  4. nach dem Update, geht nichts mehr.....
44 Beiträge 7 Kommentatoren 5.4k Aufrufe 5 Beobachtet
  • Z Zimbl
    ah ok...vielen Dank...
    So hier das Ergebnis :
                            v.2024-12-09 Raspbian+zigbee diag+masking
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v7+
          Architecture: arm
    Kernel:                 armv7l
    Userland:               32 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Display-Server:         false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    internal/modules/cjs/loader.js:781
          throw new ERR_UNKNOWN_BUILTIN_MODULE(filename);
    Error [ERR_UNKNOWN_BUILTIN_MODULE]: No such built-in module: node:timers/promises
        at new NodeError (internal/errors.js:322:7)
        at Function.Module._load (internal/modules/cjs/loader.js:781:13)
        at Module.require (internal/modules/cjs/loader.js:1003:19)
        at require (internal/modules/cjs/helpers.js:107:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/dbConnection.js:34:20)
        at Module._compile (internal/modules/cjs/loader.js:1114:14)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1143:10)
        at Module.load (internal/modules/cjs/loader.js:979:32)
        at Function.Module._load (internal/modules/cjs/loader.js:819:12)
        at Module.require (internal/modules/cjs/loader.js:1003:19) {
      code: 'ERR_UNKNOWN_BUILTIN_MODULE'
    Pending iob updates:    0
    Nodejs-Installation:
    /usr/bin/nodejs         v14.21.3
    /usr/bin/node           v14.21.3
    /usr/bin/npm            6.14.18
    /usr/bin/npx            6.14.18
    /usr/bin/corepack       0.15.1
    Recommended versions are nodejs  and npm
    nodeJS installation is correct
    MEMORY:
    Mem:            921M         57M        248M        0.0K        615M        799M
    Swap:            99M        2.0M         97M
    Total:          1.0G         59M        346M
    Active iob-Instances:   0
    ioBroker Core:          js-controller
                            admin
    ioBroker Status:
    Objects:                0
    States:                 0
    Size of iob-Database:
    9.9M    /opt/iobroker/iobroker-data/objects.jsonl
    200K    /opt/iobroker/iobroker-data/states.jsonl
    1 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    mcm1957M Online
    mcm1957M Online
    mcm1957
    @zimbl said in nach dem Update, geht nichts mehr.....:
    Das ist aber ein Zombie system. Setz ne Staubschutzmaske auf wenn du da ran gehst :-)
    Du erwartest doch nicht wirklich, dass mit node 14 noch irgendwas normal funktioniert.
    Node.js 20 ist derzeitige Empfehlung.
    Dazu muss aber auch das OS passen.
    Und die Anleitung mit der du einen aktuellen js-controller auf das System gequetscht hast vergiss ganz schnell. Mit Boardmitteln hätt dies der js.controller schon geweigert da was anzurühren.
    P.S. node 18 wird von immer mehr Adapterns nicht unterstützt. Auch wenn du dein System mit node 18 hichkriegst solltes du zeitnahe einen Update andenken.
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
    • Z Zimbl
               Icon name: computer
            Architecture: arm
      Kernel:                 armv7l
      Userland:               32 bit
      User-ID:                1000
      MEMORY:
      Swap:            99M        2.0M         97M
                              admin
      ioBroker Status:
      Objects:                0
      States:                 0
      @zimbl sagte in nach dem Update, geht nichts mehr.....:
      Die Langfassung.
      Nachdem du
      iob nodejs-update 20
      ausgeführt hast.
      Z 1 Antwort Letzte Antwort
        Die Langfassung.
        Nachdem du
        ausgeführt hast.
        Z Offline
        Z Offline
        Zimbl
        ok ich führe aus.
        Vielleicht bekomme ich es ja noch hin, das es ein gutes System wird :-)
        • Z Zimbl
          ok ich führe aus.
          Das ist durch die abgehangene Hardware schon ausgeschlossen.
            Z Offline
            Z Offline
            Zimbl
            ok, wenn wir die mal ausklammern. Sagen wir es mal so, das es das beste wird, was man rausholen kann.
            Wenn ich z.b. eine neue Hardware kaufe, kann man dann eigentlich das Backup auch auf diese dann aufspielen ?
            • Z Zimbl
              Ein Backup nur des ioBrokers: Ja
              Ein 'Backup' (Klon) des gesamten Systems: Nein
                Z Offline
                Z Offline
                Zimbl
                also ich würde dann die Normale Installation inkl. IOBroker durchführen und dann die Backups ausführen..
                das würde aber dann funktionieren...
                Aber ein Pi5 mit 4 GB sollten dann aber auch erstmal dem Stand der Technik reichen,
                oder?
                • Z Zimbl
                  oder?
                  @zimbl
                  Ja, dürfte mehr als ausreichend sein für deinen Anwendungsfall.
                  Der Raspberry4 dürfte auch ausreichen.
                  Unter 4GB würde ich allerdings nicht gehen.
                  • Z Offline
                    Z Offline
                    Zimbl
                    ja man weiß ja nie, was da alles noch so kommt...
                    Bin dann eher jemand der nicht irgendwann wieder aufrüsten will...
                    IOB Diag läuft noch..
                    aber muss auch wieder über das Skript laufen, da der normale immer noch nicht läuft...
                    steht dann dort wieder, das ich den Fix durchführen muss, aber auch , nachdem ich
                    den Fix durchgeführt habe..
                    ```bash
                    Script v.2024-12-09 Raspbian+zigbee diag+masking
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm
                    OS is similar to: debian
                    Model           : Raspberry Pi 2 Model B Rev 1.1
                    Docker          : false
                    Virtualization  : none
                    Kernel          : armv7l
                    Userland        : 32 bit
                    Systemuptime and Load:
                     18:14:20 up 12 min,  1 user,  load average: 0.37, 0.31, 0.28
                    CPU threads: 4
                    *** LIFE CYCLE STATUS ***
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    ~ Under-voltage has occurred
                    ~ Arm frequency capping has occurred
                    *** TIME AND TIMEZONES ***
                                   Local time: Tue 2024-12-10 18:14:21 CET
                               Universal time: Tue 2024-12-10 17:14:21 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    *** Users and Groups ***
                    User that called 'iob diag':
                    pi
                    HOME=/home/pi
                    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                    js-controller is not running
                    *** DISPLAY-SERVER SETUP ***
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            921M         59M        435M        0.0K        426M        797M
                    Swap:            99M          0B         99M
                    Total:          1.0G         59M        535M
                    Active iob-Instances:   1
                              921 M total memory
                               60 M used memory
                              241 M active memory
                              150 M inactive memory
                              435 M free memory
                               68 M buffer memory
                              358 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    top - 18:14:21 up 12 min,  1 user,  load average: 0.37, 0.31, 0.28
                    Tasks: 120 total,   1 running, 119 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  2.5 us,  3.8 sy,  0.0 ni, 93.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :    922.0 total,    435.7 free,     60.0 used,    426.4 buff/cache
                    MiB Swap:    100.0 total,    100.0 free,      0.0 used.    797.1 avail Mem
                    *** FAILED SERVICES ***
                      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                    * iobroker.service loaded failed failed ioBroker Server
                    * rc-local.service loaded failed failed /etc/rc.local Compatibility
                    2 loaded units listed.
                    *** DMESG CRITICAL ERRORS ***
                    *** FILESYSTEM ***
                    /dev/root      ext4       59G  6.8G   50G  13% /
                    devtmpfs       devtmpfs  333M     0  333M   0% /dev
                    tmpfs          tmpfs     461M     0  461M   0% /dev/shm
                    tmpfs          tmpfs     185M  940K  184M   1% /run
                    /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
                    tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
                    [Tue Dec 10 18:02:05 2024] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=a13bd72e-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Tue Dec 10 18:02:09 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Tue Dec 10 18:02:09 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                    [Tue Dec 10 18:02:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                    Show mounted filesystems:
                    TARGET  SOURCE         FSTYPE OPTIONS
                    /       /dev/mmcblk0p2 ext4   rw,noatime
                    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,ioc
                    /var:
                    2.2G    /var/
                    1.9G    /var/log/journal/b4db8c2bf1074a1ba2ba6c07d9465d9d
                    1.9G    /var/log
                    123M    /var/cache
                    Archived and active journals take up 1.8G in the file system.
                    /opt/iobroker/backups:
                    94M     /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    804M    /opt/iobroker/iobroker-data/
                    720M    /opt/iobroker/iobroker-data/files
                    617M    /opt/iobroker/iobroker-data/files/javascript.admin
                    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
                    12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                    8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
                    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                    USB-Devices by-id:
                    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ceccc8e6cbc9eb119edf8b4f1d69213e-if00-port0
                    *** ZigBee Settings ***
                    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v20.18.1
                    /usr/bin/node           v20.18.1
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    /usr/bin/corepack       0.29.4
                    nodejs:
                      Installed: 20.18.1-1nodesource1
                      Candidate: 20.18.1-1nodesource1
                      Version table:
                     *** 20.18.1-1nodesource1 600
                            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                         20.18.0-1nodesource1 600
                         20.17.0-1nodesource1 600
                         20.16.0-1nodesource1 600
                         20.15.1-1nodesource1 600
                         20.15.0-1nodesource1 600
                         20.14.0-1nodesource1 600
                         20.13.1-1nodesource1 600
                         20.13.0-1nodesource1 600
                         20.12.2-1nodesource1 600
                         20.12.1-1nodesource1 600
                         20.12.0-1nodesource1 600
                         20.11.1-1nodesource1 600
                         20.11.0-1nodesource1 600
                         20.10.0-1nodesource1 600
                         20.9.0-1nodesource1 600
                         20.8.1-1nodesource1 600
                         20.8.0-1nodesource1 600
                         20.7.0-1nodesource1 600
                         20.6.1-1nodesource1 600
                         20.6.0-1nodesource1 600
                         20.5.1-1nodesource1 600
                         20.5.0-1nodesource1 600
                         20.4.0-1nodesource1 600
                         20.3.1-1nodesource1 600
                         20.3.0-1nodesource1 600
                         20.2.0-1nodesource1 600
                         20.1.0-1nodesource1 600
                         20.0.0-1nodesource1 600
                         12.22.12~dfsg-1~deb11u5 500
                    No problems detected
                    Errors in npm tree: 0
                    *** ioBroker-Installation ***
                    ioBroker Status
                    iobroker is not running on this host.
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    raspberrypi         raspberrypi (version: 5.0.19, hostname: raspberrypi   , alive, uptime: 45)
                    Core adapters versions
                    js-controller:  5.0.19
                    admin:          7.1.5
                    javascript:     8.8.3
                    nodejs modules from github:     0
                    Adapter State
                      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                      system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                      system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                      system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              - disabled
                      system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                      system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
                      system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                      system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                      system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                      system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                      system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ceccc8e6cbc9eb119edf8b4f1d69213e-if00-port0
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): stable
                    Installed ioBroker-Instances
                    Used repository: stable
                    Adapter    "admin"        : 7.1.5    , installed 7.1.5
                    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                    Adapter    "deconz"       : 1.4.1    , installed 1.4.0  [Updatable]
                    Adapter    "discovery"    : 5.0.0    , installed 4.4.0  [Updatable]
                    Adapter    "gruenbeck"    : 0.0.43   , installed 0.0.42 [Updatable]
                    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                    Controller "js-controller": 7.0.3    , installed 5.0.19 [Updatable]
                    Adapter    "modbus"       : 6.3.2    , installed 6.1.0  [Updatable]
                    Adapter    "rpi2"         : 2.2.1    , installed 1.3.2  [Updatable]
                    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                    Adapter    "sonoff"       : 3.1.2    , installed 3.0.3  [Updatable]
                    Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
                    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                    Objects and States
                    Objects:        957
                    States:         570
                    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
                    Reading package lists... Done
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11824      446/sshd: /usr/sbin
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          11826      446/sshd: /usr/sbin
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12579      344/avahi-daemon: r
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          448        571/dhcpcd
                    udp        0      0 0.0.0.0:46688           0.0.0.0:*                           108        12581      344/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                108        12580      344/avahi-daemon: r
                    udp6       0      0 :::58708                :::*                                108        12582      344/avahi-daemon: r
                    udp6       0      0 :::546                  :::*                                0          13728      571/dhcpcd
                    2024-12-10 18:03:09.660  - info: admin.0 (684) terminating
                    2024-12-10 18:03:09.737  - warn: host.raspberrypi instance system.adapter.rpi2.0 terminated due to SIGTERM
                    2024-12-10 18:03:09.739  - info: host.raspberrypi instance system.adapter.rpi2.0 terminated with code null ()
                    2024-12-10 18:03:09.741  - warn: host.raspberrypi instance system.adapter.tuya.0 terminated due to SIGTERM
                    2024-12-10 18:03:09.743  - info: host.raspberrypi instance system.adapter.tuya.0 terminated with code null ()
                    2024-12-10 18:03:09.746  - warn: host.raspberrypi instance system.adapter.zigbee.0 terminated due to SIGTERM
                    2024-12-10 18:03:09.747  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code null ()
                    2024-12-10 18:03:09.827  - warn: admin.0 (684) get state error: Connection is closed.
                    2024-12-10 18:03:09.887  - warn: admin.0 (684) Could not perform strict object check of state admin.0.info.updatesJson: DB closed
                    2024-12-10 18:03:09.890  - warn: admin.0 (684) get state error: Connection is closed.
                    2024-12-10 18:03:09.895  - warn: admin.0 (684) Cannot check common objects: DB closed
                    2024-12-10 18:03:10.266  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                    2024-12-10 18:03:10.270  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                    2024-12-10 18:03:10.273  - info: host.raspberrypi instance system.adapter.modbus.0 terminated with code 0 (NO_ERROR)
                    2024-12-10 18:03:10.376  - info: host.raspberrypi instance system.adapter.ping.0 started with pid 817
                    2024-12-10 18:03:10.408  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                    2024-12-10 18:03:17.864  - info: ping.0 (817) starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.ping, node: v20.18.1, js-controller: 5.0.19
                    2024-12-10 18:03:17.941  - warn: ping.0 (817) Poll interval is too short. Reset to 5000 ms.
                    2024-12-10 18:03:21.717  - info: host.raspberrypi force terminating
                    2024-12-10 18:03:21.721  - info: host.raspberrypi Adapter ping still running
                    2024-12-10 18:03:24.399  - info: ping.0 (817) terminating with timeout
                    2024-12-10 18:03:24.407  - info: ping.0 (817) Terminated (NO_ERROR): Without reason
                    2024-12-10 18:03:26.556  - error: ping.0 (817) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                    2024-12-10 18:03:26.832  - warn: ping.0 (817) get state error: Connection is closed.
                    2024-12-10 18:03:26.840  - info: ping.0 (817) terminating
                    iob diag has finished.
                    Press any key for a summary
                    so was sollte ich nun noch durchführen ?
                    • Z Zimbl
                      ```bash
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm
                      Docker          : false
                      Kernel          : armv7l
                      Userland        : 32 bit
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      HOME=/home/pi
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:            99M          0B         99M
                                921 M total memory
                                 60 M used memory
                                241 M active memory
                                435 M free memory
                                 68 M buffer memory
                                358 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      *** FILESYSTEM ***
                      /var:
                      2.2G    /var/
                      1.9G    /var/log
                      123M    /var/cache
                      USB-Devices by-id:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      admin:          7.1.5
                      javascript:     8.8.3
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        957
                      States:         570
                      Pending Updates: 0
                      @zimbl
                      iob update
                      iob upgrade all -y
                      iob stop
                      iob upgrade self
                      iob start
                      • Z Zimbl
                        ```bash
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm
                        Docker          : false
                        Kernel          : armv7l
                        Userland        : 32 bit
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        HOME=/home/pi
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:            99M          0B         99M
                                  921 M total memory
                                   60 M used memory
                                  241 M active memory
                                  435 M free memory
                                   68 M buffer memory
                                  358 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        *** FILESYSTEM ***
                        /var:
                        2.2G    /var/
                        1.9G    /var/log
                        123M    /var/cache
                        USB-Devices by-id:
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin:          7.1.5
                        javascript:     8.8.3
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        957
                        States:         570
                        Pending Updates: 0
                        Ja, da ist ein 'Bug' drin. Deswegen ja die Testversion, da ist es behoben.
                          Z Offline
                          Z Offline
                          Zimbl
                          ah ok, danke für die Info Thomas...
                          die Updates laufen derzeit, danach führe ich wieder den DIAG aus...
                          • Z Zimbl
                            Z Offline
                            Z Offline
                            Zimbl
                            So ich habe wieder mal ein aktuelles Ergebnis :
                            ```bash
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm
                            Docker          : false
                            Kernel          : armv7l
                            Userland        : 32 bit
                             18:52:41 up 50 min,  1 user,  load average: 1.45, 1.87, 1.47
                            CPU threads: 4
                            Current issues:
                                           Local time: Tue 2024-12-10 18:52:41 CET
                                       Universal time: Tue 2024-12-10 17:52:41 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            HOME=/home/pi
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            921M        517M         75M        0.0K        328M        344M
                            Swap:            99M         92M        7.0M
                            Total:          1.0G        610M         82M
                            Active iob-Instances:   10
                                      921 M total memory
                                      517 M used memory
                                      300 M active memory
                                      466 M inactive memory
                                       74 M free memory
                                       22 M buffer memory
                                      307 M swap cache
                                       99 M total swap
                                       92 M used swap
                                        7 M free swap
                            top - 18:52:43 up 50 min,  1 user,  load average: 1.41, 1.86, 1.47
                            Tasks: 133 total,   1 running, 132 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  2.6 us,  3.9 sy,  0.0 ni, 93.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :    922.0 total,     74.4 free,    518.1 used,    329.4 buff/cache
                            MiB Swap:    100.0 total,      7.3 free,     92.7 used.    343.8 avail Mem
                            1 loaded units listed.
                            *** FILESYSTEM ***
                            /dev/root      ext4       59G  7.0G   49G  13% /
                            tmpfs          tmpfs     185M  944K  184M   1% /run
                            /var:
                            2.2G    /var/
                            1.9G    /var/log
                            123M    /var/cache
                            97M     /opt/iobroker/backups/
                            818M    /opt/iobroker/iobroker-data/
                            722M    /opt/iobroker/iobroker-data/files
                            24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                            21M     /opt/iobroker/iobroker-data/objects.jsonl
                            9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
                            USB-Devices by-id:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            raspberrypi         raspberrypi (version: 7.0.3, hostname: raspberrypi   , alive, uptime: 495)
                            js-controller:  7.0.3
                            admin:          7.1.5
                            javascript:     8.8.3
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                            + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
                            + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                            + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                            + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                            + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                            + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ceccc8e6cbc9eb119edf8b4f1d69213e-if00-port0
                            + instance is alive
                            Upgrade policy: none
                            Adapter    "deconz"       : 1.4.1    , installed 1.4.1
                            Adapter    "gruenbeck"    : 0.0.43   , installed 0.0.43
                            Controller "js-controller": 7.0.3    , installed 7.0.3
                            Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                            Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
                            Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                            Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                            Objects and States
                            Objects:        974
                            States:         665
                            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                            Pending Updates: 0
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       33968      3854/iobroker.js-co
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       33963      3854/iobroker.js-co
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       34103      3872/io.admin.0
                            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       34921      3919/io.tuya.0
                            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       34922      3919/io.tuya.0
                            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       33344      3950/io.shelly.0
                            2024-12-10 18:51:53.743  - info: host.raspberrypi stopInstance system.adapter.rpi2.0 (force=false, process=true)
                            2024-12-10 18:51:53.811  - info: rpi2.0 (5014) Got terminate signal TERMINATE_YOURSELF
                            2024-12-10 18:51:53.828  - info: host.raspberrypi stopInstance system.adapter.rpi2.0 send kill signal
                            2024-12-10 18:51:53.823  - info: rpi2.0 (5014) terminating
                            2024-12-10 18:51:53.830  - info: rpi2.0 (5014) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2024-12-10 18:51:54.454  - info: rpi2.0 (5014) terminating
                            2024-12-10 18:51:54.529  - error: rpi2.0 (5014) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2024-12-10 18:51:54.531  - error: rpi2.0 (5014) unhandled promise rejection: DB closed
                            2024-12-10 18:51:54.540  - error: rpi2.0 (5014) Error: DB closed
                                at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                                at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:2333:37)
                                at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:2374:29)
                                at process.processImmediate (node:internal/timers:485:21)
                            2024-12-10 18:51:54.543  - error: rpi2.0 (5014) DB closed
                            2024-12-10 18:51:54.668  - info: host.raspberrypi instance system.adapter.rpi2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2024-12-10 18:51:59.938  - info: host.raspberrypi instance system.adapter.rpi2.0 in version "2.2.1" started with pid 5085
                            2024-12-10 18:52:07.710  - info: rpi2.0 (5085) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.18.1, js-controller: 7.0.3
                            2024-12-10 18:53:10.144  - info: admin.0 (3872) ==> Connected system.user.admin from ::ffff:192.168.178.82
                            2024-12-10 18:53:11.238  - info: zigbee.0 (3932) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"ceccc8e6cbc9eb119edf8b4f1d69213e","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ceccc8e6cbc9eb119edf8b4f1d69213e-if00-port0","vendorId":"10c4","productId":"ea60"}]
                            2024-12-10 18:53:16.482  - info: admin.0 (3872) <== Disconnect system.user.admin from ::ffff:192.168.178.82
                            2024-12-10 18:53:24.487  - info: admin.0 (3872) ==> Connected system.user.admin from ::ffff:192.168.178.82
                            2024-12-10 18:53:46.635  - info: admin.0 (3872) <== Disconnect system.user.admin from ::ffff:192.168.178.82 javascript
                            2024-12-10 18:53:57.051  - info: admin.0 (3872) ==> Connected system.user.admin from ::ffff:192.168.178.82
                            2024-12-10 18:54:58.672  - warn: backitup.0 (3886) [iobroker/clean] No older backup files are deleted, because this backup was started manually
                            • Z Zimbl
                              ```bash
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm
                              Docker          : false
                              Kernel          : armv7l
                              Userland        : 32 bit
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:            99M         92M        7.0M
                                        921 M total memory
                                        517 M used memory
                                        300 M active memory
                                         74 M free memory
                                         22 M buffer memory
                                        307 M swap cache
                                         99 M total swap
                                         92 M used swap
                                          7 M free swap
                              *** FILESYSTEM ***
                              /var:
                              2.2G    /var/
                              1.9G    /var/log
                              123M    /var/cache
                              USB-Devices by-id:
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin:          7.1.5
                              javascript:     8.8.3
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        974
                              States:         665
                              Pending Updates: 0
                              Schau dir den an.
                              • Z Zimbl
                                ```bash
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm
                                Docker          : false
                                Kernel          : armv7l
                                Userland        : 32 bit
                                CPU threads: 4
                                Current issues:
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                HOME=/home/pi
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:            99M         92M        7.0M
                                          921 M total memory
                                          517 M used memory
                                          300 M active memory
                                           74 M free memory
                                           22 M buffer memory
                                          307 M swap cache
                                           99 M total swap
                                           92 M used swap
                                            7 M free swap
                                *** FILESYSTEM ***
                                /var:
                                2.2G    /var/
                                1.9G    /var/log
                                123M    /var/cache
                                USB-Devices by-id:
                                zigbee.X
                                Extended Pan ID:
                                *** MASKED ***
                                Pan ID:
                                *** MASKED ***
                                Channel:
                                *** MASKED ***
                                Network Key:
                                *** MASKED ***
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                admin:          7.1.5
                                javascript:     8.8.3
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        974
                                States:         665
                                Pending Updates: 0
                                @zimbl
                                Grundsätzlich sollte das Ding jetzt wieder schnurren.
                                  @zimbl
                                  Z Offline
                                  Z Offline
                                  Zimbl
                                  schrieb am zuletzt editiert von Zimbl
                                  Hallo Thomas,
                                  ich habe mir nun einen Pi5 geholt und mit dem PI Imager auch das
                                  Image drauf gemacht, soweit auch alles wie immer Konfiguriert.
                                  Was nur komisch ist, meine ETH0 Schnittstelle funktioniert nicht,
                                  ich stecke das Kabel rein, aber nichts.
                                  Keine Verbindung.
                                  ich meine früher war die immer Standard aktiv.
                                  ist das nun nicht mehr ?
                                  • Z Zimbl
                                    Hallo Thomas,
                                    Keine Verbindung.
                                    @zimbl
                                    Ja, eine Ethernet-Schnittstelle ist i.d.R. aktiv.
                                    schau dir
                                    ip a
                                    und
                                    ifconfig
                                    an.
                                    • Z Zimbl
                                      Hallo Thomas,
                                      Keine Verbindung.
                                      auch keine Aktionen an den LED der Netzwerkbuchse?
                                        Z Offline
                                        Z Offline
                                        Zimbl
                                        Ne überhaupt nichts.
                                        Das komische ist irgendwie auch, das in der dhcpcd.conf auch nichts
                                        drin steht.
                                        Gut aber wenn die nicht aktiv ist, würden ja die LEDs auch
                                        nicht funktionieren..
                                        Mit dem PI Imager habe ich 64-Bit Light installiert...
                                        • Z Zimbl
                                          drin steht.
                                          @zimbl kann ja noch ein Hardwaredefekt sein.
                                          Allerdings hatte ich so einen Effekt mal bei Armbian.
                                          Mit einer Version funktionierte das Netzwerk nicht.
                                          Aber ich glaube nicht dass das hier auch so ist.
                                          drin steht.
                                          ich kann dir gar nicht sagen, welche Konfiguration im aktuellen OS verwendet wird.
                                          Gibts da nicht auch was in raspi-config?
