  4. [SourceAnalytix 0.4.8-Final] Released !
2.3k Beiträge 184 Kommentatoren 1.7m Aufrufe 153 Beobachtet
  • B bishop9191
    @crunchip hat nichts bewirkt 😐
    crunchipC
    crunchipC
    Developer Global Moderator Most Active Forum Testing
    #2293
    @bishop9191 dann mal
    iob diag
      iob diag
      B
      B
      bishop9191
      #2294
      @crunchip was ist hier interessant? die komplette diag oder ein bestimmter bereich?
      • B bishop9191
        crunchipC
        crunchipC
        #2295
        @bishop9191 die vollständige Ausgabe
          B
          B
          bishop9191
          #2296
          @crunchip
          Script v.2025-03-08
          *** BASE SYSTEM ***
          Failed to query system properties: Failed to activate service 'org.freedesktop.hostname1': timed out (service_start_timeout=25000ms)
          OS is similar to:
          model name      : Intel(R) Core(TM) i5-6400T CPU @ 2.20GHz
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
          22:13:35 up 277 days, 23:42,  2 users,  load average: 0.09, 0.33, 0.71
          CPU threads: 2
          *** LIFE CYCLE STATUS ***
          Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
          *** TIME AND TIMEZONES ***
          Failed to query server: Connection timed out
          Failed to parse bus message: Connection timed out
          *** Users and Groups ***
          User that called 'iob diag':
          steven
          HOME=/home/steven
          GROUPS=steven sudo iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:
          System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
          *** MEMORY ***
          Mem:            4.1G        2.7G        745M        0.0K        635M        1.4G
          Swap:           512M         98M        413M
          Total:          4.6G        2.8G        1.2G
          Active iob-Instances:   32
                  4096 M total memory
                  2714 M used memory
                   575 M active memory
                  2524 M inactive memory
                   745 M free memory
                     0 M buffer memory
                   635 M swap cache
                   512 M total swap
                    98 M used swap
                   413 M free swap
          top - 22:14:50 up 277 days, 23:43,  2 users,  load average: 0.07, 0.26, 0.65
          Tasks:  58 total,   1 running,  57 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   4096.0 total,    745.4 free,   2714.7 used,    635.9 buff/cache
          MiB Swap:    512.0 total,    413.1 free,     98.9 used.   1381.3 avail Mem
          *** FAILED SERVICES ***
           UNIT                      LOAD   ACTIVE SUB    DESCRIPTION
          * logrotate.service         loaded failed failed Rotate log files
          * nftables.service          loaded failed failed nftables
          * systemd-hostnamed.service loaded failed failed Hostname Service
          * systemd-logind.service    loaded failed failed User Login Management
          * systemd-networkd.service  loaded failed failed Network Service
          * systemd-resolved.service  loaded failed failed Network Name Resolution
          * systemd-timedated.service loaded failed failed Time & Date Service
          * systemd-networkd.socket   loaded failed failed Network Service Netlink Socket
          8 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          Filesystem                       Type   Size  Used Avail Use% Mounted on
          /dev/mapper/pve-vm--100--disk--0 ext4    16G  6.3G  8.6G  43% /
          none                             tmpfs  492K  4.0K  488K   1% /dev
          tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
          tmpfs                            tmpfs  3.2G   60K  3.2G   1% /run
          tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
          [Sun Feb 16 01:02:24 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Feb 16 01:02:24 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Feb 16 01:04:49 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Feb 16 01:04:49 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Feb 23 01:02:34 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Feb 23 01:02:34 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Feb 23 01:04:47 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Feb 23 01:04:47 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sat Mar  1 00:02:37 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sat Mar  1 00:02:37 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sat Mar  1 00:04:59 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sat Mar  1 00:04:59 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Mar  2 01:02:41 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Mar  2 01:02:41 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Mar  2 01:04:55 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Mar  2 01:04:55 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Fri Mar  7 22:26:08 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Fri Mar  7 22:26:36 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Fri Mar  7 22:37:11 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Fri Mar  7 22:37:38 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Fri Mar  7 22:41:18 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Fri Mar  7 22:51:11 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Fri Mar  7 22:52:00 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Fri Mar  7 22:52:22 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Fri Mar  7 22:57:57 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Fri Mar  7 23:26:43 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Sat Mar  8 08:31:33 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Sat Mar  8 08:51:59 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Sat Mar  8 08:52:22 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Sat Mar  8 09:04:21 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Sat Mar  8 09:04:35 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Sat Mar  8 09:06:54 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sat Mar  8 09:06:54 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sat Mar  8 16:40:34 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Sat Mar  8 17:26:44 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Sat Mar  8 22:08:41 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sat Mar  8 22:09:13 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Mar  9 01:02:43 2025] EXT4-fs (dm-13): write access unavailable, skipping orphan cleanup
          [Sun Mar  9 01:02:43 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Mar  9 01:05:17 2025] EXT4-fs (dm-13): write access unavailable, skipping orphan cleanup
          [Sun Mar  9 01:05:17 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Mar 16 01:02:51 2025] EXT4-fs (dm-13): write access unavailable, skipping orphan cleanup
          [Sun Mar 16 01:02:51 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Mar 16 01:05:24 2025] EXT4-fs (dm-13): write access unavailable, skipping orphan cleanup
          [Sun Mar 16 01:05:24 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Mon Mar 17 21:05:59 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Wed Mar 19 21:48:16 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Wed Mar 19 22:11:29 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Wed Mar 19 22:11:45 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Wed Mar 19 22:35:50 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Wed Mar 19 22:36:04 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Wed Mar 19 22:39:16 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Wed Mar 19 22:39:36 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Wed Mar 19 22:48:14 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Wed Mar 19 22:48:43 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Mar 23 01:03:00 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Mar 23 01:03:00 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Mar 23 01:05:06 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Mar 23 01:05:06 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Thu Mar 27 12:21:06 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Thu Mar 27 12:21:06 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Mar 30 01:03:08 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Mar 30 01:03:08 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Mar 30 01:05:18 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Mar 30 01:05:18 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Tue Apr  1 00:03:09 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Tue Apr  1 00:03:09 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Tue Apr  1 00:05:35 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Tue Apr  1 00:05:35 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Apr  6 01:03:14 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Apr  6 01:03:14 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Apr  6 01:05:21 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Apr  6 01:05:21 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Apr 13 01:03:25 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Apr 13 01:03:25 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Apr 13 01:05:30 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Apr 13 01:05:30 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Apr 20 01:03:31 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Apr 20 01:03:31 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Apr 20 01:06:04 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Apr 20 01:06:04 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Apr 27 01:03:41 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Apr 27 01:03:41 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Apr 27 01:06:16 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Apr 27 01:06:16 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Tue Apr 29 22:17:50 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Tue Apr 29 22:17:50 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Thu May  1 00:03:43 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Thu May  1 00:03:43 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Thu May  1 00:06:05 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Thu May  1 00:06:05 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun May  4 01:03:51 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun May  4 01:03:51 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun May  4 01:06:34 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun May  4 01:06:34 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun May 11 01:03:56 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun May 11 01:03:56 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun May 11 01:06:36 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun May 11 01:06:36 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun May 18 01:04:05 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun May 18 01:04:05 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun May 18 01:06:39 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun May 18 01:06:39 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun May 25 01:04:13 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun May 25 01:04:13 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun May 25 01:06:35 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun May 25 01:06:35 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Jun  1 00:04:24 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Jun  1 00:04:24 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Jun  1 00:06:51 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Jun  1 00:06:51 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Jun  1 01:04:24 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Jun  1 01:04:24 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Jun  1 01:06:24 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Jun  1 01:06:24 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Jun  8 01:04:29 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Jun  8 01:04:29 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Jun  8 01:06:33 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Jun  8 01:06:33 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Jun 15 01:04:32 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Jun 15 01:04:32 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Jun 15 01:06:42 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Jun 15 01:06:42 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Jun 22 01:04:40 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Jun 22 01:04:40 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Jun 22 01:06:47 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Jun 22 01:06:47 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Jun 29 01:04:48 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Jun 29 01:04:48 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Jun 29 01:08:40 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Jun 29 01:08:40 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Tue Jul  1 00:04:52 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Tue Jul  1 00:04:52 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Tue Jul  1 00:07:17 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Tue Jul  1 00:07:17 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Jul  6 01:04:56 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Jul  6 01:04:56 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Jul  6 01:07:54 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Jul  6 01:07:54 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Jul 13 01:05:05 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Jul 13 01:05:05 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          [Sun Jul 13 01:07:27 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
          [Sun Jul 13 01:07:27 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
          Show mounted filesystems:
          TARGET SOURCE                           FSTYPE OPTIONS
          /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
          /var:
          1.5G    /var/
          876M    /var/log
          793M    /var/log/journal/1fced0e2937f4858ba466b3b64b52574
          471M    /var/cache
          Archived and active journals take up 56.0M in the file system.
          /opt/iobroker/backups:
          6.3M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          382M    /opt/iobroker/iobroker-data/
          250M    /opt/iobroker/iobroker-data/files
          98M     /opt/iobroker/iobroker-data/backup-objects
          48M     /opt/iobroker/iobroker-data/files/iot.admin
          47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          24M     /opt/iobroker/iobroker-data/objects.jsonl
          19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
          12M     /opt/iobroker/iobroker-data/states.jsonl
          8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
          USB-Devices by-id:
          No Devices found 'by-id'
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.19.0
          /usr/bin/node           v20.19.0
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.31.0
          nodejs:
           Installed: 20.19.0-1nodesource1
           Candidate: 20.19.4-1nodesource1
           Version table:
              20.19.4-1nodesource1 600
                 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              20.19.3-1nodesource1 600
              20.19.2-1nodesource1 600
              20.19.1-1nodesource1 600
          *** 20.19.0-1nodesource1 600
              20.18.3-1nodesource1 600
              20.18.2-1nodesource1 600
              20.18.1-1nodesource1 600
              20.18.0-1nodesource1 600
              20.17.0-1nodesource1 600
              20.16.0-1nodesource1 600
              20.15.1-1nodesource1 600
              20.15.0-1nodesource1 600
              20.14.0-1nodesource1 600
              20.13.1-1nodesource1 600
              20.13.0-1nodesource1 600
              20.12.2-1nodesource1 600
              20.12.1-1nodesource1 600
              20.12.0-1nodesource1 600
              20.11.1-1nodesource1 600
              20.11.0-1nodesource1 600
              20.10.0-1nodesource1 600
              20.9.0-1nodesource1 600
              20.8.1-1nodesource1 600
              20.8.0-1nodesource1 600
              20.7.0-1nodesource1 600
              20.6.1-1nodesource1 600
              20.6.0-1nodesource1 600
              20.5.1-1nodesource1 600
              20.5.0-1nodesource1 600
              20.4.0-1nodesource1 600
              20.3.1-1nodesource1 600
              20.3.0-1nodesource1 600
              20.2.0-1nodesource1 600
              20.1.0-1nodesource1 600
              20.0.0-1nodesource1 600
              12.22.12~dfsg-1~deb11u7 500
                 500 http://security.debian.org bullseye-security/main amd64 Packages
              12.22.12~dfsg-1~deb11u4 500
                 500 http://ftp.debian.org/debian bullseye/main amd64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 9880798)
          Core adapters versions
          js-controller:  7.0.6
          admin:          7.6.17
          javascript:     8.9.2
          nodejs modules from github:     1
          +-- iobroker.mercedesme@0.3.8 (git+ssh://git@github.com/TA2k/ioBroker.mercedesme.git#426508912896a6de0257cee3c07f2a3d3b624aa4)
          Adapter State
          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
           system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
           system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
          + system.adapter.easee.0                  : easee                 : ioBroker                                 -  enabled
          + system.adapter.eusec.0                  : eusec                 : ioBroker                                 -  enabled
          + system.adapter.evcc.0                   : evcc                  : ioBroker                                 -  enabled, port: 7070
          + system.adapter.fhem.0                   : fhem                  : ioBroker                                 -  enabled, port: 7072
           system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
          + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
          + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
           system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
          + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
          + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
           system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 - disabled
          + system.adapter.mercedesme.0             : mercedesme            : ioBroker                                 -  enabled
          + system.adapter.plenticore.0             : plenticore            : ioBroker                                 -  enabled, port: 80
          + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
          + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
          + system.adapter.sql.0                    : sql                   : ioBroker                                 -  enabled, port: 3306
          + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
          + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
           system.adapter.twinkly.0                : twinkly               : ioBroker                                 - disabled
           system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
           system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
           system.adapter.vis-map.0                : vis-map               : ioBroker                                 -  enabled
           system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
           system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
          + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.web.1                    : web                   : ioBroker                                 -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
          + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 192.168.178.31, run as: admin
           system.adapter.yeelight-2.0             : yeelight-2            : ioBroker                                 - disabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Adapters
          Used repository: stable
          Adapter    "admin"        : 7.6.17   , installed 7.6.17
          Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
          Adapter    "backitup"     : 3.3.5    , installed 3.3.5
          Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
          Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
          Adapter    "easee"        : 1.0.10   , installed 1.0.10
          Adapter    "eusec"        : 1.3.3    , installed 1.3.3
          Adapter    "evcc"         : 0.1.1    , installed 0.1.1
          Adapter    "fhem"         : 3.0.0    , installed 3.0.0
          Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
          Adapter    "hue"          : 3.16.1   , installed 3.16.1
          Adapter    "ical"         : 1.16.2   , installed 1.16.2
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "javascript"   : 8.9.2    , installed 8.9.2
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
          Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
          Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
          Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
          Adapter    "shelly"       : 10.1.0   , installed 10.1.0
          Adapter    "sql"          : 3.0.1    , installed 3.0.1
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
          Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
          Adapter    "vis-icontwo"  : 1.12.0   , installed 1.12.0
          Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
          Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
          Adapter    "web"          : 7.0.8    , installed 7.0.8
          Adapter    "yeelight-2"   : 1.5.2    , installed 1.5.2
          Objects and States
          Objects:        22035
          States:         19307
          Hit:1 http://security.debian.org bullseye-security InRelease
          Hit:2 http://ftp.debian.org/debian bullseye InRelease
          Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 90
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       453697404  294150/iobroker.js-
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       453697409  294150/iobroker.js-
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          28547      322/master
          tcp        0      0 192.168.178.31:2010     0.0.0.0:*               LISTEN      1001       780288979  421774/io.hm-rpc.0
          tcp        0      0 192.168.178.31:2001     0.0.0.0:*               LISTEN      1001       453701383  294365/io.hm-rpc.1
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          26664      1/init
          tcp        0      0 192.168.178.31:8084     0.0.0.0:*               LISTEN      1001       453703328  294613/io.ws.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       879481053  458892/io.shelly.0
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          28548      322/master
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       684842571  387474/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       890512494  463082/io.web.0
          tcp6       0      0 :::8555                 :::*                    LISTEN      1001       453701218  294324/go2rtc
          tcp6       0      0 :::8554                 :::*                    LISTEN      1001       453701217  294324/go2rtc
          tcp6       0      0 :::22                   :::*                    LISTEN      0          26843      1/init
          tcp6       0      0 :::111                  :::*                    LISTEN      0          28137      1/init
          tcp6       0      0 :::1984                 :::*                    LISTEN      1001       453701224  294324/go2rtc
          tcp6       0      0 :::20002                :::*                    LISTEN      1001       890511518  463089/io.web.1
          udp        0      0 0.0.0.0:56913           0.0.0.0:*                           1001       892075443  463100/io.eusec.0
          udp        0      0 0.0.0.0:40582           0.0.0.0:*                           1001       890511570  463100/io.eusec.0
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          28134      1/init
          udp        0      0 0.0.0.0:57613           0.0.0.0:*                           1001       892937403  463100/io.eusec.0
          udp        0      0 0.0.0.0:59550           0.0.0.0:*                           1001       890511565  463100/io.eusec.0
          udp        0      0 192.168.178.31:5353     0.0.0.0:*                           1001       850668389  447064/io.tr-064.0
          udp        0      0 0.0.0.0:46664           0.0.0.0:*                           1001       890511583  463100/io.eusec.0
          udp        0      0 0.0.0.0:47128           0.0.0.0:*                           1001       892393915  463100/io.eusec.0
          udp        0      0 0.0.0.0:55852           0.0.0.0:*                           1001       892263694  463100/io.eusec.0
          udp6       0      0 :::111                  :::*                                0          28140      1/init
          udp6       0      0 :::8555                 :::*                                1001       453701219  294324/go2rtc
          2025-07-19 21:53:49.286  - info: mercedesme.0 (466526) No Data since 180 seconds. Lost WebSocket connection. Reconnect WebSocket. Reconnects Today: 78
          2025-07-19 21:54:05.635  - info: web.1 (463089) <== Disconnect system.user.admin from ::ffff:192.168.178.35 vis.0
          2025-07-19 21:56:14.090  - info: fhem.0 (294529) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
          2025-07-19 22:00:00.006  - info: javascript.0 (393714) script.js.common.Skripte_Pool.Pool_Pumpensteuerung: Zeit
          2025-07-19 22:00:38.022  - info: host.ioBroker instance system.adapter.daswetter.0 in version "3.2.3" started with pid 469153
          2025-07-19 22:00:38.903  - info: daswetter.0 (469153) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.19.0, js-controller: 7.0.6
          2025-07-19 22:00:43.308  - info: daswetter.0 (469153) still wrong data structure from server received! repaired...
          2025-07-19 22:00:44.303  - info: daswetter.0 (469153) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
          2025-07-19 22:00:44.809  - info: daswetter.0 (469153) cleaned everything up...
          2025-07-19 22:00:44.820  - info: host.ioBroker instance system.adapter.daswetter.0 having pid 469153 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2025-07-19 22:01:14.091  - info: fhem.0 (294529) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
          2025-07-19 22:05:18.275  - info: web.1 (463089) ==> Connected system.user.admin from ::ffff:192.168.178.35
          2025-07-19 22:06:14.092  - info: fhem.0 (294529) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
          2025-07-19 22:09:06.799  - info: shelly.0 (458892) [MQTT] Device with client id "shellyplusplugs-80646fd66974" connected from 192.168.178.62!
          2025-07-19 22:09:10.246  - info: shelly.0 (458892) [MQTT] Device with client id "shellyplus1-7c87ce63d79c" connected from 192.168.178.65!
          2025-07-19 22:09:11.315  - error: sql.0 (294236) Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES (55, 1752955751310, 10.69, 1, 3, 0);: Error: Duplicate entry '55-1752955751310' for key 'PRIMARY' (id: ProxMox_Verbrauch)
          2025-07-19 22:09:56.093  - warn: eusec.0 (463100) [p2p] [P2PClientProtocol.sendPing] Heartbeat check failed for station T8400P312224379C. Connection seems lost. Try to reconnect...
          2025-07-19 22:09:56.094  - info: eusec.0 (463100) [http] [Station.onDisconnect] Disconnected from station T8400P312224379C
          2025-07-19 22:09:57.368  - warn: eusec.0 (463100) [p2p] [P2PClientProtocol.sendPing] Heartbeat check failed for station T8400P2020490E69. Connection seems lost. Try to reconnect...
          2025-07-19 22:09:57.368  - info: eusec.0 (463100) [http] [Station.onDisconnect] Disconnected from station T8400P2020490E69
          2025-07-19 22:10:01.211  - info: eusec.0 (463100) [http] [Station.onConnect] Connected to station T8400P312224379C on host 192.168.178.121 and port 14681
          2025-07-19 22:10:01.678  - info: eusec.0 (463100) [http] [Station.onConnect] Connected to station T8400P2020490E69 on host 192.168.178.101 and port 11225
          2025-07-19 22:10:21.319  - info: mercedesme.0 (466526) No Data since 180 seconds. Lost WebSocket connection. Reconnect WebSocket. Reconnects Today: 79
          2025-07-19 22:11:14.093  - info: fhem.0 (294529) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
          2025-07-19 22:13:50.630  - info: web.1 (463089) <== Disconnect system.user.admin from ::ffff:192.168.178.35 vis.0
          Ro75R 1 Antwort Letzte Antwort
          • B bishop9191
            @crunchip
            Script v.2025-03-08
            *** BASE SYSTEM ***
            OS is similar to:
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
            CPU threads: 2
            steven
            HOME=/home/steven
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:
            *** MEMORY ***
            Swap:           512M         98M        413M
                    4096 M total memory
                    2714 M used memory
                     575 M active memory
                     745 M free memory
                       0 M buffer memory
                     635 M swap cache
                     512 M total swap
                      98 M used swap
                     413 M free swap
            *** FILESYSTEM ***
            /var:
            1.5G    /var/
            876M    /var/log
            471M    /var/cache
            USB-Devices by-id:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
             Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.6.17
            javascript:     8.9.2
            Adapter State
            + instance is alive
            Objects and States
            Objects:        22035
            States:         19307
            Pending Updates: 90
            Ro75R
            Ro75R
            Ro75
            #2297
            @bishop9191 sagte in [SourceAnalytix 0.4.8-Final] Released !:
            das sieht gar nicht gesund aus.
            Ro75.
            • Ro75R Ro75
              Ro75.
              Thomas BraunT
              Thomas BraunT
              Most Active Developer
              #2298
              @ro75 sagte in [SourceAnalytix 0.4.8-Final] Released !:
              Aber nicht nur an der Stelle. Der Patient hat auch noch andere Baustellen.
              Ich würde da gleich was aktuelles sauber neuausrollen.
                B
                B
                bishop9191
                schrieb am zuletzt editiert von bishop9191
                #2299
                Script v.2025-03-08
                *** BASE SYSTEM ***
                 Static hostname: ioBroker
                       Icon name: computer-container
                         Chassis: container ☐
                  Virtualization: lxc
                          Kernel: Linux 5.15.158-2-pve
                    Architecture: x86-64
                OS is similar to:
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                 18:02:25 up 18:30,  3 users,  load average: 0.54, 0.52, 0.82
                CPU threads: 2
                Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                               Local time: Wed 2025-07-23 18:02:26 CEST
                           Universal time: Wed 2025-07-23 16:02:26 UTC
                                 RTC time: n/a
                              NTP service: inactive
                          RTC in local TZ: no
                steven
                HOME=/home/steven
                GROUPS=steven sudo users iobroker
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            4.3G        2.4G        1.3G        131K        658M        1.9G
                Swap:           536M          0B        536M
                Total:          4.8G        2.4G        1.8G
                Active iob-Instances:   31
                         4096 M total memory
                         2241 M used memory
                          337 M active memory
                         2384 M inactive memory
                         1226 M free memory
                            0 M buffer memory
                          627 M swap cache
                          512 M total swap
                            0 M used swap
                          512 M free swap
                top - 18:02:26 up 18:30,  3 users,  load average: 0.54, 0.52, 0.82
                Tasks:  61 total,   1 running,  60 sleeping,   0 stopped,   0 zombie
                MiB Mem :   4096.0 total,   1224.9 free,   2243.2 used,    627.9 buff/cache
                MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1852.8 avail Mem
                0 loaded units listed.
                *** FILESYSTEM ***
                /dev/mapper/pve-vm--104--disk--1 ext4    16G  3.5G   12G  24% /
                tmpfs                            tmpfs  3.2G  124K  3.2G   1% /run
                tmpfs                            tmpfs  1.6G     0  1.6G   0% /run/user/1000
                [Sat Jul 19 23:57:00 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun Jul 20 00:06:41 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                [Sun Jul 20 00:06:41 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                [Sun Jul 20 00:10:52 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                [Sun Jul 20 00:10:52 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                [Sun Jul 20 00:11:59 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                [Sun Jul 20 00:11:59 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                [Sun Jul 20 01:05:11 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                [Sun Jul 20 01:05:11 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                [Sun Jul 20 01:08:00 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                [Sun Jul 20 01:08:00 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                [Sun Jul 20 21:28:03 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun Jul 20 21:55:29 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun Jul 20 22:52:02 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun Jul 20 23:01:04 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun Jul 20 23:01:36 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun Jul 20 23:30:30 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun Jul 20 23:30:52 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun Jul 20 23:49:35 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                [Sun Jul 20 23:49:35 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                [Mon Jul 21 23:05:30 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Mon Jul 21 23:09:32 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Mon Jul 21 23:12:32 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                [Tue Jul 22 21:32:51 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Tue Jul 22 22:23:09 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Tue Jul 22 22:32:42 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                [Tue Jul 22 23:36:43 2025] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Tue Jul 22 23:37:30 2025] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Tue Jul 22 23:48:30 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                [Tue Jul 22 23:48:30 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                /      /dev/mapper/pve-vm--104--disk--1 ext4   rw,relatime,stripe=16
                /var:
                407M    /var/
                219M    /var/cache
                215M    /var/cache/apt
                147M    /var/lib
                139M    /var/cache/apt/archives
                Archived and active journals take up 16.0M in the file system.
                6.9M    /opt/iobroker/backups/
                327M    /opt/iobroker/iobroker-data/
                247M    /opt/iobroker/iobroker-data/files
                25M     /opt/iobroker/iobroker-data/objects.jsonl
                21M     /opt/iobroker/iobroker-data/states.jsonl
                USB-Devices by-id:
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/nodejs         v20.19.4
                /usr/bin/node           v20.19.4
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                /usr/bin/corepack       0.32.0
                nodejs:
                  Installed: 20.19.4-1nodesource1
                  Version table:
                 *** 20.19.4-1nodesource1 600
                     18.19.0+dfsg-6~deb12u2 500
                        500 http://deb.debian.org/debian bookworm/main amd64 Packages
                     18.19.0+dfsg-6~deb12u1 500
                        500 http://security.debian.org bookworm-security/main amd64 Packages
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 66604)
                admin:          7.6.17
                javascript:     8.9.2
                Adapter State
                  system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
                + instance is alive
                Adapter    "socketio"     : 6.7.1    , installed 7.0.8
                Adapter    "ws"           : 2.6.2    , installed 3.0.19
                Objects and States
                Objects:        21330
                States:         18700
                Hit:1 http://security.debian.org bookworm-security InRelease
                Hit:2 http://deb.debian.org/debian bookworm InRelease
                Pending Updates: 0
                tcp        0      0 192.168.178.31:2001     0.0.0.0:*               LISTEN      1001       914893137  737/io.hm-rpc.1
                tcp        0      0 192.168.178.31:2010     0.0.0.0:*               LISTEN      1001       917882617  3279/io.hm-rpc.0
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          914886797  1/init
                tcp        0      0 192.168.178.31:8084     0.0.0.0:*               LISTEN      1001       914897248  1202/io.ws.0
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       914891678  837/io.shelly.0
                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          914887169  291/master
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       914887805  125/iobroker.js-con
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       914887312  125/iobroker.js-con
                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          914887170  291/master
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       914887662  419/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       914903136  1235/io.web.0
                tcp6       0      0 :::111                  :::*                    LISTEN      0          914886803  1/init
                tcp6       0      0 :::22                   :::*                    LISTEN      0          914884445  1/init
                tcp6       0      0 :::8554                 :::*                    LISTEN      1001       914903160  1262/go2rtc
                tcp6       0      0 :::8555                 :::*                    LISTEN      1001       914903163  1262/go2rtc
                tcp6       0      0 :::1984                 :::*                    LISTEN      1001       914903168  1262/go2rtc
                tcp6       0      0 :::20002                :::*                    LISTEN      1001       914903133  1228/io.web.1
                udp        0      0 0.0.0.0:56374           0.0.0.0:*                           1001       914900410  1217/io.eusec.0
                udp        0      0 0.0.0.0:56523           0.0.0.0:*                           1001       916315494  1217/io.eusec.0
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          914886800  1/init
                udp        0      0 0.0.0.0:60675           0.0.0.0:*                           1001       914900419  1217/io.eusec.0
                udp        0      0 0.0.0.0:36146           0.0.0.0:*                           1001       914903173  1217/io.eusec.0
                udp        0      0 192.168.178.31:5353     0.0.0.0:*                           1001       914894872  863/io.tr-064.0
                udp6       0      0 :::111                  :::*                                0          914886806  1/init
                udp6       0      0 :::8555                 :::*                                1001       914903164  1262/go2rtc
                2025-07-23 18:00:21.772  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.OPERATING_VOLTAGE_STATUS to "Gartenhaus_Temperatur_0.OPERATING_VOLTAGE_STATUS"
                2025-07-23 18:00:21.775  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.RSSI_DEVICE to "Gartenhaus_Temperatur_0.RSSI_DEVICE"
                2025-07-23 18:00:21.777  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.OPERATING_VOLTAGE to "Gartenhaus_Temperatur_0.OPERATING_VOLTAGE"
                2025-07-23 18:00:21.780  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.TEMPERATURE_OUT_OF_RANGE to "Gartenhaus_Temperatur_0.TEMPERATURE_OUT_OF_RANGE"
                2025-07-23 18:00:21.782  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.RSSI_PEER to "Gartenhaus_Temperatur_0.RSSI_PEER"
                2025-07-23 18:00:21.784  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.ERROR_CODE to "Gartenhaus_Temperatur_0.ERROR_CODE"
                2025-07-23 18:00:21.786  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.UPDATE_PENDING to "Gartenhaus_Temperatur_0.UPDATE_PENDING"
                2025-07-23 18:00:21.788  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.1 to "Gartenhaus_Temperatur_1"
                2025-07-23 18:00:21.791  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.1.HUMIDITY to "Gartenhaus_Temperatur_1.HUMIDITY"
                2025-07-23 18:00:21.793  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.1.HUMIDITY_STATUS to "Gartenhaus_Temperatur_1.HUMIDITY_STATUS"
                2025-07-23 18:00:21.802  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.1.ACTUAL_TEMPERATURE to "Gartenhaus_Temperatur_1.ACTUAL_TEMPERATURE"
                2025-07-23 18:00:21.805  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.1.ACTUAL_TEMPERATURE_STATUS to "Gartenhaus_Temperatur_1.ACTUAL_TEMPERATURE_STATUS"
                2025-07-23 18:00:21.807  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.2 to "Gartenhaus_Temperatur_2"
                2025-07-23 18:00:21.809  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.3 to "Gartenhaus_Temperatur_3"
                2025-07-23 18:00:51.014  - info: host.ioBroker instance system.adapter.daswetter.0 in version "3.2.3" started with pid 3294
                2025-07-23 18:00:51.919  - info: daswetter.0 (3294) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.19.4, js-controller: 7.0.6
                2025-07-23 18:00:55.829  - info: daswetter.0 (3294) still wrong data structure from server received! repaired...
                2025-07-23 18:00:56.765  - info: daswetter.0 (3294) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                2025-07-23 18:00:57.271  - info: daswetter.0 (3294) cleaned everything up...
                2025-07-23 18:00:57.280  - info: host.ioBroker instance system.adapter.daswetter.0 having pid 3294 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2025-07-23 18:01:09.763  - info: sql.0 (500) enabled logging of Gartenhaus_Temperatur, Alias=true, WriteNulls=true
                2025-07-23 18:01:10.365  - info: sql.0 (500) changed history configuration to pin detected datatype for Gartenhaus_Temperatur
                2025-07-23 18:01:28.788  - info: sql.0 (500) enabled logging of Gartenhaus_Luftfeuchtigkeit, Alias=true, WriteNulls=true
                2025-07-23 18:01:28.851  - info: sql.0 (500) changed history configuration to pin detected datatype for Gartenhaus_Luftfeuchtigkeit
                2025-07-23 18:01:51.265  - info: admin.0 (419) <== Disconnect system.user.admin from ::ffff:192.168.178.13 admin
                Habe neu aufgesetzt auf Debian 12 und über Backitup die ioBroker Konfig zurückgespielt.
                Die Fehlermeldungen:
                sind laut meinen Recherchen "normal", während eines Backupvorgangs in Proxmox. Zumindest habe ich das so im Proxmox Forum gefunden...
                Das Problem mit SourceAnalytix besteht leider weiterhin 😧
                • MassiveAttackM
                  MassiveAttackM
                  MassiveAttack
                  schrieb am zuletzt editiert von MassiveAttack
                  #2300
                  Kann mir bitte jemand helfen, diesen Fehler wegzubekommen? Der kommt mittlerweile ~ alle 30 Sekunden und spammt mir das Log voll:
                  sourceanalytix.0
                  	2025-07-24 11:23:34.128	error	Input value for javascript.0.Wetterstation.Regen_Jahr, type = string but should be a number, cannot handle calculation
                  Der Type ist aber mixed bzw. auch number. Nur der Zustand hat Typ string. Wie kann ich das ändern?
                  6d6515d5-456f-4e9b-93e8-4a4d7fdb2a91-1753349201961-a48c6706-3dc6-4b79-b029-8765e864bca6-da22c1b4-e01c-4be4-9dae-6eee45755a3a.png
                  • MassiveAttackM MassiveAttack
                    sourceanalytix.0
                    M
                    M
                    michihorn
                    schrieb am zuletzt editiert von michihorn
                    #2301
                    @massiveattack Ich habe das so gemacht:
                    Ich habe einen Datenpunkt "mqtt.1.logger.GTHRN.Solar.Umwandlung" als Zahl angelegt und diesen dann per Script gefüttert. (Okay, hätte ich besser in userdata gemacht, aber egal)
                    Das Zauberwort heißt "parseFloat", siehe Script. ParseFlot wandet Text in Zahl.
                    Ich habe dann diesen Datenpunkt in SourceAnaytix ausgewertet anstatt des "Orginalen"
                    /*****Solar ErtragNL in Zahl umwandeln*************************
                    * Juli 2025
                    * Adapter:
                    * geä:23.07.25
                    const id_ertrag="mqtt.1.logger.GTHRN.Solar.totalEnergie"
                    const id_umwandlung ="mqtt.1.logger.GTHRN.Solar.Umwandlung"
                    //const id_umwandlung ="0_userdata.0.Giethoorn.Energie.Zählerstände.Umwandlung"
                    on({ id: id_ertrag, change: "any" }, async function (obj) {
                    var zahl = parseFloat(getState(id_ertrag).val)
                    log(zahl)
                    setState(id_umwandlung,zahl)
                    Michael
                    MassiveAttackM 1 Antwort Letzte Antwort
                    • M michihorn
                      * Juli 2025
                      * Adapter:
                      * geä:23.07.25
                      log(zahl)
                      Michael
                      MassiveAttackM
                      MassiveAttackM
                      MassiveAttack
                      #2302
                      @michihorn sagte in [SourceAnalytix 0.4.8-Final] Released !:
                      * Juli 2025
                      * Adapter:
                      * geä:23.07.25
                      log(zahl)
                      Michael
                      Danke, werde ich mal bei Gelegenheit testen.
                      Aber was ist das eigentliche Problem? Kann der Typ nicht mehr geändert werden?
                      • nik82N
                        nik82N
                        nik82
                        schrieb am zuletzt editiert von nik82
                        #2303
                        ich bekomme immer mal wieder diesen Fehler im Log, grundsätzlich funktioniert der Datenpunkt aber.
                        Was bedeutet das:
                        2025-12-18 18:09:13.846 - error: sourceanalytix.0 (1003) [calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":false,"ts":1766077753837,"q":0,"c":"script.js.common.Autos.SourceAnalytix","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1766077753837} | stateDetails {"alias":"Auto_Nik_Kilometer","consumption":true,"costs":true,"deviceName":"0_userdata__0__Auto__Auto_Nik_Kilometer","financialCategory":"costs","headCategory":"consumed","meter_values":true,"name":"Auto_Nik_Kilometer","stateType":"Benzin","stateUnit":"kWh","useUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1}
                        Ich habe das immer nur bei dem Datenpunkt ab und zu.
                        Danke im Voraus.
                        P.S. Ich glaub ich habs selber gefunden, ab und zu wird hier keine Zahl übertragen, glaube ich zumindest :-)
                        • nik82N nik82
                          Was bedeutet das:
                          Danke im Voraus.
                          crunchipC
                          crunchipC
                          #2304
                          @nik82 sagte in [SourceAnalytix 0.4.8-Final] Released !:
                          Der Fehler im SourceAnalytix-Adapter tritt auf, weil der aktuelle Zählerwert (Reading) nach der Einheitenkonvertierung null ist, was die Berechnung blockiert. Dies geschieht typischerweise bei ungültigen Eingabewerten, falscher Einheit oder Initialisierungsproblemen beim State
                          84.1k
