  4. Kann den Rpi Adapter auf meinem Raspberry nicht installieren
    apollon77A
adaptergpiohilfeinstallationraspberry
48 Beiträge 9 Kommentatoren 5.4k Aufrufe 7 Beobachtet
  • Basti97B Basti97
    @thomas-braun sagte in Kann den Rpi Adapter auf meinem Raspberry nicht installieren:
    iob diag
    ```bash
    Script v.2025-03-08
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v7+
          Architecture: arm
    OS is similar to: debian
    Model           : Raspberry Pi 3 Model B Plus Rev 1.3
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     09:46:33 up 14:44,  2 users,  load average: 3.28, 2.88, 2.27
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-07-16 09:46:33 CEST
               Universal time: Wed 2025-07-16 07:46:33 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            921M        216M        209M        1.0M        496M        634M
    Swap:            99M         78M         21M
    Total:          1.0G        295M        230M
    Active iob-Instances:   3
              921 M total memory
              216 M used memory
              407 M active memory
              210 M inactive memory
              209 M free memory
               70 M buffer memory
              425 M swap cache
               99 M total swap
               78 M used swap
               21 M free swap
    top - 09:46:34 up 14:44,  2 users,  load average: 3.28, 2.88, 2.27
    Tasks: 158 total,   1 running, 157 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  5.5 us,  5.5 sy,  0.0 ni, 89.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :    922.0 total,    209.1 free,    216.4 used,    496.5 buff/cache
    MiB Swap:    100.0 total,     21.0 free,     79.0 used.    633.7 avail Mem
    *** FAILED SERVICES ***
      UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
    * bthelper@hci0.service         loaded failed failed Raspberry Pi bluetooth helper
    * colord.service                loaded failed failed Manage, Install and Generate Color Profiles
    * openvpn-client@client.service loaded failed failed OpenVPN tunnel for client
    * plymouth-start.service        loaded failed failed Show Plymouth Boot Screen
    * wg-quick@wg0.service          loaded failed failed WireGuard via wg-quick(8) for wg0
    5 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    144 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    /dev/root      ext4       15G  6.2G  7.7G  45% /
    devtmpfs       devtmpfs  333M     0  333M   0% /dev
    tmpfs          tmpfs     461M  4.0K  461M   1% /dev/shm
    tmpfs          tmpfs     185M  772K  184M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs      93M   20K   93M   1% /run/user/1000
    [Tue Jul 15 19:01:52 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=44a3dce6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Tue Jul 15 19:01:55 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Jul 15 19:01:55 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue Jul 15 19:01:58 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    2.2G    /var/
    1.1G    /var/cache/apt
    1.1G    /var/cache
    992M    /var/cache/apt/archives
    865M    /var/log
    Journal file /var/log/journal/17f5be65a0144b718868da827cf6bffe/system@0c9cfaba2fdb43568eb34c2594062e00-0000000000000001-0005cf905c0cadb6.journal corrupted, ignoring file.
    Archived and active journals take up 776.1M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    103M    /opt/iobroker/iobroker-data/
    64M     /opt/iobroker/iobroker-data/files
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
    3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-CyIqcfMJ.js
    3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
    3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-IIKn7Ixx.js
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.1
    /usr/bin/node           v20.19.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.31.0
    nodejs:
      Installed: 20.19.1-1nodesource1
      Candidate: 20.19.1-1nodesource1
      Version table:
     *** 20.19.1-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
         20.19.0-1nodesource1 600
         20.18.3-1nodesource1 600
         20.18.2-1nodesource1 600
         20.18.1-1nodesource1 600
         20.18.0-1nodesource1 600
         20.17.0-1nodesource1 600
         20.16.0-1nodesource1 600
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         12.22.12~dfsg-1~deb11u7 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 35829)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.17
    javascript:     "javascript" not found
    nodejs modules from github:     0
    Adapter State
      system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
    + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1884
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "backitup"     : 3.3.5    , installed 3.2.2  [Updatable]
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
    Objects and States
    Objects:        171
    States:         106
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          14657      623/lighttpd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14552      551/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          14166      876/dnsmasq
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       285666     21933/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       285671     21933/iobroker.js-c
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          297692     25814/cupsd
    tcp6       0      0 :::80                   :::*                    LISTEN      0          14658      623/lighttpd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14554      551/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          297691     25814/cupsd
    tcp6       0      0 :::53                   :::*                    LISTEN      0          14168      876/dnsmasq
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       288840     21989/io.admin.0
    udp        0      0 0.0.0.0:59903           0.0.0.0:*                           108        12483      337/avahi-daemon: r
    udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          14165      876/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14162      876/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12897      857/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12481      337/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          116938     857/dhcpcd
    udp6       0      0 :::53                   :::*                                0          14167      876/dnsmasq
    udp6       0      0 :::58970                :::*                                108        12484      337/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        12482      337/avahi-daemon: r
    2025-07-16 00:19:31.687  - info: host.raspberrypi iobroker gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v20.19.1gyp ERR! node-gyp -v v10.1.0gyp ERR! not ok
    2025-07-16 00:19:31.836  - info: host.raspberrypi iobroker npm error code 1
    2025-07-16 00:19:31.839  - info: host.raspberrypi iobroker npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuild
    2025-07-16 00:19:31.850  - info: host.raspberrypi iobroker npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-07-15T22_18_28_400Z-debug-0.log
    2025-07-16 00:19:31.890  - error: host.raspberrypi iobroker gyp info it worked if it ends with okgyp info using node-gyp@10.1.0gyp info using node@20.19.1 | linux | armgyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/diskusage/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.19.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.19.1',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.19.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/diskusage',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]<command-line>: warning: "_GLIBCXX_USE_CXX11_ABI" redefined<command-line>: note: this is the location of the previous definitionIn file included from ../../nan/nan.h:62,                 from ../src/main.cpp:3:/home/iobroker/.cache/node-gyp/20.19.1/include/node/node.h:1226:7: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type] 1226 |       (node::addon_register_func) (regfunc),                          \      |       ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/20.19.1/include/node/node.h:1260:3: note: in expansion of macro 'NODE_MODULE_X' 1260 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)      |   ^~~~~~~~~~~~~../src/main.cpp:42:1: note: in expansion of macro 'NODE_MODULE'   42 | NODE_MODULE(diskusage, Init)      | ^~~~~~~~~~~<command-line>: warning: "_GLIBCXX_USE_CXX11_ABI" redefined<command-line>: note: this is the location of the previous definition/usr/lib/gcc/arm-linux-gnueabihf/10/crtbeginS.o: file not recognized: file format not recognizedcollect2: error: ld returned 1 exit statusmake: *** [diskusage.target.mk:135: Release/obj.target/diskusage.node] Error 1gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)gyp ERR! System Linux 6.1.21-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/diskusagegyp ERR! node -v v20.19.1gyp ERR! node-gyp -v v10.1.0gyp ERR! not ok gyp info it worked if it ends with okgyp info using node-gyp@10.1.0gyp info using node@20.19.1 | linux | armgyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-dht-sensor/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.19.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.19.1',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.19.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-dht-sensor',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]gyp info ok gyp info it worked if it ends with okgyp info using node-gyp@10.1.0gyp info using node@20.19.1 | linux | armgyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/opengpio/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.19.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.19.1',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.19.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/opengpio',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]/usr/lib/gcc/arm-linux-gnueabihf/10/crtbeginS.o: file not recognized: file format not recognizedcollect2: error: ld returned 1 exit statusmake: *** [opengpio.target.mk:133: Release/obj.target/opengpio.node] Error 1gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)gyp ERR! System Linux 6.1.21-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v20.19.1gyp ERR! node-gyp -v v10.1.0gyp ERR! not ok npm error code 1npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-07-15T22_18_28_400Z-debug-0.log
    2025-07-16 00:19:31.893  - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.rpi2@2.4.0: 1
    2025-07-16 00:19:32.961  - info: host.raspberrypi iobroker exit 25
    2025-07-16 00:22:15.158  - info: admin.0 (21989) <== Disconnect system.user.admin from ::ffff:192.168.1.3 admin
    2025-07-16 00:22:17.669  - info: admin.0 (21989) ==> Connected system.user.admin from ::ffff:192.168.1.3
    2025-07-16 00:32:36.623  - info: admin.0 (21989) <== Disconnect system.user.admin from ::ffff:192.168.1.3 admin
    2025-07-16 00:32:36.881  - info: admin.0 (21989) ==> Connected system.user.admin from ::ffff:192.168.1.3
    2025-07-16 00:32:36.925  - info: admin.0 (21989) <== Disconnect system.user.admin from ::ffff:192.168.1.3 admin
    2025-07-16 00:32:39.394  - info: admin.0 (21989) ==> Connected system.user.admin from ::ffff:192.168.1.3
    2025-07-16 00:38:54.719  - info: host.raspberrypi iobroker add rpi2 --host raspberrypi
    2025-07-16 00:39:02.488  - info: host.raspberrypi iobroker NPM version: 10.8.2
    2025-07-16 00:39:02.492  - info: host.raspberrypi iobroker Installing iobroker.rpi2@2.4.0... (System call)
    2025-07-16 00:40:08.220  - error: host.raspberrypi iobroker npm error code 1npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error make: Entering directory '/opt/iobroker/node_modules/opengpio/build'npm error   CXX(target) Release/obj.target/opengpio/cpp/opengpio.onpm error   SOLINK_MODULE(target) Release/obj.target/opengpio.nodenpm error make: Leaving directory '/opt/iobroker/node_modules/opengpio/build'npm error /usr/lib/gcc/arm-linux-gnueabihf/10/crtbeginS.o: file not recognized: file format not recognizednpm error collect2: error: ld returned 1 exit statusnpm error make: *** [opengpio.target.mk:133: Release/obj.target/opengpio.node] Error 1npm error gyp ERR! build error npm error gyp ERR! stack Error: `make` failed with exit code: 2npm error gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)npm error gyp ERR! System Linux 6.1.21-v7+npm error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpionpm error gyp ERR! node -v v20.19.1npm error gyp ERR! node-gyp -v v10.1.0npm error gyp ERR! not oknpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-07-15T22_39_03_166Z-debug-0.log
    2025-07-16 00:40:08.225  - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.rpi2@2.4.0: 1
    2025-07-16 00:40:09.283  - info: host.raspberrypi iobroker exit 25
    2025-07-16 00:45:05.391  - error: host.raspberrypi Cannot read disk size: Could not determine controller directory
    2025-07-16 00:51:31.884  - info: admin.0 (21989) <== Disconnect system.user.admin from ::ffff:192.168.1.3 admin
    2025-07-16 09:44:56.397  - info: admin.0 (21989) ==> Connected system.user.admin from ::ffff:192.168.1.3
    2025-07-16 09:48:30.566  - info: admin.0 (21989) <== Disconnect system.user.admin from ::ffff:192.168.1.3 admin
    2025-07-16 09:49:23.357  - info: admin.0 (21989) ==> Connected system.user.admin from ::ffff:192.168.1.3
    2025-07-16 09:49:23.955  - info: admin.0 (21989) <== Disconnect system.user.admin from ::ffff:192.168.1.3 admin
    iob diag has finished.
    pi@raspberrypi:~ $ obroker fix
    -bash: obroker: command not found
    pi@raspberrypi:~ $
    ```pi@raspberrypi:~ $ apt policy libgpiod*
    libgpiod-dev:
      Installed: 1.6.2-1+rpi1
      Candidate: 1.6.2-1+rpi1
      Version table:
     *** 1.6.2-1+rpi1 500
    libgpiod-doc:
      Installed: (none)
      Version table:
         1.6.2-1+rpi1 500
    libgpiod2:
      Version table:
    Thomas BraunT
    Thomas BraunT
    @basti97 sagte in Kann den Rpi Adapter auf meinem Raspberry nicht installieren:
    Setz das Ding komplett neu auf, diesmal direkt als RaspberryOS 12 'Lite - 64Bit'.
    Basti97B 1 Antwort Letzte Antwort
      Basti97B
      Basti97B
      Basti97
      @thomas-braun Und dann funktoniert es oder?
      Das komische daran ist ich hatte den Rpi vorher als Slave laufen gehabt. Das hatte ich vor längeren mal so eingestellt und er wurde auch gleich wieder erkannt und ich konnte die gpios auch steuern. Ich hatte den Verbund nicht auseinander gemacht und iobroker deinstalliert und alles neu installiert. Danach konnte ich den rpi Adapter nicht mehr installieren.
      Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
      • Basti97B Basti97
        Thomas BraunT
        Thomas BraunT
        Kann ich dir nicht sagen. Aber zumindest ist dann die Ausgangslage eine stabile.
          Basti97B
          Basti97B
          Basti97
          @thomas-braun dann probiere ich das mal vielen Dank für deine Hilfe :)
          • GarfonsoG
            GarfonsoG
            Garfonso
            @basti97
            auch wenn Thomas mich (zurecht) haut, kannst du, solange du Bullseye (also das Raspian, was du gerade drauf hast) noch drauf lässt (Sicherheitsrisiko, da EOL, entweder schon oder sehr bald...) die letzte 1.x Version vom rpi2 Adapter nehmen, also 1.3.2. (z.B. mit iob upgrade rpi2@1.3.2 installieren).
            Wenns tatsächlich nur um ein bisschen Spielen für das Kind geht, ist das vielleicht die einfacherere Lösung.
            Aber auf lange Sicht, neues System und neuen Adapter (aber vermutlich bald auch neuen PI, wenn der was tun soll). :-)
            Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
            Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
            • GarfonsoG Garfonso
              @basti97
              Thomas BraunT
              Thomas BraunT
              @garfonso
              Aber auch dem Nachwuchs würde ich da ein frisches System hinsetzen. Ich verstehe auch gar nicht, worin die Mega-Hürde hier bestehen soll. Offenbar ist das Ding ja verfügbar, da kann man ja wohl auch ein frisches System draufbügeln.
              Und für Spielereien mit LEDs und GPIOs braucht es auch keinen rpi2-Adapter/ioBroker.
              Da wird man mehr lernen, wenn man die GPIOs direkt über das OS anspricht.
              • Basti97B
                Basti97B
                Basti97
                @garfonso Dankeschön werde ich mal probieren vielen Dank. Ja ich werde das ganze irgendwann nochmal neu aufsetzen aber Kinder sind ungeduldig. Ich manchmal auch was kann ich sonst für Projekte mit den RPI 3 noch machen? Wo die 1GB reichen?
                • Basti97B Basti97
                  S
                  S
                  sonny
                  schrieb am zuletzt editiert von sonny
                  Hallo , darf ich mich hier mal mitanhängen.
                  Frisch installiertes Iob System (Hab es nach 1,5 Jahren geschafft mir die netzwerkkonfiguration zusammenzuschiessen lach- Ich wollts halt wiedermal genau wissen...)
                  Vor 5 Stunden , lief dieser Adapter also noch.
                  Es ist Debian 12, also Bookworm, nicht Trixie installiert.
                  Node 20.19.4
                  NPM 10.8.2
                  (Es geht auch mit Node 24 nicht, ich hab von 18-20-24 alles durchprobiert). Es kommt immer dasselbe:
                  NPM version: 10.8.2
                  npm error code 7npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error gyp ERR! UNCAUGHT EXCEPTION npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm error gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm error gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm error gyp ERR! stack at FSReqCallback.oncomplete (node:fs:188:23)npm error gyp ERR! System Linux 6.12.34+rpt-rpi-v8npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpionpm error gyp ERR! node -v v20.19.4npm error gyp ERR! node-gyp -v v7.1.2npm error gyp ERR! Node-gyp failed to build your package.npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-08-25T16_36_15_894Z-debug-0.log
                  host.Athena Cannot install iobroker.rpi2@2.4.0: 7
                  ERROR: Process exited with code 25
                  	iobroker npm error code 7npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error gyp ERR! UNCAUGHT EXCEPTION npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm error gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm error gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm error gyp ERR! stack at FSReqCallback.oncomplete (node:fs:188:23)npm error gyp ERR! System Linux 6.12.34+rpt-rpi-v8npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpionpm error gyp ERR! node -v v20.19.4npm error gyp ERR! node-gyp -v v7.1.2npm error gyp ERR! Node-gyp failed to build your package.npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-08-25T16_41_08_597Z-debug-0.log
                  Kann man mir bitte verraten was hier los ist ? Der Geist in der Maschine ? Das Ding lief (Ok da war er bereits installiert) vor 5 Stunden noch ohne irgendwelche Probleme.
                  Ich bin da ein wenig Ratlos :)
                  iob fix usw, auch den npm cache löschen (Auch für den user "iobroker") brachte da keine Abhilfe. Alles läuft, nur diesen Adapter kann ich nicht installieren. Es sei kurz gesagt: Ich hab mit dem backup Adapter ein Backup zurückgespielt.... (Was ebenfalls 5 Stunden alt ist)
                  Vielen Dank euch vorab. LG
                  • S sonny
                    Node 20.19.4
                    NPM 10.8.2
                    NPM version: 10.8.2
                    Thomas BraunT
                    Thomas BraunT
                    @sonny sagte in Kann den Rpi Adapter auf meinem Raspberry nicht installieren:
                    Was steht denn da drin?
                    Bitte in Codetags eingebettet posten.
                      S
                      S
                      sonny
                      Hier bitteschön :)
                      0 verbose cli /usr/bin/node /usr/bin/npm
                      1 info using npm@10.8.2
                      2 info using node@v20.19.4
                      3 silly config load:file:/usr/lib/node_modules/npm/npmrc
                      4 silly config load:file:/opt/iobroker/.npmrc
                      5 silly config load:file:/home/iobroker/.npmrc
                      6 silly config load:file:/usr/etc/npmrc
                      7 verbose title npm install iobroker.rpi2@2.4.0
                      8 verbose argv "install" "--save-exact" "--loglevel" "error" "iobroker.rpi2@2.4.0"
                      9 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2025-08-25T16_41_08_597Z-
                      10 verbose logfile /home/iobroker/.npm/_logs/2025-08-25T16_41_08_597Z-debug-0.log
                      11 silly packumentCache heap:2197815296 maxSize:549453824 maxEntrySize:274726912
                      12 silly logfile start cleaning logs, removing 1 files
                      13 silly logfile done cleaning log files
                      14 silly idealTree buildDeps
                      15 silly fetch manifest iobroker.rpi2@2.4.0
                      16 silly packumentCache full:https://registry.npmjs.org/iobroker.rpi2 cache-miss
                      17 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
                      18 http fetch GET 200 https://registry.npmjs.org/iobroker.rpi2 83ms (cache hit)
                      19 silly packumentCache full:https://registry.npmjs.org/iobroker.rpi2 set size:155094 disposed:false
                      20 silly placeDep ROOT iobroker.rpi2@2.4.0 OK for: iobroker.inst@3.0.0 want: 2.4.0
                      21 silly fetch manifest ci@^2.3.0
                      22 silly packumentCache full:https://registry.npmjs.org/ci cache-miss
                      23 silly fetch manifest opengpio@^1.0.17
                      24 silly packumentCache full:https://registry.npmjs.org/opengpio cache-miss
                      25 silly fetch manifest node-dht-sensor@^0.4.5
                      26 silly packumentCache full:https://registry.npmjs.org/node-dht-sensor cache-miss
                      27 http fetch GET 200 https://registry.npmjs.org/opengpio 33ms (cache hit)
                      28 silly packumentCache full:https://registry.npmjs.org/opengpio set size:46175 disposed:false
                      29 http fetch GET 200 https://registry.npmjs.org/ci 41ms (cache hit)
                      30 silly packumentCache full:https://registry.npmjs.org/ci set size:22895 disposed:false
                      31 http fetch GET 200 https://registry.npmjs.org/node-dht-sensor 40ms (cache hit)
                      32 silly packumentCache full:https://registry.npmjs.org/node-dht-sensor set size:76611 disposed:false
                      33 silly placeDep ROOT ci@2.3.0 OK for: iobroker.rpi2@2.4.0 want: ^2.3.0
                      34 silly placeDep ROOT node-dht-sensor@0.4.5 OK for: iobroker.rpi2@2.4.0 want: ^0.4.5
                      35 silly placeDep ROOT opengpio@1.0.18 OK for: iobroker.rpi2@2.4.0 want: ^1.0.17
                      36 silly fetch manifest node-addon-api@^1.6.3
                      37 silly packumentCache full:https://registry.npmjs.org/node-addon-api cache-miss
                      38 silly fetch manifest node-addon-api@^7.0.0
                      39 silly packumentCache full:https://registry.npmjs.org/node-addon-api cache-miss
                      40 http fetch GET 200 https://registry.npmjs.org/node-addon-api 303ms (cache hit)
                      41 silly packumentCache full:https://registry.npmjs.org/node-addon-api set size:328136 disposed:false
                      42 http fetch GET 200 https://registry.npmjs.org/node-addon-api 391ms (cache hit)
                      43 silly packumentCache full:https://registry.npmjs.org/node-addon-api set size:328136 disposed:false
                      44 silly packumentCache full:https://registry.npmjs.org/node-addon-api dispose
                      45 silly placeDep node_modules/node-dht-sensor node-addon-api@1.7.2 OK for: node-dht-sensor@0.4.5 want: ^1.6.3
                      46 silly placeDep node_modules/opengpio node-addon-api@7.1.1 OK for: opengpio@1.0.18 want: ^7.0.0
                      47 silly fetch manifest gcp-metadata@^5.2.0
                      48 silly packumentCache full:https://registry.npmjs.org/gcp-metadata cache-miss
                      49 http fetch GET 200 https://registry.npmjs.org/gcp-metadata 2190ms (cache hit)
                      50 silly packumentCache full:https://registry.npmjs.org/gcp-metadata set size:182287 disposed:false
                      51 silly placeDep node_modules/iobroker.node-red gcp-metadata@5.3.0 OK for: mongodb@6.18.0 want: ^5.2.0
                      52 silly fetch manifest gaxios@^5.0.0
                      53 silly packumentCache full:https://registry.npmjs.org/gaxios cache-miss
                      54 http fetch GET 200 https://registry.npmjs.org/gaxios 58ms (cache hit)
                      55 silly packumentCache full:https://registry.npmjs.org/gaxios set size:334347 disposed:false
                      56 silly placeDep node_modules/iobroker.node-red gaxios@5.1.3 OK for: gcp-metadata@5.3.0 want: ^5.0.0
                      57 silly fetch manifest node-fetch@^2.6.9
                      58 silly packumentCache full:https://registry.npmjs.org/node-fetch cache-miss
                      59 silly fetch manifest https-proxy-agent@^5.0.0
                      60 silly packumentCache full:https://registry.npmjs.org/https-proxy-agent cache-miss
                      61 http fetch GET 200 https://registry.npmjs.org/https-proxy-agent 28ms (cache hit)
                      62 silly packumentCache full:https://registry.npmjs.org/https-proxy-agent set size:76222 disposed:false
                      63 http fetch GET 200 https://registry.npmjs.org/node-fetch 41ms (cache hit)
                      64 silly packumentCache full:https://registry.npmjs.org/node-fetch set size:896010 disposed:false
                      65 silly fetch manifest encoding@^0.1.0
                      66 silly packumentCache full:https://registry.npmjs.org/encoding cache-miss
                      67 http fetch GET 200 https://registry.npmjs.org/encoding 9ms (cache hit)
                      68 silly packumentCache full:https://registry.npmjs.org/encoding set size:17833 disposed:false
                      69 silly placeDep node_modules/iobroker.node-red https-proxy-agent@5.0.1 OK for: gaxios@5.1.3 want: ^5.0.0
                      70 silly placeDep node_modules/iobroker.node-red node-fetch@2.7.0 OK for: gaxios@5.1.3 want: ^2.6.9
                      71 silly fetch manifest agent-base@6
                      72 silly packumentCache full:https://registry.npmjs.org/agent-base cache-miss
                      73 http fetch GET 200 https://registry.npmjs.org/agent-base 10ms (cache hit)
                      74 silly packumentCache full:https://registry.npmjs.org/agent-base set size:67460 disposed:false
                      75 silly placeDep node_modules/iobroker.node-red agent-base@6.0.2 OK for: https-proxy-agent@5.0.1 want: 6
                      76 silly reify mark retired [ '/opt/iobroker/node_modules/node-dht-sensor' ]
                      77 silly reify mark retired [ '/opt/iobroker/node_modules/@stoprocent/noble' ]
                      78 silly reify moves {
                      78 silly reify   '/opt/iobroker/node_modules/node-dht-sensor': '/opt/iobroker/node_modules/.node-dht-sensor-QmYjQqky',
                      78 silly reify   '/opt/iobroker/node_modules/@stoprocent/noble': '/opt/iobroker/node_modules/@stoprocent/.noble-3N4hliTW'
                      78 silly reify }
                      79 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
                      80 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
                      81 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-win32-x64-msvc
                      82 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-win32-x64-msvc' ]
                      83 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-win32-ia32-msvc
                      84 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-win32-ia32-msvc' ]
                      85 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-win32-arm64-msvc
                      86 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-win32-arm64-msvc' ]
                      87 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-wasm32-wasi
                      88 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-wasm32-wasi' ]
                      89 verbose reify failed optional dependency /opt/iobroker/node_modules/@napi-rs/wasm-runtime
                      90 silly reify mark deleted [ '/opt/iobroker/node_modules/@napi-rs/wasm-runtime' ]
                      91 verbose reify failed optional dependency /opt/iobroker/node_modules/@emnapi/core
                      92 silly reify mark deleted [ '/opt/iobroker/node_modules/@emnapi/core' ]
                      93 verbose reify failed optional dependency /opt/iobroker/node_modules/@tybys/wasm-util
                      94 silly reify mark deleted [ '/opt/iobroker/node_modules/@tybys/wasm-util' ]
                      95 verbose reify failed optional dependency /opt/iobroker/node_modules/@emnapi/wasi-threads
                      96 silly reify mark deleted [ '/opt/iobroker/node_modules/@emnapi/wasi-threads' ]
                      97 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-linux-x64-musl
                      98 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-linux-x64-musl' ]
                      99 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-linux-x64-gnu
                      100 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-linux-x64-gnu' ]
                      101 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-linux-arm-gnueabihf
                      102 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-linux-arm-gnueabihf' ]
                      103 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-freebsd-x64
                      104 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-freebsd-x64' ]
                      105 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-darwin-x64
                      106 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-darwin-x64' ]
                      107 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-darwin-arm64
                      108 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-darwin-arm64' ]
                      109 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-android-arm64
                      110 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-android-arm64' ]
                      111 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-android-arm-eabi
                      112 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-android-arm-eabi' ]
                      113 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-win32-x64
                      114 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-win32-x64' ]
                      115 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-win32-ia32
                      116 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-win32-ia32' ]
                      117 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-win32-arm64
                      118 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-win32-arm64' ]
                      119 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-wasm32
                      120 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-wasm32' ]
                      121 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-linuxmusl-x64
                      122 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-linuxmusl-x64' ]
                      123 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-linux-x64
                      124 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-linux-x64' ]
                      125 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-linux-s390x
                      126 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-linux-s390x' ]
                      127 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-linux-ppc64
                      128 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-linux-ppc64' ]
                      129 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-linux-arm
                      130 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-linux-arm' ]
                      131 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-libvips-linuxmusl-x64
                      132 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-libvips-linuxmusl-x64' ]
                      133 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-libvips-linux-x64
                      134 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-libvips-linux-x64' ]
                      135 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-libvips-linux-s390x
                      136 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-libvips-linux-s390x' ]
                      137 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-libvips-linux-ppc64
                      138 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-libvips-linux-ppc64' ]
                      139 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-libvips-linux-arm
                      140 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-libvips-linux-arm' ]
                      141 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-libvips-darwin-x64
                      142 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-libvips-darwin-x64' ]
                      143 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-libvips-darwin-arm64
                      144 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-libvips-darwin-arm64' ]
                      145 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-darwin-x64
                      146 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-darwin-x64' ]
                      147 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-darwin-arm64
                      148 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-darwin-arm64' ]
                      149 warn deprecated npmlog@4.1.2: This package is no longer supported.
                      150 warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
                      151 warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                      152 warn deprecated gauge@2.7.4: This package is no longer supported.
                      153 info run iobroker.rpi2@2.4.0 preinstall node_modules/iobroker.rpi2 sudo apt-get install -y libgpiod-dev || exit 0
                      154 info run iobroker.rpi2@2.4.0 preinstall { code: 0, signal: null }
                      155 info run @stoprocent/noble@1.19.1 install node_modules/@stoprocent/noble node-gyp-build
                      156 info run node-dht-sensor@0.4.5 install node_modules/node-dht-sensor node-gyp configure
                      157 info run opengpio@1.0.18 install node_modules/opengpio node-gyp rebuild
                      158 info run opengpio@1.0.18 install { code: 7, signal: null }
                      159 info run raw-socket@1.8.1 install node_modules/raw-socket node-gyp rebuild
                      160 info run node-dht-sensor@0.4.5 install { code: 7, signal: null }
                      161 verbose reify failed optional dependency /opt/iobroker/node_modules/node-dht-sensor
                      162 silly reify mark deleted [ '/opt/iobroker/node_modules/node-dht-sensor' ]
                      163 verbose reify failed optional dependency /opt/iobroker/node_modules/node-dht-sensor/node_modules/node-addon-api
                      164 silly reify mark deleted [
                      164 silly reify   '/opt/iobroker/node_modules/node-dht-sensor/node_modules/node-addon-api'
                      164 silly reify ]
                      165 info run usocket@0.3.0 install node_modules/usocket node-gyp rebuild
                      166 info run usocket@0.3.0 install { code: 1, signal: null }
                      167 verbose reify failed optional dependency /opt/iobroker/node_modules/usocket
                      168 silly reify mark deleted [ '/opt/iobroker/node_modules/usocket' ]
                      169 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp
                      170 silly reify mark deleted [
                      170 silly reify   '/opt/iobroker/node_modules/node-gyp',
                      170 silly reify   '/opt/iobroker/node_modules/.bin/node-gyp'
                      170 silly reify ]
                      171 verbose reify failed optional dependency /opt/iobroker/node_modules/env-paths
                      172 silly reify mark deleted [ '/opt/iobroker/node_modules/env-paths' ]
                      173 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/glob
                      174 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/glob' ]
                      175 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/npmlog
                      176 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/npmlog' ]
                      177 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/minimatch
                      178 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/minimatch' ]
                      179 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/are-we-there-yet
                      180 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/are-we-there-yet' ]
                      181 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/gauge
                      182 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/gauge' ]
                      183 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/brace-expansion
                      184 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/brace-expansion' ]
                      185 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/readable-stream
                      186 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/readable-stream' ]
                      187 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/aproba
                      188 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/aproba' ]
                      189 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/signal-exit
                      190 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/signal-exit' ]
                      191 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/string-width
                      192 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/string-width' ]
                      193 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/strip-ansi
                      194 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/strip-ansi' ]
                      195 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/safe-buffer
                      196 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/safe-buffer' ]
                      197 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/string_decoder
                      198 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/string_decoder' ]
                      199 verbose reify failed optional dependency /opt/iobroker/node_modules/code-point-at
                      200 silly reify mark deleted [ '/opt/iobroker/node_modules/code-point-at' ]
                      201 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/is-fullwidth-code-point
                      202 silly reify mark deleted [
                      202 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/is-fullwidth-code-point'
                      202 silly reify ]
                      203 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/ansi-regex
                      204 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/ansi-regex' ]
                      205 verbose reify failed optional dependency /opt/iobroker/node_modules/number-is-nan
                      206 silly reify mark deleted [ '/opt/iobroker/node_modules/number-is-nan' ]
                      207 info run raw-socket@1.8.1 install { code: 1, signal: null }
                      208 verbose reify failed optional dependency /opt/iobroker/node_modules/raw-socket
                      209 silly reify mark deleted [ '/opt/iobroker/node_modules/raw-socket' ]
                      210 verbose reify failed optional dependency /opt/iobroker/node_modules/net-ping
                      211 silly reify mark deleted [ '/opt/iobroker/node_modules/net-ping' ]
                      212 verbose reify failed optional dependency /opt/iobroker/node_modules/raw-socket/node_modules/nan
                      213 silly reify mark deleted [ '/opt/iobroker/node_modules/raw-socket/node_modules/nan' ]
                      214 info run @stoprocent/noble@1.19.1 install { code: 7, signal: null }
                      215 verbose reify failed optional dependency /opt/iobroker/node_modules/@stoprocent/noble
                      216 silly reify mark deleted [ '/opt/iobroker/node_modules/@stoprocent/noble' ]
                      217 verbose reify failed optional dependency /opt/iobroker/node_modules/napi-thread-safe-callback
                      218 silly reify mark deleted [ '/opt/iobroker/node_modules/napi-thread-safe-callback' ]
                      219 verbose reify failed optional dependency /opt/iobroker/node_modules/@stoprocent/noble/node_modules/node-addon-api
                      220 silly reify mark deleted [
                      220 silly reify   '/opt/iobroker/node_modules/@stoprocent/noble/node_modules/node-addon-api'
                      220 silly reify ]
                      221 verbose stack Error: command failed
                      221 verbose stack     at promiseSpawn (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:22:22)
                      221 verbose stack     at spawnWithShell (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:124:10)
                      221 verbose stack     at promiseSpawn (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:12:12)
                      221 verbose stack     at runScriptPkg (/usr/lib/node_modules/npm/node_modules/@npmcli/run-script/lib/run-script-pkg.js:77:13)
                      221 verbose stack     at runScript (/usr/lib/node_modules/npm/node_modules/@npmcli/run-script/lib/run-script.js:9:12)
                      221 verbose stack     at /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/rebuild.js:329:17
                      221 verbose stack     at run (/usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:67:22)
                      221 verbose stack     at /usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:84:9
                      221 verbose stack     at new Promise (<anonymous>)
                      221 verbose stack     at callLimit (/usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:35:69)
                      222 verbose pkgid opengpio@1.0.18
                      223 error code 7
                      224 error path /opt/iobroker/node_modules/opengpio
                      225 error command failed
                      226 error command sh -c node-gyp rebuild
                      227 error gyp ERR! UNCAUGHT EXCEPTION
                      227 error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
                      227 error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)
                      227 error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9
                      227 error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:188:23)
                      227 error gyp ERR! System Linux 6.12.34+rpt-rpi-v8
                      227 error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                      227 error gyp ERR! cwd /opt/iobroker/node_modules/opengpio
                      227 error gyp ERR! node -v v20.19.4
                      227 error gyp ERR! node-gyp -v v7.1.2
                      227 error gyp ERR! Node-gyp failed to build your package.
                      227 error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
                      228 silly unfinished npm timer reify 1756140069485
                      229 silly unfinished npm timer reify:build 1756140076895
                      230 silly unfinished npm timer build 1756140076898
                      231 silly unfinished npm timer build:deps 1756140076898
                      232 silly unfinished npm timer build:run:install 1756140079094
                      233 silly unfinished npm timer build:run:install:node_modules/opengpio 1756140079113
                      234 verbose cwd /opt/iobroker
                      235 verbose os Linux 6.12.34+rpt-rpi-v8
                      236 verbose node v20.19.4
                      237 verbose npm  v10.8.2
                      238 verbose exit 7
                      239 verbose code 7
                      • S sonny
                        Hier bitteschön :)
                        78 silly reify }
                        164 silly reify ]
                        170 silly reify ]
                        202 silly reify ]
                        220 silly reify ]
                        223 error code 7
                        238 verbose exit 7
                        239 verbose code 7
                        Thomas BraunT
                        Thomas BraunT
                        apt policy libgpiod-dev libgpiod*
                        sagt?
                          sagt?
                          S
                          S
                          sonny
                          libgpiod-dev:
                            Installed: 1.6.3-1+b3
                            Candidate: 1.6.3-1+b3
                            Version table:
                           *** 1.6.3-1+b3 500
                                  500 http://deb.debian.org/debian bookworm/main arm64 Packages
                          libgpiod-dev:
                            Version table:
                           *** 1.6.3-1+b3 500
                          libgpiod-doc:
                            Installed: (none)
                            Candidate: 1.6.3-1
                            Version table:
                               1.6.3-1 500
                                  500 http://deb.debian.org/debian bookworm/main armhf Packages
                          libgpiod2:
                            Version table:
                           *** 1.6.3-1+b3 500
                          • S sonny
                            libgpiod-dev:
                              Version table:
                             *** 1.6.3-1+b3 500
                            libgpiod-dev:
                              Version table:
                             *** 1.6.3-1+b3 500
                            libgpiod-doc:
                              Installed: (none)
                              Candidate: 1.6.3-1
                              Version table:
                                 1.6.3-1 500
                            libgpiod2:
                              Version table:
                             *** 1.6.3-1+b3 500
                            Thomas BraunT
                            Thomas BraunT
                            @sonny
                            Keine Ahnung.
                              @sonny
                              Keine Ahnung.
                              S
                              S
                              sonny
                              Ich steh auch am schlauch , ich hab mich vorher mit chatgpt ein wenig auseinandergesetzt. ich kann dieses "opengpio" bauen. wenn ichs ausserhalb von iobroker builden will.
                              Mir ist lediglich bei der installation etwas aufgefallen.
                              Nach erstellen der nvme mit dem raspberry pi imager, rein in die ssh, erste arbeit "apt update" und apt upgrade.
                              Ich wurde daraufhin während apt upgrade lief, mit einer recht merkwürdigen Frage bezüglich der Ramdisk konfrontiert. Ich hab da "Y" gedrückt. da passte irgendetwas nicht zusammen
                              Ich hatte selbiges mit einem raspberry pi 3 (Anderer Verwendungszweck), den ich vor 2 Wochen "aufgesetzt" hab, ebenfalls. Ob es damit zusammenhängt weiss ich nicht. iob fix läuft ohne nennenswerten probleme durch..
                              Ich versuch die installation nochmal morgen, vielleicht ging da irgendetwas daneben. ich habe keine Ahnung
                              • S sonny
                                OliverIOO
                                OliverIOO
                                OliverIO
                                @sonny
                                ist opengpio 1.0.18 nicht etwas zu alt für ein aktuelles betriebssystem.
                                aktuell ist 2.0.2
                                https://www.npmjs.com/package/opengpio
                                woher wird das referenziert?
                                Meine Adapter und Widgets
                                Links im Profil
                                • OliverIOO OliverIO
                                  @sonny
                                  aktuell ist 2.0.2
                                  Thomas BraunT
                                  Thomas BraunT
                                  @oliverio sagte in Kann den Rpi Adapter auf meinem Raspberry nicht installieren:
                                  opengpio 2.0.x baut aber afaik nur mit aktuellster libgpiod.
                                  Und die kommt erst mit Trixie mit:
                                  apt policy libgpiod3
                                  libgpiod3:
                                    Installed: 2.2.1-2
                                    Candidate: 2.2.1-2
                                    Version table:
                                   *** 2.2.1-2 500
                                          500 http://deb.debian.org/debian trixie/main arm64 Packages
                                  echad@chet:~ $
                                  Hier baut das Ding auch, wenn ich die package.json etwas anpasse.
                                  echad@chet:/opt/iobroker $ npm ls opengpio
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  └─┬ iobroker.rpi2@2.4.0 (git+ssh://git@github.com/Grothesk242/ioBroker.rpi2.git#c87e9539d89bac8f4d19b266679bcb78ed554f1d)
                                    └── opengpio@2.0.2
                                    libgpiod3:
                                      Installed: 2.2.1-2
                                      Candidate: 2.2.1-2
                                      Version table:
                                     *** 2.2.1-2 500
                                    echad@chet:~ $
                                      └── opengpio@2.0.2
                                    S
                                    S
                                    sonny
                                    Das Problem ist in meinem Fall dieser Backup Adapter. (Der noch nie richtig funktioniert hat, wenn es darum ging irgendetwas wiederherzustellen).Er stellt zwar alles wieder her, macht unterm Strich aber das ganze System kaputt.
                                    Hab iobroker eben wiedermal neu aufgesetzt, und konnte den adapter Rpi ohne probleme von hand aus der adapterliste installieren...
                                    Dannach spielte ich das backup mit dem backup adapter zurück, er kann DeyeIDC nicht wiederherstellen, Fehler -25 . immer das gleiche mit diesem Ding. Löscht mir meine vorangegangene Händische Installation von Rpi, und kann es natürlich mit seinem dämlichen Fehler -25 nichtmehr installieren.
                                    Ich schmeiss den nun endgültig aus dem System. Ich bin froh das ich die Datenpunkte alle separat gespeichert hab.
                                    Für zukünftige Backups nutze ich das raspiBackup und falls von Hand: Adapter von hand alle installieren, mit den entsprechenden Jsons konfigurieren, alle Datenpunkte wiederherstellen und fertig.
                                    Thomas BraunT simatecS mcm1957M 3 Antworten Letzte Antwort
                                    • S sonny
                                      Thomas BraunT
                                      Thomas BraunT
                                      Das sollte so nicht sein, hast du mal ein Issue beim Adapter angelegt? Dann kann sich @simatec das mal anschauen.
                                      Aus eigener Erfahrung funktioniert der Adapter nämlich auf meinen Systemen einwandfrei.
                                        S
                                        S
                                        sonny
                                        Ich mach grad ne vierte Testinstallation. Ich probier ein bisschen herum um das Problem besser eingrenzen zu können. Bei mir ist nix verhaut. Ich hab ja alles da .
                                        Ich betreib ein wenig Ursachenforschung. Werd natürlich Bescheid geben !. Ich glaube das der Backupadapter, beim Wiederherstellen (!) irgendetwas mit irgendwelchen Berechtigungen anstellt. Ich glaube das iobroker seine Fähigkeit "verliert" irgendwo irgendwas zu schreiben.
                                        Ich kümmer mich da kommende 2-3 Tage darum. und werd definitiv ein Issue schreiben. :)
                                        Sichern geht super rein ins NFS und ins Dr.Google Drive. Wiederherstellen eigentlich auch, bis es zur Adapterinstallation kommt. Die Adapter die nicht wiederhergestellt werden können , wegen Fehler -25 ändern sich nämlich willkürlich (Es sind nicht immer die gleichen).
                                        Ich mach momentan eine normale Installation von Hand, wie oben beschrieben, wenn das klappt, ist definitiv der BackupAdapter beim Wiederherstellen das Problem. Schauen wir mal !
                                        • S sonny
                                          dann müsste ja die Neuinstallation krumm sein und backitup biegt es richtig
                                          84.0k
