  4. Tester Zigbee Adapter 3.x gesucht
zigbeezigbee adapter
259 Beiträge 27 Kommentatoren 66.5k Aufrufe 38 Beobachtet
  • AsgothianA Asgothian
    @mickemup Ich fürchte da wirst du bei Z2M mal nachhaken müssen - ich erinnere mich dumpf an Wechselwirkungen zwischen der Styrbar Firmware, der Controller Firmware und dem benutzten Herdsman.
    Der Adapter ist da jedenfalls aussen vor - er bekommt keinen Wert, und kann deswegen auch nichts setzen.
    A.
    mickemupM Offline
    mickemupM Offline
    mickemup
    #248
    @asgothian
    Danke für den Support.
    Habe jetzt nochmals Batterien rein und raus...und plötzlich ging es:
    22:18:22.752	warn	ELEVATED:I02 (319e) value generated '85' from device 04e3e5fffe73f464 for 'Battery percent'
    22:18:22.751	warn	ELEVATED:I01 (319e) message received '{"battery":85}' from device 04e3e5fffe73f464 type 'E2001/E2002'
    22:18:22.751	warn	ELEVATED:I02 (319e) value generated '236' from device 04e3e5fffe73f464 for 'Link quality'
    22:18:22.751	warn	ELEVATED:I01 (319e) message received '{"linkquality":236}' from device 04e3e5fffe73f464 type 'E2001/E2002'
    22:18:22.750	warn	ELEVATED:O06 (2dec) Convert does not return a result result for read with {"cluster":"genPowerCfg","attributes":["batteryPercentageRemaining"]} on device 0x04e3e5fffe73f464.
    22:18:22.750	warn	ELEVATED:SUCCESS (2dec) convert result undefined for device 0x04e3e5fffe73f464
    22:18:22.750	warn	ELEVATED:I01 (319e) Zigbee Event of Type readResponse from device 0x04e3e5fffe73f464, incoming event: {"type":"readResponse","data":{"batteryPercentageRemaining":170},"linkquality":236,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":187,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
    22:18:22.162	warn	ELEVATED:O04 (2f52) convert read, {"cluster":"genPowerCfg","attributes":["batteryPercentageRemaining"]}, {} for device 0x04e3e5fffe73f464 with Endpoint read
    22:18:22.162	warn	ELEVATED:O03 (2f52) Publishing to 0x04e3e5fffe73f464 of model E2001/E2002 with read
    22:18:22.162	warn	ELEVATED:O03 (2f29) Publishing to 0x04e3e5fffe73f464 of model E2001/E2002 with send_payload
    22:18:22.162	warn	ELEVATED:O02 (2f29) Change state 'send_payload' at device 0x04e3e5fffe73f464 type E2001/E2002'
    22:18:22.121	warn	ELEVATED:O01 (2f29) User state change of state zigbee.0.04e3e5fffe73f464.send_payload with value { "read": { "cluster": "genPowerCfg", "attributes": ["batteryPercentageRemaining"] }} (ack: false) from system.adapter.javascript.0
    • HomoranH Offline
      HomoranH Offline
      #249
      Wie kann man eigentlich Änderungen an den Werten ("Kalibrierung") durchführen?
      Ich habe mir letztens noch ein paar IKEA Inspelning Steckdosen geholt, als diese wieder verfügbar waren.
      Die letzten liefen so toll, dass ich gar nicht auf "Probleme" eingestellt war.
      Habe jetzt 2 Stück davon installiert und beide zeigen anscheinend ohne Last eine Leistung um die 1W an.
      Laut Z2M
      power_calibration: Calibrates the power value (percentual offset), takes into effect on next report of device. The value must be a number.
      Abgesehen davon, dass ich nicht weiss wo und wie man den Befehl absetzt, frage ich mich wie ein prozentualer offset von 0 aussehen soll.
      Für Hilfe wäre ich sehr dankbar
        Laut Z2M
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #250
        @homoran sagte in Tester Zigbee Adapter 3.x gesucht:
        Laut Z2M
        100% sicher bin ich nicht. Es kann sein das die Kalibrierung erst gehen wird wenn ich mit dem Adapter 3.1 fertig bin.
        Was du probieren kannst:
        Option A:
        • Datenpunkt sendPayload den payload {"power_calibration":10} eintragen
        • Im log schauen ob es Meldungen gibt
        • Schauen ob sich der Leistungswert ändert.
        Option B:
        • Kachel Umdrehen.
        • Stift icon nutzen (wie beim Umbenennen / Gruppenzuordnung)
        • unten das kleine + nutzen um eine 'option' zu bekommen
        • Als Optionsname power_calibration und als Wert 10 eintragen
        • Mit save abspeichern (kann sein das da speichern steht - weiss ich gerade nicht
        • Gerät neu konfigurieren (reconfigure auf der Kachel)
        • Gerät einmal vom ioBroker aus schalten
        Ob eines davon funktioniert ist nicht klar - es hängt davon ab wie die Kalibration im Konverter umgesetzt ist. Probieren kann ich das selber aktuell nicht.
        A.
          Laut Z2M
          Option A:
          Option B:
          • Kachel Umdrehen.
          A.
          HomoranH Offline
          HomoranH Offline
          #251
          @asgothian Danke!
          @asgothian sagte in Tester Zigbee Adapter 3.x gesucht:
          Dann mach ich das doch!
          Aber:
          Methode B wäre mir lieber
          doch
          da ist (noch) kein +
          habe noch v3.0.0
          EDIT:
          Update auf 3.0.5 via latest bringt das +, aber leider keine Änderungen.
          Zumindest nicht mit 10 und -10
          EDIT2:
          über den Datenpunkt hab ich's auch versucht.
          Danach zeigte es gar nichts mehr an, immer nur 0W.
          Nach Rücksetzen auf Werkseinstellung läuft's erst mal wieder.
          ich geh da mal systematisch ran, wenn ich mehr Zeit habe
            @asgothian Danke!
            Aber:
            doch
            habe noch v3.0.0
            EDIT:
            EDIT2:
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            #252
            @asgothian Danke!
            [...snip]
            EDIT2:
            Das kann eigentlich nicht sein - die Werte werden nicht akzeptiert. Du solltest im Log die folgenden Einträge finden, wenn du die Kalibration versuchst einzustellen. Eher denk ich das da was anderes noch passiert.
            zigbee.0 2025-09-01 13:39:26.321	info	No converter available for 'E2206' with key 'voltage_calibration'
            zigbee.0 2025-09-01 13:39:26.321	info	No converter available for 'E2206' with key 'current_calibration'
            zigbee.0 2025-09-01 13:39:26.321	info	No converter available for 'E2206' with key 'power_calibration'
            zigbee.0 2025-09-01 13:39:26.321	info	No converter available for 'E2206' with key 'energy_calibration'
            Warte mal bis morgen ab - ich hab eine Steckdose hier und kann die (allerdings mit der 3.1.0RC1) durch den debugger jagen um zu sehen wie wir die Werte da rein bekommen.
            Wollte ich sowieso :)
            A
              @asgothian Danke!
              [...snip]
              EDIT2:
              A
              HomoranH Offline
              HomoranH Offline
              #253
              da war gar nichts, nada!
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                #254
                auch nicht wenn du über den Datenpunkt gegangen bist ? Das wäre komisch.
                A.
                  A.
                  HomoranH Offline
                  HomoranH Offline
                  #255
                  @asgothian
                  mea culpa!!!
                  Ich hab wohl irgendwann der Instanz das plappern abgewöhnen wollen 😞
                  Die Logstufe steht auf warn.
                  Kein Wunder dass da nichts kommt.
                    @asgothian
                    mea culpa!!!
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    #256
                    @homoran So.. nun bin ich mit der Analyse erst einmal durch - das ganze funktioniert so erst einmal nicht. Es ist nicht in den Konvertern hinterlegt (ZHC) oder im Herdsman (ZH) sondern eine Funktion die ausschliesslich bei Z2M implementiert ist.
                    Ob / Wie ich diese im Zigbee Adapter implementieren kann / will ist fraglich.
                    Dann habe ich wieder Adapter-eigenen Code der ggf. durch Code im ZHC übersteuert wird.
                    Nebenbei bin ich auf mehrere Bugs gestossen, die fuer die 3.1 behoben werden. Insbesondere im Umfeld des device_query
                    A.
                      A.
                      HomoranH Offline
                      HomoranH Offline
                      #257
                      @asgothian
                      Danke!
                      davon geht die Welt nicht unter
                      dann ist das eben ein Feature für Z2M only!
                        @asgothian
                        Danke!
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        #258
                        @asgothian
                        Das kann am Ende heraus kommen. Allerdings will ich mir anschauen was da gemacht wurde - ggf. kann ich da durchaus etwas mit machen. Aber nicht mehr heute :)
                        Was auch immer ich da mache muss aber 'allgemeingültig' sein, sprich nicht an der Ikea Steckdose oder an Steckdosen allgemein hängen, sonst müsste ich die erst noch erkennen.
                        A.
                        Nachtrag - Es geht. Zumindest bei dem Gerät wo ich es getestet hab. Und bei meiner 3.1.0RC1. Läuft wie gedacht über 'Option 2', allerdings ohne dass neu konfiguriert oder vom ioBroker aus geschaltet werden muss.
                        Es wird einfach so aktiv.
                        Ich geb Dir gerne einen Link wenn du es testen willst. (soviel zu 'nicht mehr Heute' :) )
                        • haselchenH haselchen
                          @asgothian
                          Huhu...ich hab zum Test nochmal 2 BWM bei wieder einem anderen Anbieter bestellt.
                          Es scheint, dass es überwiegend nur noch die HOBEIAN Geräte gibt.
                          Auf der Packung steht auch New Zigbee PIR LUX.
                          Er wird zwar als ZG-204ZL erkannt, aber auf der Packung stehen , vermutlich, Updatebezeichnungen des Gerätes.
                          ZG-204ZS /ZG-204ZM
                          Und da ist vermutlich der Knackpunkt.
                          Beim Anlernen (ich habe zum Testen ein Downgrade des Adapters gemacht) wird alles fein säuberlich erkannt und mit ok abgeschlossen.
                          Danach ist aber nichts okay. Das Gerät ist zwar in der Kachel und zeigt Verbindung. Aber es wird nichts aktualisiert. Es ist quasi eingefroren.
                          Jetzt die Frage, ist es möglich , ohne von Github die Version laden, dieses Gerät einzupflegen?
                          Zigbee2Mqttt hat es ja.
                          zigbee.0 2025-07-22 11:23:14.095	info	Successfully interviewed '0xa4c13871cd6e84b7', device has successfully been paired
                          zigbee.0 2025-07-22 11:23:03.071	info	Device '0xa4c13871cd6e84b7' announced itself
                          zigbee.0 2025-07-22 11:23:02.709	info	Starting interview of '0xa4c13871cd6e84b7'
                          zigbee.0 2025-07-22 11:22:48.451	info	Zigbee: allowing new devices to join.
                          Kein "WLAN" Zeichen vorm Gerät
                          Springreiter
                          #259
                          @haselchen Ich hatte auch 2 an die Seite gelegt weil sie einfach nicht wollten- und nun
                          funktionieren sie einwandfrei (Version 3.0.5)
