  4. Test Adapter wireless-mbus v0.10.x
mbuswirelesswm-buswmbus
576 Beiträge 69 Kommentatoren 255.7k Aufrufe 55 Beobachtet
  • C Offline
    Chris87
    #530
    Hello together,
    I also just got my Key, after setup I received datas, than inserted the KEY and now I get this log:
    wireless-mbus.0
    2024-11-27 16:34:54.809	error	Unknown compact frame format
    wireless-mbus.0
    2024-11-27 16:33:18.972	error	Unknown compact frame format
    wireless-mbus.0
    2024-11-27 16:32:47.088	error	Unknown compact frame format
    wireless-mbus.0
    2024-11-27 16:30:55.743	error	Unknown compact frame format
    wireless-mbus.0
    2024-11-27 16:30:39.870	error	Unknown compact frame format
    wireless-mbus.0
    2024-11-27 16:30:36.076	info	IMST: Receiver set to CA-MODE
    wireless-mbus.0
    2024-11-27 16:30:35.995	info	starting. Version 0.9.4 in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v18.17.1, js-controller: 5.0.19
    wireless-mbus.0
    2024-11-27 16:30:31.113	info	terminating
    wireless-mbus.0
    2024-11-27 16:30:30.612	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    wireless-mbus.0
    2024-11-27 16:30:30.611	info	terminating
    wireless-mbus.0
    2024-11-27 16:30:30.610	info	Got terminate signal TERMINATE_YOURSELF
    wireless-mbus.0
    2024-11-27 16:30:19.031	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"01E28B17","pnpId":"usb-Silicon_Labs_WiMOD_iM871A-usb_01E28B17-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
    wireless-mbus.0
    2024-11-27 16:29:52.290	error	encrypted message and no aeskey provided
    wireless-mbus.0
    2024-11-27 16:29:35.961	info	IMST: Receiver set to CA-MODE
    any ideas?
    /Chris
    5x Wago 750-... as Modbus-master and slave with 420DIs/380DOs/ 20AI/DMX , 3x Alexa-Dot, R-Pi3 im MagicMirror, Intel NUC 10i7 64GbRAM / 2x 1Tb m.2 NVME und SSD mit PRoxmox/ IO Broker, InfluxDB, Grafana, MotionEye.
      Meldb
      #531
      ich benutzte seid heute auch diesen Adapter danke für die Tolle Arbeit.
      Ich lese damit meinen Wasserzähler Kamstrup FlowIQ2200 aus mit dem USB Stick nano CUL 868 MBUS funktioniert super.
      • L lvogt
        @chief42 said in Test Adapter wireless-mbus v0.9.x:
        Da der Empfänger "IMST iM871A" scheinbar nicht mehr zu bekommen ist würde ich gerne wissen, ob jemand schon den neuen IMST-Adapter "iU891A-XL - Wireless M-Bus USB-Adapter 868 MHz" zum Laufen gebracht hat und wenn ja wie.
        Falls der neue Empfänger nicht unterstützt wird wäre es toll, wenn dieses Modell auch im ioBroker unterstützt werden würde.
        Viele Grüße
        Chief42
        Auf den ersten Blick sieht das für mich nach einer völlig anderen Firmware auf dem Stick aus. Ich denke ohne explizite Unterstützung für die das neue Protokoll (HCI v1.x vs HCI 2.x) wird das nichts werden.
        @doubled said in Test Adapter wireless-mbus v0.9.x:
        Hallo
        Ich habe eine Schlüssel in der Form "AB-12345" für meine Wasserzähler bekommen.
        Kann die Länge richtig sein?
        In der Adaperbeschreibung steht 16 bzw. 32 Zeichen.
        Ne eigentlich das nicht sein. Der Key müsste 16 bytes lang sein. Üblicherweise dann als "Hex String" in 32 Zeichen ausgedrückt - in sehr seltenen Fälle als 16 Zeichen String da der Key tatsächlich nur "druckbare Bytes" enthält
        W Offline
        W Offline
        wutschkooo
        #532
        @lvogt Moin :-) Also gibt es aktuell keine Chance den iU891A-XL zum Leben zu erwecken? :-( Hätte genau den (auf gut Glück gekauft) und ein paar Wasserzähler von Zenner hier, die ich gerne irgendwie in den ioBroker integrieren möchte.
        • L Offline
          lvogt
          #533
          @wutschkooo
          Es gibt jetzt auf GitHub (nicht auf npm!) eine Version mit Unterstützung für den iU891A-XL. Das ist aktuell aber eine Version die ich ausschließlich anhand der Dokumentation geschrieben habe - das muss also unbedingt von jemanden auch mal mit echter Hardware getestet werden.
          Außerdem hätte ich gerne ein DEBUG(!) Log vom Start des Adapters und idealerweise auch mit Telegramm Empfang.
          C 1 Antwort Letzte Antwort
          • L lvogt
            @wutschkooo
            Chief42
            schrieb am zuletzt editiert von Chief42
            #534
            Hallo, ich hatte den Stick auch mal auf Verdacht gekauft. Allerdings scheitere ich scheinbar schon an der Durchreichung Proxmox > ioBroker.
            Ich habe einen Enocean Empfänger, der wird so erkannt:
            Demzufolge müsste der IMST Empfänger ttyUSB3 sein oder habe ich hier einen Denkfehler? Hatte aber auch die anderen Kombinationen ausprobiert.
            Das Debuglog habe ich auch erstellt mit ttyUSB3:
            2025-01-18 15:29:13.008	debug	connected set to false
            2025-01-18 15:29:12.963	error	Serialport error: Port is not open
            2025-01-18 15:29:12.963	error	Serialport error: Error: No such file or directory, cannot open /dev/ttyUSB3
            2025-01-18 15:29:12.962	debug	IMSTv2: TX: 0c010116070c
            2025-01-18 15:29:12.960	debug	Created device of type: IMST iU891A-XL
            2025-01-18 15:29:12.948	info	starting. Version 0.10.0 (non-npm: lvogt/ioBroker.wireless-mbus#a19974d14787e521c3094c150f6d947befeefffa) in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v18.17.1, js-controller: 7.0.3
            2025-01-18 15:29:12.921	debug	States connected to redis: 127.0.0.1:9000
            2025-01-18 15:29:12.875	debug	States create User PubSub Client
            2025-01-18 15:29:12.875	debug	States create System PubSub Client
            2025-01-18 15:29:12.872	debug	Redis States: Use Redis connection: 127.0.0.1:9000
            2025-01-18 15:29:12.865	debug	Objects connected to redis: 127.0.0.1:9001
            2025-01-18 15:29:12.864	debug	Objects client initialize lua scripts
            2025-01-18 15:29:12.855	debug	Objects create User PubSub Client
            2025-01-18 15:29:12.855	debug	Objects create System PubSub Client
            2025-01-18 15:29:12.855	debug	Objects client ready ... initialize now
            2025-01-18 15:29:12.847	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
            2025-01-18 15:29:09.456	info	terminating
            2025-01-18 15:29:08.954	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2025-01-18 15:29:08.954	info	terminating
            2025-01-18 15:29:08.954	info	Got terminate signal TERMINATE_YOURSELF
            ttyUSB2 liefert das zurück:
            2025-01-18 15:44:03.612	error	Serialport error: Error: No such file or directory, cannot open /dev/ttyUSB2
            In der Übersicht taucht der USB2/3 allerdings nicht auf trotz Neustart vom ioBroker
            L 1 Antwort Letzte Antwort
            • C Chief42
              lvogt
              #535
              @chief42
              Das sind Probleme die definitiv "vor dem Adapter" anfangen. Da kann ich dir nicht helfen.
              • L lvogt
                @chief42
                Chief42
                #536
                @lvogt, da bin ich mir jetzt nicht mehr so sicher ob es an der Durchreichung liegt. Ich muss zwar zugeben das ich von Linux keine Ahnung habe aber wenn ich das sehe, wird der Empfänger doch durchgereicht, nur mit einem anderen Namen als von mir vermutet:
                usb-devices
                T:  Bus=02 Lev=01 Prnt=01 Port=01 Cnt=02 Dev#=  3 Spd=12  MxCh= 0
                D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs=  1
                P:  Vendor=04b4 ProdID=0003 Rev=00.00
                S:  Manufacturer=IMST
                S:  Product=iU891A
                C:  #Ifs= 3 Cfg#= 1 Atr=80 MxPwr=200mA
                I:  If#=0x0 Alt= 0 #EPs= 1 Cls=02(commc) Sub=02 Prot=01 Driver=cdc_acm
                I:  If#=0x1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_acm
                I:  If#=0x2 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=05 Prot=00 Driver=(none)
                dmesg | grep tty
                dmesg: read kernel buffer failed: Die Operation ist nicht erlaubt
                iobuser@iobroker3:/$ find /sys/bus/usb/devices/usb*/ -name dev
                /sys/bus/usb/devices/usb1/dev
                /sys/bus/usb/devices/usb1/1-1/dev
                /sys/bus/usb/devices/usb1/1-1/1-1:1.0/0003:0627:0001.0001/input/input4/event3/dev
                /sys/bus/usb/devices/usb1/1-1/1-1:1.0/0003:0627:0001.0001/input/input4/mouse2/dev
                /sys/bus/usb/devices/usb1/1-1/1-1:1.0/0003:0627:0001.0001/hidraw/hidraw0/dev
                /sys/bus/usb/devices/usb2/2-1/2-1:1.0/ttyUSB0/tty/ttyUSB0/dev
                /sys/bus/usb/devices/usb2/2-1/dev
                /sys/bus/usb/devices/usb2/2-1/2-1:1.1/ttyUSB1/tty/ttyUSB1/dev
                /sys/bus/usb/devices/usb2/dev
                /sys/bus/usb/devices/usb2/2-2/dev
                /sys/bus/usb/devices/usb2/2-2/2-2:1.0/tty/ttyACM0/dev
                /sys/bus/usb/devices/usb3/dev
                So wie ich es interpretiere könnte der Empfänger unter "ttyACM0/dev" erreichbar sein. Das wird im Adapter zwar angezeigt als verfügbare Schnittstelle aber funktioniert nicht.
                Im Enocean Adapter taucht der Stick übrigens mit Namen auf.
                Das Durchreichen scheint also doch zu funktionieren.
                Ich bin gespannt ob @wutschkooo mehr Erfolg hat.
                • L Offline
                  lvogt
                  #537
                  @chief42
                  Die Fehler die da im Log auftauchen kommen direkt von der serialport Library. Da stimmt definitiv irgendwas nicht mit deinem Setup. Im Zweifelsfall könnte es auch irgendein Bug sein.
                  Im Github Repository gibt es jemand er evtl. mit diesem Bug hier zu kämpfen hat: https://github.com/serialport/node-serialport/issues/2735 - bei dir sieht es danach aber eher nicht aus...
                  • L Offline
                    lvogt
                    #538
                    v0.10.0 mit "ungetestem" Support für den iU819A Stick ist jetzt auf npm.
                    Ich hatte ja eigentlich gehofft es würde vorher hier noch eine Erfolgsmeldung geben, aber ich bin leider recht sicher, dass die bisher geposteten Probleme schon "vor ioBroker" anfangen.
                    Da für jemanden mit "altem" Receiver sollte die Version 0.10.0 aber sowieso keine Schwierigkeiten machen sollte, habe ich mich jetzt entschlossen die Version auch korrekt zu veröffentlichen.
                    N 1 Antwort Letzte Antwort
                    • L lvogt
                      N Offline
                      N Offline
                      Norb 0
                      #539
                      @lvogt
                      seit dem update auf v0.10.0 kommen bei mir sporadische Fehlermeldungen:
                      wMBus Empfänger ist ein serieller CUL, ausgelesen wird ein Axis Qalcosonic Wasserzähler. Mit der älteren Version (0.9.4) gab es bis dato keine Probleme. Ich bin jetzt wieder zurück auf v0.9.4 und beobachte ob der Fehler immer noch kommt, evtl. liegt die Ursache für diese Fehlermeldungen ja irgendwo anders.
                      Einstellungen der Instanz:
                      • N Offline
                        N Offline
                        Norb 0
                        #540
                        mit der v0.9.4 bis dato keine Fehlermeldungen, bin wieder zurück auf die v0.10.0 und beobachte weiter.
                        • G Offline
                          GammaWar
                          schrieb am zuletzt editiert von GammaWar
                          #541
                          habe zufälligerweise einen IU891A-XL. Bekomme folgendes im LOG:
                          P.S.
                          Mit wmbusmaster 1.18.0 funktioniert der Stick und ich empfange Packete und Werte
                          • L Offline
                            lvogt
                            schrieb am zuletzt editiert von lvogt
                            #542
                            Hm, dann mache ich evtl. etwas falsch bei öffnen des ttyACM0 Ports falsch.
                            Ich kann mal versuchen ob ich dazu irgendwas finde - aber evtl. komme ich hier ohne Hardware einfach nicht weiter...
                            kannst du evl. mal noch die Ausgaben von ls -l /dev/ttyACM0 und id posten?
                            G 1 Antwort Letzte Antwort
                            • L lvogt
                              GammaWar
                              #543
                              @lvogt sagte in Test Adapter wireless-mbus v0.10.x:
                              ls -l /dev/ttyACM0
                              crw-rw---- 1 root dialout 166, 0 11. Mär 21:44 /dev/ttyACM0
                              id
                              uid=0(root) gid=0(root) Gruppen=0(root),20(dialout),1001(wmbusmeters)
                              • G GammaWar
                                ls -l /dev/ttyACM0
                                id
                                lvogt
                                #544
                                @gammawar Aber root ist nicht der Account unter dem ioBroker läuft oder?
                                Was gibt cat /etc/group | grep dialout für eine Ausgabe?
                                Und läuft ioBroker evtl. im Docker Container?
                                • N Norb 0
                                  lvogt
                                  #545
                                  @norb-0 Läuft 0.10.0 jetzt auch stabil?
                                  • L lvogt
                                    GammaWar
                                    #546
                                    @lvogt
                                    gibt mir nichts aus. Bekomme nur eine neue Eungabezeile.
                                    Momentan läuft der IOBroker in einer Proxmox VM. Habe es aber auch schon dirket mit einem Pi4 versucht.
                                    • G GammaWar
                                      @lvogt
                                      lvogt
                                      #547
                                      @gammawar
                                      Das kann eigentlich nicht sein. Die Ausgabe des id Befehls sagt ja, dass mindestens root Mitglied der dialout Gruppe ist...
                                      • L lvogt
                                        @gammawar
                                        GammaWar
                                        #548
                                        @lvogt
                                        habe es gerade mit Putty versucht, jetzt kam dies raus:
                                        dialout❌20:wmbusmeters,iobroker,root
                                        vorher habe ich es über die Proxmoxshell gemacht. Da kommt komischerweise nichts.
                                        • L lvogt
                                          N Offline
                                          N Offline
                                          Norb 0
                                          #549
                                          ja, 0.10.0 läuft stabil, bis dato keine Fehlermeldungen
                                          pille0557P 1 Antwort Letzte Antwort
