  4. Tester für Zigbee Adapter 2.0.x gesucht
zigbee 2.0.1
529 Beiträge 51 Kommentatoren 147.5k Aufrufe 41 Beobachtet
  • KafflerK Kaffler
    @asgothian so hatte mal Zeit:
    habe folgendes aufgebaut:
    -Reserve PI aufgesetzt. (Pi OS Legacy 64-bit lite)
    -neuer SONOFF Zigbee Gateway, ZBDongle-E 3.0 USB Dongle Plus mit 3m USB-Verlängerung Sensor 30 cm daneben.
    • Iobroker nur Zigbee-Adapter
    Das verhalten ist das Gleiche wie auf dem anderen PI, somit schließe ich das System aus.
    Konfiguration zum Testen.
    Log von dem Pairing eines Adapter
    zigbee.0	2025-05-29 21:01:07.199	info	Closing Zigbee network, 1 seconds remaining
    zigbee.0	2025-05-29 21:00:32.637	info	Device '0x00124b00292843c9' is supported, identified as: SONOFF Temperature and humidity sensor (SNZB-02)
    zigbee.0	2025-05-29 21:00:32.637	info	Successfully interviewed '0x00124b00292843c9', device has successfully been paired
    zigbee.0	2025-05-29 21:00:27.934	info	debug devices set to []
    zigbee.0	2025-05-29 21:00:27.919	warn	Device 0x00124b00292843c9 "SNZB-02" not found.
    zigbee.0	2025-05-29 21:00:16.737	info	Starting interview of '0x00124b00292843c9'
    zigbee.0	2025-05-29 21:00:07.200	info	Opening zigbee Network for 60 seconds
    zigbee.0	2025-05-29 20:59:46.816	info	Zigbee started
    zigbee.0	2025-05-29 20:59:46.813	info	Currently no devices.
    zigbee.0	2025-05-29 20:59:46.811	info	Unable to disable LED, unsupported function.
    zigbee.0	2025-05-29 20:59:46.809	info	Zigbee-Herdsman started successfully with Coordinator firmware version: {"type":"EZSP v8","meta":{"product":8,"majorrel":"6","minorrel":"10","maintrel":"3 ","revision":"6.10.3.0 build 297"}}
    zigbee.0	2025-05-29 20:59:41.835	info	Starting Zigbee-Herdsman
    zigbee.0	2025-05-29 20:59:41.833	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
    zigbee.0	2025-05-29 20:59:41.783	info	Starting Adapter npm ...
    zigbee.0	2025-05-29 20:59:41.782	info	--- creating device debug ---
    zigbee.0	2025-05-29 20:59:41.766	info	--> transmitPower : normal
    zigbee.0	2025-05-29 20:59:41.758	info	init localConfig
    zigbee.0	2025-05-29 20:59:41.728	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
    Gerät wurde angelegt
    Reconfig durchgeführt
    zigbee.0	2025-05-29 21:06:21.463	info	DeviceConfigure successful 0x00124b00292843c9 SNZB-02
    zigbee.0	2025-05-29 21:06:11.425	info	Configuring 0x00124b00292843c9 SNZB-02
    zigbee.0	2025-05-29 21:04:58.529	info	debug devices set to ["00124b00292843c9"]
    zigbee.0	2025-05-29 21:04:53.718	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"06e595039338ef118eed357af3d9b1e5","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_06e595039338ef118eed357af3d9b1e5-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"}]
    Log vom andereren System aus dem Zigbee Adapter
    c04	{"type":"attributeReport", "data":{"batteryPercentageRemaining":178}, "linkquality":255, "groupID":0, "cluster":"genPowerCfg", "meta":{"zclTransactionSequenceNumber":12, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":1}		{"battery":89}	battery	89	SUCCESS
    {"linkquality":255}	link_quality	255	SUCCESS
    1f80	{"type":"attributeReport", "data":{"batteryPercentageRemaining":177}, "linkquality":255, "groupID":0, "cluster":"genPowerCfg", "meta":{"zclTransactionSequenceNumber":11, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":1}		{"battery":88.5}	battery	88.5	SUCCESS
    9308	{"type":"attributeReport", "data":{"batteryPercentageRemaining":176}, "linkquality":255, "groupID":0, "cluster":"genPowerCfg", "meta":{"zclTransactionSequenceNumber":10, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":1}		{"battery":88}	battery	88	SUCCESS
    abd3	{"type":"attributeReport", "data":{"batteryPercentageRemaining":176}, "linkquality":255, "groupID":0, "cluster":"genPowerCfg", "meta":{"zclTransactionSequenceNumber":9, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":1}		{"battery":88}	battery	88	SUCCESS
    c321	{"type":"attributeReport", "data":{"batteryPercentageRemaining":176}, "linkquality":255, "groupID":0, "cluster":"genPowerCfg", "meta":{"zclTransactionSequenceNumber":8, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":1}		{"battery":88}	battery	88	SUCCESS
    9413	{"type":"attributeReport", "data":{"batteryPercentageRemaining":177}, "linkquality":255, "groupID":0, "cluster":"genPowerCfg", "meta":{"zclTransactionSequenceNumber":7, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":1}		{"battery":88.5}	battery	88.5	SUCCESS
    abae	{"type":"attributeReport", "data":{"batteryPercentageRemaining":177}, "linkquality":255, "groupID":0, "cluster":"genPowerCfg", "meta":{"zclTransactionSequenceNumber":6, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":1}		{"battery":88.5}	battery	88.5	SUCCESS
    f162	{"type":"attributeReport", "data":{"batteryPercentageRemaining":175}, "linkquality":255, "groupID":0, "cluster":"genPowerCfg", "meta":{"zclTransactionSequenceNumber":5, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":1}		{"battery":87.5}	battery	87.5	SUCCESS
    7d1f	{"type":"attributeReport", "data":{"batteryPercentageRemaining":174}, "linkquality":255, "groupID":0, "cluster":"genPowerCfg", "meta":{"zclTransactionSequenceNumber":4, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":1}		{"battery":87}	battery	87	SUCCESS
    955e	{"type":"attributeReport", "data":{"batteryPercentageRemaining":174}, "linkquality":255, "groupID":0, "cluster":"genPowerCfg", "meta":{"zclTransactionSequenceNumber":3, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":1}		{"battery":87}	battery	87	SUCCESS
    0953	{"type":"attributeReport", "data":{"batteryPercentageRemaining":173}, "linkquality":255, "groupID":0, "cluster":"genPowerCfg", "meta":{"zclTransactionSequenceNumber":2, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":1}		{"battery":86.5}	battery	86.5	SUCCESS
    ac80	{"type":"attributeReport", "data":{"batteryPercentageRemaining":129}, "linkquality":255, "groupID":0, "cluster":"genPowerCfg", "meta":{"zclTransactionSequenceNumber":1, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":1}		{"battery":64.5}	battery	64.5	SUCCESS
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #491
    @kaffler zeig mal einen Screenshot vom zigbee Kanalscan.
    A.
    • KafflerK Offline
      KafflerK Offline
      Kaffler
      #492
      @asgothian Moin und danke für die Hilfe.
      Scan wurde mit Error abgebrochen.
      Festgestellt das Firmware alt war mit 6.x.x. update auf 7.4.4 durchgeführt.
      Adaptereinstellungen IOB angepasst.
      SL EFR32 (EMBER)
      Quelle Firmwareupdate
      3f8f3871-d145-4eb8-aa78-561c4a8d21d8-image.png ncp-uart-sw_EZNet7.4.4_V1.0.0 (1)
      Neustart des System.
      Adapter Gestartet (alles Grün)
      Meldung System IOB
      zigbee.0	2025-05-30 10:49:10.426	warn	ELEVATED:I02 (8117) value generated '10' from device 00124b00292843c9 for 'Link quality'
      zigbee.0	2025-05-30 10:49:10.426	warn	ELEVATED:I01 (8117) message received '{"linkquality":10}' from device 00124b00292843c9 type 'SNZB-02'
      zigbee.0	2025-05-30 10:49:10.425	warn	ELEVATED:I02 (8117) value generated 'true' from device 00124b00292843c9 for 'Available'
      zigbee.0	2025-05-30 10:49:10.424	warn	ELEVATED:I01 (8117) message received '{"available":true}' from device 00124b00292843c9 type 'SNZB-02'
      zigbee.0	2025-05-30 10:49:09.458	info	debug devices set to ["00124b00292843c9"]
      zigbee.0	2025-05-30 10:49:09.428	info	Zigbee started
      zigbee.0	2025-05-30 10:49:09.425	info	Currently 1 devices are joined:
      zigbee.0	2025-05-30 10:49:09.424	info	0x00124b00292843c9 (addr 39685): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
      zigbee.0	2025-05-30 10:49:09.353	info	Unable to disable LED, unsupported function.
      zigbee.0	2025-05-30 10:49:09.350	info	Zigbee-Herdsman started successfully with Coordinator firmware version: {"type":"EmberZNet","meta":{"ezsp":13,"revision":"7.4.4 [GA]","build":0,"major":7,"minor":4,"patch":4,"special":0,"type":170}}
      zigbee.0	2025-05-30 10:49:07.347	info	Starting Zigbee-Herdsman
      zigbee.0	2025-05-30 10:49:07.345	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
      zigbee.0	2025-05-30 10:49:07.285	info	Starting Adapter npm ...
      zigbee.0	2025-05-30 10:49:07.283	info	--- creating device debug ---
      zigbee.0	2025-05-30 10:49:07.277	info	delete old Backup files. keep only last 10
      zigbee.0	2025-05-30 10:49:07.262	info	--> transmitPower : normal
      zigbee.0	2025-05-30 10:49:07.252	info	init localConfig
      zigbee.0	2025-05-30 10:49:07.223	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
      Reconfig
      zigbee.0	2025-05-30 10:56:05.460	info	DeviceConfigure successful 0x00124b00292843c9 SNZB-02
      zigbee.0	2025-05-30 10:56:00.622	info	Configuring 0x00124b00292843c9 SNZB-02
      zigbee.0	2025-05-30 10:55:46.758	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"06e595039338ef118eed357af3d9b1e5","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_06e595039338ef118eed357af3d9b1e5-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"}]
      Sensor keine Veränderung auch nach Reconfig
      DEIN VORSCHLAG SCANNEN DER NW
      Also das ist bei beiden Installationen.
      Scan startet und bricht mit Error Popup ab.
      Fehlermeldung IOBroker
      zigbee.0	2025-05-30 11:01:26.503	error	Failed to scan channels Error: {"target":0,"apsFrame":{"profileId":0,"clusterId":56,"sourceEndpoint":0,"destinationEndpoint":0,"options":4416,"groupId":0,"sequence":58},"zdoResponseClusterId":32824} timed out after 15000ms at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/ember/adapter/oneWaitress.js:133:23) at EmberOneWaitress.startWaitingFor (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/ember/adapter/oneWaitress.js:152:47) at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/ember/adapter/emberAdapter.js:1346:51 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/queue.js:29:20) at async EmberAdapter.sendZdo (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/ember/adapter/emberAdapter.js:1307:16) at async ZigbeeController.getChannelsEnergy (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:1186:32) at async Commands.getChannels (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:568:28)
      zigbee.0	2025-05-30 11:01:09.637	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"06e595039338ef118eed357af3d9b1e5","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_06e595039338ef118eed357af3d9b1e5-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"}]
      • KafflerK Kaffler
        SL EFR32 (EMBER)
        Meldung System IOB
        Reconfig
        dimaiv
        #493
        @kaffler
        Dein Zigbee Dongle kann die Kanäle gar nicht scannen, unterstützt es nicht. Das können nur die CC.
        ioBroker- NUC8i3 / Proxmox / VM
        Node.js v22.21.0
        NPM v10.9.4
        JS controller 7.1.0
        Admin 7.7.20
        ZigBee Adapter 3.3.1alpha.0
        Zigbee LAN Gateway CC2652P
        Zigbee Firmware 20250321
        • D dimaiv
          @kaffler
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          #494
          @dimaiv sagte in Tester für Zigbee Adapter 2.0.x gesucht:
          Das ist schade - war mir nicht klar, da ich keine EZSP Firmware Koordinatoren habe.
          @kaffler Das macht die Analyse komplizierter. Ich gehe aktuell davon aus das der gewählte Kanal so stark frequentiert ist das die Meldungen untergehen. Zigbee arbeitet mit vergleichsweise geringen Sende- und Empfangsleistungen. Damit ist es durchaus anfällig dafür das Meldungen durch stärkere Sender 'überstimmt' werden. Deswegen auch der Wunsch nach dem Kanal-Scan. da kann man dann sehen welche Kanäle wie 'voll' sind.
          Leider ist nicht nur WLan als Konkurrenz im 2.4 GHz Netz präsent. Auch ist nicht nur das eigene WLan, sondern auch die der Nachbarn ggf. zu berücksichtigen. Mögliche Störquellen sind:
          • 2.4 GHz WLan
          • Bluetooth
          • freie herstellerspezifische 2.4 GHz Sender/Empfänger paare (Steckdosenfernbedienungen, Funk-Kopfhörer, Funk-Tastaturen / Mäuse, etc.)
          • USB3 Geräte. (durch schlechte Kabel / Hardware-Implementierung kann bei der Kommunikation bei USB3 stark im 2.4 GHz Bereich gestreut werden - stark genug um sogar WLan zu übersteuern.
          Da insbesondere die Meldungen von Sensoren als 'fire and forget' gesandt werden gehen diese gerne mal unter.
          A.
          KafflerK 1 Antwort Letzte Antwort
          • GaspodeG Offline
            GaspodeG Offline
            Gaspode
            schrieb am zuletzt editiert von Gaspode
            #495
            nach Update auf Zigbee Adapter 2.0.5 funktioniert der Sensor nicht mehr, Fehlermeldung im Adapter:
            Woran kann das liegen?
            @arteck Muss man bei der neuen Adapter Version etwas beachten?
            Edit: hier gibt es noch weitere Fragen zum Zigbee Adapter 2.x: https://forum.iobroker.net/post/1275544
            Edit nach Verschiebung: Es geht um dieses Gerät hier: https://forum.iobroker.net/post/606728
            Hatte es dort gepostet, weil ich ursprünglich gehofft hab, dass @dimaiv was dazu sagen kann bzw. schon Anpassungen dazu hat.
            AsgothianA D 2 Antworten Letzte Antwort
            • GaspodeG Gaspode
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #496
              @gaspode Bitte die Logs vom Start des Adapters durchschauen - da gibt es Meldungen zu den externen Konvertern.
              Es ist denkbar das durch das Update der ZHC Anpassungen an den externen Konvertern notwendig werden. Diese sind erst mit der 3.0.1 in den Adapter gezogen. Sollte das der Fall sein, gibt es 2 Optionen:
              • manuelles anpassen der externen Konverter
              • Update auf die 3.0.1 aus dem Latest. Dann bitte den dazu gehörigen Thread lesen und die Hinweise beachten.
              GaspodeG 1 Antwort Letzte Antwort
              • AsgothianA Asgothian
                GaspodeG Offline
                GaspodeG Offline
                Gaspode
                #497
                @asgothian said in [Verkaufe] Zigbee Bodenfeuchtesensor:
                2025-06-02 17:22:48.523 - info: zigbee.0 (27240) starting. Version 2.0.5 in C:/ioBroker/lonwolf/node_modules/iobroker.zigbee, node: v20.18.2, js-controller: 7.0.6
                2025-06-02 17:22:48.567 - warn: zigbee.0 (27240) trying to add "fz = require(../zigbee-herdsman-converters/converters/fromZigbee)" to sandbox
                2025-06-02 17:22:48.569 - error: zigbee.0 (27240) Sandbox error: Cannot find module '../zigbee-herdsman-converters/converters/fromZigbee'
                Require stack:
                - C:\ioBroker\lonwolf\node_modules\iobroker.zigbee\main.js
                2025-06-02 17:22:48.570 - warn: zigbee.0 (27240) trying to add "tz = require(../zigbee-herdsman-converters/converters/toZigbee)" to sandbox
                2025-06-02 17:22:48.571 - error: zigbee.0 (27240) Sandbox error: Cannot find module '../zigbee-herdsman-converters/converters/toZigbee'
                Require stack:
                2025-06-02 17:22:48.571 - warn: zigbee.0 (27240) trying to add "exposes = require(../zigbee-herdsman-converters/lib/exposes)" to sandbox
                2025-06-02 17:22:48.572 - error: zigbee.0 (27240) Sandbox error: Cannot find module '../zigbee-herdsman-converters/lib/exposes'
                Require stack:
                2025-06-02 17:22:48.573 - warn: zigbee.0 (27240) trying to add "reporting = require(../zigbee-herdsman-converters/lib/reporting)" to sandbox
                2025-06-02 17:22:48.573 - error: zigbee.0 (27240) Sandbox error: Cannot find module '../zigbee-herdsman-converters/lib/reporting'
                Require stack:
                2025-06-02 17:22:48.577 - warn: zigbee.0 (27240) Trying to run sandbox for E:\iobroker\lonwolf\iobroker-data\zigbee_0\Flower_Neu.js
                2025-06-02 17:22:48.590 - error: zigbee.0 (27240) Unable to apply converter from module: E:\iobroker\lonwolf\iobroker-data\zigbee_0\Flower_Neu.js - the code does not run: ReferenceError: exposes is not defined
                Würde ungerne auf Version drei gehen, kannst du mir auf die Sprünge helfen?
                Das ist die Datei für den externen Konverter:
                Flower_Neu.js
                HomoranH AsgothianA 2 Antworten Letzte Antwort
                • GaspodeG Gaspode
                  Require stack:
                  Require stack:
                  Require stack:
                  Require stack:
                  Flower_Neu.js
                  #498
                  @gaspode sagte in [Verkaufe] Zigbee Bodenfeuchtesensor:
                  warum nicht?
                  läuft bei mir schon ewig und stabil.
                  ...oder ist das, weil du Windows hast :duckundwech:
                  EDIT:
                  Hab das mal hierhin geschoben
                    warum nicht?
                    EDIT:
                    GaspodeG Offline
                    GaspodeG Offline
                    Gaspode
                    #499
                    @homoran said in [Verkaufe] Zigbee Bodenfeuchtesensor:
                    warum nicht?
                    Weil ich im Moment keine Zeit habe, mir das alles durch zu lesen, ich will mir nix kaputt machen. An Windows liegt's sicher nicht. ;)
                    Ich hab auf den ersten Blick ehrlich gesagt nicht 100%ig verstanden, was ich beim Umstieg auf Version 3 alles tun muss. Ich hab keinen blassen Schimmer von der Zigbee Funktionsweise, ich bin da nur doofer Anwender.
                      AlexHaxe
                      #500
                      @gaspode said in Tester für Zigbee Adapter 2.0.x gesucht:
                      Der Umstieg von iobroker.zigbee 1.x auf 2.x ist der "böse" Sprung, danach müssen gfs. Skripte und Datenpunkte umkonfiguriert / nachgezogen werden. Der Sprung von 2.x auf 3.x ist da wesentlich schmerzfreier, beachten muss man einzig den Haken in den Adapter-Einstellungen, den man jetzt nach dem Upgrade einmalig setzen muss.
                      • GaspodeG Gaspode
                        Require stack:
                        Require stack:
                        Require stack:
                        Require stack:
                        Flower_Neu.js
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        #501
                        @gaspode Schau mal bitte nach wo sich die Dateien /lib/reporting.js und, converters/toZigbee.js und converters/toZigbee.js auf deinem System befinden. Da muss im Pfad meines Wissens irgendwo ein /dist eingeschoben werden damit es geht.
                        Wichtig - diese Anpassung muss nach dem Update auf 3.0.x wieder entfernt werden.
                        A.
                          A.
                          GaspodeG Offline
                          GaspodeG Offline
                          Gaspode
                          #502
                          OK, überzeugt. 😊 Danke euch. Ich versuche es dann morgen mit Version 3. Bin jetzt unterwegs.
                          Das Häkchen hatte mich in der Beschreibung irritiert, das las sich für mich so, wie ein Workaround, den man normalerweise nicht verwendet. Heute ist irgendwie nicht mein Tag. Sonst bin ich eigentlich nicht so schwer von Begriff.
                          • GaspodeG Gaspode
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            #503
                            @gaspode sagte in Tester für Zigbee Adapter 2.0.x gesucht:
                            Da kann ich was zu Scheiben:
                            Ab Adapter 2.0.0 gab es immer wieder Probleme bei einer Neuinstallatopn des Adapters. Beim ersten Start wo das zigbee subsystem aktiviert wird werden Backup Daten geschrieben. Wenn in der Folge die parametrierung geändert wird mussten diese teilweise von Hand entfernt werden - was immer wieder zu Problemen geführt hat,
                            Was dem Adapter gefehlt hat ist eine Mögkichkeit das vom UI aus zu steuern. Beim Aufbau dieser Möglichkeit fiel auf das es am besten ist wenn das zigbee Netzwerk nicht automatisch gestartet wird bis die Konfiguration erfolgreich abgeschlossen und getestet ist.
                            Bei späteren Starts soll danach das zigbee subsystem automatisch durchgestartet werden.
                            Das hätte durch einen anderen Workflow auch abgebildet würden können - aber das wäre gerade für Neulinge noch komplexer und unhandlicher gewesen. Deswegen die Entscheidung für den Haken, der bei ‚alten‘ Installationen einmal gesetzt werden muss.
                            A.
                              A.
                              mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              #504
                              @asgothian
                              Will nicht ätzen oder kritisieren. Und da mittlerweile 3.x.x existiert ist es wahrscheinlich eh schon zu spät. Wenn was super toll funktioniert kommen dann halt immer noch die "Vergoldungswünsche". Bitte nicht bös nehmen - Adapter ist super toll!
                              Hier nur eine Anregung für die Zukunft oder ähnliche Fälle:
                              Man kann bei der Adapterinstallation auch ein Script ausführen und dort erkennen ob schon eine (ältere) Installation vorliegt. Damit hätte man bei Upgrade von 1.x.x auf 2.x.x das Hakerl automatisch setzen können.
                              Ist bei einem Hackerl kein großes Ding. Aber für andere Migrationen ev. von Interesse.
                              Und für den IST Stand ev. zum Andenken:
                              Ev. würde eine Warning im Log sinnvoll sein, so in der Art:
                              Warning: Subsystem not yet started. If you configuration has been completed, please check xxxx box at configuration UI to start subsystem automatically.
                              Zumindest User die ins Log schaun (und das sind sicher nicht alle :-) hätte da nen Hinweis.
                              Support Repositoryverwaltung.
                              LESEN - gute Forenbeitrage
                              GaspodeG AsgothianA 2 Antworten Letzte Antwort
                              • mcm1957M mcm1957
                                @asgothian
                                GaspodeG Offline
                                GaspodeG Offline
                                Gaspode
                                #505
                                @mcm1957 said in Tester für Zigbee Adapter 2.0.x gesucht:
                                Der Haken kommt ja erst mit Version 3. Ich hab ehrlich gesagt noch nicht ganz verstanden, wann es sinnvoll ist, den Haken zunächst nicht zu setzen. Wenn das wirklich immer nur eine Neuinstallation des Adapters beträfe, wäre das bestimmt eine gute Sache, dass die Upgrader nicht davon behelligt werden.
                                • mcm1957M mcm1957
                                  @asgothian
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  #506
                                  @mcm1957 sagte in Tester für Zigbee Adapter 2.0.x gesucht:
                                  @asgothian
                                  [...snip]
                                  Keine Sorge - ich nehm das als Anregung und Vorschlag zur Verbesserung. Und bin Dankbar dafür.
                                  Aktuell gibt es (in aktuellen Github Version) die folgende Meldung wenn der Adapter gestartet wird ohne das der Haken da ist:
                                  Zigbee autostart option not set - omitting start of zigbee substystem!
                                  Bestehende Installationen die vor dem Update gelaufen sind sollten den Haken immer setzen. Einfach betrachtet wäre ein Skript also eine interessante option, aber
                                  1. Leider gehen viele Nutzer wenig 'systematisch' vor wenn etwas nicht sofort geht - da wird dieses und jenes neu installiert / über installiert / krumm gedreht. Mal von NPM, mal von Github, mal eine ältere Version. Ich hab im Forum an vielen Stellen mehr Probleme damit die komischen Lösungsversuche von Nutzern gerade zu biegen als das eigentlich ursächliche Problem zu lösen.
                                  Könnte ich das alles in einem Skript sauber abfangen - vielleicht.
                                  Ist es das für diesen einfachen Fall wert - in meinen Augen nicht. Einmal in die Einstellungen zu gehen und den Haken zu setzen ist jetzt nicht wirklich zuviel verlangt.
                                  1. Dadurch das die Nutzer in die Konfiguration gehen werden sie gleich noch mit einer weiteren Eigenschaft der 3.x konfrontiert - einer Verifikation von Zigbee-Einstellungen und den vom Koordinator gesicherten Einstellungen. Passen die nicht übereinander wird das angezeigt. Zusätzlich bekommen alle die noch die unsäglichen 16D ExtPanID nutzen nochmal einen Hinweis darauf das das vielleicht nicht gut ist.
                                  Über die Einstellungen lassen sich dann für die Nutzer halbwegs komfortabel auch Auffälligkeiten beheben, wie z.Bsp. die "Unart" einfach den Adapter mit dem Haken bei Screenshot 2025-06-04 at 13.34.30.png laufen zu lassen.
                                  Dieses ist gewünscht - zumindest von mir :)
                                  A.
                                  GaspodeG Thomas BraunT mcm1957M 3 Antworten Letzte Antwort
                                    @asgothian
                                    [...snip]
                                    A.
                                    GaspodeG Offline
                                    GaspodeG Offline
                                    Gaspode
                                    #507
                                    @asgothian said in Tester für Zigbee Adapter 2.0.x gesucht:
                                    Guter Punkt. :D
                                    Finde ich persönlich auch absolut ausreichend. 👍
                                      @asgothian
                                      [...snip]
                                      A.
                                      #508
                                      @asgothian sagte in Tester für Zigbee Adapter 2.0.x gesucht:
                                      Vielleicht kannst du für die ganz Unkreativen auch einen Link zu einem Hex-Generator verlinken?
                                      Ich lass mich da nämlich auch ganz gerne von solchen Diensten 'beraten'.
                                        @asgothian
                                        [...snip]
                                        A.
                                        mcm1957M Online
                                        mcm1957M Online
                                        mcm1957
                                        #509
                                        @asgothian
                                        Alles klar und für mich OK. DU entscheidest als dev was du für sinnvoll haltest.
                                        Und wenn es dir was hilft um schräge Installationen zu minimieren: Eine Installation von Github kannst du blocken. Damit zwingst du user zumindest eine (ggF Alpha) von npm zu installieren. Die mag zwar auch defekt sein aber wenigsten in sich ein definierter Zustand. (https://github.com/ioBroker/ioBroker.js-controller/blob/6ade4045339082a9408e17e0871ad26dc41206ca/schemas/io-package.json#L1371)
                                        Muss aber jeder dev selbst entscheiden was hilfreicher ist.
                                        • GaspodeG Gaspode
                                          dimaiv
                                          #510
                                          @gaspode
                                          Hier, im Thread, gibt's sogar die Lösung für dein Problem, aber, wenn man kein Zeit für Lesen hat...
                                          Lösung
                                          Node.js v22.21.0
                                          NPM v10.9.4
                                          JS controller 7.1.0
                                          Admin 7.7.20
