  4. [SourceAnalytix 0.4.8-Final] Released !
2.3k Beiträge 184 Kommentatoren 1.5m Aufrufe 153 Beobachtet
  • B bishop9191
    @crunchip in den Objekten, bei den Datenpunkten das Menü von SourceAnalytix, dass ich Datenpunkte für SourceAnalytix definieren kann
    Beowolf
    #2289
    @bishop9191
    Welche anderen "Dinge" sind denn auswählbar?
    • B Beowolf
      @bishop9191
      bishop9191
      #2290
      @beowolf telegram und sql
      • B bishop9191
        crunchipC Offline
        crunchipC Offline
        #2291
        @bishop9191 mach mal ein
        iob upload all
        Per konsole
          iob upload all
          Per konsole
          bishop9191
          #2292
          @crunchip hat nichts bewirkt 😐
          • B bishop9191
            crunchipC Offline
            crunchipC Offline
            #2293
            @bishop9191 dann mal
            iob diag
              iob diag
              bishop9191
              #2294
              @crunchip was ist hier interessant? die komplette diag oder ein bestimmter bereich?
              • B bishop9191
                crunchipC Offline
                crunchipC Offline
                #2295
                @bishop9191 die vollständige Ausgabe
                  bishop9191
                  #2296
                  @crunchip
                  Script v.2025-03-08
                  *** BASE SYSTEM ***
                  Failed to query system properties: Failed to activate service 'org.freedesktop.hostname1': timed out (service_start_timeout=25000ms)
                  OS is similar to:
                  model name      : Intel(R) Core(TM) i5-6400T CPU @ 2.20GHz
                  Docker          : false
                  Virtualization  : lxc
                  Kernel          : x86_64
                  Userland        : 64 bit
                  Systemuptime and Load:
                  22:13:35 up 277 days, 23:42,  2 users,  load average: 0.09, 0.33, 0.71
                  CPU threads: 2
                  *** LIFE CYCLE STATUS ***
                  Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                  *** TIME AND TIMEZONES ***
                  Failed to query server: Connection timed out
                  Failed to parse bus message: Connection timed out
                  *** Users and Groups ***
                  User that called 'iob diag':
                  steven
                  HOME=/home/steven
                  GROUPS=steven sudo iobroker
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video plugdev
                  *** DISPLAY-SERVER SETUP ***
                  Display-Server: false
                  Desktop:
                  Terminal:
                  System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                  *** MEMORY ***
                  Mem:            4.1G        2.7G        745M        0.0K        635M        1.4G
                  Swap:           512M         98M        413M
                  Total:          4.6G        2.8G        1.2G
                  Active iob-Instances:   32
                          4096 M total memory
                          2714 M used memory
                           575 M active memory
                          2524 M inactive memory
                           745 M free memory
                             0 M buffer memory
                           635 M swap cache
                           512 M total swap
                            98 M used swap
                           413 M free swap
                  top - 22:14:50 up 277 days, 23:43,  2 users,  load average: 0.07, 0.26, 0.65
                  Tasks:  58 total,   1 running,  57 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   4096.0 total,    745.4 free,   2714.7 used,    635.9 buff/cache
                  MiB Swap:    512.0 total,    413.1 free,     98.9 used.   1381.3 avail Mem
                  *** FAILED SERVICES ***
                   UNIT                      LOAD   ACTIVE SUB    DESCRIPTION
                  * logrotate.service         loaded failed failed Rotate log files
                  * nftables.service          loaded failed failed nftables
                  * systemd-hostnamed.service loaded failed failed Hostname Service
                  * systemd-logind.service    loaded failed failed User Login Management
                  * systemd-networkd.service  loaded failed failed Network Service
                  * systemd-resolved.service  loaded failed failed Network Name Resolution
                  * systemd-timedated.service loaded failed failed Time & Date Service
                  * systemd-networkd.socket   loaded failed failed Network Service Netlink Socket
                  8 loaded units listed.
                  *** DMESG CRITICAL ERRORS ***
                  No critical errors detected
                  *** FILESYSTEM ***
                  Filesystem                       Type   Size  Used Avail Use% Mounted on
                  /dev/mapper/pve-vm--100--disk--0 ext4    16G  6.3G  8.6G  43% /
                  none                             tmpfs  492K  4.0K  488K   1% /dev
                  tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
                  tmpfs                            tmpfs  3.2G   60K  3.2G   1% /run
                  tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
                  [Sun Feb 16 01:02:24 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Feb 16 01:02:24 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Feb 16 01:04:49 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Feb 16 01:04:49 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Feb 23 01:02:34 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Feb 23 01:02:34 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Feb 23 01:04:47 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Feb 23 01:04:47 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sat Mar  1 00:02:37 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sat Mar  1 00:02:37 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sat Mar  1 00:04:59 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sat Mar  1 00:04:59 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Mar  2 01:02:41 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Mar  2 01:02:41 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Mar  2 01:04:55 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Mar  2 01:04:55 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Fri Mar  7 22:26:08 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Fri Mar  7 22:26:36 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Fri Mar  7 22:37:11 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Fri Mar  7 22:37:38 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Fri Mar  7 22:41:18 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Fri Mar  7 22:51:11 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Fri Mar  7 22:52:00 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Fri Mar  7 22:52:22 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Fri Mar  7 22:57:57 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Fri Mar  7 23:26:43 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Sat Mar  8 08:31:33 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Sat Mar  8 08:51:59 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Sat Mar  8 08:52:22 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Sat Mar  8 09:04:21 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Sat Mar  8 09:04:35 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Sat Mar  8 09:06:54 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sat Mar  8 09:06:54 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sat Mar  8 16:40:34 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Sat Mar  8 17:26:44 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Sat Mar  8 22:08:41 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sat Mar  8 22:09:13 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Mar  9 01:02:43 2025] EXT4-fs (dm-13): write access unavailable, skipping orphan cleanup
                  [Sun Mar  9 01:02:43 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Mar  9 01:05:17 2025] EXT4-fs (dm-13): write access unavailable, skipping orphan cleanup
                  [Sun Mar  9 01:05:17 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Mar 16 01:02:51 2025] EXT4-fs (dm-13): write access unavailable, skipping orphan cleanup
                  [Sun Mar 16 01:02:51 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Mar 16 01:05:24 2025] EXT4-fs (dm-13): write access unavailable, skipping orphan cleanup
                  [Sun Mar 16 01:05:24 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Mon Mar 17 21:05:59 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Wed Mar 19 21:48:16 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Wed Mar 19 22:11:29 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Wed Mar 19 22:11:45 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Wed Mar 19 22:35:50 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Wed Mar 19 22:36:04 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Wed Mar 19 22:39:16 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Wed Mar 19 22:39:36 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                  [Wed Mar 19 22:48:14 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Wed Mar 19 22:48:43 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Mar 23 01:03:00 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Mar 23 01:03:00 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Mar 23 01:05:06 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Mar 23 01:05:06 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Thu Mar 27 12:21:06 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Thu Mar 27 12:21:06 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Mar 30 01:03:08 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Mar 30 01:03:08 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Mar 30 01:05:18 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Mar 30 01:05:18 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Tue Apr  1 00:03:09 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Tue Apr  1 00:03:09 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Tue Apr  1 00:05:35 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Tue Apr  1 00:05:35 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Apr  6 01:03:14 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Apr  6 01:03:14 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Apr  6 01:05:21 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Apr  6 01:05:21 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Apr 13 01:03:25 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Apr 13 01:03:25 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Apr 13 01:05:30 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Apr 13 01:05:30 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Apr 20 01:03:31 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Apr 20 01:03:31 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Apr 20 01:06:04 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Apr 20 01:06:04 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Apr 27 01:03:41 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Apr 27 01:03:41 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Apr 27 01:06:16 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Apr 27 01:06:16 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Tue Apr 29 22:17:50 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Tue Apr 29 22:17:50 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Thu May  1 00:03:43 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Thu May  1 00:03:43 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Thu May  1 00:06:05 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Thu May  1 00:06:05 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun May  4 01:03:51 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun May  4 01:03:51 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun May  4 01:06:34 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun May  4 01:06:34 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun May 11 01:03:56 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun May 11 01:03:56 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun May 11 01:06:36 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun May 11 01:06:36 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun May 18 01:04:05 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun May 18 01:04:05 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun May 18 01:06:39 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun May 18 01:06:39 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun May 25 01:04:13 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun May 25 01:04:13 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun May 25 01:06:35 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun May 25 01:06:35 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Jun  1 00:04:24 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Jun  1 00:04:24 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Jun  1 00:06:51 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Jun  1 00:06:51 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Jun  1 01:04:24 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Jun  1 01:04:24 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Jun  1 01:06:24 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Jun  1 01:06:24 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Jun  8 01:04:29 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Jun  8 01:04:29 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Jun  8 01:06:33 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Jun  8 01:06:33 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Jun 15 01:04:32 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Jun 15 01:04:32 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Jun 15 01:06:42 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Jun 15 01:06:42 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Jun 22 01:04:40 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Jun 22 01:04:40 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Jun 22 01:06:47 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Jun 22 01:06:47 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Jun 29 01:04:48 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Jun 29 01:04:48 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Jun 29 01:08:40 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Jun 29 01:08:40 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Tue Jul  1 00:04:52 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Tue Jul  1 00:04:52 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Tue Jul  1 00:07:17 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Tue Jul  1 00:07:17 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Jul  6 01:04:56 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Jul  6 01:04:56 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Jul  6 01:07:54 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Jul  6 01:07:54 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Jul 13 01:05:05 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Jul 13 01:05:05 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  [Sun Jul 13 01:07:27 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                  [Sun Jul 13 01:07:27 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                  Show mounted filesystems:
                  TARGET SOURCE                           FSTYPE OPTIONS
                  /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
                  /var:
                  1.5G    /var/
                  876M    /var/log
                  793M    /var/log/journal/1fced0e2937f4858ba466b3b64b52574
                  471M    /var/cache
                  Archived and active journals take up 56.0M in the file system.
                  /opt/iobroker/backups:
                  6.3M    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  382M    /opt/iobroker/iobroker-data/
                  250M    /opt/iobroker/iobroker-data/files
                  98M     /opt/iobroker/iobroker-data/backup-objects
                  48M     /opt/iobroker/iobroker-data/files/iot.admin
                  47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
                  38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                  24M     /opt/iobroker/iobroker-data/objects.jsonl
                  19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                  12M     /opt/iobroker/iobroker-data/states.jsonl
                  8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
                  USB-Devices by-id:
                  No Devices found 'by-id'
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v20.19.0
                  /usr/bin/node           v20.19.0
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  /usr/bin/corepack       0.31.0
                  nodejs:
                   Installed: 20.19.0-1nodesource1
                   Candidate: 20.19.4-1nodesource1
                   Version table:
                      20.19.4-1nodesource1 600
                         500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                      20.19.3-1nodesource1 600
                      20.19.2-1nodesource1 600
                      20.19.1-1nodesource1 600
                  *** 20.19.0-1nodesource1 600
                      20.18.3-1nodesource1 600
                      20.18.2-1nodesource1 600
                      20.18.1-1nodesource1 600
                      20.18.0-1nodesource1 600
                      20.17.0-1nodesource1 600
                      20.16.0-1nodesource1 600
                      20.15.1-1nodesource1 600
                      20.15.0-1nodesource1 600
                      20.14.0-1nodesource1 600
                      20.13.1-1nodesource1 600
                      20.13.0-1nodesource1 600
                      20.12.2-1nodesource1 600
                      20.12.1-1nodesource1 600
                      20.12.0-1nodesource1 600
                      20.11.1-1nodesource1 600
                      20.11.0-1nodesource1 600
                      20.10.0-1nodesource1 600
                      20.9.0-1nodesource1 600
                      20.8.1-1nodesource1 600
                      20.8.0-1nodesource1 600
                      20.7.0-1nodesource1 600
                      20.6.1-1nodesource1 600
                      20.6.0-1nodesource1 600
                      20.5.1-1nodesource1 600
                      20.5.0-1nodesource1 600
                      20.4.0-1nodesource1 600
                      20.3.1-1nodesource1 600
                      20.3.0-1nodesource1 600
                      20.2.0-1nodesource1 600
                      20.1.0-1nodesource1 600
                      20.0.0-1nodesource1 600
                      12.22.12~dfsg-1~deb11u7 500
                         500 http://security.debian.org bullseye-security/main amd64 Packages
                      12.22.12~dfsg-1~deb11u4 500
                         500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                  No problems detected
                  Errors in npm tree: 0
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 9880798)
                  Core adapters versions
                  js-controller:  7.0.6
                  admin:          7.6.17
                  javascript:     8.9.2
                  nodejs modules from github:     1
                  +-- iobroker.mercedesme@0.3.8 (git+ssh://git@github.com/TA2k/ioBroker.mercedesme.git#426508912896a6de0257cee3c07f2a3d3b624aa4)
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                  + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                   system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
                   system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
                  + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                  + system.adapter.easee.0                  : easee                 : ioBroker                                 -  enabled
                  + system.adapter.eusec.0                  : eusec                 : ioBroker                                 -  enabled
                  + system.adapter.evcc.0                   : evcc                  : ioBroker                                 -  enabled, port: 7070
                  + system.adapter.fhem.0                   : fhem                  : ioBroker                                 -  enabled, port: 7072
                   system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
                  + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
                  + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                  + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                  + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
                   system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                  + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
                  + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                  + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                   system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 - disabled
                  + system.adapter.mercedesme.0             : mercedesme            : ioBroker                                 -  enabled
                  + system.adapter.plenticore.0             : plenticore            : ioBroker                                 -  enabled, port: 80
                  + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
                  + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
                  + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
                  + system.adapter.sql.0                    : sql                   : ioBroker                                 -  enabled, port: 3306
                  + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
                  + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                   system.adapter.twinkly.0                : twinkly               : ioBroker                                 - disabled
                   system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                   system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                  + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                   system.adapter.vis-map.0                : vis-map               : ioBroker                                 -  enabled
                   system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                   system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                  + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.web.1                    : web                   : ioBroker                                 -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
                  + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 192.168.178.31, run as: admin
                   system.adapter.yeelight-2.0             : yeelight-2            : ioBroker                                 - disabled
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Upgrade policy: none
                  Installed ioBroker-Adapters
                  Used repository: stable
                  Adapter    "admin"        : 7.6.17   , installed 7.6.17
                  Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
                  Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                  Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
                  Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                  Adapter    "easee"        : 1.0.10   , installed 1.0.10
                  Adapter    "eusec"        : 1.3.3    , installed 1.3.3
                  Adapter    "evcc"         : 0.1.1    , installed 0.1.1
                  Adapter    "fhem"         : 3.0.0    , installed 3.0.0
                  Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
                  Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                  Adapter    "hue"          : 3.16.1   , installed 3.16.1
                  Adapter    "ical"         : 1.16.2   , installed 1.16.2
                  Adapter    "iot"          : 3.3.0    , installed 3.3.0
                  Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                  Controller "js-controller": 7.0.6    , installed 7.0.6
                  Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
                  Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
                  Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                  Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
                  Adapter    "shelly"       : 10.1.0   , installed 10.1.0
                  Adapter    "sql"          : 3.0.1    , installed 3.0.1
                  Adapter    "text2command" : 3.0.3    , installed 3.0.3
                  Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                  Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
                  Adapter    "vis-icontwo"  : 1.12.0   , installed 1.12.0
                  Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                  Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                  Adapter    "web"          : 7.0.8    , installed 7.0.8
                  Adapter    "yeelight-2"   : 1.5.2    , installed 1.5.2
                  Objects and States
                  Objects:        22035
                  States:         19307
                  Hit:1 http://security.debian.org bullseye-security InRelease
                  Hit:2 http://ftp.debian.org/debian bullseye InRelease
                  Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                  Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 90
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       453697404  294150/iobroker.js-
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       453697409  294150/iobroker.js-
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          28547      322/master
                  tcp        0      0 192.168.178.31:2010     0.0.0.0:*               LISTEN      1001       780288979  421774/io.hm-rpc.0
                  tcp        0      0 192.168.178.31:2001     0.0.0.0:*               LISTEN      1001       453701383  294365/io.hm-rpc.1
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          26664      1/init
                  tcp        0      0 192.168.178.31:8084     0.0.0.0:*               LISTEN      1001       453703328  294613/io.ws.0
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       879481053  458892/io.shelly.0
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          28548      322/master
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       684842571  387474/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       890512494  463082/io.web.0
                  tcp6       0      0 :::8555                 :::*                    LISTEN      1001       453701218  294324/go2rtc
                  tcp6       0      0 :::8554                 :::*                    LISTEN      1001       453701217  294324/go2rtc
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          26843      1/init
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          28137      1/init
                  tcp6       0      0 :::1984                 :::*                    LISTEN      1001       453701224  294324/go2rtc
                  tcp6       0      0 :::20002                :::*                    LISTEN      1001       890511518  463089/io.web.1
                  udp        0      0 0.0.0.0:56913           0.0.0.0:*                           1001       892075443  463100/io.eusec.0
                  udp        0      0 0.0.0.0:40582           0.0.0.0:*                           1001       890511570  463100/io.eusec.0
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          28134      1/init
                  udp        0      0 0.0.0.0:57613           0.0.0.0:*                           1001       892937403  463100/io.eusec.0
                  udp        0      0 0.0.0.0:59550           0.0.0.0:*                           1001       890511565  463100/io.eusec.0
                  udp        0      0 192.168.178.31:5353     0.0.0.0:*                           1001       850668389  447064/io.tr-064.0
                  udp        0      0 0.0.0.0:46664           0.0.0.0:*                           1001       890511583  463100/io.eusec.0
                  udp        0      0 0.0.0.0:47128           0.0.0.0:*                           1001       892393915  463100/io.eusec.0
                  udp        0      0 0.0.0.0:55852           0.0.0.0:*                           1001       892263694  463100/io.eusec.0
                  udp6       0      0 :::111                  :::*                                0          28140      1/init
                  udp6       0      0 :::8555                 :::*                                1001       453701219  294324/go2rtc
                  2025-07-19 21:53:49.286  - info: mercedesme.0 (466526) No Data since 180 seconds. Lost WebSocket connection. Reconnect WebSocket. Reconnects Today: 78
                  2025-07-19 21:54:05.635  - info: web.1 (463089) <== Disconnect system.user.admin from ::ffff:192.168.178.35 vis.0
                  2025-07-19 21:56:14.090  - info: fhem.0 (294529) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                  2025-07-19 22:00:00.006  - info: javascript.0 (393714) script.js.common.Skripte_Pool.Pool_Pumpensteuerung: Zeit
                  2025-07-19 22:00:38.022  - info: host.ioBroker instance system.adapter.daswetter.0 in version "3.2.3" started with pid 469153
                  2025-07-19 22:00:38.903  - info: daswetter.0 (469153) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.19.0, js-controller: 7.0.6
                  2025-07-19 22:00:43.308  - info: daswetter.0 (469153) still wrong data structure from server received! repaired...
                  2025-07-19 22:00:44.303  - info: daswetter.0 (469153) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                  2025-07-19 22:00:44.809  - info: daswetter.0 (469153) cleaned everything up...
                  2025-07-19 22:00:44.820  - info: host.ioBroker instance system.adapter.daswetter.0 having pid 469153 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2025-07-19 22:01:14.091  - info: fhem.0 (294529) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                  2025-07-19 22:05:18.275  - info: web.1 (463089) ==> Connected system.user.admin from ::ffff:192.168.178.35
                  2025-07-19 22:06:14.092  - info: fhem.0 (294529) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                  2025-07-19 22:09:06.799  - info: shelly.0 (458892) [MQTT] Device with client id "shellyplusplugs-80646fd66974" connected from 192.168.178.62!
                  2025-07-19 22:09:10.246  - info: shelly.0 (458892) [MQTT] Device with client id "shellyplus1-7c87ce63d79c" connected from 192.168.178.65!
                  2025-07-19 22:09:11.315  - error: sql.0 (294236) Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES (55, 1752955751310, 10.69, 1, 3, 0);: Error: Duplicate entry '55-1752955751310' for key 'PRIMARY' (id: ProxMox_Verbrauch)
                  2025-07-19 22:09:56.093  - warn: eusec.0 (463100) [p2p] [P2PClientProtocol.sendPing] Heartbeat check failed for station T8400P312224379C. Connection seems lost. Try to reconnect...
                  2025-07-19 22:09:56.094  - info: eusec.0 (463100) [http] [Station.onDisconnect] Disconnected from station T8400P312224379C
                  2025-07-19 22:09:57.368  - warn: eusec.0 (463100) [p2p] [P2PClientProtocol.sendPing] Heartbeat check failed for station T8400P2020490E69. Connection seems lost. Try to reconnect...
                  2025-07-19 22:09:57.368  - info: eusec.0 (463100) [http] [Station.onDisconnect] Disconnected from station T8400P2020490E69
                  2025-07-19 22:10:01.211  - info: eusec.0 (463100) [http] [Station.onConnect] Connected to station T8400P312224379C on host 192.168.178.121 and port 14681
                  2025-07-19 22:10:01.678  - info: eusec.0 (463100) [http] [Station.onConnect] Connected to station T8400P2020490E69 on host 192.168.178.101 and port 11225
                  2025-07-19 22:10:21.319  - info: mercedesme.0 (466526) No Data since 180 seconds. Lost WebSocket connection. Reconnect WebSocket. Reconnects Today: 79
                  2025-07-19 22:11:14.093  - info: fhem.0 (294529) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                  2025-07-19 22:13:50.630  - info: web.1 (463089) <== Disconnect system.user.admin from ::ffff:192.168.178.35 vis.0
                  Ro75R 1 Antwort Letzte Antwort
                  • B bishop9191
                    @crunchip
                    Script v.2025-03-08
                    *** BASE SYSTEM ***
                    OS is similar to:
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : 64 bit
                    CPU threads: 2
                    steven
                    HOME=/home/steven
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Swap:           512M         98M        413M
                            4096 M total memory
                            2714 M used memory
                             575 M active memory
                             745 M free memory
                               0 M buffer memory
                             635 M swap cache
                             512 M total swap
                              98 M used swap
                             413 M free swap
                    *** FILESYSTEM ***
                    /var:
                    1.5G    /var/
                    876M    /var/log
                    471M    /var/cache
                    USB-Devices by-id:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                     Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.6.17
                    javascript:     8.9.2
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        22035
                    States:         19307
                    Pending Updates: 90
                    Ro75R Online
                    Ro75R Online
                    Ro75
                    #2297
                    @bishop9191 sagte in [SourceAnalytix 0.4.8-Final] Released !:
                    das sieht gar nicht gesund aus.
                    Ro75.
                    • Ro75R Ro75
                      Ro75.
                      #2298
                      @ro75 sagte in [SourceAnalytix 0.4.8-Final] Released !:
                      Aber nicht nur an der Stelle. Der Patient hat auch noch andere Baustellen.
                      Ich würde da gleich was aktuelles sauber neuausrollen.
                        bishop9191
                        schrieb am zuletzt editiert von bishop9191
                        #2299
                        Script v.2025-03-08
                        *** BASE SYSTEM ***
                         Static hostname: ioBroker
                               Icon name: computer-container
                                 Chassis: container ☐
                          Virtualization: lxc
                                  Kernel: Linux 5.15.158-2-pve
                            Architecture: x86-64
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                         18:02:25 up 18:30,  3 users,  load average: 0.54, 0.52, 0.82
                        CPU threads: 2
                        Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                                       Local time: Wed 2025-07-23 18:02:26 CEST
                                   Universal time: Wed 2025-07-23 16:02:26 UTC
                                         RTC time: n/a
                                      NTP service: inactive
                                  RTC in local TZ: no
                        steven
                        HOME=/home/steven
                        GROUPS=steven sudo users iobroker
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            4.3G        2.4G        1.3G        131K        658M        1.9G
                        Swap:           536M          0B        536M
                        Total:          4.8G        2.4G        1.8G
                        Active iob-Instances:   31
                                 4096 M total memory
                                 2241 M used memory
                                  337 M active memory
                                 2384 M inactive memory
                                 1226 M free memory
                                    0 M buffer memory
                                  627 M swap cache
                                  512 M total swap
                                    0 M used swap
                                  512 M free swap
                        top - 18:02:26 up 18:30,  3 users,  load average: 0.54, 0.52, 0.82
                        Tasks:  61 total,   1 running,  60 sleeping,   0 stopped,   0 zombie
                        MiB Mem :   4096.0 total,   1224.9 free,   2243.2 used,    627.9 buff/cache
                        MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1852.8 avail Mem
                        0 loaded units listed.
                        *** FILESYSTEM ***
                        /dev/mapper/pve-vm--104--disk--1 ext4    16G  3.5G   12G  24% /
                        tmpfs                            tmpfs  3.2G  124K  3.2G   1% /run
                        tmpfs                            tmpfs  1.6G     0  1.6G   0% /run/user/1000
                        [Sat Jul 19 23:57:00 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                        [Sun Jul 20 00:06:41 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                        [Sun Jul 20 00:06:41 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                        [Sun Jul 20 00:10:52 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                        [Sun Jul 20 00:10:52 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                        [Sun Jul 20 00:11:59 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                        [Sun Jul 20 00:11:59 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                        [Sun Jul 20 01:05:11 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                        [Sun Jul 20 01:05:11 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                        [Sun Jul 20 01:08:00 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                        [Sun Jul 20 01:08:00 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                        [Sun Jul 20 21:28:03 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                        [Sun Jul 20 21:55:29 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                        [Sun Jul 20 22:52:02 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                        [Sun Jul 20 23:01:04 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                        [Sun Jul 20 23:01:36 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                        [Sun Jul 20 23:30:30 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                        [Sun Jul 20 23:30:52 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                        [Sun Jul 20 23:49:35 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                        [Sun Jul 20 23:49:35 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                        [Mon Jul 21 23:05:30 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                        [Mon Jul 21 23:09:32 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                        [Mon Jul 21 23:12:32 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                        [Tue Jul 22 21:32:51 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                        [Tue Jul 22 22:23:09 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                        [Tue Jul 22 22:32:42 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                        [Tue Jul 22 23:36:43 2025] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                        [Tue Jul 22 23:37:30 2025] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                        [Tue Jul 22 23:48:30 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                        [Tue Jul 22 23:48:30 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                        /      /dev/mapper/pve-vm--104--disk--1 ext4   rw,relatime,stripe=16
                        /var:
                        407M    /var/
                        219M    /var/cache
                        215M    /var/cache/apt
                        147M    /var/lib
                        139M    /var/cache/apt/archives
                        Archived and active journals take up 16.0M in the file system.
                        6.9M    /opt/iobroker/backups/
                        327M    /opt/iobroker/iobroker-data/
                        247M    /opt/iobroker/iobroker-data/files
                        25M     /opt/iobroker/iobroker-data/objects.jsonl
                        21M     /opt/iobroker/iobroker-data/states.jsonl
                        USB-Devices by-id:
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/nodejs         v20.19.4
                        /usr/bin/node           v20.19.4
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        /usr/bin/corepack       0.32.0
                        nodejs:
                          Installed: 20.19.4-1nodesource1
                          Version table:
                         *** 20.19.4-1nodesource1 600
                             18.19.0+dfsg-6~deb12u2 500
                                500 http://deb.debian.org/debian bookworm/main amd64 Packages
                             18.19.0+dfsg-6~deb12u1 500
                                500 http://security.debian.org bookworm-security/main amd64 Packages
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 66604)
                        admin:          7.6.17
                        javascript:     8.9.2
                        Adapter State
                          system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
                        + instance is alive
                        Adapter    "socketio"     : 6.7.1    , installed 7.0.8
                        Adapter    "ws"           : 2.6.2    , installed 3.0.19
                        Objects and States
                        Objects:        21330
                        States:         18700
                        Hit:1 http://security.debian.org bookworm-security InRelease
                        Hit:2 http://deb.debian.org/debian bookworm InRelease
                        Pending Updates: 0
                        tcp        0      0 192.168.178.31:2001     0.0.0.0:*               LISTEN      1001       914893137  737/io.hm-rpc.1
                        tcp        0      0 192.168.178.31:2010     0.0.0.0:*               LISTEN      1001       917882617  3279/io.hm-rpc.0
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          914886797  1/init
                        tcp        0      0 192.168.178.31:8084     0.0.0.0:*               LISTEN      1001       914897248  1202/io.ws.0
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       914891678  837/io.shelly.0
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          914887169  291/master
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       914887805  125/iobroker.js-con
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       914887312  125/iobroker.js-con
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          914887170  291/master
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       914887662  419/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       914903136  1235/io.web.0
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          914886803  1/init
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          914884445  1/init
                        tcp6       0      0 :::8554                 :::*                    LISTEN      1001       914903160  1262/go2rtc
                        tcp6       0      0 :::8555                 :::*                    LISTEN      1001       914903163  1262/go2rtc
                        tcp6       0      0 :::1984                 :::*                    LISTEN      1001       914903168  1262/go2rtc
                        tcp6       0      0 :::20002                :::*                    LISTEN      1001       914903133  1228/io.web.1
                        udp        0      0 0.0.0.0:56374           0.0.0.0:*                           1001       914900410  1217/io.eusec.0
                        udp        0      0 0.0.0.0:56523           0.0.0.0:*                           1001       916315494  1217/io.eusec.0
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          914886800  1/init
                        udp        0      0 0.0.0.0:60675           0.0.0.0:*                           1001       914900419  1217/io.eusec.0
                        udp        0      0 0.0.0.0:36146           0.0.0.0:*                           1001       914903173  1217/io.eusec.0
                        udp        0      0 192.168.178.31:5353     0.0.0.0:*                           1001       914894872  863/io.tr-064.0
                        udp6       0      0 :::111                  :::*                                0          914886806  1/init
                        udp6       0      0 :::8555                 :::*                                1001       914903164  1262/go2rtc
                        2025-07-23 18:00:21.772  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.OPERATING_VOLTAGE_STATUS to "Gartenhaus_Temperatur_0.OPERATING_VOLTAGE_STATUS"
                        2025-07-23 18:00:21.775  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.RSSI_DEVICE to "Gartenhaus_Temperatur_0.RSSI_DEVICE"
                        2025-07-23 18:00:21.777  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.OPERATING_VOLTAGE to "Gartenhaus_Temperatur_0.OPERATING_VOLTAGE"
                        2025-07-23 18:00:21.780  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.TEMPERATURE_OUT_OF_RANGE to "Gartenhaus_Temperatur_0.TEMPERATURE_OUT_OF_RANGE"
                        2025-07-23 18:00:21.782  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.RSSI_PEER to "Gartenhaus_Temperatur_0.RSSI_PEER"
                        2025-07-23 18:00:21.784  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.ERROR_CODE to "Gartenhaus_Temperatur_0.ERROR_CODE"
                        2025-07-23 18:00:21.786  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.UPDATE_PENDING to "Gartenhaus_Temperatur_0.UPDATE_PENDING"
                        2025-07-23 18:00:21.788  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.1 to "Gartenhaus_Temperatur_1"
                        2025-07-23 18:00:21.791  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.1.HUMIDITY to "Gartenhaus_Temperatur_1.HUMIDITY"
                        2025-07-23 18:00:21.793  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.1.HUMIDITY_STATUS to "Gartenhaus_Temperatur_1.HUMIDITY_STATUS"
                        2025-07-23 18:00:21.802  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.1.ACTUAL_TEMPERATURE to "Gartenhaus_Temperatur_1.ACTUAL_TEMPERATURE"
                        2025-07-23 18:00:21.805  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.1.ACTUAL_TEMPERATURE_STATUS to "Gartenhaus_Temperatur_1.ACTUAL_TEMPERATURE_STATUS"
                        2025-07-23 18:00:21.807  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.2 to "Gartenhaus_Temperatur_2"
                        2025-07-23 18:00:21.809  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.3 to "Gartenhaus_Temperatur_3"
                        2025-07-23 18:00:51.014  - info: host.ioBroker instance system.adapter.daswetter.0 in version "3.2.3" started with pid 3294
                        2025-07-23 18:00:51.919  - info: daswetter.0 (3294) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.19.4, js-controller: 7.0.6
                        2025-07-23 18:00:55.829  - info: daswetter.0 (3294) still wrong data structure from server received! repaired...
                        2025-07-23 18:00:56.765  - info: daswetter.0 (3294) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                        2025-07-23 18:00:57.271  - info: daswetter.0 (3294) cleaned everything up...
                        2025-07-23 18:00:57.280  - info: host.ioBroker instance system.adapter.daswetter.0 having pid 3294 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2025-07-23 18:01:09.763  - info: sql.0 (500) enabled logging of Gartenhaus_Temperatur, Alias=true, WriteNulls=true
                        2025-07-23 18:01:10.365  - info: sql.0 (500) changed history configuration to pin detected datatype for Gartenhaus_Temperatur
                        2025-07-23 18:01:28.788  - info: sql.0 (500) enabled logging of Gartenhaus_Luftfeuchtigkeit, Alias=true, WriteNulls=true
                        2025-07-23 18:01:28.851  - info: sql.0 (500) changed history configuration to pin detected datatype for Gartenhaus_Luftfeuchtigkeit
                        2025-07-23 18:01:51.265  - info: admin.0 (419) <== Disconnect system.user.admin from ::ffff:192.168.178.13 admin
                        Habe neu aufgesetzt auf Debian 12 und über Backitup die ioBroker Konfig zurückgespielt.
                        Die Fehlermeldungen:
                        sind laut meinen Recherchen "normal", während eines Backupvorgangs in Proxmox. Zumindest habe ich das so im Proxmox Forum gefunden...
                        Das Problem mit SourceAnalytix besteht leider weiterhin 😧
                        • MassiveAttackM Online
                          MassiveAttack
                          schrieb am zuletzt editiert von MassiveAttack
                          #2300
                          Kann mir bitte jemand helfen, diesen Fehler wegzubekommen? Der kommt mittlerweile ~ alle 30 Sekunden und spammt mir das Log voll:
                          sourceanalytix.0
                          	2025-07-24 11:23:34.128	error	Input value for javascript.0.Wetterstation.Regen_Jahr, type = string but should be a number, cannot handle calculation
                          Der Type ist aber mixed bzw. auch number. Nur der Zustand hat Typ string. Wie kann ich das ändern?
                          6d6515d5-456f-4e9b-93e8-4a4d7fdb2a91-1753349201961-a48c6706-3dc6-4b79-b029-8765e864bca6-da22c1b4-e01c-4be4-9dae-6eee45755a3a.png
                          • MassiveAttackM MassiveAttack
                            sourceanalytix.0
                            michihorn
                            schrieb am zuletzt editiert von michihorn
                            #2301
                            @massiveattack Ich habe das so gemacht:
                            Ich habe einen Datenpunkt "mqtt.1.logger.GTHRN.Solar.Umwandlung" als Zahl angelegt und diesen dann per Script gefüttert. (Okay, hätte ich besser in userdata gemacht, aber egal)
                            Das Zauberwort heißt "parseFloat", siehe Script. ParseFlot wandet Text in Zahl.
                            Ich habe dann diesen Datenpunkt in SourceAnaytix ausgewertet anstatt des "Orginalen"
                            /*****Solar ErtragNL in Zahl umwandeln*************************
                            * Juli 2025
                            * Adapter:
                            * geä:23.07.25
                            const id_ertrag="mqtt.1.logger.GTHRN.Solar.totalEnergie"
                            const id_umwandlung ="mqtt.1.logger.GTHRN.Solar.Umwandlung"
                            //const id_umwandlung ="0_userdata.0.Giethoorn.Energie.Zählerstände.Umwandlung"
                            on({ id: id_ertrag, change: "any" }, async function (obj) {
                            var zahl = parseFloat(getState(id_ertrag).val)
                            log(zahl)
                            setState(id_umwandlung,zahl)
                            Michael
                            MassiveAttackM 1 Antwort Letzte Antwort
                            • M michihorn
                              * Juli 2025
                              * Adapter:
                              * geä:23.07.25
                              log(zahl)
                              Michael
                              MassiveAttack
                              #2302
                              @michihorn sagte in [SourceAnalytix 0.4.8-Final] Released !:
                              * Juli 2025
                              * Adapter:
                              * geä:23.07.25
                              log(zahl)
                              Michael
                              Danke, werde ich mal bei Gelegenheit testen.
                              Aber was ist das eigentliche Problem? Kann der Typ nicht mehr geändert werden?
                              • nik82N Offline
                                nik82N Offline
                                nik82
                                schrieb am zuletzt editiert von nik82
                                #2303
                                ich bekomme immer mal wieder diesen Fehler im Log, grundsätzlich funktioniert der Datenpunkt aber.
                                Was bedeutet das:
                                2025-12-18 18:09:13.846 - error: sourceanalytix.0 (1003) [calculationHandler] reading incorrect after conversion contact DEV and provide these info | Reading : null | start reading {"val":null,"ack":false,"ts":1766077753837,"q":0,"c":"script.js.common.Autos.SourceAnalytix","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1766077753837} | stateDetails {"alias":"Auto_Nik_Kilometer","consumption":true,"costs":true,"deviceName":"0_userdata__0__Auto__Auto_Nik_Kilometer","financialCategory":"costs","headCategory":"consumed","meter_values":true,"name":"Auto_Nik_Kilometer","stateType":"Benzin","stateUnit":"kWh","useUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1}
                                Ich habe das immer nur bei dem Datenpunkt ab und zu.
                                Danke im Voraus.
                                P.S. Ich glaub ich habs selber gefunden, ab und zu wird hier keine Zahl übertragen, glaube ich zumindest :-)
                                • nik82N nik82
                                  Was bedeutet das:
                                  Danke im Voraus.
                                  crunchipC Offline
                                  crunchipC Offline
                                  #2304
                                  @nik82 sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                  Der Fehler im SourceAnalytix-Adapter tritt auf, weil der aktuelle Zählerwert (Reading) nach der Einheitenkonvertierung null ist, was die Berechnung blockiert. Dies geschieht typischerweise bei ungültigen Eingabewerten, falscher Einheit oder Initialisierungsproblemen beim State
