  4. Test Adapter rpi2 2.x
    1.5k
519 Beiträge 29 Kommentatoren 212.4k Aufrufe 20 Beobachtet
    @searcher57 sagte in Test Adapter rpi2 2.x:
    Adapter gerade neu installiert, ohne Erfolg!
    bist du sicher?
    nicht nur die Instanz neu erstellt?
    S
    S
    searcher57
    #285
    @homoran said in Test Adapter rpi2 2.x:
    bist du sicher?
    Ja, bin mir sicher. Den Adapter gelöscht und über beta neu installiert und konfiguriert.
    • S searcher57
      @searcher57 said in Test Adapter rpi2 2.x:
      @thomas-braun said in Test Adapter rpi2 2.x:
      @searcher57
      Und was verrät
      cd /opt/iobroker/ && npm ls opengpio
      pi@Raspi58GB:~ $ cd /opt/iobroker/ && npm ls opengpio
      iobroker.inst@3.0.0 /opt/iobroker
      └─┬ iobroker.rpi2@2.2.2
        └── opengpio@1.0.17
      pi@Raspi58GB:/opt/iobroker $
      Hier nochmal das Protokoll:
      pi2.0
      	2024-12-22 16:20:54.990	warn	If the library is installed and npm list | grep opengpio shows the npm library is also installed, please report this issue to the adapter developer with the model of your device and deboug output from an adapter start.
      rpi2.0
      	2024-12-22 16:20:54.990	warn	Please make sure that libgpiod-dev (on raspian/debian run sudo apt install libgpiod-dev) is installed in the system and then reinstall the adapter.
      rpi2.0
      	2024-12-22 16:20:54.989	warn	Cannot initialize GPIO: No chip found. GPIO functionality disabled!
      rpi2.0
      	2024-12-22 16:20:54.675	info	starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.18.1, js-controller: 7.0.3
      rpi2.0
      	2024-12-22 16:20:50.340	info	terminating
      rpi2.0
      	2024-12-22 16:20:49.841	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      rpi2.0
      	2024-12-22 16:20:49.840	info	terminating
      rpi2.0
      	2024-12-22 16:20:49.839	info	Got terminate signal TERMINATE_YOURSELF
      rpi2.0
      	2024-12-22 16:19:27.683	info	GPIO ports are not configured
      rpi2.0
      	2024-12-22 16:19:26.628	info	starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.18.1, js-controller: 7.0.3
      rpi2.0
      	2024-12-22 16:16:33.859	info	terminating
      rpi2.0
      	2024-12-22 16:16:33.359	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      rpi2.0
      	2024-12-22 16:16:33.359	info	terminating
      rpi2.0
      	2024-12-22 16:16:33.358	info	Got terminate signal TERMINATE_YOURSELF
      rpi2.0
      	2024-12-22 16:05:28.448	warn	If the library is installed and npm list | grep opengpio shows the npm library is also installed, please report this issue to the adapter developer with the model of your device and deboug output from an adapter start.
      rpi2.0
      	2024-12-22 16:05:28.448	warn	Please make sure that libgpiod-dev (on raspian/debian run sudo apt install libgpiod-dev) is installed in the system and then reinstall the adapter.
      Thomas BraunT
      Thomas BraunT
      #286
      Dann bitte:
        Dann bitte:
        S
        S
        searcher57
        #287
        Dann bitte:
        Danke für Deine Mühe! Habe ich schon gemacht!
        Frohe Weihnachten!!
        Thomas BraunT GarfonsoG 2 Antworten Letzte Antwort
        • S searcher57
          Dann bitte:
          Frohe Weihnachten!!
          Thomas BraunT
          Thomas BraunT
          #288
          @searcher57
          Hier?
          https://github.com/iobroker-community-adapters/ioBroker.rpi2/issues
            @searcher57
            Hier?
            S
            S
            searcher57
            #289
            @searcher57
            Hier?
            Nein, mache ich!
            • MoppedmanM Moppedman
              @garfonso Erst man vielen Dank das du das Startverhalten anpassen willst. Wenn du das fertig hast teste ich das gerne für dich. Einfach nur melden
              Hinsichtlich des Freischalten verstehe ich jetzt, das weder im alten noch im neunen Adapter die Ausgänge zurückgeschaltet werden.
              Kann es sein das im Betriebssystem für die GPIOs dieses Verhalten hinterlegt ist. Wenn ich das richtig gelesen habe wurden die GPIO von der Pi Foundation völlig neu aufgesetzt.
              GarfonsoG
              GarfonsoG
              Garfonso
              #290
              @moppedman
              Gerne die 2.3.0 testen, die bald im latest / auf npm erscheinen sollte.
              Da habe ich es jetzt so angepasst, dass Einfach nur Ausgang gar nicht beim starten gesetzt wird und die mit Startwert entsprechend einmal beim starten gesetzt werden, egal was jeweils im state (noch) steht.
              Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
              Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
              MoppedmanM 1 Antwort Letzte Antwort
                GarfonsoG
                GarfonsoG
                Garfonso
                #291
                @moppedman said in Test Adapter rpi2 2.x:
                Ja, das ist meine Vermutung, dass es daran liegt. Ich habe extra nochmal in die alte Bibliothek reingeguckt, ob die da irgendwas macht. Aber da passiert beim beenden überall nichts.
                Wenn das wichtig ist, könnte man das vielleicht als zusätzlichen Konfigurationsparameter beim Ausgang mit dazu geben.
                • S searcher57
                  Dann bitte:
                  Frohe Weihnachten!!
                  GarfonsoG
                  GarfonsoG
                  Garfonso
                  #292
                  @searcher57
                  debug log steht da. Bitte mal auf debug stellen und das log von nem Adapter start einfügen. Wenn wir Glück haben steht da was drinnen.... ansonsten hab ich spontan keine Idee, was da noch schief gehen soll. :-/
                  Frohe Weihnachten trotzdem. :-)
                  S 2 Antworten Letzte Antwort
                  • GarfonsoG Garfonso
                    @searcher57
                    S
                    S
                    searcher57
                    #293
                    @garfonso said in Test Adapter rpi2 2.x:
                    @searcher57
                    Habe ich in GitHub schon gemacht, aber hier nochmal:
                    rpi2.0
                    	2024-12-24 11:25:59.212	warn	If the library is installed and npm list | grep opengpio shows the npm library is also installed, please report this issue to the adapter developer with the model of your device and deboug output from an adapter start.
                    rpi2.0
                    	2024-12-24 11:25:59.212	warn	Please make sure that libgpiod-dev (on raspian/debian run sudo apt install libgpiod-dev) is installed in the system and then reinstall the adapter.
                    rpi2.0
                    	2024-12-24 11:25:59.211	warn	Cannot initialize GPIO: No chip found. GPIO functionality disabled!
                    rpi2.0
                    	2024-12-24 11:25:58.956	info	starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.18.1, js-controller: 7.0.3
                    rpi2.0
                    	2024-12-24 11:25:51.507	info	terminating
                    rpi2.0
                    	2024-12-24 11:25:51.008	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    rpi2.0
                    	2024-12-24 11:25:51.008	info	terminating
                    rpi2.0
                    	2024-12-24 11:25:51.006	info	Got terminate signal TERMINATE_YOURSELF
                    Auch Dir frohe und besinnliche Weihnachten!
                      @searcher57
                      S
                      S
                      searcher57
                      #294
                      @searcher57
                      So jetzt hab ich es!
                      rpi2.0
                      	2024-12-26 16:37:21.190	debug	wlan disabled -> clean up.
                      rpi2.0
                      	2024-12-26 16:37:21.190	debug	-1
                      rpi2.0
                      	2024-12-26 16:37:21.190	debug	CURRENT = wlan false
                      rpi2.0
                      	2024-12-26 16:37:21.190	debug	uptime disabled -> clean up.
                      rpi2.0
                      	2024-12-26 16:37:21.189	debug	-1
                      rpi2.0
                      	2024-12-26 16:37:21.189	debug	CURRENT = uptime false
                      rpi2.0
                      	2024-12-26 16:37:21.189	debug	temperature disabled -> clean up.
                      rpi2.0
                      rpi2.0
                      	2024-12-26 16:37:21.189	debug	CURRENT = temperature false
                      rpi2.0
                      	2024-12-26 16:37:21.188	debug	swap disabled -> clean up.
                      rpi2.0
                      	2024-12-26 16:37:21.188	debug	-1
                      rpi2.0
                      	2024-12-26 16:37:21.188	debug	CURRENT = swap false
                      rpi2.0
                      	2024-12-26 16:37:21.188	debug	sdcard disabled -> clean up.
                      rpi2.0
                      rpi2.0
                      	2024-12-26 16:37:21.188	debug	CURRENT = sdcard false
                      rpi2.0
                      	2024-12-26 16:37:21.141	debug	SETSTATE FOR rpi2.0.network.net_send VALUE = 37315299695
                      rpi2.0
                      	2024-12-26 16:37:21.141	debug	---> POST: for net_send in [object Object]
                      rpi2.0
                      	2024-12-26 16:37:21.089	debug	SETSTATE FOR rpi2.0.network.net_received VALUE = -32564790012
                      rpi2.0
                      	2024-12-26 16:37:21.089	debug	VALUE: 32564790012 POST: $1*-1
                      rpi2.0
                      	2024-12-26 16:37:21.089	debug	---> POST: $1*-1 for net_received in [object Object]
                      rpi2.0
                      	2024-12-26 16:37:21.089	debug	-1
                      rpi2.0
                      	2024-12-26 16:37:21.088	debug	CURRENT = network true
                      rpi2.0
                      	2024-12-26 16:37:21.041	debug	SETSTATE FOR rpi2.0.memory.memory_available VALUE = 5125.67
                      rpi2.0
                      	2024-12-26 16:37:21.041	debug	VALUE: 5248688 POST: $1/1024
                      rpi2.0
                      	2024-12-26 16:37:21.040	debug	---> POST: $1/1024 for memory_available in [object Object]
                      rpi2.0
                      	2024-12-26 16:37:20.993	debug	SETSTATE FOR rpi2.0.memory.memory_free VALUE = 1112.42
                      rpi2.0
                      	2024-12-26 16:37:20.993	debug	VALUE: 1139120 POST: $1/1024
                      rpi2.0
                      	2024-12-26 16:37:20.992	debug	---> POST: $1/1024 for memory_free in [object Object]
                      rpi2.0
                      	2024-12-26 16:37:20.945	debug	SETSTATE FOR rpi2.0.memory.memory_total VALUE = 8052.33
                      rpi2.0
                      	2024-12-26 16:37:20.945	debug	VALUE: 8245584 POST: $1/1024
                      rpi2.0
                      	2024-12-26 16:37:20.945	debug	---> POST: $1/1024 for memory_total in [object Object]
                      rpi2.0
                      	2024-12-26 16:37:20.944	debug	-1
                      rpi2.0
                      	2024-12-26 16:37:20.944	debug	CURRENT = memory true
                      rpi2.0
                      	2024-12-26 16:37:20.898	debug	SETSTATE FOR rpi2.0.raspberry.mem_gpu VALUE = 4
                      rpi2.0
                      	2024-12-26 16:37:20.897	debug	---> POST: for mem_gpu in [object Object]
                      rpi2.0
                      	2024-12-26 16:37:20.852	debug	SETSTATE FOR rpi2.0.raspberry.mem_arm VALUE = 1020
                      rpi2.0
                      	2024-12-26 16:37:20.852	debug	---> POST: for mem_arm in [object Object]
                      rpi2.0
                      	2024-12-26 16:37:20.805	debug	SETSTATE FOR rpi2.0.raspberry.cpu_voltage VALUE = 0.77
                      rpi2.0
                      	2024-12-26 16:37:20.804	debug	---> POST: for cpu_voltage in [object Object]
                      rpi2.0
                      	2024-12-26 16:37:20.804	debug	-1
                      rpi2.0
                      	2024-12-26 16:37:20.804	debug	CURRENT = raspberry true
                      rpi2.0
                      	2024-12-26 16:37:20.756	debug	SETSTATE FOR rpi2.0.cpu.scaling_governor VALUE = ondemand
                      rpi2.0
                      	2024-12-26 16:37:20.756	debug	---> POST: for scaling_governor in [object Object]
                      rpi2.0
                      	2024-12-26 16:37:20.712	debug	SETSTATE FOR rpi2.0.cpu.load15 VALUE = 0.21
                      rpi2.0
                      	2024-12-26 16:37:20.712	debug	NAME: load15 VALUE: 0.21
                      rpi2.0
                      	2024-12-26 16:37:20.712	debug	MATCHING: 0.21
                      rpi2.0
                      	2024-12-26 16:37:20.666	debug	SETSTATE FOR rpi2.0.cpu.load5 VALUE = 0.31
                      rpi2.0
                      	2024-12-26 16:37:20.665	debug	NAME: load5 VALUE: 0.31
                      rpi2.0
                      	2024-12-26 16:37:20.665	debug	MATCHING: 0.31
                      rpi2.0
                      	2024-12-26 16:37:20.620	debug	SETSTATE FOR rpi2.0.cpu.load1 VALUE = 0.48
                      rpi2.0
                      	2024-12-26 16:37:20.620	debug	NAME: load1 VALUE: 0.48
                      rpi2.0
                      	2024-12-26 16:37:20.620	debug	MATCHING: 0.48
                      rpi2.0
                      	2024-12-26 16:37:20.620	debug	---> POST: for load1,load5,load15 in [object Object]
                      rpi2.0
                      	2024-12-26 16:37:20.560	debug	SETSTATE FOR rpi2.0.cpu.cpu_frequency VALUE = 1600
                      rpi2.0
                      	2024-12-26 16:37:20.560	debug	VALUE: 1600000 POST: $1/1000
                      rpi2.0
                      	2024-12-26 16:37:20.560	debug	---> POST: $1/1000 for cpu_frequency in [object Object]
                      rpi2.0
                      	2024-12-26 16:37:20.560	debug	-1
                      rpi2.0
                      	2024-12-26 16:37:20.560	debug	CURRENT = cpu true
                      rpi2.0
                      	2024-12-26 16:37:20.560	debug	PARSING: wlan
                      rpi2.0
                      	2024-12-26 16:37:20.560	debug	PARSING: uptime
                      rpi2.0
                      	2024-12-26 16:37:20.559	debug	PARSING: temperature
                      rpi2.0
                      	2024-12-26 16:37:20.559	debug	PARSING: swap
                      rpi2.0
                      	2024-12-26 16:37:20.559	debug	PARSING: sdcard
                      rpi2.0
                      	2024-12-26 16:37:20.559	debug	---> POST:
                      rpi2.0
                      	2024-12-26 16:37:20.559	debug	GROUPS: 2
                      rpi2.0
                      	2024-12-26 16:37:20.559	debug	---> REGEXP: /(.*)/
                      rpi2.0
                      	2024-12-26 16:37:20.558	debug	------------- 37315299695
                      rpi2.0
                      	2024-12-26 16:37:20.556	debug	---> cat /sys/class/net/e*/statistics/tx_bytes
                      rpi2.0
                      	2024-12-26 16:37:20.556	debug	PARSING: net_send
                      rpi2.0
                      	2024-12-26 16:37:20.556	debug	---> POST: $1*-1
                      rpi2.0
                      	2024-12-26 16:37:20.555	debug	GROUPS: 2
                      rpi2.0
                      	2024-12-26 16:37:20.555	debug	---> REGEXP: /(.*)/
                      rpi2.0
                      	2024-12-26 16:37:20.555	debug	------------- 32564790012
                      rpi2.0
                      	2024-12-26 16:37:20.552	debug	---> cat /sys/class/net/e*/statistics/rx_bytes
                      rpi2.0
                      	2024-12-26 16:37:20.552	debug	PARSING: net_received
                      rpi2.0
                      	2024-12-26 16:37:20.552	debug	PARSING: network
                      rpi2.0
                      	2024-12-26 16:37:20.552	debug	---> POST: $1/1024
                      rpi2.0
                      	2024-12-26 16:37:20.552	debug	GROUPS: 2
                      rpi2.0
                      	2024-12-26 16:37:20.552	debug	---> REGEXP: /MemAvailable:\s+(\d+)/m
                      rpi2.0
                      	2024-12-26 16:37:20.551	debug	------------- MemTotal: 8245584 kB MemFree: 1138400 kB MemAvailable: 5248688 kB Buffers: 216192 kB Cached: 3800864 kB SwapCached: 208 kB Active: 3254944 kB Inactive: 3335408 kB Active(anon): 2575088 kB Inactive(anon): 0 kB Active(file): 679856 kB Inactive(file): 3335408 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 204784 kB SwapFree: 191472 kB Zswap: 0 kB Zswapped: 0 kB Dirty: 544 kB Writeback: 0 kB AnonPages: 2573280 kB Mapped: 240144 kB Shmem: 1792 kB KReclaimable: 259760 kB Slab: 306864 kB SReclaimable: 259760 kB SUnreclaim: 47104 kB KernelStack: 7760 kB PageTables: 145904 kB SecPageTables: 0 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 4327568 kB Committed_AS: 3961776 kB VmallocTotal: 68180246528 kB VmallocUsed: 19824 kB VmallocChunk: 0 kB Percpu: 1280 kB CmaTotal: 327680 kB CmaFree: 259904 kB
                      rpi2.0
                      	2024-12-26 16:37:20.549	debug	---> cat /proc/meminfo
                      rpi2.0
                      	2024-12-26 16:37:20.548	debug	PARSING: memory_available
                      rpi2.0
                      	2024-12-26 16:37:20.548	debug	---> POST: $1/1024
                      rpi2.0
                      	2024-12-26 16:37:20.548	debug	GROUPS: 2
                      rpi2.0
                      	2024-12-26 16:37:20.548	debug	---> REGEXP: /MemFree:\s+(\d+)/
                      rpi2.0
                      	2024-12-26 16:37:20.547	debug	------------- MemTotal: 8245584 kB MemFree: 1139120 kB MemAvailable: 5249408 kB Buffers: 216192 kB Cached: 3800864 kB SwapCached: 208 kB Active: 3254352 kB Inactive: 3335408 kB Active(anon): 2574496 kB Inactive(anon): 0 kB Active(file): 679856 kB Inactive(file): 3335408 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 204784 kB SwapFree: 191472 kB Zswap: 0 kB Zswapped: 0 kB Dirty: 544 kB Writeback: 0 kB AnonPages: 2572688 kB Mapped: 240144 kB Shmem: 1792 kB KReclaimable: 259760 kB Slab: 306864 kB SReclaimable: 259760 kB SUnreclaim: 47104 kB KernelStack: 7712 kB PageTables: 145904 kB SecPageTables: 0 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 4327568 kB Committed_AS: 3961776 kB VmallocTotal: 68180246528 kB VmallocUsed: 19792 kB VmallocChunk: 0 kB Percpu: 1280 kB CmaTotal: 327680 kB CmaFree: 259904 kB
                      rpi2.0
                      	2024-12-26 16:37:20.545	debug	---> cat /proc/meminfo
                      rpi2.0
                      	2024-12-26 16:37:20.545	debug	PARSING: memory_free
                      rpi2.0
                      	2024-12-26 16:37:20.545	debug	---> POST: $1/1024
                      rpi2.0
                      	2024-12-26 16:37:20.545	debug	GROUPS: 2
                      rpi2.0
                      	2024-12-26 16:37:20.544	debug	---> REGEXP: /MemTotal:\s+(\d+)/
                      rpi2.0
                      	2024-12-26 16:37:20.544	debug	------------- MemTotal: 8245584 kB MemFree: 1139120 kB MemAvailable: 5249408 kB Buffers: 216192 kB Cached: 3800864 kB SwapCached: 208 kB Active: 3254352 kB Inactive: 3335408 kB Active(anon): 2574496 kB Inactive(anon): 0 kB Active(file): 679856 kB Inactive(file): 3335408 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 204784 kB SwapFree: 191472 kB Zswap: 0 kB Zswapped: 0 kB Dirty: 544 kB Writeback: 0 kB AnonPages: 2572688 kB Mapped: 240144 kB Shmem: 1792 kB KReclaimable: 259760 kB Slab: 306864 kB SReclaimable: 259760 kB SUnreclaim: 47104 kB KernelStack: 7712 kB PageTables: 145312 kB SecPageTables: 0 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 4327568 kB Committed_AS: 3961776 kB VmallocTotal: 68180246528 kB VmallocUsed: 19792 kB VmallocChunk: 0 kB Percpu: 1280 kB CmaTotal: 327680 kB CmaFree: 259904 kB
                      rpi2.0
                      	2024-12-26 16:37:20.541	debug	---> cat /proc/meminfo
                      rpi2.0
                      	2024-12-26 16:37:20.541	debug	PARSING: memory_total
                      rpi2.0
                      	2024-12-26 16:37:20.540	debug	PARSING: memory
                      rpi2.0
                      	2024-12-26 16:37:20.540	debug	---> POST:
                      rpi2.0
                      	2024-12-26 16:37:20.540	debug	GROUPS: 2
                      rpi2.0
                      	2024-12-26 16:37:20.540	debug	---> REGEXP: /(\d+)/
                      rpi2.0
                      	2024-12-26 16:37:20.539	debug	------------- gpu=4M
                      rpi2.0
                      	2024-12-26 16:37:20.535	debug	---> vcgencmd get_mem gpu
                      rpi2.0
                      	2024-12-26 16:37:20.535	debug	PARSING: mem_gpu
                      rpi2.0
                      	2024-12-26 16:37:20.535	debug	---> POST:
                      rpi2.0
                      	2024-12-26 16:37:20.535	debug	GROUPS: 2
                      rpi2.0
                      	2024-12-26 16:37:20.535	debug	---> REGEXP: /(\d+)/
                      rpi2.0
                      	2024-12-26 16:37:20.535	debug	------------- arm=1020M
                      rpi2.0
                      	2024-12-26 16:37:20.531	debug	---> vcgencmd get_mem arm
                      rpi2.0
                      	2024-12-26 16:37:20.531	debug	PARSING: mem_arm
                      rpi2.0
                      	2024-12-26 16:37:20.531	debug	---> POST:
                      rpi2.0
                      	2024-12-26 16:37:20.531	debug	GROUPS: 2
                      rpi2.0
                      	2024-12-26 16:37:20.530	debug	---> REGEXP: /(\d+.\d+)V/
                      rpi2.0
                      	2024-12-26 16:37:20.530	debug	------------- volt=0.7659V
                      rpi2.0
                      	2024-12-26 16:37:20.526	debug	---> vcgencmd measure_volts core
                      rpi2.0
                      	2024-12-26 16:37:20.526	debug	PARSING: cpu_voltage
                      rpi2.0
                      	2024-12-26 16:37:20.526	debug	PARSING: raspberry
                      rpi2.0
                      	2024-12-26 16:37:20.526	debug	---> POST:
                      rpi2.0
                      	2024-12-26 16:37:20.526	debug	GROUPS: 2
                      rpi2.0
                      	2024-12-26 16:37:20.526	debug	---> REGEXP: /(.*)/
                      rpi2.0
                      	2024-12-26 16:37:20.525	debug	------------- ondemand
                      rpi2.0
                      	2024-12-26 16:37:20.522	debug	---> cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
                      rpi2.0
                      	2024-12-26 16:37:20.522	debug	PARSING: scaling_governor
                      rpi2.0
                      	2024-12-26 16:37:20.522	debug	NAME: load15, VALULE: 0.21
                      rpi2.0
                      	2024-12-26 16:37:20.522	debug	MATCHING: 0.21
                      rpi2.0
                      	2024-12-26 16:37:20.522	debug	NAME: load5, VALULE: 0.31
                      rpi2.0
                      	2024-12-26 16:37:20.522	debug	MATCHING: 0.31
                      rpi2.0
                      	2024-12-26 16:37:20.522	debug	NAME: load1, VALULE: 0.48
                      rpi2.0
                      	2024-12-26 16:37:20.521	debug	MATCHING: 0.48
                      rpi2.0
                      	2024-12-26 16:37:20.521	debug	GROUPS: 4
                      rpi2.0
                      	2024-12-26 16:37:20.521	debug	---> REGEXP: /^(\S+)\s(\S+)\s(\S+)/
                      rpi2.0
                      	2024-12-26 16:37:20.521	debug	------------- 0.48 0.31 0.21 1/480 1339934
                      rpi2.0
                      	2024-12-26 16:37:20.518	debug	---> cat /proc/loadavg
                      rpi2.0
                      	2024-12-26 16:37:20.518	debug	PARSING: load1,load5,load15
                      rpi2.0
                      	2024-12-26 16:37:20.518	debug	---> POST: $1/1000
                      rpi2.0
                      	2024-12-26 16:37:20.518	debug	GROUPS: 2
                      rpi2.0
                      	2024-12-26 16:37:20.518	debug	---> REGEXP: /(.*)/
                      rpi2.0
                      	2024-12-26 16:37:20.517	debug	------------- 1600000
                      rpi2.0
                      	2024-12-26 16:37:20.515	debug	---> test -r /sys/devices/system/cpu/cpufreq/policy0/cpuinfo_cur_freq && cat /sys/devices/system/cpu/cpufreq/policy0/cpuinfo_cur_freq || test -r /sys/devices/system/cpu/cpufreq/policy0/scaling_cur_freq && cat /sys/devices/system/cpu/cpufreq/policy0/scaling_cur_freq || echo -1000
                      rpi2.0
                      	2024-12-26 16:37:20.515	debug	PARSING: cpu_frequency
                      rpi2.0
                      	2024-12-26 16:37:20.514	debug	PARSING: cpu
                      rpi2.0
                      	2024-12-26 16:37:20.514	debug	start parsing
                      rpi2.0
                      	2024-12-26 16:36:21.272	debug	GPIO chip undefined initialized
                      rpi2.0
                      	2024-12-26 16:36:21.272	debug	Got chip: undefined
                      rpi2.0
                      	2024-12-26 16:36:21.271	warn	If the library is installed and npm list | grep opengpio shows the npm library is also installed, please report this issue to the adapter developer with the model of your device and deboug output from an adapter start.
                      rpi2.0
                      	2024-12-26 16:36:21.271	warn	Please make sure that libgpiod-dev (on raspian/debian run sudo apt install libgpiod-dev) is installed in the system and then reinstall the adapter.
                      rpi2.0
                      	2024-12-26 16:36:21.271	warn	Cannot initialize GPIO: No chip found. GPIO functionality disabled!
                      rpi2.0
                      	2024-12-26 16:36:21.271	debug	Using GPIO chip 4 for Raspberry Pi 5 or newer.
                      rpi2.0
                      	2024-12-26 16:36:21.271	debug	Got 5 from Raspberry Pi 5 Model B Rev 1.0
                      Z GarfonsoG 2 Antworten Letzte Antwort
                      • S searcher57
                        @searcher57
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        Z
                        Z
                        Zimbl
                        #295
                        ich würde mich gerne auch an diesem Thema anschließen, ich habe genau das gleiche Problem, ich kann
                        diese GPIO nicht ansteuern, wenn ich das Probiere, dann wird der Ausgang bzw. in dem Fall True/False rot.
                        Den Adapter habe ich bereits einmal De-Installiert und dann wieder Installiert.
                        Aber immer noch alles ohne Erfolg.
                        Anbei mein Diag :
                        ```bash
                        Script v.2024-10-19
                        *** BASE SYSTEM ***
                         Static hostname: raspihome
                               Icon name: computer
                                  Kernel: Linux 6.6.62+rpt-rpi-2712
                            Architecture: arm64
                        OS is similar to:
                        Model           : Raspberry Pi 5 Model B Rev 1.0
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : 64 bit
                        Systemuptime and Load:
                         10:47:05 up 7 min,  2 users,  load average: 1.06, 0.49, 0.25
                        CPU threads: 4
                        *** LIFE CYCLE STATUS ***
                        Operating System is the current Debian stable version codenamed 'bookworm'!
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** TIME AND TIMEZONES ***
                                       Local time: Sat 2024-12-28 10:47:05 CET
                                   Universal time: Sat 2024-12-28 09:47:05 UTC
                                         RTC time: Sat 2024-12-28 09:47:05
                                      NTP service: active
                                  RTC in local TZ: no
                        *** Users and Groups ***
                        User that called 'iob diag':
                        pi
                        HOME=/home/pi
                        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
                        iobroker
                        HOME=/home/iobroker
                        *** DISPLAY-SERVER SETUP ***
                        Display-Server: false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            4.2G        1.4G        2.0G        5.8M        998M        2.9G
                        Swap:           202M          0B        202M
                        Total:          4.4G        1.4G        2.2G
                        Active iob-Instances:   7
                                 4045 M total memory
                                 1300 M used memory
                                 1327 M active memory
                                  629 M inactive memory
                                 1862 M free memory
                                   69 M buffer memory
                                  883 M swap cache
                                  192 M total swap
                                    0 M used swap
                                  192 M free swap
                        top - 10:47:05 up 7 min,  2 users,  load average: 1.06, 0.49, 0.25
                        Tasks: 175 total,   1 running, 174 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   4045.0 total,   1862.7 free,   1300.6 used,    952.3 buff/cache
                        MiB Swap:    193.0 total,    193.0 free,      0.0 used.   2744.4 avail Mem
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** DMESG CRITICAL ERRORS ***
                        No critical errors detected
                        *** FILESYSTEM ***
                        udev           devtmpfs  2.0G     0  2.0G   0% /dev
                        tmpfs          tmpfs     405M  5.4M  400M   2% /run
                        /dev/mmcblk0p2 ext4      6.9G  6.3G  182M  98% /
                        tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                        tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                        /dev/mmcblk0p1 vfat      510M   65M  446M  13% /boot/firmware
                        tmpfs          tmpfs     405M   16K  405M   1% /run/user/1000
                        [Sat Dec 28 10:39:15 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:97:18:01 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=918bb801-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=GB cfg80211.ieee80211_regdom=GB
                        [Sat Dec 28 10:39:17 2024] EXT4-fs (mmcblk0p2): mounted filesystem 3b445224-0aeb-4897-9108-009ed4211fb4 ro with ordered data mode. Quota mode: none.
                        [Sat Dec 28 10:39:19 2024] EXT4-fs (mmcblk0p2): re-mounted 3b445224-0aeb-4897-9108-009ed4211fb4 r/w. Quota mode: none.
                        Show mounted filesystems:
                        TARGET           SOURCE         FSTYPE OPTIONS
                        /                /dev/mmcblk0p2 ext4   rw,noatime
                        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        950M    /var/
                        445M    /var/cache
                        431M    /var/cache/apt
                        317M    /var/cache/apt/archives
                        185M    /var/lib
                        Archived and active journals take up 120.5M in the file system.
                        /opt/iobroker/backups:
                        18M     /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        856M    /opt/iobroker/iobroker-data/
                        772M    /opt/iobroker/iobroker-data/files
                        617M    /opt/iobroker/iobroker-data/files/javascript.admin
                        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                        37M     /opt/iobroker/iobroker-data/objects.jsonl
                        25M     /opt/iobroker/iobroker-data/files/wireless-settings.admin/static/js/main.fe851d24.js.map
                        24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                        12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                        11M     /opt/iobroker/iobroker-data/files/wireless-settings.admin/static/js/main.fe851d24.js
                        USB-Devices by-id:
                        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ceccc8e6cbc9eb119edf8b4f1d69213e-if00-port0
                        HINT:
                        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                        /dev/ttyUSB0
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v20.18.1
                        /usr/bin/node           v20.18.1
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        /usr/bin/corepack       0.29.4
                        nodejs:
                          Installed: 20.18.1-1nodesource1
                          Candidate: 20.18.1-1nodesource1
                          Version table:
                         *** 20.18.1-1nodesource1 1001
                                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                             20.18.0-1nodesource1 1001
                             20.17.0-1nodesource1 1001
                             20.16.0-1nodesource1 1001
                             20.15.1-1nodesource1 1001
                             20.15.0-1nodesource1 1001
                             20.14.0-1nodesource1 1001
                             20.13.1-1nodesource1 1001
                             20.13.0-1nodesource1 1001
                             20.12.2-1nodesource1 1001
                             20.12.1-1nodesource1 1001
                             20.12.0-1nodesource1 1001
                             20.11.1-1nodesource1 1001
                             20.11.0-1nodesource1 1001
                             20.10.0-1nodesource1 1001
                             20.9.0-1nodesource1 1001
                             20.8.1-1nodesource1 1001
                             20.8.0-1nodesource1 1001
                             20.7.0-1nodesource1 1001
                             20.6.1-1nodesource1 1001
                             20.6.0-1nodesource1 1001
                             20.5.1-1nodesource1 1001
                             20.5.0-1nodesource1 1001
                             20.4.0-1nodesource1 1001
                             20.3.1-1nodesource1 1001
                             20.3.0-1nodesource1 1001
                             20.2.0-1nodesource1 1001
                             20.1.0-1nodesource1 1001
                             20.0.0-1nodesource1 1001
                             18.19.0+dfsg-6~deb12u2 500
                                500 http://deb.debian.org/debian bookworm/main arm64 Packages
                             18.19.0+dfsg-6~deb12u1 500
                                500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                        No problems detected
                        Errors in npm tree: 0
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        raspihome        raspihome (version: 6.0.11, hostname: raspihome   , alive, uptime: 31)
                        Core adapters versions
                        js-controller:  6.0.11
                        admin:          7.1.5
                        javascript:     8.8.3
                        nodejs modules from github:     0
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : raspihome                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                        + system.adapter.backitup.0               : backitup              : raspihome                              -  enabled
                          system.adapter.discovery.0              : discovery             : raspihome                              -  enabled
                        + system.adapter.javascript.0             : javascript            : raspihome                              -  enabled
                          system.adapter.modbus.0                 : modbus                : raspihome                              -  enabled
                          system.adapter.rpi2.0                   : rpi2                  : raspihome                              -  enabled
                        + system.adapter.shelly.0                 : shelly                : raspihome                              -  enabled, port: 1882, bind: 0.0.0.0
                          system.adapter.terminal.0               : terminal              : raspihome                              -  enabled, port: 8088, bind: 0.0.0.0 (SSL), run as: admin
                        + system.adapter.tuya.0                   : tuya                  : raspihome                              -  enabled
                          system.adapter.welcome.0                : welcome               : raspihome                              -  enabled, port: 80, bind: 0.0.0.0, run as: admin
                          system.adapter.wireless-settings.0      : wireless-settings     : raspihome                              - disabled
                        + system.adapter.zigbee.0                 : zigbee                : raspihome                              -  enabled, port: /dev/ttyUSB0
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Upgrade policy: none
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "admin"        : 7.1.5    , installed 7.1.5
                        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                        Controller "js-controller": 7.0.6    , installed 6.0.11 [Updatable]
                        Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                        Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
                        Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                        Adapter    "welcome"      : 1.0.2    , installed 1.0.2
                        Adapter    "wireless-settings": 1.0.2, installed 1.0.2
                        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                        Objects and States
                        Objects:        815
                        States:         616
                        Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                        Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                        Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6337       760/sshd: /usr/sbin
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19159      4186/iobroker.js-co
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19164      4186/iobroker.js-co
                        tcp6       0      0 :::80                   :::*                    LISTEN      1001       22054      4711/io.welcome.0
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          6339       760/sshd: /usr/sbin
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19205      4206/io.admin.0
                        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       22139      4757/io.terminal.0
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       22600      4366/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       22601      4366/io.tuya.0
                        udp        0      0 0.0.0.0:38105           0.0.0.0:*                           104        656        604/avahi-daemon: r
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        654        604/avahi-daemon: r
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       20981      4299/io.shelly.0
                        udp6       0      0 :::34920                :::*                                104        657        604/avahi-daemon: r
                        udp6       0      0 fe80::9fc3:98f7:bf5:546 :::*                                0          6430       711/NetworkManager
                        udp6       0      0 fe80::4bfa:4f8a:169:546 :::*                                0          875        711/NetworkManager
                        udp6       0      0 :::5353                 :::*                                104        655        604/avahi-daemon: r
                        • Z Zimbl
                          Anbei mein Diag :
                          ```bash
                          Script v.2024-10-19
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          OS is similar to:
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                          CPU threads: 4
                          Current issues:
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          HOME=/home/pi
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:           202M          0B        202M
                                   4045 M total memory
                                   1300 M used memory
                                   1862 M free memory
                                     69 M buffer memory
                                    883 M swap cache
                                    192 M total swap
                                      0 M used swap
                                    192 M free swap
                          *** FILESYSTEM ***
                          /var:
                          950M    /var/
                          445M    /var/cache
                          431M    /var/cache/apt
                          185M    /var/lib
                          USB-Devices by-id:
                          HINT:
                          /dev/ttyUSB0
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin:          7.1.5
                          javascript:     8.8.3
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        815
                          States:         616
                          Pending Updates: 0
                          Thomas BraunT
                          Thomas BraunT
                          #296
                          @zimbl sagte in Test Adapter rpi2 2.x:
                          Auf Stand bringen.
                          Z 1 Antwort Letzte Antwort
                            Auf Stand bringen.
                            Z
                            Z
                            Zimbl
                            #297
                            oh da habe ich schlechte Erfahrung mit gemacht, diese akt. durchzuführen.
                            Kannst du mir genau sagen, wie ich da am besten vorgehe ?
                            Hatte da mal eine Anleitung aus dem Netz gehabt und alles ging irgendwie schief was schief gehen konnte :-)
                            • Z Zimbl
                              Thomas BraunT
                              Thomas BraunT
                              #298
                              Und ich habe schlechte Erfahrungen mit ungepflegten Kisten gemacht.
                              iob stop
                              iob update
                              iob upgrade self
                              iob start
                              Fertig.
                                iob stop
                                iob update
                                iob upgrade self
                                iob start
                                Fertig.
                                Z
                                Z
                                Zimbl
                                #299
                                nein ich meine damit irgendwelche Anleitungen im Netz zu nehmen, wusste jetzt nicht, das es auch einfach mit dem Standard möglich ist, weil ich hatte den schon durchgeführt...aber hatte der das wohl nicht gemacht...
                                vielen Dank Thomas...
                                • Z Zimbl
                                  Thomas BraunT
                                  Thomas BraunT
                                  #300
                                  @zimbl
                                  'Der' macht das aber nicht ohne Meldungen...
                                  Die 'der' Admin dann liest.
                                    @zimbl
                                    Z
                                    Z
                                    Zimbl
                                    #301
                                    ja aber jetzt habe ich das alles aktualisiert...und es ist aber immer noch so, wenn ich einen GPIO Ansteuern möchte, wird der Befehl TRUE or FALSE ....ROT...nicht Grün...wie sonst...
                                    was kann ich nun noch machen ?
                                    • Z Zimbl
                                      Thomas BraunT
                                      Thomas BraunT
                                      #302
                                      Abwarten.
                                      Und/oder bei GitHub evtl. zum passenden Issue weitere Erkenntnisse beitragen.
                                      • Z
                                        Z
                                        Zimbl
                                        #303
                                        ist es eigentlich möglich einen alten RPI2 Adapter zu installieren ?
                                        • Z Zimbl
                                          Thomas BraunT
                                          Thomas BraunT
                                          #304
                                          @zimbl
                                          Wozu? Der funktioniert ja dann noch weniger als der aktuelle. Der Adapter musste ja genau deswegen angepasst werden, weil der an mehrere Stellen nicht mehr funktionierte.
                                          83.8k
