  4. Kann den Rpi Adapter auf meinem Raspberry nicht installieren
    apollon77A
adaptergpiohilfeinstallationraspberry
48 Beiträge 9 Kommentatoren 5.6k Aufrufe 7 Beobachtet
  • Basti97B Basti97
    @thomas-braun ist vielleicht nodejs zu neu?
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    @basti97
    Gib mal die Ausgabe von
    iob diag
    bekannt sowie von
    apt policy libgpiod*
    Basti97B 1 Antwort Letzte Antwort
      @basti97
      iob diag
      bekannt sowie von
      Basti97B
      Basti97B
      Basti97
      @thomas-braun sagte in Kann den Rpi Adapter auf meinem Raspberry nicht installieren:
      iob diag
      ```bash
      Script v.2025-03-08
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v7+
            Architecture: arm
      OS is similar to: debian
      Model           : Raspberry Pi 3 Model B Plus Rev 1.3
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       09:46:33 up 14:44,  2 users,  load average: 3.28, 2.88, 2.27
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      ~ Arm frequency capping has occurred
      *** TIME AND TIMEZONES ***
                     Local time: Wed 2025-07-16 09:46:33 CEST
                 Universal time: Wed 2025-07-16 07:46:33 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            921M        216M        209M        1.0M        496M        634M
      Swap:            99M         78M         21M
      Total:          1.0G        295M        230M
      Active iob-Instances:   3
                921 M total memory
                216 M used memory
                407 M active memory
                210 M inactive memory
                209 M free memory
                 70 M buffer memory
                425 M swap cache
                 99 M total swap
                 78 M used swap
                 21 M free swap
      top - 09:46:34 up 14:44,  2 users,  load average: 3.28, 2.88, 2.27
      Tasks: 158 total,   1 running, 157 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  5.5 us,  5.5 sy,  0.0 ni, 89.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :    922.0 total,    209.1 free,    216.4 used,    496.5 buff/cache
      MiB Swap:    100.0 total,     21.0 free,     79.0 used.    633.7 avail Mem
      *** FAILED SERVICES ***
        UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
      * bthelper@hci0.service         loaded failed failed Raspberry Pi bluetooth helper
      * colord.service                loaded failed failed Manage, Install and Generate Color Profiles
      * openvpn-client@client.service loaded failed failed OpenVPN tunnel for client
      * plymouth-start.service        loaded failed failed Show Plymouth Boot Screen
      * wg-quick@wg0.service          loaded failed failed WireGuard via wg-quick(8) for wg0
      5 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      144 CRITICAL ERRORS DETECTED!
      Check 'sudo dmesg --level=emerg,alert,crit -T' for details
      *** FILESYSTEM ***
      /dev/root      ext4       15G  6.2G  7.7G  45% /
      devtmpfs       devtmpfs  333M     0  333M   0% /dev
      tmpfs          tmpfs     461M  4.0K  461M   1% /dev/shm
      tmpfs          tmpfs     185M  772K  184M   1% /run
      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs      93M   20K   93M   1% /run/user/1000
      [Tue Jul 15 19:01:52 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=44a3dce6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Tue Jul 15 19:01:55 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Tue Jul 15 19:01:55 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Tue Jul 15 19:01:58 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      2.2G    /var/
      1.1G    /var/cache/apt
      1.1G    /var/cache
      992M    /var/cache/apt/archives
      865M    /var/log
      Journal file /var/log/journal/17f5be65a0144b718868da827cf6bffe/system@0c9cfaba2fdb43568eb34c2594062e00-0000000000000001-0005cf905c0cadb6.journal corrupted, ignoring file.
      Archived and active journals take up 776.1M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      103M    /opt/iobroker/iobroker-data/
      64M     /opt/iobroker/iobroker-data/files
      47M     /opt/iobroker/iobroker-data/files/admin.admin
      46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
      22M     /opt/iobroker/iobroker-data/objects.jsonl
      8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
      3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-CyIqcfMJ.js
      3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
      3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-IIKn7Ixx.js
      USB-Devices by-id:
      No Devices found 'by-id'
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.1
      /usr/bin/node           v20.19.1
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.31.0
      nodejs:
        Installed: 20.19.1-1nodesource1
        Candidate: 20.19.1-1nodesource1
        Version table:
       *** 20.19.1-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
           20.19.0-1nodesource1 600
           20.18.3-1nodesource1 600
           20.18.2-1nodesource1 600
           20.18.1-1nodesource1 600
           20.18.0-1nodesource1 600
           20.17.0-1nodesource1 600
           20.16.0-1nodesource1 600
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           12.22.12~dfsg-1~deb11u7 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 35829)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.17
      javascript:     "javascript" not found
      nodejs modules from github:     0
      Adapter State
        system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1884
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "backitup"     : 3.3.5    , installed 3.2.2  [Updatable]
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
      Objects and States
      Objects:        171
      States:         106
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          14657      623/lighttpd
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14552      551/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          14166      876/dnsmasq
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       285666     21933/iobroker.js-c
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       285671     21933/iobroker.js-c
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          297692     25814/cupsd
      tcp6       0      0 :::80                   :::*                    LISTEN      0          14658      623/lighttpd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14554      551/sshd: /usr/sbin
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          297691     25814/cupsd
      tcp6       0      0 :::53                   :::*                    LISTEN      0          14168      876/dnsmasq
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       288840     21989/io.admin.0
      udp        0      0 0.0.0.0:59903           0.0.0.0:*                           108        12483      337/avahi-daemon: r
      udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          14165      876/dnsmasq
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14162      876/dnsmasq
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12897      857/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12481      337/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          116938     857/dhcpcd
      udp6       0      0 :::53                   :::*                                0          14167      876/dnsmasq
      udp6       0      0 :::58970                :::*                                108        12484      337/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        12482      337/avahi-daemon: r
      2025-07-16 00:19:31.687  - info: host.raspberrypi iobroker gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v20.19.1gyp ERR! node-gyp -v v10.1.0gyp ERR! not ok
      2025-07-16 00:19:31.836  - info: host.raspberrypi iobroker npm error code 1
      2025-07-16 00:19:31.839  - info: host.raspberrypi iobroker npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuild
      2025-07-16 00:19:31.850  - info: host.raspberrypi iobroker npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-07-15T22_18_28_400Z-debug-0.log
      2025-07-16 00:19:31.890  - error: host.raspberrypi iobroker gyp info it worked if it ends with okgyp info using node-gyp@10.1.0gyp info using node@20.19.1 | linux | armgyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/diskusage/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.19.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.19.1',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.19.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/diskusage',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]<command-line>: warning: "_GLIBCXX_USE_CXX11_ABI" redefined<command-line>: note: this is the location of the previous definitionIn file included from ../../nan/nan.h:62,                 from ../src/main.cpp:3:/home/iobroker/.cache/node-gyp/20.19.1/include/node/node.h:1226:7: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type] 1226 |       (node::addon_register_func) (regfunc),                          \      |       ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/20.19.1/include/node/node.h:1260:3: note: in expansion of macro 'NODE_MODULE_X' 1260 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)      |   ^~~~~~~~~~~~~../src/main.cpp:42:1: note: in expansion of macro 'NODE_MODULE'   42 | NODE_MODULE(diskusage, Init)      | ^~~~~~~~~~~<command-line>: warning: "_GLIBCXX_USE_CXX11_ABI" redefined<command-line>: note: this is the location of the previous definition/usr/lib/gcc/arm-linux-gnueabihf/10/crtbeginS.o: file not recognized: file format not recognizedcollect2: error: ld returned 1 exit statusmake: *** [diskusage.target.mk:135: Release/obj.target/diskusage.node] Error 1gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)gyp ERR! System Linux 6.1.21-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/diskusagegyp ERR! node -v v20.19.1gyp ERR! node-gyp -v v10.1.0gyp ERR! not ok gyp info it worked if it ends with okgyp info using node-gyp@10.1.0gyp info using node@20.19.1 | linux | armgyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-dht-sensor/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.19.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.19.1',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.19.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-dht-sensor',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]gyp info ok gyp info it worked if it ends with okgyp info using node-gyp@10.1.0gyp info using node@20.19.1 | linux | armgyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/opengpio/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/20.19.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.19.1',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.19.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/opengpio',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]/usr/lib/gcc/arm-linux-gnueabihf/10/crtbeginS.o: file not recognized: file format not recognizedcollect2: error: ld returned 1 exit statusmake: *** [opengpio.target.mk:133: Release/obj.target/opengpio.node] Error 1gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)gyp ERR! System Linux 6.1.21-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v20.19.1gyp ERR! node-gyp -v v10.1.0gyp ERR! not ok npm error code 1npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-07-15T22_18_28_400Z-debug-0.log
      2025-07-16 00:19:31.893  - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.rpi2@2.4.0: 1
      2025-07-16 00:19:32.961  - info: host.raspberrypi iobroker exit 25
      2025-07-16 00:22:15.158  - info: admin.0 (21989) <== Disconnect system.user.admin from ::ffff:192.168.1.3 admin
      2025-07-16 00:22:17.669  - info: admin.0 (21989) ==> Connected system.user.admin from ::ffff:192.168.1.3
      2025-07-16 00:32:36.623  - info: admin.0 (21989) <== Disconnect system.user.admin from ::ffff:192.168.1.3 admin
      2025-07-16 00:32:36.881  - info: admin.0 (21989) ==> Connected system.user.admin from ::ffff:192.168.1.3
      2025-07-16 00:32:36.925  - info: admin.0 (21989) <== Disconnect system.user.admin from ::ffff:192.168.1.3 admin
      2025-07-16 00:32:39.394  - info: admin.0 (21989) ==> Connected system.user.admin from ::ffff:192.168.1.3
      2025-07-16 00:38:54.719  - info: host.raspberrypi iobroker add rpi2 --host raspberrypi
      2025-07-16 00:39:02.488  - info: host.raspberrypi iobroker NPM version: 10.8.2
      2025-07-16 00:39:02.492  - info: host.raspberrypi iobroker Installing iobroker.rpi2@2.4.0... (System call)
      2025-07-16 00:40:08.220  - error: host.raspberrypi iobroker npm error code 1npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error make: Entering directory '/opt/iobroker/node_modules/opengpio/build'npm error   CXX(target) Release/obj.target/opengpio/cpp/opengpio.onpm error   SOLINK_MODULE(target) Release/obj.target/opengpio.nodenpm error make: Leaving directory '/opt/iobroker/node_modules/opengpio/build'npm error /usr/lib/gcc/arm-linux-gnueabihf/10/crtbeginS.o: file not recognized: file format not recognizednpm error collect2: error: ld returned 1 exit statusnpm error make: *** [opengpio.target.mk:133: Release/obj.target/opengpio.node] Error 1npm error gyp ERR! build error npm error gyp ERR! stack Error: `make` failed with exit code: 2npm error gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)npm error gyp ERR! System Linux 6.1.21-v7+npm error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpionpm error gyp ERR! node -v v20.19.1npm error gyp ERR! node-gyp -v v10.1.0npm error gyp ERR! not oknpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-07-15T22_39_03_166Z-debug-0.log
      2025-07-16 00:40:08.225  - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.rpi2@2.4.0: 1
      2025-07-16 00:40:09.283  - info: host.raspberrypi iobroker exit 25
      2025-07-16 00:45:05.391  - error: host.raspberrypi Cannot read disk size: Could not determine controller directory
      2025-07-16 00:51:31.884  - info: admin.0 (21989) <== Disconnect system.user.admin from ::ffff:192.168.1.3 admin
      2025-07-16 09:44:56.397  - info: admin.0 (21989) ==> Connected system.user.admin from ::ffff:192.168.1.3
      2025-07-16 09:48:30.566  - info: admin.0 (21989) <== Disconnect system.user.admin from ::ffff:192.168.1.3 admin
      2025-07-16 09:49:23.357  - info: admin.0 (21989) ==> Connected system.user.admin from ::ffff:192.168.1.3
      2025-07-16 09:49:23.955  - info: admin.0 (21989) <== Disconnect system.user.admin from ::ffff:192.168.1.3 admin
      iob diag has finished.
      pi@raspberrypi:~ $ obroker fix
      -bash: obroker: command not found
      pi@raspberrypi:~ $
      ```pi@raspberrypi:~ $ apt policy libgpiod*
      libgpiod-dev:
        Installed: 1.6.2-1+rpi1
        Candidate: 1.6.2-1+rpi1
        Version table:
       *** 1.6.2-1+rpi1 500
      libgpiod-doc:
        Installed: (none)
        Version table:
           1.6.2-1+rpi1 500
      libgpiod2:
        Version table:
      Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
      • Basti97B Basti97
        iob diag
        ```bash
        Script v.2025-03-08
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm
        Docker          : false
        Kernel          : armv7l
        Userland        : 32 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M         78M         21M
                  921 M total memory
                  216 M used memory
                  407 M active memory
                  209 M free memory
                   70 M buffer memory
                  425 M swap cache
                   99 M total swap
                   78 M used swap
                   21 M free swap
        *** FILESYSTEM ***
        /var:
        2.2G    /var/
        1.1G    /var/cache/apt
        1.1G    /var/cache
        865M    /var/log
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.6.17
        Adapter State
        + instance is alive
        Objects and States
        Objects:        171
        States:         106
        Pending Updates: 0
        pi@raspberrypi:~ $
        libgpiod-dev:
          Version table:
        libgpiod-doc:
          Installed: (none)
          Version table:
             1.6.2-1+rpi1 500
        libgpiod2:
          Version table:
        Thomas BraunT
        Thomas BraunT
        @basti97 sagte in Kann den Rpi Adapter auf meinem Raspberry nicht installieren:
        Setz das Ding komplett neu auf, diesmal direkt als RaspberryOS 12 'Lite - 64Bit'.
          Basti97B
          Basti97B
          Basti97
          @thomas-braun Und dann funktoniert es oder?
          Das komische daran ist ich hatte den Rpi vorher als Slave laufen gehabt. Das hatte ich vor längeren mal so eingestellt und er wurde auch gleich wieder erkannt und ich konnte die gpios auch steuern. Ich hatte den Verbund nicht auseinander gemacht und iobroker deinstalliert und alles neu installiert. Danach konnte ich den rpi Adapter nicht mehr installieren.
          • Basti97B Basti97
            Thomas BraunT
            Thomas BraunT
            Kann ich dir nicht sagen. Aber zumindest ist dann die Ausgangslage eine stabile.
              Basti97B
              Basti97B
              Basti97
              @thomas-braun dann probiere ich das mal vielen Dank für deine Hilfe :)
              • GarfonsoG
                GarfonsoG
                Garfonso
                @basti97
                auch wenn Thomas mich (zurecht) haut, kannst du, solange du Bullseye (also das Raspian, was du gerade drauf hast) noch drauf lässt (Sicherheitsrisiko, da EOL, entweder schon oder sehr bald...) die letzte 1.x Version vom rpi2 Adapter nehmen, also 1.3.2. (z.B. mit iob upgrade rpi2@1.3.2 installieren).
                Wenns tatsächlich nur um ein bisschen Spielen für das Kind geht, ist das vielleicht die einfacherere Lösung.
                Aber auf lange Sicht, neues System und neuen Adapter (aber vermutlich bald auch neuen PI, wenn der was tun soll). :-)
                Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
                Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
                • GarfonsoG Garfonso
                  @basti97
                  Thomas BraunT
                  Thomas BraunT
                  @garfonso
                  Aber auch dem Nachwuchs würde ich da ein frisches System hinsetzen. Ich verstehe auch gar nicht, worin die Mega-Hürde hier bestehen soll. Offenbar ist das Ding ja verfügbar, da kann man ja wohl auch ein frisches System draufbügeln.
                  Und für Spielereien mit LEDs und GPIOs braucht es auch keinen rpi2-Adapter/ioBroker.
                  Da wird man mehr lernen, wenn man die GPIOs direkt über das OS anspricht.
                  • Basti97B
                    Basti97B
                    Basti97
                    @garfonso Dankeschön werde ich mal probieren vielen Dank. Ja ich werde das ganze irgendwann nochmal neu aufsetzen aber Kinder sind ungeduldig. Ich manchmal auch was kann ich sonst für Projekte mit den RPI 3 noch machen? Wo die 1GB reichen?
                    • Basti97B Basti97
                      S
                      S
                      sonny
                      schrieb am zuletzt editiert von sonny
                      Hallo , darf ich mich hier mal mitanhängen.
                      Frisch installiertes Iob System (Hab es nach 1,5 Jahren geschafft mir die netzwerkkonfiguration zusammenzuschiessen lach- Ich wollts halt wiedermal genau wissen...)
                      Vor 5 Stunden , lief dieser Adapter also noch.
                      Es ist Debian 12, also Bookworm, nicht Trixie installiert.
                      Node 20.19.4
                      NPM 10.8.2
                      (Es geht auch mit Node 24 nicht, ich hab von 18-20-24 alles durchprobiert). Es kommt immer dasselbe:
                      NPM version: 10.8.2
                      npm error code 7npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error gyp ERR! UNCAUGHT EXCEPTION npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm error gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm error gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm error gyp ERR! stack at FSReqCallback.oncomplete (node:fs:188:23)npm error gyp ERR! System Linux 6.12.34+rpt-rpi-v8npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpionpm error gyp ERR! node -v v20.19.4npm error gyp ERR! node-gyp -v v7.1.2npm error gyp ERR! Node-gyp failed to build your package.npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-08-25T16_36_15_894Z-debug-0.log
                      host.Athena Cannot install iobroker.rpi2@2.4.0: 7
                      ERROR: Process exited with code 25
                      	iobroker npm error code 7npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error gyp ERR! UNCAUGHT EXCEPTION npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm error gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm error gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm error gyp ERR! stack at FSReqCallback.oncomplete (node:fs:188:23)npm error gyp ERR! System Linux 6.12.34+rpt-rpi-v8npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpionpm error gyp ERR! node -v v20.19.4npm error gyp ERR! node-gyp -v v7.1.2npm error gyp ERR! Node-gyp failed to build your package.npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-08-25T16_41_08_597Z-debug-0.log
                      Kann man mir bitte verraten was hier los ist ? Der Geist in der Maschine ? Das Ding lief (Ok da war er bereits installiert) vor 5 Stunden noch ohne irgendwelche Probleme.
                      Ich bin da ein wenig Ratlos :)
                      iob fix usw, auch den npm cache löschen (Auch für den user "iobroker") brachte da keine Abhilfe. Alles läuft, nur diesen Adapter kann ich nicht installieren. Es sei kurz gesagt: Ich hab mit dem backup Adapter ein Backup zurückgespielt.... (Was ebenfalls 5 Stunden alt ist)
                      Vielen Dank euch vorab. LG
                      • S sonny
                        Node 20.19.4
                        NPM 10.8.2
                        NPM version: 10.8.2
                        Thomas BraunT
                        Thomas BraunT
                        @sonny sagte in Kann den Rpi Adapter auf meinem Raspberry nicht installieren:
                        Was steht denn da drin?
                        Bitte in Codetags eingebettet posten.
                          S
                          S
                          sonny
                          Hier bitteschön :)
                          0 verbose cli /usr/bin/node /usr/bin/npm
                          1 info using npm@10.8.2
                          2 info using node@v20.19.4
                          3 silly config load:file:/usr/lib/node_modules/npm/npmrc
                          4 silly config load:file:/opt/iobroker/.npmrc
                          5 silly config load:file:/home/iobroker/.npmrc
                          6 silly config load:file:/usr/etc/npmrc
                          7 verbose title npm install iobroker.rpi2@2.4.0
                          8 verbose argv "install" "--save-exact" "--loglevel" "error" "iobroker.rpi2@2.4.0"
                          9 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2025-08-25T16_41_08_597Z-
                          10 verbose logfile /home/iobroker/.npm/_logs/2025-08-25T16_41_08_597Z-debug-0.log
                          11 silly packumentCache heap:2197815296 maxSize:549453824 maxEntrySize:274726912
                          12 silly logfile start cleaning logs, removing 1 files
                          13 silly logfile done cleaning log files
                          14 silly idealTree buildDeps
                          15 silly fetch manifest iobroker.rpi2@2.4.0
                          16 silly packumentCache full:https://registry.npmjs.org/iobroker.rpi2 cache-miss
                          17 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
                          18 http fetch GET 200 https://registry.npmjs.org/iobroker.rpi2 83ms (cache hit)
                          19 silly packumentCache full:https://registry.npmjs.org/iobroker.rpi2 set size:155094 disposed:false
                          20 silly placeDep ROOT iobroker.rpi2@2.4.0 OK for: iobroker.inst@3.0.0 want: 2.4.0
                          21 silly fetch manifest ci@^2.3.0
                          22 silly packumentCache full:https://registry.npmjs.org/ci cache-miss
                          23 silly fetch manifest opengpio@^1.0.17
                          24 silly packumentCache full:https://registry.npmjs.org/opengpio cache-miss
                          25 silly fetch manifest node-dht-sensor@^0.4.5
                          26 silly packumentCache full:https://registry.npmjs.org/node-dht-sensor cache-miss
                          27 http fetch GET 200 https://registry.npmjs.org/opengpio 33ms (cache hit)
                          28 silly packumentCache full:https://registry.npmjs.org/opengpio set size:46175 disposed:false
                          29 http fetch GET 200 https://registry.npmjs.org/ci 41ms (cache hit)
                          30 silly packumentCache full:https://registry.npmjs.org/ci set size:22895 disposed:false
                          31 http fetch GET 200 https://registry.npmjs.org/node-dht-sensor 40ms (cache hit)
                          32 silly packumentCache full:https://registry.npmjs.org/node-dht-sensor set size:76611 disposed:false
                          33 silly placeDep ROOT ci@2.3.0 OK for: iobroker.rpi2@2.4.0 want: ^2.3.0
                          34 silly placeDep ROOT node-dht-sensor@0.4.5 OK for: iobroker.rpi2@2.4.0 want: ^0.4.5
                          35 silly placeDep ROOT opengpio@1.0.18 OK for: iobroker.rpi2@2.4.0 want: ^1.0.17
                          36 silly fetch manifest node-addon-api@^1.6.3
                          37 silly packumentCache full:https://registry.npmjs.org/node-addon-api cache-miss
                          38 silly fetch manifest node-addon-api@^7.0.0
                          39 silly packumentCache full:https://registry.npmjs.org/node-addon-api cache-miss
                          40 http fetch GET 200 https://registry.npmjs.org/node-addon-api 303ms (cache hit)
                          41 silly packumentCache full:https://registry.npmjs.org/node-addon-api set size:328136 disposed:false
                          42 http fetch GET 200 https://registry.npmjs.org/node-addon-api 391ms (cache hit)
                          43 silly packumentCache full:https://registry.npmjs.org/node-addon-api set size:328136 disposed:false
                          44 silly packumentCache full:https://registry.npmjs.org/node-addon-api dispose
                          45 silly placeDep node_modules/node-dht-sensor node-addon-api@1.7.2 OK for: node-dht-sensor@0.4.5 want: ^1.6.3
                          46 silly placeDep node_modules/opengpio node-addon-api@7.1.1 OK for: opengpio@1.0.18 want: ^7.0.0
                          47 silly fetch manifest gcp-metadata@^5.2.0
                          48 silly packumentCache full:https://registry.npmjs.org/gcp-metadata cache-miss
                          49 http fetch GET 200 https://registry.npmjs.org/gcp-metadata 2190ms (cache hit)
                          50 silly packumentCache full:https://registry.npmjs.org/gcp-metadata set size:182287 disposed:false
                          51 silly placeDep node_modules/iobroker.node-red gcp-metadata@5.3.0 OK for: mongodb@6.18.0 want: ^5.2.0
                          52 silly fetch manifest gaxios@^5.0.0
                          53 silly packumentCache full:https://registry.npmjs.org/gaxios cache-miss
                          54 http fetch GET 200 https://registry.npmjs.org/gaxios 58ms (cache hit)
                          55 silly packumentCache full:https://registry.npmjs.org/gaxios set size:334347 disposed:false
                          56 silly placeDep node_modules/iobroker.node-red gaxios@5.1.3 OK for: gcp-metadata@5.3.0 want: ^5.0.0
                          57 silly fetch manifest node-fetch@^2.6.9
                          58 silly packumentCache full:https://registry.npmjs.org/node-fetch cache-miss
                          59 silly fetch manifest https-proxy-agent@^5.0.0
                          60 silly packumentCache full:https://registry.npmjs.org/https-proxy-agent cache-miss
                          61 http fetch GET 200 https://registry.npmjs.org/https-proxy-agent 28ms (cache hit)
                          62 silly packumentCache full:https://registry.npmjs.org/https-proxy-agent set size:76222 disposed:false
                          63 http fetch GET 200 https://registry.npmjs.org/node-fetch 41ms (cache hit)
                          64 silly packumentCache full:https://registry.npmjs.org/node-fetch set size:896010 disposed:false
                          65 silly fetch manifest encoding@^0.1.0
                          66 silly packumentCache full:https://registry.npmjs.org/encoding cache-miss
                          67 http fetch GET 200 https://registry.npmjs.org/encoding 9ms (cache hit)
                          68 silly packumentCache full:https://registry.npmjs.org/encoding set size:17833 disposed:false
                          69 silly placeDep node_modules/iobroker.node-red https-proxy-agent@5.0.1 OK for: gaxios@5.1.3 want: ^5.0.0
                          70 silly placeDep node_modules/iobroker.node-red node-fetch@2.7.0 OK for: gaxios@5.1.3 want: ^2.6.9
                          71 silly fetch manifest agent-base@6
                          72 silly packumentCache full:https://registry.npmjs.org/agent-base cache-miss
                          73 http fetch GET 200 https://registry.npmjs.org/agent-base 10ms (cache hit)
                          74 silly packumentCache full:https://registry.npmjs.org/agent-base set size:67460 disposed:false
                          75 silly placeDep node_modules/iobroker.node-red agent-base@6.0.2 OK for: https-proxy-agent@5.0.1 want: 6
                          76 silly reify mark retired [ '/opt/iobroker/node_modules/node-dht-sensor' ]
                          77 silly reify mark retired [ '/opt/iobroker/node_modules/@stoprocent/noble' ]
                          78 silly reify moves {
                          78 silly reify   '/opt/iobroker/node_modules/node-dht-sensor': '/opt/iobroker/node_modules/.node-dht-sensor-QmYjQqky',
                          78 silly reify   '/opt/iobroker/node_modules/@stoprocent/noble': '/opt/iobroker/node_modules/@stoprocent/.noble-3N4hliTW'
                          78 silly reify }
                          79 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
                          80 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
                          81 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-win32-x64-msvc
                          82 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-win32-x64-msvc' ]
                          83 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-win32-ia32-msvc
                          84 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-win32-ia32-msvc' ]
                          85 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-win32-arm64-msvc
                          86 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-win32-arm64-msvc' ]
                          87 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-wasm32-wasi
                          88 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-wasm32-wasi' ]
                          89 verbose reify failed optional dependency /opt/iobroker/node_modules/@napi-rs/wasm-runtime
                          90 silly reify mark deleted [ '/opt/iobroker/node_modules/@napi-rs/wasm-runtime' ]
                          91 verbose reify failed optional dependency /opt/iobroker/node_modules/@emnapi/core
                          92 silly reify mark deleted [ '/opt/iobroker/node_modules/@emnapi/core' ]
                          93 verbose reify failed optional dependency /opt/iobroker/node_modules/@tybys/wasm-util
                          94 silly reify mark deleted [ '/opt/iobroker/node_modules/@tybys/wasm-util' ]
                          95 verbose reify failed optional dependency /opt/iobroker/node_modules/@emnapi/wasi-threads
                          96 silly reify mark deleted [ '/opt/iobroker/node_modules/@emnapi/wasi-threads' ]
                          97 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-linux-x64-musl
                          98 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-linux-x64-musl' ]
                          99 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-linux-x64-gnu
                          100 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-linux-x64-gnu' ]
                          101 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-linux-arm-gnueabihf
                          102 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-linux-arm-gnueabihf' ]
                          103 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-freebsd-x64
                          104 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-freebsd-x64' ]
                          105 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-darwin-x64
                          106 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-darwin-x64' ]
                          107 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-darwin-arm64
                          108 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-darwin-arm64' ]
                          109 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-android-arm64
                          110 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-android-arm64' ]
                          111 verbose reify failed optional dependency /opt/iobroker/node_modules/@node-rs/bcrypt-android-arm-eabi
                          112 silly reify mark deleted [ '/opt/iobroker/node_modules/@node-rs/bcrypt-android-arm-eabi' ]
                          113 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-win32-x64
                          114 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-win32-x64' ]
                          115 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-win32-ia32
                          116 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-win32-ia32' ]
                          117 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-win32-arm64
                          118 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-win32-arm64' ]
                          119 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-wasm32
                          120 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-wasm32' ]
                          121 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-linuxmusl-x64
                          122 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-linuxmusl-x64' ]
                          123 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-linux-x64
                          124 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-linux-x64' ]
                          125 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-linux-s390x
                          126 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-linux-s390x' ]
                          127 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-linux-ppc64
                          128 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-linux-ppc64' ]
                          129 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-linux-arm
                          130 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-linux-arm' ]
                          131 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-libvips-linuxmusl-x64
                          132 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-libvips-linuxmusl-x64' ]
                          133 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-libvips-linux-x64
                          134 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-libvips-linux-x64' ]
                          135 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-libvips-linux-s390x
                          136 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-libvips-linux-s390x' ]
                          137 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-libvips-linux-ppc64
                          138 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-libvips-linux-ppc64' ]
                          139 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-libvips-linux-arm
                          140 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-libvips-linux-arm' ]
                          141 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-libvips-darwin-x64
                          142 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-libvips-darwin-x64' ]
                          143 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-libvips-darwin-arm64
                          144 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-libvips-darwin-arm64' ]
                          145 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-darwin-x64
                          146 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-darwin-x64' ]
                          147 verbose reify failed optional dependency /opt/iobroker/node_modules/@img/sharp-darwin-arm64
                          148 silly reify mark deleted [ '/opt/iobroker/node_modules/@img/sharp-darwin-arm64' ]
                          149 warn deprecated npmlog@4.1.2: This package is no longer supported.
                          150 warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
                          151 warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                          152 warn deprecated gauge@2.7.4: This package is no longer supported.
                          153 info run iobroker.rpi2@2.4.0 preinstall node_modules/iobroker.rpi2 sudo apt-get install -y libgpiod-dev || exit 0
                          154 info run iobroker.rpi2@2.4.0 preinstall { code: 0, signal: null }
                          155 info run @stoprocent/noble@1.19.1 install node_modules/@stoprocent/noble node-gyp-build
                          156 info run node-dht-sensor@0.4.5 install node_modules/node-dht-sensor node-gyp configure
                          157 info run opengpio@1.0.18 install node_modules/opengpio node-gyp rebuild
                          158 info run opengpio@1.0.18 install { code: 7, signal: null }
                          159 info run raw-socket@1.8.1 install node_modules/raw-socket node-gyp rebuild
                          160 info run node-dht-sensor@0.4.5 install { code: 7, signal: null }
                          161 verbose reify failed optional dependency /opt/iobroker/node_modules/node-dht-sensor
                          162 silly reify mark deleted [ '/opt/iobroker/node_modules/node-dht-sensor' ]
                          163 verbose reify failed optional dependency /opt/iobroker/node_modules/node-dht-sensor/node_modules/node-addon-api
                          164 silly reify mark deleted [
                          164 silly reify   '/opt/iobroker/node_modules/node-dht-sensor/node_modules/node-addon-api'
                          164 silly reify ]
                          165 info run usocket@0.3.0 install node_modules/usocket node-gyp rebuild
                          166 info run usocket@0.3.0 install { code: 1, signal: null }
                          167 verbose reify failed optional dependency /opt/iobroker/node_modules/usocket
                          168 silly reify mark deleted [ '/opt/iobroker/node_modules/usocket' ]
                          169 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp
                          170 silly reify mark deleted [
                          170 silly reify   '/opt/iobroker/node_modules/node-gyp',
                          170 silly reify   '/opt/iobroker/node_modules/.bin/node-gyp'
                          170 silly reify ]
                          171 verbose reify failed optional dependency /opt/iobroker/node_modules/env-paths
                          172 silly reify mark deleted [ '/opt/iobroker/node_modules/env-paths' ]
                          173 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/glob
                          174 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/glob' ]
                          175 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/npmlog
                          176 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/npmlog' ]
                          177 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/minimatch
                          178 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/minimatch' ]
                          179 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/are-we-there-yet
                          180 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/are-we-there-yet' ]
                          181 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/gauge
                          182 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/gauge' ]
                          183 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/brace-expansion
                          184 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/brace-expansion' ]
                          185 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/readable-stream
                          186 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/readable-stream' ]
                          187 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/aproba
                          188 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/aproba' ]
                          189 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/signal-exit
                          190 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/signal-exit' ]
                          191 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/string-width
                          192 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/string-width' ]
                          193 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/strip-ansi
                          194 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/strip-ansi' ]
                          195 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/safe-buffer
                          196 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/safe-buffer' ]
                          197 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/string_decoder
                          198 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/string_decoder' ]
                          199 verbose reify failed optional dependency /opt/iobroker/node_modules/code-point-at
                          200 silly reify mark deleted [ '/opt/iobroker/node_modules/code-point-at' ]
                          201 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/is-fullwidth-code-point
                          202 silly reify mark deleted [
                          202 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/is-fullwidth-code-point'
                          202 silly reify ]
                          203 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/ansi-regex
                          204 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/ansi-regex' ]
                          205 verbose reify failed optional dependency /opt/iobroker/node_modules/number-is-nan
                          206 silly reify mark deleted [ '/opt/iobroker/node_modules/number-is-nan' ]
                          207 info run raw-socket@1.8.1 install { code: 1, signal: null }
                          208 verbose reify failed optional dependency /opt/iobroker/node_modules/raw-socket
                          209 silly reify mark deleted [ '/opt/iobroker/node_modules/raw-socket' ]
                          210 verbose reify failed optional dependency /opt/iobroker/node_modules/net-ping
                          211 silly reify mark deleted [ '/opt/iobroker/node_modules/net-ping' ]
                          212 verbose reify failed optional dependency /opt/iobroker/node_modules/raw-socket/node_modules/nan
                          213 silly reify mark deleted [ '/opt/iobroker/node_modules/raw-socket/node_modules/nan' ]
                          214 info run @stoprocent/noble@1.19.1 install { code: 7, signal: null }
                          215 verbose reify failed optional dependency /opt/iobroker/node_modules/@stoprocent/noble
                          216 silly reify mark deleted [ '/opt/iobroker/node_modules/@stoprocent/noble' ]
                          217 verbose reify failed optional dependency /opt/iobroker/node_modules/napi-thread-safe-callback
                          218 silly reify mark deleted [ '/opt/iobroker/node_modules/napi-thread-safe-callback' ]
                          219 verbose reify failed optional dependency /opt/iobroker/node_modules/@stoprocent/noble/node_modules/node-addon-api
                          220 silly reify mark deleted [
                          220 silly reify   '/opt/iobroker/node_modules/@stoprocent/noble/node_modules/node-addon-api'
                          220 silly reify ]
                          221 verbose stack Error: command failed
                          221 verbose stack     at promiseSpawn (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:22:22)
                          221 verbose stack     at spawnWithShell (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:124:10)
                          221 verbose stack     at promiseSpawn (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:12:12)
                          221 verbose stack     at runScriptPkg (/usr/lib/node_modules/npm/node_modules/@npmcli/run-script/lib/run-script-pkg.js:77:13)
                          221 verbose stack     at runScript (/usr/lib/node_modules/npm/node_modules/@npmcli/run-script/lib/run-script.js:9:12)
                          221 verbose stack     at /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/rebuild.js:329:17
                          221 verbose stack     at run (/usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:67:22)
                          221 verbose stack     at /usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:84:9
                          221 verbose stack     at new Promise (<anonymous>)
                          221 verbose stack     at callLimit (/usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:35:69)
                          222 verbose pkgid opengpio@1.0.18
                          223 error code 7
                          224 error path /opt/iobroker/node_modules/opengpio
                          225 error command failed
                          226 error command sh -c node-gyp rebuild
                          227 error gyp ERR! UNCAUGHT EXCEPTION
                          227 error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
                          227 error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)
                          227 error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9
                          227 error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:188:23)
                          227 error gyp ERR! System Linux 6.12.34+rpt-rpi-v8
                          227 error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                          227 error gyp ERR! cwd /opt/iobroker/node_modules/opengpio
                          227 error gyp ERR! node -v v20.19.4
                          227 error gyp ERR! node-gyp -v v7.1.2
                          227 error gyp ERR! Node-gyp failed to build your package.
                          227 error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
                          228 silly unfinished npm timer reify 1756140069485
                          229 silly unfinished npm timer reify:build 1756140076895
                          230 silly unfinished npm timer build 1756140076898
                          231 silly unfinished npm timer build:deps 1756140076898
                          232 silly unfinished npm timer build:run:install 1756140079094
                          233 silly unfinished npm timer build:run:install:node_modules/opengpio 1756140079113
                          234 verbose cwd /opt/iobroker
                          235 verbose os Linux 6.12.34+rpt-rpi-v8
                          236 verbose node v20.19.4
                          237 verbose npm  v10.8.2
                          238 verbose exit 7
                          239 verbose code 7
                          • S sonny
                            Hier bitteschön :)
                            78 silly reify }
                            164 silly reify ]
                            170 silly reify ]
                            202 silly reify ]
                            220 silly reify ]
                            223 error code 7
                            238 verbose exit 7
                            239 verbose code 7
                            Thomas BraunT
                            Thomas BraunT
                            apt policy libgpiod-dev libgpiod*
                            sagt?
                              sagt?
                              S
                              S
                              sonny
                              libgpiod-dev:
                                Installed: 1.6.3-1+b3
                                Candidate: 1.6.3-1+b3
                                Version table:
                               *** 1.6.3-1+b3 500
                                      500 http://deb.debian.org/debian bookworm/main arm64 Packages
                              libgpiod-dev:
                                Version table:
                               *** 1.6.3-1+b3 500
                              libgpiod-doc:
                                Installed: (none)
                                Candidate: 1.6.3-1
                                Version table:
                                   1.6.3-1 500
                                      500 http://deb.debian.org/debian bookworm/main armhf Packages
                              libgpiod2:
                                Version table:
                               *** 1.6.3-1+b3 500
                              • S sonny
                                libgpiod-dev:
                                  Version table:
                                 *** 1.6.3-1+b3 500
                                libgpiod-dev:
                                  Version table:
                                 *** 1.6.3-1+b3 500
                                libgpiod-doc:
                                  Installed: (none)
                                  Candidate: 1.6.3-1
                                  Version table:
                                     1.6.3-1 500
                                libgpiod2:
                                  Version table:
                                 *** 1.6.3-1+b3 500
                                Thomas BraunT
                                Thomas BraunT
                                @sonny
                                Keine Ahnung.
                                  @sonny
                                  Keine Ahnung.
                                  S
                                  S
                                  sonny
                                  Ich steh auch am schlauch , ich hab mich vorher mit chatgpt ein wenig auseinandergesetzt. ich kann dieses "opengpio" bauen. wenn ichs ausserhalb von iobroker builden will.
                                  Mir ist lediglich bei der installation etwas aufgefallen.
                                  Nach erstellen der nvme mit dem raspberry pi imager, rein in die ssh, erste arbeit "apt update" und apt upgrade.
                                  Ich wurde daraufhin während apt upgrade lief, mit einer recht merkwürdigen Frage bezüglich der Ramdisk konfrontiert. Ich hab da "Y" gedrückt. da passte irgendetwas nicht zusammen
                                  Ich hatte selbiges mit einem raspberry pi 3 (Anderer Verwendungszweck), den ich vor 2 Wochen "aufgesetzt" hab, ebenfalls. Ob es damit zusammenhängt weiss ich nicht. iob fix läuft ohne nennenswerten probleme durch..
                                  Ich versuch die installation nochmal morgen, vielleicht ging da irgendetwas daneben. ich habe keine Ahnung
                                  • S sonny
                                    OliverIOO
                                    OliverIOO
                                    OliverIO
                                    @sonny
                                    ist opengpio 1.0.18 nicht etwas zu alt für ein aktuelles betriebssystem.
                                    aktuell ist 2.0.2
                                    https://www.npmjs.com/package/opengpio
                                    woher wird das referenziert?
                                    Meine Adapter und Widgets
                                    Links im Profil
                                    • OliverIOO OliverIO
                                      @sonny
                                      aktuell ist 2.0.2
                                      Thomas BraunT
                                      Thomas BraunT
                                      @oliverio sagte in Kann den Rpi Adapter auf meinem Raspberry nicht installieren:
                                      opengpio 2.0.x baut aber afaik nur mit aktuellster libgpiod.
                                      Und die kommt erst mit Trixie mit:
                                      apt policy libgpiod3
                                      libgpiod3:
                                        Installed: 2.2.1-2
                                        Candidate: 2.2.1-2
                                        Version table:
                                       *** 2.2.1-2 500
                                              500 http://deb.debian.org/debian trixie/main arm64 Packages
                                      echad@chet:~ $
                                      Hier baut das Ding auch, wenn ich die package.json etwas anpasse.
                                      echad@chet:/opt/iobroker $ npm ls opengpio
                                      iobroker.inst@3.0.0 /opt/iobroker
                                      └─┬ iobroker.rpi2@2.4.0 (git+ssh://git@github.com/Grothesk242/ioBroker.rpi2.git#c87e9539d89bac8f4d19b266679bcb78ed554f1d)
                                        └── opengpio@2.0.2
                                        libgpiod3:
                                          Installed: 2.2.1-2
                                          Candidate: 2.2.1-2
                                          Version table:
                                         *** 2.2.1-2 500
                                        echad@chet:~ $
                                          └── opengpio@2.0.2
                                        S
                                        S
                                        sonny
                                        Das Problem ist in meinem Fall dieser Backup Adapter. (Der noch nie richtig funktioniert hat, wenn es darum ging irgendetwas wiederherzustellen).Er stellt zwar alles wieder her, macht unterm Strich aber das ganze System kaputt.
                                        Hab iobroker eben wiedermal neu aufgesetzt, und konnte den adapter Rpi ohne probleme von hand aus der adapterliste installieren...
                                        Dannach spielte ich das backup mit dem backup adapter zurück, er kann DeyeIDC nicht wiederherstellen, Fehler -25 . immer das gleiche mit diesem Ding. Löscht mir meine vorangegangene Händische Installation von Rpi, und kann es natürlich mit seinem dämlichen Fehler -25 nichtmehr installieren.
                                        Ich schmeiss den nun endgültig aus dem System. Ich bin froh das ich die Datenpunkte alle separat gespeichert hab.
                                        Für zukünftige Backups nutze ich das raspiBackup und falls von Hand: Adapter von hand alle installieren, mit den entsprechenden Jsons konfigurieren, alle Datenpunkte wiederherstellen und fertig.
                                        Thomas BraunT simatecS mcm1957M 3 Antworten Letzte Antwort
                                        • S sonny
                                          Thomas BraunT
                                          Thomas BraunT
                                          Das sollte so nicht sein, hast du mal ein Issue beim Adapter angelegt? Dann kann sich @simatec das mal anschauen.
                                          Aus eigener Erfahrung funktioniert der Adapter nämlich auf meinen Systemen einwandfrei.
                                          84.0k
