  4. Test Adapter rpi2 2.x
520 Beiträge 29 Kommentatoren 230.0k Aufrufe 20 Beobachtet
  • S searcher57
    @thomas-braun said in Test Adapter rpi2 2.x:
    @searcher57 sagte in Test Adapter rpi2 2.x:
    Dann bitte:
    please report this issue to the adapter developer with the model of your device and deboug output from an adapter start
    Danke für Deine Mühe! Habe ich schon gemacht!
    Frohe Weihnachten!!
    GarfonsoG
    GarfonsoG
    Garfonso
    #292
    @searcher57
    debug log steht da. Bitte mal auf debug stellen und das log von nem Adapter start einfügen. Wenn wir Glück haben steht da was drinnen.... ansonsten hab ich spontan keine Idee, was da noch schief gehen soll. :-/
    Frohe Weihnachten trotzdem. :-)
    Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
    Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
    S 2 Antworten Letzte Antwort
    • GarfonsoG Garfonso
      @searcher57
      S
      S
      searcher57
      #293
      @garfonso said in Test Adapter rpi2 2.x:
      @searcher57
      Habe ich in GitHub schon gemacht, aber hier nochmal:
      rpi2.0
      	2024-12-24 11:25:59.212	warn	If the library is installed and npm list | grep opengpio shows the npm library is also installed, please report this issue to the adapter developer with the model of your device and deboug output from an adapter start.
      rpi2.0
      	2024-12-24 11:25:59.212	warn	Please make sure that libgpiod-dev (on raspian/debian run sudo apt install libgpiod-dev) is installed in the system and then reinstall the adapter.
      rpi2.0
      	2024-12-24 11:25:59.211	warn	Cannot initialize GPIO: No chip found. GPIO functionality disabled!
      rpi2.0
      	2024-12-24 11:25:58.956	info	starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.18.1, js-controller: 7.0.3
      rpi2.0
      	2024-12-24 11:25:51.507	info	terminating
      rpi2.0
      	2024-12-24 11:25:51.008	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      rpi2.0
      	2024-12-24 11:25:51.008	info	terminating
      rpi2.0
      	2024-12-24 11:25:51.006	info	Got terminate signal TERMINATE_YOURSELF
      Auch Dir frohe und besinnliche Weihnachten!
        @searcher57
        S
        S
        searcher57
        #294
        @searcher57
        So jetzt hab ich es!
        rpi2.0
        	2024-12-26 16:37:21.190	debug	wlan disabled -> clean up.
        rpi2.0
        	2024-12-26 16:37:21.190	debug	-1
        rpi2.0
        	2024-12-26 16:37:21.190	debug	CURRENT = wlan false
        rpi2.0
        	2024-12-26 16:37:21.190	debug	uptime disabled -> clean up.
        rpi2.0
        	2024-12-26 16:37:21.189	debug	-1
        rpi2.0
        	2024-12-26 16:37:21.189	debug	CURRENT = uptime false
        rpi2.0
        	2024-12-26 16:37:21.189	debug	temperature disabled -> clean up.
        rpi2.0
        rpi2.0
        	2024-12-26 16:37:21.189	debug	CURRENT = temperature false
        rpi2.0
        	2024-12-26 16:37:21.188	debug	swap disabled -> clean up.
        rpi2.0
        	2024-12-26 16:37:21.188	debug	-1
        rpi2.0
        	2024-12-26 16:37:21.188	debug	CURRENT = swap false
        rpi2.0
        	2024-12-26 16:37:21.188	debug	sdcard disabled -> clean up.
        rpi2.0
        rpi2.0
        	2024-12-26 16:37:21.188	debug	CURRENT = sdcard false
        rpi2.0
        	2024-12-26 16:37:21.141	debug	SETSTATE FOR rpi2.0.network.net_send VALUE = 37315299695
        rpi2.0
        	2024-12-26 16:37:21.141	debug	---> POST: for net_send in [object Object]
        rpi2.0
        	2024-12-26 16:37:21.089	debug	SETSTATE FOR rpi2.0.network.net_received VALUE = -32564790012
        rpi2.0
        	2024-12-26 16:37:21.089	debug	VALUE: 32564790012 POST: $1*-1
        rpi2.0
        	2024-12-26 16:37:21.089	debug	---> POST: $1*-1 for net_received in [object Object]
        rpi2.0
        	2024-12-26 16:37:21.089	debug	-1
        rpi2.0
        	2024-12-26 16:37:21.088	debug	CURRENT = network true
        rpi2.0
        	2024-12-26 16:37:21.041	debug	SETSTATE FOR rpi2.0.memory.memory_available VALUE = 5125.67
        rpi2.0
        	2024-12-26 16:37:21.041	debug	VALUE: 5248688 POST: $1/1024
        rpi2.0
        	2024-12-26 16:37:21.040	debug	---> POST: $1/1024 for memory_available in [object Object]
        rpi2.0
        	2024-12-26 16:37:20.993	debug	SETSTATE FOR rpi2.0.memory.memory_free VALUE = 1112.42
        rpi2.0
        	2024-12-26 16:37:20.993	debug	VALUE: 1139120 POST: $1/1024
        rpi2.0
        	2024-12-26 16:37:20.992	debug	---> POST: $1/1024 for memory_free in [object Object]
        rpi2.0
        	2024-12-26 16:37:20.945	debug	SETSTATE FOR rpi2.0.memory.memory_total VALUE = 8052.33
        rpi2.0
        	2024-12-26 16:37:20.945	debug	VALUE: 8245584 POST: $1/1024
        rpi2.0
        	2024-12-26 16:37:20.945	debug	---> POST: $1/1024 for memory_total in [object Object]
        rpi2.0
        	2024-12-26 16:37:20.944	debug	-1
        rpi2.0
        	2024-12-26 16:37:20.944	debug	CURRENT = memory true
        rpi2.0
        	2024-12-26 16:37:20.898	debug	SETSTATE FOR rpi2.0.raspberry.mem_gpu VALUE = 4
        rpi2.0
        	2024-12-26 16:37:20.897	debug	---> POST: for mem_gpu in [object Object]
        rpi2.0
        	2024-12-26 16:37:20.852	debug	SETSTATE FOR rpi2.0.raspberry.mem_arm VALUE = 1020
        rpi2.0
        	2024-12-26 16:37:20.852	debug	---> POST: for mem_arm in [object Object]
        rpi2.0
        	2024-12-26 16:37:20.805	debug	SETSTATE FOR rpi2.0.raspberry.cpu_voltage VALUE = 0.77
        rpi2.0
        	2024-12-26 16:37:20.804	debug	---> POST: for cpu_voltage in [object Object]
        rpi2.0
        	2024-12-26 16:37:20.804	debug	-1
        rpi2.0
        	2024-12-26 16:37:20.804	debug	CURRENT = raspberry true
        rpi2.0
        	2024-12-26 16:37:20.756	debug	SETSTATE FOR rpi2.0.cpu.scaling_governor VALUE = ondemand
        rpi2.0
        	2024-12-26 16:37:20.756	debug	---> POST: for scaling_governor in [object Object]
        rpi2.0
        	2024-12-26 16:37:20.712	debug	SETSTATE FOR rpi2.0.cpu.load15 VALUE = 0.21
        rpi2.0
        	2024-12-26 16:37:20.712	debug	NAME: load15 VALUE: 0.21
        rpi2.0
        	2024-12-26 16:37:20.712	debug	MATCHING: 0.21
        rpi2.0
        	2024-12-26 16:37:20.666	debug	SETSTATE FOR rpi2.0.cpu.load5 VALUE = 0.31
        rpi2.0
        	2024-12-26 16:37:20.665	debug	NAME: load5 VALUE: 0.31
        rpi2.0
        	2024-12-26 16:37:20.665	debug	MATCHING: 0.31
        rpi2.0
        	2024-12-26 16:37:20.620	debug	SETSTATE FOR rpi2.0.cpu.load1 VALUE = 0.48
        rpi2.0
        	2024-12-26 16:37:20.620	debug	NAME: load1 VALUE: 0.48
        rpi2.0
        	2024-12-26 16:37:20.620	debug	MATCHING: 0.48
        rpi2.0
        	2024-12-26 16:37:20.620	debug	---> POST: for load1,load5,load15 in [object Object]
        rpi2.0
        	2024-12-26 16:37:20.560	debug	SETSTATE FOR rpi2.0.cpu.cpu_frequency VALUE = 1600
        rpi2.0
        	2024-12-26 16:37:20.560	debug	VALUE: 1600000 POST: $1/1000
        rpi2.0
        	2024-12-26 16:37:20.560	debug	---> POST: $1/1000 for cpu_frequency in [object Object]
        rpi2.0
        	2024-12-26 16:37:20.560	debug	-1
        rpi2.0
        	2024-12-26 16:37:20.560	debug	CURRENT = cpu true
        rpi2.0
        	2024-12-26 16:37:20.560	debug	PARSING: wlan
        rpi2.0
        	2024-12-26 16:37:20.560	debug	PARSING: uptime
        rpi2.0
        	2024-12-26 16:37:20.559	debug	PARSING: temperature
        rpi2.0
        	2024-12-26 16:37:20.559	debug	PARSING: swap
        rpi2.0
        	2024-12-26 16:37:20.559	debug	PARSING: sdcard
        rpi2.0
        	2024-12-26 16:37:20.559	debug	---> POST:
        rpi2.0
        	2024-12-26 16:37:20.559	debug	GROUPS: 2
        rpi2.0
        	2024-12-26 16:37:20.559	debug	---> REGEXP: /(.*)/
        rpi2.0
        	2024-12-26 16:37:20.558	debug	------------- 37315299695
        rpi2.0
        	2024-12-26 16:37:20.556	debug	---> cat /sys/class/net/e*/statistics/tx_bytes
        rpi2.0
        	2024-12-26 16:37:20.556	debug	PARSING: net_send
        rpi2.0
        	2024-12-26 16:37:20.556	debug	---> POST: $1*-1
        rpi2.0
        	2024-12-26 16:37:20.555	debug	GROUPS: 2
        rpi2.0
        	2024-12-26 16:37:20.555	debug	---> REGEXP: /(.*)/
        rpi2.0
        	2024-12-26 16:37:20.555	debug	------------- 32564790012
        rpi2.0
        	2024-12-26 16:37:20.552	debug	---> cat /sys/class/net/e*/statistics/rx_bytes
        rpi2.0
        	2024-12-26 16:37:20.552	debug	PARSING: net_received
        rpi2.0
        	2024-12-26 16:37:20.552	debug	PARSING: network
        rpi2.0
        	2024-12-26 16:37:20.552	debug	---> POST: $1/1024
        rpi2.0
        	2024-12-26 16:37:20.552	debug	GROUPS: 2
        rpi2.0
        	2024-12-26 16:37:20.552	debug	---> REGEXP: /MemAvailable:\s+(\d+)/m
        rpi2.0
        	2024-12-26 16:37:20.551	debug	------------- MemTotal: 8245584 kB MemFree: 1138400 kB MemAvailable: 5248688 kB Buffers: 216192 kB Cached: 3800864 kB SwapCached: 208 kB Active: 3254944 kB Inactive: 3335408 kB Active(anon): 2575088 kB Inactive(anon): 0 kB Active(file): 679856 kB Inactive(file): 3335408 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 204784 kB SwapFree: 191472 kB Zswap: 0 kB Zswapped: 0 kB Dirty: 544 kB Writeback: 0 kB AnonPages: 2573280 kB Mapped: 240144 kB Shmem: 1792 kB KReclaimable: 259760 kB Slab: 306864 kB SReclaimable: 259760 kB SUnreclaim: 47104 kB KernelStack: 7760 kB PageTables: 145904 kB SecPageTables: 0 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 4327568 kB Committed_AS: 3961776 kB VmallocTotal: 68180246528 kB VmallocUsed: 19824 kB VmallocChunk: 0 kB Percpu: 1280 kB CmaTotal: 327680 kB CmaFree: 259904 kB
        rpi2.0
        	2024-12-26 16:37:20.549	debug	---> cat /proc/meminfo
        rpi2.0
        	2024-12-26 16:37:20.548	debug	PARSING: memory_available
        rpi2.0
        	2024-12-26 16:37:20.548	debug	---> POST: $1/1024
        rpi2.0
        	2024-12-26 16:37:20.548	debug	GROUPS: 2
        rpi2.0
        	2024-12-26 16:37:20.548	debug	---> REGEXP: /MemFree:\s+(\d+)/
        rpi2.0
        	2024-12-26 16:37:20.547	debug	------------- MemTotal: 8245584 kB MemFree: 1139120 kB MemAvailable: 5249408 kB Buffers: 216192 kB Cached: 3800864 kB SwapCached: 208 kB Active: 3254352 kB Inactive: 3335408 kB Active(anon): 2574496 kB Inactive(anon): 0 kB Active(file): 679856 kB Inactive(file): 3335408 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 204784 kB SwapFree: 191472 kB Zswap: 0 kB Zswapped: 0 kB Dirty: 544 kB Writeback: 0 kB AnonPages: 2572688 kB Mapped: 240144 kB Shmem: 1792 kB KReclaimable: 259760 kB Slab: 306864 kB SReclaimable: 259760 kB SUnreclaim: 47104 kB KernelStack: 7712 kB PageTables: 145904 kB SecPageTables: 0 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 4327568 kB Committed_AS: 3961776 kB VmallocTotal: 68180246528 kB VmallocUsed: 19792 kB VmallocChunk: 0 kB Percpu: 1280 kB CmaTotal: 327680 kB CmaFree: 259904 kB
        rpi2.0
        	2024-12-26 16:37:20.545	debug	---> cat /proc/meminfo
        rpi2.0
        	2024-12-26 16:37:20.545	debug	PARSING: memory_free
        rpi2.0
        	2024-12-26 16:37:20.545	debug	---> POST: $1/1024
        rpi2.0
        	2024-12-26 16:37:20.545	debug	GROUPS: 2
        rpi2.0
        	2024-12-26 16:37:20.544	debug	---> REGEXP: /MemTotal:\s+(\d+)/
        rpi2.0
        	2024-12-26 16:37:20.544	debug	------------- MemTotal: 8245584 kB MemFree: 1139120 kB MemAvailable: 5249408 kB Buffers: 216192 kB Cached: 3800864 kB SwapCached: 208 kB Active: 3254352 kB Inactive: 3335408 kB Active(anon): 2574496 kB Inactive(anon): 0 kB Active(file): 679856 kB Inactive(file): 3335408 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 204784 kB SwapFree: 191472 kB Zswap: 0 kB Zswapped: 0 kB Dirty: 544 kB Writeback: 0 kB AnonPages: 2572688 kB Mapped: 240144 kB Shmem: 1792 kB KReclaimable: 259760 kB Slab: 306864 kB SReclaimable: 259760 kB SUnreclaim: 47104 kB KernelStack: 7712 kB PageTables: 145312 kB SecPageTables: 0 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 4327568 kB Committed_AS: 3961776 kB VmallocTotal: 68180246528 kB VmallocUsed: 19792 kB VmallocChunk: 0 kB Percpu: 1280 kB CmaTotal: 327680 kB CmaFree: 259904 kB
        rpi2.0
        	2024-12-26 16:37:20.541	debug	---> cat /proc/meminfo
        rpi2.0
        	2024-12-26 16:37:20.541	debug	PARSING: memory_total
        rpi2.0
        	2024-12-26 16:37:20.540	debug	PARSING: memory
        rpi2.0
        	2024-12-26 16:37:20.540	debug	---> POST:
        rpi2.0
        	2024-12-26 16:37:20.540	debug	GROUPS: 2
        rpi2.0
        	2024-12-26 16:37:20.540	debug	---> REGEXP: /(\d+)/
        rpi2.0
        	2024-12-26 16:37:20.539	debug	------------- gpu=4M
        rpi2.0
        	2024-12-26 16:37:20.535	debug	---> vcgencmd get_mem gpu
        rpi2.0
        	2024-12-26 16:37:20.535	debug	PARSING: mem_gpu
        rpi2.0
        	2024-12-26 16:37:20.535	debug	---> POST:
        rpi2.0
        	2024-12-26 16:37:20.535	debug	GROUPS: 2
        rpi2.0
        	2024-12-26 16:37:20.535	debug	---> REGEXP: /(\d+)/
        rpi2.0
        	2024-12-26 16:37:20.535	debug	------------- arm=1020M
        rpi2.0
        	2024-12-26 16:37:20.531	debug	---> vcgencmd get_mem arm
        rpi2.0
        	2024-12-26 16:37:20.531	debug	PARSING: mem_arm
        rpi2.0
        	2024-12-26 16:37:20.531	debug	---> POST:
        rpi2.0
        	2024-12-26 16:37:20.531	debug	GROUPS: 2
        rpi2.0
        	2024-12-26 16:37:20.530	debug	---> REGEXP: /(\d+.\d+)V/
        rpi2.0
        	2024-12-26 16:37:20.530	debug	------------- volt=0.7659V
        rpi2.0
        	2024-12-26 16:37:20.526	debug	---> vcgencmd measure_volts core
        rpi2.0
        	2024-12-26 16:37:20.526	debug	PARSING: cpu_voltage
        rpi2.0
        	2024-12-26 16:37:20.526	debug	PARSING: raspberry
        rpi2.0
        	2024-12-26 16:37:20.526	debug	---> POST:
        rpi2.0
        	2024-12-26 16:37:20.526	debug	GROUPS: 2
        rpi2.0
        	2024-12-26 16:37:20.526	debug	---> REGEXP: /(.*)/
        rpi2.0
        	2024-12-26 16:37:20.525	debug	------------- ondemand
        rpi2.0
        	2024-12-26 16:37:20.522	debug	---> cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
        rpi2.0
        	2024-12-26 16:37:20.522	debug	PARSING: scaling_governor
        rpi2.0
        	2024-12-26 16:37:20.522	debug	NAME: load15, VALULE: 0.21
        rpi2.0
        	2024-12-26 16:37:20.522	debug	MATCHING: 0.21
        rpi2.0
        	2024-12-26 16:37:20.522	debug	NAME: load5, VALULE: 0.31
        rpi2.0
        	2024-12-26 16:37:20.522	debug	MATCHING: 0.31
        rpi2.0
        	2024-12-26 16:37:20.522	debug	NAME: load1, VALULE: 0.48
        rpi2.0
        	2024-12-26 16:37:20.521	debug	MATCHING: 0.48
        rpi2.0
        	2024-12-26 16:37:20.521	debug	GROUPS: 4
        rpi2.0
        	2024-12-26 16:37:20.521	debug	---> REGEXP: /^(\S+)\s(\S+)\s(\S+)/
        rpi2.0
        	2024-12-26 16:37:20.521	debug	------------- 0.48 0.31 0.21 1/480 1339934
        rpi2.0
        	2024-12-26 16:37:20.518	debug	---> cat /proc/loadavg
        rpi2.0
        	2024-12-26 16:37:20.518	debug	PARSING: load1,load5,load15
        rpi2.0
        	2024-12-26 16:37:20.518	debug	---> POST: $1/1000
        rpi2.0
        	2024-12-26 16:37:20.518	debug	GROUPS: 2
        rpi2.0
        	2024-12-26 16:37:20.518	debug	---> REGEXP: /(.*)/
        rpi2.0
        	2024-12-26 16:37:20.517	debug	------------- 1600000
        rpi2.0
        	2024-12-26 16:37:20.515	debug	---> test -r /sys/devices/system/cpu/cpufreq/policy0/cpuinfo_cur_freq && cat /sys/devices/system/cpu/cpufreq/policy0/cpuinfo_cur_freq || test -r /sys/devices/system/cpu/cpufreq/policy0/scaling_cur_freq && cat /sys/devices/system/cpu/cpufreq/policy0/scaling_cur_freq || echo -1000
        rpi2.0
        	2024-12-26 16:37:20.515	debug	PARSING: cpu_frequency
        rpi2.0
        	2024-12-26 16:37:20.514	debug	PARSING: cpu
        rpi2.0
        	2024-12-26 16:37:20.514	debug	start parsing
        rpi2.0
        	2024-12-26 16:36:21.272	debug	GPIO chip undefined initialized
        rpi2.0
        	2024-12-26 16:36:21.272	debug	Got chip: undefined
        rpi2.0
        	2024-12-26 16:36:21.271	warn	If the library is installed and npm list | grep opengpio shows the npm library is also installed, please report this issue to the adapter developer with the model of your device and deboug output from an adapter start.
        rpi2.0
        	2024-12-26 16:36:21.271	warn	Please make sure that libgpiod-dev (on raspian/debian run sudo apt install libgpiod-dev) is installed in the system and then reinstall the adapter.
        rpi2.0
        	2024-12-26 16:36:21.271	warn	Cannot initialize GPIO: No chip found. GPIO functionality disabled!
        rpi2.0
        	2024-12-26 16:36:21.271	debug	Using GPIO chip 4 for Raspberry Pi 5 or newer.
        rpi2.0
        	2024-12-26 16:36:21.271	debug	Got 5 from Raspberry Pi 5 Model B Rev 1.0
        Z GarfonsoG 2 Antworten Letzte Antwort
        • S searcher57
          @searcher57
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          rpi2.0
          Z
          Z
          Zimbl
          #295
          ich würde mich gerne auch an diesem Thema anschließen, ich habe genau das gleiche Problem, ich kann
          diese GPIO nicht ansteuern, wenn ich das Probiere, dann wird der Ausgang bzw. in dem Fall True/False rot.
          Den Adapter habe ich bereits einmal De-Installiert und dann wieder Installiert.
          Aber immer noch alles ohne Erfolg.
          Anbei mein Diag :
          ```bash
          Script v.2024-10-19
          *** BASE SYSTEM ***
           Static hostname: raspihome
                 Icon name: computer
                    Kernel: Linux 6.6.62+rpt-rpi-2712
              Architecture: arm64
          OS is similar to:
          Model           : Raspberry Pi 5 Model B Rev 1.0
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           10:47:05 up 7 min,  2 users,  load average: 1.06, 0.49, 0.25
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'bookworm'!
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** TIME AND TIMEZONES ***
                         Local time: Sat 2024-12-28 10:47:05 CET
                     Universal time: Sat 2024-12-28 09:47:05 UTC
                           RTC time: Sat 2024-12-28 09:47:05
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
          iobroker
          HOME=/home/iobroker
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            4.2G        1.4G        2.0G        5.8M        998M        2.9G
          Swap:           202M          0B        202M
          Total:          4.4G        1.4G        2.2G
          Active iob-Instances:   7
                   4045 M total memory
                   1300 M used memory
                   1327 M active memory
                    629 M inactive memory
                   1862 M free memory
                     69 M buffer memory
                    883 M swap cache
                    192 M total swap
                      0 M used swap
                    192 M free swap
          top - 10:47:05 up 7 min,  2 users,  load average: 1.06, 0.49, 0.25
          Tasks: 175 total,   1 running, 174 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   4045.0 total,   1862.7 free,   1300.6 used,    952.3 buff/cache
          MiB Swap:    193.0 total,    193.0 free,      0.0 used.   2744.4 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          udev           devtmpfs  2.0G     0  2.0G   0% /dev
          tmpfs          tmpfs     405M  5.4M  400M   2% /run
          /dev/mmcblk0p2 ext4      6.9G  6.3G  182M  98% /
          tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
          tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
          /dev/mmcblk0p1 vfat      510M   65M  446M  13% /boot/firmware
          tmpfs          tmpfs     405M   16K  405M   1% /run/user/1000
          [Sat Dec 28 10:39:15 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:97:18:01 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=918bb801-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=GB cfg80211.ieee80211_regdom=GB
          [Sat Dec 28 10:39:17 2024] EXT4-fs (mmcblk0p2): mounted filesystem 3b445224-0aeb-4897-9108-009ed4211fb4 ro with ordered data mode. Quota mode: none.
          [Sat Dec 28 10:39:19 2024] EXT4-fs (mmcblk0p2): re-mounted 3b445224-0aeb-4897-9108-009ed4211fb4 r/w. Quota mode: none.
          Show mounted filesystems:
          TARGET           SOURCE         FSTYPE OPTIONS
          /                /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          950M    /var/
          445M    /var/cache
          431M    /var/cache/apt
          317M    /var/cache/apt/archives
          185M    /var/lib
          Archived and active journals take up 120.5M in the file system.
          /opt/iobroker/backups:
          18M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          856M    /opt/iobroker/iobroker-data/
          772M    /opt/iobroker/iobroker-data/files
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          37M     /opt/iobroker/iobroker-data/objects.jsonl
          25M     /opt/iobroker/iobroker-data/files/wireless-settings.admin/static/js/main.fe851d24.js.map
          24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
          12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
          11M     /opt/iobroker/iobroker-data/files/wireless-settings.admin/static/js/main.fe851d24.js
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ceccc8e6cbc9eb119edf8b4f1d69213e-if00-port0
          HINT:
          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
          /dev/ttyUSB0
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.18.1
          /usr/bin/node           v20.18.1
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.4
          nodejs:
            Installed: 20.18.1-1nodesource1
            Candidate: 20.18.1-1nodesource1
            Version table:
           *** 20.18.1-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
               20.18.0-1nodesource1 1001
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
                  500 http://deb.debian.org/debian bookworm/main arm64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          raspihome        raspihome (version: 6.0.11, hostname: raspihome   , alive, uptime: 31)
          Core adapters versions
          js-controller:  6.0.11
          admin:          7.1.5
          javascript:     8.8.3
          nodejs modules from github:     0
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspihome                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          + system.adapter.backitup.0               : backitup              : raspihome                              -  enabled
            system.adapter.discovery.0              : discovery             : raspihome                              -  enabled
          + system.adapter.javascript.0             : javascript            : raspihome                              -  enabled
            system.adapter.modbus.0                 : modbus                : raspihome                              -  enabled
            system.adapter.rpi2.0                   : rpi2                  : raspihome                              -  enabled
          + system.adapter.shelly.0                 : shelly                : raspihome                              -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.terminal.0               : terminal              : raspihome                              -  enabled, port: 8088, bind: 0.0.0.0 (SSL), run as: admin
          + system.adapter.tuya.0                   : tuya                  : raspihome                              -  enabled
            system.adapter.welcome.0                : welcome               : raspihome                              -  enabled, port: 80, bind: 0.0.0.0, run as: admin
            system.adapter.wireless-settings.0      : wireless-settings     : raspihome                              - disabled
          + system.adapter.zigbee.0                 : zigbee                : raspihome                              -  enabled, port: /dev/ttyUSB0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.1.5    , installed 7.1.5
          Adapter    "backitup"     : 3.0.25   , installed 3.0.25
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 6.0.11 [Updatable]
          Adapter    "modbus"       : 6.3.2    , installed 6.3.2
          Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
          Adapter    "shelly"       : 8.2.1    , installed 8.2.1
          Adapter    "terminal"     : 1.0.0    , installed 1.0.0
          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
          Adapter    "welcome"      : 1.0.2    , installed 1.0.2
          Adapter    "wireless-settings": 1.0.2, installed 1.0.2
          Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
          Objects and States
          Objects:        815
          States:         616
          Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6337       760/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19159      4186/iobroker.js-co
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19164      4186/iobroker.js-co
          tcp6       0      0 :::80                   :::*                    LISTEN      1001       22054      4711/io.welcome.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          6339       760/sshd: /usr/sbin
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19205      4206/io.admin.0
          tcp6       0      0 :::8088                 :::*                    LISTEN      1001       22139      4757/io.terminal.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       22600      4366/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       22601      4366/io.tuya.0
          udp        0      0 0.0.0.0:38105           0.0.0.0:*                           104        656        604/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        654        604/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       20981      4299/io.shelly.0
          udp6       0      0 :::34920                :::*                                104        657        604/avahi-daemon: r
          udp6       0      0 fe80::9fc3:98f7:bf5:546 :::*                                0          6430       711/NetworkManager
          udp6       0      0 fe80::4bfa:4f8a:169:546 :::*                                0          875        711/NetworkManager
          udp6       0      0 :::5353                 :::*                                104        655        604/avahi-daemon: r
          • Z Zimbl
            Anbei mein Diag :
            ```bash
            Script v.2024-10-19
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
            CPU threads: 4
            Current issues:
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:           202M          0B        202M
                     4045 M total memory
                     1300 M used memory
                     1862 M free memory
                       69 M buffer memory
                      883 M swap cache
                      192 M total swap
                        0 M used swap
                      192 M free swap
            *** FILESYSTEM ***
            /var:
            950M    /var/
            445M    /var/cache
            431M    /var/cache/apt
            185M    /var/lib
            USB-Devices by-id:
            HINT:
            /dev/ttyUSB0
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.1.5
            javascript:     8.8.3
            Adapter State
            + instance is alive
            Objects and States
            Objects:        815
            States:         616
            Pending Updates: 0
            Thomas BraunT
            Thomas BraunT
            Most Active Developer
            #296
            @zimbl sagte in Test Adapter rpi2 2.x:
            Auf Stand bringen.
            Z 1 Antwort Letzte Antwort
              Auf Stand bringen.
              Z
              Z
              Zimbl
              #297
              oh da habe ich schlechte Erfahrung mit gemacht, diese akt. durchzuführen.
              Kannst du mir genau sagen, wie ich da am besten vorgehe ?
              Hatte da mal eine Anleitung aus dem Netz gehabt und alles ging irgendwie schief was schief gehen konnte :-)
              • Z Zimbl
                Thomas BraunT
                Thomas BraunT
                #298
                Und ich habe schlechte Erfahrungen mit ungepflegten Kisten gemacht.
                iob stop
                iob update
                iob upgrade self
                iob start
                Fertig.
                  iob stop
                  iob update
                  iob upgrade self
                  iob start
                  Fertig.
                  Z
                  Z
                  Zimbl
                  #299
                  nein ich meine damit irgendwelche Anleitungen im Netz zu nehmen, wusste jetzt nicht, das es auch einfach mit dem Standard möglich ist, weil ich hatte den schon durchgeführt...aber hatte der das wohl nicht gemacht...
                  vielen Dank Thomas...
                  • Z Zimbl
                    Thomas BraunT
                    Thomas BraunT
                    #300
                    @zimbl
                    'Der' macht das aber nicht ohne Meldungen...
                    Die 'der' Admin dann liest.
                      @zimbl
                      Z
                      Z
                      Zimbl
                      #301
                      ja aber jetzt habe ich das alles aktualisiert...und es ist aber immer noch so, wenn ich einen GPIO Ansteuern möchte, wird der Befehl TRUE or FALSE ....ROT...nicht Grün...wie sonst...
                      was kann ich nun noch machen ?
                      • Z Zimbl
                        Thomas BraunT
                        Thomas BraunT
                        #302
                        Abwarten.
                        Und/oder bei GitHub evtl. zum passenden Issue weitere Erkenntnisse beitragen.
                        • Z
                          Z
                          Zimbl
                          #303
                          ist es eigentlich möglich einen alten RPI2 Adapter zu installieren ?
                          • Z Zimbl
                            Thomas BraunT
                            Thomas BraunT
                            #304
                            @zimbl
                            Wozu? Der funktioniert ja dann noch weniger als der aktuelle. Der Adapter musste ja genau deswegen angepasst werden, weil der an mehrere Stellen nicht mehr funktionierte.
                              @zimbl
                              Z
                              Z
                              Zimbl
                              #305
                              achso ok, das wusste ich nicht. Weil mit dem alten PI2 hatte ich keine Probleme.
                              Ich habe nun jetzt aufgerüstet und siehe da, es geht gerade noch weniger.
                              Aber gut, dann Abwarten...
                              • Z Zimbl
                                #306
                                es ist nicht der Pi2 oder 5, sondern das komplett neu gestrickte Betriebssystem, das mit Bookworm kam.
                                • S
                                  S
                                  Smallfeuer
                                  #307
                                  Also bei mir geht jetzt auf dem Pi3 nichts mehr.
                                  Alles bereinigt, Adapter gelöscht, Update und upgrade & IOB update -> alles erledigt.
                                  GPIO kann ich auch nicht mehr manuell auslesen .. gpio readall bringt kein ergebnis
                                  Ideen?
                                  rpi2.0
                                  2024-12-29 20:09:32.163	warn	If the library is installed and npm list | grep opengpio shows the npm library is also installed, please report this issue to the adapter developer with the model of your device and deboug output from an adapter start.
                                  rpi2.0
                                  2024-12-29 20:09:32.161	warn	Please make sure that libgpiod-dev (on raspian/debian run sudo apt install libgpiod-dev) is installed in the system and then reinstall the adapter.
                                  rpi2.0
                                  2024-12-29 20:09:32.158	warn	Cannot initialize GPIO: No chip found. GPIO functionality disabled!
                                  rpi2.0
                                  2024-12-29 20:09:29.021	info	starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v18.17.1, js-controller: 7.0.6
                                  rpi2.0
                                  2024-12-29 20:09:11.869	info	terminating
                                  rpi2.0
                                  2024-12-29 20:09:11.374	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  rpi2.0
                                  2024-12-29 20:09:11.369	info	terminating
                                  rpi2.0
                                  2024-12-29 20:09:11.362	info	Got terminate signal TERMINATE_YOURSELF
                                  rpi2.0
                                  2024-12-29 20:08:40.966	info	GPIO ports are not configured
                                  rpi2.0
                                  2024-12-29 20:08:36.489	info	starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v18.17.1, js-controller: 7.0.6
                                  rpi2.0
                                  2024-12-29 15:55:32.670	info	terminating
                                  rpi2.0
                                  2024-12-29 15:55:32.174	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  rpi2.0
                                  2024-12-29 15:55:32.171	info	terminating
                                  rpi2.0
                                  2024-12-29 15:55:32.165	info	Got terminate signal TERMINATE_YOURSELF
                                  • S Smallfeuer
                                    Ideen?
                                    rpi2.0
                                    rpi2.0
                                    rpi2.0
                                    rpi2.0
                                    rpi2.0
                                    rpi2.0
                                    rpi2.0
                                    rpi2.0
                                    rpi2.0
                                    rpi2.0
                                    rpi2.0
                                    rpi2.0
                                    rpi2.0
                                    rpi2.0
                                    S
                                    S
                                    Smallfeuer
                                    #308
                                    @smallfeuer sagte in Test Adapter rpi2 2.x:
                                    pi@Pi3IOBrokerGarage:~ $ sudo apt-get update && sudo apt-get upgrade
                                    Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                                    OK:2 https://deb.nodesource.com/node_18.x buster InRelease
                                    OK:3 http://archive.raspberrypi.org/debian buster InRelease
                                    Es wurden 15,0 kB in 1 s geholt (11,3 kB/s).
                                    Paketaktualisierung (Upgrade) wird berechnet... Fertig
                                    0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                    pi@Pi3IOBrokerGarage:~ $ sudo apt-get install -y build-essential python
                                    build-essential ist schon die neueste Version (12.6).
                                    python ist schon die neueste Version (2.7.16-1).
                                    pi@Pi3IOBrokerGarage:~ $ sudo apt-get install -y libgpiod-dev
                                    libgpiod-dev ist schon die neueste Version (1.2-3+rpi1).
                                    • S Smallfeuer
                                      Thomas BraunT
                                      Thomas BraunT
                                      #309
                                      @smallfeuer
                                      Buster ist ZU ALT!!!
                                      Seit Jahren tot. Beerdige das Ding.
                                        @smallfeuer
                                        S
                                        S
                                        Smallfeuer
                                        #310
                                        @thomas-braun Also das Gesamte System platt machen und was (?) raufspielen? Sorry, es gibt echt so viele Versionen. Der Pi läuft nur im Slave. Normalerweise sollte es total egal sein, welches System...aber gut. Was muss auf die SD Karte?
                                        • S Smallfeuer
                                          Thomas BraunT
                                          Thomas BraunT
                                          #311
                                          Nein, ist es nicht...
                                          https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                          84.1k
