  4. Betatest Bright Sky v1.1.x
213 Beiträge 23 Kommentatoren 31.9k Aufrufe 34 Beobachtet
  • T Nicht stören
    T Nicht stören
    ticaki
    @homoran sagte in Betatest Bright Sky v0.1.x:
    2025-08-19 21:13:07.505 error Error fetching weather data: {"message":"Request failed with status code 404","name":"AxiosError","stack":"AxiosError: Request failed with status code 404\n at settle (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:2090:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:3207:11)\n at IncomingMessage.emit (node:events:536:35)\n at endReadableNT (node:internal/streams/readable:1698:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)\n at Axios.request (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:4317:41)\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n at async Brightsky.weatherCurrentlyUpdate (/opt/iobroker/node_modules/iobroker.brightsky/build/main.js:361:22)\n at async Brightsky.weatherCurrentlyLoop (/opt/iobroker/node_modules/iobroker.brightsky/build/main.js:309:5)\n at async Brightsky.onReady (/opt/iobroker/node_modules/iobroker.brightsky/build/main.js:86:7)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, /","User-Agent":"axios/1.11.0","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"https://api.brightsky.dev/current_weather?lat=...&lon=....&max_dist=10000","allowAbsoluteUrls":true},"code":"ERR_BAD_REQUEST","status":404} brightsky.0
    Mit Link meine ich - in dieser Fehlermeldung versteckt sich das:
    jetzt kopiert man den Link in den Browser und die Antwort hilft mir und auch euch weiter. Wenn die Koordinaten nicht unterstützt werden steht da: {"detail":"No sources match your criteria"}
    Spenden
    • T ticaki
      @ticaki DANKE!
      ist wohl schon zu spät, da hätte ich selbst drauf kommen müssen
      ...und ja, das passiert bei dem URL aus dem Log
      • T Nicht stören
        T Nicht stören
        ticaki
        Kurzzusammengefasst:
        v0.2.0
        • dwd station id kann eingegeben werden
        • wmo station id kann eingegeben werden
        • links auf Listen für beides hinzugefügt
        • current, hourly, daily kann abgewählt werden
        • info text hinzugefügt
        bei den beiden Stations IDs kann eine kommagetrennte liste verwendet werden. 02345,01111 das ist eine prioritäten liste nicht eine anzeige liste :)
        Die ID's sind 5 stellig, bei Bedarf mit 0 vorne auffüllen.
        Koordinaten und die Stationen sind ein entweder oder - ist ein station ausgefüllt wird diese verwendet, wenn nicht die Koordinaten.
        EDIT: der DWD Link wurde getauscht, im ersten Link haben ein paar 100/1000 Stationen gefehlt.
        Spenden
        • T ticaki
          v0.2.0
          sigi234S Online
          sigi234S Online
          @ticaki sagte in Betatest Bright Sky v0.2.x:
          v0.2.0
          Läuft. Info ist da aber nicht Richtig? Current habe ich abgewählt.
          brightsky.0
          	2025-08-20 11:38:26.377	info	Adapter brightsky.0 is now ready. Weather data will be updated every 30 minutes for current weather and every 1 hours for hourly weather. Daily weather data will also be created.
          brightsky.0
          	2025-08-20 11:38:17.641	info	starting. Version 0.2.0 (non-npm: ticaki/ioBroker.brightsky#6547eca25fd5fd367f7a8918c6c91cedb52ff00c) in C:/SmartHome/node_modules/iobroker.brightsky, node: v22.18.0, js-controller: 7.0.7
          brightsky.0
          	2025-08-20 11:36:45.774	info	terminating
          brightsky.0
          	2025-08-20 11:36:45.267	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          brightsky.0
          	2025-08-20 11:36:45.266	info	terminating
          brightsky.0
          	2025-08-20 11:36:45.260	info	Got terminate signal TERMINATE_YOURSELF
          • sigi234S sigi234
            v0.2.0
            brightsky.0
            brightsky.0
            brightsky.0
            brightsky.0
            brightsky.0
            brightsky.0
            T Nicht stören
            T Nicht stören
            ticaki
            @sigi234
            Ja info ist noch alt - das mache ich dann noch richtig :)
            Spenden
            • T ticaki
              @sigi234
              sigi234S Online
              sigi234S Online
              @sigi234
              Ok, bin ein wenig pingelig. 😀
              Habe noch einige Null Werte:
              • sigi234S sigi234
                @sigi234
                T Nicht stören
                T Nicht stören
                ticaki
                @sigi234
                2025-08-20 12:00:03.335  - info: brightsky.0 (371389) Adapter started with configuration: Position: ...,..., WMO Station ID: 11035, DWD Station ID: , Currently data disabled - Hourly data enabled. Poll interval: 1 hours - Daily data enabled., Max distance: 50000 meters.
                2025-08-20 12:00:03.335  - info: brightsky.0 (371389) Using WMO Station ID: 11035
                so sieht es jetzt aus - ist auf github
                null werte stehen da weil es keine werte von der api gibt - z.B. humidity wird aktuell nicht in den Vorhersagen mit geliefert - lass ich aber drin, weil es könnte ja sein das sie ab morgen mitgeliefert werden. :)
                Spenden
                • T ticaki
                  @sigi234
                  sigi234S Online
                  sigi234S Online
                  @sigi234
                  Perfekt! 👍
                    Bin heute noch zu nix gekommen, schaff ich auch nicht.
                    Einzig etwas ist beim drübersehen aufgefallen
                    sind da die Einheiten bei daily falsch, oder die Werte?
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      Most Active Forum Testing
                      ja
                      Die daily.00.solar ist eine Summierung der Stundenleistung eines Tages und müsste ebenfalls kWh/m² sein
                      Die daily.00.solar_max könnte, da sie die maximale Spitze (Summe der Energie einer Stunde) innerhalb eines Tages interpretiert
                      • kWh/m²
                      oder eben, da es ein gemessener Stundenwert ist auch in (teilen wir doch mal durch 1 = 1h)
                      • kW/m² ausgedrückt werden
                      • ArmilarA Armilar
                        ja
                        • kWh/m²
                        @armilar sagte in Betatest Bright Sky v0.2.x:
                        ist es das?
                        ich würde es als die maximale Sonnenleistung des Tages interpretieren, also reine kW/m²
                        ArmilarA T 2 Antworten Letzte Antwort
                          ist es das?
                          ArmilarA Offline
                          ArmilarA Offline
                          Armilar
                          prognostiziert ist wohl der bessere Begriff für einen Forecast der kommenden Stunden
                          EDIT: würde den auch als reine kW/m² darstellen
                          Tatsächliche Einheit für Stunden ist allerdings wie folgt angegeben:
                          Wäre aber ebenfalls so wie du das bereits interpretierst auch die maximale Sonneleistung eines Tages in kW/m²
                            ist es das?
                            T Nicht stören
                            T Nicht stören
                            ticaki
                            Solar ist ein summenwert und das h ist wegen müdigkeit entfernt worden - ja macht keinen Sinn - ich schreibe bei den summenwerten jetzt noch in common.names das es summenwerte sind.
                            Edit: Ich hab das h jetzt hin gemacht, wenn ihr euch geeinigt habe, mache ich es dann so wie ihr sagt :D
                            EDIT2:
                            ausserdem sunrise und sunset zu daily hinzugefügt, wird aus den Koordinaten berechnet.
                            Spenden
                            • T ticaki
                              EDIT2:
                              woher nimmst du das?
                              Ich hab leider auch nur mein "Gefühl" und keine Fakten.
                              Hier ein kräftig auf allen Beinen hinkendes Beispiel:
                              Die höchste Sonnenleistung auf meiner Solaranlage waren 4.35 kW / 23m²
                              Bei einem Wirkungsgrad von knapp 25% wären das etwa 0.756kW/m² Sonnenleistung
                              ohne jegliches Summieren
                              passt also hervorragend zu dem Adapterwert
                                T Nicht stören
                                T Nicht stören
                                ticaki
                                Ich glaube ich hab gerade nen Knoten im Kopf - Ich summiere die Stunden kWh/m2 werte und erhalte dann den geschätzten Tageswert. das sind dann kwh/m2/tag also was der zähler im schrank sich an einem tag bewegt.
                                Spenden
                                • T ticaki
                                  @ticaki das ist radiation! die ist in kWh/m²
                                  ich rede von solar Max, die ist IMHO keine Summe, und ein einmaliger Leistungswert in kW/m²
                                    T Nicht stören
                                    T Nicht stören
                                    ticaki
                                    Das ist der höchste Stundenwert der rein kommt. Daily wird aus STundenwerten berechnet und alle mix max werte sind jeweils der kleinste bzw. höchste Stundenwert.
                                    Spenden
                                    • T ticaki
                                      also ein Zeitraum?
                                      Da müssten wir mal bei einen Bier lange drüber sprechen
                                      ich behaupte es ist ein Momentanwert, ggf. wenige Minuten.
                                      Der maximale Wert eben
                                        also ein Zeitraum?
                                        ArmilarA Offline
                                        ArmilarA Offline
                                        Armilar
                                        Denke das trifft es:
                                        EDIT war etwas wenig Überschrift ;-)
                                        • ArmilarA Armilar
                                          @armilar ja!
                                          Natürlich liegt der max Wert auch in einer Stunde.
                                          bei optimalem Verlauf hast du einen Parabelverlauf mit einen Maximum.
                                          Wenn du die Parabel in einstündige Timeslices teilst liegt das Maximum in einem Slice, ist aber nach meinem Verständnis nicht die Summe davon
                                          EDIT
                                          demnach doch eine Summe 🤔
                                          EDIT2
                                          aber beim Tag dann doch nicht 😂
