  4. Test Adapter Daikin-Cloud 0.4.0
282 Beiträge 41 Kommentatoren 81.2k Aufrufe 43 Beobachtet
  • ArmilarA Armilar
    @lemmi
    habe mal ein wenig Zeit gefunden, um das Skript auf alle Device-Typen und Adapterinstanzen anzupassen.
    TypeScript anlegen. Inhalt reinwerfen. Sollte nichts angepasst werden müssen. Skript starten...
    Die Daten für jedes Daikin-Device in der Onnecta-App (Klima, Wärmepumpe, heating, cooling, Total, etc.) werden unter 0_userdata.0.daikin-cloud.... angelegt.
    @apollon77 - evtl. kann man das in den Adapter schreddern...
    /* TypeScript (TS) @Armilar
     * This Script will read the consumption Data from Daikin-Cloud adapter and transform the raw data into individual data points similar to how it's shown in the Daikin Onecta App.
     * It will also sum up the historic consumption from the current and previous year and update the total consumption meter going forward.
     * The data is created in the following path analogous to the daikin cloud data
     * 0_userdata.0.daikin-cloud.0...
     * Createtd: 14.11.2024
    // Log-Mode
    const logMode: any = 'info'; // 'info' or 'debug'
    // Path in 0_userdata
    const mainPath: string = '0_userdata.0.';
    // Onnecta hours (if d-raw)
    const hourly: Array<string>  = ["00:00 - 02:00", "02:00 - 04:00", "04:00 - 06:00", "06:00 - 08:00", "08:00 - 10:00", "10:00 - 12:00", "12:00 - 14:00", "14:00 - 16:00", "16:00 - 18:00", "18:00 - 20:00", "20:00 - 22:00", "22:00 - 24:00"];
    // Onnecta weekdays (if w-raw)
    const daily: Array<string>   = ["01_Monday", "02_Tuesday", "03_Wednesday", "04_Thursday", "05_Friday", "06_Saturday", "07_Sunday"];
    // Onnecta months  (if m-raw)
    const monthly: Array<string> = ["01_Januray", "02_February", "03_March", "04_April", "05_May", "06_June", "07_July", "08_August", "09_September", "10_October", "11_November", "12_December"];
    let devices: string[] = getDeviceNames("daikin-cloud.");
    function setOrCreateState(id: string, value: any, forceCreation: boolean = true, common: Partial<iobJS.StateCommon> = {}, callback?: iobJS.SetStateCallback): void {
        if (!existsState(id)) {
            createState(id, value, forceCreation, common, callback);
        } else {
            setState(id, value, true);
    // Get Daikin Device Names
    function getDeviceNames(vAdapterInstance: string): string[] {
        let devices = [];
        $(vAdapterInstance + '*raw').each(function (id) {
            if (devices.indexOf(id) == -1) {
                devices.push(id);
        return devices;
    async function writeConsumtionData(path: string, rawType: string, rawData: number[]): Promise<void> {
        log(rawType + ' - ' + rawData, logMode);
        let total: number = 0;
        switch (rawType) {
    	case "d-raw":
                for (let j = 0; j < 12; j++) {
                    let dpName = "Yesterday." + hourly[j];
                    setOrCreateState(mainPath + path + dpName, rawData[j], true, {type: 'number', name: hourly[j], role: 'value.power', unit: 'kWh'});
                    log(mainPath + path + dpName + ': ' + rawData[j], logMode);
                    total = total + rawData[j];
                setOrCreateState(mainPath + path + 'Total.Yesterday', total, true, {type: 'number', name: 'Yesterday', role: 'value.power',unit: 'kWh'});
                total = 0;
                for (let j = 12; j < 24; j++) {
                    let dpName = "Today." + hourly[j-12];
                    setOrCreateState(mainPath + path + dpName, rawData[j], true, {type: 'number', name: hourly[j-12], role: 'value.power', unit: 'kWh'});
                setOrCreateState(mainPath + path + 'Total.Today', total, true, {type: 'number', name: 'Today', role: 'value.power',unit: 'kWh'});
                break;
    	case "w-raw":
                for (let j = 0; j < 7; j++) {
                    let dpName = "LastWeek." + daily[j];
                    setOrCreateState(mainPath + path + dpName, rawData[j], true, {type: 'number', name: daily[j], role: 'value.power', unit: 'kWh'});
                setOrCreateState(mainPath + path + 'Total.LastWeek', total, true, {type: 'number', name: 'LastWeek', role: 'value.power',unit: 'kWh'});
                total = 0;
                for (let j = 7; j < 14; j++) {
                    let dpName = "ThisWeek." + daily[j-7];
                    setOrCreateState(mainPath + path + dpName, rawData[j], true, {type: 'number', name: daily[j-7], role: 'value.power', unit: 'kWh'});
                setOrCreateState(mainPath + path + 'Total.ThisWeek', total, true, {type: 'number', name: 'ThisWeek', role: 'value.power',unit: 'kWh'});
                break;
    	case "m-raw":
                    let dpName = "LastYear." + monthly[j];
                    setOrCreateState(mainPath + path + dpName, rawData[j], true, {type: 'number', name: monthly[j], role: 'value.power', unit: 'kWh'});
                setOrCreateState(mainPath + path + 'Total.LastYear', total, true, {type: 'number', name: 'LastYear', role: 'value.power',unit: 'kWh'});
                total = 0;
                    let dpName = "ThisYear." + monthly[j-12];
                    setOrCreateState(mainPath + path + dpName, rawData[j], true, {type: 'number', name: monthly[j-12], role: 'value.power', unit: 'kWh'});
                setOrCreateState(mainPath + path + 'Total.ThisYear', total, true, {type: 'number', name: 'ThisYear', role: 'value.power',unit: 'kWh'});
                break;
    async function readConsumtionData(): Promise<void> {
        for (let i = 0; i < devices.length; i++) {
            //get d-raw; w-raw; m-raw
            let dev: any = devices[i].split('.');
            let state = getState(devices[i]).val;
            state = state.slice(1,-1);
            state = state.replaceAll('null', '0');
            await writeConsumtionData(devices[i].slice(0,-5), dev[dev.length -1], Array.from(state.split(','), Number));
    readConsumtionData();
    on({ id: [].concat(Array.prototype.slice.apply($('daikin-cloud.*.lastUpdateReceived'))), change: 'any' }, async (obj) => {
        await readConsumtionData();
    Lemmi
    #212
    @armilar Welchen Teil des Skriptes muss ich denn kopieren und einfügen? Irgendwie haut das bei mir nicht hin. Das Blockly funzt.
    Vielen Dank1
    • K Kredar
      @armilar sagte in Test Adapter Daikin-Cloud 0.4.0:
      • This Script will read the consumption Data from Daikin-Cloud adapter and transform the raw data into individual data points similar to how it's shown in the Daikin Onecta App.
      • It will also sum up the historic consumption from the current and previous year and update the total consumption meter going forward.
      • The data is created in the following path analogous to the daikin cloud data
      • 0_userdata.0.daikin-cloud.0...
      • Createtd: 14.11.2024
      // Log-Mode
      } else {
      let devices = [];
      devices.push(id);
      return devices;
      switch (rawType) {
      case "d-raw":
      total = 0;
      break;
      case "w-raw":
      total = 0;
      break;
      case "m-raw":
      total = 0;
      break;
      Super da ist ja auch meine Klimaanlage von Daikin drinnen :) Läuft 1a. Danke für das überarbeite Script. Merci
      Lemmi
      schrieb am zuletzt editiert von Lemmi
      #213
      @kredar
      Problem gelöst!!! Ich bin auch ein kleines dummerchen. Habe die ganze Zeit versucht unter Javaskript das Ding ans laufen zu bringen. Kann ja auch nicht klappen denn es steht doch deutlich geschrieben "TypeScript (TS)" anlegen. Das richtige Skript angelegt und alles reingeschmissen. Siehe da, es funzt.
      Vielen Dank an @kredar
      • L Lemmi
        @kredar
        Kredar
        #214
        @lemmi
        steht ja auch da, TS Script :)
        Super wenn es nun geht ;)
        • apollon77A apollon77
          Aktuelle Test Version 0.4.0
          Veröffentlichungsdatum 04.07.2024
          Github Link https://github.com/Apollon77/ioBroker.daikin-cloud
          Sooo, siehe https://github.com/Apollon77/ioBroker.daikin-cloud/issues/215#issuecomment-2208891591
          Erste Testversion auf GitHub.
          • Install von GitHub https://github.com/Apollon77/ioBroker.daikin-cloud
          • Erster Start sollte eine Fehlemeldung zeigen das man sich einloggen soll
          • Admin UI aufrufen, ABER eine Admin-Instanz mit aktiviertem HTTPS!! Und nicht per localhost/127.0.0.1 aufrufen!
          • Anleitung im Admin Ui befolgen
          Danach bitte testen.
          ACHTUNG: Die neue API hat eine Limitierung auf 200 Anfragen pro Tag! Daher ist das Standard Abfrageinterval 15 Minuten und man kann einen Slow Polling interval (zb Nachts) per State aktivieren.
          Bitte Feedback geben
          Dokumentation, Texte und Übersetzung ist noch "WIP"
          Hofmann IOBRF
          schrieb am zuletzt editiert von Hofmann IOBRF
          #215
          @apollon77 Die Verbindung zur Cloud hat nun einige Zeit gut funktioniert.
          Heute Morgen hatte ich einen "Error on update (1): expected 200 OK, got: 500 Internal Server Error" Fehler.
          Danach ging gar nichts mehr.
          Die Daikin Status Seite meldet keinen Fehler.
          Also habe ich die App gelöscht und neu angelegt.
          Ohne Erfolg.
          Nach dem Zugriff bestätigen bekomme ich die Fehlermeldung "Error on OAuth process: OPError: invalid_grant (invalid authorization code)"
          Hat noch wer aktuell Probleme damit?
          Jetzt meldet auch die Daikin Status Seite meldet Fehler!
          Geht jetzt wieder!
          Die Cloud ist halt einfach nicht sehr stabil!
          nik82N 1 Antwort Letzte Antwort
          • H Hofmann IOBRF
            Ohne Erfolg.
            Geht jetzt wieder!
            nik82N Offline
            nik82N Offline
            nik82
            #216
            @hofmann-iobrf
            Kam bei mir auch, ich musste nur wieder authentifizieren:
            Und jetzt gehts wieder...
            G 1 Antwort Letzte Antwort
            • nik82N nik82
              @hofmann-iobrf
              Gismoh
              #217
              @nik82
              War bei mir ebenso, auch der App Zugriff war gestört.
              War bei Daikin auch bekannt, und hatten dran gearbeitet.
              Mit der neuen Authentifizierung über den Adapter funktioniert nun es auch wieder im IOBroker.
              ioBroker auf: Lenovo ThinkCentre M910Q Tiny i5-7500T 16 GB mit proxmox in VM (Bookworm)
              • H Offline
                Hofmann IOBRF
                #218
                Es gibt in der App ein Update für die Benutzerschnittstelle. Hat das schon jemand gemacht? Kommt der Adapter danach damit klar?
                Aktuell läuft es sehr gut mit dem Adapter, deswegen frage ich mal.
                H 1 Antwort Letzte Antwort
                • H Hofmann IOBRF
                  Hofmann IOBRF
                  #219
                  @hofmann-iobrf ist hier noch jemand?
                  • H Hofmann IOBRF
                    ArmilarA Offline
                    ArmilarA Offline
                    Armilar
                    Most Active Forum Testing
                    #220
                    @hofmann-iobrf
                    ja, der Adapter reicht nur die Daten durch... Du kannst das Update machen
                    • ArmilarA Armilar
                      @hofmann-iobrf
                      Hofmann IOBRF
                      #221
                      @armilar Ja, hat geklappt. Funktioniert alles. Nur die Energiedaten kommen jetzt noch unregelmäßiger. Tlw. 2h später.
                      • H Hofmann IOBRF
                        #222
                        @hofmann-iobrf Das wäre eine Frage an Daikin, da kann der Adapter leider nichts tun.
                          mhuber
                          #223
                          ich habe ein neues Innengerät bekommen, hab bis jetzt immer den anderen Adapter (lokale Kommunikation) verwendet, das geht beim neuen Innengerät nicht mehr. Habe nun den Cloud Adapter Version 0.4.11 installiert.
                          Connect usw. funktioniert, Devices werden offline angezeigt aber das dürfte normal sein wie ich hier gelesen habe.
                          Ich kann aber kein Gerät ein oder ausschalten, woran kann das liegen? Das wäre ja "onOffMode" oder? Habe auch ein paar Minuten gewartet, es tut sich nichts.
                          Kann mir jemand helfen! Danke!
                          F 1 Antwort Letzte Antwort
                          • M mhuber
                            FritzTheCat
                            #224
                            @mhuber Hallo, ja "onOffMode" ist der richtige Schalter, aber da muss man normalerweise nicht warten. Bei mir ist die Verzögerung ganz gleich wie bei der normalen Fernbedienung direkt oder ca. 1 Sekunde.
                            Das Gerät wird allerdings auch nicht offline angezeigt:
                            Vielleicht findest Du eine Fehlermelung im Log?
                            • F FritzTheCat
                              mhuber
                              #225
                              @fritzthecat ist bei mir so nicht gegangen, Adapter deinstalliert, nochmal installiert und es geht, komisch....
                              Wie bekommen Du das "online" in grün hin? Bei mir zeigt es offline, aber es scheint alles zu gehen
                              • M mhuber
                                #226
                                @mhuber Es gibt wohl einige Geräte die den Online Status nicht korrekt zurückmelden ... andere gehen. Schau mal GitHub issues. Haben bisher noch keine Lösung
                                • ArmilarA Armilar
                                  @lemmi
                                  // Log-Mode
                                      } else {
                                      let devices = [];
                                              devices.push(id);
                                      return devices;
                                      switch (rawType) {
                                  	case "d-raw":
                                              total = 0;
                                              break;
                                  	case "w-raw":
                                              total = 0;
                                              break;
                                  	case "m-raw":
                                              total = 0;
                                              break;
                                  topsurfer
                                  schrieb am zuletzt editiert von topsurfer
                                  #227
                                  @armilar Auch von mir ein Danke für das Script, lief auf Anhieb!
                                  Frage (hoffe es ist nicht zu OT),
                                  Jetzt sieht man ja die DP auch mit historischen Daten (z.B. letzte 12 Monate je ein Monatsverbrauch), gibt es einen Trick, diese Daten mit entsprechendem Timestamp in eine InfluxDB zu bekommen, oder ist händige Arbeit angesagt (mittels insert ...)
                                  Die jetzt neuen Monatswerte würde ich per Cron am Monatsende dann in die DB schreiben lassen (oder?)
                                  • apollon77A Offline
                                    #228
                                    @Armilar Soll ich den Post mit dem Skript mal in der Adapter Readme verlinken?
                                      ArmilarA Offline
                                      ArmilarA Offline
                                      Armilar
                                      #229
                                      @apollon77
                                      ja gerne... 😊
                                      hier verschwindet es ja irgendwann im "ich habe ja nicht alle Posts gelesen" ;-)
                                      • T topsurfer
                                        ArmilarA Offline
                                        ArmilarA Offline
                                        Armilar
                                        #230
                                        @topsurfer
                                        ja, du kannst je Gerät die Totalwerte nutzen...
                                        Wenn die sich ändern in die influxdb schreiben...
                                        Sollte ja alles vorhanden sein, was für eine Auswertung erforderlich ist.
                                        • ArmilarA Armilar
                                          @topsurfer
                                          topsurfer
                                          #231
                                          @armilar Ja, das gilt aber doch nur für aktuelle Werte, die sich noch ändern.
                                          Meinte ja alte Daten von z.B. Monatswert 08.2024, der ändert sich ja nicht mehr.
                                          Den will ich ja mit Timestamp 31.08.2024 in die DB bekommen, das geht wohl nur händig, oder?
