kommt wohl aus dem Bereich homeauto.py, jetzt kann ich damit aber auch nicht mehr anfangen, ob das jetzt an der FritzBox liegt, oder ob die Version 7.57 da für die AX eine Macke hat oder ob Du da vielleicht Geräte in Samrt Home eingerichtet hast und deswegen der Fehler kommt.
    Warte einfach mal ab, was bb-Ricardo zu dem Fehler sagt.
    Bernd
      Moin,
      Bernd
      M
      M
      Maxtor62
      #136
      @dp20eic
      ok, danke für Deine Mühe. Im SmatHome hab ich nur Fritz Geräte über DECT eingerichtet, außer die drei Rollladen Motoren. Die sind von BoxControl, was auch über DECT läuft. Da sollte die Fritte ja kein Problem haben.
      Ich werde mich in Geduld üben.
      Stefan
      Wer meint er ist was, hat aufgehört was zu werden
      • M Maxtor62
        @dp20eic
        Stefan
        #137
        Moin,
        na dann kann es ja doch sein, dass da etwas nicht korrekt eingerichtet oder installiert ist. Du solltest mal gleich dein issuse auf Github mit allen Informationen erweitern, damit bb-Ricardo nicht erst noch nachfragen muss, verzögert dann ja nur zusätzlich.
        Bernd
          Moin,
          Bernd
          M
          M
          Maxtor62
          #138
          @dp20eic
          es ist unglaublich.
          FritzBox boot tut gut.
          Jetzt funktioniert alles.
          Danke Dir noch mal.
          Stefan
          • M Maxtor62
            @dp20eic
            es ist unglaublich.
            Danke Dir noch mal.
            Stefan
            #139
            Danke Dir noch mal.
            Moin,
            bidde schön, ist aber nicht meine Verdienst, Du kannst Dich bei bb-Ricardo bedanken.
            Und ja, mach mal, tut ein Boot gut :)
            Bernd
              @damrak2022 vllt kommst du hiermit besser zurecht
              M
              M
              michihorn
              #140
              @crunchip Hallo hab mal mitgelesen, bei der Anleitung die Du empfohlen hast, scheitere ich schon bei sudo pip install fritzcollectd mit folgender Meldung:
              error: externally-managed-environment
              × This environment is externally managed
              ╰─> To install Python packages system-wide, try apt install
                  python3-xyz, where xyz is the package you are trying to
                  install.
                  If you wish to install a non-Debian-packaged Python package,
                  create a virtual environment using python3 -m venv path/to/venv.
                  Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
                  sure you have python3-full installed.
                  For more information visit http://rptl.io/venv
              note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
              hint: See PEP 668 for the detailed specification.
              Hast du ne Ahnung was ich tun muss?
              Michael
              • M michihorn
                    install.
                Michael
                crunchipC
                crunchipC
                Developer Global Moderator Most Active Forum Testing
                #141
                @michihorn hast du das befolgt?
                https://forum.iobroker.net/post/793557
                  M
                  M
                  michihorn
                  schrieb am zuletzt editiert von michihorn
                  #142
                  @crunchip Ja habe ich, selbst mit "neu" aufgesetzter Maschine klappt es nicht
                  habe es jetzt mal so versucht:
                  pip install fritzcollectd --break-system-packages
                  Ist durch gelaufen, brachte am Ende aber folgende Meldung:
                    note: This error originates from a subprocess, and is likely not a problem with pip.
                  error: legacy-install-failure
                  × Encountered error while trying to install package.
                  ╰─> lxml
                  note: This is an issue with the package mentioned above, not pip.
                  hint: See above for output from the failure.
                  EDIT: So hat es geklappt:
                  Quelle
                  Eine TOP Anleitung zur Installation der Fritzbox Visualisierung findet man unter:
                  Anleitung
                  Keine Panik die Anleitung trägt den Titel "Fritz!Box Monitoring mit Raspberry Pi Zero W" funktioniert aber auch top bei neueren Versionen. Kleiner Tip, sollte mal die Installation von collectd schiefgehen, kann die Installation komplett mit "sudo apt-get purge --auto-remove collectd" gelöscht werden.
                  • M michihorn
                    ╰─> lxml
                    Quelle
                    Anleitung
                    crunchipC
                    crunchipC
                    #143
                    @michihorn kann dir da aktuell nicht weiterhelfen, hab das schon lange nicht mehr laufen.
                    • Sleepless135S
                      Sleepless135S
                      Sleepless135
                      #144
                      Moin in die Runde,
                      versuche mich gerade auch mal die Influx DB mit neuen Daten zu füttern.
                      Mein kleines Problem ist das ich das Script nicht mal zum laufen bekomme.
                      Traceback (most recent call last):
                      File "/opt/fritzinfluxdb/./fritzinfluxdb.py", line 27, in <module>
                      from fritzinfluxdb.classes.fritzbox.handler import FritzBoxHandler, FritzBoxLuaHandler
                      File "/opt/fritzinfluxdb/fritzinfluxdb/classes/fritzbox/handler.py", line 13, in <module>
                      import requests
                      ModuleNotFoundError: No module named 'requests'
                      Hat jemand eine Idee was ihm fehlt ?
                      Gruß Tim
                      83.9k
