  4. Tester für Zigbee Adapter 2.0.x gesucht
zigbee 2.0.1
529 Beiträge 51 Kommentatoren 147.5k Aufrufe 41 Beobachtet
  • KafflerK Kaffler
    @asgothian Moin und danke für die Hilfe.
    Scan wurde mit Error abgebrochen.
    Festgestellt das Firmware alt war mit 6.x.x. update auf 7.4.4 durchgeführt.
    Adaptereinstellungen IOB angepasst.
    SL EFR32 (EMBER)
    Quelle Firmwareupdate
    3f8f3871-d145-4eb8-aa78-561c4a8d21d8-image.png ncp-uart-sw_EZNet7.4.4_V1.0.0 (1)
    Neustart des System.
    Adapter Gestartet (alles Grün)
    Meldung System IOB
    zigbee.0	2025-05-30 10:49:10.426	warn	ELEVATED:I02 (8117) value generated '10' from device 00124b00292843c9 for 'Link quality'
    zigbee.0	2025-05-30 10:49:10.426	warn	ELEVATED:I01 (8117) message received '{"linkquality":10}' from device 00124b00292843c9 type 'SNZB-02'
    zigbee.0	2025-05-30 10:49:10.425	warn	ELEVATED:I02 (8117) value generated 'true' from device 00124b00292843c9 for 'Available'
    zigbee.0	2025-05-30 10:49:10.424	warn	ELEVATED:I01 (8117) message received '{"available":true}' from device 00124b00292843c9 type 'SNZB-02'
    zigbee.0	2025-05-30 10:49:09.458	info	debug devices set to ["00124b00292843c9"]
    zigbee.0	2025-05-30 10:49:09.428	info	Zigbee started
    zigbee.0	2025-05-30 10:49:09.425	info	Currently 1 devices are joined:
    zigbee.0	2025-05-30 10:49:09.424	info	0x00124b00292843c9 (addr 39685): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
    zigbee.0	2025-05-30 10:49:09.353	info	Unable to disable LED, unsupported function.
    zigbee.0	2025-05-30 10:49:09.350	info	Zigbee-Herdsman started successfully with Coordinator firmware version: {"type":"EmberZNet","meta":{"ezsp":13,"revision":"7.4.4 [GA]","build":0,"major":7,"minor":4,"patch":4,"special":0,"type":170}}
    zigbee.0	2025-05-30 10:49:07.347	info	Starting Zigbee-Herdsman
    zigbee.0	2025-05-30 10:49:07.345	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
    zigbee.0	2025-05-30 10:49:07.285	info	Starting Adapter npm ...
    zigbee.0	2025-05-30 10:49:07.283	info	--- creating device debug ---
    zigbee.0	2025-05-30 10:49:07.277	info	delete old Backup files. keep only last 10
    zigbee.0	2025-05-30 10:49:07.262	info	--> transmitPower : normal
    zigbee.0	2025-05-30 10:49:07.252	info	init localConfig
    zigbee.0	2025-05-30 10:49:07.223	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
    Reconfig
    zigbee.0	2025-05-30 10:56:05.460	info	DeviceConfigure successful 0x00124b00292843c9 SNZB-02
    zigbee.0	2025-05-30 10:56:00.622	info	Configuring 0x00124b00292843c9 SNZB-02
    zigbee.0	2025-05-30 10:55:46.758	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"06e595039338ef118eed357af3d9b1e5","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_06e595039338ef118eed357af3d9b1e5-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"}]
    Sensor keine Veränderung auch nach Reconfig
    DEIN VORSCHLAG SCANNEN DER NW
    Also das ist bei beiden Installationen.
    Scan startet und bricht mit Error Popup ab.
    Fehlermeldung IOBroker
    zigbee.0	2025-05-30 11:01:26.503	error	Failed to scan channels Error: {"target":0,"apsFrame":{"profileId":0,"clusterId":56,"sourceEndpoint":0,"destinationEndpoint":0,"options":4416,"groupId":0,"sequence":58},"zdoResponseClusterId":32824} timed out after 15000ms at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/ember/adapter/oneWaitress.js:133:23) at EmberOneWaitress.startWaitingFor (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/ember/adapter/oneWaitress.js:152:47) at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/ember/adapter/emberAdapter.js:1346:51 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/queue.js:29:20) at async EmberAdapter.sendZdo (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/ember/adapter/emberAdapter.js:1307:16) at async ZigbeeController.getChannelsEnergy (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:1186:32) at async Commands.getChannels (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:568:28)
    zigbee.0	2025-05-30 11:01:09.637	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"06e595039338ef118eed357af3d9b1e5","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_06e595039338ef118eed357af3d9b1e5-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"}]
    dimaiv
    #493
    @kaffler
    Dein Zigbee Dongle kann die Kanäle gar nicht scannen, unterstützt es nicht. Das können nur die CC.
    ioBroker- NUC8i3 / Proxmox / VM
    Node.js v22.21.0
    NPM v10.9.4
    JS controller 7.1.0
    Admin 7.7.20
    ZigBee Adapter 3.3.1alpha.0
    Zigbee LAN Gateway CC2652P
    Zigbee Firmware 20250321
    • D dimaiv
      @kaffler
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      #494
      @dimaiv sagte in Tester für Zigbee Adapter 2.0.x gesucht:
      Das ist schade - war mir nicht klar, da ich keine EZSP Firmware Koordinatoren habe.
      @kaffler Das macht die Analyse komplizierter. Ich gehe aktuell davon aus das der gewählte Kanal so stark frequentiert ist das die Meldungen untergehen. Zigbee arbeitet mit vergleichsweise geringen Sende- und Empfangsleistungen. Damit ist es durchaus anfällig dafür das Meldungen durch stärkere Sender 'überstimmt' werden. Deswegen auch der Wunsch nach dem Kanal-Scan. da kann man dann sehen welche Kanäle wie 'voll' sind.
      Leider ist nicht nur WLan als Konkurrenz im 2.4 GHz Netz präsent. Auch ist nicht nur das eigene WLan, sondern auch die der Nachbarn ggf. zu berücksichtigen. Mögliche Störquellen sind:
      • 2.4 GHz WLan
      • Bluetooth
      • freie herstellerspezifische 2.4 GHz Sender/Empfänger paare (Steckdosenfernbedienungen, Funk-Kopfhörer, Funk-Tastaturen / Mäuse, etc.)
      • USB3 Geräte. (durch schlechte Kabel / Hardware-Implementierung kann bei der Kommunikation bei USB3 stark im 2.4 GHz Bereich gestreut werden - stark genug um sogar WLan zu übersteuern.
      Da insbesondere die Meldungen von Sensoren als 'fire and forget' gesandt werden gehen diese gerne mal unter.
      A.
      KafflerK 1 Antwort Letzte Antwort
      • GaspodeG Offline
        GaspodeG Offline
        Gaspode
        schrieb am zuletzt editiert von Gaspode
        #495
        nach Update auf Zigbee Adapter 2.0.5 funktioniert der Sensor nicht mehr, Fehlermeldung im Adapter:
        Woran kann das liegen?
        @arteck Muss man bei der neuen Adapter Version etwas beachten?
        Edit: hier gibt es noch weitere Fragen zum Zigbee Adapter 2.x: https://forum.iobroker.net/post/1275544
        Edit nach Verschiebung: Es geht um dieses Gerät hier: https://forum.iobroker.net/post/606728
        Hatte es dort gepostet, weil ich ursprünglich gehofft hab, dass @dimaiv was dazu sagen kann bzw. schon Anpassungen dazu hat.
        AsgothianA D 2 Antworten Letzte Antwort
        • GaspodeG Gaspode
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          #496
          @gaspode Bitte die Logs vom Start des Adapters durchschauen - da gibt es Meldungen zu den externen Konvertern.
          Es ist denkbar das durch das Update der ZHC Anpassungen an den externen Konvertern notwendig werden. Diese sind erst mit der 3.0.1 in den Adapter gezogen. Sollte das der Fall sein, gibt es 2 Optionen:
          • manuelles anpassen der externen Konverter
          • Update auf die 3.0.1 aus dem Latest. Dann bitte den dazu gehörigen Thread lesen und die Hinweise beachten.
          GaspodeG 1 Antwort Letzte Antwort
          • AsgothianA Asgothian
            GaspodeG Offline
            GaspodeG Offline
            Gaspode
            #497
            @asgothian said in [Verkaufe] Zigbee Bodenfeuchtesensor:
            2025-06-02 17:22:48.523 - info: zigbee.0 (27240) starting. Version 2.0.5 in C:/ioBroker/lonwolf/node_modules/iobroker.zigbee, node: v20.18.2, js-controller: 7.0.6
            2025-06-02 17:22:48.567 - warn: zigbee.0 (27240) trying to add "fz = require(../zigbee-herdsman-converters/converters/fromZigbee)" to sandbox
            2025-06-02 17:22:48.569 - error: zigbee.0 (27240) Sandbox error: Cannot find module '../zigbee-herdsman-converters/converters/fromZigbee'
            Require stack:
            - C:\ioBroker\lonwolf\node_modules\iobroker.zigbee\main.js
            2025-06-02 17:22:48.570 - warn: zigbee.0 (27240) trying to add "tz = require(../zigbee-herdsman-converters/converters/toZigbee)" to sandbox
            2025-06-02 17:22:48.571 - error: zigbee.0 (27240) Sandbox error: Cannot find module '../zigbee-herdsman-converters/converters/toZigbee'
            Require stack:
            2025-06-02 17:22:48.571 - warn: zigbee.0 (27240) trying to add "exposes = require(../zigbee-herdsman-converters/lib/exposes)" to sandbox
            2025-06-02 17:22:48.572 - error: zigbee.0 (27240) Sandbox error: Cannot find module '../zigbee-herdsman-converters/lib/exposes'
            Require stack:
            2025-06-02 17:22:48.573 - warn: zigbee.0 (27240) trying to add "reporting = require(../zigbee-herdsman-converters/lib/reporting)" to sandbox
            2025-06-02 17:22:48.573 - error: zigbee.0 (27240) Sandbox error: Cannot find module '../zigbee-herdsman-converters/lib/reporting'
            Require stack:
            2025-06-02 17:22:48.577 - warn: zigbee.0 (27240) Trying to run sandbox for E:\iobroker\lonwolf\iobroker-data\zigbee_0\Flower_Neu.js
            2025-06-02 17:22:48.590 - error: zigbee.0 (27240) Unable to apply converter from module: E:\iobroker\lonwolf\iobroker-data\zigbee_0\Flower_Neu.js - the code does not run: ReferenceError: exposes is not defined
            Würde ungerne auf Version drei gehen, kannst du mir auf die Sprünge helfen?
            Das ist die Datei für den externen Konverter:
            Flower_Neu.js
            HomoranH AsgothianA 2 Antworten Letzte Antwort
            • GaspodeG Gaspode
              Require stack:
              Require stack:
              Require stack:
              Require stack:
              Flower_Neu.js
              #498
              @gaspode sagte in [Verkaufe] Zigbee Bodenfeuchtesensor:
              warum nicht?
              läuft bei mir schon ewig und stabil.
              ...oder ist das, weil du Windows hast :duckundwech:
              EDIT:
              Hab das mal hierhin geschoben
                warum nicht?
                EDIT:
                GaspodeG Offline
                GaspodeG Offline
                Gaspode
                #499
                @homoran said in [Verkaufe] Zigbee Bodenfeuchtesensor:
                warum nicht?
                Weil ich im Moment keine Zeit habe, mir das alles durch zu lesen, ich will mir nix kaputt machen. An Windows liegt's sicher nicht. ;)
                Ich hab auf den ersten Blick ehrlich gesagt nicht 100%ig verstanden, was ich beim Umstieg auf Version 3 alles tun muss. Ich hab keinen blassen Schimmer von der Zigbee Funktionsweise, ich bin da nur doofer Anwender.
                  AlexHaxe
                  #500
                  @gaspode said in Tester für Zigbee Adapter 2.0.x gesucht:
                  Der Umstieg von iobroker.zigbee 1.x auf 2.x ist der "böse" Sprung, danach müssen gfs. Skripte und Datenpunkte umkonfiguriert / nachgezogen werden. Der Sprung von 2.x auf 3.x ist da wesentlich schmerzfreier, beachten muss man einzig den Haken in den Adapter-Einstellungen, den man jetzt nach dem Upgrade einmalig setzen muss.
                  • GaspodeG Gaspode
                    Require stack:
                    Require stack:
                    Require stack:
                    Require stack:
                    Flower_Neu.js
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    #501
                    @gaspode Schau mal bitte nach wo sich die Dateien /lib/reporting.js und, converters/toZigbee.js und converters/toZigbee.js auf deinem System befinden. Da muss im Pfad meines Wissens irgendwo ein /dist eingeschoben werden damit es geht.
                    Wichtig - diese Anpassung muss nach dem Update auf 3.0.x wieder entfernt werden.
                    A.
                      A.
                      GaspodeG Offline
                      GaspodeG Offline
                      Gaspode
                      #502
                      OK, überzeugt. 😊 Danke euch. Ich versuche es dann morgen mit Version 3. Bin jetzt unterwegs.
                      Das Häkchen hatte mich in der Beschreibung irritiert, das las sich für mich so, wie ein Workaround, den man normalerweise nicht verwendet. Heute ist irgendwie nicht mein Tag. Sonst bin ich eigentlich nicht so schwer von Begriff.
                      • GaspodeG Gaspode
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        #503
                        @gaspode sagte in Tester für Zigbee Adapter 2.0.x gesucht:
                        Da kann ich was zu Scheiben:
                        Ab Adapter 2.0.0 gab es immer wieder Probleme bei einer Neuinstallatopn des Adapters. Beim ersten Start wo das zigbee subsystem aktiviert wird werden Backup Daten geschrieben. Wenn in der Folge die parametrierung geändert wird mussten diese teilweise von Hand entfernt werden - was immer wieder zu Problemen geführt hat,
                        Was dem Adapter gefehlt hat ist eine Mögkichkeit das vom UI aus zu steuern. Beim Aufbau dieser Möglichkeit fiel auf das es am besten ist wenn das zigbee Netzwerk nicht automatisch gestartet wird bis die Konfiguration erfolgreich abgeschlossen und getestet ist.
                        Bei späteren Starts soll danach das zigbee subsystem automatisch durchgestartet werden.
                        Das hätte durch einen anderen Workflow auch abgebildet würden können - aber das wäre gerade für Neulinge noch komplexer und unhandlicher gewesen. Deswegen die Entscheidung für den Haken, der bei ‚alten‘ Installationen einmal gesetzt werden muss.
                        A.
                          A.
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          #504
                          @asgothian
                          Will nicht ätzen oder kritisieren. Und da mittlerweile 3.x.x existiert ist es wahrscheinlich eh schon zu spät. Wenn was super toll funktioniert kommen dann halt immer noch die "Vergoldungswünsche". Bitte nicht bös nehmen - Adapter ist super toll!
                          Hier nur eine Anregung für die Zukunft oder ähnliche Fälle:
                          Man kann bei der Adapterinstallation auch ein Script ausführen und dort erkennen ob schon eine (ältere) Installation vorliegt. Damit hätte man bei Upgrade von 1.x.x auf 2.x.x das Hakerl automatisch setzen können.
                          Ist bei einem Hackerl kein großes Ding. Aber für andere Migrationen ev. von Interesse.
                          Und für den IST Stand ev. zum Andenken:
                          Ev. würde eine Warning im Log sinnvoll sein, so in der Art:
                          Warning: Subsystem not yet started. If you configuration has been completed, please check xxxx box at configuration UI to start subsystem automatically.
                          Zumindest User die ins Log schaun (und das sind sicher nicht alle :-) hätte da nen Hinweis.
                          Support Repositoryverwaltung.
                          LESEN - gute Forenbeitrage
                          GaspodeG AsgothianA 2 Antworten Letzte Antwort
                          • mcm1957M mcm1957
                            @asgothian
                            GaspodeG Offline
                            GaspodeG Offline
                            Gaspode
                            #505
                            @mcm1957 said in Tester für Zigbee Adapter 2.0.x gesucht:
                            Der Haken kommt ja erst mit Version 3. Ich hab ehrlich gesagt noch nicht ganz verstanden, wann es sinnvoll ist, den Haken zunächst nicht zu setzen. Wenn das wirklich immer nur eine Neuinstallation des Adapters beträfe, wäre das bestimmt eine gute Sache, dass die Upgrader nicht davon behelligt werden.
                            • mcm1957M mcm1957
                              @asgothian
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              #506
                              @mcm1957 sagte in Tester für Zigbee Adapter 2.0.x gesucht:
                              @asgothian
                              [...snip]
                              Keine Sorge - ich nehm das als Anregung und Vorschlag zur Verbesserung. Und bin Dankbar dafür.
                              Aktuell gibt es (in aktuellen Github Version) die folgende Meldung wenn der Adapter gestartet wird ohne das der Haken da ist:
                              Zigbee autostart option not set - omitting start of zigbee substystem!
                              Bestehende Installationen die vor dem Update gelaufen sind sollten den Haken immer setzen. Einfach betrachtet wäre ein Skript also eine interessante option, aber
                              1. Leider gehen viele Nutzer wenig 'systematisch' vor wenn etwas nicht sofort geht - da wird dieses und jenes neu installiert / über installiert / krumm gedreht. Mal von NPM, mal von Github, mal eine ältere Version. Ich hab im Forum an vielen Stellen mehr Probleme damit die komischen Lösungsversuche von Nutzern gerade zu biegen als das eigentlich ursächliche Problem zu lösen.
                              Könnte ich das alles in einem Skript sauber abfangen - vielleicht.
                              Ist es das für diesen einfachen Fall wert - in meinen Augen nicht. Einmal in die Einstellungen zu gehen und den Haken zu setzen ist jetzt nicht wirklich zuviel verlangt.
                              1. Dadurch das die Nutzer in die Konfiguration gehen werden sie gleich noch mit einer weiteren Eigenschaft der 3.x konfrontiert - einer Verifikation von Zigbee-Einstellungen und den vom Koordinator gesicherten Einstellungen. Passen die nicht übereinander wird das angezeigt. Zusätzlich bekommen alle die noch die unsäglichen 16D ExtPanID nutzen nochmal einen Hinweis darauf das das vielleicht nicht gut ist.
                              Über die Einstellungen lassen sich dann für die Nutzer halbwegs komfortabel auch Auffälligkeiten beheben, wie z.Bsp. die "Unart" einfach den Adapter mit dem Haken bei Screenshot 2025-06-04 at 13.34.30.png laufen zu lassen.
                              Dieses ist gewünscht - zumindest von mir :)
                              A.
                              GaspodeG Thomas BraunT mcm1957M 3 Antworten Letzte Antwort
                                @asgothian
                                [...snip]
                                A.
                                GaspodeG Offline
                                GaspodeG Offline
                                Gaspode
                                #507
                                @asgothian said in Tester für Zigbee Adapter 2.0.x gesucht:
                                Guter Punkt. :D
                                Finde ich persönlich auch absolut ausreichend. 👍
                                  @asgothian
                                  [...snip]
                                  A.
                                  #508
                                  @asgothian sagte in Tester für Zigbee Adapter 2.0.x gesucht:
                                  Vielleicht kannst du für die ganz Unkreativen auch einen Link zu einem Hex-Generator verlinken?
                                  Ich lass mich da nämlich auch ganz gerne von solchen Diensten 'beraten'.
                                    @asgothian
                                    [...snip]
                                    A.
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    #509
                                    @asgothian
                                    Alles klar und für mich OK. DU entscheidest als dev was du für sinnvoll haltest.
                                    Und wenn es dir was hilft um schräge Installationen zu minimieren: Eine Installation von Github kannst du blocken. Damit zwingst du user zumindest eine (ggF Alpha) von npm zu installieren. Die mag zwar auch defekt sein aber wenigsten in sich ein definierter Zustand. (https://github.com/ioBroker/ioBroker.js-controller/blob/6ade4045339082a9408e17e0871ad26dc41206ca/schemas/io-package.json#L1371)
                                    Muss aber jeder dev selbst entscheiden was hilfreicher ist.
                                    • GaspodeG Gaspode
                                      dimaiv
                                      #510
                                      @gaspode
                                      Hier, im Thread, gibt's sogar die Lösung für dein Problem, aber, wenn man kein Zeit für Lesen hat...
                                      Lösung
                                      Node.js v22.21.0
                                      NPM v10.9.4
                                      JS controller 7.1.0
                                      Admin 7.7.20
                                      • D dimaiv
                                        @gaspode
                                        Lösung
                                        GaspodeG Offline
                                        GaspodeG Offline
                                        Gaspode
                                        #511
                                        @dimaiv said in Tester für Zigbee Adapter 2.0.x gesucht:
                                        @gaspode
                                        Lösung
                                        Mein Problem ist mit V 3 des Adapters ja gelöst. Ist halt nicht einfach, in einem Thread mit über 500 Beiträgen die Übersicht zu behalten. Also sehe es mir bitte nach, dass ich die Lösung übersehen habe.
                                        Edit:
                                        So, jetzt wieder daheim und nicht mehr nur am Handy.
                                        Nochmal zur Erklärung: Ich hatte ja eigentlich direkt in deinem Thread gepostet, weil ich diesen Thread hier nicht gefunden hatte. @Homoran war dann so nett, den Teil hierher zu verschieben, wodurch es jetzt aussieht, als hätte ich direkt hier gefragt.
                                        Konstruktiver Vorschlag: Willst du in deinem Eingangspost deines Threads einen kurzen Hinweis schreiben, was bei Umstieg auf den Zigbee Adapter 2 zu beachten ist und dass man die Anpassung im Adapter Version 3 gar nicht mehr braucht? Damit würdest du den Käufern deines Feuchtesensors bestimmt viel Sucherei ersparen, nicht jeder findet zielgenau den richtigen Tipp im Tester Thread. Ich war zumindest zu blind dafür.
                                        • GaspodeG Gaspode
                                          @gaspode
                                          Lösung
                                          Edit:
                                          dimaiv
                                          #512
                                          @gaspode
                                          Mit aktuelle Zigbee Adapter Version , also, 3.0.1 läuft alles gut wie gewohnt.
                                          Mein einziger Vorschlag wäre, so schnell wie es geht, Zigbee Adapter auf die Version 3.x.x updaten.
                                          Node.js v22.21.0
                                          NPM v10.9.4
                                          JS controller 7.1.0
                                          Admin 7.7.20
