  4. Zigbee Helligkeitssensor gibt keine Werte aus
49 Beiträge 8 Kommentatoren 7.8k Aufrufe 5 Beobachtet
  • FredFF FredF
    @surfer09
    Mal mit einer neuen Batterie versucht? Meiner Erfahrung nach ist dieser Sensor mit schwacher Batterie etwas "zickig"
    Ansonsten, das Log vom Zigbee Adapter beim Anlernen noch zeigen.
    surfer09S Offline
    surfer09S Offline
    surfer09
    schrieb am zuletzt editiert von surfer09
    @fredf Die Batterie ist eigentlich noch recht neu. Die würde ich ausschließen.
    Ich habe mal das LOG angehangen vom Anlernen.
    2025-02-26 18:57:10.714 - debug: zigbee.0 (1620) handleMessage. {"type":"commandIdentifyQuery","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":39,"_applicationVersion":27,"_dateCode":"20200312","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":262,"inputClusters":[0,1024,3,1],"outputClusters":[3],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.sen_ill.mgl01","manufacturerName":"XIAOMI","powerSource":3,"zclVersion":3,"appVersion":27,"stackVersion":2,"hwVersion":1,"dateCode":"20200312","swBuildId":"2019\u0000www."}},"genPowerCfg":{"attributes":{"batteryVoltage":30}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":6021}}},"deviceIeeeAddress":"0x04cf8cdf3c81a421","deviceNetworkAddress":6365,"_binds":[{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x4c5bb3fffe92c427","endpointID":1}],"_configuredReportings":[{"cluster":1024,"attrId":0,"minRepIntval":15,"maxRepIntval":3600,"repChange":500}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x04cf8cdf3c81a421"}}],"_hardwareVersion":1,"_ieeeAddr":"0x04cf8cdf3c81a421","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1740592630714,"_manufacturerID":4718,"_manufacturerName":"XIAOMI","_modelID":"lumi.sen_ill.mgl01","_networkAddress":6365,"_powerSource":"Battery","_softwareBuildID":"2019\u0000www.","_stackVersion":2,"_type":"EndDevice","_zclVersion":3,"_linkquality":168,"_skipDefaultResponse":false,"_checkinInterval":3600,"_pendingRequestTimeout":3600000,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{},"linkquality":168,"groupID":0,"cluster":"genIdentify","meta":{"zclTransactionSequenceNumber":7,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
    2025-02-26 18:57:10.715 - debug: zigbee.0 (1620) Received Zigbee message from '0x04cf8cdf3c81a421', type 'commandIdentifyQuery', cluster 'genIdentify', data '{}' from endpoint 1 with groupID 0
    2025-02-26 18:57:10.715 - debug: zigbee.0 (1620) Type commandIdentifyQuery device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":39,"_applicationVersion":27,"_dateCode":"20200312","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":262,"inputClusters":[0,1024,3,1],"outputClusters":[3],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.sen_ill.mgl01","manufacturerName":"XIAOMI","powerSource":3,"zclVersion":3,"appVersion":27,"stackVersion":2,"hwVersion":1,"dateCode":"20200312","swBuildId":"2019\u0000www."}},"genPowerCfg":{"attributes":{"batteryVoltage":30}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":6021}}},"deviceIeeeAddress":"0x04cf8cdf3c81a421","deviceNetworkAddress":6365,"_binds":[{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x4c5bb3fffe92c427","endpointID":1}],"_configuredReportings":[{"cluster":1024,"attrId":0,"minRepIntval":15,"maxRepIntval":3600,"repChange":500}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x04cf8cdf3c81a421"}}],"_hardwareVersion":1,"_ieeeAddr":"0x04cf8cdf3c81a421","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1740592630714,"_manufacturerID":4718,"_manufacturerName":"XIAOMI","_modelID":"lumi.sen_ill.mgl01","_networkAddress":6365,"_powerSource":"Battery","_softwareBuildID":"2019\u0000www.","_stackVersion":2,"_type":"EndDevice","_zclVersion":3,"_linkquality":168,"_skipDefaultResponse":false,"_checkinInterval":3600,"_pendingRequestTimeout":3600000,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["illuminance","illuminance_lux"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"manuSpecificLumi","type":["attributeReport","readResponse"]}],"exposes":[{"name":"battery","label":"Battery","access":1,"type":"numeric","property":"battery","description":"Remaining battery in %, can take up to 24 hours before reported","category":"diagnostic","unit":"%","value_max":100,"value_min":0},{"name":"voltage","label":"Voltage","access":1,"type":"numeric","property":"voltage","description":"Voltage of the battery in millivolts","category":"diagnostic","unit":"mV"},{"name":"illuminance","label":"Illuminance","access":5,"type":"numeric","property":"illuminance","description":"Raw measured illuminance"},{"name":"illuminance_lux","label":"Illuminance (lux)","access":5,"type":"numeric","property":"illuminance_lux","description":"Measured illuminance in lux","unit":"lx"},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"meta":{"battery":{"voltageToPercentage":{"min":2850,"max":3000}}},"onEvent":null,"zigbeeModel":["lumi.sen_ill.mgl01"],"model":"GZCGQ01LM","vendor":"Xiaomi","whiteLabel":[{"vendor":"Xiaomi","model":"YTC4043GL"}],"description":"Mi light sensor","options":[{"name":"illuminance_calibration","label":"Illuminance calibration","access":2,"type":"numeric","property":"illuminance_calibration","description":"Calibrates the illuminance value (percentual offset), takes into effect on next report of device."},{"name":"illuminance_lux_calibration","label":"Illuminance lux calibration","access":2,"type":"numeric","property":"illuminance_lux_calibration","description":"Calibrates the illuminance_lux value (percentual offset), takes into effect on next report of device."}]},"name":"0x04cf8cdf3c81a421"} incoming event: {"type":"commandIdentifyQuery","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":39,"_applicationVersion":27,"_dateCode":"20200312","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":262,"inputClusters":[0,1024,3,1],"outputClusters":[3],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"modelId":"lumi.sen_ill.mgl01","manufacturerName":"XIAOMI","powerSource":3,"zclVersion":3,"appVersion":27,"stackVersion":2,"hwVersion":1,"dateCode":"20200312","swBuildId":"2019\u0000www."}},"genPowerCfg":{"attributes":{"batteryVoltage":30}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":6021}}},"deviceIeeeAddress":"0x04cf8cdf3c81a421","deviceNetworkAddress":6365,"_binds":[{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x4c5bb3fffe92c427","endpointID":1}],"_configuredReportings":[{"cluster":1024,"attrId":0,"minRepIntval":15,"maxRepIntval":3600,"repChange":500}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x04cf8cdf3c81a421"}}],"_hardwareVersion":1,"_ieeeAddr":"0x04cf8cdf3c81a421","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1740592630714,"_manufacturerID":4718,"_manufacturerName":"XIAOMI","_modelID":"lumi.sen_ill.mgl01","_networkAddress":6365,"_powerSource":"Battery","_softwareBuildID":"2019\u0000www.","_stackVersion":2,"_type":"EndDevice","_zclVersion":3,"_linkquality":168,"_skipDefaultResponse":false,"_checkinInterval":3600,"_pendingRequestTimeout":3600000,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{},"linkquality":168,"groupID":0,"cluster":"genIdentify","meta":{"zclTransactionSequenceNumber":7,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
    2025-02-26 18:57:10.719 - debug: zigbee.0 (1620) No converter available for 'GZCGQ01LM' '04cf8cdf3c81a421' with cluster 'genIdentify' and type 'commandIdentifyQuery'
    Vielleicht hat noch jemand eine andere Empfehlung für einen Lichtsensor über Zigbee.
    • surfer09S surfer09
      ich habe diesen Helligkeitssensor im Einsatz, leider gibt er keine Werte aus.
      Ich setze den Zigbee Adapter 1.10.14 ein. Habe den Sensor jetzt auch schon mehrfach neu angelernt, leider kein Erfolg.
      Hat jemand vielleicht eine Idee, was ich machen kann?
      crunchipC Offline
      crunchipC Offline
      @surfer09 sagte in Zigbee Helligkeitssensor gibt keine Werte aus:
      vllt ein Hinweis zur Firmware deines Sticks
      https://www.zigbee2mqtt.io/devices/GZCGQ01LM.html
      surfer09S 1 Antwort Letzte Antwort
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @surfer09 Bitte testen:
        • Update auf die 2.0.1 aus dem Latest Zweig.
        • Debug für den Sensor aktivieren (siehe Hier)
        • Prüfen mit welchem Payload Nachrichten vom Gerät am Adapter ankommen.
        • Prüfen ob das Gerät neu 'Konfiguriert' werden kann. (Button auf der Rückseite der Gerätekachel). Dabei das Gerät wach halten.
        A.
        crunchipC surfer09S 2 Antworten Letzte Antwort
        • AsgothianA Asgothian
          A.
          crunchipC Offline
          crunchipC Offline
          @asgothian sagte in Zigbee Helligkeitssensor gibt keine Werte aus:
          sollte dieser Sensor denn nicht auch mit seiner jetzigen installierten Version funktionieren?
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @crunchip sagte in Zigbee Helligkeitssensor gibt keine Werte aus:
            Tut er bei mir. Aber es gibt so viele Effekte das ich keine Lust habe in altem Code zu graben. Also auf die aktuelle Version, dann weiter testen.
            nebenbei ist in dieser Version das aktivieren der Debug-Nachrichten deutlich komfortabler als es das in der alten Version war. Und auch entsprechend gut dokumentiert (link)
            A.
              A.
              crunchipC Offline
              crunchipC Offline
              hab ich mir gerade schon angesehen
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                Und.. Meinung dazu ?
                  crunchipC Offline
                  crunchipC Offline
                  @asgothian klingt vielversprechend und sauber aufgebaut. Habe jedoch davon keinen nutzen da ich z2m nutze.
                  setzt jeoch immer noch voraus, das
                  eine Rolle spielt, jedoch noch keine Info kam, was genutzt wird
                    A.
                    surfer09S Offline
                    surfer09S Offline
                    surfer09
                    @asgothian: Also.. ich bräuchte da mal Hilfe zu, weil ich noch nie Firmware Updates auf die Sensoren gepackt habe. Wie muss ich dazu vorgehen?
                    Hier werden mir keine Update angeboten...
                    crunchipC arteckA AsgothianA 3 Antworten Letzte Antwort
                      surfer09S Offline
                      surfer09S Offline
                      surfer09
                      @crunchip Also ich habe den SONOFF Zigbee 3.0 USB Dongle mit der Firmware 7.4.5 (GA) im Einsatz. Ich steige bei den ganzen Firmwares auch nicht wirklich durch, welche man davon nutzen sollte, oder auch nicht. Scheinbar gibt es dafür auch mehrere Möglichkeiten, wenn ich das richtig verstehe? 🤔
                        crunchipC Offline
                        crunchipC Offline
                        @surfer09 davon hat doch niemand etwas geschrieben
                          crunchipC Offline
                          crunchipC Offline
                          Soweit ich weiß, ist das davon abhängig welcher Chip auf dem Stick verbaut ist
                            arteckA Offline
                            arteckA Offline
                            arteck
                            @surfer09 wie währe es wenn du erstmal GENAUER lesen würdest was man von dir braucht...
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              Nochmal von vorne:
                              • Firmware auf dem Gerät ist wahrscheinlich nicht veraltet.
                              • Firmware auf dem Stick ist wahrscheinlich ok.
                              • Irgendeine Firmware aktualisieren bringt im Zweifelsfall erst einmal wenig
                              • Du musst schauen was das Gerät an Nachrichten Sendet. Das geht (auch) mit der Adapter Version die du nutzt, aber nicht so elegant. Bitte hier lesen, da steht was zu tun ist.
                              • Du musst schauen ob es Möglich ist dem Gerät eine Konfiguration zu senden. Dafür gibt es auf der Gerätekachel einen entsprechenden Button. Wichtig dabe ist das Du das Gerät vor dem Konfigurieren aufweckst, sonst geht das sowieso schief.
                              Ohne Informationen ob das Gerät überhaupt etwas relevantes Sendet ist alles nur stochern im Dunkeln und tauschen wir mal XYZ aus, vielleicht geht es dann, keine vernünftige Fehlerprüfung.
                              A.
                                Nochmal von vorne:
                                A.
                                surfer09S Offline
                                surfer09S Offline
                                surfer09
                                Also ich weiß nicht, was hier über Nacht passiert ist, aber plötzlich meldet er die Werte. Verstehen muss man das nicht?!
                                  Maddin77
                                  Servus
                                  ich häng mich hier mal dran mit einem Helligkeits Sensor
                                  Diesen Hier Tuya ZG-204ZL
                                  leider bekomme ich Werte mit denen es sich nicht wirklich Steuern lässt in meinen Augen
                                  evtl. müsste ich was anders einstellen, weis nur nicht wie
                                  hier mal paar Daten und Bilder
                                  Der Gerät im Zigbee Adapter
                                  Hier die Objekte aus IOB
                                  ich nehme die Iluminance Raw
                                  und so schaut die Aufzeichnung dann aus 15sek
                                  evtl. jemand nenn Tipp für mich
                                  Danke schon mal
                                  haselchenH arteckA 2 Antworten Letzte Antwort
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @surfer09
                                    was bist du aber auch ungeduldig :-)
                                    • M Maddin77
                                      Servus
                                      Danke schon mal
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      @maddin77
                                      Wo hakt es denn?
                                      Genau den Gleichen habe ich und viele andere hier auch.
                                      • haselchenH haselchen
                                        @maddin77
                                        Wo hakt es denn?
                                        Maddin77
                                        schrieb am zuletzt editiert von Maddin77
                                        @haselchen
                                        Naja er spring von 2500 auf 1600 und dann auf 0
                                        Da bleibt nicht viel spiel zum schalten.
                                        Ich dachte es wäre ne schönere Rampe zum abfragen.
                                        Also damit ich besser und genauer auswerten könnte.
                                        Die Sonne geht ja auch langsam weg und nicht so ruck artik.
                                        • M Maddin77
                                          @haselchen
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          @maddin77
                                          Also .
                                          Nimm den Datenpunkt wo null Minuten drin steht .
                                          Schreib da meinetwegen 5 rein ( Haken bei bestätigt nicht setzen).
                                          Vorher drückst Du am BWM den Pairingknopf.
                                          Dann blinkt er vorne rot.
                                          Dann drückst Du auf OK mit den 5minuten .
                                          Und in der Kachel sollte jetzt 5minutes stehen und im DP auch .
                                          Und nun beobachte nochmal das Verhalten mit der Helligkeit .
