  4. Adapter "smartmeter"
    1.0k
3.6k Beiträge 281 Kommentatoren 3.1m Aufrufe 162 Beobachtet
  • GoerschG Offline
    GoerschG Offline
    Goersch
    #802
    Hab hier ein kleines node.js Problem - verstehe es aber nicht so ganz.
    Ich bin auf node 8.9.4 und npm 4.6.1.
    ` > host.iobroker-solar 2018-01-31 14:19:28.889 error instance system.adapter.smartmeter.0 terminated with code 1 ()
    host.iobroker-solar 2018-01-31 14:19:28.889 error Caught by controller[0]: at Object.Module._extensions..js (module.js:654:10)
    host.iobroker-solar 2018-01-31 14:19:28.889 error Caught by controller[0]: at Module._compile (module.js:643:30)
    host.iobroker-solar 2018-01-31 14:19:28.889 error Caught by controller[0]: at Object. (/opt/iobroker/node_modules/serialport/lib/bindings.js:3:35)
    host.iobroker-solar 2018-01-31 14:19:28.889 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:76:44)
    host.iobroker-solar 2018-01-31 14:19:28.888 error Caught by controller[0]: at require (internal/module.js:11:18)
    host.iobroker-solar 2018-01-31 14:19:28.888 error Caught by controller[0]: at Module.require (module.js:587:17)
    host.iobroker-solar 2018-01-31 14:19:28.888 error Caught by controller[0]: at Function.Module._load (module.js:491:3)
    host.iobroker-solar 2018-01-31 14:19:28.888 error Caught by controller[0]: at tryModuleLoad (module.js:499:12)
    host.iobroker-solar 2018-01-31 14:19:28.888 error Caught by controller[0]: at Module.load (module.js:556:32)
    host.iobroker-solar 2018-01-31 14:19:28.888 error Caught by controller[0]: at Object.Module._extensions..node (module.js:672:18)
    host.iobroker-solar 2018-01-31 14:19:28.888 error Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
    host.iobroker-solar 2018-01-31 14:19:28.887 error Caught by controller[0]: NODE_MODULE_VERSION 57. Please try re-compiling or re-installing
    host.iobroker-solar 2018-01-31 14:19:28.887 error Caught by controller[0]: NODE_MODULE_VERSION 59. This version of Node.js requires
    host.iobroker-solar 2018-01-31 14:19:28.887 error Caught by controller[0]: was compiled against a different Node.js version using
    host.iobroker-solar 2018-01-31 14:19:28.887 error Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node'
    host.iobroker-solar 2018-01-31 14:19:28.887 error Caught by controller[0]: ^
    host.iobroker-solar 2018-01-31 14:19:28.887 error Caught by controller[0]: throw e
    host.iobroker-solar 2018-01-31 14:19:28.886 error Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:83 `
    Hab schon "smartmeter" neu installiert und auch "npm rebuild" ausprobiert - es gibt keine Fehlermeldung. Sobald ich die Instanz aber starte, kommt obige Fehlermeldung.
    Ich war zwischenzeitig mal auf der node 9 Version, bin dann aber wieder zurück auf die 8er node version und hab die 9er node version komplett deinstalliert. Muss ich noch was übersetzen? Andere instanzen (modbus, sma-em) laufen ohne Probleme auf dem System. Mehrmals gebootet wurde auch zwischenzeitig.
    • apollon77A Offline
      #803
      Naja wechel zwischen node-Versionen ist immer blöd.
      Am einfachsten löst sich das indem man neuinstalliert.
      also beende mal den smartmeter.
      gehe in /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/
      und wenn es da ein serialport verzeichnis gibt lösche das mal komplett
      Dann adapter neu installieren(am besten gleich die 1.1.0 aus dem Github :-) )
      wenn es dann immer noch so bleibt dann liegt noch woanders eine serialport installation die man dann auch löschen muss … aber das kann dann wieder größere auswirkungen haben auf andere Adaoter
      • GoerschG Offline
        GoerschG Offline
        Goersch
        #804
        Ich hab das Verzeichnis gelöscht und die 1.1.0 installiert - sieht jetzt besser aus :D
        Danke!
        Was mich ein wenig verwirrt, ist, dass die Instanz auch dann grün ist, wenn an dem USB Port gar nichts angeschlossen ist. Aber das ist "schöner wohnen" 8-)
          #805
          Ja, da smartmeter oft in bestimmten Abständen Daten liesst und sonst der serielle Port geschlossen ist macht ein "connection"-Datenpunkt keinen sinn. Damit gibt es nur "Prozess alive" oder "Prozess nicht alive" (grün/rot). Gelb gibt es hier nicht. (würde ständig gelb-rot wechseln wenn man "connected" wörtlich nimmt :-)
            #806
            1.1.0 offiziell veröffentlicht
              MartyBr
              #807
              herzlichen Glückwunsch, dass ist ja ein toller Adapter. Ich wollte in Kürze den Homematic-Adapter mit dem LED-Sensor kaufen.
              Ich baue gerade meine Visualisierung in ioBroker auf und bin total begeistert.
              Erstens von der Community. Hier wird geholfen! Zweitens ist der Tonfall nicht so Oberlehrerhaft wie in anderen Foren.
              Drittens ist das Potential dieser Lösung gigantisch. Ich sehe da VIEL ARBEIT auf mich zukommen, meine Installation Zug um Zug auf den ioBroker zu überführen. Das ist aber eine andere Sache.
              Mein Anliegen ganz konkret: Ich möchte den Stromverbrauch meines Hauses messen und auswerten können. Ich betreibe 2 Stromzähler, einen für den Haushaltsstrom und einen für die Wärmepumpe.
              Beide sind vom Typ Logarex LK13B, scheinen nach meinen Recherchen eher eingeschränkt in ihrer D0-Schnittstelle zu sein.
              Nun schwanke ich zwischen der Smartmeter ioBroker Lösung und der reinen Homematic, wo Zähler und Sensor aufeinander abgestimmt sind und wohl nur die Zählimpulse zählen und verarbeiten.
              Wie stehen denn die Chancen diesen Stromzähler auszulesen? Hat schon jemand Erfahrung mit diesem Tschechichen Gerät gemacht? Die sollen in Brandenburg häufig verbaut worden sein.
              Martin
              Martin
              Homematic und Homematic IP
                #808
                Hast du mal links oder Details zu Deinen Rechercheergebnissen zur d0 Schnittstelle?!
                  #809
                  Laut https://knx-user-forum.de/forum/öffentl … post676040 kommt zwar ggf nicht viel an Daten aber d0 sollte tun.
                  Und auch ich würde einen ir Wert immer Impulsen zählen vorziehen.
                    #810
                    Habe auch gerade den thread im Knx Forum gelesen.
                    1.8.0 ist schon mal ezwas, dann braucht es noch ein skript und einen selbsterstellten Datenpunkt Wert_alt um den Stromverbrauch der letzten x Sekunden zu berechnen.
                    Gruß Rainer
                      MartyBr
                      #811
                      Hallo Herzlichen Dank für die schnellen Meldungen.
                      Ich hatte als Link auch das knx-Forum.
                      Für mic heisst das:
                      Der Smartmeter-Adapter kann die Daten aufnehmen.
                      Der Tastkopf könnte dann der Volkszähler LED-Tastkopf sein oder besser der von EMH oder SMA?
                      Ich brauche dann eine zweite iobroker Instanz (ein zweiter Raspberry als Slave)
                      Werden die beiden Tastköpfe dann per USB angeschlossen?
                      Vielen Dank für eure Hilfe
                      Martin
                      Martin
                        #812
                        Der volkszähler ir Kopf funktioniert super und sollte so bei 25/30 eur liegen. Und ja per usb.
                        Slave brauchst du wenn du den iobroker Server nicht da in die Nähe stellen kannst/willst :-)
                          MartyBr
                          #813
                          Hallo Apollon77,
                          okay,
                          dann gehe ich das Thema mal aktiv an :geek:
                          Danke dir für deine Hilfe am Sonntag!
                          Martin
                          Martin
                          • GoerschG Offline
                            GoerschG Offline
                            Goersch
                            #814
                            man kann auch eine USB via Netzwerk Verlängerung nutzen - hat bei mir gut funktiniert und ist günstiger
                              MartyBr
                              #815
                              Hallo Goersch,
                              was ist das? So eine Art PoE oder ein USB-Extender? Hast du eine Hardware Empfehlung?
                              Habe gerade beim Volkszähler Projekt zwei Tastköpfe angefragt. Mal schauen, wann die kommen.
                              Martin
                              Martin
                              • GoerschG Offline
                                GoerschG Offline
                                Goersch
                                #816
                                das hier hat bei mir an einem Raspi 3 ohne Probleme funktioniert
                                https://www.amazon.de/gp/aw/d/B001TOG6M … UTF8&psc=1
                                  #817
                                  Interessantes Teil,
                                  lediglich die Formulierung:
                                  > Übertragen Sie USB-Signale per Netzwerkkabel über 60 Meter weit!
                                  verheißt mir nichts Gutes.
                                  Kann ich das übers Netzwerk (inkl. Switch) nutzen, oder nur statt eines USB-Kabels ein Netzwerkkabel nehmen.
                                    MartyBr
                                    #818
                                    Für 15 € kann man ja einen Test wagen. Geht schneller, als einen neuen Raps zu besorgen. Langfristig werden ich meinen iobroker auf einen NUC umziehen und den Raps dann für die Homematic nutzen.
                                    Martin
                                    Martin
                                    • GoerschG Offline
                                      GoerschG Offline
                                      Goersch
                                      #819
                                      @Rainer: ne, das geht nicht über den switch
                                      Bei mir war noch eine Netzwerk Leitung frei, die ich nutzen konntr
                                      • D Online
                                        D Online
                                        darkiop
                                        #820
                                        Hallo, ich logge aktuell zum Test mit dem Skript von A200 [1] den Zählerstand meines Wärmepumpenzählers. Für die Datenpunkte habe ich die History bzw. SQL Funktion aktiviert - ebefalls die Option 'Änderungen aufzeichnen'.
                                        Es werden allerdings, im Beispiel des Tageswertes mehre Werte in die DB geschrieben:
                                        ~~![](</s><URL url=)<link_text text="http://forum.iobroker.net/download/file ... 2d206a7ef8">http://forum.iobroker.net/download/file.php?mode=view&id=21745&sid=2fc26b76bf70408ffc69a42d206a7ef8</link_text>" />
                                        Woran kann das liegen?
                                        [1] http://forum.iobroker.net/viewtopic.php?p=51017#p51017~~ 5671_2018-02-06_09_36_13-clipboard.png
                                        Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                                          #821
                                          Der sql Adapter loggt beim Start ein NULL und danach immer den letzten existierenden Wert damit der Start wieder gesetzt ist.
                                          In dem Fall ist das bei dir "unerwünscht".
                                          Ich tippe ja das du wegen Backup unnötigerweise ioBroker jeden Tag neu startest … das solltest DU dann 0:0:0 Uhr machen oder kurz drauf.Sonst geht dir hier das kaputt
