  4. Betatest Bright Sky v1.1.x
213 Beiträge 23 Kommentatoren 31.9k Aufrufe 34 Beobachtet
    @armilar sagte in Betatest Bright Sky v0.1.x:
    10513 ist Köln/Bonn
    hab's editiert gehabt
    unter current ist Kön Bonn, unter forecast ist Ville.
    Ihr seid ja schneller, als die Polizei erlaubt. Da ist ja schon wieder ein Update 😉
    aber auch
    brightsky.0
    	2025-08-19 21:41:20.137	warn	Invalid poll interval currently: 60. Using default value of 30 minute.
    admin.0
    	2025-08-19 21:40:52.462	warn	brightsky has an invalid jsonConfig: [{"instancePath":"/items/wmo_station","schemaPath":"#/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"step"},"message":"must NOT have additional properties"},{"instancePath":"/items/wmo_station","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/25/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"else"},"message":"must match \"else\" schema"}]
    brightsky.0
    	2025-08-19 21:40:49.670	warn	Invalid poll interval currently: 60. Using default value of 30 minute.
    brightsky.0
    	2025-08-19 21:40:49.669	warn	Invalid WMO station ID. Using default value of "".
    brightsky.0
    	2025-08-19 21:38:53.694	warn	Invalid poll interval currently: 60. Using default value of 30 minute.
    brightsky.0
    	2025-08-19 21:38:53.693	warn	Invalid WMO station ID. Using default value of "".
    brightsky.0
    	2025-08-19 21:14:49.817	warn	Invalid poll interval currently: 60. Using default value of 30 minute.
    brightsky.0
    	2025-08-19 21:13:07.505	error	Error fetching weather data: {"message":"Request failed with status code 404","name":"AxiosError","stack":"AxiosError: Request failed with status code 404\n at settle (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:2090:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:3207:11)\n at IncomingMessage.emit (node:events:536:35)\n at endReadableNT (node:internal/streams/readable:1698:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)\n at Axios.request (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:4317:41)\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n at async Brightsky.weatherCurrentlyUpdate (/opt/iobroker/node_modules/iobroker.brightsky/build/main.js:361:22)\n at async Brightsky.weatherCurrentlyLoop (/opt/iobroker/node_modules/iobroker.brightsky/build/main.js:309:5)\n at async Brightsky.onReady (/opt/iobroker/node_modules/iobroker.brightsky/build/main.js:86:7)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/1.11.0","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"https://api.brightsky.dev/current_weather?lat=...&lon=....&max_dist=10000","allowAbsoluteUrls":true},"code":"ERR_BAD_REQUEST","status":404}
    brightsky.0
    	2025-08-19 21:13:04.291	warn	Invalid poll interval currently: 60. Using default value of 30 minute.
    T Nicht stören
    T Nicht stören
    ticaki
    @homoran ist ja schön das ihr lat und long immer durch unsinn ersetzt. aber ich kopiere den unsinn da jetzt nicht raus suche mir koordinaten nur um dann das falsche ergebniss zu sehen - selbst ist der man - link im browser öffnen und gucken was der schreibt :P
    jsonConfig ist gefixt
    dwd_station_id ist eingebaut aber noch nicht getestet
    muß auch noch die lat long deaktivieren wenn man eine der stationen eingibt - die spielen dann keine rolle mehr
    Spenden
      10513 ist Köln/Bonn
      aber auch
      brightsky.0
      admin.0
      brightsky.0
      brightsky.0
      brightsky.0
      brightsky.0
      brightsky.0
      brightsky.0
      brightsky.0
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      Most Active Forum Testing
      Current
      und Forecast
      Beide Köln/Bonn ;-)
      • ArmilarA Armilar
        Current
        und Forecast
        Beide Köln/Bonn ;-)
        @armilar bei mir nicht 😢
        Current
        hourly
        ich mach morgen weiter!
        du hast ja schon wieder was neues in der Konfig
        • T Nicht stören
          T Nicht stören
          ticaki
          @homoran sagte in Betatest Bright Sky v0.1.x:
          2025-08-19 21:13:07.505 error Error fetching weather data: {"message":"Request failed with status code 404","name":"AxiosError","stack":"AxiosError: Request failed with status code 404\n at settle (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:2090:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:3207:11)\n at IncomingMessage.emit (node:events:536:35)\n at endReadableNT (node:internal/streams/readable:1698:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)\n at Axios.request (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:4317:41)\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n at async Brightsky.weatherCurrentlyUpdate (/opt/iobroker/node_modules/iobroker.brightsky/build/main.js:361:22)\n at async Brightsky.weatherCurrentlyLoop (/opt/iobroker/node_modules/iobroker.brightsky/build/main.js:309:5)\n at async Brightsky.onReady (/opt/iobroker/node_modules/iobroker.brightsky/build/main.js:86:7)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, /","User-Agent":"axios/1.11.0","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"https://api.brightsky.dev/current_weather?lat=...&lon=....&max_dist=10000","allowAbsoluteUrls":true},"code":"ERR_BAD_REQUEST","status":404} brightsky.0
          Mit Link meine ich - in dieser Fehlermeldung versteckt sich das:
          jetzt kopiert man den Link in den Browser und die Antwort hilft mir und auch euch weiter. Wenn die Koordinaten nicht unterstützt werden steht da: {"detail":"No sources match your criteria"}
          Spenden
          • T ticaki
            @ticaki DANKE!
            ist wohl schon zu spät, da hätte ich selbst drauf kommen müssen
            ...und ja, das passiert bei dem URL aus dem Log
            • T Nicht stören
              T Nicht stören
              ticaki
              Kurzzusammengefasst:
              v0.2.0
              • dwd station id kann eingegeben werden
              • wmo station id kann eingegeben werden
              • links auf Listen für beides hinzugefügt
              • current, hourly, daily kann abgewählt werden
              • info text hinzugefügt
              bei den beiden Stations IDs kann eine kommagetrennte liste verwendet werden. 02345,01111 das ist eine prioritäten liste nicht eine anzeige liste :)
              Die ID's sind 5 stellig, bei Bedarf mit 0 vorne auffüllen.
              Koordinaten und die Stationen sind ein entweder oder - ist ein station ausgefüllt wird diese verwendet, wenn nicht die Koordinaten.
              EDIT: der DWD Link wurde getauscht, im ersten Link haben ein paar 100/1000 Stationen gefehlt.
              Spenden
              • T ticaki
                v0.2.0
                sigi234S Online
                sigi234S Online
                @ticaki sagte in Betatest Bright Sky v0.2.x:
                v0.2.0
                Läuft. Info ist da aber nicht Richtig? Current habe ich abgewählt.
                brightsky.0
                	2025-08-20 11:38:26.377	info	Adapter brightsky.0 is now ready. Weather data will be updated every 30 minutes for current weather and every 1 hours for hourly weather. Daily weather data will also be created.
                brightsky.0
                	2025-08-20 11:38:17.641	info	starting. Version 0.2.0 (non-npm: ticaki/ioBroker.brightsky#6547eca25fd5fd367f7a8918c6c91cedb52ff00c) in C:/SmartHome/node_modules/iobroker.brightsky, node: v22.18.0, js-controller: 7.0.7
                brightsky.0
                	2025-08-20 11:36:45.774	info	terminating
                brightsky.0
                	2025-08-20 11:36:45.267	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                brightsky.0
                	2025-08-20 11:36:45.266	info	terminating
                brightsky.0
                	2025-08-20 11:36:45.260	info	Got terminate signal TERMINATE_YOURSELF
                • sigi234S sigi234
                  v0.2.0
                  brightsky.0
                  brightsky.0
                  brightsky.0
                  brightsky.0
                  brightsky.0
                  brightsky.0
                  T Nicht stören
                  T Nicht stören
                  ticaki
                  @sigi234
                  Ja info ist noch alt - das mache ich dann noch richtig :)
                  Spenden
                  • T ticaki
                    @sigi234
                    sigi234S Online
                    sigi234S Online
                    @sigi234
                    Ok, bin ein wenig pingelig. 😀
                    Habe noch einige Null Werte:
                    • sigi234S sigi234
                      @sigi234
                      T Nicht stören
                      T Nicht stören
                      ticaki
                      @sigi234
                      2025-08-20 12:00:03.335  - info: brightsky.0 (371389) Adapter started with configuration: Position: ...,..., WMO Station ID: 11035, DWD Station ID: , Currently data disabled - Hourly data enabled. Poll interval: 1 hours - Daily data enabled., Max distance: 50000 meters.
                      2025-08-20 12:00:03.335  - info: brightsky.0 (371389) Using WMO Station ID: 11035
                      so sieht es jetzt aus - ist auf github
                      null werte stehen da weil es keine werte von der api gibt - z.B. humidity wird aktuell nicht in den Vorhersagen mit geliefert - lass ich aber drin, weil es könnte ja sein das sie ab morgen mitgeliefert werden. :)
                      Spenden
                      • T ticaki
                        @sigi234
                        sigi234S Online
                        sigi234S Online
                        @sigi234
                        Perfekt! 👍
                          Bin heute noch zu nix gekommen, schaff ich auch nicht.
                          Einzig etwas ist beim drübersehen aufgefallen
                          sind da die Einheiten bei daily falsch, oder die Werte?
                            ArmilarA Offline
                            ArmilarA Offline
                            Armilar
                            ja
                            Die daily.00.solar ist eine Summierung der Stundenleistung eines Tages und müsste ebenfalls kWh/m² sein
                            Die daily.00.solar_max könnte, da sie die maximale Spitze (Summe der Energie einer Stunde) innerhalb eines Tages interpretiert
                            • kWh/m²
                            oder eben, da es ein gemessener Stundenwert ist auch in (teilen wir doch mal durch 1 = 1h)
                            • kW/m² ausgedrückt werden
                            • ArmilarA Armilar
                              ja
                              • kWh/m²
                              @armilar sagte in Betatest Bright Sky v0.2.x:
                              ist es das?
                              ich würde es als die maximale Sonnenleistung des Tages interpretieren, also reine kW/m²
                              ArmilarA T 2 Antworten Letzte Antwort
                                ist es das?
                                ArmilarA Offline
                                ArmilarA Offline
                                Armilar
                                prognostiziert ist wohl der bessere Begriff für einen Forecast der kommenden Stunden
                                EDIT: würde den auch als reine kW/m² darstellen
                                Tatsächliche Einheit für Stunden ist allerdings wie folgt angegeben:
                                Wäre aber ebenfalls so wie du das bereits interpretierst auch die maximale Sonneleistung eines Tages in kW/m²
                                  ist es das?
                                  T Nicht stören
                                  T Nicht stören
                                  ticaki
                                  Solar ist ein summenwert und das h ist wegen müdigkeit entfernt worden - ja macht keinen Sinn - ich schreibe bei den summenwerten jetzt noch in common.names das es summenwerte sind.
                                  Edit: Ich hab das h jetzt hin gemacht, wenn ihr euch geeinigt habe, mache ich es dann so wie ihr sagt :D
                                  EDIT2:
                                  ausserdem sunrise und sunset zu daily hinzugefügt, wird aus den Koordinaten berechnet.
                                  Spenden
                                  • T ticaki
                                    EDIT2:
                                    woher nimmst du das?
                                    Ich hab leider auch nur mein "Gefühl" und keine Fakten.
                                    Hier ein kräftig auf allen Beinen hinkendes Beispiel:
                                    Die höchste Sonnenleistung auf meiner Solaranlage waren 4.35 kW / 23m²
                                    Bei einem Wirkungsgrad von knapp 25% wären das etwa 0.756kW/m² Sonnenleistung
                                    ohne jegliches Summieren
                                    passt also hervorragend zu dem Adapterwert
                                      T Nicht stören
                                      T Nicht stören
                                      ticaki
                                      Ich glaube ich hab gerade nen Knoten im Kopf - Ich summiere die Stunden kWh/m2 werte und erhalte dann den geschätzten Tageswert. das sind dann kwh/m2/tag also was der zähler im schrank sich an einem tag bewegt.
                                      Spenden
                                      • T ticaki
                                        @ticaki das ist radiation! die ist in kWh/m²
                                        ich rede von solar Max, die ist IMHO keine Summe, und ein einmaliger Leistungswert in kW/m²
                                          T Nicht stören
                                          T Nicht stören
                                          ticaki
                                          Das ist der höchste Stundenwert der rein kommt. Daily wird aus STundenwerten berechnet und alle mix max werte sind jeweils der kleinste bzw. höchste Stundenwert.
                                          Spenden
