  4. nach dem Update, geht nichts mehr.....
44 Beiträge 7 Kommentatoren 5.4k Aufrufe 5 Beobachtet
    @zimbl
    Alle drei Zeilen eingeben / einkopieren. Nicht nur herunterladen.
    Also
    curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
    chmod 744 iob_diag.sh
    ./iob_diag.sh
    Z Offline
    Z Offline
    Zimbl
    ah ok...vielen Dank...
    So hier das Ergebnis :
                            v.2024-12-09 Raspbian+zigbee diag+masking
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v7+
          Architecture: arm
    Kernel:                 armv7l
    Userland:               32 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Display-Server:         false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    internal/modules/cjs/loader.js:781
          throw new ERR_UNKNOWN_BUILTIN_MODULE(filename);
    Error [ERR_UNKNOWN_BUILTIN_MODULE]: No such built-in module: node:timers/promises
        at new NodeError (internal/errors.js:322:7)
        at Function.Module._load (internal/modules/cjs/loader.js:781:13)
        at Module.require (internal/modules/cjs/loader.js:1003:19)
        at require (internal/modules/cjs/helpers.js:107:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/dbConnection.js:34:20)
        at Module._compile (internal/modules/cjs/loader.js:1114:14)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1143:10)
        at Module.load (internal/modules/cjs/loader.js:979:32)
        at Function.Module._load (internal/modules/cjs/loader.js:819:12)
        at Module.require (internal/modules/cjs/loader.js:1003:19) {
      code: 'ERR_UNKNOWN_BUILTIN_MODULE'
    Pending iob updates:    0
    Nodejs-Installation:
    /usr/bin/nodejs         v14.21.3
    /usr/bin/node           v14.21.3
    /usr/bin/npm            6.14.18
    /usr/bin/npx            6.14.18
    /usr/bin/corepack       0.15.1
    Recommended versions are nodejs  and npm
    nodeJS installation is correct
    MEMORY:
    Mem:            921M         57M        248M        0.0K        615M        799M
    Swap:            99M        2.0M         97M
    Total:          1.0G         59M        346M
    Active iob-Instances:   0
    ioBroker Core:          js-controller
                            admin
    ioBroker Status:
    Objects:                0
    States:                 0
    Size of iob-Database:
    9.9M    /opt/iobroker/iobroker-data/objects.jsonl
    200K    /opt/iobroker/iobroker-data/states.jsonl
    1 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    mcm1957M Thomas BraunT 2 Antworten Letzte Antwort
    • Z Offline
      Z Offline
      Zimbl
      so ich habe das nun mal wieder ausgeführt und er versucht nun wieder zu starten...
      curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -
      sudo apt-get install -y nodejs
      • Z Zimbl
                 Icon name: computer
              Architecture: arm
        Kernel:                 armv7l
        Userland:               32 bit
        User-ID:                1000
        MEMORY:
        Swap:            99M        2.0M         97M
                                admin
        ioBroker Status:
        Objects:                0
        States:                 0
        mcm1957M Online
        mcm1957M Online
        mcm1957
        @zimbl said in nach dem Update, geht nichts mehr.....:
        Das ist aber ein Zombie system. Setz ne Staubschutzmaske auf wenn du da ran gehst :-)
        Du erwartest doch nicht wirklich, dass mit node 14 noch irgendwas normal funktioniert.
        Node.js 20 ist derzeitige Empfehlung.
        Dazu muss aber auch das OS passen.
        Und die Anleitung mit der du einen aktuellen js-controller auf das System gequetscht hast vergiss ganz schnell. Mit Boardmitteln hätt dies der js.controller schon geweigert da was anzurühren.
        P.S. node 18 wird von immer mehr Adapterns nicht unterstützt. Auch wenn du dein System mit node 18 hichkriegst solltes du zeitnahe einen Update andenken.
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        • Z Zimbl
                   Icon name: computer
                Architecture: arm
          Kernel:                 armv7l
          Userland:               32 bit
          User-ID:                1000
          MEMORY:
          Swap:            99M        2.0M         97M
                                  admin
          ioBroker Status:
          Objects:                0
          States:                 0
          @zimbl sagte in nach dem Update, geht nichts mehr.....:
          Die Langfassung.
          Nachdem du
          iob nodejs-update 20
          ausgeführt hast.
          Z 1 Antwort Letzte Antwort
            Die Langfassung.
            Nachdem du
            ausgeführt hast.
            Z Offline
            Z Offline
            Zimbl
            ok ich führe aus.
            Vielleicht bekomme ich es ja noch hin, das es ein gutes System wird :-)
            • Z Zimbl
              ok ich führe aus.
              Das ist durch die abgehangene Hardware schon ausgeschlossen.
                Z Offline
                Z Offline
                Zimbl
                ok, wenn wir die mal ausklammern. Sagen wir es mal so, das es das beste wird, was man rausholen kann.
                Wenn ich z.b. eine neue Hardware kaufe, kann man dann eigentlich das Backup auch auf diese dann aufspielen ?
                • Z Zimbl
                  Ein Backup nur des ioBrokers: Ja
                  Ein 'Backup' (Klon) des gesamten Systems: Nein
                    Z Offline
                    Z Offline
                    Zimbl
                    also ich würde dann die Normale Installation inkl. IOBroker durchführen und dann die Backups ausführen..
                    das würde aber dann funktionieren...
                    Aber ein Pi5 mit 4 GB sollten dann aber auch erstmal dem Stand der Technik reichen,
                    oder?
                    • Z Zimbl
                      oder?
                      @zimbl
                      Ja, dürfte mehr als ausreichend sein für deinen Anwendungsfall.
                      Der Raspberry4 dürfte auch ausreichen.
                      Unter 4GB würde ich allerdings nicht gehen.
                      • Z Offline
                        Z Offline
                        Zimbl
                        ja man weiß ja nie, was da alles noch so kommt...
                        Bin dann eher jemand der nicht irgendwann wieder aufrüsten will...
                        IOB Diag läuft noch..
                        aber muss auch wieder über das Skript laufen, da der normale immer noch nicht läuft...
                        steht dann dort wieder, das ich den Fix durchführen muss, aber auch , nachdem ich
                        den Fix durchgeführt habe..
                        ```bash
                        Script v.2024-12-09 Raspbian+zigbee diag+masking
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm
                        OS is similar to: debian
                        Model           : Raspberry Pi 2 Model B Rev 1.1
                        Docker          : false
                        Virtualization  : none
                        Kernel          : armv7l
                        Userland        : 32 bit
                        Systemuptime and Load:
                         18:14:20 up 12 min,  1 user,  load average: 0.37, 0.31, 0.28
                        CPU threads: 4
                        *** LIFE CYCLE STATUS ***
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        ~ Under-voltage has occurred
                        ~ Arm frequency capping has occurred
                        *** TIME AND TIMEZONES ***
                                       Local time: Tue 2024-12-10 18:14:21 CET
                                   Universal time: Tue 2024-12-10 17:14:21 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** Users and Groups ***
                        User that called 'iob diag':
                        pi
                        HOME=/home/pi
                        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                        js-controller is not running
                        *** DISPLAY-SERVER SETUP ***
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            921M         59M        435M        0.0K        426M        797M
                        Swap:            99M          0B         99M
                        Total:          1.0G         59M        535M
                        Active iob-Instances:   1
                                  921 M total memory
                                   60 M used memory
                                  241 M active memory
                                  150 M inactive memory
                                  435 M free memory
                                   68 M buffer memory
                                  358 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        top - 18:14:21 up 12 min,  1 user,  load average: 0.37, 0.31, 0.28
                        Tasks: 120 total,   1 running, 119 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  2.5 us,  3.8 sy,  0.0 ni, 93.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :    922.0 total,    435.7 free,     60.0 used,    426.4 buff/cache
                        MiB Swap:    100.0 total,    100.0 free,      0.0 used.    797.1 avail Mem
                        *** FAILED SERVICES ***
                          UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                        * iobroker.service loaded failed failed ioBroker Server
                        * rc-local.service loaded failed failed /etc/rc.local Compatibility
                        2 loaded units listed.
                        *** DMESG CRITICAL ERRORS ***
                        *** FILESYSTEM ***
                        /dev/root      ext4       59G  6.8G   50G  13% /
                        devtmpfs       devtmpfs  333M     0  333M   0% /dev
                        tmpfs          tmpfs     461M     0  461M   0% /dev/shm
                        tmpfs          tmpfs     185M  940K  184M   1% /run
                        /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
                        tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
                        [Tue Dec 10 18:02:05 2024] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=a13bd72e-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Tue Dec 10 18:02:09 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Tue Dec 10 18:02:09 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Tue Dec 10 18:02:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                        Show mounted filesystems:
                        TARGET  SOURCE         FSTYPE OPTIONS
                        /       /dev/mmcblk0p2 ext4   rw,noatime
                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,ioc
                        /var:
                        2.2G    /var/
                        1.9G    /var/log/journal/b4db8c2bf1074a1ba2ba6c07d9465d9d
                        1.9G    /var/log
                        123M    /var/cache
                        Archived and active journals take up 1.8G in the file system.
                        /opt/iobroker/backups:
                        94M     /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        804M    /opt/iobroker/iobroker-data/
                        720M    /opt/iobroker/iobroker-data/files
                        617M    /opt/iobroker/iobroker-data/files/javascript.admin
                        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                        22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
                        12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                        8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
                        8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                        USB-Devices by-id:
                        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ceccc8e6cbc9eb119edf8b4f1d69213e-if00-port0
                        *** ZigBee Settings ***
                        Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v20.18.1
                        /usr/bin/node           v20.18.1
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        /usr/bin/corepack       0.29.4
                        nodejs:
                          Installed: 20.18.1-1nodesource1
                          Candidate: 20.18.1-1nodesource1
                          Version table:
                         *** 20.18.1-1nodesource1 600
                                500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                             20.18.0-1nodesource1 600
                             20.17.0-1nodesource1 600
                             20.16.0-1nodesource1 600
                             20.15.1-1nodesource1 600
                             20.15.0-1nodesource1 600
                             20.14.0-1nodesource1 600
                             20.13.1-1nodesource1 600
                             20.13.0-1nodesource1 600
                             20.12.2-1nodesource1 600
                             20.12.1-1nodesource1 600
                             20.12.0-1nodesource1 600
                             20.11.1-1nodesource1 600
                             20.11.0-1nodesource1 600
                             20.10.0-1nodesource1 600
                             20.9.0-1nodesource1 600
                             20.8.1-1nodesource1 600
                             20.8.0-1nodesource1 600
                             20.7.0-1nodesource1 600
                             20.6.1-1nodesource1 600
                             20.6.0-1nodesource1 600
                             20.5.1-1nodesource1 600
                             20.5.0-1nodesource1 600
                             20.4.0-1nodesource1 600
                             20.3.1-1nodesource1 600
                             20.3.0-1nodesource1 600
                             20.2.0-1nodesource1 600
                             20.1.0-1nodesource1 600
                             20.0.0-1nodesource1 600
                             12.22.12~dfsg-1~deb11u5 500
                        No problems detected
                        Errors in npm tree: 0
                        *** ioBroker-Installation ***
                        ioBroker Status
                        iobroker is not running on this host.
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        raspberrypi         raspberrypi (version: 5.0.19, hostname: raspberrypi   , alive, uptime: 45)
                        Core adapters versions
                        js-controller:  5.0.19
                        admin:          7.1.5
                        javascript:     8.8.3
                        nodejs modules from github:     0
                        Adapter State
                          system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                          system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                          system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                          system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              - disabled
                          system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                          system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
                          system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                          system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                          system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                          system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                          system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ceccc8e6cbc9eb119edf8b4f1d69213e-if00-port0
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "admin"        : 7.1.5    , installed 7.1.5
                        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                        Adapter    "deconz"       : 1.4.1    , installed 1.4.0  [Updatable]
                        Adapter    "discovery"    : 5.0.0    , installed 4.4.0  [Updatable]
                        Adapter    "gruenbeck"    : 0.0.43   , installed 0.0.42 [Updatable]
                        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                        Controller "js-controller": 7.0.3    , installed 5.0.19 [Updatable]
                        Adapter    "modbus"       : 6.3.2    , installed 6.1.0  [Updatable]
                        Adapter    "rpi2"         : 2.2.1    , installed 1.3.2  [Updatable]
                        Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                        Adapter    "sonoff"       : 3.1.2    , installed 3.0.3  [Updatable]
                        Adapter    "tuya"         : 3.16.0   , installed 3.15.0 [Updatable]
                        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                        Objects and States
                        Objects:        957
                        States:         570
                        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Reading package lists... Done
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11824      446/sshd: /usr/sbin
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          11826      446/sshd: /usr/sbin
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12579      344/avahi-daemon: r
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          448        571/dhcpcd
                        udp        0      0 0.0.0.0:46688           0.0.0.0:*                           108        12581      344/avahi-daemon: r
                        udp6       0      0 :::5353                 :::*                                108        12580      344/avahi-daemon: r
                        udp6       0      0 :::58708                :::*                                108        12582      344/avahi-daemon: r
                        udp6       0      0 :::546                  :::*                                0          13728      571/dhcpcd
                        2024-12-10 18:03:09.660  - info: admin.0 (684) terminating
                        2024-12-10 18:03:09.737  - warn: host.raspberrypi instance system.adapter.rpi2.0 terminated due to SIGTERM
                        2024-12-10 18:03:09.739  - info: host.raspberrypi instance system.adapter.rpi2.0 terminated with code null ()
                        2024-12-10 18:03:09.741  - warn: host.raspberrypi instance system.adapter.tuya.0 terminated due to SIGTERM
                        2024-12-10 18:03:09.743  - info: host.raspberrypi instance system.adapter.tuya.0 terminated with code null ()
                        2024-12-10 18:03:09.746  - warn: host.raspberrypi instance system.adapter.zigbee.0 terminated due to SIGTERM
                        2024-12-10 18:03:09.747  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code null ()
                        2024-12-10 18:03:09.827  - warn: admin.0 (684) get state error: Connection is closed.
                        2024-12-10 18:03:09.887  - warn: admin.0 (684) Could not perform strict object check of state admin.0.info.updatesJson: DB closed
                        2024-12-10 18:03:09.890  - warn: admin.0 (684) get state error: Connection is closed.
                        2024-12-10 18:03:09.895  - warn: admin.0 (684) Cannot check common objects: DB closed
                        2024-12-10 18:03:10.266  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                        2024-12-10 18:03:10.270  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                        2024-12-10 18:03:10.273  - info: host.raspberrypi instance system.adapter.modbus.0 terminated with code 0 (NO_ERROR)
                        2024-12-10 18:03:10.376  - info: host.raspberrypi instance system.adapter.ping.0 started with pid 817
                        2024-12-10 18:03:10.408  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                        2024-12-10 18:03:17.864  - info: ping.0 (817) starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.ping, node: v20.18.1, js-controller: 5.0.19
                        2024-12-10 18:03:17.941  - warn: ping.0 (817) Poll interval is too short. Reset to 5000 ms.
                        2024-12-10 18:03:21.717  - info: host.raspberrypi force terminating
                        2024-12-10 18:03:21.721  - info: host.raspberrypi Adapter ping still running
                        2024-12-10 18:03:24.399  - info: ping.0 (817) terminating with timeout
                        2024-12-10 18:03:24.407  - info: ping.0 (817) Terminated (NO_ERROR): Without reason
                        2024-12-10 18:03:26.556  - error: ping.0 (817) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2024-12-10 18:03:26.832  - warn: ping.0 (817) get state error: Connection is closed.
                        2024-12-10 18:03:26.840  - info: ping.0 (817) terminating
                        iob diag has finished.
                        Press any key for a summary
                        so was sollte ich nun noch durchführen ?
                        • Z Zimbl
                          ```bash
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm
                          Docker          : false
                          Kernel          : armv7l
                          Userland        : 32 bit
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          HOME=/home/pi
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            99M          0B         99M
                                    921 M total memory
                                     60 M used memory
                                    241 M active memory
                                    435 M free memory
                                     68 M buffer memory
                                    358 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          *** FILESYSTEM ***
                          /var:
                          2.2G    /var/
                          1.9G    /var/log
                          123M    /var/cache
                          USB-Devices by-id:
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin:          7.1.5
                          javascript:     8.8.3
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        957
                          States:         570
                          Pending Updates: 0
                          @zimbl
                          iob update
                          iob upgrade all -y
                          iob stop
                          iob upgrade self
                          iob start
                          • Z Zimbl
                            ```bash
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm
                            Docker          : false
                            Kernel          : armv7l
                            Userland        : 32 bit
                            CPU threads: 4
                            Current issues:
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            HOME=/home/pi
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:            99M          0B         99M
                                      921 M total memory
                                       60 M used memory
                                      241 M active memory
                                      435 M free memory
                                       68 M buffer memory
                                      358 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            *** FILESYSTEM ***
                            /var:
                            2.2G    /var/
                            1.9G    /var/log
                            123M    /var/cache
                            USB-Devices by-id:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin:          7.1.5
                            javascript:     8.8.3
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        957
                            States:         570
                            Pending Updates: 0
                            Ja, da ist ein 'Bug' drin. Deswegen ja die Testversion, da ist es behoben.
                              Z Offline
                              Z Offline
                              Zimbl
                              ah ok, danke für die Info Thomas...
                              die Updates laufen derzeit, danach führe ich wieder den DIAG aus...
                              • Z Zimbl
                                Z Offline
                                Z Offline
                                Zimbl
                                So ich habe wieder mal ein aktuelles Ergebnis :
                                ```bash
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm
                                Docker          : false
                                Kernel          : armv7l
                                Userland        : 32 bit
                                 18:52:41 up 50 min,  1 user,  load average: 1.45, 1.87, 1.47
                                CPU threads: 4
                                Current issues:
                                               Local time: Tue 2024-12-10 18:52:41 CET
                                           Universal time: Tue 2024-12-10 17:52:41 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                HOME=/home/pi
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            921M        517M         75M        0.0K        328M        344M
                                Swap:            99M         92M        7.0M
                                Total:          1.0G        610M         82M
                                Active iob-Instances:   10
                                          921 M total memory
                                          517 M used memory
                                          300 M active memory
                                          466 M inactive memory
                                           74 M free memory
                                           22 M buffer memory
                                          307 M swap cache
                                           99 M total swap
                                           92 M used swap
                                            7 M free swap
                                top - 18:52:43 up 50 min,  1 user,  load average: 1.41, 1.86, 1.47
                                Tasks: 133 total,   1 running, 132 sleeping,   0 stopped,   0 zombie
                                %Cpu(s):  2.6 us,  3.9 sy,  0.0 ni, 93.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :    922.0 total,     74.4 free,    518.1 used,    329.4 buff/cache
                                MiB Swap:    100.0 total,      7.3 free,     92.7 used.    343.8 avail Mem
                                1 loaded units listed.
                                *** FILESYSTEM ***
                                /dev/root      ext4       59G  7.0G   49G  13% /
                                tmpfs          tmpfs     185M  944K  184M   1% /run
                                /var:
                                2.2G    /var/
                                1.9G    /var/log
                                123M    /var/cache
                                97M     /opt/iobroker/backups/
                                818M    /opt/iobroker/iobroker-data/
                                722M    /opt/iobroker/iobroker-data/files
                                24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                                21M     /opt/iobroker/iobroker-data/objects.jsonl
                                9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
                                USB-Devices by-id:
                                zigbee.X
                                Extended Pan ID:
                                *** MASKED ***
                                Pan ID:
                                *** MASKED ***
                                Channel:
                                *** MASKED ***
                                Network Key:
                                *** MASKED ***
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                raspberrypi         raspberrypi (version: 7.0.3, hostname: raspberrypi   , alive, uptime: 495)
                                js-controller:  7.0.3
                                admin:          7.1.5
                                javascript:     8.8.3
                                Adapter State
                                + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
                                + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                                + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                                + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                                + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ceccc8e6cbc9eb119edf8b4f1d69213e-if00-port0
                                + instance is alive
                                Upgrade policy: none
                                Adapter    "deconz"       : 1.4.1    , installed 1.4.1
                                Adapter    "gruenbeck"    : 0.0.43   , installed 0.0.43
                                Controller "js-controller": 7.0.3    , installed 7.0.3
                                Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                                Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
                                Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                                Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                Objects and States
                                Objects:        974
                                States:         665
                                Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                Pending Updates: 0
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       33968      3854/iobroker.js-co
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       33963      3854/iobroker.js-co
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       34103      3872/io.admin.0
                                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       34921      3919/io.tuya.0
                                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       34922      3919/io.tuya.0
                                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       33344      3950/io.shelly.0
                                2024-12-10 18:51:53.743  - info: host.raspberrypi stopInstance system.adapter.rpi2.0 (force=false, process=true)
                                2024-12-10 18:51:53.811  - info: rpi2.0 (5014) Got terminate signal TERMINATE_YOURSELF
                                2024-12-10 18:51:53.828  - info: host.raspberrypi stopInstance system.adapter.rpi2.0 send kill signal
                                2024-12-10 18:51:53.823  - info: rpi2.0 (5014) terminating
                                2024-12-10 18:51:53.830  - info: rpi2.0 (5014) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2024-12-10 18:51:54.454  - info: rpi2.0 (5014) terminating
                                2024-12-10 18:51:54.529  - error: rpi2.0 (5014) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2024-12-10 18:51:54.531  - error: rpi2.0 (5014) unhandled promise rejection: DB closed
                                2024-12-10 18:51:54.540  - error: rpi2.0 (5014) Error: DB closed
                                    at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                    at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                                    at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:2333:37)
                                    at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:2374:29)
                                    at process.processImmediate (node:internal/timers:485:21)
                                2024-12-10 18:51:54.543  - error: rpi2.0 (5014) DB closed
                                2024-12-10 18:51:54.668  - info: host.raspberrypi instance system.adapter.rpi2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-12-10 18:51:59.938  - info: host.raspberrypi instance system.adapter.rpi2.0 in version "2.2.1" started with pid 5085
                                2024-12-10 18:52:07.710  - info: rpi2.0 (5085) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.18.1, js-controller: 7.0.3
                                2024-12-10 18:53:10.144  - info: admin.0 (3872) ==> Connected system.user.admin from ::ffff:192.168.178.82
                                2024-12-10 18:53:11.238  - info: zigbee.0 (3932) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"ceccc8e6cbc9eb119edf8b4f1d69213e","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ceccc8e6cbc9eb119edf8b4f1d69213e-if00-port0","vendorId":"10c4","productId":"ea60"}]
                                2024-12-10 18:53:16.482  - info: admin.0 (3872) <== Disconnect system.user.admin from ::ffff:192.168.178.82
                                2024-12-10 18:53:24.487  - info: admin.0 (3872) ==> Connected system.user.admin from ::ffff:192.168.178.82
                                2024-12-10 18:53:46.635  - info: admin.0 (3872) <== Disconnect system.user.admin from ::ffff:192.168.178.82 javascript
                                2024-12-10 18:53:57.051  - info: admin.0 (3872) ==> Connected system.user.admin from ::ffff:192.168.178.82
                                2024-12-10 18:54:58.672  - warn: backitup.0 (3886) [iobroker/clean] No older backup files are deleted, because this backup was started manually
                                • Z Zimbl
                                  ```bash
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm
                                  Docker          : false
                                  Kernel          : armv7l
                                  Userland        : 32 bit
                                  CPU threads: 4
                                  Current issues:
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  HOME=/home/pi
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:            99M         92M        7.0M
                                            921 M total memory
                                            517 M used memory
                                            300 M active memory
                                             74 M free memory
                                             22 M buffer memory
                                            307 M swap cache
                                             99 M total swap
                                             92 M used swap
                                              7 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  2.2G    /var/
                                  1.9G    /var/log
                                  123M    /var/cache
                                  USB-Devices by-id:
                                  zigbee.X
                                  Extended Pan ID:
                                  *** MASKED ***
                                  Pan ID:
                                  *** MASKED ***
                                  Channel:
                                  *** MASKED ***
                                  Network Key:
                                  *** MASKED ***
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  admin:          7.1.5
                                  javascript:     8.8.3
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        974
                                  States:         665
                                  Pending Updates: 0
                                  Schau dir den an.
                                  • Z Zimbl
                                    ```bash
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm
                                    Docker          : false
                                    Kernel          : armv7l
                                    Userland        : 32 bit
                                    CPU threads: 4
                                    Current issues:
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    HOME=/home/pi
                                    iobroker
                                    HOME=/home/iobroker
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:            99M         92M        7.0M
                                              921 M total memory
                                              517 M used memory
                                              300 M active memory
                                               74 M free memory
                                               22 M buffer memory
                                              307 M swap cache
                                               99 M total swap
                                               92 M used swap
                                                7 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    2.2G    /var/
                                    1.9G    /var/log
                                    123M    /var/cache
                                    USB-Devices by-id:
                                    zigbee.X
                                    Extended Pan ID:
                                    *** MASKED ***
                                    Pan ID:
                                    *** MASKED ***
                                    Channel:
                                    *** MASKED ***
                                    Network Key:
                                    *** MASKED ***
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    admin:          7.1.5
                                    javascript:     8.8.3
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        974
                                    States:         665
                                    Pending Updates: 0
                                    @zimbl
                                    Grundsätzlich sollte das Ding jetzt wieder schnurren.
                                      @zimbl
                                      Z Offline
                                      Z Offline
                                      Zimbl
                                      schrieb am zuletzt editiert von Zimbl
                                      Hallo Thomas,
                                      ich habe mir nun einen Pi5 geholt und mit dem PI Imager auch das
                                      Image drauf gemacht, soweit auch alles wie immer Konfiguriert.
                                      Was nur komisch ist, meine ETH0 Schnittstelle funktioniert nicht,
                                      ich stecke das Kabel rein, aber nichts.
                                      Keine Verbindung.
                                      ich meine früher war die immer Standard aktiv.
                                      ist das nun nicht mehr ?
                                      • Z Zimbl
                                        Hallo Thomas,
                                        Keine Verbindung.
                                        @zimbl
                                        Ja, eine Ethernet-Schnittstelle ist i.d.R. aktiv.
                                        schau dir
                                        ip a
                                        und
                                        ifconfig
                                        an.
                                        • Z Zimbl
                                          Hallo Thomas,
                                          Keine Verbindung.
                                          auch keine Aktionen an den LED der Netzwerkbuchse?
