  3. Off Topic
  4. Pflege des Betriebssystems
  5. Meldung über Zeitfehler - Was ist das ?
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
65 Beiträge 5 Kommentatoren 10.2k Aufrufe 3 Beobachtet
  • dogfight76D dogfight76
    @thomas-braun said in Meldung über Zeitfehler - Was ist das ?:
    Ausgabe von
    Im putty den Befehl ausführen ?
    EDIT: Die Ausgabe des Befehl in putty:
    ```bash
    Script v.2025-02-23
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     14:52:43 up 2 days,  1:59,  2 users,  load average: 0.29, 0.13, 0.07
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2025-04-04 14:52:43 CEST
               Universal time: Fri 2025-04-04 12:52:43 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    dogfight76
    HOME=/home/dogfight76
    GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        918M        1.9G        1.0M        935M        2.8G
    Swap:            99M          0B         99M
    Total:          3.9G        918M        2.0G
    Active iob-Instances:   14
             3794 M total memory
              918 M used memory
             1064 M active memory
              641 M inactive memory
             1939 M free memory
              126 M buffer memory
              809 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 14:52:44 up 2 days,  1:59,  2 users,  load average: 0.29, 0.13, 0.07
    Tasks: 176 total,   1 running, 175 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  1.4 us,  2.8 sy,  0.0 ni, 95.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3794.3 total,   1940.0 free,    918.2 used,    936.2 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2799.5 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4       59G  9.0G   47G  17% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
    [Wed Apr  2 12:53:00 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Wed Apr  2 12:53:01 2025] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Wed Apr  2 12:53:01 2025] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Wed Apr  2 12:53:02 2025] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Wed Apr  2 12:53:02 2025] EXT4-fs (mmcblk0p2): 2 orphan inodes deleted
    [Wed Apr  2 12:53:02 2025] EXT4-fs (mmcblk0p2): recovery complete
    [Wed Apr  2 12:53:02 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Apr  2 12:53:02 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Wed Apr  2 12:53:04 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.3G    /var/
    1.3G    /var/log/journal/7d1338ad4ea145258230302c11232948
    1.3G    /var/log
    734M    /var/cache
    Archived and active journals take up 1.2G in the file system.
    /opt/iobroker/backups:
    93M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    791M    /opt/iobroker/iobroker-data/
    728M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    17M     /opt/iobroker/iobroker-data/objects.jsonl
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.7e9d7842.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.0
    /usr/bin/node           v20.18.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.3
    nodejs:
      Installed: 20.18.0-1nodesource1
      Candidate: 20.18.3-1nodesource1
      Version table:
         20.18.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
     *** 20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u6 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 25418)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.3
    javascript:     8.8.3
    nodejs modules from github:     1
    +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
    Adapter State
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
      system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
      system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
      system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
      system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
      system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
      system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
    + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
    + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
      system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.3    , installed 7.6.3
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
    Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Objects and States
    Objects:        1150
    States:         885
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 93
    *** Listening Ports ***
    tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       1146617    115154/io.mqtt.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15374      564/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          942202     94334/cupsd
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       1148504    115241/io.jarvis.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1147461    114977/iobroker.js-
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1147466    114977/iobroker.js-
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1149410    114995/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1149599    115203/io.web.0
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          942201     94334/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15376      564/sshd: /usr/sbin
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14987      479/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1147680    115132/io.chromecas
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14601      403/avahi-daemon: r
    udp        0      0 0.0.0.0:36388           0.0.0.0:*                           108        14603      403/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          15860      479/dhcpcd
    udp6       0      0 :::44044                :::*                                108        14604      403/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14602      403/avahi-daemon: r
    2025-04-04 14:45:15.296  - warn: javascript.0 (115051)     at Object.<anonymous> (script.js.common.Meine_Geraete.Heizung.Akt_VL:9:19)
    2025-04-04 14:45:15.297  - warn: javascript.0 (115051)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2025-04-04 14:45:15.298  - warn: javascript.0 (115051)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2025-04-04 14:45:15.298  - warn: javascript.0 (115051)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
    2025-04-04 14:45:15.299  - warn: javascript.0 (115051)     at processImmediate (node:internal/timers:483:21)
    2025-04-04 14:45:15.300  - info: javascript.0 (115051) script.js.common.Meine_Geraete.Heizung.Akt_VL: null
    2025-04-04 14:45:15.300  - warn: javascript.0 (115051) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.26" not found (3)
    2025-04-04 14:45:15.303  - warn: javascript.0 (115051)     at Object.<anonymous> (script.js.common.Meine_Geraete.Heizung.Akt_VL:10:137)
    2025-04-04 14:45:15.303  - warn: javascript.0 (115051)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2025-04-04 14:45:15.304  - warn: javascript.0 (115051)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2025-04-04 14:45:15.304  - warn: javascript.0 (115051)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
    2025-04-04 14:45:15.304  - warn: javascript.0 (115051)     at processImmediate (node:internal/timers:483:21)
    2025-04-04 14:46:45.183  - warn: javascript.0 (115051) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.25" not found (3)
    2025-04-04 14:46:45.185  - warn: javascript.0 (115051)     at Object.<anonymous> (script.js.common.Meine_Geraete.Heizung.Akt_VL:9:19)
    2025-04-04 14:46:45.185  - warn: javascript.0 (115051)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2025-04-04 14:46:45.186  - warn: javascript.0 (115051)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2025-04-04 14:46:45.186  - warn: javascript.0 (115051)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
    2025-04-04 14:46:45.186  - warn: javascript.0 (115051)     at processImmediate (node:internal/timers:483:21)
    2025-04-04 14:46:45.187  - info: javascript.0 (115051) script.js.common.Meine_Geraete.Heizung.Akt_VL: null
    2025-04-04 14:46:45.187  - warn: javascript.0 (115051) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.25" not found (3)
    2025-04-04 14:46:45.188  - warn: javascript.0 (115051)     at Object.<anonymous> (script.js.common.Meine_Geraete.Heizung.Akt_VL:10:137)
    2025-04-04 14:46:45.189  - warn: javascript.0 (115051)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    2025-04-04 14:46:45.189  - warn: javascript.0 (115051)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    2025-04-04 14:46:45.189  - warn: javascript.0 (115051)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
    2025-04-04 14:46:45.189  - warn: javascript.0 (115051)     at processImmediate (node:internal/timers:483:21)
    iob diag has finished.
    @dogfight76 sagte in Meldung über Zeitfehler - Was ist das ?:
    Das kannst du schon mal auf Version 12 'Bookworm' bringen. Geht beim Raspberry aber nur per Neuinstallation.
    Das Dateisystem hat einen Treffer:
    Da könnten auch deine Probleme mit dem System herrühren.
    System regelmäßiger auf Stand bringen:
    Pending Updates: 93
    Es darf da keine fast 3stellige Zahl an Updates anstehen.
    dogfight76D 2 Antworten Letzte Antwort
      Pending Updates: 93
      dogfight76D Offline
      dogfight76D Offline
      dogfight76
      Ok, das bedeutet jetzt wieviel Aufwand ?
      ioBroker Backup werden ja autom. gemacht.
      Aber das bedeutet praktisch bei Null anfangen, richtig ?
        Keine Ahnung. Hängt halt davon ab wie sattelfest du dabei bist und was da alles konfiguriert wurde. Ist ja dein System.
        Wenn es nur der ioBroker ist, dann ist das ganze Ding in einer Stunde gehalten.
        dogfight76D 1 Antwort Letzte Antwort
          dogfight76D Offline
          dogfight76D Offline
          dogfight76
          @thomas-braun Auf dem Pi läuft nur ioBroker für die VIS Steuerung der Wärmepumpe
          Das mit den Updates verstehe ich nicht. Deine Befehle mal eingeben aus deiner letzten Hilfestellung für mich, mit dem Ergebnis:
          Befehle waren diese, in der Reihenfolge:
          sudo apt update
          sudo apt full-upgrade
          sudo reboot
          Da keine Updates gemeldet wurden dann diese hinterher:
          iob update
          iob upgrade all -y
          Das Ergebnis siehst du auf dem Screenshot
            sudo apt update
            sudo reboot
            iob update
            iob upgrade all -y
            @dogfight76
            KEINE Screenshots.
              @dogfight76
              KEINE Screenshots.
              dogfight76D Offline
              dogfight76D Offline
              dogfight76
              @thomas-braun Sorry, aber ich kann ich nicht mehr kopieren.
              Aber mehr als auf dem Screenshot stand da nicht.
                Ich lese keine Screenshots.
                  dogfight76D Offline
                  dogfight76D Offline
                  dogfight76
                  @thomas-braun Und was soll ich jetzt machen ? Bekomme den Text da ja nicht mehr rauskopiert um es in das Code-Fenster zu kopieren.
                  Bin eh angefangen den ioBroker mit dem Debian GNU/Linux 12 'Bookworm auf einen Pi 4 Version A zu installieren.
                  Dann Backup drauf und alles ist aktuell.
                    Pending Updates: 93
                    dogfight76D Offline
                    dogfight76D Offline
                    dogfight76
                    so, habe das Upgrade auf die aktuelle Version Bookworm gemacht. Dann Updates installiert , von Bookworm und auch iobroker.
                    Wollte dir die Ausgabe von "iob diag" zeigen, aber da kommt diese Meldung:
                    dogfight76@ioBroker-neu:~ $ iob update
                    dogfight76@ioBroker-neu:~ $ iob diag
                    /usr/bin/iob: line 21: /home/iobroker/iob_diag.log: Permission denied
                    dogfight76@ioBroker-neu:~ $ sudo iob diag
                    ***For security reasons ioBroker should not be run or administrated as root.***
                    By default only a user that is member of iobroker group can execute ioBroker commands.
                    Please read the Documentation on how to set up such a user, if not done yet.
                    Only in very special cases you can run iobroker commands by adding the --allow-root option at the end of the command line.
                    Please note that this option may be disabled in the future, so please change your setup accordingly now.
                      Bei RaspiOS kann man dieses Upgrade nicht (so einfach) durchführen.
                      Da geht im Prinzip nur Neuinstallation!
                        dogfight76D Offline
                        dogfight76D Offline
                        dogfight76
                        Ist eine komplette Neusinatllation gemacht worden !
                        Hatte einen Pi 4 Modell A rumliegen , mit 128GB miscroSD und daruaf alles frisch aufgesetzt ! Bis halt zu dem Punkt "iob diag"
                          @dogfight76 wie hast du den user angelegt?
                          wie hast du iobroker installiert?
                          • mit welchem user?
                            Permission denied
                            Der user dogfight76 ist vermutlich nicht in der richtigen Gruppe. Oder der wurde nach der Installation noch nicht neueingeloggt.
                              • mit welchem user?
                              dogfight76D Offline
                              dogfight76D Offline
                              dogfight76
                              Guten morgen,
                              @homoran said in Meldung über Zeitfehler - Was ist das ?:
                              Nach dieser Anleitung hier aus dem Forum:
                              https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                              Und danach mein ioBroker-Backup eingespielt.
                                Guten morgen,
                                und die Antwort auf die zweite Frage?
                                @homoran sagte in Meldung über Zeitfehler - Was ist das ?:
                                mit welchem user?
                                  Guten morgen,
                                  @dogfight76
                                  Hast du unmittelbar nach der Installation den dogfight76 abgemeldet?
                                  Hast du unmittelbar nach der Installation den iob fix ausgefürht?
                                  Zeig die Ausgabe von
                                  groups
                                  ls -l /home
                                  • dogfight76D Offline
                                    dogfight76D Offline
                                    dogfight76
                                    angemldet im ioBroker ? Ist der User gemeint ?
                                    Im ioBroker angemeldet mit vergebenem User und meinem vergebenem Passwort.
                                    Die Anleitung einfach bis zum Ende abgearbeitet ,dann die Update/Upgrade Befehle ausgeführt
                                    Danach im ioBroker angemeldet und das Backup eingespielt.
                                    Dann wollte ich über putty den Befehle "iob diag" durchlaufen lassen um das Ergebnis hier für die Kontrolle einzufügen.
                                    Da kam der Fehler......
                                      @dogfight76
                                      groups
                                      ls -l /home
                                      dogfight76D Offline
                                      dogfight76D Offline
                                      dogfight76
                                      Habe "iob stop" und dann "iob fix" ausgeführt.
                                      Die Ausgabe dazu:
                                      dogfight76@ioBroker-neu:~ $ iob stop
                                      dogfight76@ioBroker-neu:~ $ iob fix
                                      library: loaded
                                      Library version=2024-10-22
                                          Welcome to the ioBroker installation fixer!
                                          Script version: 205-02-02
                                          You might need to enter your password a couple of times.
                                          Installing prerequisites (1/5)
                                      Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
                                      Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
                                      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                                      Get:5 http://deb.debian.org/debian-security bookworm-security/main armhf Packages [231 kB]
                                      Get:6 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [246 kB]
                                      Hit:7 http://archive.raspberrypi.com/debian bookworm InRelease
                                      Fetched 580 kB in 1s (421 kB/s)
                                      Reading package lists... Done
                                          Checking ioBroker user and directory permissions (2/5)
                                          Check and cleanup npm temporary directories (3/5)
                                      Done.
                                          Database maintenance (4/5)
                                      Checking for uncompressed JSONL databases... This might take a while!
                                      Compressing /opt/iobroker/iobroker-data/states.jsonl
                                      Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                      Compressed 2 JSONL files. Done
                                          Checking autostart (5/5)
                                      ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
                                      Authentication is required to stop 'iobroker.service'.
                                      Authenticating as: ,,, (dogfight76)
                                      Password: polkit-agent-helper-1: pam_authenticate failed: Authentication failure
                                      !%GunffiEnabling autostart...
                                      ighterAutostart enabled!
                                          Your installation was fixed successfully
                                          Run iobroker start to start ioBroker again!
                                      Jezt "iob start" gemacht. Dann die Abfrage "ls -l /home"
                                      Ergebnis:
                                      dogfight76@ioBroker-neu:~ $ ls -l /home
                                      total 8
                                      drwx------ 5 dogfight76 dogfight76 4096 Apr  5 10:59 dogfight76
                                      drwxr-xr-x 3 iobroker   iobroker   4096 Apr  5 10:59 iobroker
                                        Die Ausgabe dazu:
                                        library: loaded
                                        Done.
                                        Ergebnis:
                                        total 8
                                        dogfight76D Offline
                                        dogfight76D Offline
                                        dogfight76
                                        schrieb am zuletzt editiert von dogfight76
                                        Jetzt geht auch der Befehl:
                                        "iob diag"
                                        Läuft gerade, Ergebnis kommt sofort
                                        Edit für Ergebnis:
                                        Copy text starting here:
                                        ```bash
        v.2025-02-23
                                         Static hostname: ioBroker-neu
                                               Icon name: computer
                                                  Kernel: Linux 6.12.20+rpt-rpi-v8
                                            Architecture: arm64
                                        Kernel:                 aarch64
                                        Userland:               64 bit
                                        User-ID:                1000
                                        Boot Target:            multi-user.target
                                        Pending OS-Updates:     0
                                        Pending iob updates:    0
                                        Nodejs-Installation:
                                        /usr/bin/nodejs         v20.19.0
                                        /usr/bin/node           v20.19.0
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        /usr/bin/corepack       0.31.0
                                        Recommended versions are nodejs 20.19.0 and npm 10.8.2
                                        nodeJS installation is correct
                                        MEMORY:
                                        Mem:            4.0G        1.1G        2.2G        1.2M        807M        2.9G
                                        Swap:           536M          0B        536M
                                        Total:          4.5G        1.1G        2.7G
                                        Active iob-Instances:   13
                                        ioBroker Core:          js-controller           7.0.6
        admin                   7.6.3
                                        Objects type: jsonl
                                        States  type: jsonl
                                        + system.adapter.admin.0                  : admin                 : ioBroker-neu                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        + system.adapter.web.0                    : web                   : ioBroker-neu                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        Objects:                1150
                                        States:                 882
                                        Size of iob-Database:
                                        12M     /opt/iobroker/iobroker-data/objects.jsonl
                                        684K    /opt/iobroker/iobroker-data/states.jsonl
                                        Operating System is the current Debian stable version codenamed 'bookworm'!
                                        Das Ergebniss Fenster ist neu in der Version "Bookworm" ?
                                        Thomas BraunT dogfight76D 2 Antworten Letzte Antwort
                                          "iob diag"
                                          Edit für Ergebnis:
                                          ```bash
        v.2025-02-23
                                                 Icon name: computer
                                              Architecture: arm64
                                          Kernel:                 aarch64
                                          Userland:               64 bit
                                          User-ID:                1000
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          MEMORY:
                                          Swap:           536M          0B        536M
        admin                   7.6.3
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects:                1150
                                          States:                 882
                                          Nein.
                                          Gib mal die Langfassung.
